LRS3120x1A5xxxW
18-75V Input, 12V/1.5A Output
Leading the Advancement of Power Conversion
12V 1.5A 1X1 Isolated Converter
Features
● High efficiency, 87% (12V/1.5A)
● Optimal thermal performance
● Industry standard footprint and pin out
● Low profile, 0.39” (9.91mm)
● Robust stability
● Monotonic start-up
● Fixed frequency operation
● Basic Insulation, 2250Vdc input-to-output
isolation
● Designed to meet UL 60950-1 2nd edition †
Options
● Negative/Positive enable logic
● Auto-restart after fault shutdown
● Various pin lengths
Part Numbering System
LRS
3
120
Series
Name:
Input
Voltage:
Output
Voltage:
Enabling
Logic:
Rated
Output
Current:
LRS
3: 18-60V
or 18-75V
Unit: 0.1V
120:12V
P: positive
N:negative
Unit: A
1A5:1.5A
5
1A5
Pin Length
Options:
Electrical
Options:
K:0.110"
N:0.145"
R:0.180"
0:latch-up
2:auto-restart
Mechanical Options
Lead-free,
(ROHS-6 Compliant)
5: open frame
W
Suffix
W:18-75V
Input voltage
UL is a registered trademark of Underwriters Laboratory Inc.
Datasheet
LRS3120x1A5xxxW
06-23-2015
1
LRS3120x1A5xxxW
Absolute Maximum Ratings
Excessive stresses over these absolute maximum ratings can cause permanent damage to the converter.
Operation should be limited to the conditions outlined under the Electrical Specification Section.
Parameter
Input Voltage (continuous)
Input Voltage (continuous, non-operating)
Operating Ambient Temperature
(See Thermal Consideration section)
Storage Temperature
Symbol
Min
Max
Unit
Vi
Vi
-0.5
75
100
Vdc
Vdc
To
-40
85*
˚C
Tstg
-55
125
˚C
* Derating curves provided in this datasheet end at 85ºC ambient temperature. Operation above 85ºC ambient temperature is allowed provided
the temperatures of the key components do not exceed the limit stated in the Thermal Considerations section.
Electrical Specifications
These specifications are valid over the converter’s full range of input voltage, resistive load, and temperature unless
noted otherwise.
Input Specifications
Parameter
Input Voltage
Input Current
Quiescent Input Current (Typical Vin)
Standby Input Current
Input Reflected-ripple Current, Peak-to-peak
(5 Hz to 20 MHz, 12 μH source impedance)
Input Ripple Rejection (120 Hz)
Input Turn-on Voltage Threshold
Input Turn-off Voltage Threshold
Input Voltage ON/OFF Hysteresis
Output Specifications
Parameter
Output Voltage Set Point
(Typical Vin; Io = Io,max; Ta = 25°C)
Output Voltage Set Point (over all conditions)
Output Regulation:
Line Regulation (Over full input range, Io = 1/2 of load)
Load Regulation (Io = Io,min to Io,max, typical Vin)
Temperature (Ta = -40°C to 85 °C)
Output Ripple and Noise Voltage
RMS
Peak-to-peak (5 Hz to 20 MHz bandwidth, Vin = 36V)
External Load Capacitance
Output Current
Output Power
Efficiency
(Typical Vin; Io = Io,max, TA = 25ºC)
Startup Delay (from the toggle of the enable to Vo reaching 10% of
set point; Typical Vin; Io=Io,max; Ta = 25ºC)
Startup Time (Vo from 10% to 90% of output set point; Typical Vin;
Io = Io,max; Ta = 25ºC)
Datasheet
LRS3120x1A5xxxW
Symbol
Min
Typical
Max
Unit
Vi
Ii,max
Ii,Qsnt
Ii,stdby
18
36
16
3
75
3
Vdc
A
mA
mA
10
mA
16
14
1
17
15
2
18
16
4
dB
V
V
V
Symbol
Min
Typical
Max
Unit
11.8
12.0
12.2
Vdc
11.7
12.3
Vdc
0.05
0.05
15
0.2
0.2
50
%Vo
%Vo
mV
