REG710NA-2.5/3K
REG710NA-2.5/3K
    ROCHESTER(罗切斯特)
    SOT23-6
    SWITCHED CAPACITOR CONVERTER
REG710NA-2.5/3K 数据手册
Sample & Buy Product Folder Support & Community Tools & Software Technical Documents Reference Design REG71050, REG71055, REG710 SBAS221H – DECEMBER 2001 – REVISED OCTOBER 2015 REG710xx Buck-Boost Charge Pump with up to 60-mA Output Current 1 Features 3 Description • • • • • The REG710 family of devices are switched capacitor voltage converters that generate regulated, low-ripple output voltage from an unregulated input voltage. A wide input supply voltage from 1.8 V to 5.5 V makes the REG710 family of devices ideal for a variety of battery sources, such as single-cell Li-Ion, or 2-cell and 3-cell nickel-based or alkaline-based chemistries. 1 • • • • Wide Input Voltage Range: 1.8 V to 5.5 V Automatic Step-Up and Step-Down Operation Low Input Current Ripple Low Output Voltage Ripple Minimum Number of External Components—No Inductors 1-MHz Internal Oscillator Allows Small Capacitors Shutdown Mode Thermal and Current Limit Protection Six Fixed Output Voltages Available: – 2.5 V, 2.7 V, 3 V, 3.3 V, 5 V, 5.5 V 2 Applications • • • • • • • • White LED Driver Smart Card Readers SIM Cards Handheld devices Modems PCMCIA Cards LCD Displays Battery Backup Supplies The input voltage may vary above and below the output voltage and the output remains in regulation. The device works as step-up or step-down converters without the need of an inductor, providing low EMI DC-DC conversion. The high switching frequency allows the use of small surface-mount capacitors, saving board space and reducing cost. The REG710 device is thermally protected and current limited, protecting the load and the regulator during fault conditions. Typical ground pin current (quiescent current) is 65 μA with no load, and less than 1 μA in shutdown mode. Device Information(1) PART NUMBER REG710 REG71050 REG71055 PACKAGE BODY SIZE (NOM) SOT-23 (6) 2.90 mm × 1.60 mm SOT (6) 2.90 mm × 1.60 mm SON (6) 2.00 mm × 2.00 mm SOT-23 (6) 2.90 mm × 1.60 mm (1) For all available packages, see the orderable addendum at the end of the data sheet. spacing Typical Operating Circuit Efficiency vs Load Current CPUMP 0.22mF 90 VIN = 2.7V VIN 3 1 5 CIN 2.2mF 80 6 REG710 2 GND VOUT COUT 2.2mF Efficiency (%) Enable 4 VIN = 3V VIN = 3.3V 70 VIN = 3.6V 60 VIN = 4.2V 50 VIN = VOUT 40 30 0.1 1 10 Load Current (mA) 100 1 An IMPORTANT NOTICE at the end of this data sheet addresses availability, warranty, changes, use in safety-critical applications, intellectual property matters and other important disclaimers. PRODUCTION DATA. REG71050, REG71055, REG710 SBAS221H – DECEMBER 2001 – REVISED OCTOBER 2015 www.ti.com Table of Contents 1 2 3 4 5 6 7 8 Features .................................................................. Applications ........................................................... Description ............................................................. Revision History..................................................... Device Comparison Table..................................... Pin Configuration and Functions ......................... Specifications......................................................... 1 1 1 2 3 3 3 7.1 7.2 7.3 7.4 7.5 7.6 3 4 4 4 4 6 Absolute Maximum Ratings ...................................... ESD Ratings.............................................................. Recommended Operating Conditions....................... Thermal Information .................................................. Electrical Characteristics........................................... Typical Characteristics .............................................. Detailed Description .............................................. 