BMR4641002/001
BMR4641002/001
    FLEX(伟创力)
    SMD20 模块
    非隔离 PoL 模块,数字 直流转换器 1 输出 0.6 ~ 3.3V 40A 4.5V - 14V 输入
BMR4641002/001 数据手册
INTERNAL USE ONLY INTERNAL USE ONLY PRODUCT SPECIFICATION TABLE OF CONTENTS No. Prepared (Subject resp) Prepared (Subject resp) jidgjian Grace Jiang Approved (Document resp) Approved (Document resp) 1 (4) 1 (1) No. Checked Checked BMR46 series PoL Regulators jidgjian Grace Jiang Input 4.5-14 V, Input V, Output Output up up to to 50 A A // 165 W W 1/1301-BMR 464 Uen Technical BPOW 00201-00152 Uen Specification Date Rev Date 7/4/2019 7/10/2009 Rev 1/28701-BMR G PD1 © Flex © Y464 D Rev.B July 2019 Key Features • Small package 30.85 x 20.0 x 8.2 mm (1.215 x 0.787 x 0.323 in) SIP: 33.0 x 7.6 x 18.1 mm (1.30 x 0.30 x 0.713 in) • 0.6 V - 3.3 V output voltage range • High efficiency, typ. 97.2% at 5Vin, 3.3Vout half load • Configuration and Monitoring via PMBus • Dynamic Loop Compensation (DLC) & fast loop transient response • Synchonization & phase spreading • Current sharing, Voltage Tracking & Voltage margining • MTBF 14.2 Mh General Characteristics            Fully regulated For narrow board pitch applications (15 mm/0.6 in) Non-Linear Response for reduction of decoupling cap. Input under voltage shutdown Over temperature protection Output short-circuit & Output over voltage protection Remote control & Power Good Voltage setting via pin-strap or PMBus Configurable via Graphical User Interface ISO 9001/14001 certified supplier Highly automated manufacturing ensures quality Safety Approvals Design for Environment Meets requirements in high-temperature lead-free soldering processes. Contents Ordering Information General Information Safety Specification Absolute Maximum Ratings ............................................................. 2 ............................................................. 2 ............................................................. 3 ............................................................. 4 Electrical Specification 40A/ 0.6-3.3V Through hole and Surface mount version 40A/ 0.6-3.3V Single in Line version (SIP) 50A/ 0.6-3.3V DLC, Through hole and Surface mount version 50A/ 0.6-3.3V DLC, Single in Line version (SIP) 50A/ 0.6-3.3V Single in Line version (SIP) BMR4640002, BMR4641002 ................ 5 BMR4642002 ...................................... 14 BMR4640008, BMR4641008 .............. 23 BMR4642008 ...................................... 32 BMR4642012 ...................................... 41 EMC Specification ........................................................... 49 Operating Information ........................................................... 49 Thermal Consideration ........................................................... 60 Connections ........................................................... 61 Mechanical Information ........................................................... 71 Soldering Information – Surface Mounting and Hole Mounting (Laydown version)................................................... 74 Delivery Package Information (Laydown version) ........................................................... 75 Soldering Information – Hole Mounting (SIP version) ........................................................... 76 Delivery Package Information (SIP version) ........................................................... 76 Product Qualification Specification ........................................................... 77 Technical Specification BMR46 series PoL Regulators Input 4.5-14 V, Output up to 50 A / 165 W 1/28701-BMR 464 Rev.B Mean steady-state failure rate, λ 71 nFailures/h Output 0.6-3.3 V, 40 A/ 132 W 0.6-3.3 V, 50 A/ 165 W 0.6-3.3 V, 50 A/ 165 W Product number and Packaging BMR 464 n 1 n 2 n 3 n 4 /n 5 n 6 n 7 n 8 Options / n5 n1 n2 n3 n4 Mounting / ο ο Mechanical Hardware Variants ο Packaging Compatibility with RoHS requirements n6 n7 ο ο n8 The products are compatible with the relevant clauses and requirements of the RoHS directive 2011/65/EU and have a maximum concentration value of 0.1% by weight in homogeneous materials for lead, mercury, hexavalent chromium, PBB and PBDE and of 0.01% by weight in homogeneous materials for cadmium. ο Exemptions in the RoHS directive utilized in Flex products are found in the Statement of Compliance document. / / / Configuration file ο Options Description n1 0 1 2 Through hole mount version (TH) Surface mount version (SMD) Single in line (SIP) n2 0 1 Standard mechanical option Long pin option, 5.5mm pin length (for SIP) Short pin option, 3.28mm pin length (for SIP) LB pin option, 4.57mm pin length (for SIP) 3 4 12 40 A 50 A, Dynamic Loop Compensation (DLC) 50 A, No DLC (for SIP) n5 n6 n7 001 002 CTRL pin positive logic (active high) CTRL pin negative logic (active low) n8 B C Antistatic tray of 100 products (SIP only) Antistatic tape & reel of 130 products (Sample delivery avalable in lower quantities. Not for SIP) n3 n4 02 08 Std. deviation, σ 12.7 nFailures/h MTBF (mean value) for the BMR 464 series = 14.2 Mh. MTBF at 90% confidence level = 11.52 Mh / ο July 2019 © Flex Ordering Information Product program BMR464x002/001 (x=0,1,2) BMR464x008/001 (x=0,1,2) BMR464x012/001 (x=0,1,2) 2 Example: Product number BMR4640002/001C equals a through-hole mounted, open frame, PMBus and analog pin strap, positive RC logic, standard configuration variant, package tape & reel. General Information Reliability The failure rate (λ) and mean time between failures (MTBF= 1/λ) is calculated at max output power and an operating ambient temperature (T A ) of +40°C. Flex uses Telcordia SR-332 Issue 2 Method 1 to calculate the mean steady-state failure rate and standard deviation (σ). Telcordia SR-332 Issue 2 also provides techniques to estimate the upper confidence levels of failure rates based on the mean and standard deviation. Flex fulfills and will continuously fulfill all its obligations under regulation (EC) No 1907/2006 concerning the registration, evaluation, authorization and restriction of chemicals (REACH) as they enter into force and is through product materials declarations preparing for the obligations to communicate information on substances in the products. Quality Statement The products are designed and manufactured in an industrial environment where quality systems and methods like ISO 9000, Six Sigma, and SPC are intensively in use to boost the continuous improvements strategy. Infant mortality or early failures in the products are screened out and they are subjected to an ATE-based final test. Conservative design rules, design reviews and product qualifications, plus the high competence of an engaged work force, contribute to the high quality of the products. Warranty Warranty period and conditions are defined in Flex General Terms and Conditions of Sale. Limitation of Liability Flex does not make any other warranties, expressed or implied including any warranty of merchantability or fitness for a particular purpose (including, but not limited to, use in life support applications, where malfunctions of product can cause injury to a person’s health or life). © Flex 2019 The information and specifications in this technical specification is believed to be correct at the time of publication. However, no liability is accepted for inaccuracies, printing errors or for any consequences thereof. Flex reserves the right to change the contents of this technical specification at any time without prior notice. Technical Specification BMR46 series PoL Regulators Input 4.5-14 V, Output up to 50 A / 165 W Safety Specification General information Flex Power DC/DC converters and DC/DC regulators are designed in accordance with the safety standards IEC 62368-1, EN 62368-1 and UL 62368-1 Audio/video, information and communication technology equipment Part 1: Safety requirements IEC/EN/UL 62368-1 contains requirements to prevent injury or damage due to the following hazards: • • • • • • Electrical shock Electrically-caused fire Injury caused by hazardous substances Mechanically-caused injury Skin burn Radiation-caused injury On-board DC/DC converters, Power interface modules and DC/DC regulators are defined as component power supplies. As components they cannot fully comply with the provisions of any safety requirements without “conditions of acceptability”. Clearance between conductors and between conductive parts of the component power supply and conductors on the board in the final product must meet the applicable safety requirements. Certain conditions of acceptability apply for component power supplies with limited stand-off (see Mechanical Information for further information). It is the responsibility of the installer to ensure that the final product housing these components complies with the requirements of all applicable safety standards and regulations for the final product. Component power supplies for general use shall comply with the requirements in IEC/EN/UL 62368-1. Product related standards, e.g. IEEE 802.3af Power over Ethernet, and ETS-300132-2 Power interface at the input to telecom equipment, operated by direct current (dc) are based on IEC/EN/UL 60950-1 with regards to safety. Flex Power DC/DC converters, Power interface modules and DC/DC regulators are UL 62368-1 recognized and certified in accordance with EN 62368-1. The flammability rating for all construction parts of the products meet requirements for V-0 class material according to IEC 60695-11-10, Fire hazard testing, test flames – 50 W horizontal and vertical flame test methods. 1/28701-BMR 464 Rev.B 3 July 2019 © Flex Non - isolated DC/DC regulators The DC/DC regulator output is ES1 energy source if the input source meets the requirements for ES1 according to IEC/EN/UL 62368-1. Ericsson Internal PRODUCT SPECIFICATION Prepared (also subject responsible if other) EAB/FJB/GM QLAANDR Approved 1 (21) No. 2/1301-BMR 464 Uen Checked EAB/FJB/GM (Ksenia (MICRF) BMR46 series PoL Harrisen) Regulators Input 4.5-14 V, Output up to 50 A / 165 W 4 Technical Specification Reference Date Rev 2014-05-02 C1/28701-BMR 464 Rev.B July 2019 © Flex Absolute Maximum Ratings Characteristics min TP1, TP2 Operating temperature (see Thermal Consideration section) -40 125 °C TS Storage temperature -40 125 °C VI Input voltage (See Operating Information Section for input and output voltage relations) Logic I/O voltage CTRL, SA0, SA1, SALERT, SCL, SDA, VSET, SYNC, GCB, PG typ max Unit -0.3 16 V -0.3 6.5 V Ground voltage differential -S, PREF, GND -0.3 0.3 V Analog pin voltage VO, +S, VTRK -0.3 6.5 V Stress in excess of Absolute Maximum Ratings may cause pe rmanent damage. Absolute Maximum Ratings, sometimes referred to as no destruction limits, are normally tested with one parameter at a t ime exceeding the limits in the Electrical Specification. If exposed to stress above these limits, function and performance may degrade in an unspecified manner. Configuration File This product is designed with a digital control circuit. The control circuit uses a configuration file which determines the functionality and performance of the product. The Electrical Specification table shows parameter values of functionality and performance with the default configuration file, unless otherwise specified. The default configuration file is designed to fit most application needs w ith focus on hi gh efficiency. If different characteristics are required it is possible to change the configuration file to optimize certain performance characteristics. Note that current sharing operation requires changed configuration file. See application notes AN307 for further information. In this Technical specification examples are included to show the possibilities with digital control. See Operating Information section for information about trade offs when optimizing certain key performance characteristics. Fundamental Circuit Diagram CI = 140 μF, CO = 400 μF Ericsson Internal PRODUCT SPECIFICATION Prepared (also subject responsible if other) EAB/FJB/GM QLAANDR Approved 2 (21) No. 2/1301-BMR 464 Uen Checked EAB/FJB/GM (Ksenia (MICRF) BMR46 series PoL Harrisen) Regulators Input 4.5-14 V, Output up to 50 A / 165 W 5 Technical Specification Reference Date Rev 2014-05-02 C1/28701-BMR 464 Rev.B July 2019 © Flex Electrical Specification BMR 464 0002, BMR 464 1002 TP1 = -30 to +95 °C, VI = 4.5 to 14 V, VI > VO + 1.0 V Typical values given at: TP1 = +25 °C, VI = 12.0 V, max IO, unless otherwise specified under Conditions. Default configuration file, 190 10-CDA 102 0206/001. External CIN = 470 µF/10 mΩ, COUT = 470 µF/10 mΩ. See Operating Information section for selection of capacitor types. Sense pins are connected to the output pins. Characteristics VI Conditions Input voltage rise time Output voltage without pin strap Output voltage adjustment range Output voltage adjustment including margining Output voltage set-point resolution Output voltage accuracy VO Load regulation; IO = 0 - 100% VOac Output ripple & noise CO = 470 μF (minimum external capacitance). See Note 11 IO Output current IS Static input current at max IO Ilim Current limit threshold Short circuit current RMS, hiccup mode, See Note 3 50% of max IO η max Unit 2.4 V/ms 0.60 Efficiency max IO Pd Power dissipation at max IO Pli Input idling power (no load) Default configuration: Continues Conduction Mode, CCM typ 3.3 V V 0.54 3.63 V 1.2 See Note 17 ±0.025 Including line, load, temp. See Note 14 Current sharing operation See Note 15 1 % -2 2 % 4.7 2 3 3 3 2 2 2 2 15 20 25 35 VO = 0.6 V VO = 1.0 V VO = 1.8V VO = 3.3 V VO = 0.6 V VO = 1.0 V VO = 1.8V VO = 3.3 V VO = 0.6 V VO = 1.0 V VO = 1.8 V VO = 3.3 V See Note 18 VO = 0.6 V VO = 1.0 V VO = 1.8 V VO = 3.3 V % FS -1 Internal resistance +S/-S to VOUT/GND Line regulation Isc min monotonic 0.001 Ω mV mV mVp-p 40 2.45 3.80 6.49 11.58 42 A 52 VO = 0.6 V VO = 1.0 V VO = 1.8 V VO = 3.3 V 10 9 9 7 VO = 0.6 V VO = 1.0 V VO = 1.8 V VO = 3.3 V VO = 0.6 V VO = 1.0 V VO = 1.8 V VO = 3.3 V VO = 0.6 V VO = 1.0 V VO = 1.8 V VO = 3.3 V VO = 0.6 V VO = 1.0 V VO = 1.8 V VO = 3.3 V 84.6 89.7 93.3 95.3 81.8 87.7 92.4 95.0 5.37 5.60 5.92 6.98 1.10 1.10 1.40 2.20 A A A % % W W Ericsson Internal PRODUCT SPECIFICATION Prepared (also subject responsible if other) EAB/FJB/GM QLAANDR Approved 2/1301-BMR 464 Uen Checked EAB/FJB/GM (Ksenia (MICRF) BMR46 series PoL Harrisen) Regulators Input 4.5-14 V, Output up to 50 A / 165 W Characteristics PCTRL Ci Co COUT Vtr1 ttr1 fs Input standby power Internal input capacitance Internal output capacitance Total external output capacitance ESR range of capacitors (per single capacitor) Load transient peak voltage deviation (H to L) Load step 25-75-25% of max IO Default configuration di/dt = 2 A/μs CO = 470 μF (minimum external capacitance) see Note 12 Load transient recovery time, Note 5 (H to L) Load step 25-75-25% of max IO Default configuration di/dt = 2 A/μs CO = 470 μF (minimum external capacitance) see Note 12 Switching frequency Switching frequency range, see Note 19 Switching frequency set-point accuracy Control Circuit PWM Duty Cycle Minimum Sync Pulse Width Input Clock Frequency Drift Tolerance Input Under Voltage Lockout, UVLO Input Over Voltage Protection, IOVP Power Good, PG, See Note 2 Output voltage Over/Under Voltage Protection, OVP/UVP UVLO threshold UVLO threshold range Set point accuracy UVLO hysteresis UVLO hysteresis range Delay Fault response IOVP threshold IOVP threshold range Set point accuracy IOVP hysteresis IOVP hysteresis range Delay Fault response PG threshold PG hysteresis PG delay PG delay range UVP threshold UVP threshold range UVP hysteresis OVP threshold OVP threshold range UVP/OVP response time UVP/OVP response time range Fault response 6 Technical Specification Reference Date Rev 2014-05-02 C1/28701-BMR 464 Rev.B Conditions Turned off with CTRL-pin 3 (21) No. July 2019 © Flex min Default configuration: Monitoring enabled, Precise timing enabled typ max Unit mW 180 140 400 See Note 9 470 30 000 μF μF μF See Note 9 5 30 mΩ VO = 0.6 V 250 VO = 1.0 V 250 VO = 1.8 V 240 VO = 3.3 V 220 VO = 0.6 V 150 VO = 1.0 V 100 VO = 1.8 V 100 VO = 3.3 V 50 μs 320 200-640 PMBus configurable External clock source mV -5 5 150 -13 5 95 13 3.85 3.85-14 PMBus configurable -150 150 0.35 0-10.15 PMBus configurable 2.5 See Note 3 Automatic restart, 70 ms 16 4.2-16 PMBus configurable -150 PMBus configurable 150 1 0-11.8 2.5 See Note 3 PMBus configurable PMBus configurable PMBus configurable PMBus configurable See Note 3 Automatic restart, 70 ms 90 5 10 0-500 85 0-100 5 115 100-115 25 5-60 Automatic restart, 70 ms kHz kHz % % ns % V V mV V V μs V V mV V V μs % VO % VO ms s % VO % VO % VO % VO % VO μs μs Ericsson Internal PRODUCT SPECIFICATION Prepared (also subject responsible if other) EAB/FJB/GM QLAANDR Approved Checked BMR46 series(Ksenia PoL Regulators EAB/FJB/GM Harrisen) (MICRF) Input 4.5-14 V, Output up to 50 A / 165 W Characteristics Over Current Protection, OCP Over Temperature Protection, OTP at P1 See Note 8 VIL VIH IIL VOL VOH IOL IOH fSMB tset thold tfree Cp Logic input low threshold Logic input high threshold Logic input low sink current Logic output low signal level Logic output high signal level Logic output low sink current Logic output high source current SMBus Operating frequency Setup time, SMBus Hold time, SMBus Bus free time, SMBus Internal capacitance on logic pins Initialization time Delay duration Delay duration range Output Voltage Delay Time See Note 6 Output Voltage Ramp Time See Note 13 2/1301-BMR 464 Uen Technical Date Delay accuracy turn-on Delay accuracy turn-off Ramp duration Ramp duration range Ramp time accuracy VTRK Input Bias Current VTRK Tracking Ramp Accuracy (VO - VVTRK) VTRK Regulation Accuracy (VO - VVTRK) Current difference between products in a current sharing group READ_IOUT vs IO typ See Note 1 See Note 1 See Note 1 max 48 0-48 32 1-32 Automatic restart, 70 ms 120 -40…+120 15 0-160 Automatic restart, 240 ms C C C C 0.8 0.6 0.4 2.25 4 2 100 10 250 300 2 10 See Note 10 See Note 16 PMBus configurable Default configuration: CTRL controlled Precise timing enabled PMBus controlled Precise timing disabled Current sharing operation 35 10 2-500000 Current sharing operation VVTRK = 5.5 V 100% tracking, see Note 7 Current sharing operation 2 phases, 100% tracking VO = 1.0 V, 10 ms ramp 100% Tracking Current sharing operation 100% Tracking Steady state operation Ramp-up IO = 0-40 A, TP1 = 0 to +95 °C VI = 4.5-14 V, VO = 1.0 V IO = 0-40 A, TP1 = 0 to +95 °C VI = 4.5-14 V, VO = 0.6-3.3 V V V mA V V mA mA kHz ns ns ms pF ms ms ±0.25 ms -0.25/+4 ms -0.25/+4 ms 10 0-200 100 20 PMBus configurable Unit A A Tsw Tsw 2 CTRL READ_VIN vs VI READ_VOUT vs VO READ_IOUT vs IO min PMBus configurable See Note 3 SYNC, SCL, SDA, SALERT, GCB, PG July 2019 © Flex PMBus configurable SYNC, SA0, SA1, SCL, SDA, GCB, CTRL, VSET 7 Specification Reference C 1/28701-BMR 464 Rev.B PMBus configurable See Note 4 PMBus configurable See Note 3 Number of products in a current sharing group Monitoring accuracy Rev 2014-05-02 Conditions OCP threshold OCP threshold range Protection delay, Protection delay range Fault response OTP threshold OTP threshold range OTP hysteresis OTP hysteresis range Fault response 4 (21) No. 110 -100 ms µs % 200 100 ±100 µA mV mV -1 1 % -2 2 % Max 2 x READ_IOUT monitoring accuracy 4 7 A 3 1 % % ±2.5 A ±4 A Ericsson Internal PRODUCT SPECIFICATION Prepared (also subject responsible if other) EAB/FJB/GM QLAANDR Approved 5 (21) No. Checked BMR46 series(Ksenia PoL Regulators EAB/FJB/GM Harrisen) (MICRF) Input 4.5-14 V, Output up to 50 A / 165 W 2/1301-BMR 464 Uen Technical Date 2014-05-02 Rev Specification Reference C 1/28701-BMR 464 Rev.B July 2019 © Flex Note 1: See section I2C/SMBus Setup and Hold Times – Definitions. Note 2: Monitorable over PMBus Interface. Note 3: Automatic restart ~70 or 240 ms after fault if the fault is no longer present. Continuous restart attempts if the fault reappear after restart. See Operating Information and AN302 for other fault response options. Note 4: Tsw is the switching period. Note 5: Within +/-3% of VO Note 6: See section Soft-start Power Up. Note 7: Tracking functionality is designed to follow a VTRK signal with slew rate < 2.4 V/ms. For faster VTRK signals accuracy will depend on the regulator bandwidth. Note 8: See section Over Temperature Protection (OTP). Note 9: See section External Capacitors. Note 10: See section Initialization Procedure. Note 11: See graph Output Ripple vs External Capacitance and Operating information section Output Ripple and Noise. Note 12: See graph Load Transient vs. External Capacitance and Operating information section External Capacitors. Note 13: Time for reaching 100% of nominal Vout. Note 14: For Vout < 1.0 V accuracy is +/-10 mV. For further deviations see section Output Voltage Adjust using PMBus. Note 15: Accuracy here means deviation from ideal output voltage level given by configured droop and actual load. Includes line, load and temperature variations. Note 16: For current sharing the Output Voltage Delay Time must be reconfigured to minimum 15 ms, see AN307 for details. Note 17: For steady state operation above 1.05 x 3.3 V, please contact your local Flex sales representative. Note 18: A minimum load current is not required if Low Power mode is used (monitoring disabled). Note 19: Please check with your local Flex Sales representative if you intend to adjust the frequency exceeds 320 KHz ±10%. 8 Ericsson Internal PRODUCT SPECIFICATION Prepared (also subject responsible if other) 6 (21) No. EAB/FJB/GM QLAANDR 2/1301-BMR 464 Uen Approved Checked EAB/FJB/GM (Ksenia (MICRF) BMR46 series PoL Harrisen) Regulators Input 4.5-14 V, Output up to 50 A / 165 W 9 Technical Specification Reference Date Rev 2014-05-02 C1/28701-BMR 464 Rev.B July 2019 © Flex Typical Characteristics Efficiency and Power Dissipation BMR 464 0002, BMR 464 1002 Efficiency vs. Output Current, VI = 5 V Power Dissipation vs. Output Current, VI = 5 V [W] 8 [%] 100 95 6 90 0.6 V 85 0.6 V 1.0 V 1.8 V 80 75 4 1.0 V 2 1.8 V 3.3 V 0 8 16 24 32 3.3 V 0 40 [A] 0 8 16 24 32 40 [A] Efficiency vs. load current and output voltage: TP1 = +25 °C, VI=5 V, fsw = 320 kHz, CO = 470 µF/10 mΩ. Dissipated power vs. load current and output voltage: TP1 = +25 °C, VI = 5 V, fsw = 320 kHz, CO = 470 µF/10 mΩ. Efficiency vs. Output Current, VI = 12 V Power Dissipation vs. Output Current, VI = 12 V [%] [W] 100 8 95 6 90 0.6 V 85 1.8 V 80 75 4 0.6 V 1.0 V 1.0 V 2 1.8 V 3.3 V 0 8 16 24 32 3.3 V 0 40 [A] 0 8 16 24 32 Efficiency vs. load current and output voltage at TP1 = +25 °C, VI = 12 V, fsw = 320 kHz, CO = 470 µF/10 mΩ. Dissipated power vs. load current and output voltage: TP1 = +25 °C, VI = 12 V, fsw = 320 kHz, CO = 470 µF/10 mΩ. Efficiency vs. Output Current and Switching Frequency Power Dissipation vs. Output Current and Switching frequency [W] 8 [%] 95 90 200 kHz 85 320 kHz 80 480 kHz 75 640 kHz 70 40 [A] 8 16 24 32 Efficiency vs. load current and switch frequency at TP1 = +25 °C, VI = 12 V, VO = 1.0 V, CO = 470 µF/10 mΩ Default configuration except changed frequency 40 [A] 320 kHz 4 480 kHz 2 0 0 200 kHz 6 640 kHz 0 8 16 24 32 Dissipated power vs. load current and switch frequency at TP1 = +25 °C. VI = 12 V, VO = 1.0 V, CO = 470 µF/10 mΩ Default configuration except changed frequency 40 [A] Ericsson Internal PRODUCT SPECIFICATION Prepared (also subject responsible if other) 7 (21) No. EAB/FJB/GM QLAANDR 2/1301-BMR 464 Uen Approved Checked EAB/FJB/GM (Ksenia (MICRF) BMR46 series PoL Harrisen) Regulators Input 4.5-14 V, Output up to 50 A / 165 W Technical Specification Reference Date Rev 2014-05-02 C1/28701-BMR 464 Rev.B July 2019 © Flex Typical Characteristics Load Transient BMR 464 0002, BMR 464 1002 Load Transient vs. External Capacitance, VO = 1.0 V Load Transient vs. External Capacitance, VO = 3.3 V [mV] [mV] 250 250 200 Default PID/NLR 200 Default PID/NLR 150 Opt. PID, No NLR 150 Opt. PID, No NLR 100 Default PID, Opt. NLR 100 Default PID, Opt. NLR Opt. PID/NLR 50 0 0 1 2 3 10 4 0 5 [mF] Opt. PID/NLR 50 0 1 2 3 4 5 [mF] Load transient peak voltage deviation vs. external capacitance. Step-change (10-30-10 A). Parallel coupling of capacitors with 470 µF/10 mΩ, TP1 = +25 °C, VI = 12 V, VO = 1.0 V, fsw = 320 kHz, di/dt = 2 A/µs Load transient peak voltage deviation vs. external capacitance. Step-change (10-30-10 A). Parallel coupling of capacitors with 470 µF/10 mΩ, TP1 = +25 °C, VI = 12 V, VO = 3.3 V, fsw = 320 kHz, di/dt = 2 A/µs Load transient vs. Switch Frequency Output Load Transient Response, Default PID/NLR [mV] 300 Default PID/NLR 250 Opt. PID, No NLR 200 150 Default PID, Opt. NLR 100 Opt. PID/NLR 50 200 300 400 500 600 [kHz] Load transient peak voltage deviation vs. frequency. Step-change (10-30-10 A). TP1 = +25 °C, VI = 12 V, VO = 1.0 V, CO = 470 µF/10 mΩ Note: In the load transient graphs, the worst-case scenario (load step 30-10 A) has been considered. Output voltage response to load current step-change (10-30-10 A) at: TP1 = +25 °C, VI = 12 V, VO = 1.0 V di/dt = 2 A/µs, fsw = 320 kHz, CO = 470 µF/10 mΩ Top trace: output voltage (200 mV/div.). Bottom trace: load current (10 A/div.). Time scale: (0.1 ms/div.). Ericsson Internal PRODUCT SPECIFICATION Prepared (also subject responsible if other) 8 (21) No. EAB/FJB/GM QLAANDR 2/1301-BMR 464 Uen Approved Checked EAB/FJB/GM (Ksenia (MICRF) BMR46 series PoL Harrisen) Regulators Input 4.5-14 V, Output up to 50 A / 165 W Rev 2014-05-02 C1/28701-BMR 464 Rev.B July 2019 © Flex Typical Characteristics Output Current Characteristic BMR 464 0002, BMR 464 1002 Output Current Derating, VO = 0.6 V Output Current Derating, VO = 1.0 V [A] [A] 40 40 3.0 m/s 30 3.0 m/s 30 2.0 m/s 2.0 m/s 20 1.0 m/s 1.0 m/s 20 0.5 m/s 0.5 m/s 10 0 Nat. Conv. 10 0 40 60 80 100 120 [°C] Nat. Conv. 40 60 80 100 120 [°C] Available load current vs. ambient air temperature and airflow at VO = 0.6 V, VI = 12 V. See Thermal Consideration section. Available load current vs. ambient air temperature and airflow at VO = 1.0 V, VI = 12 V. See Thermal Consideration section. Output Current Derating, VO = 1.8 V Output Current Derating, VO = 3.3 V [A] [A] 40 40 3.0 m/s 30 3.0 m/s 30 2.0 m/s 20 1.0 m/s 2.0 m/s 20 1.0 m/s 0.5 m/s 10 0 Nat. Conv. 40 60 80 11 Technical Specification Reference Date 100 0.5 m/s 10 0 120 [°C] Available load current vs. ambient air temperature and airflow at VO = 1.8 V, VI = 12 V. See Thermal Consideration section. Nat. Conv. 40 60 80 100 120 [°C] Available load current vs. ambient air temperature and airflow at VO = 3.3 V, VI = 12 V. See Thermal Consideration section. Current Limit Characteristics, VO = 1.0 V Current Limit Characteristics, VO = 3.3 V [V] [V] 1,2 4,0 0,9 3,0 VI = 4.5, 5.0 V 4.5 V VI = 12, 14 V VI = 4.5, 5.0 V 0,6 5.0 V 12 V 5.0 V 12 V 14 V 0,3 0,0 4.5 V VI = 12, 14 V 2,0 14 V 1,0 40 42 44 46 48 50 [A] Output voltage vs. load current at TP1 = +25 °C, VO = 1.0 V. Note: Output enters hiccup mode at current limit. 0,0 40 42 44 46 48 50 [A] Output voltage vs. load current at TP1 = +25 °C, VO = 3.3 V. Note: Output enters hiccup mode at current limit. Ericssson Internal PRO ODUCT SPEC CIFICATION N Pre epared (also subject responsible if other) 9 (2 21) No. EA AB/FJB/GM QLAANDR 2/1301-BMR 464 4 Uen Approved Checked EA AB/FJB/GM (Ksenia risen) (MICRF F) BMR46 series PoL Har Regulators Input 4.5-14 V, Output up to 50 A / 165 W 12 Technical Specification Reference R Date Rev 2014 4-05-02 C1/28701-BMR 464 Rev.B July 2019 © Flex Ty ypical Chara acteristics Output Voltag ge BMR R 464 0002, BMR B 464 10 002 Ou utput Ripple & Noise, VO = 1.0 V Outp put Ripple & Noise, VO = 3.3 3 V Ou utput voltage ripple e at: TP1 = +25 °C, Trace: output vo oltage (10 mV/div..). VI = 12 V, CO = 470 µF/10 mΩ Time scale: (2 µs/div.). IO = 40 A 20 MHz bandwidth Outpu ut voltage ripple att: TP1 = +25 °C, T Trace: output volttage (10 mV/div.). VI = 12 V, CO = 470 µF//10 mΩ T Time scale: (2 µs//div.). 