P1405A
P1405A
    PRISEMI(上海芯导电子)
    DFN6_2X2MM
    过电压保护器 电源电压3V~32V DFN6_2X2MM
P1405A 数据手册
P1405A Over voltage protector Description The P1405A over-voltage protection device features an ultra-low 30mΩ (typical) on-resistance high current integrated N-MOSFET which actively protects low-voltage systems from voltage supply faults up to +32VDC. An input voltage exceeding the over-voltage threshold will cause the internal MOSFET to turn off, preventing excessive voltage from damaging downstream devices. P1405A has thermal protection at 140°C The P1405A is available in a RoHS and Green compliant DFN2x2-6L package. VIN VBUS VOUT VBUSOUT 1uF PUDN 1uF P1405A GND Figure 1. Typical Application 6 1 VBUSOUT 2 PUND 3 GND P1405X XXXXX YYMM VBUS VBUS NC5 5 NC4 4 GND P1405A Figure 2. Pin order (Bottom view) and Marking (Top view) Feature Application  Wide Input voltage range: 3.0-32V  Cellular Phones, Smart Phones, PDAs  Ultra-low 30mohm On-resistance.  Tablet, Portable Media Players  Fixed OVP Threshold:6.0V  Gaming Device, Digital Cameras  Fast turn-off response time: 50ns  Soft-start function to avoid in-rush current  -40-85°C operation temperature  DFN2x2-6L Rev.06.7 1 www.prisemi.com P1405A Over voltage protector Pin Definitions Pin# PIN Name Description 1 VBUSOUT 2 PUND 3 GND Ground. 4 NC4 Not connected. 5 NC5 Not connected. 6 VBUS Output voltage. Pull down output voltage to ground when input voltage is higher than OVP threshold voltage. Input voltage. Block Diagram VBUS,6 VBUSOUT,1 PUDN,2 OVP Charge control Pump LDO Figure 3. IC Block Diagram Rev.06.7 2 www.prisemi.com P1405A Over voltage protector Absolute maximum rating Parameter(Note1) Symbol Value Units VBUS -0.3 to 32 V VBUSOUT -0.3 to 7 V PUDN voltage range VPUDN -0.3 to 7 V AVDD voltage range VAVDD -0.3 to 7 V Switch I/O Continuous Current IIN 3 A Junction temperature TJ 150 ℃ Lead temperature(Soldering,10s) TL 260 ℃ TSTG -55 to 150 ℃ 3000 V 500 V VBUS voltage range VBUSOUT voltage range Storage temperature HBM (Except VBUSOUT PIN) ESD Ratings CDM Note 1: Stresses greater than those listed under "Absolute Maximum Ratings" may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated under "Recommended Operating Conditions" is not implied. Exposure to "Absolute Maximum Ratings" for extended periods may affect device reliability. Recommended Operating Conditions Parameter Symbol Value Units VBUS 3.0 to 32,typical=5 V TA -40 to 85 ℃ RθJA 67.5 ℃/W VBUS input voltage range Operating ambient temperature Thermal Resistance Note 2: Junction to Ambient thermal resistance is highly dependent on PCB layout. Values are based on thermal properties of the device when soldered to an EV board. Rev.06.7 3 www.prisemi.com P1405A Over voltage protector Electrical Characteristics (TA=25℃,VBUS=5V,CIN=1uF,COUT=1uF,for 5V application,unless otherwise specified.) Parameter Symbol Conditions Min. Typ. Max. Units Basic Operation IDDQ1 VBUS=5V,No load 120 uA IDDQ2 VBUS=30V,No load 190 uA VBUS Rising 2.4 VBUS=0->5V to Output ON 18 VBUS=5V,IOUT=1A 30 40 mΩ 6.0 6.15 V Quiescent Supply Current UVLO Threshold Voltage Start-up Delay Time Main Switch ON-Resistance VUVLO TSTART_DLY RON 3.2 V ms Over-Voltage Protection VBUS OVP Threshold VOVP OVP Response Time tOVP OVP Recovery Time tR_OVP Output discharge resistance RDCHG VBUS Rising VIN > VOVP to VOUT stop rising VIN < VOVP to VOUT start rising VIN > VOVP 5.85 50 ns 18 ms 400 Ω Thermal Protection Over-Temperature Protection Threshold TSD 140 ℃ Over-Temperature Protection Hysteresis THYS 20 ℃ Rev.06.7 4 www.prisemi.com P1405A Over voltage protector Typical Characteristics VBUS VBUS VBUSOUT VBUSOUT IOUT 5ms/div 2ms/div Figure 4. Start-up waveform(Rload=10Ω) Figure 5. OVP response VBUS VBUSOUT 5ms/div Figure 6. OVP recovery waveform Rev.06.7 5 www.prisemi.com P1405A Over voltage protector Product dimension (DFN2x2-6L) A Millimeters C 4 Inches Dim 5 6 MIN MAX MIN MAX A 1.924 2.076 0.076 0.082 B 1.924 2.076 0.076 0.082 C 0.250 0.400 0.010 0.016 H F E 6 3 B 3 G 1 2 D Bottom view L D 0.650(typ.) 0.026(typ.) E 0.200 MIN. 0.008 MIN. F 0.520 0.720 0.020 0.028 G 0.750 1.100 0.030 0.043 H 0.174 0.380 0.007 0.015 J 0.550 0.800 0.022 0.031 L 0 0.050 0 0.002 K 0.180 0.200 0.007 0.008 K J Side view 2.30 0.40 0.45 0.25 0.65 0.77 1.15 Unit:mm PCB Layout Guide Rev.06.7 6 www.prisemi.com P1405A Over voltage protector IMPORTANT NOTICE and are registered trademarks of Prisemi Electronics Co., Ltd (Prisemi) ,Prisemi reserves the right to make changes without further notice to any products herein. Prisemi makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does Prisemi assume any liability arising out of the application or use of any product or circuit, and specifically disclaims any and all liability, including without limitation special, consequential or incidental damages. “Typical” parameters which may be provided in Prisemi data sheets and/or specifications can and do vary in different applications and actual performance may vary over time. All operating parameters, including “Typicals” must be validated for each customer application by customer’s technical experts. Prisemi does not convey any license under its patent rights nor the rights of others. The products listed in this document are designed to be used with ordinary electronic equipment or devices, Should you intend to use these products with equipment or devices which require an extremely high level of reliability and the malfunction of with would directly endanger human life (such as medical instruments, aerospace machinery, nuclear-reactor controllers, fuel controllers and other safety devices), please be sure to consult with our sales representative in advance. Website: http://www.prisemi.com For additional information, please contact your local Sales Representative. ©Copyright 2009, Prisemi Electronics is a registered trademark of Prisemi Electronics. All rights are reserved. Rev.06.7 7 www.prisemi.com
P1405A 价格&库存
很抱歉,暂时无法提供与“P1405A”相匹配的价格&库存,您可以联系我们找货
P1405A
    • 3000+0.53393
    库存:189000