7 8.1 Overview ................................................................... 7 8.2 Functional Block Diagram ......................................... 8 8.3 Feature Description................................................... 8 8.4 Device Functional Modes.......................................... 8 9 Application and Implementation ........................ 10 9.1 Application Information............................................ 10 9.2 Typical Applications ................................................ 10 9.3 System Examples ................................................... 14 10 Power Supply Recommendations ..................... 17 11 Layout................................................................... 17 11.1 Layout Guidelines ................................................. 17 11.2 Layout Example .................................................... 17 12 Device and Documentation Support ................. 18 12.1 12.2 12.3 12.4 12.5 12.6 Device Support...................................................... Related Links ........................................................ Community Resources.......................................... Trademarks ........................................................... Electrostatic Discharge Caution ............................ Glossary ................................................................ 18 18 18 18 18 18 13 Mechanical, Packaging, and Orderable Information ........................................................... 18 4 Revision History NOTE: Page numbers for previous revisions may differ from page numbers in the current version. Changes from Revision G (January 2009) to Revision H • 2 Page Added ESD Ratings table, Feature Description section, Device Functional Modes, Application and Implementation section, Power Supply Recommendations section, Layout section, Device and Documentation Support section, and Mechanical, Packaging, and Orderable Information section ................................................................................................. 1 Submit Documentation Feedback Copyright © 2001–2015, Texas Instruments Incorporated Product Folder Links: REG71050 REG71055 REG710 REG71050, REG71055, REG710 www.ti.com SBAS221H – DECEMBER 2001 – REVISED OCTOBER 2015 5 Device Comparison Table ORDER NUMBER OUTPUT VOLTAGE REG71055 5.5 V REG710NA-5 5V REG71050 REG710NA-3.3 3.3 V REG710NA-3 3V REG710NA-2.7 2.7 V REG710NA-2.5 2.5 V 6 Pin Configuration and Functions DDC and DBV Package 6-Pin SOT and SOT-23 Top View VOUT 1 6 CPUMP+ GND 2 5 VIN Enable 3 4 CPUMP- DRV Package 6-Pin SON With Exposed Thermal Pad Top View CPUMP+ VIN CPUMP- 1 Exposed 6 2 Thermal 5 Pad 3 4 VOUT Enable GND Pin Functions PIN I/O DESCRIPTION NAME DDC/DBV DRV Cpump- 4 3 – Connect to the flying capacitor Cpump+ 6 1 – Connect to the flying capacitor Enable 3 5 I Hardware Enable/Disable pin (high=enable) GND 2 4 – Ground Vin 5 2 I Input supply pin. Connect the input capacitor to this pin. Vout 1 6 O Output supply. Connect the output capacitor to this pin. 7 Specifications 7.1 Absolute Maximum Ratings over operating free-air temperature range (unless otherwise noted) MIN MAX VIN Supply voltage –0.3 6 Enable Enable input –0.3 Output short-circuit duration VIN Operating ambient temperature –55 125 TJ Operating ambient temperature –55 150 Tstg Storage