Io
Po
30
100
500
1.5
18
mVrms
mVp-p
μF
A
W
η
87
5
10
ms
10
15
ms
06-23-2015
2
LRS3120x1A5xxxW
Output Specifications (continued)
Parameter
Symbol
Total turn on time (from the toggle of the enable to Vo reaching in
regulation of the output set point; Overall condition)
Output Over Current Protection trip point/Iomax
Output Over Voltage trip point
Output ripple frequency
Dynamic Response
(Typical Vin; Ta = 25°C; Load transient 0.1A/μs)
Load step from 50% to 75% of full load:
Peak deviation
Settling time (to 10% band of Vo deviation)
Load step from 50% to 25% of full load
Peak deviation
General Specifications
Parameter
Io,cli
Min
Typical
Max
Unit
15
ms
105
115
370
125
400
150
140
430
%Io
%Vo
kHz
3
200
%Vo
μs
3
200
%Vo
μs
Symbol
Min
Typical
Max
Unit
Logic Low – Module On
Logic High – Module Off
Logic High – Module On
Logic Low – Module Off
VON/OFF
ION/OFF
VON/OFF
ION/OFF
1.2
1.0
15
50
V
mA
V
μA
80
10
1200
110
%Vo
pF
MΩ
Remote Enable
Negative Logic:
Positive Logic:
Logic Low:
Logic High:
ION/OFF = 1.0mA
VON/OFF = 0.0V
ION/OFF = 0.0μA
Leakage Current
Output Voltage Trim Range
Isolation Capacitance
Isolation Resistance
Calculated MTBF (Telecordia SR-332, 2011, Issue 3), full load,
40°C, typical input voltage
12.0
106 -hour
Efficiency (%)
Power Loss (W)
Characteristic Curves
Output Current (A)
Output Current (A)
o
Figure 1. Efficiency vs. Load Current (25 C)
Datasheet
LRS3120x1A5xxxW
o
Figure 2. Power Loss vs. Load Current (25 C)
06-23-2015
3
LRS3120x1A5xxxW
Output Control
(2V/div)
Output Control
(2V/div)
Output Voltage
(5V/div)
Output Voltage
(5V/div)
Time – t (10ms/div)
Time - t (10ms/div)
Figure 4. Start-Up from Enable Control
(Typical Vin, zero load)
Figure 3. Start-Up from Enable Control
(Typical Vin, full load )
Vin = 18V
Vin = 36V
Vin = 75V
Input Current Ripple
(20mA/div)
Output Voltage Ripple
(50mV/div)
Vin = 18V
Time – t (1μs/div)
Vin = 36V
Vin = 75V
Time – t (2μs/div)
Figure 6. Input Reflected Ripple Current at Full Load
Output Current
0.5A/div
Output Current
0.5A/div
Output voltage
200mV/div
Output Voltage
200mV/div
Figure 5. Output Ripple Voltage at Full Load
Time – t (200μs/div)
Figure 7. Transient Load Response
Top: Output voltage deviation
Bottom: Load current step (-25% full load)
Test Cond.: Output current at 50% full load, typical
Vin, slew rate 0.1A/µs
Datasheet
LRS3120x1A5xxxW
Figure 8. Transient Load Response
Bottom: Load current step (+25% full load)
06-23-2015
4
LRS3120x1A5xxxW
Input Current (A)
Output Voltage (V)
Input Voltage (V)
Output Current (A)
Figure 9. Input Characteristics
Figure 10. Output Characteristics
155℃
Output Current (A)
140℃
110℃
80℃
60℃
Airflow Direction
3
2
4
Ambient Air Temperature (°C)
Figure 11. Current Derating Curve
under Nature Convection
(open frame unit using soldered interface)
Figure 12. Thermal Image for Airflow Direction 3
(1.5A output, 55°C ambient, 200 LFM, typical Vin,
Datasheet
Air Flow
1
LRS3120x1A5xxxW
06-23-2015
5
LRS3120x1A5xxxW
Feature Descriptions
Remote ON/OFF
The converter can be turned on and off by changing
the voltage or resistance between the ON/OFF pin
and Vin(-).
The LRS3 Series of converters is
available with factory selectable positive logic or
negative enabling logic.
