HYT-1203
SPEC V1.0
规格书
Specification
品 名
HYT-1203
Model name
PROPRIETARY
Huayu Electronic co.,Ltd.
CONFIDENTIAL
Version #
Spec V1.0
制作日期
Date
2018/4/01
准备
Prepared
Yi Shen
Acoustic specialist,R&D Dept.
承认
Approved
Qian Wanjin
Executive Manager,R&D Dept.
兴化市华宇电子有限公司
地址:江苏省兴化市陈堡工业区人民路 1 号
电话:13625199874 传真:0523-83723118
邮箱:3912453758@qq.com 网址:www.js-huayu.com
Components Operating Div.
HYT-1203
1.适用范围:本规范适用于 HYT-1203
This specifications apply the
SPEC V1.0
蜂鸣器。
HYT-1203
buzzer.
2.基本规格/General specification
项目/Item
额定电压
1
Rated voltage
工作电压
2
Operation voltage
声压
3
Sound Pressure Level=SPL
平均消费电流
4
Average consumption current
振荡频率
5
Oscillation frequency
响应时间
6
Response time
工作温度范围
7
Range of operation temperature
保存温度范围
8
Range of preservation temperature
端子强度
9
Terminal strength
外部尺寸
10
Externals size
重量
11
Mass
规格/Spec
条件/Condition
3VDC
2~5VDC
Min 85dB
Max 30mA
2400±300Hz
测试环境:标准状态,标准驱动电路,额
定电压
测试距离:0.1m
Standard State,Standard Drive Circuit.
Rated voltage,Distance at 0.1m
Max 50mS
-30~+80℃
-40~+85℃
10N
Φ12x9.5
拉负荷方向的终端轴
Pull load on the direction of the terminal axis
参阅附图
Refer to the attached drawing
2g
3. 电气和声学测试条件/Electrical And Acoustical Measuring Condition
驱动电路/Recommended Driving Circuit
Resonant frequency, 1/2 duty cycle. Square wave.
Signal amplitude should be large enough tosaturate the
transistor.
设置 Recommended Setting
HYT-1203
4.可靠性规范/Reliability specification
SPEC V1.0
项目/Item
试验条件/Test condition
判断标准/Criteria
引用规格
1
高温保存试验
+85℃环境下放置 96 小时
经过测试,符合规格,没
GB/T
High temperature
Exposure to +85℃ for 96 hrs.
有任何不合格的外观和性
2423.2
能 , 除了是 80 分贝或以
Preservation
2
3
低温保存试验
-40℃环境下放置 96 小时
上(2400±300 Hz)
GB/T
Low
Exposure to -40℃ for 96 hrs.
After the test the part
2423.1
temperature
preservation
shall meet specificati
耐温试验
-ons without any degra
GB/T
-dation in appearance
2423.4
Thermal Shock
-40℃
+85℃
30min
10 次周期
And performance except
30min
SPL.SPL shall be 80 dB
10 cycles
4
温湿度试验
More.(at 2400±300 Hz)
65℃、90~95%RH
Thermal,Humidity
Shock
a、b=0.5H
25℃、90~95%RH
5H
a
6H
b
12H.(1 个周期)
5
6
10 cycles
常温寿命试验
常温(25℃±10℃)电压 3VDC 连续测试 1000 小时
Ordinary
Driving the sounder at 3VDC for 1000hrs in the room
Temp.Life
temperature(25℃±10℃)
高温寿命试验
高温(+85℃)电压 3VDC 连续测试 500 小时
High Temp.Life
Driving
the
sounder
at
3VDC
for
500hrs
in
the
low
500hrs
in
the
low
temperature(+85℃)
7
低温寿命试验
低温(-40℃)电压 3VDC 连续测试 500 小时
Low Temp.Life
Driving
the
sounder
at
3VDC
for
temperature(-40℃)
8
9
引脚拉力试验
10N 的拉力在引脚上拉 10±1 秒
GB/T
Lead strength
Pull load on the direction of the terminal axis for 10±1 sec.
2423.29
振动试验
10~55~10Hz 正弦波测试 1 分钟,振幅 1.52mm 最大 91m/S² X,Y,
GB/T
Vibration
Z 三个方向每个 2 小时总计 6 小时
2423.10
10~55~10Hz Sinewave,Sweep 1 min,Amplitude 1.52mm Max91m/S
² X,Y,Z 3Direction 2hrs each,Total 6hrs
10
自由掉落试验
70cm 高自由掉落到厚 40mm 的木板上,每个方向一次
排除弯曲的针
GB/T
Free drop
Free drop,70cm height, on wood boad (t40mm)
Exclude bending of Pin
2423.8
X,Y,Z 3Direction 1time each, total 3times.
11
波峰焊耐热试验
250±5℃焊接温度。浸泡时间 3±0.2sec
经过测试,符合规格,没有任
GB/T
Solder
Soldering into solderbath:Solder Temp.250±5℃
何不合格的外观和性能
2423.28
heat
resistance
12
Soaking Time:3±0.2sec
耐洗性试验
溶剂:去离子水,溶剂温度:55±5℃,浸泡时间:5±0.5 分钟
Shall meet specificatio
Washability
Solvent:deionized water,Solvent temp:55±5℃
-ns without any degrada
Soaking time:5±0.5minutes
-tion in appearance and
performance
13
引脚可焊性试验
40℃,相对湿度 90~95%RH 放置 240 小时,370±5℃焊接温度。 引脚 95%必须覆盖着焊料
GB/T
Solderability
浸泡时间:6±0.5sec。
2423.28
95% surface of lead pins must
Pretreatment:40℃,90~95%RH*240hrs
be covered with fresh solder
Soldering into solderbath:Solder Temp.370±5℃
and no soldering holes
Soaking Time:6±0.5sec
Should be found
5.尺寸图/Dimension
(UNT:mm)
Tolerance:±0.5mm Except Specified
6.频率图/Frequency Curve
3Vo-p 50% duty Square wave,10cm
7.Packing Method/包装图
兴化市华宇电子有限公司
很抱歉,暂时无法提供与“HYT-1203”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+4.76426
- 30+4.59998
- 100+4.27141
- 500+3.94284
- 1000+3.77855