temperature –55 150 Product Folder Links: REG71050 REG71055 REG710 V Indefinite TA Copyright © 2001–2015, Texas Instruments Incorporated UNIT Submit Documentation Feedback °C 3 REG71050, REG71055, REG710 SBAS221H – DECEMBER 2001 – REVISED OCTOBER 2015 www.ti.com 7.2 ESD Ratings VALUE V(ESD) (1) (2) Electrostatic discharge Human body model (HBM), per ANSI/ESDA/JEDEC JS-001 (1) ±2000 Charged device model (CDM), per JEDEC specification JESD22C101 (2) ±500 UNIT V JEDEC document JEP155 states that 500-V HBM allows safe manufacturing with a standard ESD control process. JEDEC document JEP157 states that 250-V CDM allows safe manufacturing with a standard ESD control process. 7.3 Recommended Operating Conditions over operating free-air temperature range (unless otherwise noted) MIN NOM MAX UNIT INPUT VOLTAGE Tested Startup (1) TA (1) REG71055 3 5.5 V REG710-5 2.7 5.5 V All other models 1.8 5.5 V Operating ambient temperature range –40 85 °C See conditions under Output Voltage with a resistive load no lower than typical VOUT/IOUT in Electrical Characteristics. 7.4 Thermal Information REG710 THERMAL METRIC (1) DRV DDC DBV 6 PINS 6 PINS 6 PINS UNIT RθJA Junction-to-ambient thermal resistance 119.1 204.6 184.4 °C/W RθJC(top) Junction-to-case (top) thermal resistance 110.5 50.5 124.6 °C/W RθJB Junction-to-board thermal resistance 88.7 54.3 30.6 °C/W ψJT Junction-to-top characterization parameter 7.7 0.8 22.1 °C/W ψJB Junction-to-board characterization parameter 89 52.8 30.1 °C/W RθJC(bot) Junction-to-case (bottom) thermal resistance 61.8 n/a n/a °C/W (1) For more information about traditional and new thermal metrics, see the Semiconductor and IC Package Thermal Metrics application report, SPRA953. 7.5 Electrical Characteristics TA = -40ºC to 85ºC, typical values are at TA = 25°C (unless otherwise noted), VIN = (VOUT / 2 + 0.75 V), IOUT = 10 mA, CIN = COUT = 2.2 μF, CPUMP = 0.22 μF, and VENABLE = 1.3 V, unless otherwise noted. PARAMETER TEST CONDITIONS MIN TYP MAX UNIT SUPPLY VIN Input voltage range. Tested Startup. REG71055 REG710-5 See conditions under Output Voltage with a resistive load no lower than typical VOUT/IOUT. All other models IQ ISD Operating quiescent current IOUT = 0 mA, TA = 25°C Shutdown current VIN = 1.8 V to 5.5 V, Enable = 0 V, TA = 25°C 3 5.5 2.7 5.5 1.8 5.5 V 65 100 μA 0.01 1 μA V CONTROL SIGNALS (ENABLE) Logic high input voltage VIN = 1.8 V to 5.5 V 1.3 VIN Logic low input voltage VIN = 1.8 V to 5.5 V –0.2 0.4 V Logic high input current VIN = 1.8 V to 5.5 V, TA = 25°C 100 nA Logic low input current VIN = 1.8 V to 5.5 V, TA = 25°C 100 OSCILLATOR FREQUENCY (1) (1) 4 1 nA MHz The converter regulates by enabling and disabling periods of switching cycles. The switching frequency is the oscillator frequency during an active period. Submit Documentation Feedback Copyright © 2001–2015, Texas Instruments Incorporated Product Folder Links: REG71050 REG71055 REG710 REG71050, REG71055, REG710 www.ti.com SBAS221H – DECEMBER 2001 – REVISED OCTOBER 2015 Electrical Characteristics (continued) TA = -40ºC to 85ºC, typical values are at TA = 25°C (unless otherwise noted), VIN = (VOUT / 2 + 0.75 V), IOUT = 10 mA, CIN = COUT = 2.2 μF, CPUMP = 0.22 μF, and VENABLE = 1.3 V, unless otherwise noted. PARAMETER TEST CONDITIONS MIN TYP MAX UNIT IOUT ≤ 10 mA, 3 V ≤ VIN ≤ 5.5 V 5.2 5.5 5.8 V IOUT ≤ 30 mA, 3.25 V ≤ VIN ≤ 5.5 V 5.2 5.5 5.8 V IOUT ≤ 10 mA, 2.7 V ≤ VIN ≤ 5.5 V 4.7 5 5.3 V IOUT ≤ 30 mA, 3 V ≤ VIN ≤ 5.5 V 4.7 5 5.3 V IOUT ≤ 60 mA, 3.3 V ≤ VIN ≤ 4.2 V 4.6 5 5.4 V IOUT ≤ 10 mA, 1.8 V ≤ VIN ≤ 5.5 V 3.1 3.3 3.5 V IOUT ≤ 30 mA, 2.2 V ≤ VIN ≤ 5.5 V 3.1 3.3 3.5 V IOUT ≤ 10 mA, 1.8 V ≤ VIN ≤ 5.5 V 2.82 3 3.18 V IOUT ≤ 30 mA, 2.2 V ≤ VIN ≤ 5.5 V 2.82 3 3.18 V IOUT ≤ 10 mA, 1.8 V ≤ VIN ≤ 5.5 V 2.54 2.7 2.86 V IOUT ≤ 30 mA, 2 V ≤ VIN ≤ 5.5 V 2.54 2.7 2.86 V IOUT ≤ 10 mA, 1.8 V ≤ VIN ≤ 5.5 V 2.35 2.5 2.65 V IOUT ≤ 30 mA, 2 V ≤ VIN ≤ 5.5 V 2.35 2.5 2.65 OUTPUT REG71055 REG710-5, REG71050 REG710-3.3 REG710-3 REG710-2.7 REG710-2.5 Iout Nominal output current TA = 25°C Isc Short circuit output current TA = 25°C RIPPLE VOLTAGE (2) IOUT = 30 mA, TA = 25°C IOUT = 10 mA, VIN = 1.8 V, REG7103.3, TA = 25°C EFFICIENCY (3) V 30 mA 100 mA 35 mVPP 90% THERMAL SHUTDOWN (2) (3) Shutdown temperature 160 °C Shutdown recovery 140 °C Effective series resistance (ESR) of capacitors is < 0.1 Ω. See efficiency curves for other VIN/VOUT configurations. Copyright © 2001–2015, Texas Instruments Incorporated Product Folder Links: REG71050 REG71055 REG710 Submit Documentation Feedback 5 REG71050, REG71055, REG710 SBAS221H – DECEMBER 2001 – REVISED OCTOBER 2015 www.ti.com 7.6 Typical Characteristics At TA = 25°C, VIN = (VOUT / 2 + 0.75 V), IOUT = 5 mA, CIN = COUT = 2.2 μF, CPUMP = 0.22 μF, and VENABLE = 1.3 V, unless otherwise noted. 100 20 18 16 Supply Current (nA) Supply Current (mA) 80 60 40 20 14 12 10 8 6 4 2 0 -40 -30 -20 -10 0 0 -40 -30 -20 -10 0 10 20 30 40 50 60 70 80 90 Temperature (°C) No load Not enabled Figure 1. Supply Current vs Temperature Figure 2. Supply Current vs Temperature 0.2 25 0.1 Percentage of Units (%) Output Voltage Change (%) 10 20 30 40 50 60 70 80 90 Temperature (°C) 0.0 -0.1 -0.2 -0.3 -0.4 20 15 10 5 > 100 < 100 < 52 < 76 < 28 140 3.2 V REG710-2.7 > 3.4 V REG710-3 > 3.7 V REG710-3.3 > 4.0 V REG710-5, REG71050, REG71055 Step-up only Table 1 lists the approximate values of the input voltage at which the device changes internal operating mode. See efficiency curves in Typical Characteristics for various loads and input voltages. Copyright © 2001–2015, Texas Instruments Incorporated Product Folder Links: REG71050 REG71055 REG710 Submit Documentation Feedback 9 REG71050, REG71055, REG710 SBAS221H – DECEMBER 2001 – REVISED OCTOBER 2015 www.ti.com 9 Application and Implementation NOTE Information in the following applications sections is not part of the TI component specification, and TI does not warrant its accuracy or completeness. TI’s customers are responsible for determining suitability of components for their purposes. Customers should validate and test their design implementation to confirm system functionality. 9.1 Application Information The REG710 is a switched capacitor voltage converter that produces a regulated, low-ripple output voltage from an unregulated input voltage range from 1.8 V to 5.5 V. The high switching frequency allows the use of small surface-mount capacitors. The following section gives guidance to choose external components to complete the power supply design. Application curves are included for the typical application shown below. 9.2 Typical Applications CPUMP 0.22mF Enable VIN 3 4 6 1 5 CIN 2.2mF REG710 VOUT COUT 2.2mF 2 GND Figure 7. Typical Operating Circuit 9.2.1 Design Requirements The REG710 family of switched capacitor voltage converters offers a variety of regulated fixed output voltages. This family supports unregulated input voltages which can have values that are lower or higher than the regulated output voltage. Only input and output capacitors as well as a pump capacitor are required to have a fully functional converter. The following design procedure is adequate for the whole VIN, VOUT and load current range of REG710. 