BZX84B2V4-BZX84B51
Surface Mount Zener Diodes
B:2% tolerance
SOT-23
Features
Planar Die Construction.
350mw Power Dissipation.
Zener Voltages From 2.4V -51V
Ideally Suited For Automated Assembly Prcesses.
Applications
Dimensions in inches and (millimeters)
350Mw Surface mount zener diode
Ordering Information
Type No.
BZX84B2V4-BZX84B51
Marking
Package Code
See Table on page2
SOT-23
MAXIMUM RATING @ Ta=25℃ unless otherwise specified
Characteristic
Symbol
Value
Unit
Power Dissipation
Pd
350
mW
Thermal Resistance, Junction to Ambient Air
RθjA
357
℃/W
Operating and Storage Temperature Range
Tj,Tstg
-65 to+150
ht t p : //
Revision:20170701-P1
www.lgesemi .c o m
mail:lge@lgesemi.com
BZX84B2V4-BZX84B51
ELECTRICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified
Maximum Zener
Zerner Voltage Range
Reverse
Impedance
Marking
Maximum
Current
Type Number
Code
VZ@IZT
IZT
ZZT@IZT
ZZK@IZK
IR
VR
Nom(V)
Min(V)
Max(V)
(mA)
(Ω)
(Ω)
(mA)
(μA)
(V)
BZX84B2V4
Z50
2.4
2.35
2.45
5
100
275
1
50
1
BZX84B2V7
Z51
2.7
2.65
2.75
5
100
600
1
BZX84B3V0
Z52
3.0
2.94
3.06
5
95
600
1
10
1
BZX84B3V3
Z53
3.3
3.23
3.37
5
95
600
1
5
1
BZX84B3V6
Z54
3.6
3.53
3.67
5
90
600
1
5
1
BZX84B3V9
Z55
3.9
3.82
3.98
5
90
600
1
3
1
BZX84B4V3
Z56
4.3
4.21
4.39
5
90
600
1
3
1
BZX84B4V7
Z57
4.7
4.61
4.79
5
80
500
1
3
2
BZX84B5V1
Z58
5.1
5
5.2
5
60
480
1
2
2
BZX84B5V6
Z59
5.6
5.49
5.71
5
40
400
1
1
2
BZX84B6V2
Z60
6.2
6.08
6.32
5
10
150
1
3
4
BZX84B6V8
Z61
6.8
6.66
6.94
5
15
80
1
2
4
BZX84B7V5
Z62
7.5
7.35
7.65
5
15
80
1
1
5
BZX84B8V2
Z63
8.2
8.04
8.36
5
15
80
1
0.7
5
BZX84B9V1
Z64
9.1
8.92
9.28
5
15
100
1
0.5
6
BZX84B10
Z65
10
9.8
10.2
5
1
0.2
7
BZX84B11
Z66
11
10.8
11.2
5
1
0.1
8
BZX84B12
Z67
12
11.8
12.2
5
25
150
1
0.1
8
BZX84B13
Z68
13
12.7
13.3
5
30
170
1
0.1
8
BZX84B15
Z69
15
14.7
15.3
5
30
200
1
0.05
10.5
BZX84B16
Z70
16
15.7
16.3
5
40
200
1
0.05
11.2
BZX84B18
Z71
18
17.6
18.4
5
45
225
1
0.05
12.6
BZX84B20
Z72
20.4
5
55
225
1
0.05
14
ht t p : //
www.lgesemi .c o m
BZX84B2V4-BZX84B51
Maximum Zener
Reverse
Impedance
Marking
Maximum
Current
Type Number
Code
VZ@IZT
IZT
ZZT@IZT
ZZK@IZK
IR
VR
Nom(V)
Min(V)
Max(V)
(mA)
(Ω)
(Ω)
(mA)
(μA)
(V)
BZX84B22
Z73
22
21.6
22.4
5
55
250
1
0.05
15.4
BZX84B24
Z74
24
23.5
24.5
5
70
250
1
0.05
16.8
BZX84B27
Z75
27
26.5
27.5
2
80
300
0.5
0.05
18.9
BZX84B30
Z76
30
29.4
30.6
2
80
300
0.5
0.05
21
BZX84B33
Z77
33
32.3
33.7
2
80
325
0.5
0.05
23.1
BZX84B36
Z78
36
35.3
36.7
2
90
350
0.5
0.05
25.2
BZX84B39
Z79
39
38.2
39.8
2
130
350
0.5
0.05
27.3
BZX84B43
Z80
43
42.1
43.9
2
150
375
0.5
0.05
30.1
BZX84B47
Z81
47
46.1
47.9
2
170
375
0.5
0.05
32.9
BZX84B51
Z82
51
50
52
2
180
400
0.5
0.05
35.7
TYPICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified
ht t p : //
www.lgesemi .c o m
BZX84B2V4-BZX84B51
PACKAGE
SPQ/PCS
CARTON
SPQ/PCS
CARTON
SIZE/CM
CARTON
GW/KG
CARTON
NW/KG
SOT- 23
3000/REEL
90000
40X20X22
5.00
4.00
ht t p : //
www.lgesemi .c o m
很抱歉,暂时无法提供与“BZX84B6V8”相匹配的价格&库存,您可以联系我们找货
