QMA6100P
QMA6100P
    QST(矽睿)
    LGA12_2X2MM
    加速度传感器 LGA12_2X2MM 1.71V~3.6V
QMA6100P 数据手册
矽睿 Document #: 13-52-20 Title: QMA6100P Preliminary Datasheet Rev: A1 Abstract 3-Axis Accelerometer QMA6100P Advanced Information The QMA6100P is a three-axis accelerometer. This surface-mount, small sized chip has integrated acceleration transducer with signal conditioning ASIC, sensing tilt, motion, shock and vibration, targeted for applications such as screen rotation, step counting, sleep monitor, gaming and personal navigation in mobile and wearable smart devices. The QMA6100P is based on the state-of-the-art, high resolution single crystal silicon MEMS technology. Along with custom-designed 14-bit ADC ASIC, it offers the advantages of low noise, high accuracy, low power consumption, and offset trimming. The device supports digital interface I2C and SPI. The QMA6100P is in a 2x2x0.95 mm3 surface mount 12-pin land grid array (LGA) package. FEATURES  3-Axis Accelerometer in a 2x2x0.95 mm3 Land Grid Array Package (LGA), guaranteed to operate over a temperature range of -40 °C to +85 °C.  14-Bit ADC with low noise accelerometer sensor  I C Interface with SDR modes. 2 Support SPI digital interface  Built-In Self-Test BENEFIT  Small size for highly integrated products. Signals have been digitized and factory trimmed.  High resolution allows for motion and tilt sensing  High-Speed Interfaces for fast data communications.  Enables low-cost functionality test after assembly in production  Wide range operation voltage (1.71V to 3.6V) and low power consumption (5-44uA low power conversion current)  Automatically maintains sensor’s sensitivity under wide operation voltage range and compatible with battery powered applications  Integrated FIFO with depth of 64 frames RoHS compliant, halogen-free  Environmental protection and wide  Built–in motion algorithm  Low power and easy applications including applications step counting, sleep monitor, gaming and personal navigation 矽睿 Document #: 13-52-20 Title: QMA6100P Preliminary Datasheet Rev: A1 CONTENTS CONTENTS....................................................................................................................................................................................... 2 1 INTERNAL SCHEMATIC DIAGRAM ................................................................................................................................... 3 1.1 Internal Schematic Diagram ..................................................................................................................................... 3 2 SPECIFICATIONS AND I/O CHARACTERISTICS .............................................................................................................. 3 2.1 Product Specifications .............................................................................................................................................. 3 2.2 Absolute Maximum Ratings ..................................................................................................................................... 4 2.3 I/O Characteristics .................................................................................................................................................... 5 3 PACKAGE PIN CONFIGURATIONS ..................................................................................................................................... 5 3.1 Package 3-D View .................................................................................................................................................... 5 3.2 Package Outlines ...................................................................................................................................................... 7 4 EXTERNAL CONNECTION ................................................................................................................................................... 8 4.1 I2C Single Supply connection .................................................................................................................................. 8 4.2 SPI Single Supply connection .................................................................................................................................. 8 5 BASIC DEVICE OPERATION ................................................................................................................................................ 9 5.1 Acceleration sensor................................................................................................................................................... 9 5.2 Power Management .................................................................................................................................................. 9 5.3 Power On/Off Time ................................................................................................................................................ 10 5.4 Communication Bus Interface I2C and Its Addresses ............................................................................................. 11 6 MODES OF OPERATION ..................................................................................................................................................... 11 6.1 Modes Transition .................................................................................................................................................... 11 6.2 Description of Modes ............................................................................................................................................. 12 7 Functions and interrupts .......................................................................................................................................................... 12 7.1 STEP_ INT ............................................................................................................................................................. 13 7.2 DRDY_INT ............................................................................................................................................................ 13 7.3 ANY_MOT_INT .................................................................................................................................................... 14 7.4 SIG_MOT_INT ...................................................................................................................................................... 16 7.5 NO_MOT_INT ....................................................................................................................................................... 16 7.6 TAP_INT ................................................................................................................................................................ 17 7.7 RAISE_INT ............................................................................................................................................................ 18 7.8 FIFO_INT ............................................................................................................................................................... 18 7.9 Interrupt configuration ............................................................................................................................................ 19 8 I2C COMMUNICATION PROTOCOL .................................................................................................................................. 21 8.1 I2C Timings ............................................................................................................................................................ 21 8.2 I2C R/W Operation ................................................................................................................................................. 21 8.3 Serial Peripheral Interface(SPI) .............................................................................................................................. 23 9 REGISTERS ........................................................................................................................................................................... 26 9.1 Register Map .......................................................................................................................................................... 26 9.2 Register Definition ................................................................................................................................................. 