OB2EL89CLIC112YLC-156.25M 数据手册
Differential Oscillator
YSO230LR
Applications
Features
‧10 GB Ethernet,
SONET, SATA, SAS,
Fibre Channel
‧Freq range:13.5MHz-200MHz.
‧Package Size: 2.5*2.0 ,3.2*2.5 , 5.0*3.2
7.0*5.0mm.
‧Output LVPECL or LVDS.
Specifications
LVPECL
Item/Type
Output Frequency Range
LVDS
7050/5032
3225/2520
7050/5032
3225/2520
13.5~200MHZ
13.5~156.25MHZ
13.5~200MHZ
13.5~156.25MHZ
Supply Voltage
2.5V~3.3V
Remarks
1.8V, 2.5V~3.3V
Operating Temperature Range
-40~+85℃,or specify
Storage Temperature Range
-55~+125℃
Total Stability
±50ppm
Current Consumption
80mA Max
50mA Max
Disable Current
60mA Max
40mA Max
OE=Vcc,LVPECL=(50)Ω or LVDS=(100)Ω
10uA Max
Output Voltage (LVPECL)
VOH=Vcc-1.03 Min
VOL=Vcc-1.6 Max
VOD= 247~454mV
VOD1, VOD2
dVOD=50mV Max.
dVOD=|VOD1-VOD2|
VOS= 1.125~1.375V
VOS1, VOS2
dVOS=|VOD1-VOD2|
Output Voltage (LVDS)
Output Load Condition
OE=GND
DC characteristics
DC characteristics
dVOS=50mV Max.
L_PECL=50Ω
Terminated to Vcc-2.0V
L_LVDS=100Ω
Connected between OUT to OUT
Input Voltage
VIH=70% VccMin, VIL=30%Vcc Max
Output Symmetry
OE terminal
45~55%
Rise Time/Fall Time
LVPECL: Between 20% and 80% of (VOH-VOL),
LVDS:Between 20% and 80% Differential Output
peak to peak voltage
0.8nS Max
Start-up time
10mS
Time at minimum supply voltage to be 0 s
Aging
±3ppm
25℃First year, Vcc=2.5V,3.3V
100MHZ
Phase Jitter(12KHZ~20MHZ)
125MHZ
148.5MHZ
156.25MHZ
0.3ps Typ.
180MHZ
200MHZ
0.1ps Typ.
Pin Dimension
Pin
#1
#2
#3
#4
#5
#6
FUNCTION
OE
NC
GND
OUT+
OUT-
VDD
Notes: To maintain stable operation provide a 0.01uF to 0.1uF by-pass capacitor at a location
as near as possible to the power source terminal of the crystal product (between Vcc-GND).
www.yxc.hk
第1页共3页
YSO230LR
Dimensions and Patterns [unit:mm]
Package Size – Dimensions (Unit: mm)
Recommended Land Pattern (Unit: mm)
2.5*2.0mm
3.2*2.5mm
5.0*3.2mm
7.0*5.0mm
Notes:
1.A capacitor of value 0.01uf~0.1uf or higher between Vdd and GND is required.
www.yxc.hk
第2页共3页
YSO230LR
Reflow Soldering Profile
Temperature
Pre Heating Temperature Tp1 ~ Tp2 = + 170 °C
Heating Temperature
TMlt = + 220 °C
Peek Temperature
TMax. = + 260 °C
+260℃
TMax.
+220℃
Tmlt
Point of measuring
In case of Solder ability Terminal.
In case of Resistance to soldering heat Surface.
Tp2
Tp1
35s
100s
t(time)
Test Circuit
LVDS
LVPECL
Taping Specification(Unit: mm)
Size(OSC)
A
B
C
D
E
F
G
H
SMD-7050
180±2.0
16.0±0.3
7.50±0.1
5.50±0.1
8.0±0.1
2.00±0.1
61.0±1.0
16.0±1.0
SMD-5032
180±2.0
12.0±0.3
5.40±0.1
3.60±0.1
8.0±0.1
1.70±0.1
61.0±1.0
12.0±1.0
SMD-3225
180±2.0
8.0±0.3
3.40±0.1
2.70±0.1
4.0±0.1
1.50±0.1
61.0±1.0
8.0±1.0
SMD-2520
180±2.0
8.0±0.3
2.90±0.1
2.40±0.1
4.0±0.1
1.20±0.1
61.0±1.0
8.0±1.0
www.yxc.hk
第3页共3页
OB2EL89CLIC112YLC-156.25M 价格&库存
很抱歉,暂时无法提供与“OB2EL89CLIC112YLC-156.25M”相匹配的价格&库存,您可以联系我们找货
