MF254V-12-04-1000-H70 数据手册
1
2
3
Technical Data
Materlal:
Pin(outer sleeve):Brass,machined CuZn38Pb2
Plating(outer sleeve):
Tin Plated:2μm/80μ"NI,5μm/200μ"Sn
Gold Plated:2μm"/80μ"Ni,0.8μ" gold
Plating(Contact ):2 μm/80μ"NI,gold or Tin plated
Insuiator:PPS UL94V-0
Cllp(Contact 6 Flnger):Beryllium copper,heat teated
4
6
5
Electrical:
Current rating:3Amps/contact max.
Contact resistance:≤4m Ω/contact
Insuiation resistance:≥1000M Ω at V=100V
Operaing voitage:60VAC/DC
Mechanical:
Average Insertion force with steel pin of ∅0.66mm/0.38":<140g
Average withdrawal force with steel pin of ∅0.66mm/0.38":>25g
Mechanical lige cycle:min 200
Operaling temperature:-40°C to+105°C
Soldering temperature:+255°C
Critical Dimensions: *
P.C.B LAYOUT
2.54mm Machined Female Header
MF254V-12-xx-1000-H70
MF254V-12-04-1000-H70 价格&库存
很抱歉,暂时无法提供与“MF254V-12-04-1000-H70”相匹配的价格&库存,您可以联系我们找货
