CFM06S SERIES
6 WATT OPEN FRAME
AC-DC MODULES
Features
Universal Input Range 90~264Vac
High Efficiency up to 83%
0.764”x 1.555” Compact Size
Class II
No Load Power 95% Reduction
Criterion A
Voltage Interruptions
IEC 61000-4-11:2020, >95% Reduction
Criterion B
Application Note Link
CFM06S Series App Notes
CHARACTERISTIC CURVE
Power Derating Curve
Derating curve for Natural Convection
Rated Load (%)
100%
75%
50%
25%
0%
-40 -30 -20 -10 0 10 20 30 40 50 60 70 80
Ambient Temperature(oC)
Performance Data
CFM06S050 (Eff Vs Io)
85%
80%
80%
Efficiency (%)
Efficiency (%)
CFM06S033 (Eff Vs Io)
85%
75%
70%
65%
115V
60%
55%
50%
10%
30%
40%
50%
60%
70%
80%
65%
115V
60%
50%
10%
90% 100%
Current Load (%)
www.cincon.com
70%
55%
230V
20%
75%
230V
20%
30%
40%
50%
60%
70%
80%
90% 100%
Current Load (%)
4
REVISION: V16
CFM06S
CFM06S120 (Eff Vs Io)
85%
85%
80%
80%
Efficiency (%)
Efficiency (%)
CFM06S090 (Eff Vs Io)
75%
70%
65%
115V
60%
55%
50%
10%
30%
40%
50%
60%
70%
80%
75%
70%
65%
115V
60%
55%
230V
20%
50%
10%
90% 100%
230V
20%
30%
Current Load (%)
80%
80%
75%
70%
65%
115V
60%
40%
50%
60%
70%
70%
80%
90% 100%
80%
75%
70%
65%
55%
10%
90% 100%
Current Load (%)
www.cincon.com
60%
115V
60%
230V
30%
50%
CFM06S240 (Eff Vs Io)
85%
Efficiency (%)
Efficiency (%)
CFM06S150 (Eff Vs Io)
20%
40%
Current Load (%)
85%
55%
10%
Series
230V
20%
30%
40%
50%
60%
70%
80%
90% 100%
Current Load (%)
5
REVISION: V16
CFM06S
Series
MECHANICAL SPECIFICATION
CFM06SXXX
CFM06SXXX-E
1.555 [39.50]
0.201 [5.10]
4
Φ0.020[Φ0.50]
0.300[7.62]
1.618 [41.10]
1.300[33.02]
Φ0.020[Φ0.50]
0.159 [4.04]
PIN CONNECTION
Pin
Function
1
ACN
2
ACL
3
+Vout
-Vout
4
BOTTOM VIEW
4
2
3
0.827 [21.00]
0.600[15.24]
1
0.113 [2.88]
0.720 [18.30]max
0.201 [5.10]
0.583 [14.80]max
0.300 [7.62]
2
0.098 [2.50]max
0.600 [15.24]
0.082 [2.08]
0.764 [19.40]
3
1
0.787 [20.00]
0.128 [3.24]
All Dimensions In Inches[mm]
Tolerance Inches:x.xxx= ± 0.02
Millimeters: x.xx = ± 0.5
0.128 [3.25]
1.950 [49.53]
0.118 [3.00]
CN2
0]
3.2
Φ
6
1
.12
Φ0
23
CFM06SXXX-T
1
2
0.728 [18.50]
1.714 [43.53]
0.472 [12.00]
0.128 [3.25]
1.300 [33.02]
AC Input Connector(CN1):JST B3B-PH-K-S(LF)(SN) or equivalent
Pin
CN1
ACN
2
3
ACL
PHR-3
or equivalent
Terminal
SPH-002T-P0.5L
or equivalent
DC Output Connector(CN2):JST B2B-PH-K-S(LF)(SN) or equivalent
Pin
1
2
0.689 [17.50]max
0.591 [15.00]max
0.098 [2.50]max
0.118 [3.00]
Function Mating Housing
1
+Vout
PHR-2
or equivalent
-Vout
Terminal
SPH-002T-P0.5L
or equivalent
sales@cincon.com.tw
www.cincon.com
6
REVISION: V16
很抱歉,暂时无法提供与“CFM06S050”相匹配的价格&库存,您可以联系我们找货