9.2.2 Detailed Design Procedure 9.2.2.1 Capacitor Selection For minimum output voltage ripple, the output capacitor COUT should be a ceramic, surface-mount type. Tantalum capacitors generally have a higher effective series resistance (ESR) and may contribute to higher output voltage ripple. Leaded capacitors also increase ripple due to the higher inductance of the package itself. To achieve best operation with low input voltage and high load current, the input and pump capacitors (CIN and CPUMP, respectively) should also be surface-mount ceramic types. In all cases, X7R or X5R dielectric are recommended. See the typical operating circuit shown in Figure 7 for component values. With light loads or higher input voltage, a smaller 0.1-μF pump capacitor (CPUMP) and smaller 1-μF input and output capacitors (CIN and COUT, respectively) can be used. To minimize output voltage ripple, increase the output capacitor, COUT, to 10 μF or larger. The capacitors listed in Table 2 can be used with the REG710. This table is only a representative list of compatible parts. 10 Submit Documentation Feedback Copyright © 2001–2015, Texas Instruments Incorporated Product Folder Links: REG71050 REG71055 REG710 REG71050, REG71055, REG710 www.ti.com SBAS221H – DECEMBER 2001 – REVISED OCTOBER 2015 Table 2. Suggested Capacitors MANUFACTURER Panasonic Taiyo Yuden RATED WORKING VOLTAGE 10 V VALUE TOLERANCE C1206C255K8RAC 2.2 μF ±10% X7R 1206 C1206C224K8RAC 0.22 μF ±10% X7R 1206 10 V ECJ−2YBOJ225K 2.2 μF ±10% X5R 805 6.3 V ECJ−2VBIC224K 0.22 μF ±10% X7R 805 16 V ECJ−2VBIC104 0.1 μF ±10% X7R 805 16 V EMK316BJ225KL 2.2 μF ±10% X7R 1206 16 V TKM316BJ224KF 0.22 μF ±10% X7R 1206 25 V PART NUMBER Kemet PACKAGE SIZE DIELECTRIC MATERIAL 9.2.3 Application Curves 90 90 REG710-5, REG71050 REG71055 VIN = 2.7V 80 80 VIN = 3V 70 Efficiency (%) Efficiency (%) REG710-3.3 REG710-3 60 50 40 REG710-2.5 REG710-2.7 30 1.5 2.0 70 VIN = 3.6V 60 VIN = 4.2V 50 VIN = VOUT 40 2.5 3.0 3.5 VIN (V) 4.0 4.5 5.0 30 0.1 5.5 1 10 Load Current (mA) 100 REG710-5V, REG71050 Figure 8. Efficiency vs VIN Figure 9. Efficiency vs Load Current 90 90 VIN = 1.8V 70 80 Efficiency (%) 80 Efficiency (%) VIN = 3.3V VIN = 2.2V 60 50 VIN = 1.8V 70 VIN = 2.2V 60 50 VIN = VOUT VIN = VOUT 40 40 30 0.1 1 10 Load Current (mA) REG710-3.3V 100 30 0.1 1 10 Load Current (mA) 100 REG710-3.3V Figure 10. Efficiency vs Load Current Figure 11. Efficiency vs Load Current Copyright © 2001–2015, Texas Instruments Incorporated Product Folder Links: REG71050 REG71055 REG710 Submit Documentation Feedback 11 REG71050, REG71055, REG710 SBAS221H – DECEMBER 2001 – REVISED OCTOBER 2015 80 80 75 75 70 70 VIN = 1.8V 65 60 Efficiency (%) Efficiency (%) www.ti.com VIN = 2.2V 55 50 45 VIN = 1.8V 60 55 VIN = 2.2V 50 45 VIN = VOUT 40 65 VIN = VOUT 40 35 35 30 0.1 1 10 Load Current (mA) 30 0.1 100 REG710-2.7V 1 10 Load Current (mA) 100 REG710-2.5 Figure 12. Efficiency vs Load Current Figure 13. Efficiency vs Load Current REG710-3.3V RL = 110W 20mV/div VOUT 4.5V 3.5V 2V/div Buck Mode VIN Boost Mode 50mV/div 10mA/div VOUT ILOAD BW = 20MHz BW = 20MHz Time (50ms/div) Time (10ms/div) Figure 14. Load Transient Response Figure 15. Line Transient Response 90 REG710-2.7 COUT = 2.2mF 80 Output Ripple (mVPP) COUT = 2.2mF 20mV/div COUT = 10mF, CPUMP = 1mF 20mV/div REG710-3.3V VIN = 2.4V RL = 332W BW = 20MHz Time (5ms/div) 70 60 50 REG710-3.3 COUT = 2.2mF 40 30 REG710-2.7 COUT = 10mF 20 REG710-3.3 COUT = 10mF 10 0 1.0 1.5 