GLF1511
GLF1511
    GLF(杰夫微)
    6-UFBGA,WLCSP
    电源开关/驱动器 1:1 N 通道 4A 6-WLCSP(0.97x1.47)
GLF1511 数据手册
GLF1511 4 A, Ultra Low Ron N-channel Load Switch with wide Input Voltage Range and Reverse Current Blocking Product Specification DESCRIPTION FEATURES The GLF1511 load switch is a fully integrated 4 A NMOS load switch with IQSmartTM advanced technology. The device is ideal for the mobile computing and data storage markets as a high performance solution for load switch applications. The GLF1511 provides a constant low onresistance of 13 mΩ at the full input voltage range. The fixed rise time helps prevent undesirable inrush current when turned on and the internal EN pin pulldown resistor ensures the device remains in the shutdown mode when disabled. In shutdown mode the GLF1511 consumes ultra-low current at the wide input supply voltage. The GLF1511 features a reverse current blocking protection. When the GLF1511 is disabled, it prevents reverse current flowing from the output to the input source. The GLF1511 is available in a wafer level chip scale package (WLCSP) measuring 0.97 mm x 1.47 mm x 0.55 mm with a 0.5 mm pitch. This allows the user to save board space.     Supply Voltage Range: 0.7 V to 5.5 V Low RON: 13 mΩ Typ IOUT Max: 4 A Ultra-Low IQ: o 2 μA Typ at 0.7 VIN o14 μA Typ at 3.3 VIN o30 μA Typ at 5.5 VIN  Ultra-Low ISD: o0.015 μA Typ at 0.7 VIN o0.030 μA Typ at 5.5 VIN Controlled VOUT Turn-on Time Internal EN Pull-Down Resistor Integrated Output Discharge Switch Reverse Current Blocking Protection When Disabled  Operating Temperature Range: - 40 °C to 105 °C  HBM: 8 kV, CDM: 2 kV  0.97 mm x 1.47 mm x 0.55 mm, 6 Bumps Wafer Level Chip Scale Package     APPLICATIONS  Data Storage, SSD  Wearables  Low Power Subsystems PACKAGE 0.97 mm x 1.47 mm x 0.55 mm, 0.5 mm Pitch Rev.0.0 Feb 2023 Copyright © 2023 GLF Integrated Power. All Rights Reserved. www.glfipower.com Page 1 GLF1511 4 A, Ultra Low Ron N-channel Load Switch with wide input voltage Range and Reverse Current Blocking APPLICATION DIAGRAM DEVICE ORDERING INFORMATION Part Number Top Mark RON Typ. at Vin Range Output Discharge EN Activity GLF1511 FL 13 mΩ 250 Ω High FUNCTIONAL BLOCK DIAGRAM Figure 1. Functional Block Diagram PIN CONFIGURATION PIN DEFINITION Pin # Name A1, B1 VOUT A2, B2 VIN C1 GND C2 EN Description Switch Output Switch Input. Supply Voltage for IC Ground Enable to control the switch Figure 2. 0.97 mm x 1.47 mm x 0.55 mm WLCSP Rev.0.0 Feb 2023 Copyright © 2023 GLF Integrated Power. All Rights Reserved. www.glfipower.com Page 2 GLF1511 4 A, Ultra Low Ron N-channel Load Switch with wide input voltage Range and Reverse Current Blocking ABSOLUTE MAXIMUM RATINGS Stresses exceeding the absolute maximum ratings may damage the device. The device may not function or be operable above the recommended operating conditions; extended exposure to stresses above the recommended operating conditions may affect device reliability. The absolute maximum ratings are stress ratings only. Symbol Parameter VIN, VOUT, VEN Each Pin Voltage Range to GND Min. Max. Unit -0.3 6 V 4 A IOUT Maximum Continuous Switch Current PD Power Dissipation at TA = 25 °C 1 W TSTG Storage Junction Temperature -65 150 °C Operating Temperature Range Thermal Resistance, Junction to Ambient (board dependent) Human Body Model, JESD22-A114 Electrostatic