28 The information contained herein is the exclusive property of QST, and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of QST. 2 / 37 矽睿 Document #: 13-52-20 Title: QMA6100P Preliminary Datasheet Rev: A1 1 INTERNAL SCHEMATIC DIAGRAM 1.1 Internal Schematic Diagram Sinc FS Offset SDM G-SENSOR CVA INT1 Interrupt Gain INT2 AD0 IF (I2C/SPI) VPMXYZ BG OSC FIFO SDX Reg File SCX OTP SENB GND POWER(A+D) POR Mode FSM SelfTest Block Diagram Table 1. Block Function Block Transducer CVA Interrupt FSM I2C/SPI OSC Power VDD GND Figure 1. RESV2 Function 3-axis acceleration sensor Charge-to-Voltage amplifier for sensor signals Digital interrupt engine, to generate interrupt signal on data conversion, and motion function Finite state machine, to control device in different mode Interface logic data I/O Oscillator for internal operation Power block, including LDO 2 SPECIFICATIONS AND I/O CHARACTERISTICS 2.1 Product Specifications Table 2. Specifications (* Tested and specified at 25°C and 3.0V VDD except stated otherwise.) The information contained herein is the exclusive property of QST, and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of QST. 3 / 37 矽睿 Parameter Supply voltage VDD Standby current Low power current Low noise current Document #: 13-52-20 Title: QMA6100P Preliminary Datasheet Conditions VDD, for internal blocks VDD and VDDIO on ODR=800 Hz ODR=400 Hz ODR=200 Hz ODR=80 Hz ODR=50Hz ODR=25 Hz ODR=12.5 Hz ODR=6.25 Hz Min 1.71 Data output rate (ODR) Max 3.6 Unit V μA μA μA 1.25 1000 Samples /sec Startup time From the time when VDD reaches to 90% of final value to the time when device is ready for conversion 2 ms Wakeup time From the time device enters into active mode to the time device is ready for conversion 1 ms Operating temperature Acceleration Full Range Sensitivity Sensitivity Temperature Drift Sensitivity tolerance Zero-g offset Zero-g offset Temperature Drift Noise density Nonlinearity Cross Axis Sensitivity 2.2 Typ 3.3 0.5 38 19 10 5 149 75 38 19 Rev: A1 -40 ±2/±4/±8/ ±16/±32 4096 2048 1024 512 256 FS=±2g FS=±4g FS=±8g FS=±16g FS=±32g ℃ 85 g LSB/g FS=±2g, Normal VDD Supplies ±0.02 %/℃ Gain accuracy FS=±2g, Normal VDD Supplies ±4 ±80 % mg FS=±2g, Normal VDD Supplies ±2 mg/℃ FS=±2g, run state FS=±2g, Best fit straight line, 220 ±0.5 1 μg/√Hz %FS % Absolute Maximum Ratings Table 3. Absolute Maximum Ratings (Tested at 25°C except stated otherwise.) Item Power Supply Voltage Input Voltage (other than power) Reflow Classificaition Storage Temperature Symbol Min Max Unit Vddmax -0.3 5.4 V Vmax -0.2 Vdd+0.2 V MSL3, 260℃ Peak Temperature ℃ Tstr -50 150 The information contained herein is the exclusive property of QST, and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of QST. Remark 4 / 37 矽睿 Document #: 13-52-20 Title: QMA6100P Preliminary Datasheet Storage Humidity ESD(HBM) ESD(MM) ESD(CDM) Shock Immunity Hstr Vhbm Vmm Vcdm 10 95 ±2000 ±200 ±500 10000 %RH V V V g Rev: A1 duration < 200uS 2.3 I/O Characteristics Table 4. I/O Characteristics Item Digital Input Low Voltage Digital Input High Voltage Digital Input Hysterisis Digital Output Low Voltage(I2C) Digital Output Low Voltage (SPI) Digital Output High Voltage1 (SPI) (Vio>=1.62V) Digital Output High Voltage2 (SPI) (Vio>=1.2V) Leakage Current at Output OFF Internal Pullup Resistor I2C Load Capacitor Load Capacitance of Reset Terminal Pulse Width of Asynchronous Reset Power on Startup Time Symbol Vil_d Vih_d Vidhys Vol_d1 Vol_d2 Condition Min Vddio*0.8 Vddio*0.1 0 0 Typ - Max Vddio*0.2 Vddio*0.2 Vddio*0.2 Unit V V V V V Vddio*0.8 - - V Vddio*0.6 - - V -10 - 10 70 120 190 - - 400 µA koh m pF Crst - - 20 pF Trst 100 - - µsec Tstart - - 10 msec Io=3mA (SDI) *1) Io=1mA (SDI, SDO) *1) Voh_d1 Io=1mA (SDI, SDO) *1) Voh_d2 Ioff Rpullup Cb Io=1mA (SDI, SDO) *1) SDX, AD0 SENB SDX, SCX 3 PACKAGE PIN CONFIGURATIONS 3.1 Package 3-D View Arrow indicates direction of g field that generates a positive output reading in normal measurement configuration. Z X QMA6100P Y The information contained herein is the exclusive property of QST, and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of QST. 5 / 37 Document #: 矽睿 Figure 2. Package View Table 5. Pin Configurations 13-52-20 Title: QMA6100P Preliminary Datasheet No Name IO Description 1 2 3 4 5 6 7 8 9 10 11 12 AD0 SDX VDD RESV1 INT1 INT2 NC GNDIO GND SENB RESV2 SCX I I/O P A O O NC G G I A I LSB of I2C address, or SDO of SPI serial data output SDA of I2C serial data, or SDI of SPI serial data input Power supply to internal circuitry Reserved Interrupt1 Interrupt2 Not connected Ground to IO Ground to internal circuitry Protocol selection Reserved SCL of I2C serial clock, or SCK of SPI serial clock No Name IO 1 2 3 4 5 6 AD0 SDX VDD RESV1 INT1 INT2 I I/O P A O O I2C VDDIO/GND SDA VDD Float/GND INT1 INT2 Rev: A1 Logic Level Connectivity SPI_3W Float SDI/SDO VDD Float/GND INT1 INT2 VDDIO VDDIO NA NA VDDIO VDDIO NA GND NA VDDIO NA VDDIO SPI_4W MISO MOSI VDD Float/GND INT1 INT2 The information contained herein is the exclusive property of QST, and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of QST. 6 / 37 矽睿 7 8 9 10 11 12 NC GNDIO GND SENB RESV2 SCX NC G G I A I Document #: NC GND GND VDDIO/Float VDDIO/Float/GND SCL 13-52-20 Title: QMA6100P Preliminary Datasheet NC GND GND CSB VDDIO/Float/GND SCK Rev: A1 NC GND GND CSB VDDIO/Float/GND SCK 3.2 Package Outlines 3.2.1 Package Type LGA (Land Grid Array) 3.2.2 Package Outline Drawing 2.0mm (Length)*2.0mm (Width)*0.95mm (Height) NOTE: 1. CONTROLLING DIMENSION: MILLIMETER. Figure 3. 3.2.3 Package Outline Drawing Tape And Reel Devices are shipped in reels, in standard cardboard box packaging. Package Reel Size WidthxPitch Qty/reel Trailer(Inner layer Min length) LGA(2x2) 13” 12*4 5000 300mm Leader(Outer layer Min length 300mm The information contained herein is the exclusive property of QST, and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of QST. Pin 1 Location Up Right 7 / 37 矽睿 4 4.1 Document #: 13-52-20 Title: QMA6100P Preliminary Datasheet Rev: A1 EXTERNAL CONNECTION I2C Single Supply connection P Figure 4. 4.2 I2C Single Supply Connection SPI Single Supply connection The information contained herein is the exclusive property of QST, and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of QST. 8 / 37 矽睿 Document #: 13-52-20 Title: QMA6100P Preliminary Datasheet Rev: A1 P Figure 5. SPI Single Supply Connection 5 BASIC DEVICE OPERATION 5.1 Acceleration sensor The QMA6100P acceleration sensor circuit consists of tri-axial sensors and application specific support circuits to measure the acceleration of device. When a DC power supply is applied to the sensor, the sensor converts any accelerating incident in the sensitive axis directions to charge output. 5.2 Power Management Device has one power supply pins. VDD is the main power supply for all of the internal blocks, including analog and digital. The device contains a power-on-reset generator. It generates reset pulse as power on, which can load the register’s default value, for the device to function properly. To make sure the POR block functions well, we should have such constrains on the timing of VDD The information contained herein is the exclusive property of QST, and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of QST. 9 / 37 矽睿 Document #: 13-52-20 Title: QMA6100P Preliminary Datasheet Rev: A1 The device should turn-on both power pins in order to operate properly. When the device is powered on, all registers are reset by POR, then the device transits to the standby mode and waits for further commends. Table 6 provides references for four power states. Table 6. Power States Power State 1 2 5.3 VDD 0V 1.71V-3.6V Power State Description Device off Device on, normal operation mode, enters standby mode after POR Power On/Off Time Device has one power supply pins and two ground pins. VDD is the main power supply for all of the internal blocks, including analog and digital. GND is 0V supply for all of internal blocks, and GNDIO for digital interface. There is no limitation on the voltage levels of VDD , as long as it is within operating range. The device contains a power-on-reset generator. It generates reset pulse as power on, which can load the register’s default value, for the device to function properly. To make sure the POR block functions well, we should have such constrains on the timing of VDD. The power on/off time related to the device is in Table 7 Table 7. Time Required for Power On/Off Parameter POR Completion Time Symbol PORT Power off Voltage SDV Power on Interval PINT Power on Time PSUP Condition Time Period After VDD and VDDIO at Operating Voltage to Ready for I2C Commend and Analogy Measurement. Voltage that Device Considers to be Power Down. Time Period Required for Voltage Lower Than SDV to Enable Next POR Time Period Required for Voltage from SDV to 90% of final value Min. Typ. Max. 250 Unit μs 0.2 V 100 The information contained herein is the exclusive property of QST, and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of QST. μs 50 ms 10 / 37 矽睿 Figure 9. 