4 A IO = 40 20 MHz bandwidth Ou utput Ripple v vs. Input Volttage Outp put Ripple vs s. Frequency [mVpk-pk] [mV Vpk-pk] 40 4 100 80 30 3 0.6 V 1.0 V 20 2 1.8 V 1.0 V 1.8 V 40 3.3 V 10 1 0 0.6 V 60 3.3 V 20 5 9 7 11 0 [V] 13 3 2 200 250 300 350 400 45 50 500 550 600 [kHz] Ou utput voltage ripple e Vpk-pk at: TP1 = +25°C, CO = 470 µF F/10 mΩ, IO = 40 A. A Outpu ut voltage ripple Vpk-pk at: TP1 = +25°°C, VI = 12 V, CO = 470 µF/10 mΩ, IO = 40 4 A. Default configuration except ch hanged frequencyy. Ou utput Ripple v vs. External Capacitance C Load d regulation, VO = 1.0 V [mV] [V] 40 4 1,01 10 30 3 0.6 V 1.0 V 20 2 1.8 V 3.3 V 10 1 0 0 1 2 3 4 5 [mF] Outtput voltage ripple Vpk-pk at: TP1 = +2 25 °C, VI = 12 V, IO = 40 A. Parallel coupling of ca apacitors with 470 0 µF/10 mΩ, 1,00 05 4.5 V 5.0 V 1,00 00 12 V 14 V 0,99 95 0,99 90 0 8 16 24 32 40 0 [A] Load regulation at Vo = 1.0 V at: TP1 = +2 25 °C, CO = 470 µF F/10 mΩ Ericsson Internal PRODUCT SPECIFICATION Prepared (also subject responsible if other) No. EAB/FJB/GM QLAANDR Approved 2/1301-BMR 464 Uen Checked EAB/FJB/GM (Ksenia (MICRF) BMR46 series PoL Harrisen) Regulators Input 4.5-14 V, Output up to 50 A / 165 W Typical Characteristics Start-up and shut-down Rev 2014-05-02 C1/28701-BMR 464 Rev.B 13 July 2019 © Flex Shut-down by input source Top trace: output voltage (0.5 V/div.). Bottom trace: input voltage (5 V/div.). Time scale: (20 ms/div.). Start-up by CTRL signal Start-up by enabling CTRL signal at: TP1 = +25 °C, VI = 12 V, VO = 1.0 V CO = 470 µF/10 mΩ, IO = 40 A Technical Specification Reference Date BMR 464 0002, BMR 464 1002 Start-up by input source Start-up enabled by connecting VI at: TP1 = +25 °C, VI = 12 V, VO = 1.0 V CO = 470 µF/10 mΩ, IO = 40 A 10 (21) Shut-down enabled by disconnecting VI at: TP1 = +25 °C, VI = 12 V, VO = 1.0 V CO = 470 µF/10 mΩ, IO = 40 A Top trace: output voltage (0.5 V/div). Bottom trace: input voltage (5 V/div.). Time scale: (2 ms/div.). Shut-down by CTRL signal Top trace: output voltage (0.5 V/div.). Bottom trace: CTRL signal (5 V/div.). Time scale: (20 ms/div.). Shut-down enabled by disconnecting VI at: TP1 = +25 °C, VI = 12 V, VO = 1.0 V CO = 470 µF/10 mΩ, IO = 40 A Top trace: output voltage (0.5 V/div). Bottom trace: CTRL signal (5 V/div.). Time scale: (2 ms/div.). Ericsson Internal PRODUCT SPECIFICATION Prepared (also subject responsible if other) EAB/FJB/GM QLAANDR Approved 11 (21) No. 2/1301-BMR 464 Uen Checked EAB/FJB/GM (Ksenia (MICRF) BMR46 series PoL Harrisen) Regulators Input 4.5-14 V, Output up to 50 A / 165 W 14 Technical Specification Reference Date Rev 2014-05-02 C1/28701-BMR 464 Rev.B July 2019 © Flex Electrical Specification BMR 464 2002 (SIP) TP1 = -30 to +95 °C, VI = 4.5 to 14 V, VI > VO + 1.0 V Typical values given at: TP1 = +25 °C, VI = 12.0 V, max IO, unless otherwise specified under Conditions. Default configuration file, 190 10-CDA 102 0259/001. External CIN = 470 µF/10 mΩ, COUT = 470 µF/10 mΩ. See Operating Information section for selection of capacitor types. Sense pins are connected to the output pins. Characteristics VI Conditions Input voltage rise time Output voltage without pin strap Output voltage adjustment range Output voltage adjustment including margining Output voltage set-point resolution Output voltage accuracy VO Load regulation; IO = 0 - 100% VOac Output ripple & noise CO = 470 μF (minimum external capacitance). See Note 11 IO Output current IS Static input current at max IO Ilim Current limit threshold Short circuit current RMS, hiccup mode, See Note 3 50% of max IO η max Unit 2.4 V/ms 0.60 Efficiency max IO Pd Power dissipation at max IO Pli Input idling power (no load) Default configuration: Continues Conduction Mode, CCM typ 3.3 V V 0.54 3.63 V 1.2 See Note 17 ±0.025 Including line, load, temp. See Note 14 Current sharing operation See Note 15 -1 -2 Internal resistance +S/-S to VOUT/GND Line regulation Isc min monotonic 1 % 2 % 4.7 2 2 2 2 2 2 2 2 20 25 30 45 VO = 0.6 V VO = 1.0 V VO = 1.8V VO = 3.3 V VO = 0.6 V VO = 1.0 V VO = 1.8V VO = 3.3 V VO = 0.6 V VO = 1.0 V VO = 1.8 V VO = 3.3 V See Note 18 VO = 0.6 V VO = 1.0 V VO = 1.8 V VO = 3.3 V % FS 0.001 Ω mV mV mVp-p 40 2.46 3.81 6.51 11.61 42 A 52 VO = 0.6 V VO = 1.0 V VO = 1.8 V VO = 3.3 V 9 8 8 6 VO = 0.6 V VO = 1.0 V VO = 1.8 V VO = 3.3 V VO = 0.6 V VO = 1.0 V VO = 1.8 V VO = 3.3 V VO = 0.6 V VO = 1.0 V VO = 1.8 V VO = 3.3 V VO = 0.6 V VO = 1.0 V VO = 1.8 V VO = 3.3 V 85.8 90.5 93.7 95.5 81.4 87.5 92.1 94.7 5.48 5.70 6.12 7.32 0.90 0.90 1.10 1.70 A A A % % W W Ericsson Internal PRODUCT SPECIFICATION Prepared (also subject responsible if other) EAB/FJB/GM QLAANDR Approved 2/1301-BMR 464 Uen Checked EAB/FJB/GM (Ksenia (MICRF) BMR46 series PoL Harrisen) Regulators Input 4.5-14 V, Output up to 50 A / 165 W Characteristics PCTRL Ci Co COUT Vtr1 ttr1 fs Input standby power Internal input capacitance Internal output capacitance Total external output capacitance ESR range of capacitors (per single capacitor) Load transient peak voltage deviation (H to L) Load step 25-75-25% of max IO Default configuration di/dt = 2 A/μs CO = 470 μF (minimum external capacitance) see Note 12 Load transient recovery time, Note 5 (H to L) Load step 25-75-25% of max IO Default configuration di/dt = 2 A/μs CO = 470 μF (minimum external capacitance) see Note 12 Switching frequency Switching frequency range, see Note 19 Switching frequency set-point accuracy Control Circuit PWM Duty Cycle Minimum Sync Pulse Width Input Clock Frequency Drift Tolerance Input Under Voltage Lockout, UVLO Input Over Voltage Protection, IOVP Power Good, PG, See Note 2 Output voltage Over/Under Voltage Protection, OVP/UVP UVLO threshold UVLO threshold range Set point accuracy UVLO hysteresis UVLO hysteresis range Delay Fault response IOVP threshold IOVP threshold range Set point accuracy IOVP hysteresis IOVP hysteresis range Delay Fault response PG threshold PG hysteresis PG delay PG delay range UVP threshold UVP threshold range UVP hysteresis OVP threshold OVP threshold range UVP/OVP response time UVP/OVP response time range Fault response 15 Technical Specification Reference Date Rev 2014-05-02 C1/28701-BMR 464 Rev.B Conditions Turned off with CTRL-pin 12 (21) No. July 2019 © Flex min Default configuration: Monitoring enabled, Precise timing enabled typ max Unit mW 170 140 400 See Note 9 470 30 000 μF μF μF See Note 9 5 30 mΩ VO = 0.6 V 240 VO = 1.0 V 240 VO = 1.8 V 220 VO = 3.3 V 200 VO = 0.6 V 120 VO = 1.0 V 100 VO = 1.8 V 80 VO = 3.3 V 40 μs 320 200-640 PMBus configurable External clock source mV -5 5 150 -13 5 95 13 3.85 3.85-14 PMBus configurable -150 150 0.35 0-10.15 PMBus configurable 2.5 See Note 3 Automatic restart, 70 ms 16 4.2-16 PMBus configurable -150 PMBus configurable 150 1 0-11.8 2.5 See Note 3 PMBus configurable PMBus configurable PMBus configurable PMBus configurable See Note 3 Automatic restart, 70 ms 90 5 10 0-500 85 0-100 5 115 100-115 25 5-60 Automatic restart, 70 ms kHz kHz % % ns % V V mV V V μs V V mV V V μs % VO % VO ms s % VO % VO % VO % VO % VO μs μs Ericsson Internal PRODUCT SPECIFICATION Prepared (also subject responsible if other) EAB/FJB/GM QLAANDR Approved Checked BMR46 series PoL Harrisen) Regulators EAB/FJB/GM (Ksenia (MICRF) Input 4.5-14 V, Output up to 50 A / 165 W Characteristics Over Current Protection, OCP Over Temperature Protection, OTP at P1 See Note 8 VIL VIH IIL VOL VOH IOL IOH fSMB tset thold tfree Cp Logic input low threshold Logic input high threshold Logic input low sink current Logic output low signal level Logic output high signal level Logic output low sink current Logic output high source current SMBus Operating frequency Setup time, SMBus Hold time, SMBus Bus free time, SMBus Internal capacitance on logic pins Initialization time Delay duration Delay duration range Output Voltage Delay Time See Note 6 Output Voltage Ramp Time See Note 13 2/1301-BMR 464 Uen Technical Date Rev 2014-05-02 C Conditions OCP threshold OCP threshold range Protection delay, Protection delay range Fault response OTP threshold OTP threshold range OTP hysteresis OTP hysteresis range Fault response Delay accuracy turn-on Delay accuracy turn-off Ramp duration Ramp duration range Ramp time accuracy VTRK Input Bias Current VTRK Tracking Ramp Accuracy (VO - VVTRK) VTRK Regulation Accuracy (VO - VVTRK) Current difference between products in a current sharing group READ_IOUT vs IO typ See Note 1 See Note 1 See Note 1 max 48 0-48 32 1-32 Automatic restart, 70 ms 120 -40…+120 15 0-160 Automatic restart, 240 ms C C C C 0.8 0.6 0.4 2.25 4 2 100 10 250 300 2 10 See Note 10 See Note 16 PMBus configurable Default configuration: CTRL controlled Precise timing enabled PMBus controlled Precise timing disabled Current sharing operation 35 10 2-500000 Current sharing operation VVTRK = 5.5 V 100% tracking, see Note 7 Current sharing operation 2 phases, 100% tracking VO = 1.0 V, 10 ms ramp 100% Tracking Current sharing operation 100% Tracking Steady state operation Ramp-up IO = 0-40 A, TP1 = 0 to +95 °C VI = 4.5-14 V, VO = 1.0 V IO = 0-40 A, TP1 = 0 to +95 °C VI = 4.5-14 V, VO = 0.6-3.3 V V V mA V V mA mA kHz ns ns ms pF ms ms ±0.25 ms -0.25/+4 ms -0.25/+4 ms 10 0-200 100 20 PMBus configurable Unit A A Tsw Tsw 2 CTRL READ_VIN vs VI READ_VOUT vs VO READ_IOUT vs IO min PMBus configurable See Note 3 SYNC, SCL, SDA, SALERT, GCB, PG July 2019 © Flex PMBus configurable SYNC, SA0, SA1, SCL, SDA, GCB, CTRL, VSET 16 Specification Reference 1/28701-BMR 464 Rev.B PMBus configurable See Note 4 PMBus configurable See Note 3 Number of products in a current sharing group Monitoring accuracy 13 (21) No. 110 -100 ms µs % 200 100 ±100 µA mV mV -1 1 % -2 2 % Max 2 x READ_IOUT monitoring accuracy 4 7 A 3 1 % % ±2.5 A ±4 A Ericsson Internal PRODUCT SPECIFICATION Prepared (also subject responsible if other) No. EAB/FJB/GM QLAANDR Approved Checked BMR46 series PoL Harrisen) Regulators EAB/FJB/GM (Ksenia (MICRF) Input 4.5-14 V, Output up to 50 A / 165 W 2/1301-BMR 464 Uen Technical Date Rev 2014-05-02 C 14 (21) Specification Reference 1/28701-BMR 464 Rev.B July 2019 © Flex Note 1: See section I2C/SMBus Setup and Hold Times – Definitions. Note 2: Monitorable over PMBus Interface. Note 3: Automatic restart ~70 or 240 ms after fault if the fault is no longer present. Continuous restart attempts if the fault reappear after restart. See Operating Information and AN302 for other fault response options. Note 4: Tsw is the switching period. Note 5: Within +/-3% of VO Note 6: See section Soft-start Power Up. Note 7: Tracking functionality is designed to follow a VTRK signal with slew rate < 2.4 V/ms. For faster VTRK signals accuracy will depend on the regulator bandwidth. Note 8: See section Over Temperature Protection (OTP). Note 9: See section External Capacitors. Note 10: See section Initialization Procedure. Note 11: See graph Output Ripple vs External Capacitance and Operating information section Output Ripple and Noise. Note 12: See graph Load Transient vs. External Capacitance and Operating information section External Capacitors. Note 13: Time for reaching 100% of nominal Vout. Note 14: For Vout < 1.0 V accuracy is +/-10 mV. For further deviations see section Output Voltage Adjust using PMBus. Note 15: Accuracy here means deviation from ideal output voltage level given by configured droop and actual load. Includes line, load and temperature variations. Note 16: For current sharing the Output Voltage Delay Time must be reconfigured to minimum 15 ms, see AN307 for details. Note 17: For steady state operation above 1.05 x 3.3 V, please contact your local Flex sales representative. Note 18: A minimum load current is not required if Low Power mode is used (monitoring disabled). Note 19: Please check with your local Flex Sales representative if you intend to adjust the frequency exceeds 320 KHz ±10%. 17 Ericsson Internal PRODUCT SPECIFICATION Prepared (also subject responsible if other) 15 (21) No. EAB/FJB/GM QLAANDR 2/1301-BMR 464 Uen Approved Checked EAB/FJB/GM (Ksenia (MICRF) BMR46 series PoL Harrisen) Regulators Input 4.5-14 V, Output up to 50 A / 165 W 18 Technical Specification Reference Date Rev 2014-05-02 C1/28701-BMR 464 Rev.B July 2019 © Flex Typical Characteristics Efficiency and Power Dissipation BMR 464 2002 (SIP) Efficiency vs. Output Current, VI = 5 V Power Dissipation vs. Output Current, VI = 5 V [W] 8 [%] 100 95 6 90 0.6 V 85 0.6 V 1.0 V 1.8 V 80 75 4 1.0 V 2 1.8 V 3.3 V 0 8 16 24 32 3.3 V 0 40 [A] 0 8 16 24 32 40 [A] Efficiency vs. load current and output voltage: TP1 = +25 °C, VI = 5 V, fsw = 320 kHz, CO = 470 µF/10 mΩ. Dissipated power vs. load current and output voltage: TP1 = +25°C. VI = 5 V, fsw = 320 kHz, CO = 470 µF/10 mΩ. Efficiency vs. Output Current, VI = 12 V Power Dissipation vs. Output Current, VI = 12 V [W] 8 [%] 100 95 6 90 0.6 V 85 1.0 V 1.8 V 80 75 4 0.6 V 1.0 V 2 1.8 V 3.3 V 3.3 V 0 0 8 16 24 32 40 [A] 0 8 16 24 32 Efficiency vs. load current and output voltage at TP1 = +25 °C, VI = 12 V, fsw = 320 kHz, CO = 470 µF/10 mΩ. Dissipated power vs. load current and output voltage: TP1 = +25 °C, VI = 12 V, fsw = 320 kHz, CO = 470 µF/10 mΩ. Efficiency vs. Output Current and Switching Frequency Power Dissipation vs. Output Current and Switching frequency [%] [W] 8 95 90 200 kHz 85 320 kHz 80 480 kHz 75 640 kHz 70 40 [A] 0 8 16 24 32 Efficiency vs. load current and switch frequency at TP1 = +25 °C, VI = 12 V, VO = 1.0 V, CO = 470 µF/10 mΩ Default configuration except changed frequency 40 [A] 200 kHz 6 320 kHz 4 480 kHz 2 0 640 kHz 0 8 16 24 32 Dissipated power vs. load current and switch frequency at TP1 = +25 °C, VI = 12 V, VO = 1.0 V, CO = 470 µF/10 mΩ Default configuration except changed frequency 40 [A] Ericsson Internal PRODUCT SPECIFICATION Prepared (also subject responsible if other) EAB/FJB/GM QLAANDR 2/1301-BMR 464 Uen Approved Checked EAB/FJB/GM (Ksenia (MICRF) BMR46 series PoL Harrisen) Regulators Input 4.5-14 V, Output up to 50 A / 165 W Technical Specification Reference Date Rev 2014-05-02 C1/28701-BMR 464 Rev.B Load Transient vs. External Capacitance, VO = 3.3 V [mV] [mV] 