Discharge Capability Charged Device Model, JESD22-C101 -40 105 85 °C °C/W TA θJA ESD 8 2 kV RECOMMENDED OPERATING CONDITIONS Over operating temperature, unless otherwise noted Symbol VIN VOUT Parameter Input Supply Voltage Output Voltage Range Min. Max. Unit 0.7 0 5.5 5.5 V V ELECTRICAL CHARACTERISTICS VIN = 0.7 V to 5.5 V and TA = 25 °C unless otherwise noted. Symbol Parameter Conditions Min. Typ. Max. Unit Basic Operation IQ Quiescent Current EN = VIN, IOUT= 0 mA, VIN = 0.7 V 2 EN = VIN, IOUT= 0 mA, VIN = 1.0V 2.5 EN = VIN, IOUT= 0 mA, VIN = 2.5 V 9 EN = VIN, IOUT= 0 mA, VIN = 3.3 V 14 EN = VIN, IOUT= 0 mA, VIN = 5.5 V EN = VIN, IOUT= 0 mA, VIN = 5.5 V 30 TA= 85 °C 0.015 EN = Disable, IOUT= 0 mA, VIN= 5.5 V Shutdown Current EN = Disable, IOUT= 0 mA, VIN= 5.5 V 0.030 TA= 85 °C 0.83 (1) TA= 105 °C 2.85 (1) TA= 25 °C RON On-Resistance VIN=0.7 V to 5.5 V, IOUT= 200 mA TA= 85 °C 13 Output Discharge Resistance VIH EN Input Logic High Voltage mΩ 17 VEN = Low , IFORCE= 2 mA 250 VIN = 0.7 V to 1.5 V 1.1 VIN = 1.5 V to 5.5 V 0.5 Ω VIN = 0.7 V to 1.5 V 0.15 VIN = 1.5 V to 5.5 V 0.3 VIL EN Input Logic Low Voltage REN EN pull-down resistance VEN = 3.3 V IEN EN Current VEN = 5.5 V Rev.0.0 Feb 2023 20 16 (1) TA= 105 °C (1) RDSC μA 105 (1) EN = Disable, IOUT= 0 mA, VIN= 0.7 V ISD 50 54 (1) TA= 105 °C 4 Copyright © 2023 GLF Integrated Power. All Rights Reserved. www.glfipower.com 10 V MΩ 0.8 μA Page 3 GLF1511 4 A, Ultra Low Ron N-channel Load Switch with wide input voltage Range and Reverse Current Blocking Switching Characteristics (1), (2) VIN = 0.7 V, TA =25 °C tdON Turn-On Delay tR VOUT Rise Time tdOFF Turn-Off Delay tF VOUT Fall Time 145 RL=150 Ω, CIN=1.0 µF, COUT=0.1 µF 190 38 μs 17 VIN = 1.1 V, TA =25 °C tdON Turn-On Delay tR VOUT Rise Time tdOFF Turn-Off Delay tF VOUT Fall Time 120 RL=150 Ω, CIN=1.0 µF, COUT=0.1 µF 240 8 μs 18 VIN = 2.5 V, TA =25 °C tdON Turn-On Delay tR VOUT Rise Time tdOFF Turn-Off Delay tF VOUT Fall Time 90 RL=150 Ω, CIN=1.0 µF, COUT=0.1 µF 310 2 μs 18 VIN = 3.3 V, TA =25 °C tdON Turn-On Delay 80 tR VOUT Rise Time 360 tdOFF Turn-Off Delay tF VOUT Fall Time RL=150 Ω, CIN=1.0 µF, COUT=0.1 µF 1.5 μs 18 VIN = 5.0 V, TA =25 °C tdON Turn-On Delay tR VOUT Rise Time tdOFF Turn-Off Delay tF VOUT Fall Time 70 RL=150 Ω, CIN=1.0 µF, COUT=0.1 µF 360 1.5 μs 18 Notes: 1. By design; characterized, not production tested. 2. tON = tdON + tR, tOFF = tdOFF + tF TIMING DIAGRAM Figure 3. Timing Diagram Rev.0.0 Feb 2023 Copyright © 2023 GLF Integrated Power. All Rights Reserved. www.glfipower.com Page 4 GLF1511 4 A, Ultra Low Ron N-channel Load Switch with wide input voltage Range and Reverse Current Blocking TYPICAL PERFORMANCE CHARACTERISTICS Figure 4. On-Resistance vs. Supply Voltage Figure 5. Quiescent Current vs. Temperature Figure 6. Shutdown Current vs. Temperature Figure 7. Output Discharge Resistance vs. Temperature Figure 8. EN Input Logic High Threshold vs. Temperature Rev.0.0 Feb 2023 Figure 9. EN Input Logic Low Threshold vs. Temperature Copyright © 2023 GLF Integrated Power. All Rights Reserved. www.glfipower.com Page 5 GLF1511 4 A, Ultra Low Ron N-channel Load Switch with wide input voltage Range and Reverse Current Blocking EN [2V / Div] VOUT [1V / Div] EN [2V / Div] 200 μs/div Figure 10. Turn-On Response VIN=0.7 V, CIN=1.0 µF, COUT=0.1 µF, RL=150 Ω EN [2V / Div] VOUT [1V / Div] 200 μs/div EN [2V / Div] Figure 11. Turn-Off Response VIN=0.7 V, CIN=1.0 µF, COUT=0.1 µF, RL=150 Ω VOUT [1V / Div] 10 μs/div Figure 13. Turn-Off Response VIN=1.1 V, CIN=1.0 µF, COUT=0.1 µF, RL=150 Ω EN [2V / Div] 200 μs/div Figure 14. Turn-On Response VIN=2.5 V, CIN=1.0 µF, COUT=0.1 µF, RL=150 Ω Rev.0.0 Feb 2023 10 μs/div EN [2V / Div] Figure 12. Turn-On Response VIN=1.1 V, CIN=1.0 µF, COUT=0.1 µF, RL=150 Ω VOUT [1V / Div] VOUT [1V / Div] VOUT [1V / Div] 10 μs/div Figure 15. Turn-Off Response VIN=2.5 V, CIN=1.0 µF, COUT=0.1 µF, RL=150 Ω Copyright © 2023 GLF Integrated Power. All Rights Reserved. www.glfipower.com Page 6 GLF1511 4 A, Ultra Low Ron N-channel Load Switch with wide input voltage Range and Reverse Current Blocking EN [2V / Div] VOUT [1V / Div] EN [2V / Div] 200 μs/div Figure 16. Turn-On Response VIN=3.3 V, CIN=1.0 µF, COUT=0.1 µF, RL=150 Ω EN [2V / Div] VOUT [1V / Div] VOUT [1V / Div] 10 μs/div Figure 17. Turn-Off Response VIN=3.3 V, CIN=1.0 µF, COUT=0.1 µF, RL=150 Ω EN [2V / Div] 200 μs/div Figure 18. Turn-On Response VIN=5.0 V, CIN=1.0 µF, COUT=0.1 µF, RL=150 Ω VOUT [1V / Div] 10 μs/div Figure 19. Turn-Off Response VIN=5.0 V, CIN=1.0 µF, COUT=0.1 µF, RL=150 Ω VOUT [1V / Div] I_reverse [100mA / Div] VIN [1V / Div] 40 ms/div Figure 20. Reverse Current Blocking When Disabled VIN=VEN=0 V, VOUT=0 V to 4.5 V, CIN=1.0 µF, COUT=0.1 µF Rev.0.0 Feb 2023 Copyright © 2023 GLF Integrated Power. All Rights Reserved. www.glfipower.com Page 7 GLF1511 4 A, Ultra Low Ron N-channel Load Switch with wide input voltage Range and Reverse Current Blocking APPLICATION INFORMATION The GLF1511 is a fully integrated 4 A NMOS load switch with fixed slew rate control to limit the inrush current during turn on. Each device is capable of operating over a wide input range from 0.7 V to 5.5 V with very low on-resistance to reduce conduction loss. In the off state, these devices consume very low leakage current, avoiding unwanted standby current from the input power supply. The GLF1511 is available in the 0.97 mm x 1.47 mm wafer level chip scale package with 6 bumps at 0.5 mm pitch to save space in compact applications. Input Capacitor A capacitor is recommended to be placed close to the VIN pin to reduce the voltage drop on the input power rail caused by transient inrush current at start-up. A higher input capacitor value can be used to further attenuate the input voltage drop. Output Capacitor An output capacitor is recommended to minimize voltage undershoot on the output pin during the transition when the switch is turned off. Undershoot can be caused by parasitic inductance from board traces or intentional load inductances. If load inductances do exist, use of an output capacitor can improve output voltage stability and system reliability. The COUT capacitor should be placed close to the VOUT and GND pins. Reverse Current Blocking The GLF1511 has a built-in reverse current blocking protection. When the device is disabled, the reverse current blocking protection is activated to prevent the reverse current from the Vout to the Vin source. EN pin The GLF1511 can be activated by EN pin high. Note that the EN pin has an internal pull-down resistor to maintain a reliable status without EN signal applied from an external controller. Board Layout All traces should be as short as possible to