5.4 Document #: 13-52-20 Title: QMA6100P Preliminary Datasheet Rev: A1 Power On/Off Timing Communication Bus Interface I2C and Its Addresses This device will be connected to a serial interface bus as a slave device under the control of a master device, such as the processor. Control of this device is carried out via I²C. This device is compliant with I²C -Bus Specification, document number: 9398 393 40011. As an I²C compatible device, this device has a 7-bit serial address and supports I²C protocols. This device supports standard and fast speed modes, 100 kHz and 400 kHz, respectively. External pull-up resistors are required to support all these modes. There are two I2C addresses selected by connecting pin 1 (AD0) to GND or VDD. to “001001” and the LSB can be configured by AD0. Table 8. The first six MSB are hardware configured I2C Address Options AD0 (pin 1) Connect to GND Connect to VDD I2C Slave Address (HEX) 12 13 I2C Slave Address (BIN) 0010010 0010011 6 MODES OF OPERATION 6.1 Modes Transition QMA6100P has two different operational modes, controlled by register (0x11), MODE_BIT. The main purpose of these modes is for power management. The modes can be transited from one to another, as shown below, through I2C commands. The default mode after power-on is standby mode. The information contained herein is the exclusive property of QST, and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of QST. 11 / 37 Document #: 矽睿 13-52-20 Title: QMA6100P Preliminary Datasheet Rev: A1 Power Off Reset (POR or Soft Reset) Reset (POR or Soft Reset) NVM Load NVM Load 0x36=0xB6 0x36=0xB6 Standby Standby 0x11=1 0x11=1 0x33=1 Active 0x33=1 0x11=0 Active 0x11=0 0x36=0xB6 0x36=0xB6 Figure 10. Basic operation flow after power-on Figure 11. The work mode transferring The default mode after power on is standby mode. Through I2C instruction, device can switch between standby mode and active mode. With SOFTRESET by writing 0xB6 into register 0x36, all of the registers will get default values. SOFTRESET can be done both in active mode and in standby mode. Also, by writing 1 in NVM_LOAD (0x33) when device is in active mode, the NVM related image registers will get default value from NVM, however, other registers will keep the values of their own. 6.2 Description of Modes 6.2.1 Active Mode In active mode, the ADC digitizes the charge signals from transducer, and digital signal processor conditions these signals in digital domain, processes the interrupts, and send data to Data registers (0x01~0x06) and FIFO (accessible through register 0x3F). 6.2.2 Standby Mode In standby mode, most of the blocks are off, while device is ready for access through I2C. Standby mode is the default mode after power on or soft reset. Device can enter into this mode by set the soft reset register (0x36) to 0xB6 or set the MODE_BIT (0x11) to logic 0. 7 Functions and interrupts ASIC support interrupts, such as STEP_INT, DRDY_INT, ANY_MOT_INT, SIG_MOT_INT, NO_MOT_INT, RAISE_INT and FIFO_INT, etc. The information contained herein is the exclusive property of QST, and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of QST. 12 / 37 矽睿 Document #: 13-52-20 Title: QMA6100P Preliminary Datasheet Rev: A1 7.1 STEP_ INT The STEP_FPAG detect that the user is entering/exiting step mode. When the user enters into step mode, at least one axis sensor data will vary periodically, by numbering the variation periods and the acceleration intensity the step counter can be calculated. Figure 10. STEP SIGNAL The related interrupt status bit is STEP_INT (0x0A) and SIG_STEP (0x0A). When the interrupt is generated, the value of STEP_INT will be set to logic 1, which will be cleared after the interrupt status register is read by user. STEP_IEN/SIG_STEP_IEN (0x16/0x16) is the enable bit for the STEP_INT/SIG_STEP_INT. Also, to get this interrupt on PIN_INT1 and/or PIN_INT2, we need to set INT1_STEP (0x19)/INT1_SIG_STEP (0x19) or INT2_STEP (0x1B) /INT2_SIG_STEP (0x1B) to logic 1, to map the internal interrupt to the interrupt PINs. 7.2 DRDY_INT The width of the acceleration data is 14 bits, in two’s complement representation. The data of each axis is split into 2 parts, the MSB part (one byte contains bit 13 to bit 6) and the LSB part (one byte contains bit 5 to bit 0). Reading data should start with LSB part. When user is reading the LSB byte of data, to ensure the integrity of the acceleration data, the content of MSB can be locked, by setting SHADOW_DIS (0x21) to logic 0. This lock function can be disabled by setting SHADOW_DIS to logic 1. Without lock, the MSB and LSB content will be updated by new value immediately. The bit NEW_DATA in the LSB byte is the flag of the new data. If new data is updated, this NEW_DATA flag will be 1, and will be cleared when corresponding MSB or LSB is read by user. Also, the user should note that even with SHADOW_DIS=0, the data of 3 axes are not guaranteed from the same time point. The device supports four different acceleration measurement ranges. The range is setting through RANGE (0x0F), and the details as following: Acceleration RANGE Resolution range 0001 2g 244ug/LSB 0010 4g 488ug/LSB 0100 8g 977ug/LSB The information contained herein is the exclusive property of QST, and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of QST. 13 / 37 矽睿 1000 1111 Others Document #: 13-52-20 Title: QMA6100P Preliminary Datasheet 16g 32g 2g Rev: A1 1.95mg/LSB 3.91mg/LSB 244ug/LSB The interrupt for the new data serves for the synchronous data reading for the host. It is generated after storing a new value of z-axis acceleration data into data register. This interrupt will be cleared automatically when the next data conversion cycle starts, and the interrupt will be effective about 64*MCLK, and automatically cleared. The interrupt mode for the new data is fixed to be non-latched. 7.3 ANY_MOT_INT Any motion Any motion detection uses slope between two successive data to detect the changes in motion. It generates interrupt when a preset threshold ANY_MOT_TH (0x2E) is exceeded. The time difference between two successive data depends on the output data rate (ODR). Slope(t1) = (𝑎𝑐𝑐(𝑡1) − 𝑎𝑐𝑐(𝑡0)) ∗ 𝑂𝐷𝑅 The any motion detection criteria are fulfilled and interrupt is generated if any of enabled channels exceeds ANY_MOT_TH for ANY_MOT_DUR (0x2C) consecutive times. As long as all the enabled channels data fall or stay below ANY_MOT_TH for ANY_MOT_DUR consecutive times, the interrupt will be reset unless the interrupt signal is latched. The any motion detection engine will send out the signals of axis which triggered the interrupt (ANY_MOT_FIRST_X (0x09), ANY_MOT_FIRST_Y (0x09), ANY_MOT_FIRST_Z (0x09)) and the sign of the motion (ANY_MOT_SIGN (0x09)) The information contained herein is the exclusive property of QST, and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of QST. 14 / 37 矽睿 Document #: 13-52-20 Title: QMA6100P Preliminary Datasheet Rev: A1 acceleration time slope +threshould time -threshould duration duration counter duration time interrupt time There is an option for using any motion detector to detect high-g. If the 0x2F (any_mot_in_sel) is logic-1, the input of any-motion detector would be acceleration, and the threshold range would cover full scale range. ANY_MOT_TH*16 LSB 0 Threshold of Any Motion ANY_MOT_TH*32 LSB Slope of Accel 1 0 Any Motion Detector Accel 1 any_mot_in_sel any_mot_in_sel (0x2F) : 0 for any motion detection 1 for high-g detection The information contained herein is the exclusive property of QST, and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of QST. 15 / 37 矽睿 Document #: 13-52-20 Title: QMA6100P Preliminary Datasheet Rev: A1 7.4 SIG_MOT_INT A significant motion is a motion due to a change in user location. The algorithm is as following: 1) Look for movement, same setting as any motion detection 2) If movement detected, sleep for T_Skip (0x2F) 3) Look for movement a) If no movement detected within T_Proof (0x2F), go back to 1 b) If movement detected, report a significant movement, and generate the interrupt The significant motion detection and any motion detection are exclusive, user can select either one through SIG_MOT_SEL (0x2F). If significant motion is detected, the engine will set SIG_MOT_INT (0x0A). any-motion result time T_skip (sleep) T_proof (detect) interrupt 1/ODR time 7.5 NO_MOT_INT No-motion interrupt is generated if the slope (absolute value of acceleration difference) on all selected axes is smaller than the programmable threshold for a programmable time. Figure shows the timing for the no-motion interrupt. Register (0x2C) NO_MOT_DUR defines the delay times before the no-motion interrupt is generated. Table lists the delay times adjustable with register (0x2C) NO_MOT_DUR. The no-motion interrupt is enabled per axis by writing logic 1 to bits (0x18) NO_MOTION_EN_X, (0x18) NO_MOTION_EN_Y, and (0x18) NO_MOTION_EN_Z, respectively. The no-motion threshold is set through the (0x2D) NO_MOT_TH register. The meaning of an LSB of (0x2D) NO_MOT_TH depends on the selected g-range: it corresponds to 3.91mg in 2g-range (7.81mg in 4g-range, 15.6mg in 8g-range, 31.25mg in 16g-range, 62.5mg in 32g-range). Therefore the maximum value is 996mg in 2g-range (2g in 4g-range, 4g in 8g-range, 8g in 16g-range, and 16g in 32g-range). The time difference between the successive acceleration samples depends on the selected ODR and equates to 1/ODR. The information contained herein is the exclusive property of QST, and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of QST. 16 / 37 矽睿 Document #: 13-52-20 Title: QMA6100P Preliminary Datasheet Rev: A1 acceleration time slope +threshould time ` -threshould duration counter duration time interrupt time 7.6 TAP_INT Tap detection allows the device to detect the events such as clicking or double clicking of a touch-pad. A tap event is detected if a pre-defined slope of the acceleration. The tap detection includes single tap (S_TAP), double tap (D_TAP), triple tap (T_TAP), and quadruple tap (Q_TAP). A ‘Single tap’ is a single