Technical Datasheet
CP40_1180018
Cool Power Technologies
40W Isolated DC/DC Converter
Features
Ultra-wide input voltage range: 9 – 36Vin
High efficiency: 90% at full load, nominal Vin
Output: 5 V at 8 A, 40W max.
Tiny 0.94” X 0.94” x 0.35” max ht (Thru-hole)
0.94” X 0.94” x 0.396” Surface Mount
1” x 1” x 0.41” Encapsulated Product
RoHS 3 Directive 2015/863/EU
No minimum load/capacitance required
On-board input differential “PI" LC-filter
Withstands 100 V input transients
Fixed-frequency operation
Meets UL94, V-0 flammability rating
Full protection (OTP, OCP, OVP, UVLO w/auto-restart)
Remote ON/OFF - positive or negative enable logic options
Output voltage trim range: ±10% (see Output Voltage Trim Equations section)
Weight: 0.266 oz [7.54 g] (open frame), 0.67 oz [19g] (encapsulated)
Basic Insulation w/2250VDC I/O isolation (open frame), 1600VDC (encapsulated)
Complies with UL/CSA60950-1, TUV per IEC/EN60950-1, 2nd edition
Compliant to REACH (EC) No 1907/2006, 205 SVHC update
Designed to meet Class B conducted emissions per FCC and EN55032 when used with external
filter (see EMC Compliance section below.)
Description
The “Cool Power Technologies” CP40_1180018 DC-DC converter is an open frame isolated 1” X 1” DCDC module that conforms to industry standard pinout and trim equations. The converter operates over
an input voltage range of 9 to 36 VDC, and provides a tightly regulated output voltage with an output
current rating of 8 A. The output is fully isolated from the input and the converter meets Basic
Insulation requirements with 2250VDC I/O isolation rating open frame, 1600VDC for the encapsulated
version. The standard feature set includes remote On/Off (positive or negative enable), input
undervoltage lockout, output overvoltage protection, overcurrent and short circuit protections, output
voltage trim and overtemperature shutdown with hysteresis. The high efficiency of the CP40_1180018
allows operation over a wide ambient temperature range with minimal derating.
www.dcdc.com
603-893-2330
- 1-
Technical Datasheet
CP40_1180018
TABLE OF CONTENTS
SECTION
PAGE
FEATURES & DESCRIPTION
APPLICATION DIAGRAM
1
2
ELECTRICAL SPECIFICATIONS
CHARACTERISTIC PERFORMANCE CURVES
CHARACTERISTIC WAVEFORMS
APPLICATION NOTES
RIPPLE MEASUREMENTS TEST SET-UP
OUTPUT VOLTAGE TRIM EQUATIONS
• THERMAL DERATING
• EMC COMPLIANCE
MECHANICAL OUTLINE & PCB FOOTPRINT
ORDERING INFORMATION
3
6
7
9
9
10
11
13
14
16
APPLICATION DIAGRAM
www.dcdc.com
603-893-2330
- 2-
Technical Datasheet
CP40_1180018
9–36Vin, 5V/8Aout
Conditions: TA = 25 ºC, Airflow = 300 LFM, Vin = 24 VDC, Cin = 100 µF, unless otherwise specified.
Input Characteristics
Parameter
Conditions
Min
1
Typ
Max
Unit
Operating Input Voltage Range
9
24
36
VDC
Input Under-Voltage Lock-out
Turn-on Threshold
Turn-off Threshold
9.1
8.2
9.3
8.5
9.5
8.7
VDC
Input Voltage Transient
100ms
50
VDC
Maximum Input Current
VIN = 9VDC; IOUT = 8A
5.4
A
Input Standby Current
Converter Disabled
2
5
mA
Input No-Load Current
Converter Enabled
60
mA
RMS
mA
Input Reflected Ripple Current
5Hz to 50MHz
See Fig 15 for setup
Input Voltage Ripple Rejection
120Hz
50
Short Circuit Input Current
Inrush Current
All
Conditions
Min
4.925
30
mAPK-PK
dB
0.1
A2/s
Typ
Max
Unit
5.00
5.075
VDC
8
A
16
A
A
3
ARMS
4700
uF
mVPK-PK
±0.02
±0.02
±0.1
±0.1
5.15
%Vo
%Vo
V
Output Characteristics
Parameter
Output Voltage Set point
Output Current
Output Current Limit Inception
9
Peak Short-Circuit Current
10mΩ Short
RMS Short-Circuit Current
10mΩ Short
External Load Capacitance
Output Ripple and Noise
20 MHz bandwidth
Output Regulation
Line:
Load:
Overall Output Regulation:
11
2
0.1 uF Ceramic +
22uF Ceramic
See Fig 16 for setup
Over line, load & temp.