2.0 2.5 3.0 3.5 4.0 VIN (V) 4.5 5.0 5.5 6.0 REG710-2.7V REG710-3.3V Figure 16. Output Ripple Voltage 12 Submit Documentation Feedback Figure 17. Output Ripple Voltage vs VIN Copyright © 2001–2015, Texas Instruments Incorporated Product Folder Links: REG71050 REG71055 REG710 REG71050, REG71055, REG710 www.ti.com SBAS221H – DECEMBER 2001 – REVISED OCTOBER 2015 90 250 REG710-3 COUT = 2.2mF 70 225 200 REG710-5 REG71050 COUT = 2.2mF 60 50 REG710-2.5 COUT = 2.2mF REG710-5 REG71050 COUT = 10mF 40 30 20 10 0 1.0 2.0 REG710-2.5 REG710-3 2.5 3.0 175 150 125 100 3.5 4.0 VIN (V) 4.5 5.0 5.5 75 50 REG710-3 COUT = 10mF REG710-2.5, COUT = 10mF 1.5 Load Current (mA) Output Ripple (mVPP) 80 25 0 1.5 6.0 2.0 2.5 3.0 3.5 VIN (V) 4.0 4.5 5.0 5.5 REG710-5 Figure 18. Output Ripple Voltage vs VIN Figure 19. Short-Circuit Load Current vs VIN 100mA/div IIN VOUT 2V/div REG710-3.3V VIN = 3.0V IO = 30mA BW = 20MHz Time (50ms/div) Figure 20. Input Current at Turn-On Copyright © 2001–2015, Texas Instruments Incorporated Product Folder Links: REG71050 REG71055 REG710 Submit Documentation Feedback 13 REG71050, REG71055, REG710 SBAS221H – DECEMBER 2001 – REVISED OCTOBER 2015 www.ti.com 9.3 System Examples 9.3.1 1.8 V to 5.0 V With 10-mA Output Current The REG710 family of charge pumps can be cascaded to reach higher output voltages, as shown in Figure 21. 0.22mF CP1 0.22mF CP2 3.3V 3.0V 1.8V VIN + VIN - REG710-3.3 REG710-3 2.2mF CIN EN 5.0V VOUT GND VIN VOUT REG71050 REG710-5 2.2mF EN 2.2mF COUT GND Figure 21. REG710 Circuit for Step-Up Operation From 1.8 V to 5 V With 10-mA Output Current This application circuits operates from 1.8 V input voltage and generates 5 V output voltage supporting 10 mA load current. Higher output voltages can be achieved when two REG710 devices are connected in cascade. When cascading two devices from the REG710 family, the relationship between output current and input voltage must be taken into account. (see Electrical Characteristics). In this case, REG710 can deliver a maximum of 10 mA. REG7103.3 or REG710-3 can be used. A second charge pump, REG71050 or REG710-5, steps up the voltage from 3 V or 3.3 V to 5 V. Connect both Enable pins together. 14 Submit Documentation Feedback Copyright © 2001–2015, Texas Instruments Incorporated Product Folder Links: REG71050 REG71055 REG710 REG71050, REG71055, REG710 www.ti.com SBAS221H – DECEMBER 2001 – REVISED OCTOBER 2015 System Examples (continued) 9.3.2 Doubling the Output Current 0.22mF CP1 VIN VOUT VOUT REG710-3.3 + VIN - 4.7mF CIN GND 4.7mF COUT 0.22mF CP2 VIN VOUT REG710-3.3 GND Figure 22. REG710 Circuit for Doubling the Output Current When higher output currents are required, the REG710 family can be paralleled to double the output current. When paralleling two devices the relationship between output current and input voltage must be taken into account (see Electrical Characteristics). This particular application can deliver 20 mA for an input voltage from 1.8 V to 5.5 V, or 60-mA output for an input voltage from 2.2 V to 5.5 V. The output voltage is 3.3 V. Copyright © 2001–2015, Texas Instruments Incorporated Product Folder Links: REG71050 REG71055 REG710 Submit Documentation Feedback 15 REG71050, REG71055, REG710 SBAS221H – DECEMBER 2001 – REVISED OCTOBER 2015 www.ti.com 9.3.3 Driving LEDs CPUMP 0.22mF Enable 3.3V to 4.2V REG71050 REG710-5 R R R LED LED LED COUT 2.2mF CIN 2.2mF GND Figure 23. REG710 Circuit for Driving LEDs The REG710 family can be used to drive LEDs. The feed forward voltage of the chosen LED determines the required output voltage. In this application, the charge pump can drive multiple LEDs up to 60 mA in total. R= 16 5 V - VLED ILED Submit Documentation Feedback (2) Copyright © 2001–2015, Texas Instruments Incorporated Product Folder Links: REG71050 REG71055 REG710 REG71050, REG71055, REG710 www.ti.com SBAS221H – DECEMBER 2001 – REVISED OCTOBER 2015 10 Power Supply Recommendations The input supply to the REG710 must have a current rating according to the supply voltage, output voltage and output current of the REG710. 