event within a certain shock time, followed by a certain quiet time. A ‘double tap’ consists of a first such event followed by a second event within a defined time frame, and so on. Each tap interrupt can be enabled (disabled) by setting ‘1’ (‘0’) to S_TAP_EN(0x16), D_TAP_EN(0x16), T_TAP_EN(0x16), and Q_TAP_EN(0x16). The status of each tap interrupt is stored in S_TAP_INT(0x0A), D_TAP_INT(0x0A), T_TAP_INT(0x0A), and Q_TAP_INT(0x0B). The shock and quiet threshold for detecting a tap event is set by register (0x2B) TAP_SHOCK_TH and (0x1E) TAP_QUIET_TH. The meaning of threshold LSB is 31.25mg, the range is 0 ~ 2G. The tap input selection is defined in (0x2B) TAP_IN_SEL, the default input is √𝑥 2 + 𝑦 2 + 𝑧 2 , the tap detector could only detect 1 axis as shown below: TAP_IN_SEL: 0: X-axis 1: Y-axis 2: Z-axis 3: √𝑥 2 + 𝑦 2 + 𝑧 2 In figure the timing for tap is visualized: The information contained herein is the exclusive property of QST, and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of QST. 17 / 37 矽睿 Document #: 13-52-20 Title: QMA6100P Preliminary Datasheet Rev: A1 Slope +Shock Threshould +Quiet Threshould -Quiet Threshould time -Shock Threshould shock time quiet time shock time quiet time shock time Single Tap Interrupt quiet time shock time quiet time duration time duration time duration time 12.5ms time Double Tap Interrupt 12.5ms time Triple Tap Interrupt 12.5ms time Quadruple Tap Interrupt 12.5ms time 7.7 RAISE_INT Raise wake algorithm is used to detect the action of raise hand (or hand down). The interrupt is enabled by writing logic 1 to bits (0X16[1]) RAISE_EN, (0X16[2]) HD_EN. User can adjust the sensitivity through the registers. The register RAISE_WAKE_SUM_TH(0X22[5:0]) defines the strength of hand action (raise and down). The register RAISE_DIFF_TH(0X23[1:0],0X22[7:6]) defines the differential values of twice actions, when the hand behavior almost done the differential value will be smaller and we can use this register to set the threshold. RAISE_WAKE_PERIOD and RAISE_WAKE_TIMEOUT_TH define the duration of the total hand action. 7.8 FIFO_INT This device has integrated FIFO memory, capable of storing up to 64 frames, with each frame contains three 14bits words, for acceleration data of X, Y, and Z axis. All of the 3-axes acceleration is sampled at same time point The FIFO can be configured as three modes, FIFO mode, STREAM mode, and BYPASS mode. FIFO mode. In FIFO mode, the acceleration data of selected axes are stored in the buffer memory. If enabled, a watermark interrupt can be triggered when the buffer filled up to the defined level. The buffer will continuously be filled until the fill level reaches to 64. When the buffer is full, data collection stops, and the new data will be ignored. Also, FIFO_FULL interrupt will be triggered when enabled. STREAM mode In STREAM mode, the acceleration data of selected axes will be stored into the buffer until the buffer is full. The buffer’s depth is 64 now. when the buffer is full, data collection continues, and the oldest data is discarded. If enabled, a watermark interrupt will be triggered when the fill level reached to the defined level. Also, when buffer is full, FIFO_FULL interrupt will be triggered if enabled. If any old data is discarded, the FIFO_OR (0x0B) will be set to be logic 1. BYPASS mode In BYPASS mode, only the current acceleration data of selected axes can be read out from FIFO. The FIFO acts like the STREAM mode when a depth of 1. Compared to reading directly from data register, this mode has the advantage of ensuring the package of xyz data are from same time point. The data registers are updated sequentially and have chance for The information contained herein is the exclusive property of QST, and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of QST. 18 / 37 矽睿 Document #: 13-52-20 Title: QMA6100P Preliminary Datasheet Rev: A1 xyz data are from different time. Also, if any old data is discarded, the FIFO_OR will be set to be logic 1, similar as that in STREAM mode. The FIFO mode can be configured by setting FIFO_MODE (0x3E). FIFO_MODE MODE 00 BYPASS 01 FIFO 10 STREAM 11 FIFO User can select the acceleration data of which axes to be stored in FIFO. This configuration can be done by setting FIFO_CH (0x3E) If all of the 3-axes data are selected, the format of data read from 0x3F is as following XLSB XMSB YLSB YMSB ZLSB ZMSB These comprise one frame If only one axis is enabled, the format data read from 0x3F is as following YLSB YMSB These comprise one frame If the frame is not read completely, the remaining parts of the frame will be discarded. If the FIFO is read beyond the FIFO fill level, all zeroes will be read out. FIFO_FRAME_COUNTER (0x0E) reflects the current filled level of the buffer. If additional data frames are written into the buffer when FIFO is full (in STREAM mode or BYPASS mode), then FIFO_OR (0x0B) is set to be logic 1. This FIFO_OR bit can be considered as flag of discarding old data. When a write access to one of the FIFO configuration registers (0x3E) or watermark registers (0x31) occurs, the FIFO buffer will be cleared, the FIFO fill level indication register FIFO_FRAME_COUNTER (0x0E) will be cleared, and the FIFO_OR (0x0B) will be cleared as well. As mentioned above, FIFO controller contains two interrupts, FIFO_FULL interrupt and watermark interrupt. These two interrupts are functional in all of the FIFO operating modes. The watermark interrupt is triggered when the filled level of buffer reached to the level that is defined by register FIFO_WM_LVL (0x31), if the interrupt is enabled by setting INT_FWM_EN (0x17) to logic 1 and INT1_FWM (0x1A) or INT2_FWM (0x1C) is set. The FIFO_FULL interrupt is triggered when the buffer has been fully filled. In FIFO mode, the filled level is 64, and in STREAM mode the filled level is 64, in BYPASS mode the filled level is 1. To enable FIFO_FULL interrupt, INT_FFULL_EN (0x17) should be set to 1, and INT1_FFULL (0x1A) and INT2_FFULL (0x1C) is set. The status of watermark interrupt and FIFO full interrupt can be read through INT_STAT (0x0B) After soft-reset, the watermark interrupt and FIFO full interrupt are disabled. For the FIFO to recollect the data, user should reconfigure the register FIFO_MODE. 7.9 Interrupt configuration The device has the above 3 interrupt engines. Each of the interrupts can be enabled and configured independently. If the trigger condition of the enabled interrupt fulfilled, the corresponding interrupt status bit will be set to logic 1, and the mapped interrupt pin will be activated. The device has two interrupt PINs, INT1 and INT2. Each of the interrupts can be mapped to either PIN or both PINs. The interrupt status registers INT_ST(0x09~0x0d) will update when a new data word is written into the data registers. If an interrupt is disabled, the related active interrupt status bit is disabled immediately. The information contained herein is the exclusive property of QST, and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of QST. 19 / 37 矽睿 Document #: 13-52-20 Title: QMA6100P Preliminary Datasheet Rev: A1 When interrupt condition is fulfilled, related bit of interrupt will be set, until the associated interrupt condition is no more valid. Read operation to related register will also clear the register. Device supports 2 interrupt modes, non-latched, and latched mode. The interrupt modes are set through LATCH_INT (0x21). In non-latched mode, the mapped interrupt pin will be set and/or cleared same as associated interrupt register bit. Also, the mapped interrupt pin can be cleared with read operation to any of the INT_ST(0x09~0x0d). Exception to this is the new data interrupt and step interrupt, which are automatically reset after a fixed time (T_Pulse = 64/MCLK), no matter LATCH_INT (0x21) is set to 0 or 1. In latched mode, the clearings of mapped pins are determined by INT_RD_CLR (0x21). If the condition for trigging the interrupt still holds, the interrupt status will be set again with the next change of the data registers. Mapping the interrupt pins can be set by INT_MAP (0x19~0x1B). The electrical interrupt pins can be set INT_PIN_CONF (0x20). The active logic level can be set to 1 or 0, and the interrupt pin can be set to open-drain or push-pull. The information contained herein is the exclusive property of QST, and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of QST. 20 / 37 矽睿 Document #: 13-52-20 Title: QMA6100P Preliminary Datasheet Rev: A1 8 I2C COMMUNICATION PROTOCOL 8.1 I2C Timings Table 9 and Figure 11 describe the I2C communication protocol times Table 9. I2C Timings Parameter SCL Clock SCL Low Period SCL High Period SDA Setup Time SDA Hold Time Start Hold Time Start Setup Time Stop Setup Time New Transmission Time Rise Time Fall Time Figure 11. t sudat t hddat t hdsta t susta t susto t buf Condition Min. 0 1 1 0.1 0 0.6 0.6 0.6 1.3 Typ. Max. 400 Unit kHz μs μs 0.9 tr tf μs μs μs μs μs μs μs μs I2C Timing Diagram 8.2 I2C R/W Operation 8.2.1 Abbreviation Table 10. Symbol fscl t low t high Abbreviation The information contained herein is the exclusive property of QST, and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of QST. 21 / 37 矽睿 SACK MACK NACK RW 8.2.2 Document #: 13-52-20 Title: QMA6100P Preliminary Datasheet Rev: A1 Acknowledged by slave Acknowledged by master Not acknowledged by master Read/Write Start/Stop/Ack START: Data transmission begins with a high to transition on SDA while SCL is held high. Once I 2C transmission starts, the bus is considered busy. STOP: STOP condition is a low to high transition on SDA line while SCL is held high. ACK: Each byte of data transferred must be acknowledged. The transmitter must release the SDA line during the acknowledge pulse while the receiver must then pull the SDA line low so that it remains stable low during the high period of the acknowledge clock cycle. NACK: If the receiver doesn’t pull down the SDA line during the high period of the acknowledge clock cycle, it’s recognized as NACK by the transmitter. 