4.85
www.dcdc.com
603-893-2330
- 3-
Technical Datasheet
CP40_1180018
ELECTRICAL SPECIFICATIONS (continued)
9–36Vin, 5V/8Aout
Absolute Maximum Ratings
Parameter
Input Voltage
Operating Temperature
Tref , see Thermal
Derating section
Conditions
Min
Continuous Operation
Max
Unit
VDC
Open Frame
-40
+123
°C
Encapsulated Module
-40
+105
°C
-55
+125
°C
Max
Unit
Storage Temperature
Typ
Feature Characteristics
Parameter
Conditions
Min
Switching Frequency
440
Output Voltage Trim Range2
Output Over-voltage Protection
Over-temperature Protection
Peak Backdrive Output Current
during startup into prebiased
output
Backdrive Output Current in OFF
state
Power On to Output Turn-ON Time
Enable to Output Turn-ON Time
Output Enable ON/OFF
Negative Enable
Converter ON
Converter OFF
Positive Enable
Converter ON
Converter OFF
Enable Pin Current Source/Sink
Output Voltage Overshoot @
Startup
Auto-Restart Period
Typ
-10
Non-latching
115
130
kHz
+10
140
Avg. PCB temp,
non-latching
135
Sinking current from
external voltage source
equal to VOUT – 0.6V and
connected to the output
via 1Ω resistor.
COUT=220µF, Aluminum
350
500
mA
Converter disabled
mA
VOUT = 0.9*VOUT_NOM
15
mS
VOUT = 0.9*VOUT_NOM
15
mS
-0.7
2.4
0.8
15
VDC
VDC
2.4
-0.7
0.25
1
VDC
VDC
mA
%Vo
All voltages are
WRT –Vin.
Converter has internal
pull-up of approx. 5V
(OVP, OCP)
100
°C
ms
www.dcdc.com
603-893-2330
- 4-
Technical Datasheet
CP40_1180018
9–36Vin, 5V/8Aout
Conditions: Ta = 25 ºC, Airflow = 300 LFM, Vin = 24 VDC, Cin = 100 µF, unless otherwise specified.
Efficiency
Parameter
Full Load
50% Load
Conditions
Min
Typ
Max
Unit
Vin = 12Vin
89
90
Vin = 24Vin
89
90
Vin = 12Vin
89
91
Vin = 24Vin
87
89
Conditions
Min
Typ
Max
Unit
80
120
mV
Dynamic Response
Parameter
Load Change 25%-50% or 50%–
75% of Iout Max, di/dt = 0.1 A/µs
Cout = 0.1 µF ceramic
+ 22 µF ceramic
See Fig 16
Settling Time to 1% of Vout
Load Change 25%-75% or 75%–
25% of Iout Max, di/dt = 0.2 A/µs
100
Cout = 1 µF ceramic
+ 1000 µF Oscon
µS
80
120
mV
100
µS
1000
pF
Isolation Specifications
Isolation Capacitance
Isolation Resistance
Isolation Voltage
Input to Output Open Frame
Input to Output –
Encapsulated
10
MΩ
2250
VDC
1600
VDC
Reliability
Per Telcordia SR-332, Issue 2:
Method I, Case 3
(IO=80% of IO_max, TA=40°C,
airflow = 200 lfm, 90% confidence)
MTBF
3,363,122
Hours
FITs
(failures in 109 hours)
297
/109
Hours
Notes:
1) Unit will regulate at 9Vin up to 50% maximum load. Full rated load requires 9.5Vin minimum.