11 Layout 11.1 Layout Guidelines Large transient currents flow in the VIN, VOUT, and GND traces. To minimize both input and output ripple, keep the capacitors as close as possible to the regulator using short, direct circuit traces. A suggested printed-circuit-board (PCB) routing is shown in Figure 24. The trace lengths from the input and output capacitors have been kept as short as possible. 11.2 Layout Example Area: < 0.08 in2 VENABLE VOUT VIN 1 COUT CP CIN GND Figure 24. Suggested PCB Design for Minimum Ripple Copyright © 2001–2015, Texas Instruments Incorporated Product Folder Links: REG71050 REG71055 REG710 Submit Documentation Feedback 17 REG71050, REG71055, REG710 SBAS221H – DECEMBER 2001 – REVISED OCTOBER 2015 www.ti.com 12 Device and Documentation Support 12.1 Device Support 12.1.1 Third-Party Products Disclaimer TI'S PUBLICATION OF INFORMATION REGARDING THIRD-PARTY PRODUCTS OR SERVICES DOES NOT CONSTITUTE AN ENDORSEMENT REGARDING THE SUITABILITY OF SUCH PRODUCTS OR SERVICES OR A WARRANTY, REPRESENTATION OR ENDORSEMENT OF SUCH PRODUCTS OR SERVICES, EITHER ALONE OR IN COMBINATION WITH ANY TI PRODUCT OR SERVICE. 12.2 Related Links The table below lists quick access links. Categories include technical documents, support and community resources, tools and software, and quick access to sample or buy. Table 3. Related Links PARTS PRODUCT FOLDER SAMPLE & BUY TECHNICAL DOCUMENTS TOOLS & SOFTWARE SUPPORT & COMMUNITY REG71050 Click here Click here Click here Click here Click here REG71055 Click here Click here Click here Click here Click here 12.3 Community Resources The following links connect to TI community resources. Linked contents are provided "AS IS" by the respective contributors. They do not constitute TI specifications and do not necessarily reflect TI's views; see TI's Terms of Use. TI E2E™ Online Community TI's Engineer-to-Engineer (E2E) Community. Created to foster collaboration among engineers. At e2e.ti.com, you can ask questions, share knowledge, explore ideas and help solve problems with fellow engineers. Design Support TI's Design Support Quickly find helpful E2E forums along with design support tools and contact information for technical support. 12.4 Trademarks E2E is a trademark of Texas Instruments. All other trademarks are the property of their respective owners. 12.5 Electrostatic Discharge Caution These devices have limited built-in ESD protection. The leads should be shorted together or the device placed in conductive foam during storage or handling to prevent electrostatic damage to the MOS gates. 12.6 Glossary SLYZ022 — TI Glossary. This glossary lists and explains terms, acronyms, and definitions. 13 Mechanical, Packaging, and Orderable Information The following pages include mechanical, packaging, and orderable information. This information is the most current data available for the designated devices. This data is subject to change without notice and revision of this document. For browser-based versions of this data sheet, refer to the left-hand navigation. 