300 300 Default PID/NLR 250 Opt. PID, No NLR 200 150 Default PID, Opt. NLR 100 Opt. PID/NLR 50 1 2 July 2019 BMR 464 2002 (SIP) Load Transient vs. External Capacitance, VO = 1.0 V 0 19 © Flex Typical Characteristics Load Transient 0 16 (21) No. 3 Opt. PID, No NLR 200 150 Default PID, Opt. NLR 100 Opt. PID/NLR 50 0 4 [mF] Default PID/NLR 250 0 1 2 3 4 [mF] Load transient peak voltage deviation vs. external capacitance. Step-change (10-30-10 A). Parallel coupling of capacitors with 470 µF/10 mΩ, TP1 = +25 °C, VI = 12 V, VO = 1.0 V, fsw = 320 kHz, di/dt = 2 A/µs Load transient peak voltage deviation vs. external capacitance. Step-change (10-30-10 A). Parallel coupling of capacitors with 470 µF/10 mΩ, TP1 = +25 °C, VI = 12 V, VO = 3.3 V, fsw = 320 kHz, di/dt = 2 A/µs Load transient vs. Switch Frequency Output Load Transient Response, Default PID/NLR [mV] 400 Default PID/NLR 350 300 Opt. PID, No NLR 250 200 Default PID, Opt. NLR 150 Opt. PID/NLR 100 50 200 300 400 500 600 [kHz] Load transient peak voltage deviation vs. frequency. Step-change (10-30-10 A). TP1 = +25 °C, VI = 12 V, VO = 1.0 V, CO = 470 µF/10 mΩ Note: In the load transient graphs, the worst-case scenario (load step 30-10 A) has been considered. Output voltage response to load current step-change (10-30-10 A) at: TP1 = +25 °C, VI = 12 V, VO = 1.0 V di/dt = 2 A/µs, fsw = 320 kHz, CO = 470 µF/10 mΩ Top trace: output voltage (200 mV/div.). Bottom trace: load current (10 A/div.). Time scale: (0.1 ms/div.). Ericsson Internal PRODUCT SPECIFICATION Prepared (also subject responsible if other) 17 (21) No. EAB/FJB/GM QLAANDR 2/1301-BMR 464 Uen Approved Checked EAB/FJB/GM (Ksenia (MICRF) BMR46 series PoL Harrisen) Regulators Input 4.5-14 V, Output up to 50 A / 165 W Rev 2014-05-02 C1/28701-BMR 464 Rev.B July 2019 © Flex Typical Characteristics Output Current Characteristic BMR 464 2002 (SIP) Output Current Derating, VO = 0.6 V Output Current Derating, VO = 1.0 V [A] [A] 40 40 3.0 m/s 30 3.0 m/s 30 2.0 m/s 2.0 m/s 1.0 m/s 20 1.0 m/s 20 0.5 m/s 0.5 m/s 10 0 Nat. Conv. 40 60 80 100 120 10 0 [°C] Nat. Conv. 40 60 80 100 120 [°C] Available load current vs. ambient air temperature and airflow at VO = 0.6 V, VI = 12 V. See Thermal Consideration section. Available load current vs. ambient air temperature and airflow at VO = 1.0 V, VI = 12 V. See Thermal Consideration section. Output Current Derating, VO = 1.8 V Output Current Derating, VO = 3.3 V [A] [A] 40 40 3.0 m/s 30 3.0 m/s 30 2.0 m/s 1.0 m/s 20 2.0 m/s 20 1.0 m/s 0.5 m/s 10 0 Nat. Conv. 40 60 80 20 Technical Specification Reference Date 100 120 0.5 m/s 10 0 [°C] Available load current vs. ambient air temperature and airflow at VO = 1.8 V, VI = 12 V. See Thermal Consideration section. Nat. Conv. 40 60 80 100 120 [°C] Available load current vs. ambient air temperature and airflow at VO = 3.3 V, VI = 12 V. See Thermal Consideration section. Current Limit Characteristics, VO = 1.0 V Current Limit Characteristics, VO = 3.3 V [V] [V] 1,2 4,0 0,9 3,0 VI = 4.5, 5.0 V 4.5 V VI = 12, 14 V VI = 4.5, 5.0 V 0,6 5.0 V 12 V 14 V 0,3 0,0 40 42 44 46 48 50 [A] Output voltage vs. load current at TP1 = +25 °C, VO = 1.0 V. Note: Output enters hiccup mode at current limit. 4.5 V VI = 12, 14 V 2,0 5.0 V 12 V 14 V 1,0 0,0 40 42 44 46 48 50 [A] Output voltage vs. load current at TP1 = +25 °C, VO = 3.3 V. Note: Output enters hiccup mode at current limit. Ericsson Internal PRODUCT SPECIFICATION Prepared (also subject responsible if other) 18 (21) No. EAB/FJB/GM QLAANDR 2/1301-BMR 464 Uen Approved Checked EAB/FJB/GM (Ksenia (MICRF) BMR46 series PoL Harrisen) Regulators Input 4.5-14 V, Output up to 50 A / 165 W 21 Technical Specification Reference Date Rev 2014-05-02 C1/28701-BMR 464 Rev.B July 2019 © Flex Typical Characteristics Output Voltage BMR 464 2002 (SIP) Output Ripple & Noise, VO = 1.0 V Output Ripple & Noise, VO = 3.3 V Output voltage ripple at: TP1 = +25 °C, Trace: output voltage (10 mV/div.). Time scale: (2 µs/div.). VI = 12 V, CO = 470 µF/10 mΩ IO = 40 A 20 MHz bandwidth Output voltage ripple at: TP1 = +25 °C, Trace: output voltage (10 mV/div.). Time scale: (2 µs/div.). VI = 12 V, CO = 470 µF/10 mΩ IO = 40 A 20 MHz bandwidth Output Ripple vs. Input Voltage Output Ripple vs. Frequency [mVpk-pk] [mVpk-pk] 50 100 40 80 0.6 V 30 1.0 V 1.8 V 20 0.6 V 60 1.0 V 1.8 V 40 3.3 V 0 3.3 V 20 10 5 7 9 11 0 [V] 13 200 250 300 350 400 450 500 550 600 [kHz] Output voltage ripple Vpk-pk at: TP1 = +25 °C, CO = 470 µF/10 mΩ, IO = 40 A. Output voltage ripple Vpk-pk at: TP1 = +25 °C, VI = 12 V, CO = 470 µF/10 mΩ, IO = 40 A. Default configuration except changed frequency. Output Ripple vs. External Capacitance Load regulation, VO=1.0V [mV] [V] 50 1,010 40 0.6V 30 1.0 V 1.8 V 20 3.3 V 10 0 0 1 2 3 4 [mF] Output voltage ripple Vpk-pk at: TP1 = +25 °C, VI = 12 V, IO = 40 A. Parallel coupling of capacitors with 470 µF/10 mΩ 1,005 4.5V 5V 1,000 12 V 14 V 0,995 0,990 0 8 16 24 32 40 [A] Load regulation at Vo = 1.0 V at: TP1 = +25 °C, CO = 470 µF/10 mΩ Ericsson Internal PRODUCT SPECIFICATION Prepared (also subject responsible if other) EAB/FJB/GM QLAANDR Approved 2/1301-BMR 464 Uen Checked EAB/FJB/GM (Ksenia (MICRF) BMR46 series PoL Harrisen) Regulators Input 4.5-14 V, Output up to 50 A / 165 W Technical Specification Reference Date Rev 2014-05-02 C1/28701-BMR 464 Rev.B July 2019 BMR 464 2002 (SIP) Start-up by input source Shut-down by input source Top trace: output voltage (0.5 V/div.). Bottom trace: input voltage (5 V/div.). Time scale: (20 ms/div.). Start-up by CTRL signal Start-up by enabling CTRL signal at: TP1 = +25 °C, VI = 12 V, VO = 1.0 V CO = 470 µF/10 mΩ, IO = 40 A 22 © Flex Typical Characteristics Start-up and shut-down Start-up enabled by connecting VI at: TP1 = +25 °C, VI = 12 V, VO = 1.0 V CO = 470 µF/10 mΩ, IO = 40 A 19 (21) No. Shut-down enabled by disconnecting VI at: TP1 = +25 °C, VI = 12 V, VO = 1.0 V CO = 470 µF/10 mΩ, IO = 40 A Top trace: output voltage (0.5 V/div). Bottom trace: input voltage (5 V/div.). Time scale: (2 ms/div.). Shut-down by CTRL signal Top trace: output voltage (0.5 V/div.). Bottom trace: CTRL signal (5 V/div.). Time scale: (20 ms/div.). Shut-down enabled by disconnecting VI at: TP1 = +25 °C, VI = 12 V, VO = 1.0 V CO = 470 µF/10 mΩ, IO = 40 A Top trace: output voltage (0.5 V/div). Bottom trace: CTRL signal (5 V/div.). Time scale: (2 ms/div.). Ericsson Internal PRODUCT SPECIFICATION Prepared (also subject responsible if other) 2 (20) No. EHOSMIR 2/1301-BMR 464 0008 Uen Approved Checked EAB/FJB/GM (Ksenia (EKRIROB) BMR46 series PoL Harrisen) Regulators Input 4.5-14 V, Output up to 50 A / 165 W 23 Technical Specification Reference Date Rev 2014-05-02 C1/28701-BMR 464 Rev.B July 2019 © Flex Electrical Specification BMR 464 0008, BMR 464 1008 TP1 = -30 to +95 °C, VI = 4.5 to 14 V, VI > VO + 1.0 V Typical values given at: TP1 = +25 °C, VI = 12.0 V, max IO, unless otherwise specified under Conditions. Default configuration file, 190 10-CDA 102 0498/001. External CIN = 470 µF/10 mΩ, COUT = 470 µF/10 mΩ. See Operating Information section for selection of capacitor types. Sense pins are connected to the output pins. Characteristics VI Conditions Input voltage rise time Output voltage without pin strap Output voltage adjustment range Output voltage adjustment including margining Output voltage set-point resolution Output voltage accuracy VO Load regulation; IO = 0 - 100% VOac Output ripple & noise CO = 470 μF (minimum external capacitance). See Note 11 IO Output current IS Static input current at max IO Ilim Current limit threshold Short circuit current RMS, hiccup mode, See Note 3 50% of max IO η max Unit 2.4 V/ms 0.60 Efficiency max IO Pd Power dissipation at max IO Pli Input idling power (no load) Default configuration: Continues Conduction Mode, CCM typ 3.3 V V 0.54 3.63 V 1.2 See Note 17 ±0.025 Including line, load, temp. See Note 14 Current sharing operation See Note 15 1 % -2 2 % 47 2 2 2 3 2 2 2 2 20 25 30 35 VO = 0.6 V VO = 1.0 V VO = 1.8 V VO = 3.3 V VO = 0.6 V VO = 1.0 V VO = 1.8 V VO = 3.3 V VO = 0.6 V VO = 1.0 V VO = 1.8 V VO = 3.3 V See Note 18 VO = 0.6 V VO = 1.0 V VO = 1.8 V VO = 3.3 V % FS -1 Internal resistance +S/-S to VOUT/GND Line regulation Isc min monotonic 0.001 Ω mV mV mVp-p 50 3.10 4.80 8.19 14.53 52 A 65 VO = 0.6 V VO = 1.0 V VO = 1.8 V VO = 3.3 V 11 9 7 6 VO = 0.6 V VO = 1.0 V VO = 1.8 V VO = 3.3 V VO = 0.6 V VO = 1.0 V VO = 1.8 V VO = 3.3 V VO = 0.6 V VO = 1.0 V VO = 1.8 V VO = 3.3 V VO = 0.6 V VO = 1.0 V VO = 1.8 V VO = 3.3 V 85.6 90.4 93.7 95.7 80.5 86.9 91.6 94.6 7.25 7.54 8.28 9.36 0.90 0.90 1.10 1.67 A A A % % W W Ericsson Internal PRODUCT SPECIFICATION Prepared (also subject responsible if other) EHOSMIR 2/1301-BMR 464 0008 Uen Approved Checked EAB/FJB/GM (Ksenia (EKRIROB) BMR46 series PoL Harrisen) Regulators Input 4.5-14 V, Output up to 50 A / 165 W Characteristics PCTRL Ci Co COUT Vtr1 ttr1 fs Input standby power Turned off with CTRL-pin Load transient peak voltage deviation (L to H/H to L) Load step 25-75-25% of max IO Default configuration di/dt = 2 A/μs CO = 470 μF (minimum external capacitance) see Note 12 Load transient recovery time, Note 5 (L to H/H to L) Load step 25-75-25% of max IO Default configuration di/dt = 2 A/μs CO = 470 μF (minimum external capacitance) see Note 12 Switching frequency Switching frequency range, see Note 20 Switching frequency set-point accuracy Control Circuit PWM Duty Cycle Minimum Sync Pulse Width Input Clock Frequency Drift Tolerance Input Over Voltage Protection, IOVP Power Good, PG, See Note 2 Output voltage Over/Under Voltage Protection, OVP/UVP UVLO threshold UVLO threshold range Set point accuracy UVLO hysteresis UVLO hysteresis range Delay Fault response IOVP threshold IOVP threshold range Set point accuracy IOVP hysteresis IOVP hysteresis range Delay Fault response PG threshold PG hysteresis PG delay PG delay range UVP threshold UVP threshold range UVP hysteresis OVP threshold OVP threshold range UVP/OVP response time UVP/OVP response time range Fault response 24 Technical Specification Reference Date Rev 2014-05-02 C1/28701-BMR 464 Rev.B Conditions Internal input capacitance Internal output capacitance Total external output capacitance ESR range of capacitors (per single capacitor) Input Under Voltage Lockout, UVLO 3 (20) No. July 2019 © Flex min Default configuration: Monitoring enabled, Precise timing enabled typ max Unit mW 170 140 400 See Note 9 470 30 000 μF μF μF See Note 9 5 30 mΩ VO = 0.6 V 79 / 256 VO = 1.0 V 127 / 298 VO = 1.8 V 144 / 324 VO = 3.3 V 210 / 327 VO = 0.6 V 60 / 100 VO = 1.0 V 100 / 100 VO = 1.8 V 100 / 100 VO = 3.3 V 100 / 100 -5 5 150 -13 5 95 13 3.85 3.85-14 PMBus configurable -150 150 0.35 0-10.15 2.5 Automatic restart, 70 ms 16 4.2-16 PMBus configurable See Note 3 PMBus configurable -150 PMBus configurable See Note 3 See Note 19 PMBus configurable PMBus configurable PMBus configurable PMBus configurable See Note 3 μs 320 200-640 PMBus configurable External clock source mV 150 1 0-11.8 2.5 Automatic restart, 70 ms 90 5 Direct after DLC 0-500 85 0-100 5 115 100-115 25 5-60 Automatic restart, 70 ms kHz kHz % % ns % V V mV V V μs V V mV V V μs % VO % VO s % VO % VO % VO % VO % VO μs μs Ericsson Internal PRODUCT SPECIFICATION Prepared (also subject responsible if other) EHOSMIR Approved Checked BMR46 series(Ksenia PoL Regulators EAB/FJB/GM Harrisen) (EKRIROB) Input 4.5-14 V, Output up to 50 A / 165 W Characteristics Over Current Protection, OCP Over Temperature Protection, OTP at P2 See Note 8 VIL VIH IIL VOL VOH IOL IOH fSMB tset thold tfree Cp Logic input low threshold Logic input high threshold Logic input low sink current Logic output low signal level Logic output high signal level Logic output low sink current Logic output high source current SMBus Operating frequency Setup time, SMBus Hold time, SMBus Bus free time, SMBus Internal capacitance on logic pins Initialization time Output Voltage Delay Time See Note 6 Output Voltage Ramp Time See Note 13 2/1301-BMR 464 0008 Uen Technical Date Delay duration Delay duration range Delay accuracy turn-on Delay accuracy turn-off Ramp duration Ramp duration range Ramp time accuracy VTRK Input Bias Current VTRK Tracking Ramp Accuracy (VO - VVTRK) VTRK Regulation Accuracy (VO - VVTRK) Current difference between products in a current sharing group READ_IOUT vs IO typ See Note 1 See Note 1 See Note 1 max 62 0-62 32 1-32 Automatic restart, 70 ms 120 -40…+125 25 0-165 Automatic restart, 240 ms C C C C 0.8 0.6 0.4 2.25 4 2 100 10 250 300 2 10 See Note 10 See Note 16 PMBus configurable 40 10 5-500000 Current sharing operation VVTRK = 5.5 V 100% tracking, see Note 7 Current sharing operation 2 phases, 100% tracking VO = 1.0 V, 10 ms ramp 100% Tracking Current sharing operation 100% Tracking Steady state operation Ramp-up IO = 0-50 A, TP1 = 0 to +95 °C VI = 4.5-14 V, VO = 1.0 V IO = 0-50 A, TP1 = 0 to +95 °C VI = 4.5-14 V, VO = 0.6-3.3 V V V mA V V mA mA kHz ns ns ms pF ms ms -0.25/+4 ms -0.25/+4 ms 10 0-200 100 20 PMBus configurable Unit A A Tsw Tsw 2 CTRL READ_VIN vs VI READ_VOUT vs VO READ_IOUT vs IO min PMBus configurable See Note 3 SYNC, SCL, SDA, SALERT, GCB, PG July 2019 © Flex PMBus configurable SYNC, SA0, SA1, SCL, SDA, GCB, CTRL, VSET 25 Specification Reference C 1/28701-BMR 464 Rev.B PMBus configurable See Note 4 PMBus configurable See Note 3 Number of products in a current sharing group Monitoring accuracy Rev 2014-05-02 Conditions OCP threshold OCP threshold range Protection delay, Protection delay range Fault response OTP threshold OTP threshold range OTP hysteresis OTP hysteresis range Fault response 4 (20) No. 110 -100 ms µs % 200 100 ±100 µA mV mV -1 1 % -2 2 % Max 2 x READ_IOUT monitoring accuracy 4 7 A 3 1 % % ±3.0 A ±5.0 A Ericsson Internal PRODUCT SPECIFICATION Prepared (also subject responsible if other) EHOSMIR Approved 5 (20) No. Checked BMR46 series(Ksenia PoL Regulators EAB/FJB/GM Harrisen) (EKRIROB) Input 4.5-14 V, Output up to 50 A / 165 W 2/1301-BMR 464 0008 Uen Technical Date 2014-05-02 Rev Specification Reference C 1/28701-BMR 464 Rev.B July 2019 © Flex Note 1: See section I2C/SMBus Setup and Hold Times – Definitions. Note 2: Monitorable over PMBus Interface. Note 3: Automatic restart ~70 or 240 ms after fault if the fault is no longer present. Continuous restart attempts if the fault reappear after restart. See Operating Information and AN302 for other fault response options. Note 4: Tsw is the switching period. Note 5: Within +/-3% of VO Note 6: See section Soft-start Power Up. Note 7: Tracking functionality is designed to follow a VTRK signal with slew rate < 2.4 V/ms. For faster VTRK signals accuracy will depend on the regulator bandwidth. Note 8: See section Over Temperature Protection (OTP). Note 9: See section External Capacitors. Note 10: See section Initialization Procedure. Note 11: See graph Output Ripple vs External Capacitance and Operating information section Output Ripple and Noise. Note 12: See graph Load Transient vs. External Capacitance and Operating information section External Capacitors. Note 13: Time for reaching 100% of nominal Vout. Note 14: For Vout < 1.0 V accuracy is +/-10 mV. For further deviations see section Output Voltage Adjust using PMBus. Note 15: Accuracy here means deviation from ideal output voltage level given by configured droop and actual load. Includes line, load and temperature variations. Note 16: For current sharing the Output Voltage Delay Time must be reconfigured to minimum 15 ms, see AN307 for details. Note 17: For steady state operation above 1.05 x 3.3 V, please contact your local Flex sales representative. Note 18: A minimum load current is not required if Low Power mode is used (monitoring disabled). Note 19: See sections Dynamic Loop Compensation and Power Good. Note 20: Please check with your local Flex Sales representative if you intend to adjust the frequency exceeds 320 KHz ±10%. 