2) 10% trim-up limited to 11 - 32 Vin range.
www.dcdc.com
603-893-2330
- 5-
Technical Datasheet
CP40_1180018
CHARACTERISTIC CURVES:
95%
6
90%
5
Power Dissipation (W)
Vin=9V
Efficiency
85%
80%
Vin=9V
75%
Vin=12V
70%
Vin=24V
65%
Vin=24V
4
Vin=36V
3
2
1
Vin=36V
60%
1.6
2.4
3.2
4
4.8
5.6
Output Current (A)
6.4
7.2
8
Figure 1. Efficiency vs Output Current, 300lfm
airflow, 25°C ambient.
1
2
3
4
5
Output Current (A)
6
7
8
Figure 2. Power Dissipation vs. Load Current,
300lfm airflow, 25°C ambient.
8
8
7
7
N/C ~40LFM (0.2m/s)
6
Output Current (A)
Output Current (A)
Vin=12V
100 LFM (0.5 m/s)
5
200 LFM (1.0 m/s)
4
300 LFM (1.5
m/s)
3
2
1
N/C ~40LFM (0.2m/s)
100 LFM (0.5 m/s)
6
200 LFM (1.0 m/s)
5
300 LFM (1.5 m/s)
4
3
2
1
40
55
70
85
Ambient Temperature (°C)
25
40
55
70
85
Figure 3. Output Current Derating vs Ambient
Temperature & Airflow (Open Frame module)
Vin = 24 V (airflow from pin 1 to pin 2)
Figure 4. Output Current Derating vs Ambient
Vin = 12 V (airflow from pin 1 to pin 2)
8
Output Current (A)
7
N/C ~40LFM (0.2m/s)
6
100 LFM (0.5 m/s)
5
200 LFM (1.0 m/s)
4
300 LFM (1.5
m/s)
3
2
1
40
55
70
85
Figure 5. Output Current Derating vs Ambient
Temperature & Airflow (Encapsulated module)
Vin = 12V,24V
Figure 6. Thermal Image of CP40B1180018
8A output, 55C Ambient, 200lfm airflow,
Vin = 24V, Tmax = 121°C
www.dcdc.com
603-893-2330
- 6-
Technical Datasheet
CP40_1180018
CHARACTERISTIC WAVEFORMS:
Figure 7. Input Reflected Ripple Current (20mA/div),
time scale – 1uS/div. Vin=Vin_nom, full load
(see Fig 15)
Figure 8. . Output Voltage Ripple (20mV/div),
Cout=0.1uF ceramic + 22uF ceramic (see Fig 16)
Figure 9. Startup Waveform via Enable Pin,
time scale 4mS/div. Vin=Vin_nom, Iout=no load
Cout=0, Ch1=Vout (2V/div), Ch2=Enable (5V/div)
Figure 10. Startup Waveform via Line Voltage,
time scale 4mS/div. Vin=Vin_nom, Iout=full load
Cout=0uF, Ch1=Vout (2V/div), Ch2=Vin (20V/div)
Figure 11. Startup Waveform via Enable Pin,
Cout=4700uF, Ch1=Vout (2V/div), Ch2=Enable (5V/div)
Figure 12. Load Transient Response (100mV/div),
di/dt=0.1A/uS, 50%-75%-50% of full load, Cout=Fig16
time scale: 200uS/div. Ch1=Vout, Ch2=Iout (2A/div)
www.dcdc.com
603-893-2330
- 7-
Technical Datasheet
CP40_1180018
Figure 13. Load Transient Response (100mV/div),
di/dt=0.1A/uS, 25%-50%-25% of full load, Cout=Fig16
Figure 14. Load Transient Response 50mV/div),
di/dt=0.2A/uS, 25% - 75% - 25% of full load +1000uF
low ESR Oscon, time scale: 200uS/div. Ch1=Vout,
Ch2=Iout (2A/div)
www.dcdc.com
603-893-2330
- 8-
Technical Datasheet
CP40_1180018
Application Notes
INPUT REFLECTED RIPPLE TEST SETUP:
TO OSCILLOSCOPE
Current Probe
Vin(+)
Lsource:
10 uH
DC
Source
Csource: 220 uF
ESR < 0.1 OHM
@ 20 ºC, 100 kHz
100 uF
ESR < 0.7 OHM
Vin(-)
Note: Measure input reflected-ripple current with a simulated source inductance (Ltest) of 10 uH.