18 Submit Documentation Feedback Copyright © 2001–2015, Texas Instruments Incorporated Product Folder Links: REG71050 REG71055 REG710 PACKAGE OPTION ADDENDUM www.ti.com 20-Dec-2023 PACKAGING INFORMATION Orderable Device Status (1) Package Type Package Pins Package Drawing Qty Eco Plan (2) Lead finish/ Ball material MSL Peak Temp Op Temp (°C) Device Marking (3) Samples (4/5) (6) REG71050DDCR SOT-23-THIN DDC 6 3000 RoHS & Green NIPDAU Level-1-260C-UNLIM -40 to 85 GAAI LIFEBUY SOT-23-THIN DDC 6 3000 RoHS & Green NIPDAU Level-1-260C-UNLIM -40 to 85 GAAI REG71050DDCT ACTIVE SOT-23-THIN DDC 6 250 RoHS & Green NIPDAU Level-1-260C-UNLIM -40 to 85 GAAI Samples REG71050DRVR ACTIVE WSON DRV 6 3000 RoHS & Green NIPDAU Level-2-260C-1 YEAR -40 to 85 CFF Samples REG71050DRVT ACTIVE WSON DRV 6 250 RoHS & Green Call TI | NIPDAU Level-2-260C-1 YEAR -40 to 85 CFF Samples REG71055DDCR ACTIVE SOT-23-THIN DDC 6 3000 RoHS & Green NIPDAU Level-1-260C-UNLIM -40 to 85 R10H Samples REG71055DDCT ACTIVE SOT-23-THIN DDC 6 250 RoHS & Green NIPDAU Level-1-260C-UNLIM -40 to 85 R10H Samples REG71055DDCTG4 LIFEBUY SOT-23-THIN DDC 6 250 RoHS & Green NIPDAU Level-1-260C-UNLIM -40 to 85 R10H REG710NA-2.5/250 ACTIVE SOT-23 DBV 6 250 RoHS & Green NIPDAU Level-1-260C-UNLIM -40 to 85 R10G Samples REG710NA-2.7/250 ACTIVE SOT-23 DBV 6 250 RoHS & Green NIPDAU Level-1-260C-UNLIM -40 to 85 R10F Samples REG710NA-3.3/250 ACTIVE SOT-23 DBV 6 250 RoHS & Green NIPDAU Level-1-260C-UNLIM -40 to 85 R10C Samples REG710NA-3.3/250G4 LIFEBUY SOT-23 DBV 6 250 RoHS & Green NIPDAU Level-1-260C-UNLIM -40 to 85 R10C REG710NA-3.3/3K ACTIVE SOT-23 DBV 6 3000 RoHS & Green NIPDAU Level-1-260C-UNLIM -40 to 85 R10C Samples REG710NA-3/250 ACTIVE SOT-23 DBV 6 250 RoHS & Green NIPDAU Level-1-260C-UNLIM -40 to 85 R10D Samples REG710NA-3/3K ACTIVE SOT-23 DBV 6 3000 RoHS & Green NIPDAU Level-1-260C-UNLIM -40 to 85 R10D Samples REG710NA-5/250 ACTIVE SOT-23 DBV 6 250 RoHS & Green NIPDAU Level-1-260C-UNLIM -40 to 85 R10B Samples REG710NA-5/250G4 LIFEBUY SOT-23 DBV 6 250 RoHS & Green NIPDAU Level-1-260C-UNLIM -40 to 85 R10B REG710NA-5/3K ACTIVE SOT-23 DBV 6 3000 RoHS & Green NIPDAU Level-1-260C-UNLIM -40 to 85 R10B REG71050DDCRG4 ACTIVE (1) The marketing status values are defined as follows: ACTIVE: Product device recommended for new designs. LIFEBUY: TI has announced that the device will be discontinued, and a lifetime-buy period is in effect. NRND: Not recommended for new designs. Device is in production to support existing customers, but TI does not recommend using this part in a new design. PREVIEW: Device has been announced but is not in production. Samples may or may not be available. OBSOLETE: TI has discontinued the production of the device. Addendum-Page 1 Samples Samples PACKAGE OPTION ADDENDUM www.ti.com 20-Dec-2023 (2) RoHS: TI defines "RoHS" to mean semiconductor products that are compliant with the current EU RoHS requirements for all 10 RoHS substances, including the requirement that RoHS substance do not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, "RoHS" products are suitable for use in specified lead-free processes. TI may reference these types of products as "Pb-Free". RoHS Exempt: TI defines "RoHS Exempt" to mean products that contain lead but are compliant with EU RoHS pursuant to a specific EU RoHS exemption. Green: TI defines "Green" to mean the content of Chlorine (Cl) and Bromine (Br) based flame retardants meet JS709B low halogen requirements of
REG710NA-2.5/3K 价格&库存
很抱歉,暂时无法提供与“REG710NA-2.5/3K”相匹配的价格&库存,您可以联系我们找货
