LA3484A
36V, 3A, 520KHz, Synchronous, Step-Down Converter
LA3484A
Overview
Features
The LA3484A is an
easy
to
use
synchronous
stepdown Buck. Which
integrated low on
resistance high-side
eSOP8L
and low-side power
MOSFETs.
The
LA3484A can deliver 3A of output current
efficiently with constant on time (COT)
control for fast loop response.
The LA3484A achieves high power
conversion efficiency over a wide load
range by scaling down the switching
frequency under light-load conditions to
reduce switching and gate driving losses.
The LA3484A has built-in protection
features, such as cycle-by-cycle current
limit, hiccup mode short-circuit protection,
FB open short protection and thermal
shutdown in case of excessive power
dissipation. The LA3484A is available in a
space-saving eSOP8L package.
4.5V to 36V Wide Input Range
3A Continuous Output Current
120mΩ/80mΩ
Internal
Power
MOSFETs
Constant On Time Control for Fast
Loop Response
520KHz Switching Frequency
Audio Mode at Light Load
Support Up to 98% Large Range Duty
Cycle
Internal Soft Start
Output Voltage adjustable from 0.6V
Support Pre-Biased Output Startup
Full
Protection,
Over
Current
Protection and Hiccup, Output Over
Voltage Protection, FB Open Short
Protection,
Over
Temperature
Protection
Available in an eSOP8L Package
Applications
Robots
Home Appliance and Whitegoods
Multi-functional Printer
Soundbar
Industrial Control
Typical Application
C4 0.1uF
VIN
C1
10uF
VIN
R3
300k
BST
LA3484A
EN
10uH
Vout: 5V/3A
C2
47uF
R1
15K
FB
GND
Rev.0.81
2021/05
L1
SW
R2
2K
1
LA3484A
Package Mark and Order Information
Device
LA3484A
Package
eSOP8L
Temperature range
-40 to 150℃
Packaging Type
T/R 2500pcs/roll
Purchase Contact
sales@latticeart.com
Pin Diagram
2.VIN
3.SW
4.GND
LA3484A
LLLLLLL
WWY
1.BST
8.NC
7.EN
6.NC
LA3484A: Product code
LLLLLLL: Lot number
WWY: Date Code
5.FB
9. Exposed Pad
Pin Description
Pin No.
Symbol
1
BST
2
VIN
3
SW
4
GND
5
FB
Feedback input to the convertor. Connect a resistor divider to
set the output voltage. Never short this terminal to ground
during operation.
6,8
NC
Not Connected.
7
EN
Precision enable input to the convertor. Do not float. High = on,
Low = off. Can be tied to VIN by a resistor. Precision enable
input allows adjustable UVLO by external resistor divider.
9
EP
Exposed Pad. Connect this pad to GND.
Rev.0.81
2021/05
Pin Description
Bootstrap capacitor connection for high-side FET driver.
Connect a high quality 100nF capacitor from this pin to the SW
pin.
Supply input terminal to internal bias LDO and high-side FET.
Connect to input supply and input bypass capacitors CIN. Input
bypass capacitors must be directly connected to this pin and
GND.
Switching output of the convertor. Internally connected to
source of the high-side FET and drain of the low-side FET.
Connect to power inductor.
Power Ground terminal.
2
LA3484A
Block Diagram
2.4ms
SS
0.6V
Rev.0.81
2021/05
3
LA3484A
Absolute Maximum Ratings (Note 1)
TA=250C, unless otherwise specified.
Symbol
Definition
VIN
VIN to GND
SW
SW to GND
EN
BST
All Other
Pins
TSTG
Tj
Max Input current to EN pin
BST to SW
Storage temperature
Junction temperature
Ratings
-0.3~38
-0.7 (-5V in
10ns)~VIN + 0.7
100(2)
-0.3~6
Unit
V
-0.3~6
V
V
μA
V
o
-55 to150
-40 to150
o
C
C
Note 1: Stresses beyond those listed under “absolute maximum ratings” may cause permanent damage to
the device. These are not tested at manufacturing.
Note 2: For details on ENs ABS max rating, please refer to the Enable Control section.
Recommended Operating Conditions
Symbol
BST
FB
EN
VIN
Definition
BST to SW
FB to GND
EN to GND
VIN to GND
VOUT
VOUT to GND
IOUT
Max Continuous Output Current
Ratings
4~5
0~1
0~5
4.5~36
0.6~VIN*DMAX(3) or
VOUT
很抱歉,暂时无法提供与“LA3484A”相匹配的价格&库存,您可以联系我们找货
