EC2SA-05S05N
EC2SA-05S05N
    CINCON
    SIP-7
    隔离模块 直流转换器 1 输出 5V 400mA 4.5V - 9V 输入
EC2SA-05S05N 数据手册
V19 EC2SA SERIES ︳ 2 WATT WIDE INPUT DC-DC CONVERTERS FEATURES * 2W Isolated Output * Compact SIP-8 Package * Efficiency to 84% * 2:1 Input Range * Regulated Outputs * Remote On/Off Control * 1500VDC Isolation * Continuous Short Circuit Protection * Under Voltage Protection * Safety Meets IEC/EN/UL 62368-1 MODEL NUMBER INPUT VOLTAGE OUTPUT VOLTAGE EC2SA-05S33N EC2SA-05S05N EC2SA-05S12N EC2SA-05S15N EC2SA-05D05N EC2SA-05D12N EC2SA-05D15N EC2SA-12S33N EC2SA-12S05N EC2SA-12S12N EC2SA-12S15N EC2SA-12D05N EC2SA-12D12N EC2SA-12D15N EC2SA-24S33N EC2SA-24S05N EC2SA-24S12N EC2SA-24S15N EC2SA-24D05N EC2SA-24D12N EC2SA-24D15N EC2SA-48S33N EC2SA-48S05N EC2SA-48S12N EC2SA-48S15N EC2SA-48D05N EC2SA-48D12N EC2SA-48D15N 4.5-9.0 VDC 4.5-9.0 VDC 4.5-9.0 VDC 4.5-9.0 VDC 4.5-9.0 VDC 4.5-9.0 VDC 4.5-9.0 VDC 9-18 VDC 9-18 VDC 9-18 VDC 9-18 VDC 9-18 VDC 9-18 VDC 9-18 VDC 18-36 VDC 18-36 VDC 18-36 VDC 18-36 VDC 18-36 VDC 18-36 VDC 18-36 VDC 36-75 VDC 36-75 VDC 36-75 VDC 36-75 VDC 36-75 VDC 36-75 VDC 36-75 VDC 3.3 VDC 5 VDC 12 VDC 15 VDC ±5 VDC ±12 VDC ±15 VDC 3.3 VDC 5 VDC 12 VDC 15 VDC ±5 VDC ±12 VDC ±15 VDC 3.3 VDC 5 VDC 12 VDC 15 VDC ±5 VDC ±12 VDC ±15 VDC 3.3 VDC 5 VDC 12 VDC 15 VDC ±5 VDC ±12 VDC ±15 VDC OUTPUT CURRENT MIN. 0 mA 0 mA 0 mA 0 mA ±0 mA ±0 mA ±0 mA 0 mA 0 mA 0 mA 0 mA ±0 mA ±0 mA ±0 mA 0 mA 0 mA 0 mA 0 mA ±0 mA ±0 mA ±0 mA 0 mA 0 mA 0 mA 0 mA ±0 mA ±0 mA ±0 mA MAX. 500 mA 400 mA 167 mA 134 mA ±200 mA ±83 mA ±67 mA 500 mA 400 mA 167 mA 134 mA ±200 mA ±83 mA ±67 mA 500 mA 400 mA 167 mA 134 mA ±200 mA ±83 mA ±67 mA 500 mA 400 mA 167 mA 134 mA ±200 mA ±83 mA ±67 mA NOTE: 1. Nominal Input Voltage 5, 12, 24 or 48VDC 1 INPUT CURRENT NO LOAD 60 mA 60 mA 60 mA 60 mA 60 mA 60 mA 60 mA 30 mA 30 mA 30 mA 30 mA 30 mA 30 mA 30 mA 18 mA 18 mA 18 mA 18 mA 18 mA 18 mA 18 mA 9 mA 9 mA 9 mA 9 mA 9 mA 9 mA 9 mA % CAPACITOR EFF. LOAD MAX. FULL LOAD 452 mA 73 500uF 526 mA 76 400uF 501 mA 80 167uF 503 mA 80 134uF 519 mA 77 200uF 504 mA 79 83uF 503 mA 80 67uF 181 mA 76 500uF 211 mA 79 400uF 204 mA 82 167uF 202 mA 83 134uF 211 mA 79 200uF 202 mA 82 83uF 202 mA 83 67uF 90 mA 76 500uF 105 mA 79 400uF 102 mA 82 167uF 101 mA 83 134uF 105 mA 79 200uF 102 mA 81 83uF 100 mA 84 67uF 46 mA 74 500uF 53 mA 79 400uF 51 mA 82 167uF 50 mA 84 134uF 53 mA 78 200uF 51 mA 82 83uF 50 mA 84 67uF V19 SPECIFICATIONS All Specifications Typical at Nominal Line, Full Load, and 25℃ Unless Otherwise Noted INPUT SPECIFICATIONS: GENERAL SPECIFICATIONS: Input Voltage Range ........……………....…........... 5V ........................... 4.5-9V 12V .......................... 9-18V 24V ........................ 18-36V 48V ..………........... 36-75V Input Surge Voltage (100ms max.) ………….….… 5V …............... 15Vdc max. 12V ................. 25Vdc max. 24V ................. 50Vdc max. 48V ............... 100Vdc max. Under Voltage Protection (note5): 5Vin power up …………………….....………..... 4.2Vdc max. power down …………………....……………. 3Vdc min. 12Vin power up ……….………………..……...... 7.3Vdc max. power down ………………………..………. 5.6Vdc min. 24Vin power up ………………………..……….... 15.5Vdc max. power down …………………..……………. 12Vdc min. Efficiency ..............................................................…..……... See Table Isolation Voltage ..........……………………....…..........…. 1500VDC min. Isolation Resistance .........................…........................…. 109 ohm min. Isolation Capacitance ………………..……………………..…… 500pF typ. Switching Frequency ......................….............……………... 100KHz min. Operating Ambient Temperature …………………...