G12P10TE
P-Channel Enhancement Mode Power MOSFET
Description
The G12P10TE uses advanced trench technology to provide
excellent RDS(ON) , low gate charge. It can be used in a wide
variety of applications.
General Features
l
l
l
l
l
VDS
ID (at VGS = -10V)
RDS(ON) (at VGS = -10V)
RDS(ON) (at VGS = -4.5V)
100% Avalanche Tested
-100V
-12A
< 200mΩ
< 220mΩ
Schematic diagram
l RoHS Compliant
l ESD (HBM)>7.0KV
Application
l Power switch
l DC/DC converters
TO-220
Ordering Information
Device
Package
Marking
Packaging
G12P10TE
TO-220
G12P10
50pcs/Tube
Absolute Maximum Ratings TC = 25ºC, unless otherwise noted
Parameter
Symbol
Value
Unit
VDS
-100
V
ID
-12
A
IDM
-48
A
Gate-Source Voltage
VGS
±20
V
Power Dissipation
PD
44.6
W
EAS
25
mJ
TJ, Tstg
-55 To 150
ºC
Symbol
Value
Unit
Thermal Resistance, Junction-to-Ambient
RthJA
55
ºC/W
Maximum Junction-to-Case
RthJC
2.8
ºC/W
Drain-Source Voltage
Continuous Drain Current
Pulsed Drain Current
(note1)
Single pulse avalanche energy
(note2)
Operating Junction and Storage Temperature Range
Thermal Resistance
Parameter
www.gofordsemi.com
TEL:0755-29961263
FAX:0755-29961466(A1744-V1.1)
G12P10TE
Specifications TJ = 25ºC, unless otherwise noted
Parameter
Symbol
Test Conditions
Drain-Source Breakdown Voltage
V(BR)DSS
Zero Gate Voltage Drain Current
Gate-Source Leakage
Value
Unit
Min.
Typ.
Max.
VGS = 0V, ID = -250µA
-100
V
IDSS
VDS = -100V, VGS = 0V
-1
μA
IGSS
VGS = ±20V
±10
uA
Gate-Source Threshold Voltage
VGS(th)
VDS = VGS, ID = -250µA
-1
-1.6
-2.5
V
Drain-Source On-Resistance
RDS(on)
VGS = -10V, ID = -6A
170
200
VGS = -4.5V, ID = -6A
180
220
Forward Transconductance
gFS
VDS = -15V,ID = -6A
12
1717
50
46
33
4
7
52
12
38
28
Static Parameters
mΩ
S
Dynamic Parameters
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Total Gate Charge
Qg
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
Turn-on Delay Time
td(on)
Turn-on Rise Time
tr
Turn-off Delay Time
td(off)
Turn-off Fall Time
VGS = 0V,
VDS = -50V,
f = 1.0MHz
VDD = -50V,
ID = -6A,
VGS = -10V
VDD = -50V,
ID = -6A,
RG = 9Ω
tf
pF
nC
ns
Drain-Source Body Diode Characteristics
Continuous Body Diode Current
IS
TC = 25ºC
-12
A
Body Diode Voltage
VSD
TJ = 25ºC, ISD = -6A, VGS = 0V
-1.2
V
Reverse Recovery Charge
Qrr
35
nC
Reverse Recovery Time
Trr
46
ns
IF = -6A, VGS = 0V
di/dt=-500A/us
Notes
1.
Repetitive Rating: Pulse width limited by maximum junction temperature
2.
EAS condition : Tj=25℃ ,VDD=-50V,VGS=-10V,L=0.5mH,Rg=25Ω
3.
Identical low side and high side switch with identical RG
www.gofordsemi.com
TEL:0755-29961263
G12P10TE
Gate Charge Test Circuit
Switch Time Test Circuit
EAS Test Circuit
www.gofordsemi.com
TEL:0755-29961263
G12P10TE
Typical Characteristics TJ = 25ºC, unless otherwise noted
Figure 1. Output Characteristics
Figure 2. Transfer Characteristics
8
8
-10V
6
5
-2.6V
4
-2.4V
3
2
VGS= -2.2V
1
VDS= -5V
7
-3V
-4.5V
-ID, Drain Current (A)
7
2
6
5
4
25℃
3
2
1
3
-VDS, Drain-to-Source Voltage (V)
-Vgs Gate-Source Voltage(V)
RDS(on), On-Resistance (mΩ)
225
VGS= -4.5V
175
VGS= -10V
125
100
2
4
6
8
10
12
-ID-Drain Current (A)
1500
1000
500
Coss
Crss
10
40
50
-VDS Drain-Source Voltage(V)
www.gofordsemi.com
VDD = -50V
ID = -6A
8
6
4
2
40
-Is, Reverse Drain Current (A)
Capacitance(pF)
Ciss
Figure 6. Source-Drain Diode Forward
2500
Qg Gate Charge(nC)
Figure 5. Capacitance
2000
4
10
Figure 4. Gate Charge
250
150
2
-VGS, Gate-to-Source Voltage (V)
Figure 3.Drain Source On Resistance
200
1
60
TEL:0755-29961263
-VSD, Source-to-Drain Voltage (V)
G12P10TE
Figure 10. Safe Operation Area
VGS = -10V
ID = -6A
-ID, Drain Current(A)
RDS(on), (Normalized)
Figure 7. Drain-Source On-Resistance
ZthJC, Thermal Impedance (ºC/W)
TJ, Junction Temperature (ºC)
TJ(MAX)=150℃
TC=25℃
-VDS, Drain-Source Voltage(V)
Figure 9. Normalized Maximum Transient
Thermal Impedance
Pulse Width (s)
www.gofordsemi.com
TEL:0755-29961263
G12P10TE
TO-220 Package Information
www.gofordsemi.com
TEL:0755-29961263
很抱歉,暂时无法提供与“G12P10TE”相匹配的价格&库存,您可以联系我们找货