26 Ericsson Internal PRODUCT SPECIFICATION Prepared (also subject responsible if other) EHOSMIR 2/1301-BMR 464 0008 Uen Approved Checked EAB/FJB/GM (Ksenia (EKRIROB) BMR46 series PoL Harrisen) Regulators Input 4.5-14 V, Output up to 50 A / 165 W Rev 2014-05-02 C1/28701-BMR 464 Rev.B July 2019 © Flex BMR 464 0008, BMR 464 1008 Efficiency vs. Output Current, VI = 5 V Power Dissipation vs. Output Current, VI = 5 V [%] [W] 100 12 95 10 8 90 0.6 V 1.0 V 85 80 0 10 20 30 40 0.6 V 6 1.0 V 1.8 V 4 1.8 V 3.3 V 2 3.3 V 0 50 [A] 0 10 20 30 40 50 [A] Efficiency vs. load current and output voltage: TP1 = +25 °C, VI = 5 V, fsw = 320 kHz, CO = 470 µF/10 mΩ. Dissipated power vs. load current and output voltage: TP1 = +25 °C, VI = 5 V, fsw = 320 kHz, CO = 470 µF/10 mΩ. Efficiency vs. Output Current, VI = 12 V Power Dissipation vs. Output Current, VI = 12 V [%] [W] 100 12 10 95 8 90 0.6 V 1.0 V 85 80 75 27 Technical Specification Reference Date Typical Characteristics Efficiency and Power Dissipation 75 6 (20) No. 0 10 20 30 40 0.6 V 6 1.0 V 1.8 V 4 1.8 V 3.3 V 2 3.3 V 0 50 [A] 0 10 20 30 40 50 [A] Efficiency vs. load current and output voltage at TP1 = +25 °C, VI = 12 V, fsw = 320 kHz, CO = 470 µF/10 mΩ. Dissipated power vs. load current and output voltage: TP1 = +25 °C, VI = 12 V, fsw = 320 kHz, CO = 470 µF/10 mΩ. Efficiency vs. Output Current and Switching Frequency Power Dissipation vs. Output Current and Switching frequency [%] [W] 95 12 90 200 kHz 85 10 200 kHz 8 320 kHz 6 320 kHz 80 480 kHz 4 480 kHz 75 640 kHz 2 640 kHz 70 0 10 20 30 40 Efficiency vs. load current and switch frequency at TP1 = +25 °C, VI = 12 V, VO = 1.0 V, CO = 470 µF/10 mΩ. Default configuration except changed frequency 50 [A] 0 0 10 20 30 40 50 [A] Dissipated power vs. load current and switch frequency at TP1 = +25 °C, VI = 12 V, VO = 1.0 V, CO = 470 µF/10 mΩ. Default configuration except changed frequency Ericsson Internal PRODUCT SPECIFICATION Prepared (also subject responsible if other) 7 (20) No. EHOSMIR 2/1301-BMR 464 0008 Uen Approved Checked EAB/FJB/GM (Ksenia (EKRIROB) BMR46 series PoL Harrisen) Regulators Input 4.5-14 V, Output up to 50 A / 165 W Technical Specification Reference Date Rev 2014-05-02 C1/28701-BMR 464 Rev.B July 2019 © Flex Typical Characteristics Load Transient BMR 464 0008, BMR 464 1008 Load Transient vs. External Capacitance, VO = 1.0 V [mV] 500 Universal PID, No NLR Load Transient vs. External Capacitance, VO = 3.3 V [mV] 500 Universal PID, No NLR DLC, No NLR 400 300 Universal PID, Default NLR 300 Universal PID, Default NLR 200 DLC, Default NLR 200 DLC, Default NLR 100 Universal PID, Opt. NLR 100 Universal PID, Opt. NLR 400 DLC, Opt. NLR 0 0 1 2 3 4 5 [mF] 0 DLC, No NLR DLC, Opt. NLR 0 1 2 3 4 5 [mF] Load transient peak voltage deviation vs. external capacitance. Step (12.5-37.5-12.5 A). Parallel coupling of capacitors with 470 µF/10 mΩ, TP1 = +25 °C, VI = 12 V, VO = 1.0 V, fsw = 320 kHz, di/dt = 2 A/µs Load transient peak voltage deviation vs. external capacitance. Step (12.5-37.5-12.5 A). Parallel coupling of capacitors with 470 µF/10 mΩ, TP1 = +25 °C, VI = 12 V, VO = 3.3 V, fsw = 320 kHz, di/dt = 2 A/µs Load transient vs. Switch Frequency Output Load Transient Response, Default Configuration [mV] 600 Universal PID, No NLR 500 DLC, No NLR 400 Universal PID, Default NLR 300 DLC, Default NLR 200 Universal PID, Opt. NLR 100 0 DLC, Opt. NLR 200 300 400 28 500 600 [kHz] Load transient peak voltage deviation vs. frequency. Step-change (12.5-37.5-12.5 A). TP1 = +25 °C. VI = 12 V, VO = 1.0 V, CO = 470 µF/10 mΩ Note 1: For Universal PID, see section Dynamic Loop Compensation (DLC). Note 2: In the load transient graphs, the worst-case scenario (load step 37.5-12.5 A) has been considered. Output voltage response to load current Step-change (12.5-37.5-12.5 A) at: TP1 = +25 °C, VI = 12 V, VO = 1.0 V di/dt = 2 A/µs, fsw = 320 kHz CO = 470 µF/10 mΩ Top trace: output voltage (200 mV/div.). Bottom trace: load current (10 A/div.). Time scale: (0.1 ms/div.). Ericsson Internal PRODUCT SPECIFICATION Prepared (also subject responsible if other) 8 (20) No. EHOSMIR 2/1301-BMR 464 0008 Uen Approved Checked EAB/FJB/GM (Ksenia (EKRIROB) BMR46 series PoL Harrisen) Regulators Input 4.5-14 V, Output up to 50 A / 165 W 29 Technical Specification Reference Date Rev 2014-05-02 C1/28701-BMR 464 Rev.B July 2019 © Flex Typical Characteristics Output Current Characteristic BMR 464 0008, BMR 464 1008 Output Current Derating, VO = 0.6 V Output Current Derating, VO = 1.0 V [A] [A] 50 50 3.0 m/s 40 2.0 m/s 3.0 m/s 40 2.0 m/s 30 1.0 m/s 30 1.0 m/s 20 0.5 m/s 20 0.5 m/s Nat. Conv. 10 0 20 40 60 80 100 0 120 [°C] Nat. Conv. 10 20 40 60 80 100 120 [°C] Available load current vs. ambient air temperature and airflow at VO = 0.6 V, VI = 12 V. See Thermal Consideration section. Available load current vs. ambient air temperature and airflow at VO = 1.0 V, VI = 12 V. See Thermal Consideration section. Output Current Derating, VO = 1.8 V Output Current Derating, VO = 3.3 V [A] [A] 50 50 3.0 m/s 3.0 m/s 40 2.0 m/s 40 30 1.0 m/s 30 20 0.5 m/s 20 Nat. Conv. 10 10 0 0 20 40 60 80 100 120 [°C] Available load current vs. ambient air temperature and airflow at VO = 1.8 V, VI = 12 V. See Thermal Consideration section. 2.0 m/s Nat. Conv. 20 40 60 80 100 120 [°C] Current Limit Characteristics, VO = 3.3 V [V] [V] 1,2 4,0 VI = 4.5, 5 .0V VI = 5.0, 12 V 0,9 3,0 4.5 V 4.5 V 5.0 V 0,6 14 V 0,3 55 60 65 [A] Output voltage vs. load current at TP1 = +25 °C, VO = 1.0 V. Note: Output enters hiccup mode at current limit. 5.0 V 2,0 12 V VI = 4.5,14 V 50 0.5 m/s Available load current vs. ambient air temperature and airflow at VO = 3.3 V, VI = 12 V. See Thermal Consideration section. Current Limit Characteristics, VO = 1.0 V 0,0 1.0 m/s 12 V VI = 12, 14 V 14 V 1,0 0,0 50 55 60 65 [A] Output voltage vs. load current at TP1 = +25 °C, VO = 3.3 V. Note: Output enters hiccup mode at current limit. Ericsson Internal PRODUCT SPECIFICATION Prepared (also subject responsible if other) 9 (20) No. EHOSMIR 2/1301-BMR 464 0008 Uen Approved Checked EAB/FJB/GM (Ksenia (EKRIROB) BMR46 series PoL Harrisen) Regulators Input 4.5-14 V, Output up to 50 A / 165 W 30 Technical Specification Reference Date Rev 2014-05-02 C1/28701-BMR 464 Rev.B July 2019 © Flex Typical Characteristics Output Voltage BMR 464 0008, BMR 464 1008 Output Ripple & Noise, VO = 1.0 V Output Ripple & Noise, VO = 3.3 V Output voltage ripple at: TP1 = +25 °C, Trace: output voltage (10 mV/div.). Time scale: (2 µs/div.). VI = 12 V, CO = 470 µF/10 mΩ IO = 50 A 20 MHz bandwidth Output voltage ripple at: TP1 = +25 °C, Trace: output voltage (10 mV/div.). Time scale: (2 µs/div.). VI = 12 V, CO = 470 µF/10 mΩ IO = 50 A 20 MHz bandwidth Output Ripple vs. Input Voltage Output Ripple vs. Frequency [mVpk-pk] [mVpk-pk] 40 70 60 30 50 0.6 V 1.0 V 40 1.0 V 1.8 V 30 3.3 V 20 0.6 V 20 10 1.8 V 3.3 V 10 0 5 7 9 11 0 [V] 13 200 300 400 500 600 [kHz] Output voltage ripple Vpk-pk at: TP1 = +25 °C, CO = 470 µF/10 mΩ, IO = 50 A Output voltage ripple Vpk-pk at: TP1 = +25 °C, VI = 12 V, CO = 470 µF/10 mΩ, IO = 50 A. Default configuration except changed frequency. Output Ripple vs. External Capacitance Load regulation, VO = 1.0 V [mV] [V] 40 1,010 30 0.6 V 1.0 V 20 1.8 V 3.3 V 10 0 0 1 2 3 4 5 [mF] Output voltage ripple Vpk-pk at: TP1 = +25 °C, VI = 12 V. IO = 50 A. Parallel coupling of capacitors with 470 µF/10 mΩ 1,005 4.5 V 5.0 V 1,000 12 V 14 V 0,995 0,990 0 5 10 15 20 25 [A] Load regulation at VO = 1.0 V, TP1 = +25 °C, CO = 470 µF/10 mΩ Ericsson Internal PRODUCT SPECIFICATION Prepared (also subject responsible if other) No. EHOSMIR Approved 2/1301-BMR 464 0008 Uen Checked EAB/FJB/GM (Ksenia (EKRIROB) BMR46 series PoL Harrisen) Regulators Input 4.5-14 V, Output up to 50 A / 165 W Typical Characteristics Start-up and shut-down Rev 2014-05-02 C1/28701-BMR 464 Rev.B 31 July 2019 © Flex Shut-down by input source Top trace: output voltage (0.5 V/div.). Bottom trace: input voltage (5 V/div.). Time scale: (20 ms/div.). Start-up by CTRL signal Start-up by enabling CTRL signal at: TP1 = +25 °C, VI = 12 V, VO = 1.0 V CO = 470 µF/10 mΩ, IO = 50 A Technical Specification Reference Date BMR 464 0008, BMR 464 1008 Start-up by input source Start-up enabled by connecting VI at: TP1 = +25 °C, VI = 12 V, VO = 1.0 V CO = 470 µF/10 mΩ, IO = 50 A 10 (20) Shut-down enabled by disconnecting VI at: TP1 = +25 °C, VI = 12 V, VO = 1.0 V CO = 470 µF/10 mΩ, IO = 50 A Top trace: output voltage (0.5 V/div.). Bottom trace: input voltage (5 V/div.). Time scale: (2 ms/div.). Shut-down by CTRL signal Top trace: output voltage (0.5 V/div.). Bottom trace: CTRL signal (2 V/div.). Time scale: (20 ms/div.). Shut-down enabled by disconnecting VI at: TP1 = +25 °C, VI = 12 V, VO = 1.0 V CO = 470 µF/10 mΩ, IO = 50 A Top trace: output voltage (0.5 V/div). Bottom trace: CTRL signal (2 V/div.). Time scale: (2 ms/div.). Ericsson Internal PRODUCT SPECIFICATION Prepared (also subject responsible if other) 11 (20) No. EHOSMIR 2/1301-BMR 464 0008 Uen Approved Checked EAB/FJB/GM (Ksenia (EKRIROB) BMR46 series PoL Harrisen) Regulators Input 4.5-14 V, Output up to 50 A / 165 W 32 Technical Specification Reference Date Rev 2014-05-02 C1/28701-BMR 464 Rev.B July 2019 © Flex Electrical Specification BMR 464 2008 (SIP) TP1 = -30 to +95 °C, VI = 4.5 to 14 V, VI > VO + 1.0 V Typical values given at: TP1 = +25 °C, VI = 12.0 V, max IO, unless otherwise specified under Conditions. Default configuration file, 190 10-CDA 102 0499/001. External CIN = 470 µF/10 mΩ, COUT = 470 µF/10 mΩ. See Operating Information section for selection of capacitor types. Sense pins are connected to the output pins. Characteristics VI Conditions Input voltage rise time Output voltage without pin strap Output voltage adjustment range Output voltage adjustment including margining Output voltage set-point resolution Output voltage accuracy VO Load regulation; IO = 0 - 100% VOac Output ripple & noise CO = 470 μF (minimum external capacitance). See Note 11 IO Output current IS Static input current at max IO Ilim Current limit threshold Short circuit current RMS, hiccup mode, See Note 3 50% of max IO η max Unit 2.4 V/ms 0.60 Efficiency max IO Pd Power dissipation at max IO Pli Input idling power (no load) Default configuration: Continues Conduction Mode, CCM typ 3.3 V V 0.54 3.63 V 1.2 See Note 17 ±0.025 Including line, load, temp. See Note 14 Current sharing operation See Note 15 -1 -2 Internal resistance +S/-S to VOUT/GND Line regulation Isc min monotonic 1 % 2 % 47 2 2 2 3 2 2 2 2 20 25 30 40 VO = 0.6 V VO = 1.0 V VO = 1.8 V VO = 3.3 V VO = 0.6 V VO = 1.0 V VO = 1.8 V VO = 3.3 V VO = 0.6 V VO = 1.0 V VO = 1.8 V VO = 3.3 V See Note 18 VO = 0.6 V VO = 1.0 V VO = 1.8 V VO = 3.3 V % FS 0.001 Ω mV mV mVp-p 50 3.12 4.81 8.22 14.59 52 A 65 VO = 0.6 V VO = 1.0 V VO = 1.8 V VO = 3.3 V 10 8 6 5 VO = 0.6 V VO = 1.0 V VO = 1.8 V VO = 3.3 V VO = 0.6 V VO = 1.0 V VO = 1.8 V VO = 3.3 V VO = 0.6 V VO = 1.0 V VO = 1.8 V VO = 3.3 V VO = 0.6 V VO = 1.0 V VO = 1.8 V VO = 3.3 V 85.2 90.2 93.3 95.3 80.2 86.6 91.2 94.2 7.40 7.73 8.68 10.15 0.95 0.95 1.22 1.88 A A A % % W W Ericsson Internal PRODUCT SPECIFICATION Prepared (also subject responsible if other) EHOSMIR 2/1301-BMR 464 0008 Uen Approved Checked EAB/FJB/GM (Ksenia (EKRIROB) BMR46 series PoL Harrisen) Regulators Input 4.5-14 V, Output up to 50 A / 165 W Characteristics PCTRL Ci Co COUT Vtr1 ttr1 fs Input standby power Turned off with CTRL-pin Load transient peak voltage deviation (L to H/H to L) Load step 25-75-25% of max IO Default configuration di/dt = 2 A/μs CO = 470 μF (minimum external capacitance) see Note 12 Load transient recovery time, Note 5 (L to H/H to L) Load step 25-75-25% of max IO Default configuration di/dt = 2 A/μs CO = 470 μF (minimum external capacitance) see Note 12 Switching frequency Switching frequency range, see Note 20 Switching frequency set-point accuracy Control Circuit PWM Duty Cycle Minimum Sync Pulse Width Input Clock Frequency Drift Tolerance Input Over Voltage Protection, IOVP Power Good, PG, See Note 2 Output voltage Over/Under Voltage Protection, OVP/UVP UVLO