8.2.3 I2C Write I C write sequence begins with start condition generated by master followed by 7 bits slave address and a write bit (R/W=0). The slave sends an acknowledge bit (ACK=0) and releases the bus. The master sends the one-byte register address. The slave again acknowledges the transmission and waits for 8 bits data which shall be written to the specified register address. After the slave acknowledges the data byte, the master generates a stop signal and terminates the writing protocol. 2 Table 11. I2C Write Slave Address STOP Data (0x80) 1 0 0 0 0 0 0 0 SACK Register Address (0x11) 0 0 0 1 0 0 0 1 SACK SACK START 8.2.4 R W 0 0 1 0 0 1 0 0 I2C Read I C write sequence consists of a one-byte I2C write phase followed by the I2C read phase. A start condition must be generated between two phases. The I2C write phase addresses the slave and sends the register address to be read. After slave acknowledges the transmission, the master generates again a start condition and sends the slave address together with a read bit (R/W=1). Then master releases the bus and waits for the data bytes to be read out from slave. After each data byte the master has to generate an acknowledge bit (ACK = 0) to enable further data transfer. A NACK from the master stops the data being transferred from the slave. The slave releases the bus so that the master can generate a STOP condition and terminate the transmission. The register address is automatically incremented and more than one byte can be sequentially read out. Once a new data read transmission starts, the start address will be set to the register address specified in the current I 2C write command. 2 Table 12. I2C Read Slave Address Data (0x00) SACK Register Address (0x00) 0 0 0 0 0 0 0 0 M AC K R W SA CK ST AR T Slave Address SACK START R W 0 0 1 0 0 1 0 0 Data (0x01) The information contained herein is the exclusive property of QST, and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of QST. 22 / 37 矽睿 Data (0x02) 0 0 0 0 0 0 1 0 ………………………………. Data (0x07) 0 0 0 0 0 0 0 0 ………………………………. Rev: A1 STOP 0 0 0 0 0 0 0 0 NACK 0 0 0 0 0 0 1 0 MACK 0 0 1 0 0 1 0 1 MACK MACK 8.3 13-52-20 Title: QMA6100P Preliminary Datasheet Document #: Serial Peripheral Interface(SPI) The timing specification of SPI is given in the following table. Table 13: SPI timing Parameter Clock Frequency Symbol fSPI Condition Max. load on SDI or SDO=25pF Min. 0 Max. 10 Unit MHz t SCKL t SCKH 20 20 ns SDI Setup Time SDI Hold Time SDO Output Delay t SDI_setup t SDI_hold t SDO_OD 20 20 ns ns ns ns SENB Setup Time SENB Hold Time t SENB_setup t SENB_hold SCK Low Pulse SCK High Pulse ns Load =25pF Load =250pF, Vddio =2.4V 30 40 20 40 ns ns The following figure shows the definition of SPI timing given in table 13: tSENB_hold tSENB_setup SENB SCK tSCKL tSCKH SDI tSDI_setup tSDI_hold SDO tSDO_OD Figure. 12 SPI timing diagram The SPI interface of QMA6100P is compatible with two modes, ‘00’ and ‘11’. The automatic selection between mode ‘00’ and mode ‘11’ is done based on the value of SCK at the falling edge of SENB. Two configurations of SPI interface are supported by QMA6100P: 4-wire and 3-wire. The same protocol is used by both configurations. The device operates in 4-wire configuration by default. The configuration can be switched to 3-wire configuration by setting EN_SPI3W(0x20[5])=1. Pin SDI is used as the common data pin in 3wire configuration. The information contained herein is the exclusive property of QST, and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of QST. 23 / 37 13-52-20 Title: QMA6100P Preliminary Datasheet Document #: 矽睿 Rev: A1 For single byte read or write operation, 16-bit protocols are used. QMA6100P also supports multiple-byte read or write operations. In 4-wire configuration, SENB(low active), SCK(serial clock), SDI(serial data input) and SDO(serial data output) pins are used. The communication starts when SENB is pulled low by SPI master and stops when SENB is pulled high. SCK is also controlled by SPI master. SDI and SDO are driven at the falling edge of SCK and should be captured at the rising edge of SCK. The basic write operation waveform for 4-wire configuration is depicted below in figure 13. During the entire write cycle SDO remains in high impedance state. 4-Wire SPI Write Timing Diagram (Mode 3) SENB SCK SDI R/W A6 A5 A4 A3 A2 A1 A0 DI7 DI6 DI5 DI4 DI3 DI2 DI1 DI0 DI5 DI4 DI3 DI2 DI1 DI0 SDO 4-Wire SPI Write Timing Diagram (Mode 0) SENB SCK SDI R/W A6 A5 A4 A3 A2 A1 A0 DI7 DI6 SDO Bit 0 : R/W bit, R/W=0 : write mode; R/W=1 : read mode. Bit 1-7 : 7-bit address of registers. Bit 8-15 : Data DI7~DI0 (write mode). It is the data that will be written into the slave. (MSB first) Bit 8-15 : Data DO7~DO0 (read mode). It is the data that will be read from the device. (MSB first) Figure 13: 4-wire basic SPI Write sequence The basic read operation waveform for 4-wire configuration is depicted in figure 14 below. The information contained herein is the exclusive property of QST, and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of QST. 24 / 37 13-52-20 Title: QMA6100P Preliminary Datasheet Document #: 矽睿 Rev: A1 4-Wire SPI Read Timing Diagram (Mode 3) SENB SCK SDI R/W A6 A5 A4 A3 A2 A1 A0 SDO DI7 DI6 DI5 DI4 DI3 DI2 DI1 DI0 DO7 DO6 DO5 DO4 DO3 DO2 DO1 DO0 4-Wire SPI Read Timing Diagram (Mode 0) SENB SCK SDI R/W A6 A5 A4 A3 A2 SDO A1 A0 DI7 DI6 DI5 DI4 DI3 DI2 DI1 DI0 DO7 DO6 DO5 DO4 DO3 DO2 DO1 DO0 Bit 0 : R/W bit, R/W=0 : write mode; R/W=1 : read mode. Bit 1-7 : 7-bit address of registers. Bit 8-15 : Data DI7~DI0 (write mode). It is the data that will be written into the slave. (MSB first) Bit 8-15 : Data DO7~DO0 (read mode). It is the data that will be read from the device. (MSB first) Figure 14: 4-wire basic SPI Read sequence The data bits are defined as follows: Bit0: Read/Write bit. When 0, the data DI is written to the chip. When 1, the data DO is read from the chip. Bit1-7: Address A(6:0). Bit8-15: when in write mode, these are the data DI, which will be written to the address. When in read mode, these are the DO, which are read from the address. Multiple byte read/write operations are possible by keeping SENB low and continuing the data transfer. Only the first register address has to be provided. Addresses are automatically incremented after each read/write access as long as SENB stays low. The principle of multiple read/write is shown below. The information contained herein is the exclusive property of QST, and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of QST. 25 / 37 矽睿 Document #: 13-52-20 Title: QMA6100P Preliminary Datasheet Rev: A1 Burst Read Timing Diagram SENB SCK SDI R, Index Address DataR from Regindex+1 DataR from Regindex SDO DataR from Regindex+2 Burst Write Timing Diagram SENB SCK SDI W, Index Address Dataw to Regindex Dataw to Regindex+1 Dataw to Regindex+2 SDO Figure 15: SPI multiple byte Read/Write In 3-wire configuration, SENB(low active), SCK(serial clock) and SDI(serial data input) pins are used. The communication starts when SENB is pulled low by SPI master and stops when SENB is pulled high. SCK is also controlled by SPI master. SDI is driven at the falling edge of SCK when used as input of the device and should be captured at the rising edge of SCK when used as the output of the device. 