minimize parasitic inductance effect. Wide traces for VIN, VOUT, and GND will help reduce signal degradation and parasitic effects during dynamic operations as well as improve the thermal performance at high load current. Rev.0.0 Feb 2023 Copyright © 2023 GLF Integrated Power. All Rights Reserved. www.glfipower.com Page 8 GLF1511 4 A, Ultra Low Ron N-channel Load Switch with wide input voltage Range and Reverse Current Blocking PACKAGE OUTLINE Notes 1. ALL DIMENSIONS ARE IN MILLIMETERS (ANGLES IN DEGRESS) 2. DIMENSIONING AND TOLERANCING PER ANSI Y14.5M-1994. 3. A3: BACKSIDE LAMINATION Rev.0.0 Feb 2023 Copyright © 2023 GLF Integrated Power. All Rights Reserved. www.glfipower.com Page 9 GLF1511 4 A, Ultra Low Ron N-channel Load Switch with wide input voltage Range and Reverse Current Blocking TAPE AND REEL INFORMATION REEL DIMENSIONS QUADRANT ASSIGNMENTS PIN 1 ORIENTATION TAPE TAPE DIMENSIONS P W Device Package Pins SPQ Reel Diameter (mm) Reel Width W1 A0 B0 K0 P W Pin1 GLF1511 WLCSP 6 3000 180 9 1.18 1.68 0.83 4 8 Q1 Remark: A0: Dimension designed to accommodate the component width B0: Dimension designed to accommodate the component length C0: Dimension designed to accommodate the component thickness W: Overall width of the carrier tape P: Pitch between successive cavity centers Rev.0.0 Feb 2023 Copyright © 2023 GLF Integrated Power. All Rights Reserved. www.glfipower.com Page 10 GLF1511 4 A, Ultra Low Ron N-channel Load Switch with wide input voltage Range and Reverse Current Blocking SPECIFICATION DEFINITIONS Document Type Meaning Product Status Target Specification This is a target specification intended to support exploration and discussion of critical needs for a proposed or target device. Spec limits including typical, minimum, and maximum values are desired, or target, limits. GLF reserves the right to change limits at any time without warning or notification. A target specification in no way guarantees future production of the device in question. Design / Development Preliminary Specification This is a draft version of a product specification. The specification is still under internal review and subject to change. GLF reserves the right to change the specification at any time without warning or notification. A preliminary specification in no way guarantees future production of the device in question. Qualification Product Specification This document represents the anticipated production performance characteristics of the device. Production DISCLAIMERS Information in this document is believed to be accurate and reliable, however GLF assumes no liability for errors or omissions. Device performance may be impacted by testing methods and application use cases. Users are responsible to independently evaluate the applicability, usability, and suitability of GLF devices in their application. In no case will GLF be liable for incidental, indirect, or consequential damages associated with the use, mis-use, or sale of its product. Customers are wholly responsible to assure GLF devices meet their system level and end product requirements. GLF retains the right to change the information provided in this data sheet without notice. Rev.0.0 Feb 2023 Copyright © 2023 GLF Integrated Power. All Rights Reserved. www.glfipower.com Page 11
GLF1511 价格&库存
很抱歉,暂时无法提供与“GLF1511”相匹配的价格&库存,您可以联系我们找货
