GC20N65F
N-Channel Enhancement Mode Power MOSFET
Description
The GC20N65F uses advanced trench technology to
provide excellent RDS(ON) , low gate charge. It can be used in
a wide variety of applications.
General Features
l
l
l
l
VDS
ID (at VGS = 10V)
RDS(ON) (at VGS = 10V)
100% Avalanche Tested
650V
20A
190mΩ
Schematic diagram
l RoHS Compliant
Application
l Power switch
l DC/DC converters
TO-220F
Ordering Information
Device
Package
Marking
Packaging
GC20N65F
TO-220F
GC20N65
50psc/Tube
Absolute Maximum Ratings TC = 25ºC, unless otherwise noted
Parameter
Symbol
Value
Unit
VDS
650
V
ID
A
IDM
80
A
Gate-Source Voltage
VGS
±30
V
Power Dissipation
PD
40
W
EAS
484
mJ
TJ, Tstg
-55 To 150
ºC
Symbol
Value
Unit
Thermal Resistance, Junction-to-Ambient
RthJA
65
ºC/W
Maximum Junction-to-Case
RthJC
3.1
ºC/W
Drain-Source Voltage
Continuous Drain Current
Pulsed Drain Current
(note1)
Single pulse avalanche energy
(note2)
Operating Junction and Storage Temperature Range
Thermal Resistance
Parameter
www.gofordsemi.com
TEL:0755-29961263
FAX:0755-29961466(A1098)
GC20N65F
Specifications TJ = 25ºC, unless otherwise noted
Parameter
Symbol
Test Conditions
Drain-Source Breakdown Voltage
V(BR)DSS
Zero Gate Voltage Drain Current
Gate-Source Leakage
Value
Unit
Min.
Typ.
Max.
VGS = 0V, ID = 250µA
650
V
IDSS
VDS = 650V, VGS = 0V
1
μA
IGSS
VGS = ±30V
±100
nA
Gate-Source Threshold Voltage
VGS(th)
VDS = VGS, ID = 250µA
2
3.5
4
V
Drain-Source On-Resistance
RDS(on)
VGS = 10V, ID = 10A
148
190
mΩ
Forward Transconductance
gFS
VGS = 5V, ID = 10A
16
S
1603
38
3
39
9
16
77
36
120
63
Static Parameters
Dynamic Parameters
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Total Gate Charge
Qg
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
Turn-on Delay Time
td(on)
Turn-on Rise Time
tr
Turn-off Delay Time
td(off)
Turn-off Fall Time
VGS = 0V,
VDS = 100V,
f = 1.0MHz
VDD = 480V,
ID = 10A,
VGS = 10V
VDD = 400V,
ID = 10A,
RG = 25Ω
tf
pF
nC
ns
Drain-Source Body Diode Characteristics
Continuous Body Diode Current
IS
TC = 25ºC
A
Body Diode Voltage
VSD
TJ = 25ºC, ISD = 10A, VGS = 0V
1.2
V
Reverse Recovery Charge
Qrr
7.5
nC
Reverse Recovery Time
Trr
IF = 10A, VGS = 0V
di/dt=100A/us
375
ns
Notes
1.
Repetitive Rating: Pulse width limited by maximum junction temperature
2.
EAS condition : Tj=25℃ ,VDD=50V,VGS=10V,L=0.5mH,Rg=25Ω
3.
Identical low side and high side switch with identical RG
www.gofordsemi.com
TEL:0755-29961263
GC20N65F
Gate Charge Test Circuit
Switch Time Test Circuit
EAS Test Circuit
www.gofordsemi.com
TEL:0755-29961263
GC20N65F
Typical Characteristics TJ = 25ºC, unless otherwise noted
Figure 1. Output Characteristics
12
ID, Drain Current (A)
14
10V
6.5V
6V
10
14
Figure 2. Transfer Characteristics
5.5V
8
6
5V
4
2
2
3
Vgs Gate-Source Voltage(V)
RDS(on),On-Resistance(mΩ)
VGS= 10V
80
40
10
15
2
4
6
8
10
10
VDD =480V
ID = 10A
8
6
4
2
ID-Drain Current(A)
40
50
Qg Gate Charge(nC)
Figure 5. Capacitance
Figure 6. Source-Drain Diode Forward
Is, Reverse Drain Current (A)
16000
14000
Capacitance(pF)
Figure 4. Gate Charge
120
12000
10000
8000
25℃
Figure 3. Drain Source On Resistance
160
Coss
Ciss
2000
4
VGS, Gate-to-Source Voltage (V)
200
4000
6
VDS, Drain-to-Source Voltage (V)
240
6000
8
280
2
VGS= 4.5V
VDS= 5V
12
Crss
40
50
60
VDS Drain-Source Voltage(V)
www.gofordsemi.com
TEL:0755-29961263
VSD, Source-to-Drain Voltage (V)
GC20N65F
VGS = 10V
ID = 10A
Figure 8. Safe Operation Area
ID, Drain Current(A)
RDS(on), (Normalized)
Figure 7. Drain-Source On-Resistance
TJ, Junction Temperature (ºC)
VDS, Drain-Source Voltage(V)
ZthJC, Thermal Impedance (ºC/W)
Figure 9. Normalized Maximum Transient
Thermal Impedance
3.1°C/W
Pulse Width (s)
www.gofordsemi.com
TEL:0755-29961263
GC20N65F
TO-220F Package Information
www.gofordsemi.com
TEL:0755-29961263
很抱歉,暂时无法提供与“GC20N65F”相匹配的价格&库存,您可以联系我们找货