Capacitor CS offsets possible source impedance.
Figure 15. Input Reflected-ripple Current Test Setup.
OUTPUT RIPPLE TEST SETUP:
COPPER STRIP
Vout(+)
22 uF
0.1 uF
SCOPE
RESISTIVE
LOAD
Vout(-)
Use a 0.1µF X7R ceramic capacitor and 22µF @16V X7R ceramic capacitor. Scope measurement made
using a BNC socket. Position the load 3 in. [76mm] from module.
Figure 16. Peak-to-Peak Output Noise Measurement Test Setup.
www.dcdc.com
603-893-2330
- 9-
Technical Datasheet
CP40_1180018
Application Notes (cont)
OUTPUT VOLTAGE TRIM:
Output voltage adjustment is accomplished by connecting an external resistor between the Trim Pin
and either the +Vout or –Vout Pins.
TRIM UP EQUATION:
Rtrim_up ( Ω )
12750
− 2050
Vdes − 5
Where Rtrim_up is the resistance value in ohms and Vdes is the desired output voltage.
E.g. to trim the output up 10%,
R trim_up
Enable
12750
− 2050 ⋅ Ω
5.5 − 5
or Rtrim_up = 23.45 kOhm
-Vout
Rtrim_up
-Vin
Rload
Trim
+Vin
+Vout
Figure 17. Trim UP circuit configuration
TRIM-DOWN EQUATION:
5100 ⋅ ( Vdes − 2.5)
Rtrim_down ( Ω )
5 − Vdes
− 2050
Where Rtrim_down is the resistance value in ohms and Vdes is the desired output voltage.
Enable
-Vout
-Vin
Rload
Trim
+Vin
Rtrim_down
+Vout
Figure 18. Trim DOWN circuit configuration
www.dcdc.com
603-893-2330
- 10 -
Technical Datasheet
CP40_1180018
Thermal Derating
It is preferable that the DC-DC module have an unobstructed flow of air across it for best
thermal performance. Components taller than ~ 2mm in front of the module can deflect airflow
and possibly create hotspots.
Significant cooling is achieved through conductive flow from the modules I/O pins to the host
PCB. Sufficiently large traces connecting the dc-dc converter to the source and load will help
ensure thermal derating performance will meet or exceed the derating curves published in this
datasheet.
If the module is expected to be operated near the load limits defined in the derating curves, insystem verification of module derating performance should be performed to ensure long-term
system reliability. Peak temperatures are to be measured using infrared thermography or by
gluing a fine gauge (AWG #40) thermocouple at the Tref location(s) shown below. Temperature
at the specified location(s) should be kept below 123ºC for open frame units, 105ºC for
encapsulated modules in order to maintain optimum converter reliability.
Open Frame
Encapsulated
Input Undervoltage Lockout
The converter is disabled until the input voltage has exceeded the UVLO turn-on threshold.
Once the input voltage exceeds this level (see Input Under-Voltage Lock-out in Electrical
Specifications table) the module will commence soft-start. Hysteresis of 1-3 volts minimizes the
likelihood of pulling the input voltage below the turn-off threshold during startup which could
create an undesirable on/off cycling condition. The converter will continue to operate until the
input voltage subsequently falls below the UVLO turn-off threshold.
Enable Pin Function
The module has a remote enable function that allows it to be turned on or off remotely. The
Enable pin is referenced to the negative input pin (-Vin) of the converter. Modules can be
ordered with either negative or positive enable.
The negative enable option the module will not turn on unless the enable pin is connected to –
Vin. The positive enable option allows the converter to turn on as soon as voltage sufficient to
exceed the UVLO of the converter has been applied to the input terminals. In this case the
module is turned off by connecting the Enable pin to –Vin. On/off thresholds are located in the
Electrical Specifications table.
www.dcdc.com
603-893-2330
- 11 -
Technical Datasheet
CP40_1180018
Output Overvoltage Protection
The module has an independent feedback loop that will disable the output of the converter if a
voltage greater than about 125% of the nominal set point is detected. When this threshold is
reached, the converter will shut down and remain off for the amount of time specified by the
Auto-Restart Period. The converter will attempt a restart once this period of time has elapsed.