threshold UVLO threshold range Set point accuracy UVLO hysteresis UVLO hysteresis range Delay Fault response IOVP threshold IOVP threshold range Set point accuracy IOVP hysteresis IOVP hysteresis range Delay Fault response PG threshold PG hysteresis PG delay PG delay range UVP threshold UVP threshold range UVP hysteresis OVP threshold OVP threshold range UVP/OVP response time UVP/OVP response time range Fault response 33 Technical Specification Reference Date Rev 2014-05-02 C1/28701-BMR 464 Rev.B Conditions Internal input capacitance Internal output capacitance Total external output capacitance ESR range of capacitors (per single capacitor) Input Under Voltage Lockout, UVLO 12 (20) No. July 2019 © Flex min Default configuration: Monitoring enabled, Precise timing enabled typ max Unit mW 170 140 400 See Note 9 470 30 000 μF μF μF See Note 9 5 30 mΩ VO = 0.6 V 90 / 300 VO = 1.0 V 120 / 300 VO = 1.8 V 160 / 305 VO = 3.3 V 230 / 315 VO = 0.6 V 70 / 100 VO = 1.0 V 100 / 100 VO = 1.8 V 100 / 100 VO = 3.3 V 100 / 100 -5 5 150 -13 5 95 13 3.85 3.85-14 PMBus configurable -150 150 0.35 0-10.15 2.5 Automatic restart, 70 ms 16 4.2-16 PMBus configurable See Note 3 PMBus configurable -150 PMBus configurable See Note 3 See Note 19 PMBus configurable PMBus configurable PMBus configurable PMBus configurable See Note 3 μs 320 200-640 PMBus configurable External clock source mV 150 1 0-11.8 2.5 Automatic restart, 70 ms 90 5 Direct after DLC 0-500 85 0-100 5 115 100-115 25 5-60 Automatic restart, 70 ms kHz kHz % % ns % V V mV V V μs V V mV V V μs % VO % VO ms s % VO % VO % VO % VO % VO μs μs Ericsson Internal PRODUCT SPECIFICATION Prepared (also subject responsible if other) EHOSMIR Approved Checked BMR46 series PoL Harrisen) Regulators EAB/FJB/GM (Ksenia (EKRIROB) Input 4.5-14 V, Output up to 50 A / 165 W Characteristics Over Current Protection, OCP Over Temperature Protection, OTP at P2 See Note 8 VIL VIH IIL VOL VOH IOL IOH fSMB tset thold tfree Cp Logic input low threshold Logic input high threshold Logic input low sink current Logic output low signal level Logic output high signal level Logic output low sink current Logic output high source current SMBus Operating frequency Setup time, SMBus Hold time, SMBus Bus free time, SMBus Internal capacitance on logic pins Initialization time Output Voltage Delay Time See Note 6 Output Voltage Ramp Time See Note 13 2/1301-BMR 464 0008 Uen Technical Date Rev 2014-05-02 C Conditions OCP threshold OCP threshold range Protection delay, Protection delay range Fault response OTP threshold OTP threshold range OTP hysteresis OTP hysteresis range Fault response Delay duration Delay duration range Delay accuracy turn-on Delay accuracy turn-off Ramp duration Ramp duration range Ramp time accuracy VTRK Input Bias Current VTRK Tracking Ramp Accuracy (VO - VVTRK) VTRK Regulation Accuracy (VO - VVTRK) Current difference between products in a current sharing group READ_IOUT vs IO typ See Note 1 See Note 1 See Note 1 max 60 0-60 32 1-32 Automatic restart, 70 ms 120 -40…+125 25 0-165 Automatic restart, 240 ms C C C C 0.8 0.6 0.4 2.25 4 2 100 10 250 300 2 10 See Note 10 See Note 16 PMBus configurable 40 10 5-500000 Current sharing operation VVTRK = 5.5 V 100% tracking, see Note 7 Current sharing operation 2 phases, 100% tracking VO = 1.0 V, 10 ms ramp 100% Tracking Current sharing operation 100% Tracking Steady state operation Ramp-up IO = 0-50 A, TP1 = 0 to +95 °C VI = 4.5-14 V, VO = 1.0 V IO = 0-50 A, TP1 = 0 to +95 °C VI = 4.5-14 V, VO = 0.6-3.3 V V V mA V V mA mA kHz ns ns ms pF ms ms -0.25/+4 ms -0.25/+4 ms 10 0-200 100 20 PMBus configurable Unit A A Tsw Tsw 2 CTRL READ_VIN vs VI READ_VOUT vs VO READ_IOUT vs IO min PMBus configurable See Note 3 SYNC, SCL, SDA, SALERT, GCB, PG July 2019 © Flex PMBus configurable SYNC, SA0, SA1, SCL, SDA, GCB, CTRL, VSET 34 Specification Reference 1/28701-BMR 464 Rev.B PMBus configurable See Note 4 PMBus configurable See Note 3 Number of products in a current sharing group Monitoring accuracy 13 (20) No. 110 -100 ms µs % 200 100 ±100 µA mV mV -1 1 % -2 2 % Max 2 x READ_IOUT monitoring accuracy 4 7 A 3 1 % % ±3.0 A ±5.0 A Ericsson Internal PRODUCT SPECIFICATION Prepared (also subject responsible if other) No. EHOSMIR Approved Checked BMR46 series PoL Harrisen) Regulators EAB/FJB/GM (Ksenia (EKRIROB) Input 4.5-14 V, Output up to 50 A / 165 W 2/1301-BMR 464 0008 Uen Technical Date Rev 2014-05-02 C 14 (20) Specification Reference 1/28701-BMR 464 Rev.B July 2019 © Flex Note 1: See section I2C/SMBus Setup and Hold Times – Definitions. Note 2: Monitorable over PMBus Interface. Note 3: Automatic restart ~70 or 240 ms after fault if the fault is no longer present. Continuous restart attempts if the fault reappear after restart. See Operating Information and AN302 for other fault response options. Note 4: Tsw is the switching period. Note 5: Within +/-3% of VO Note 6: See section Soft-start Power Up. Note 7: Tracking functionality is designed to follow a VTRK signal with slew rate < 2.4 V/ms. For faster VTRK signals accuracy will depend on the regulator bandwidth. Note 8: See section Over Temperature Protection (OTP). Note 9: See section External Capacitors. Note 10: See section Initialization Procedure. Note 11: See graph Output Ripple vs External Capacitance and Operating information section Output Ripple and Noise. Note 12: See graph Load Transient vs. External Capacitance and Operating information section External Capacitors. Note 13: Time for reaching 100% of nominal Vout. Note 14: For Vout < 1.0 V accuracy is +/-10 mV. For further deviations see section Output Voltage Adjust using PMBus. Note 15: Accuracy here means deviation from ideal output voltage level given by configured droop and actual load. Includes line, load and temperature variations. Note 16: For current sharing the Output Voltage Delay Time must be reconfigured to minimum 15 ms, see AN307 for details. Note 17: For steady state operation above 1.05 x 3.3 V, please contact your local Flex sales representative. Note 18: A minimum load current is not required if Low Power mode is used (monitoring disabled). Note 19: See sections Dynamic Loop Compensation and Power Good. Note 20: Please check with your local flex Sales representative if you intend to adjust the frequency exceed 320 KHz. 35 Ericsson Internal PRODUCT SPECIFICATION Prepared (also subject responsible if other) EHOSMIR 2/1301-BMR 464 0008 Uen Approved Checked EAB/FJB/GM (Ksenia (EKRIROB) BMR46 series PoL Harrisen) Regulators Input 4.5-14 V, Output up to 50 A / 165 W Rev 2014-05-02 C1/28701-BMR 464 Rev.B July 2019 © Flex BMR 464 2008 (SIP) Efficiency vs. Output Current, VI = 5 V Power Dissipation vs. Output Current, VI = 5 V [%] [W] 100 12 10 95 8 90 0.6 V 1.0 V 85 80 0 10 20 30 40 0.6 V 6 1.0 V 1.8 V 4 1.8 V 3.3 V 2 3.3 V 0 50 [A] 0 10 20 30 40 50 [A] Efficiency vs. load current and output voltage: TP1 = +25 °C, VI = 5 V, fsw = 320 kHz, CO = 470 µF/10 mΩ. Dissipated power vs. load current and output voltage: TP1 = +25 °C, VI = 5 V, fsw = 320 kHz, CO = 470 µF/10 mΩ. Efficiency vs. Output Current, VI = 12 V Power Dissipation vs. Output Current, VI = 12 V [%] [W] 100 12 10 95 8 90 0.6 V 1.0 V 85 80 75 36 Technical Specification Reference Date Typical Characteristics Efficiency and Power Dissipation 75 15 (20) No. 0 10 20 30 40 0.6 V 6 1.0 V 1.8 V 4 1.8 V 3.3 V 2 3.3 V 0 50 [A] 0 10 20 30 40 50 [A] Efficiency vs. load current and output voltage at TP1 = +25 °C, VI=12 V, fsw = 320 kHz, CO = 470 µF/10 mΩ. Dissipated power vs. load current and output voltage: TP1 = +25 °C, VI=12 V, fsw = 320 kHz, CO = 470 µF/10 mΩ. Efficiency vs. Output Current and Switching Frequency Power Dissipation vs. Output Current and Switching frequency [%] [W] 95 12 90 200 kHz 85 10 200 kHz 8 320 kHz 6 320 kHz 80 480 kHz 4 480 kHz 75 640 kHz 2 640 kHz 70 0 10 20 30 40 Efficiency vs. load current and switch frequency at TP1 = +25 °C, VI = 12 V, VO = 1.0 V, CO = 470 µF/10 mΩ. Default configuration except changed frequency 50 [A] 0 0 10 20 30 40 50 [A] Dissipated power vs. load current and switch frequency at TP1 = +25 °C, VI = 12 V, VO = 1.0 V, CO = 470 µF/10 mΩ. Default configuration except changed frequency Ericsson Internal PRODUCT SPECIFICATION Prepared (also subject responsible if other) 16 (20) No. EHOSMIR 2/1301-BMR 464 0008 Uen Approved Checked EAB/FJB/GM (Ksenia (EKRIROB) BMR46 series PoL Harrisen) Regulators Input 4.5-14 V, Output up to 50 A / 165 W Technical Specification Reference Date Rev 2014-05-02 C1/28701-BMR 464 Rev.B July 2019 © Flex Typical Characteristics Load Transient BMR 464 2008 (SIP) Load Transient vs. External Capacitance, VO = 1.0 V [mV] 500 Universal PID, No NLR 400 Load Transient vs. External Capacitance, VO = 3.3 V [mV] 500 Universal PID, No NLR DLC, No NLR 400 300 Universal PID, Default NLR 300 Universal PID, Default NLR 200 DLC, Default NLR 200 DLC, Default NLR 100 Universal PID, Opt. NLR 100 Universal PID, Opt. NLR DLC, Opt. NLR 0 0 1 2 3 4 5 [mF] 0 DLC, No NLR DLC, Opt. NLR 0 1 2 3 4 5 [mF] Load transient peak voltage deviation vs. external capacitance. Step (12.5-37.5-12.5 A). Parallel coupling of capacitors with 470 µF/10 mΩ, TP1 = +25 °C. VI = 12 V, VO = 1.0 V, fsw = 320 kHz, di/dt = 2 A/µs Load transient peak voltage deviation vs. external capacitance. Step (12.5-37.5-12.5 A). Parallel coupling of capacitors with 470 µF/10 mΩ, TP1 = +25 °C. VI = 12 V, VO = 3.3 V, fsw = 320 kHz, di/dt = 2 A/µs Load transient vs. Switch Frequency Output Load Transient Response, Default Configuration [mV] 600 Universal PID, No NLR 500 DLC, No NLR 400 Universal PID, Default NLR 300 DLC, Default NLR 200 Universal PID, Opt. NLR 100 0 DLC, Opt. NLR 200 300 400 37 500 600 [kHz] Load transient peak voltage deviation vs. frequency. Step-change (12.5-37.5-12.5 A). TP1 = +25 °C. VI = 12 V, VO = 1.0 V, CO = 470 µF/10 mΩ Note 1: For Universal PID, see section Dynamic Loop Compensation (DLC). Note 2: In these graphs, the worst-case scenario (load step 37.5-12.5 A) has been considered. Output voltage response to load Step-change (12.5-37.5-12.5 A) at: TP1 = +25 °C, VI = 12 V, VO = 1.0 V di/dt = 2 A/µs, fsw = 320 kHz CO = 470 µF/10 mΩ Top trace: output voltage (200 mV/div.). Bottom trace: load current (10 A/div.). Time scale: (0.1 ms/div.). Ericsson Internal PRODUCT SPECIFICATION Prepared (also subject responsible if other) 17 (20) No. EHOSMIR 2/1301-BMR 464 0008 Uen Approved Checked EAB/FJB/GM (Ksenia (EKRIROB) BMR46 series PoL Harrisen) Regulators Input 4.5-14 V, Output up to 50 A / 165 W 38 Technical Specification Reference Date Rev 2014-05-02 C1/28701-BMR 464 Rev.B July 2019 © Flex Typical Characteristics Output Current Characteristic BMR 464 2008 (SIP) Output Current Derating, VO = 0.6 V Output Current Derating, VO = 1.0 V [A] [A] 50 50 3.0 m/s 40 2.0 m/s 3.0 m/s 40 2.0 m/s 30 1.0 m/s 30 1.0 m/s 20 0.5 m/s 20 0.5 m/s Nat. Conv. 10 0 20 40 60 80 100 0 120 [°C] Nat. Conv. 10 20 40 60 80 100 120 [°C] Available load current vs. ambient air temperature and airflow at VO = 0.6 V, VI = 12 V. See Thermal Consideration section. Available load current vs. ambient air temperature and airflow at VO = 1.0 V, VI = 12 V. See Thermal Consideration section. Output Current Derating, VO = 1.8 V Output Current Derating, VO = 3.3 V [A] [A] 50 50 3.0 m/s 3.0 m/s 40 40 2.0 m/s 30 1.0 m/s 30 1.0 m/s 20 0.5 m/s 20 0.5 m/s Nat. Conv. 10 0 20 40 60 80 100 Available load current vs. ambient air temperature and airflow at VO = 1.8 V, VI = 12 V. See Thermal Consideration section. Nat. Conv. 10 0 120 [°C] 2.0 m/s 20 40 60 80 100 120 [°C] Available load current vs. ambient air temperature and airflow at VO = 3.3 V, VI = 12 V. See Thermal Consideration section. Current Limit Characteristics, VO = 1.0 V Current Limit Characteristics, VO = 3.3 V [V] [V] 1,2 4,0 0,9 3,0 4.5 V 4.5 V 5.0 V 0,6 VI = 4.5, 5.0 V VI =12, 14 V 12 V 14 V 0,3 0,0 50 55 60 65 [A] Output voltage vs. load current at TP1 = +25 °C, VO = 1.0 V. Note: Output enters hiccup mode at current limit. 