For the negative control logic, the converter is ON
when the ON/OFF pin is at a logic low level and OFF
when the ON/OFF pin is at a logic high level. With
positive control logic, the converter is ON when the
ON/OFF pin is at a logic high level and OFF when the
ON/OFF pin is at a logic low level.
With the internal pull-up circuitry, a simple external
switch between the ON/OFF pin and Vin(-) can control
the converter. A few example circuits for controlling
the ON/OFF pin are shown in Figures 13, 14 and 15.
The logic low level is from 0V to 1.2V and the
maximum sink current during logic low is 1mA. The
external switch must be capable of maintaining a
logic-low level while sinking up to this current. The
logic high level is from 3.5V to 15V. The converter
has an internal pull-up circuit that ensures the
ON/OFF pin at a high logic level when the leakage
current at ON/OFF pin is no greater than 50μA.
TTL/
CMOS
ON/OFF
Vin(−)
Figure 15. Direct Logic Drive
Output Voltage Adjustment (Trim)
The trim pin allows the user to adjust the output
voltage set point. To increase the output voltage, an
external resistor is connected between the TRIM pin
and Vout(-). To decrease the output voltage, an
and Vout (+). The output voltage trim range is 80% to
110% of its specified nominal output voltage. The
circuit configuration for trim down operation is shown
in Figure16.
To decrease the output voltage, the value of the
external resistor should be
Rdown = (
(Vadj − 2.5) ⋅10
− 0.511)(kΩ)
12 − Vadj
Where
ON/OFF
Vadj= Adjusted Output Voltage
The circuit configuration for trim up operation is shown
in Figure17.To increase the output voltage, the value
of the resistor should be
Vin(−)
Rup = (
Figure 13. Opto Coupler Enable Circuit
2.5 ⋅ 10
− 0.511)(kΩ)
Vadj − 12
Where
ON/OFF
Vin(−)
As the output voltage at the converter output terminals
are higher than the specified nominal level when using
the trim up and/or remote sense functions, it is
important not to exceed the maximum power rating of
the converter as given in the Specifications table.
Figure 14. Open Collector Enable Circuit
Datasheet
LRS3120x1A5xxxW
06-23-2015
6
LRS3120x1A5xxxW
Output Over-Voltage Protection (OVP)
Load
Vo(+)
TRIM
Rdown
With the auto-restart version, the converter will
operate in a hiccup mode (repeatedly try to restart)
until the cause of the over-voltage condition is cleared.
Vo(−)
Figure 16. Circuit to Decrease Output Voltage
Vo(+)
Rup
Load
TRIM
With the latch-off version, the converter will latch off
when the output voltage exceeds the limit. The
converter can be restarted by toggling the ON/OFF
switch or recycling the input voltage.
Vo(−)
Figure 17. Circuit to Increase Output Voltage
Over Temperature Production (OTP)
With the latch-off version, the converter will shut down
and latch off if an over-temperature condition is
detected. The converter has a temperature sensor
located at a carefully selected position in the converter
circuit board, which represents the thermal condition
of key components of the converter. The thermal
shutdown circuit is designed to turn the converter off
when the temperature at the sensor reaches 120°C.
The module can be restarted by toggling the ON/OFF
resume operation after the converter cools down.
Input Under-Voltage Lockout
This feature prevents the converter from starting until
the input voltage reaches the turn-on voltage
threshold, and keeps the converter running until the
input voltage falls below the turn-off voltage threshold.
Both turn-on and turn-off voltage thresholds are
defined in the Input Specifications table.
The
hysteresis prevents oscillations.
Output Over-Current Protection (OCP)
This converter can be ordered in either latch-off or
auto-restart version upon OCP, OVP, and OTP.
when the load current exceeds the limit.
The
until the cause of the over-current condition is cleared.
Datasheet
LRS3120x1A5xxxW
Design Considerations
Input Source Impedance
As with any DC/DC converter, the stability of the
LRS3 converters may be compromised if the source
impedance is too high or inductive. It’s desirable to
keep the input source ac-impedance as low as
possible. Although the converters are designed to be
stable without adding external input capacitors for
typical source impedance, it is recommended to add a
33µF low ESR electrolytic capacitors at the input of
the converter, which reduces the potential negative
impact of the source impedance on the converter
stability. These electrolytic capacitors should have
sufficient RMS current rating over the operating
temperature range.