…... -40℃ to +85℃ De-rating, Above 85℃ …………..…… Linearly to Zero Power at 100℃ Case Temperature (note4) ………………………………….. 100℃ max. Cooling ………………………………..…….…………. Natural Convection Storage Temperature …………………..….......……........ -55℃ to +125℃ Humidity ................................................. 95% RH max. Non Condensing MTBF ……MIL-HDBK-217F, GB, 25℃, Full Load ……… 2500Khrs typ. Dimensions …………..… 0.86x0.36x0.44 Inches(21.80x9.20x11.10 mm) Case Material ……………………………… Non-Conductive Black Plastic Weight …….……………………………………….……………………... 4.8g 48Vin power up ………………………..………...... 31Vdc max. NOTE: power down ………………………..………. 24Vdc min. Input Filter ………………………………………………..….………... Capacitive Remote On/Off control (note7): Module Off (Input Idle Current) ……..……… 1mA max. OUTPUT SPECIFICATIONS: 1. For asymmetric loading both channels must be at 25% load or more. 2. Measured from high line to low line. 3. Measured from full load to 10% load. 4. Maximum case temperature under any operating condition should not be exceeded 100℃. Typical Derating curve for Natural Convection 120% 100% LOAD(%) Voltage Accuracy ............................................……….................. ±1.5% max. Voltage Balance (Dual) ……………………………….………….... ±1.0% max. Cross Regulation (Dual) (note1) ….. Asymmetrical Load 25%/100% ... ±5.0% max. Transient Response: 25% Step Load Change Error Band ……….………………….. ±6% Vout Nominal Recovery Time …………..……………….…….. < 500us Ripple & Noise, 20MHz BW ……………..….……………..... 75mV pk-pk max. Temperature Coefficient ....................…………..............…..... ±0.03%/°C max. Line Regulation (note2) .…….………………..........................…. ±0.5% max. Load Regulation (note3) ……..…....… Single …..........…............. ±0.5% max. Dual …...……………….... ±1.0% max. Output Short Circuit Protection ...............................................…. Continuous Start up Time …………………………………….………………....…... 1ms typ. 5. Suffix “N“ to the model with under voltage protection. 6. Suffix “N“ to the model is present standard and recommend, without suffix “N“ Models are not recommend for new design. 7. Suffix “N“ Models: Module on …………. 0 to < 0.8VDC or open circuit Module off ………..………..…………..4 to 15VDC Other Models: Module on …….…. 0 to < 1.2VDC or open circuit Module off………..………..……….. 5.5 to 15VDC -40 85 80% 60% Natural Convection 40% 20% 0% -40 CASE SIP-8: 100 -20 0.01 [0.3] 0.70 [17.8] Bottom View 1 2 3 5 6 7 8 0.44[11.1] 0.36[9.2] 0.10 [2.5] 0.14[3.5] 0.16 [4.1] 0.02 [0.5] 0.86 [21.8] 0.08 [2.0] PIN CONNECTION Dual Pin Single 1 -V Input -V Input 2 +V Input +V Input 3 On/Off On/Off 5 NC NC +V Output 6 +V Output 7 -V Output Common -V Output 8 NC NC: NO CONNECTION WITH PIN All Dimensions In Inches(mm) Tolerances : Inches millimeters X.XX±0.02 X.X±0.5 Pin ±0.002 ±0.05 0.02 [0.5] 2 0 20 40 60 Ambient Temperature(oC) 80 100
EC2SA-05S05N
物料型号: - EC2SA系列提供了多种型号,包括EC2SA-05S33N、EC2SA-05S05N、EC2SA-05S12N等,这些型号的输入电压范围从4.5-9.0VDC到36-75VDC不等,输出电压有3.3VDC、5VDC、12VDC、15VDC以及它们的正负电压版本。
器件简介: - 这些转换器具有2瓦的隔离输出,采用紧凑的SIP-8封装,效率高达84%。它们还具有2:1的输入范围、调节输出、远程开关控制、1500VDC隔离、连续短路保护、欠压保护,并符合IEC/EN/UL 62368-1安全标准。
引脚分配: - 引脚1和2是输入电压引脚,分别为负和正输入。 - 引脚3用于远程开关控制。 - 引脚6是正输出,引脚7是负输出或公共地,具体取决于单通道或双通道配置。 - 引脚5和8没有连接。
参数特性: - 输入电压范围从4.5-9.0VDC到36-75VDC。 - 输出电压包括正负电压选项。 - 输出电流从0 mA到500 mA不等。 - 效率从73%到84%不等。 - 具有欠压保护和输入电压范围保护。
功能详解: - 转换器在25℃时的典型工作条件为标称线电压和满载。 - 输入电压范围和电压精度是关键参数。 - 输出规格包括电压平衡、交叉调节、瞬态响应、纹波和噪声等。
应用信息: - 这些转换器适用于需要高效率和隔离保护的应用场合。
封装信息: - 封装类型为SIP-8,尺寸为0.86x0.36x0.44英寸(21.80x9.20x11.10毫米),重量为4.8克。
EC2SA-05S05N 价格&库存
很抱歉,暂时无法提供与“EC2SA-05S05N”相匹配的价格&库存,您可以联系我们找货
EC2SA-05S05N
  • 1+89.324531+11.08067
库存:86