Output Overtemperature Protection
To provide protection under certain fault conditions, the unit is equipped with a thermal
shutdown circuit. The unit will shutdown if the average PCB temperature exceeds approx.
135ºC, but the thermal shutdown is not intended as a guarantee that the unit will survive
temperatures beyond its rating. The module will automatically restart once it has cooled below
the shutdown temperature minus hysteresis (typically 20 deg C.)
SMT Version Layout Considerations (if applicable)
Copper traces with sufficient cross-section must be provided for all output & input pins. SMT
pads tied to internal power/ground planes must have multiple vias around each SMT pad to
couple expected current loads from module pins into internal traces/planes. One 0.024”
(0.6mm) diameter via for each 4A of expected source or load current must be provided as close
to the termination as possible, preferably in the direction of current flow from SMT pad to load.
Vias must be at least 0.024” (0.6 mm) away from the SMT pad to prevent solder from flowing
into the vias.
SMT pads on the host card are to be 0.075” (1.9mm) diameter. Solder paste screen opening
should be 0.070” diameter and the screen should be 0.006” (0.15 mm) thick (other thicknesses
are possible; 0.006” provides a good compromise between solder volume and coplanarity
compensation.)
Paralleling Converters
Modules may be paralleled but it is recommended that the total power draw not exceed the
output power rating of a single module. External sharing controllers are recommended for
reliability and to ensure equal distribution of the load to the converters.
www.dcdc.com
603-893-2330
- 12 -
Technical Datasheet
CP40_1180018
EMC Compliance
To meet Class B compliance for EN55032 (CISPR 32) or FCC part 15 sub part j, the following input
filter is required:
Figure 19. EMI Filter
L1 =
C1,C2,C3 =
C4 =
C5,C6 =
0.59 mH Common Mode Inductor (Pulse P0353NL)
2.2uF ceramic
220uF electrolytic
10nF (@2kV if output is ref. to gnd.)
80
70
60
EN55022 ClassB Average Limits
dBuV
50
40
30
150k
300k
500k
1M
3M
5M
10M
30M
Frequency (Hz)
Figure 20. CP40_1180018 Conducted Emissions using above specified input filter.
Vin = 24V, Full Resistive Load
www.dcdc.com
603-893-2330
- 13 -
Technical Datasheet
CP40_1180018
MODULE PIN ASSIGNMENT:
PIN #
1
DESIGNATION
VIN (+)
2
3
4
5
6
VIN (-)
On/Off
VOUT (-)
Trim
VOUT (+)
NOTES
1) All dimensions in inches [mm]
Tolerances: .xx ± 0.02 [.x ± .5]
.xxx ± 0.010 [.xx ± .25]
2) TH pins Ø 0.040” [1.02] with Ø 0.070” [1.77] standoff shoulders.
3) SMT pins are Ø 0.060”
4) Keep Out Area – no copper traces or vias should be placed in this area.
5) All pins are gold plated with nickel under plating (ROHS).
6) Weight: 7.54 g (0.266 oz.) open frame, 19g (0.67 oz.) encapsulated
7) Workmanship: Meets or exceeds IPC-A-610 Class II
MECHANICAL OUTLINE - Open Frame:
Through-hole
Surface Mount
Note: keep out area should be free of copper traces
www.dcdc.com
603-893-2330
- 14 -
Technical Datasheet
CP40_1180018
MECHANICAL OUTLINE – Encapsulated Module:
www.dcdc.com
603-893-2330
- 15 -
Technical Datasheet
CP40_1180018
Ordering Information:
Product
Series
Package
Configuration
No. of
Outputs
Output
Voltage
Output
Current
Input
Voltage
Enable logic
option
SMT Option
CP40
B or C
1
1
800
18
N or P
S
9 – 36V
N = Negative
P = Positive
Blank = No
Enable or
Trim Pin
Surface
Mount
40W 1x1
B = Open Frame
1 output
C = Encapsulated
5V
8.0A
Rev 1.11, 1-March-21
www.dcdc.com
603-893-2330
- 16 -