3-Wire SPI Read/Write Timing Diagram (Mode 3) SENB SCK SDI R/W A6 A5 A4 A3 A2 A1 A0 D7 D6 D5 D4 D3 D2 D1 D0 Bit 0 : R/W bit, R/W=0 : write mode; R/W=1 : read mode. Bit 1-7: 7-bit address of registers. Bit 8-15: R/W=0 : D7 ~ D0 are written into slave; R/W=1 : D7~D0 are read from slave. (MSB first). Figure 16: 3-wire basic SPI Read/Write sequence 9 REGISTERS 9.1 Register Map The information contained herein is the exclusive property of QST, and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of QST. 26 / 37 Document #: 矽睿 13-52-20 Title: QMA6100P Preliminary Datasheet Rev: A1 The table below provides a list of the 8-bit registers embedded in the device and their respective function and addresses Table 14. Register Map Add. 0x3F 0x3E 0x3D 0x3C 0x3B 0x3A 0x39 0x38 0x37 0x36 0x35 0x34 0x33 0x32 0x31 0x30 0x2F 0x2E 0x2D 0x2C 0x2B 0x2A 0x29 0x28 0x27 0x26 0x25 0x24 0x23 0x22 0x21 0x20 0x1F 0x1E 0x1D 0x1C 0x1B 0x1A 0x19 0x18 0x17 0x16 0x15 0x14 0x13 0x12 0x11 0x10 0x0F 0x0E 0x0D 0x0C 0x0B 0x0A 0x09 0x08 0x07 0x06 0x05 0x04 0x03 0x02 0x01 0x00 Name FIFO_CFG bit7 bit6 FIFO_MODE IMAGE OFFSET_X S_RESET Z_TH[3:0] YZ_TH_SEL[2:0] Internal ST FIFO_WM RST_MOT MOT_CFG TAP OS_CUST na INT_CFG INT_PIN_CFG STEP_CFG INT_MAP INT_EN na PM BW FSR FIFO_ST INT_ST na DATA CHIP ID bit5 bit4 bit3 bit2 bit1 FIFO_DATA RAISE_XYZ_SW FIFO_EN_Z FIFO_EN_Y GAIN_Z GAIN_Y GAIN_X OFFSET_Z OFFSET_Y OFFSET_X GAIN_Z OFFSET_Y SOFTRESET: 0xB6 / NVM_UNLOCK: 0xB3 X_TH[3:0] Y_TH[4:0] SELFTEST_BIT SELFTEST_SIGN bit0 FIFO_EN_X STEP_BP_AXIS FIFO_WTMK_LVL MO_BP_LPF RFF_BP_LPF STEP_BP_LPF TAP_RST_N NO_MOT_RST_N SIG_MOT_RST_NANY_MOT_RST_N SIG_MOT_TPROOF SIG_MOT_TSKIP SIG_MOT_SEL ANY_MOT_TH NO_MOT_TH NO_MOT_DUR ANY_MOT_DUR TAP_IN_SEL TAP_SHOCK_TH TAP_DUR TAP_QUIET TAP_SHOCK T_TAP_DELAY TAP_EARIN OS_CUST_Z OS_CUST_Y OS_CUST_X RAISE_MODE RAISE_WAKE_PERIOD[10:8] RAISE_WAKE_TIMEOUT_TH[11:8] RAISE_WAKE_PERIOD[7:0] RAISE_WAKE_TIMEOUT_TH[7:0] HD_Z_TH[2:0] HD_X_TH[2:0] RAISE_WAKE_DIFF_TH[3:2] RAISE_WAKE_DIFF_TH[1:0] RAISE_WAKE_SUM_TH[5:0] LATCH_INT_STEP INT_RD_CLR SHADOW_DIS DIS_I2C LATCH_INT DIS_PU_SENB DIS_IE_AD0 EN_SPI3W STEP_COUNT_PEAK INT2_OD INT2_LVL INT1_OD INT1_LVL STEP_START_CNT STEP_COUNT_PEAK STEP_COUNT_P2P NLPF_STEP TAP_QUIET_TH[5:0] STEP_INTERVAL EN_RESET_DC INT2_NO_MOT INT2_FWM INT2_FFULL INT2_DATA INT2_Q_TAP INT2_ANY_MOT INT2_S_TAP INT2_SIG_STEP INT2_D_TAP INT2_T_TAP INT2_STEP INT2_HD INT2_RAISE INT2_SIG_MOT INT1_NO_MOT INT1_FWM INT1_FFULL INT1_DATA INT1_Q_TAP INT1_ANY_MOT INT1_S_TAP INT1_SIG_STEP INT1_D_TAP INT1_T_TAP INT1_STEP INT1_HD INT1_RAISE INT1_SIG_MOT NO_MOT_EN_Z NO_MOT_EN_Y NO_MOT_EN_X ANY_MOT_EN_Z ANY_MOT_EN_Y ANY_MOT_EN_X INT_FWM_EN INT_FFULL_EN INT_DATA_EN S_TAP_EN SIG_STEP_IEN D_TAP_EN T_TAP_EN STEP_IEN HD_EN RAISE_EN Q_TAP_EN STEP_TIME_UP STEP_TIME_LOW STEP_CLR STEP_PRECISION STEP_EN STEP_SAMPLE_CNT T_RSTB_SINC_SEL MCLK_SEL MODE_BIT NLPF BW RANGE EN_16B FIFO_FRAME_COUNTER STEP_CNT TAP_SIGN FIFO_OR FIFO_WM_INT FIFO_FULL_INT DATA_INT EARIN_FLAG Q_TAP_INT S_TAP_INT SIG_STEP D_TAP_INT T_TAP_INT STEP_INT HD_INT RAISE_INT SIG_MOT_INT NO_MOT STEP_FLAG ANY_MOT_SIGN ANY_MOT_FIRST_Z ANY_MOT_FIRST_Y ANY_MOT_FIRST_X STEP_CNT STEP_CNT ACC_Z ACC_Z 0 NEWDATA_Z ACC_Y ACC_Y 0 NEWDATA_Y ACC_X ACC_X 0 NEWDATA_X CHIP ID to indicate the product version ANY_MOT_IN_SEL The information contained herein is the exclusive property of QST, and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of QST. 27 / 37 R/W R RW RW RW RW RW RW RW RW RW RW RW RW RW RW RW RW RW RW RW RW RW RW RW RW RW RW RW RW RW RW RW RW RW RW RW RW RW RW RW RW RW RW RW RW RW RW RW RW R R R R R R R R R R R R R R R DEF 00 07 NVM NVM NVM NVM NVM NVM NVM 00 66 9D 05 00 00 3F 00 00 00 00 CD 05 00 00 00 02 81 00 7C D8 00 05 A9 08 00 00 00 00 00 00 00 00 16 19 7F 14 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ANA Document #: 矽睿 9.2 13-52-20 Title: QMA6100P Preliminary Datasheet Rev: A1 Register Definition Register 0x00 (CHIP ID) Bit7 Bit6 Bit5 CHIP_ID This register is used to identify the device Register 0x01 ~ 0x02 (DXL, DXM) Bit7 Bit6 Bit5 DX DX DX: NEWDATA_X: Bit4 Bit3 Bit2 Bit1 Bit0 R/W RW Default 0x90 Bit4 Bit3 Bit2 Bit1 Bit0 NEWDATA _X R/W R Default 0x00 R 0x00 R/W R Default 0x00 R 0x00 R/W R Default 0x00 R 0x00 Bit0 R/W R R Default 0x00 0x00 14bits acceleration data of x-channel. This data is in two’s complement. 1, acceleration data of x-channel has been updated since last reading 0, acceleration data of x-channel has not been updated since last reading Register 0x03 ~ 0x04 (DYL, DYM) Bit7 Bit6 Bit5 DY DY DY: NEWDATA_Y: Bit4 Bit3 Bit2 Bit1 14bits acceleration data of y-channel. This data is in two’s complement. 1, acceleration data of y-channel has been updated since last reading 0, acceleration data of y-channel has not been updated since last reading Register 0x05 ~ 0x06 (DZL, DZM) Bit7 Bit6 Bit5 DZ DZ DZ: NEWDATA_Z: Bit4 Bit3 Bit2 Bit1 Register 0x09 (INT_ST0) Bit7 Bit6 NO_MOT STEP_FLAG STEP_FLAG: ANY_MOT_SIGN: ANY_MOT_FIRST_Z: ANY_MOT_FIRST_Y: ANY_MOT_FIRST_X: Bit0 NEWDATA _Z 14bits acceleration data of z-channel. This data is in two’s complement. 1, acceleration data of z-channel has been updated since last reading 0, acceleration data of z-channel has not been updated since last reading Register 0x07 ~ 0x08 (STEP_CNT) Bit7 Bit6 Bit5 Bit4 Bit3 Bit2 Bit1 STEP_CNT STEP_CNT STEP_CNT: 16 bits of step counter, out of total 24bits data. The MSB data are in 0x0e NO_MOT: Bit0 NEWDATA _Y Bit5 Bit4 Bit3 ANY_MOT _SIGN Bit2 ANY_MOT _FIRST_Z Bit1 ANY_MOT _FIRST_Y Bit0 ANY_MOT _FIRST_X R/W R Default 0x00 Bit2 HD_INT Bit1 RAISE_INT Bit0 SIG_MOT_I NT R/W R Default 0x00 1, no_motion interrupt active 0, no_motion interrupt inactive 1, STEP detected 0, STEP not detected 1, sign of any_motion triggering signal is negative 0, sign of any_motion triggering signal is positive 1, any_motion interrupt is triggered by Z axis 0, any_motion interrupt is not triggered by Z axis 1, any_motion interrupt is triggered by Y axis 0, any_motion interrupt is not triggered by Y axis 1, any_motion interrupt is triggered by X axis 0, any_motion interrupt is not triggered by X axis Register 0x0a (INT_ST1) Bit7 Bit6 S_TAP_INT SIG_STEP Bit5 D_TAP_INT Bit4 T_TAP_INT Bit3 STEP_INT The information contained herein is the exclusive property of QST, and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of QST. 28 / 37 矽睿 S_TAP_INT: SIG_STEP: D_TAP_INT: STEP_INT: T_TAP_INT: HD_INT: RAISE_INT: SIG_MOT_INT: 13-52-20 Title: QMA6100P Preliminary Datasheet Document #: Rev: A1 1, single tap is active 0, single tap is inactive 1, significant step is active 0, significant step is inactive 1, double tap is active 0, double tap is inactive 1, step valid interrupt is active 0, step quit interrupt is inactive 1, triple tap is active 0, triple tap is inactive 1, hand down interrupt is active 0, hand down interrupt is inactive 1, raise hand interrupt is active 0, raise hand interrupt is inactive 1, significant interrupt is active 0, significant interrupt is inactive Register 0x0b (INT_ST2) Bit7 Bit6 Bit5 Bit4 Bit3 FIFO_OR FIFO_WM_ FIFO_FULL DATA_INT INT _INT FIFO_OR: 1, FIFO Over-Run occurred 0, FIFO Over-Run not occurred FIFO_WM_INT: 1, FIFO watermark interrupt is active 0, FIFO watermark interrupt is inactive FIFO_FULL_INT: 1, FIFO full interrupt is active 0, FIFO full interrupt is inactive DATA_INT: 1, data ready interrupt active 0, data ready interrupt inactive EARIN_FLAG: 1, ear-in interrupt is active 0, ear-in interrupt is inactive Q_TAP_INT: 1, quad tap is active 0, quad tap is inactive Bit2 Bit1 EARIN_FLA G Register 0x0c (INT_ST3) Bit7 Bit6 Bit5 Bit4 Bit3 TAP_SIGN TAP_SIGN: 1, tap sign is along with positive direction 0, tap sign is along with negative direction Bit2 Bit0 Q_TAP_INT Bit1 Register 0x0d (INT_ST4) Bit7 Bit6 Bit5 Bit4 Bit3 Bit2 Bit1 STEP_CNT STEP_CNT: 8bit MSB data of step counter, out of total 24bits data. The LSB data are in 0x07 and 0x08 R/W R Default 0x00 Bit0 R/W R Default 0x00 Bit0 R/W R Default 0x00 Register 0x0e (FIFO_ST) Bit7 Bit6 Bit5 Bit4 Bit3 Bit2 Bit1 Bit0 R/W Default FIFO_FRAME_COUNTER R 0x00 FIFO_FRAME_COUNTER: Fill level of FIFO buffer. An empty FIFO corresponds to 0x00. The frame counter can be cleared by reading out all of the frames, or by writing register 0x3e (FIFO_CFG1) or 0x31. Register 0x0f (FSR) Bit7 Bit6 Bit5 Bit4 Bit3 Bit2 LPF_HPF RANGE RANGE: set the full scale of the accelerometer. Setting as following RANGE 0001 0010 0100 1000 1111 Others Acceleration range 2g 4g 8g 16g 32g 2g Bit1 Bit0 R/W RW Default 0x00 Resolution 244ug/LSB 488g/LSB 977ug/LSB 1.95mg/LSB 3.91mg/LSB 244ug/LSB The information contained herein is the exclusive property of QST, and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of QST. 29 / 37 矽睿 Document #: Register 0x10 (BW) Bit7 Bit6 Bit5 Bit4 HPF[2] NLPF BW NLPF: 00: no LPF. 01: NLPF=2. 10: NLPF=4. 11: NLPF=8 BW: bandwidth setting, as following 13-52-20 Title: QMA6100P Preliminary Datasheet Bit3 Bit2 Bit1 Bit0 R/W RW Default 0xE0 Bit5 Bit4 Bit3 Bit2 Bit1 T_RSTB_SINC_SEL MCLK_SEL 1, set device into active mode 0, set device into standby mode T_RSTB_SINC_SEL: Reset clock setting. The preset time is reserved for CIC filter in digital MCLK_SEL: set the master clock to digital Bit0 R/W RW Default 0x00 Register 0x11 (PM) Bit7 Bit6 MODE_BIT MODE_BIT: Rev: A1 Register 0x12 (STEP_CONF0) Bit7 Bit6 Bit5 Bit4 Bit3 Bit2 Bit1 Bit0 R/W Default STEP_EN STEP_SAMPLE_CNT RW 0x14 STEP_EN: enable step counter, this bit should be set 1 when using step counter STEP_SAMPLE_CNT: sample count setting to renew dynamic threshold. The actual value is STEP_SAMPLE_CNT*8, default is 0xC, 96 sample count Register 0x13 (STEP_CONF1) Bit7 Bit6 Bit5 Bit4 Bit3 Bit2 STEP_CLR STEP_PRECISION STEP_CLR: clear step count in register 0x0D ,0x08 and 0x07 STEP_PRECISION: algorithm setting Register 0x14 (STEP_CONF2) Bit7 Bit6 Bit5 STEP_TIME_LOW STEP_TIME_LOW: algorithm setting Register 0x15 (STEP_CONF3) Bit7 Bit6 Bit5 STEP_TIME_UP STEP_TIME_UP: algorithm setting Bit1 Bit0 R/W RW Default 0x7F Bit4 Bit3 Bit2 Bit1 Bit0 R/W RW Default 0x19 Bit4 Bit3 Bit2 Bit1 Bit0 R/W RW Default 0x00 Bit2 HD_EN Bit1 RAISE_EN Bit0 Q_TAP_EN R/W RW Default 0x00 Register 0x16 (INT_EN0) Bit7 Bit6 Bit5 Bit4 Bit3 S_TAP_EN SIG_STEP_I D_TAP_EN T_TAP_EN STEP_IEN EN S_TAP_EN: 1, enable single tap 0, disable single tap SIG_STEP_IEN: 1, enable significant step interrupt 0, disable significant