5.0 V 2,0 VI = 4.5, 14 V 12 V VI = 5.0, 12 V 14 V 1,0 0,0 50 55 60 65 [A] Output voltage vs. load current at TP1 = +25 °C, VO = 3.3 V. Note: Output enters hiccup mode at current limit. Ericsson Internal PRODUCT SPECIFICATION Prepared (also subject responsible if other) 18 (20) No. EHOSMIR 2/1301-BMR 464 0008 Uen Approved Checked EAB/FJB/GM (Ksenia (EKRIROB) BMR46 series PoL Harrisen) Regulators Input 4.5-14 V, Output up to 50 A / 165 W 39 Technical Specification Reference Date Rev 2014-05-02 C1/28701-BMR 464 Rev.B July 2019 © Flex Typical Characteristics Output Voltage BMR 464 2008 (SIP) Output Ripple & Noise, VO = 1.0 V Output Ripple & Noise, VO = 3.3 V Output voltage ripple at: TP1 = +25 °C, Trace: output voltage (10 mV/div.). Time scale: (2 µs/div.). VI = 12 V, CO = 470 µF/10 mΩ IO = 50 A Output voltage ripple at: TP1 = +25 °C, Trace: output voltage (10 mV/div.). Time scale: (2 µs/div.). VI = 12 V, CO = 470 µF/10 mΩ IO = 50 A Output Ripple vs. Input Voltage Output Ripple vs. Frequency [mVpk-pk] [mVpk-pk] 40 70 60 30 50 0.6 V 1.0 V 40 1.0 V 1.8 V 30 3.3 V 20 0.6 V 20 10 1.8 V 3.3 V 10 0 5 7 9 11 0 [V] 13 200 300 400 500 600 [kHz] Output voltage ripple Vpk-pk at: TP1 = +25 °C, CO = 470 µF/10 mΩ, IO = 50 A. Output voltage ripple Vpk-pk at: TP1 = +25 °C, VI = 12 V, CO = 470 µF/10 mΩ, IO = 50 A. Default configuration except changed frequency. Output Ripple vs. External Capacitance Load regulation, VO = 1.0 V [mV] [V] 40 1,010 30 0.6 V 1.0 V 20 1.8 V 3.3 V 10 0 0 1 2 3 4 5 [mF] Output voltage ripple Vpk-pk at: TP1 = +25 °C, VI = 12 V, IO = 50 A. Parallel coupling of capacitors with 470 µF/10 mΩ 1,005 4.5 V 5.0 V 1,000 12 V 14 V 0,995 0,990 0 5 10 15 20 25 [A] Load regulation at VO = 1.0 V, TP1 = +25 °C, CO = 470 µF/10 mΩ Ericsson Internal PRODUCT SPECIFICATION Prepared (also subject responsible if other) EHOSMIR Approved 2/1301-BMR 464 0008 Uen Checked EAB/FJB/GM (Ksenia (EKRIROB) BMR46 series PoL Harrisen) Regulators Input 4.5-14 V, Output up to 50 A / 165 W Technical Specification Reference Date Rev 2014-05-02 C1/28701-BMR 464 Rev.B July 2019 BMR 464 2008 (SIP) Start-up by input source Shut-down by input source Top trace: output voltage (0.5 V/div.). Bottom trace: input voltage (5 V/div.). Time scale: (20 ms/div.). Start-up by CTRL signal Start-up by enabling CTRL signal at: TP1 = +25 °C, VI = 12 V, VO = 1.0 V CO = 470 µF/10 mΩ, IO = 50 A 40 © Flex Typical Characteristics Start-up and shut-down Start-up enabled by connecting VI at: TP1 = +25 °C, VI = 12 V, VO = 1.0 V CO = 470 µF/10 mΩ, IO = 50 A 19 (20) No. Shut-down enabled by disconnecting VI at: TP1 = +25 °C, VI = 12 V, VO = 1.0 V CO = 470 µF/10 mΩ, IO = 50 A Top trace: output voltage (0.5 V/div). Bottom trace: input voltage (5 V/div.). Time scale: (2 ms/div.). Shut-down by CTRL signal Top trace: output voltage (0.5 V/div.). Bottom trace: CTRL signal (2 V/div.). Time scale: (20 ms/div.). Shut-down enabled by disconnecting VI at: TP1 = +25 °C, VI = 12 V, VO = 1.0 V CO = 470 µF/10 mΩ, IO = 50 A Top trace: output voltage (0.5 V/div). Bottom trace: CTRL signal (2 V/div.). Time scale: (2 ms/div.). ERICSSON INTERNAL PRODUCT SPECIFICATION Prepared (Subject resp) 2 (10) No. JIDDASUN Dan Sun Approved (Document resp) 2/1301-BMR 464 2012 Uen Checked JIDDASUN Dan SunRegulators BMR46 series PoL Input 4.5-14 V, Output up to 50 A / 165 W 41 Technical Specification Date Rev 1/7/2019 C1/28701-BMR 464 Rev.B July 2019 © Flex Electrical Specification BMR 464 2012 (SIP) TP1 = -30 to +95 °C, VI = 4.5 to 14 V, VI > VO + 1.0 V Typical values given at: TP1 = +25 °C, VI = 12.0 V, max IO, unless otherwise specified under Conditions. External CIN = 470 µF/10 mΩ, COUT = 470 µF/10 mΩ. See Operating Information section for selection of capacitor types. Sense pins are connected to the output pins. Characteristics VI Conditions Input voltage rise time Output voltage without pin strap Output voltage adjustment range Output voltage adjustment including margining Output voltage set-point resolution Output voltage accuracy VO Load regulation; IO = 0 - 100% VOac Output ripple & noise CO = 470 μF (minimum external capacitance). See Note 11 IO Output current IS Static input current at max IO Ilim Current limit threshold Short circuit current RMS, hiccup mode, See Note 3 50% of max IO η Efficiency max IO Pd Power dissipation at max IO Pli Input idling power (no load) Default configuration: Continues Conduction Mode, CCM PCTRL Input standby power Turned off with CTRL-pin Ci Co COUT max Unit 2.4 V/ms 0.60 Internal input capacitance Internal output capacitance Total external output capacitance ESR range of capacitors (per capacitor) typ 3.3 V V 0.54 3.63 V 1.2 See Note 17 ±0.025 Including line, load, temp. See Note 14 Current sharing operation See Note 15 -1 -2 Internal resistance +S/-S to VOUT/GND Line regulation Isc min monotonic 1 % 2 % 47 2 2 2 3 2 2 2 2 20 25 30 35 VO = 0.6 V VO = 1.0 V VO = 1.8 V VO = 3.3 V VO = 0.6 V VO = 1.0 V VO = 1.8 V VO = 3.3 V VO = 0.6 V VO = 1.0 V VO = 1.8 V VO = 3.3 V See Note 18 VO = 1.0 V VO = 3.3 V % FS 0.001 Ω mV mV mVp-p 50 4.9 14.53 52 A 65 VO = 0.6 V VO = 1.0 V VO = 1.8 V VO = 3.3 V 11 9 7 6 VO = 1.0 V VO = 3.3 V VO = 1.0 V VO = 3.3 V VO = 1.0 V VO = 3.3 V VO = 0.6 V VO = 1.0 V VO = 1.8 V VO = 3.3 V 90.4 95.7 86.9 94.6 7.54 9.36 0.90 0.90 1.10 1.67 Default configuration: Monitoring enabled, Precise timing enabled 170 470 5 A A % % W W mW 140 400 See Note 9 See Note 9 A 30 000 30 μF μF μF mΩ ERICSSON INTERNAL PRODUCT SPECIFICATION Prepared (Subject resp) JIDDASUN Dan Sun Approved (Document resp) 2/1301-BMR 464 2012 Uen Checked JIDDASUN Dan SunRegulators BMR46 series PoL Input 4.5-14 V, Output up to 50 A / 165 W Vtr1 ttr1 fs Load transient peak voltage deviation (L to H/H to L) Load step 20-60-20% of max IO Load transient recovery time, Note 5 (L to H/H to L) Load step 20-60-20% of max IO Default configuration di/dt = 2 A/μs CO = 470 μF (minimum external capacitance) see Note 12 Default configuration di/dt = 2 A/μs CO = 470 μF (minimum external capacitance) see Note 12 Switching frequency Switching frequency range, see Note 19 Switching frequency set-point accuracy Control Circuit PWM Duty Cycle Minimum Sync Pulse Width Input Clock Frequency Drift Tolerance Input Under Voltage Lockout, UVLO Input Over Voltage Protection, IOVP Power Good, PG, See Note 2 Output voltage Over/Under Voltage Protection, OVP/UVP Over Current Protection, OCP Over Temperature Protection, OTP at P2 See Note 8 3 (10) No. UVLO threshold UVLO threshold range Set point accuracy UVLO hysteresis UVLO hysteresis range Delay Fault response IOVP threshold IOVP threshold range Set point accuracy IOVP hysteresis IOVP hysteresis range Delay Fault response PG threshold PG hysteresis PG delay PG delay range UVP threshold UVP threshold range UVP hysteresis OVP threshold OVP threshold range UVP/OVP response time UVP/OVP response time range Fault response OCP threshold OCP threshold range Protection delay, Protection delay range Fault response OTP threshold OTP threshold range OTP hysteresis OTP hysteresis range Fault response 42 Technical Specification Date Rev 1/7/2019 C1/28701-BMR 464 Rev.B July 2019 © Flex VO = 1.0 V 127 / 298 mV VO = 3.3 V 210 / 327 VO = 1.0 V 100 / 100 μs VO = 3.3 V 100 / 100 320 200-640 PMBus configurable External clock source -5 5 150 -13 5 95 13 3.85 3.85-14 PMBus configurable -150 150 0.35 0-10.15 2.5 Automatic restart, 70 ms 16 4.2-16 PMBus configurable See Note 3 PMBus configurable -150 PMBus configurable See Note 3 PMBus configurable PMBus configurable PMBus configurable PMBus configurable PMBus configurable PMBus configurable See Note 3 PMBus configurable See Note 4 PMBus configurable See Note 3 PMBus configurable PMBus configurable See Note 3 150 1 0-11.8 2.5 Automatic restart, 70 ms 90 5 10 0-500 85 0-100 5 115 100-115 25 5-60 Automatic restart, 70 ms 62 0-62 32 1-32 Automatic restart, 70 ms 120 -40…+125 25 0-165 Automatic restart, 240 ms kHz kHz % % ns % V V mV V V μs V V mV V V μs % VO % VO s s % VO % VO % VO % VO % VO μs μs A A Tsw Tsw C C C C ERICSSON INTERNAL PRODUCT SPECIFICATION Prepared (Subject resp) JIDDASUN Dan Sun Approved (Document resp) Checked BMR46 series PoL JIDDASUN Dan SunRegulators Input 4.5-14 V, Output up to 50 A / 165 W VIL VIH IIL VOL VOH IOL IOH fSMB tset thold tfree Cp Logic input low threshold Logic input high threshold Logic input low sink current Logic output low signal level Logic output high signal level Logic output low sink current Logic output high source current SMBus Operating frequency Setup time, SMBus Hold time, SMBus Bus free time, SMBus Internal capacitance on logic pins Initialization time Output Voltage Delay Time See Note 6 Output Voltage Ramp Time See Note 13 Delay duration Delay duration range Delay accuracy turn-on Delay accuracy turn-off Ramp duration Ramp duration range Ramp time accuracy VTRK Input Bias Current VTRK Tracking Ramp Accuracy (VO - VVTRK) VTRK Regulation Accuracy (VO - VVTRK) Current difference between products in a current sharing group Date READ_IOUT vs IO Rev 1/28701-BMR 464 Rev.B 1/7/2019 SYNC, SA0, SA1, SCL, SDA, GCB, CTRL, VSET SYNC, SCL, SDA, SALERT, GCB, PG See Note 1 See Note 1 See Note 1 July 2019 C © Flex 0.8 2 CTRL 0.6 0.4 2.25 4 2 100 10 250 300 2 10 See Note 10 See Note 16 PMBus configurable 40 10 5-500000 Current sharing operation VVTRK = 5.5 V 100% tracking, see Note 7 Current sharing operation 2 phases, 100% tracking VO = 1.0 V, 10 ms ramp 100% Tracking Current sharing operation 100% Tracking Steady state operation Ramp-up IO = 0-50 A, TP1 = 0 to +95 °C VI = 4.5-14 V, VO = 1.0 V IO = 0-50 A, TP1 = 0 to +95 °C VI = 4.5-14 V, VO = 0.6-3.3 V V V mA V V mA mA kHz ns ns ms pF ms ms -0.25/+4 ms -0.25/+4 ms 10 0-200 100 20 PMBus configurable READ_VIN vs VI READ_VOUT vs VO READ_IOUT vs IO 43 2/1301-BMR 464Technical 2012 Uen Specification Number of products in a current sharing group Monitoring accuracy 4 (10) No. 110 -100 ms µs % 200 100 ±100 µA mV mV -1 1 % -2 2 % Max 2 x READ_IOUT monitoring accuracy 4 7 A 3 1 % % ±3.0 A ±5.0 A Note 1: See section I2C/SMBus Setup and Hold Times – Definitions. Note 2: Monitorable over PMBus Interface. Note 3: Automatic restart ~70 or 240 ms after fault if the fault is no longer present. Continuous restart attempts if the fault reappear after restart. See Operating Information and AN302 for other fault response options. Note 4: Tsw is the switching period. Note 5: Within +/-3% of VO Note 6: See section Soft-start Power Up. Note 7: Tracking functionality is designed to follow a VTRK signal with slew rate < 2.4 V/ms. For faster VTRK signals accuracy will depend on the regulator bandwidth. Note 8: See section Over Temperature Protection (OTP). Note 9: See section External Capacitors. Note 10: See section Initialization Procedure. Note 11: See graph Output Ripple vs External Capacitance and Operating information section Output Ripple and Noise. Note 12: See graph Load Transient vs. External Capacitance and Operating information section External Capacitors. Note 13: Time for reaching 100% of nominal Vout. Note 14: For Vout < 1.0 V accuracy is +/-10 mV. For further deviations see section Output Voltage Adjust using PMBus. Note 15: Accuracy here means deviation from ideal output voltage level given by configured droop and actual load. Includes line, load and temperature variations. Note 16: For current sharing the Output Voltage Delay Time must be reconfigured to minimum 15 ms, see AN307 for details. Note 17: For steady state operation above 1.05 x 3.3 V, please contact your local Flex sales representative. Note 18: A minimum load current is not required if Low Power mode is used (monitoring disabled). Note 19: Please check with your local Flex Sales representative if you intend to adjust the frequency exceed 320 KHz ±10%. ERICSSON INTERNAL PRODUCT SPECIFICATION Prepared (Subject resp) JIDDASUN Dan Sun 2/1301-BMR 464 2012 Uen Approved (Document resp) Checked Rev 1/7/2019 C1/28701-BMR 464 Rev.B July 2019 © Flex Typical Characteristics Efficiency and Power Dissipation BMR 464 2012 (SIP) Efficiency vs. Output Current, VI = 5 V Power Dissipation vs. Output Current, VI = 5 V [%] [W] 100 12 10 95 8 90 0.6 V 1.0 V 85 80 0 10 20 30 40 0.6 V 6 1.0 V 1.8 V 4 1.8 V 3.3 V 2 3.3 V 0 50 [A] 0 10 20 30 40 50 [A] Efficiency vs. load current and output voltage: TP1 = +25 °C, VI = 5 V, fsw = 320 kHz, CO = 470 µF/10 mΩ. Dissipated power vs. load current and output voltage: TP1 = +25 °C, VI = 5 V, fsw = 320 kHz, CO = 470 µF/10 mΩ. Efficiency vs. Output Current, VI = 12 V Power Dissipation vs. Output Current, VI = 12 V [%] [W] 100 12 95 10 90 0.6 V 85 80 75 44 Technical Specification Date JIDDASUN Dan SunRegulators BMR46 series PoL Input 4.5-14 V, Output up to 50 A / 165 W 75 5 (10) No. 10 20 30 40 0.6 V 1.0 V 6 1.8 V 4 1.8 V 2 3.3 V 3.3 V 0 8 0 50 [A] 1.0 V 0 10 20 30 40 50 [A] Efficiency vs. load current and output voltage at TP1 = +25 °C, VI = 12 V, fsw = 320 kHz, CO = 470 µF/10 mΩ. Dissipated power vs. load current and output voltage: TP1 = +25 °C, VI = 12 V, fsw = 320 kHz, CO = 470 µF/10 mΩ. Efficiency vs. Output Current and Switching Frequency Power Dissipation vs. Output Current and Switching frequency [%] [W] 95 12 90 200 kHz 85 10 200 kHz 8 320 kHz 6 320 kHz 80 480 kHz 4 480 kHz 75 640 kHz 2 640 kHz 70 0 10 20 30 40 Efficiency vs. load current and switch frequency at TP1 = +25 °C, VI = 12 V, VO = 1.0 V, CO = 470 µF/10 mΩ. Default configuration except changed frequency 50 [A] 0 0 10 20 30 40 50 [A] Dissipated power vs. load current and switch frequency at TP1 = +25 °C, VI = 12 V, VO = 1.0 V, CO = 470 µF/10 mΩ. Default configuration except changed frequency ERICSSON INTERNAL PRODUCT SPECIFICATION Prepared (Subject resp) JIDDASUN Dan Sun 2/1301-BMR 464 2012 Uen Approved (Document resp) Checked JIDDASUN Dan SunRegulators BMR46 series PoL Input 4.5-14 V, Output up to 50 A / 165 W Technical Specification Date Rev 1/7/2019 C1/28701-BMR 464 Rev.B 45 July 2019 © Flex Typical Characteristics Load Transient BMR 464 2012 (SIP) Load Transient vs. External Capacitance, VO = 1.0 V Load Transient vs. External Capacitance, VO = 3.3 V [mV] 500 [mV] 500 Universal PID, No NLR 400 300 Optimized PID, Default NLR 200 Optimized PID, Opt. NLR 100 0 6 (10) No. 300 1 2 3 4 5 [mF] Optimized PID, Default NLR 200 Optimized PID, Opt. NLR 100 0 0 Universal PID, No NLR 400 0 1 2 3 4 5 [mF] Load transient peak voltage deviation vs. external capacitance. Step (12.5-37.5-12.5 A). Parallel coupling of capacitors with 470 µF/10 mΩ, TP1 = +25 °C, VI = 12 V, VO = 1.0 V, fsw = 320 kHz, di/dt = 2 A/µs Load transient peak voltage deviation vs. external capacitance. Step (12.5-37.5-12.5 A). Parallel coupling of capacitors with 470 µF/10 mΩ, TP1 = +25 °C, VI = 12 V, VO = 3.3 V, fsw = 320 kHz, di/dt = 2 A/µs Output Load Transient Response, Default Configuration Output Load Transient Response, Opt. PID, Opt.NLR Output voltage response to load current Step-change (10-30-10 A) at: TP1 = +25 °C, VI = 12 V, VO = 1.0 V di/dt = 2 A/µs, fsw = 320 kHz CO = 4000 µF Top trace: output voltage (100 mV/div.). Output voltage response to load current Top trace: output voltage (100 mV/div.). Bottom trace: load current (10 A/div.). Step-change (10-30-10 A) at: Bottom trace: load current (10 A/div.). Time scale: (0.1 ms/div.). TP1 = +25 °C, VI = 12 V, VO = 1.0 V Time scale: (0.1 ms/div.). di/dt = 2 A/µs, fsw = 320 kHz CO = 4000 µF Output Load Transient Response, Opt. PID, default NLR Output voltage response to load current Step-change (10-30-10 A) at: TP1 = +25 °C, VI = 12 V, VO = 1.0 V di/dt = 2 A/µs, fsw = 320 kHz CO = 4000 µF Top trace: output voltage (200 mV/div.). Bottom trace: load current (10 A/div.). Time scale: (0.1 ms/div.). ERICSSON INTERNAL PRODUCT SPECIFICATION Prepared (Subject resp) 7 (10) No. JIDDASUN Dan Sun 2/1301-BMR 464 2012 Uen Approved (Document resp) Checked JIDDASUN Dan SunRegulators BMR46 series PoL Input 4.5-14 V, Output up to 50 A / 165 W Technical Specification Date Rev 1/7/2019 C1/28701-BMR 464 Rev.B July 2019 © Flex Typical Characteristics Output Current Characteristic BMR 464 2012 (SIP) Output Current Derating, VO = 0.6 V Output Current Derating, VO = 1.0 V [A] [A] 50 50 3.0 m/s 40 2.0 m/s 3.0 m/s 40 2.0 m/s 30 1.0 m/s 30 1.0 m/s 20 0.5 m/s 20 0.5 m/s Nat. Conv. 10 0 20 40 60 80 100 Nat. Conv. 10 0 120 [°C] Available load current vs. ambient air temperature and airflow at VO = 0.6 V, VI = 12 V. See Thermal Consideration section. 