ROTARY CODED SWITCHES (SMD)
RoHS compliant
SH-7000
INTERNAL STRUCTURE
④
①
②
③
⑧
⑨
⑦
⑤
Part name
■ FEATURES
RoHS compliant
Center Common terminal pins location
High digit visibility
Gray code output available
Washable
Resin material is UL Recognized 94V0
⑥
Material
①
Marking cover
Stainless steel (SUS 304)
②
Cover
③
“O” ring
④
Rotor
⑤
Spacer
⑥
Slider contact
⑦
Fixed contact
⑧
Housing
⑨
Terminal pin
Silicone rubber
Polyphenylenesulfide
Copper alloy, Gold-plated
■ PART NUMBER DESIGNATION
S H - 7 0 1 0 T A
Series name
Shape of terminal
Shape of rotor
A: J-hook
B: Gull wing
C:Through hole pins
0:Without knob (Minus slot)
Form of packaging
Code format
1:10 positions, real code
3:10 positions, complementary code
4:10 positions, gray code
5:16 positions, real code
7:16 positions, complementary code
8:16 positions, gray code
※ Please refer to the LIST OF PART NUMBERS when placing orders.
T:Taping (Reel)
M:Magazine
Setting position
0:Top setting
SH-7000
■ CODE FORMAT
16 positions
No. of positions
10 positions
Position
0 1 2 3 4 5 6 7 8 9 A B C D E F
8
Real code
4
2
1
Code
Complementary code
Gray code
8 ●
4 ●
2 ●
2
1
A
J-hook
B
Gull wing
Taping
C
Through hole pins
Taping
Top setting Minus slot
Magazine
Magazine
Magazine
Taping
Form of
packaging
Shape of
terminal
4
Shape of
rotor
● …Contact closed
■ LIST OF PART NUMBERS
Setting
position
1 ●
8
Binary coded decimal
Binary coded hexadecimal
Real code Complementary code Gray code
Pieces in
package
SH-7010TA SH-7030TA
SH-7050TA SH-7070TA
500 pcs./reel
SH-7010MA SH-7030MA
SH-7050MA SH-7070MA
50 pcs./stick
SH-7010TB SH-7030TB SH-7040TB SH-7050TB SH-7070TB SH-7080TB 500 pcs./reel
SH-7010MB SH-7030MB SH-7040MB SH-7050MB SH-7070MB SH-7080MB 50 pcs./stick
SH-7010MC SH-7030MC
SH-7050MC SH-7070MC
50 pcs./stick
: Not manufactured
※ Verify the above part numbers when placing orders.Taping and
magazine version can be supplied only in reel or stick unit.
■ STANDARD SPECIFICATIONS
Circuit type
Operating temperature range
Storage temperature range
Sealing
Net weight
BCD
(Real code, Complementary code, Gray code)
BCH
− 40 ~ 85 °C
− 40 ~ 105 °C (Gray code)
■ ELECTRICAL CHARACTERISTICS
Contact rating
Non-switching
Switching
Minimum
Contact resistance
Insulation resistance
Washable by “O” ring
※ Please refer to page 150,151
Approx. 0.38 g
Dielectric strength
DC50 V 100 mA
DC5 V 100 mA
DC20 mV 1 μ A
100 m Ω maximum
1000 M Ω (DC100 V) minimum
AC250 V, 60 s
SH-7000
■ MECHANICAL CHARACTERISTICS
No. of positions
10, 16
Stepping angle
36° (10 positions)
22.5° (16 positions)
Solderability
245 ± 3 °C, 2 ~ 3 s
Reflow:255 ℃ (Peak temperature)
Reflow : Peak temperature 255 °C
(Please refer to the profile below.)
Soldering heat
(Amplitude)
1.5 mm or
2
(Acceleration)98 m/s ,
Vibration
3 ~ 20 mN·m { 3 ~ 204 gf·cm}
Adjustment torque
■ ENVIRONMENTAL CHARACTERISTICS
Flow : 260 ± 3 °C as the temperature in a pot
of molten solder, immersion from head
of terminal to backside of board,5 ~ 6
s, two times maximum
10-500-10 Hz, 3 directions for 2 h each
490 m/s2, 11 ms
6 directions for 3 times each
Shock
Load life
10000 steps minimum, DC5 V, 100 mA
Humidity
40 °C, Relative humidity 90 ~ 95 %,
240 h
High temp. exposure
85 °C, 96 h
105 °C, 96 h (Gray code)
Low temp. exposure
−40 °C, 96 h
−40 (0.5 h) ~ 85 °C ( 0.5 h ), 5 cycles
−40 (0.5 h) ~ 105 °C ( 0.5 h ), 5 cycles (Gray code)
Thermal shock
Manual soldering:
350 ± 10 °C, 3 ~ 4 s
〈Reflow profile for soldering heat evaluation〉
Shear (adhesion)
5 N {0.51 kgf} 10 s
Substrate bending
Width 90 mm, bend 3 mm, 5 s, 1 time
5 N {0.51 kgf} 10 s
{ } : Reference only
Temperature
Pull-off strength
250
200
150
Peak : 250 0 ℃
+5
Over 230℃
180℃
Pre Heating Zone
150℃
90 ± 30 s
100
30 ± 10 s
50
Heating time
Soldering Zone
リフロー回数:2回 Reflow : two times maximum
■ OUTLINE DIMENSIONS
Unless otherwise specified, tolerance: ± 0.3 (Unit: mm)
● SH-7010A (Real code)
● SH-7030A (Complementary code)
● SH-7010B (Real code)
● SH-7030B (Complementary code)
Production date code
7.3
Marking appears only with complementary code
2.54
2.54
10
② Ⓒ ⑧
0.7 W × 2.8 L × 1D
3.75
0.65 min.