step interrupt D_TAP_EN: 1, enable double tap 0, disable double tap T_TAP_EN: 1, enable triple tap 0, disable triple tap STEP_IEN: 1, enable step valid interrupt 0, disable step valid interrupt HD_EN: 1, enable hand-down interrupt 0, disable hand-down interrupt RAISE_EN: 1, enable raise-hand interrupt 0, disable raise-hand interrupt Q_TAP_EN: 1, enable quad tap 0, disable quad tap Register 0x17 (INT_EN1) The information contained herein is the exclusive property of QST, and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of QST. 30 / 37 矽睿 Document #: 13-52-20 Title: QMA6100P Preliminary Datasheet Bit7 Bit6 Bit5 Bit4 Bit3 INT_FWM_ INT_FFULL INT_DATA EN _INT _EN INT_FWM_EN: 1, enable FIFO watermark interrupt 0, disable FIFO watermark interrupt INT_FFULL_EN: 1, enable FIFO full interrupt 0, disable FIFO full interrupt INT_DATA_EN: 1, enable data ready interrupt 0, disable data ready interrupt Register 0x18 (INT_EN2) Bit7 Bit6 Bit5 Bit4 Bit3 NO_MOT_ NO_MOT_ NO_MOT_ EN_Z EN_Y EN_X NO_MOT_EN_Z: 1, enable no_motion interrupt on Z axis 0, disable no_motion interrupt on Z axis NO_MOT_EN_Y: 1, enable no_motion interrupt on Y axis 0, disable no_motion interrupt on Y axis NO_MOT_EN_X: 1, enable no_motion interrupt on X axis 0, disable no_motion interrupt on X axis ANY_MOT_EN_Z: 1, enable any_motion interrupt on Z axis 0, disable any_motion interrupt on Z axis ANY_MOT_EN_Y: 1, enable any_motion interrupt on Y axis 0, disable any_motion interrupt on Y axis ANY_MOT_EN_X: 1, enable any_motion interrupt on X axis 0, disable any_motion interrupt on X axis Bit2 Bit1 Bit0 R/W RW Default 0x00 Bit2 ANY_MOT _EN_Z Bit1 ANY_MOT _EN_Y Bit0 ANY_MOT _EN_X R/W RW Default 0x00 Bit1 INT1_RAIS E Bit0 INT1_SIG_ MOT R/W RW Default 0x00 Bit1 INT1_Q_TA P Bit0 INT1_ANY_ MOT R/W RW Default 0x00 Register 0x19 (INT_MAP0) Bit7 Bit6 Bit5 Bit4 Bit3 Bit2 INT1_S_TA INT1_SIG_ INT1_D_TA INT1_T_TA INT1_STEP INT1_HD P STEP P P INT1_S_TAP: 1, map single tap interrupt to INT1 pin 0, not map single tap interrupt to INT1 pin INT1_SIG_STEP: 1, map significant step interrupt to INT1 pin 0, not map significant step interrupt to INT1 pin INT1_D_TAP: 1, map double tap interrupt to INT1 pin 0, not map double tap interrupt to INT1 pin INT1_T_TAP: 1, map triple tap interrupt to INT1 pin 0, not map triple tap interrupt to INT1 pin INT1_STEP: 1, map step valid interrupt to INT1 pin 0, not map step valid interrupt to INT1 pin INT1_HD: 1, map hand down interrupt to INT1 pin 0, not map hand down interrupt to INT1 pin INT1_RAISE: 1, map raise hand interrupt to INT1 pin 0, not map raise hand interrupt to INT1 pin INT1_SIG_MOT: 1, map significant interrupt to INT1 pin 0, not map significant interrupt to INT1 pin Register 0x1a (INT_MAP1) Bit7 Bit6 Bit5 Bit4 Bit3 Bit2 INT1_NO_ INT1_FWM INT1_FFUL INT1_DAT MOT L A INT1_NO_MOT: 1, map no_motion interrupt to INT1 pin 0, not map no_motion interrupt to INT1 pin INT1_FWM: 1, map FIFO watermark interrupt to INT1 pin 0, not map FIFO watermark interrupt to INT1 pin INT1_FFULL: 1, map FIFO full interrupt to INT1 pin 0, not map FIFO full interrupt to INT1 pin INT1_DATA: 1, map data ready interrupt to INT1 pin 0, not map data ready interrupt to INT1 pin INT1_Q_TAP: 1, map quad tap interrupt to INT1 pin 0, not map quad tap interrupt to INT1 pin INT1_ANY_MOT: 1, map any motion interrupt to INT1 pin The information contained herein is the exclusive property of QST, and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of QST. Rev: A1 31 / 37 Document #: 矽睿 13-52-20 Title: QMA6100P Preliminary Datasheet Rev: A1 0, not map any motion interrupt to INT1 pin Register 0x1b (INT_MAP2) Bit7 Bit6 Bit5 Bit4 Bit3 Bit2 INT2_S_TAP INT2_SIG_S INT2_D_ INT2_T_TA INT2_STEP INT2_HD TEP TAP P INT2_S_TAP: 1, map single tap interrupt to INT2 pin 0, not map single tap interrupt to INT2 pin INT2_SIG_STEP: 1, map significant step interrupt to INT2 pin 0, not map significant step interrupt to INT2 pin INT2_D_TAP: 1, map double tap interrupt to INT2 pin 0, not map double tap interrupt to INT2 pin INT2_T_TAP: 1, map triple tap interrupt to INT2 pin 0, not map triple tap interrupt to INT2 pin INT2_STEP: 1, map step valid interrupt to INT2 pin 0, not map step valid interrupt to INT2 pin INT2_HD: 1, map hand down interrupt to INT2 pin 0, not map hand down interrupt to INT2 pin INT2_RAISE: 1, map raise hand interrupt to INT2 pin 0, not map raise hand interrupt to INT2 pin INT2_SIG_MOT: 1, map significant interrupt to INT2 pin 0, not map significant interrupt to INT2 pin Register 0x1c (INT_MAP3) Bit7 Bit6 Bit5 Bit4 Bit3 Bit2 INT2_NO_ INT2_FWM INT2_FFUL INT2_DAT MOT L A INT2_NO_MOT: 1, map no_motion interrupt to INT2 pin 0, not map no_motion interrupt to INT2 pin INT2_FWM: 1, map FIFO watermark interrupt to INT2 pin Bit1 INT2_RAISE Bit1 INT2_Q_TA P Bit0 INT2_SI G_MOT Bit0 INT2_ANY_ MOT R/W RW R/W RW Default 0x00 Default 0x00 0, not map FIFO watermark interrupt to INT2 pin INT2_FFULL: INT2_DATA: INT2_Q_TAP: INT2_ANY_MOT: 1, map FIFO full interrupt to INT2 pin 0, not map FIFO full interrupt to INT2 pin 1, map register data ready interrupt to INT2 pin 0, not map register data ready interrupt to INT2 pin 1, map quad tap interrupt to INT2 pin 0, not map quad tap interrupt to INT2 pin 1, map any motion interrupt to INT2 pin 0, not map any motion interrupt to INT2 pin Register 0x1d (STEP_CFG0) Bit7 Bit6 Bit5 STEP_INTERVAL STEP_INTERVAL : algorithm setting Bit4 Bit3 Bit2 Bit1 Bit0 Register 0x1e (STEP_CFG1) Bit7 Bit6 Bit5 Bit4 Bit3 Bit2 Bit1 Bit0 NLPF_STEP TAP_QUIET NLPF_STEP: Moving Average of Step: 1/2/4/8 TAP_QUIET_TH: Tap quiet threshold selection, LSB of TAP_QUIET_TH is 31.25mg in all full scale. Register 0x1f Bit7 Bit6 STEP_START_CNT STEP_START_CNT: STEP_COUNT_PEAK: STEP_COUNT_P2P: Bit5 Bit4 Bit3 STEP_COUNT_PEAK algorithm setting algorithm setting algorithm setting Register 0x20 (INTPIN_CONF) Bit7 Bit6 Bit5 DIS_PU_SE DIS_IE_AD EN_SPI3W NB 0 Bit4 STEP_COU NT_PEAK< 2> Bit3 INT2_OD R/W RW Default 0x00 R/W RW Default 0x08 Bit2 Bit1 STEP_COUNT_P2P Bit0 R/W RW Default 0xA9 Bit2 INT2_LVL Bit0 INT1_LVL R/W RW Default 0x05 Bit1 INT1_OD The information contained herein is the exclusive property of QST, and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of QST. 32 / 37 矽睿 Document #: 13-52-20 Title: QMA6100P Preliminary Datasheet Rev: A1 DIS_PU_SENB: 1, disable pull-up resistor of PIN_SENB 0, enable pull-up resistor of PIN_SENB DIS_IE_AD0: 1, disable input of AD0 0, not disable input of AD0 EN_SPI3W: 1, enable 3W SPI 0, 4W SPI STEP_COUNT_PEAK: Definition in 0x1F INT2_OD: 1, open-drain for INT2 pin 0, push-pull for INT2 pin INT2_LVL: 1, logic high as active level for INT2 pin 0, logic low as active level for INT2 pin INT1_OD: 1, open-drain for INT1 pin 0, push-pull for INT1 pin INT1_LVL: 1, logic high as active level for INT1 pin 0, logic low as active level for INT1 pin Register 0x21 (INT_CFG) Bit7 Bit6 Bit5 Bit4 Bit3 Bit2 Bit1 Bit0 R/W INT_RD_CL SHADOW_ DIS_I2C LATCH_INT LATCH_INT RW R DIS _STEP INT_RD_CLR: 1, clear all the interrupts in latched-mode, when any read operation to any of registers from 0x09 to 0x0D 0, clear the related interrupts, only when read the register INT_ST (0x09 to 0x0D), no matter the interrupts in latched-mode, or in non-latched-mode. Reading 0x09 will clear the register 0x09 only and the others keep the status SHADOW_DIS: 1, disable the shadowing function for the acceleration data 0, enable the shadowing function for the acceleration data. When shadowing is enabled, the MSB of the acceleration data is locked, when corresponding LSB of the data is reading. This can ensure the integrity of the acceleration data during the reading. The MSB will be unlocked when the MSB is read. DIS_I2C: 1: disable I2C. Setting this bit to 1 in SPI mode is recommended 0: enable I2C LATCH_INT_STEP: 1, step related interrupt is in latch mode 0, step related interrupt is in non-latch mode LATCH_INT: 1, interrupt is in latch mode 0, interrupt is in non-latch mode Register 0x22 Bit7 Bit6 Bit5 Bit4 RAISE_WAKE_DIFF_TH RAISE_WAKE_SUM_TH RAISE_WAKE_DIFF_TH: Threshold = 0 ~ 31.5 (LSB 0.5) RAISE_WAKE_SUM_TH: 0 0.2 1 0.3 2 0.4 3 0.5 4 0.6 5 0.7 6 0.8 7 0.9 8 1.0 9 1.1 10 1.2 default 0.2 Bit3 Register 0x23 Bit7 Bit6 Bit5 Bit4 Bit3 HD_Z_TH HD_X_TH HD_Z_TH: hand down z threshold, 0~7 HD_X_TH: hand down x threshold, 0~7 RAISE_WAKE_DIFF_TH: Threshold = 0 ~ 31.5 (LSB 0.5) Bit2 Bit2 Bit1 Bit0 Bit1 Bit0 RAISE_WAKE_DIFF_TH Default 0x0C R/W RW Default 0xD8 R/W RW Default 0x7C Register 0x24 The information contained herein is the exclusive property of QST, and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of QST. 33 / 37 矽睿 Document #: 13-52-20 Title: QMA6100P Preliminary Datasheet Bit7 Bit6 Bit5 Bit4 Bit3 Bit2 Bit1 RAISE_WAKE_TIMEOUT_TH RAISE_WAKE_TIMEOUT_TH: Raise_wake_timeout_th[11:0] * ODR period = timeout count Register 0x25 Bit7 Bit6 RAISE_WAKE_PERIOD RAISE_WAKE_PERIOD: Bit5 Bit4 Bit3 Bit2 Bit1 Rev: A1 Bit0 R/W RW Default 0x00 Bit0 R/W RW Default 0x00 Bit0 R/W RW Default 0x02 Raise_wake_period[10:0] * ODR period = wake count Register 0x26 Bit7 Bit6 Bit5 Bit4 Bit3 Bit2 Bit1 RAISE_MODE RAISE_WAKE_PERIOD RAISE_WAKE_TIMEOUT_TH RAISE_MODE: 0:raise wake function, 1:ear-in function RAISE_WAKE_PERIOD: Raise_wake_period[10:0] * ODR period = wake count RAISE_WAKE_TIMEOUT_TH: Raise_wake_timeout_th[11:0] * ODR period = timeout count Register 0x27 (OS_CUST_X) Bit7 Bit6 Bit5 Bit4 Bit3 Bit2 Bit1 Bit0 R/W OS_CUST_X RW OS_CUST_X: offset calibration of X axis for user, the LSB depends on full-scale of the device which is 3.9mg in 2g range, 7.8mg in 4g range, 15.6mg in 8g range, 31.2mg in 16g, and 62.5mg in 32g Register 0x28 (OS_CUST_Y) Bit7 Bit6 Bit5 Bit4 Bit3 Bit2 Bit1 Bit0 R/W OS_CUST_Y RW OS_CUST_Y: offset calibration of Y axis for user, the LSB depends on full-scale of the device which is 3.9mg in 2g range, 7.8mg in 4g range, 15.6mg in 8g range, 31.2mg in 16g, and 62.5mg in 32g Register 0x29 (OS_CUST_Z) Bit7 Bit6 Bit5 Bit4 Bit3 Bit2 Bit1 Bit0 R/W OS_CUST_Z RW OS_CUST_Z: offset calibration of Z axis for user, the LSB depends on full-scale of the device which is 3.9mg in 2g range, 7.8mg in 4g range, 15.6mg in 8g range, 31.2mg in 16g, and 62.5mg in 32g Register 0x2a (RAISE_WAKE_SUM_TH RAISE_WAKE_DIFF_TH) Bit7 Bit6 Bit5 Bit4 Bit3 Bit2 Bit1 Bit0 TAP_QUIET TAP_SHOC TAP_DELA TAP_EARIN TAP_DUR K Y TAP_QUIET: 1: Tap quiet time = 30ms 0: Tap quiet time = 20ms TAP_SHOCK: 1: Tap shock time = 50ms 0: Tap shock time = 75ms TAP_DELAY_Y: 0 : Triple tap interrupt would not wait for quadruple tap result. 