The converter is designed to be stable without
additional output capacitors. To further reduce the
output voltage ripple or improve the transient
response, additional output capacitors are often used
06-23-2015
7
LRS3120x1A5xxxW
in applications. When additional output capacitors are
used, a combination of ceramic capacitors and
tantalum/polymer capacitors shall be used to provide
good filtering while assuring the stability of the
converter.
Safety Considerations
The LRS3 Series of converters are designed in
accordance with EN 60950 Safety of Information
Technology Equipment Including Electrical Equipment.
Flammability ratings of the PWB and plastic
components in the converter meet 94V-0.
To protect the converter and the system, an input line
fuse is highly recommended on the un-grounded input
end.
temperature measurement method and ambient
temperature measurement point.
The thermal
derating curves in this datasheet are obtained using a
PWB fixture board and a PWB spacing board with no
opening, a board-to-board spacing of 1”, and the
converter is soldered to the test board with thermal
relieves.
Note that the natural convection condition was
measured at 0.05 m/s to 0.15 m/s (10ft./min. to 30
ft./min.
Heat Transfer
With single-board DC/DC converter designs,
convection heat transfer is the primary cooling means
for converters without a baseplate. Therefore, airflow
speed should be checked carefully for the intended
operating environment. Increasing the airflow over
the converter enhances the heat transfer via
convection.
The LRS3 Series of converters can operate in various
thermal environments. Due to the high efficiency and
optimal heat distribution, these converters exhibit
excellent thermal performance.
Figure 18 shows a recommended temperature
monitoring point for open frame modules. For reliable
operation, the temperature at this location should not
continuously exceed 120 °C.
The maximum allowable output power of any power
converter is usually determined by the electrical
design and the maximum operating temperature of its
components. The LRS3 Series of converters have
been tested comprehensively under various
conditions to generate the derating curves with the
consideration for long term reliability.
The thermal derating curves are highly influenced by
the test conditions. One of the critical variables is the
interface method between the converter and the test
fixture board. There is no standard method in the
industry for the derating tests. Some suppliers use
sockets to plug in the converter, while others solder
the converter into the fixture board. It should be
noticed that these two methods produce significantly
different results for a given converter. When the
converter is soldered into the fixture board, the
thermal performance of the converter is significantly
improved compared to using sockets due to the
reduction of the contact loss and the thermal
impedance from the pins to the fixture board. Other
factors affecting the results include the board spacing,
construction (especially copper weight, holes and
openings) of the fixture board and the spacing board,
Datasheet
LRS3120x1A5xxxW
Figure 18. Temperature Monitoring Location
EMC Considerations
The EMC performance of the converter is related to
the layout and filtering design of the customer board.
Careful layout and adequate filtering around the
converter are important to confine noise generated by
the switching actions in the converter and to optimize
system EMC performance.
06-23-2015
8
LRS3120x1A5xxxW
Mechanical Information
Pin
Name
Function
1
ON/OFF
Remote control
2
Vin(-)
Negative input
3
Vin(+)
Positive input
4
Vout(+)
Positive output
5
TRIM
Output voltage adjust
6
Vout(-)
Negative output
Notes
1)
2)
3)
4)
5)
Datasheet
LRS3120x1A5xxxW
All dimensions in mm (inches)
Tolerances: .x + .5 (.xx + 0.02)
.xx + .25 (.xxx + 0.010)
Regular input and function pins are 1.02mm (0.040”) dia. with +/0.10mm (0.004”) tolerance; the standoff shoulders are 2.00mm
(0.078”) dia. with +/- 0.15mm (0.006”) tolerance.
Output pins are 1.02mm (0.040”) dia. with +/- 0.10mm (0.004”)
tolerance; the standoff shoulders are 2.00mm (0.078”) dia. with +/0.15mm (0.006”) tolerance.
All pins are coated with 90%/10% solder, Gold, or Matte Tin finish
with Nickel under plating.
Workmanship meets or exceeds IPC-A-610 Class II
06-23-2015
9