3.75
0.7 W × 2.8 L × 1 D
7.1
5.1
7.5
7.1
② Ⓒ ⑧
④ Ⓒ ①
6 – 0.6
t = 0.15
④ Ⓒ ①
6 – 0.6
t = 0.15
0.65 min.
7.3
2.54
2.54
SH-7000
● SH-7010C (Real code)
● SH-7030C (Complementary code)
● SH-7050A (Real code)
● SH-7070A (Complementary code)
7.3
④ Ⓒ ①
0.7 W × 2.8 L × 1 D
3.5 ± 1
2.54
5.1
3.7
7.5
② Ⓒ ⑧
6 – 0.6
t = 0.15
④ Ⓒ ①
7.1
7.1
7.62 ± 0.5
7.3
2.54
② Ⓒ ⑧
3.75
2.54
2.54
0.7 W × 2.8 L × 1 D
6 – 0.6
t = 0.15
● SH-7050B (Real code)
● SH-7070B (Complementary code)
● SH-7050C (Real code)
● SH-7070C (Complementary code)
7.3
0.65 min.
6 – 0.6
t = 0.15
② Ⓒ ⑧
10
7.1
7.1
④ Ⓒ ①
7.62 ± 0.5
7.3
④ Ⓒ ①
0.7 W × 2.8 L × 1 D
3.7
3.5 ± 1
2.54
2.54
② Ⓒ ⑧
0.7 W × 2.8 L × 1 D
3.75
0.65 min.
2.54
2.54
6 – 0.6
t = 0.15
● SH-7040B (Gray code)
● SH-7080B (Gray code)
10
⑧
0.7 W × 2.8 L × 1 D
3.75
0.65 min.
②
④
0.65 min.
①
7.3
2.54
①
②
5.08
2.54
5 – 0.8
t = 0.15
10
7.1
④
2.54
⑧
0.7 W × 2.8 L × 1 D
3.75
0.65 min.
7.3
5 – 0.8
t = 0.15
7.1
0.65 min.
5.08
2.54
SH-7000
■ RECOMMENDED P.C.B. PAD OUTLINE DIMENSIONS
● A type
● B type
● Gray code
(Unit: mm)
2.5
1
5.08
1
5.08
3
9
11
11
Note) The zero point is the center of mounting.
■ TERMINAL CONNECTION / P.C.B. THROUGH HOLE DIMENSIONS
Top setting (Through hole)
Real code
Complementary
code
hole)
P.C.B. dimensions
(Bottom view)
2.54 ±2.54
0.1 ± 0.1
Terminal pin
layout
(Bottom view)
Real code
8
1
C
C
8
1
4
2
C
C
4
2
Complementary code
8
1
C
C
8
1
4
2
C
C
4
2
2.54 ± 0.1
6 –φ1 hole
2.54 ± 0.1
6 –φ1 hole
SH-7000 case
SH-7000 case
■ PACKAGING SPECIFICATIONS
● Taping version is packaged in 500 pcs. per reel.
Orders will be accepted for units of 500 pcs., i.e., 500, 1000, 1500, pcs., etc.
● Taping version is boxed with one reel (500 pcs.).
Maximum number of consecutive missing pieces = 2
Leader length and reel dimension are shown in the diagrams below:
(Unit: mm)
SH-7000
● Embossed tape dimensions
● Reel dimensions
(Unit: mm)
(Conforms to JIS C 0806-3)
(In accordance with EIAJ ET-7200A)
25.4 ± 1
2 ± 0.5
End
Head
40 mm min.
Direction of feed
φ13 ± 0.2
φ21 ± 0.8
20 pitches min.
Leader
400 mm min.
φ100 ± 1
Empty
Filled
φ330 ± 2
Empty
Part No. label
29.4 ± 1
● SH-70 □ 0TA
● SH-70 □ 0TB
1.75 ± 0.1
(Unit: mm)
12 ± 0.1
2 ± 0.1
4 ± 0.1
4 56
24
23
901
0.4 ± 0.1
11.5 ± 0.1
φ1.5
+0.1
4.3
Direction of feed
● Please order the multiple numbers of the specific packing quantities.
Pieces in package : 50 pcs./stick
● Magazine dimensions
(Unit : mm)
17.2
13.4
マガジンの長さ:390±3mm
magazine length:390±3mm long
很抱歉,暂时无法提供与“SH-7050MC”相匹配的价格&库存,您可以联系我们找货