1 : Triple tap interrupt would wait for quadruple tap result. If quadruple tap is not toggle, triple tap would toggle after tap duration time finish. TAP_EARIN: 1 : Tap enable would be related with EARIN_FLAG (reg 0x0B). If EARIN_FLAG is low, tap detection will be disabled. If EARIN_FLAG is high, tap detection is enabled by reg 0x16. 0 : Tap detection is enabled by reg 0x16. TAP_DUR: Tap duration time selection 000: 100mS 001: 150mS 010: 200mS 011: 250mS 100: 300mS 101: 400mS 110: 500mS 111: 700mS Register 0x2b (RAISE_WAKE_DIFF_TH HD_X_TH HD_Z_TH) Bit7 Bit6 Bit5 Bit4 Bit3 TAP_IN_SEL TAP_SHOCK_TH Bit2 Bit1 Bit0 Default 0x00 Default 0x00 Default 0x00 R/W RW Default 0x05 R/W RW Default 0xCD TAP_IN_SEL: Tap Detector Input Selection The information contained herein is the exclusive property of QST, and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of QST. 34 / 37 矽睿 TAP_SHOCK_TH: Document #: 13-52-20 Title: QMA6100P Preliminary Datasheet Rev: A1 0 : X-axis 1 : Y-axis 2 : Z-axis 3 : (X^2 + Y^2 + Z^2)^0.5 Tap shock threshold selection, LSB of TAP_SHOCK_TH is 31.25mg in all full scale. Register 0x2c (MOT_CONF0) Bit7 Bit6 Bit5 Bit4 Bit3 Bit2 Bit1 Bit0 R/W Default NO_MOT_DUR ANY_MOT_DUR RW 0x00 NO_MOT_DUR: no motion interrupt will be triggered when slope < NO_MOT_TH for the times which defined by NO_MOT_DUR Duration = (NO_MOT_DUR + 1) * 1s, if NO_MOT_DUR =b00 Duration = (NO_MOT_DUR + 4) * 5s, if NO_MOT_DUR =b01 Duration = (NO_MOT_DUR + 10) * 10s, if NO_MOT_DUR =b1x ANY_MOT_DUR: any motion interrupt will be triggered when slope > ANY_MOT_TH for (ANY_MOT_DUR + 1) samples Register 0x2d (MOT_CONF1) Bit7 Bit6 Bit5 Bit4 Bit3 Bit2 Bit1 NO_MOT_TH NO_MOT_TH: Threshold of no-motion interrupt. The threshold definition is as following TH= NO_MOT_TH * 16 * LSB Register 0x2e (MOT_CONF2) Bit7 Bit6 Bit5 Bit4 Bit3 Bit2 Bit1 ANY_MOT_TH ANY_MOT_TH: Threshold of any motion interrupt. The threshold definition is as following ANY_MOT_IN_SEL = 0 : Threshold = ANY_MOT_TH * 16LSB ANY_MOT_IN_SEL = 1 : Threshold = ANY_MOT_TH * 32LSB ANT_MOT_IN_SEL is 0x2F. Bit0 R/W RW Default 0x00 Bit0 R/W RW Default 0x00 Register 0x2f (MOT_CONF3) Bit7 Bit6 Bit5 Bit4 Bit3 Bit2 Bit1 Bit0 R/W RFF_BP_LP ANY_MOT SIG_MOT_TPROOF SIG_MOT_TSKIP SIG_MOT_ RW F _IN_SEL SEL RFF_BP_LP: 1: Data of register acceleration XYZ (0x01 ~ 0x06) and FIFO (0x3F) would bypass LPF. 0: Data of register file acceleration XYZ (0x01 ~ 0x06) and FIFO (0x3F) would be filtered by LPF. ANY_MOT_IN_SEL: 0: Any-motion Input is Slope. 1: Any-motion Input is Acceleration, it could detect high-g. SIG_MOT_TPROOF: 00, T_PROOF=0.25s 01, T_PROOF=0.5s 10, T_PROOF=1s 11, T_PROOF=2s SIG_MOT_TSKIP: 00, T_SKIP=1.5s 01, T_SKIP=3s 10, T_SKIP=6s 11, T_SKIP=12s SIG_MOT_SEL: 1, select significant motion interrupt 0, select any motion interrupt Register 0x30 Bit7 MO_BP_LP F MO_BP_LPF: Bit6 Bit5 Bit4 Bit3 Bit2 Bit1 STEP_BP_L TAP_RST_ NO_MOT_ SIG_MOT_ PF N RST_N RST_N 1: Input of any motion, sig motion and no motion would bypass LPF. 0: Input of any motion, significant motion and no motion would be filtered by LPF. STEP_BP_LPF: 1: Input of step counter, raise wake, and tap detector would bypass LPF. 0: Input of step counter, raise wake, and tap detector would be filtered by LPF. TAP_RST_N: 0, Reset tap detector. After reset, user should write 1 back. NO_MOT_RST_N: 0, Reset no motion detector. After reset, user should write 1 back. SIG_MOT_RST_N: 0, Reset significant motion detector. After reset, user should write 1 back. ANY_MOT_RST_N: 0, Reset any motion detector. After reset, user should write 1 back. Bit0 ANY_MOT _RST_N R/W RW Default 0x00 Default 0x1F Register 0x31 Bit7 Bit6 Bit5 Bit4 Bit3 Bit2 Bit1 Bit0 R/W Default FIFO_WTMK_LVL 0x00 FIFO_WTMK_LVL: defines FIFO water mark level. Interrupt will be generated, when the number of entries in the FIFO exceeds FIFO_WTMK_LVL. The information contained herein is the exclusive property of QST, and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of QST. 35 / 37 Document #: 矽睿 13-52-20 Title: QMA6100P Preliminary Datasheet Rev: A1 When the value of this register is changed, the FIFO_FRAME_COUNTER in 0x0E is reset to 0. Register 0x32 (ST) Bit7 Bit6 SELFTEST_ BIT SELFTEST_BIT: SELFTEST_SIGN: STEP_BP_AXIS: Bit5 Bit4 Bit2 Bit1 Bit0 R/W SELFTEST_ STEP_BP_AXIS RW SIGN 1, self-test enabled. When self-test enabled, a delay of 3ms is necessary for the value settling. 0, normal 1, set self-test excitation positive 0, set self-test excitation negative 11, bypass Z axis, use only X and Y axes data for step counter algorithm 10, bypass Y axis, use only X and Z axes data for step counter algorithm 01, bypass X axis, use only Y and Z axes data for step counter algorithm 00, use all of 3 axes data for step counter algorithm Register 0x34 (Y_TH YZ_TH_SEL) Bit7 Bit6 Bit5 Bit4 YZ_TH_SEL Y_TH Y_TH: -16 ~ 15 (m/s2) YZ_TH_SEL UNIT (m/s2) 0 7.0 1 7.5 2 8.0 3 8.5 4 9.0 5 9.5 6 10.0 7 10.5 Register 0x35 (RAISE_WAKE_PERIOD) Bit7 Bit6 Bit5 Z_TH X_TH[3:0]: 0 ~ 7.5 Z_TH[3:0] : -8 ~ 7 Bit4 Bit3 Default 0x00 Bit3 Bit2 Bit1 Bit0 R/W RW Default 0x9D Bit3 X_TH Bit2 Bit1 Bit0 R/W RW Default 0x66 Bit0 R/W RW Default 0x00 Register 0x36 (SR) Bit7 Bit6 Bit5 Bit4 Bit3 Bit2 Bit1 SOFT_RESET SOFT_RESET: 0xB6, soft reset all of the registers. After soft-reset, user should write 0x00 back Register 0x3e (FIFO_CFG0) Bit7 Bit6 Bit5 Bit4 Bit3 Bit2 Bit1 Bit0 R/W Default FIFO_MODE RAISE_XYZ_SW FIFO_EN_Z FIFO_EN_Y FIFO_EN_X RW 0x07 FIFO_MODE : FIFO_MODE: FIFO_MODE defines FIFO mode of the device. Settings as following FIFO_MODE MODE 11 FIFO 10 STREAM 01 FIFO 00 BYPASS RAISE_XYZ_SW is x/y/z axis switcher, default setting is “0: XYZ” and below is the detail configuration. Both raise wake and ear in/out can use this function. 0x3E[5:3] X Y Z 0 X Y Z 1 X Z Y 2 Y X Z 3 Y Z X 4 Z X Y 5 Z Y X 6 X Y Z 7 X Y Z 0x3E[2:0]: User can select the acceleration data of which axis to be stored in the FIFO. This configuration can be done by setting FIFO_CH, where ‘111b’ for x-, y-, and z-axis, ‘001b’ for x-axis only, ‘010b’ for y-axis only, ‘100b’ for z-axis only. The information contained herein is the exclusive property of QST, and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of QST. 36 / 37 Document #: 矽睿 Register 0x3f (FIFO_DATA) Bit7 Bit6 FIFO_DATA Bit5 Bit4 13-52-20 Title: QMA6100P Preliminary Datasheet Bit3 Bit2 Bit1 Bit0 R/W R Rev: A1 Default 0x00 FIFO_DATA: FIFO read out data. User can read out FIFO data through this register. Data format depends on the setting of FIFO_CH (0x3e). When the FIFO data is the LSB part of acceleration data, and if FIFO is empty, then FIFO_DATA is 0. Otherwise if FIFO is not empty and the data is effective, FIFO_DATA is 1 when reading LSB of acceleration. ORDERING INFORMATION Ordering Number Temperature Range Package Packaging QMA6100P -40℃~85℃ LGA-12 Tape and Reel: 5k pieces/reel FIND OUT MORE For more information on QST’s Accelerometer Sensors contact us at 86-21-69517300. The application circuits herein constitute typical usage and interface of QST product. QST does not provide warranty or assume liability of customer-designed circuits derived from this description or depiction. QST reserves the right to make changes to improve reliability, function or design. QST does not assume any liability arising out of the application or use of any product or circuit described herein; neither does it convey any license under its patent rights nor the rights of others. ISO9001 : 2015 China Patents 201510000399.8, 201510000425.7, 201310426346.3, 201310426677.7, 201310426729.0, 201210585811.3 and 201210553014.7 apply to the technology described. The information contained herein is the exclusive property of QST, and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of QST. 37 / 37
QMA6100P 价格&库存
很抱歉,暂时无法提供与“QMA6100P”相匹配的价格&库存,您可以联系我们找货
QMA6100P
  • 1+3.62500
  • 30+3.50000
  • 100+3.25000
  • 500+3.00000
  • 1000+2.87500
QMA6100P
    • 1+3.57480
    • 10+2.91600
    • 30+2.63520
    • 100+2.27880