20 40 60 80 100 120 [°C] Available load current vs. ambient air temperature and airflow at VO = 1.0 V, VI = 12 V. See Thermal Consideration section. Output Current Derating, VO = 1.8 V Output Current Derating, VO = 3.3 V [A] [A] 50 50 3.0 m/s 3.0 m/s 40 2.0 m/s 40 2.0 m/s 30 1.0 m/s 30 1.0 m/s 20 0.5 m/s 20 0.5 m/s Nat. Conv. 10 10 0 0 20 40 60 80 100 46 120 [°C] Available load current vs. ambient air temperature and airflow at VO = 1.8 V, VI = 12 V. See Thermal Consideration section. Nat. Conv. 20 40 60 80 100 120 [°C] Available load current vs. ambient air temperature and airflow at VO = 3.3 V, VI = 12 V. See Thermal Consideration section. ERICSSON INTERNAL PRODUCT SPECIFICATION Prepared (Subject resp) 8 (10) No. JIDDASUN Dan Sun 2/1301-BMR 464 2012 Uen Approved (Document resp) Checked JIDDASUN Dan SunRegulators BMR46 series PoL Input 4.5-14 V, Output up to 50 A / 165 W 47 Technical Specification Date Rev 1/7/2019 C1/28701-BMR 464 Rev.B July 2019 © Flex BMR 464 2012 (SIP) Typical Characteristics Output Voltage Output Ripple & Noise, VO = 1.0 V Output Ripple & Noise, VO = 3.3 V Output voltage ripple at: TP1 = +25 °C, Trace: output voltage (10 mV/div.). VI = 12 V, CO = 470 µF/10 mΩ Time scale: (2 µs/div.). IO = 50 A 20 MHz bandwidth Output voltage ripple at: TP1 = +25 °C, Trace: output voltage (10 mV/div.). VI = 12 V, CO = 470 µF/10 mΩ Time scale: (2 µs/div.). IO = 50 A 20 MHz bandwidth Output Ripple vs. Input Voltage Output Ripple vs. External Capacitance [mVpk-pk] 40 [mV] 40 30 0.6 V 1.0 V 20 1.8 V 3.3 V 10 0 30 7 9 11 1.8 V 3.3 V 10 [V] 13 1.0 V 20 0 5 0.6 V 0 1 2 3 4 5 [mF] Output voltage ripple Vpk-pk at: TP1 = +25 °C, CO = 470 µF/10 mΩ, IO = 50 A Output voltage ripple Vpk-pk at: TP1 = +25 °C, VI = 12 V. IO = 50 A. Parallel coupling of capacitors with 470 µF/10 mΩ Current Limit Characteristics, VO = 1.0 V Current Limit Characteristics, VO = 3.3 V [V] [V] 1.2 4.0 VI = 4.5, 5 .0V VI = 5.0, 12 V 0.9 3.0 4.5 V 4.5 V 5.0 V 0.6 12 V VI = 4.5,14 V 14 V 0.3 0.0 50 55 60 65 [A] Output voltage vs. load current at TP1 = +25 °C, VO = 1.0 V. Note: Output enters hiccup mode at current limit. 5.0 V 2.0 12 V VI = 12, 14 V 14 V 1.0 0.0 50 55 60 65 [A] Output voltage vs. load current at TP1 = +25 °C, VO = 3.3 V. Note: Output enters hiccup mode at current limit. ERICSSON INTERNAL PRODUCT SPECIFICATION Prepared (Subject resp) JIDDASUN Dan Sun Approved (Document resp) 2/1301-BMR 464 2012 Uen Checked JIDDASUN Dan SunRegulators BMR46 series PoL Input 4.5-14 V, Output up to 50 A / 165 W Date 1/7/2019 Technical Specification Rev C1/28701-BMR 464 July 2019 BMR 464 2012 (SIP) Start-up by input source Shut-down by input source Top trace: input voltage (10 V/div.). Mid trace: output voltage (1V/div) Bottom trace: PG (2 V/div.). Time scale: (20 ms/div.). Start-up by CTRL signal Start-up by enabling CTRL signal at: TP1 = +25 °C, VI = 12 V, VO = 1.0 V CO = 470 µF/10 mΩ, IO = 50 A Rev.B 48 © Flex Typical Characteristics Start-up and shut-down Start-up enabled by connecting VI at: TP1 = +25 °C, VI = 12 V, VO = 1.0 V CO = 470 µF/10 mΩ, IO = 50 A 9 (10) No. Shut-down enabled by disconnecting VI at: TP1 = +25 °C, VI = 12 V, VO = 1.0 V CO = 470 µF/10 mΩ, IO = 50 A Top trace: input voltage (10 V/div.). Mid trace: output voltage (1V/div) Bottom trace: PG (2 V/div.). Time scale: (10 ms/div.). Shut-down by CTRL signal Top trace: CTRL (5 V/div.). Mid trace: output voltage (1V/div) Bottom trace: PG (2 V/div.). Time scale: (10 ms/div.). Shut-down enabled by disconnecting VI at: TP1 = +25 °C, VI = 12 V, VO = 1.0 V CO = 470 µF/10 mΩ, IO = 50 A Top trace: CTRL (5 V/div.). Mid trace: output voltage (1V/div) Bottom trace: PG (2 V/div.). Time scale: (10 ms/div.). Technical Specification BMR46 series PoL Regulators Input 4.5-14 V, Output up to 50 A / 165 W EMC Specification Conducted EMI measured according to test set-up below. The fundamental switching frequency is 320 kHz at VI = 12 V, max IO. 1/28701-BMR 464 Rev.B 49 July 2019 © Flex Output Ripple and Noise Output ripple and noise is measured according to figure below. A 50 mm conductor works as a small inductor forming together with the two capacitors as a damped filter. Conducted EMI Input terminal value (typical for default configuration) S S 50 mm conductor Tantalum Capacitor Output 10 µF Capacitor 470 µF/10 mΩ GND Ceramic Capacitor 0.1 µF Load Vout 50 mm conductor BNC-contact to oscilloscope Output ripple and noise test set-up. Operating information EMI without filter for BMR 464 2008 To spectrum analyzer Battery supply RF Current probe 1kHz – 50MHz Resistive load C1 POL 50mm C1 = 10uF / 600VDC Feed- Thru RF capacitor 800mm 200mm Conducted EMI test set-up Layout Recommendations The radiated EMI performance of the product will depend on the PWB layout and ground layer design. It is also important to consider the stand-off of the product. If a ground layer is used, it should be connected to the output of the product and the equipment ground or chassis. A ground layer will increase the stray capacitance in the PWB and improve the high frequency EMC performance. Power Management Overview This product is equipped with a PMBus interface. The product incorporates a wide range of readable and configurable power management features that are simple to implement with a minimum of external components. Additionally, the product includes protection features that continuously safeguard the load from damage due to unexpected system faults. A fault is also shown as an alert on the SALERT pin. The following product parameters can continuously be monitored by a host: Input voltage, output voltage/current, and internal temperature. If the monitoring is not needed it can be disabled and the product enters a low power mode reducing the power consumption. The protection features are not affected. The product is delivered with a default configuration suitable for a wide range operation in terms of input voltage, output voltage, and load. The configuration is stored in an internal Non-Volatile Memory (NVM). All power management functions can be reconfigured using the PMBus interface. Please contact your local Flex representative for design support of custom configurations or appropriate SW tools for design and download of your own configurations. Input Voltage The input voltage range, 4.5 - 14 V, makes the product easy to use in intermediate bus applications when powered by a non-regulated bus converter or a regulated bus converter. See Ordering Information for input voltage range. Technical Specification BMR46 series PoL Regulators Input 4.5-14 V, Output up to 50 A / 165 W 1/28701-BMR 464 Rev.B 50 July 2019 © Flex Input Under Voltage Lockout, UVLO The product monitors the input voltage and will turn-on and turn-off at configured levels. The default turn-on input voltage level setting is 4.20 V, whereas the corresponding turn-off input voltage level is 3.85 V. Hence, the default hysteresis between turn-on and turn-off input voltage is 0.35 V. Once an input turnoff condition occurs, the device can respond in a number of ways as follows: significant inductance, the addition a capacitor with low ESR at the input of the product will ensure stable operation. 1. where I load is the output load current and D is the duty cycle. Continue operating without interruption. The unit will continue to operate as long as the input voltage can be supported. If the input voltage continues to fall, there will come a point where the unit will cease to operate. 2. Continue operating for a given delay period, followed by shutdown if the fault still exists. The device will remain in shutdown until instructed to restart. 3. Initiate an immediate shutdown until the fault has been cleared. The user can select a specific number of retry attempts. The default response from a turn-off is an immediate shutdown of the device. The device will continuously check for the presence of the fault condition. If the fault condition is no longer present, the product will be re-enabled. The turn-on and turn-off levels and response can be reconfigured using the PMBus interface. Remote Control Vext CTRL GND The product is equipped with a remote control function, i.e., the CTRL pin. The remote control can be connected to either the primary negative input connection (GND) or an external voltage (Vext), which is a 3 - 5 V positive supply voltage in accordance to the SMBus Specification version 2.0. The CTRL function allows the product to be turned on/off by an external device like a semiconductor or mechanical switch. By default the product will turn on when the CTRL pin is left open and turn off when the CTRL pin is applied to GND. The CTRL pin has an internal pull-up resistor. When the CTRL pin is left open, the voltage generated on the CTRL pin is max 5.5 V. If the device is to be synchronized to an external clock source, the clock frequency must be stable prior to asserting the CTRL pin. The product can also be configured using the PMBus interface to be “Always on”, or turn on/off can be performed with PMBus commands. Input and Output Impedance The impedance of both the input source and the load will interact with the impedance of the product. It is important that the input source has low characteristic impedance. The performance in some applications can be enhanced by addition of external capacitance as described under External Decoupling Capacitors. If the input voltage source contains External Capacitors Input capacitors: The input ripple RMS current in a buck converter is equal to Eq. 1. I inputRMS  I load D1  D , The maximum load ripple current becomes I load 2 . The ripple current is divided into three parts, i.e., currents in the input source, external input capacitor, and internal input capacitor. How the current is divided depends on the impedance of the input source, ESR and capacitance values in the capacitors. A minimum capacitance of 300 µF with low ESR is recommended. The ripple current rating of the capacitors must follow Eq. 1. For high-performance/transient applications or wherever the input source performance is degraded, additional low ESR ceramic type capacitors at the input is recommended. The additional input low ESR capacitance above the minimum level insures an optimized performance. Output capacitors: When powering loads with significant dynamic current requirements, the voltage regulation at the point of load can be improved by addition of decoupling capacitors at the load. The most effective technique is to locate low ESR ceramic and electrolytic capacitors as close to the load as possible, using several capacitors in parallel to lower the effective ESR. The ceramic capacitors will handle high-frequency dynamic load changes while the electrolytic capacitors are used to handle low frequency dynamic load changes. Ceramic capacitors will also reduce high frequency noise at the load. It is equally important to use low resistance and low inductance PWB layouts and cabling. External decoupling capacitors are a part of the control loop of the product and may affect the stability margins. Stable operation is guaranteed for the following total capacitance CO in the output decoupling capacitor bank where Eq. 2. CO  Cmin , Cmax   470, 30000 µF . The decoupling capacitor bank should consist of capacitors which has a capacitance value larger than C  Cmin and has an ESR range of Eq. 3. ESR  ESRmin , ESRmax   5, 30 mΩ The control loop stability margins are limited by the minimum time constant  min of the capacitors. Hence, the time constant of the capacitors should follow Eq. 4. Eq. 4.    min  Cmin ESRmin  2.35  s This relation can be used if your preferred capacitors have parameters outside the above stated ranges in Eq. 2 and Eq.3. Technical Specification BMR46 series PoL Regulators Input 4.5-14 V, Output up to 50 A / 165 W • If the capacitors capacitance value is C  Cmin one must use at least N capacitors where Cmin C  . N   min  and ESR  ESRmin C C   • If the ESR value is ESR  ESRmax one must use at least N capacitors of that type where  ESR  Cmin . N  and C  N ESR max   • If the ESR value is ESR ESRmin the capacitance value should be ESRmin C  Cmin . ESR For a total capacitance outside the above stated range or capacitors that do not follow the stated above requirements above a re-design of the control loop parameters will be necessary for robust dynamic operation and stability. See technical paper TP022 for further information. Control Loop The product uses a voltage-mode synchronous buck controller with a fixed frequency PWM scheme. Although the product uses a digital control loop, it operates much like a traditional analog PWM controller. As in the analog controller case, the control loop compares the output voltage to the desired voltage reference and compensation is added to keep the loop stable and fast. The resulting error signal is used to drive the PWM logic. Instead of using external resistors and capacitors required with traditional analog control loops, the product uses a digital Proportional-Integral-Derivative (PID) compensator in the control loop. The characteristics of the control loop is configured by setting PID compensation parameters. These PID settings can be reconfigured using the PMBus interface. Control Loop Compensation Setting The products without DLC are by default configured with a robust control loop compensation setting (PID setting) which allows for a wide range operation of input and output voltages and capacitive loads as defined in the section External Decoupling Capacitors. For an application with a specific input voltage, output voltage, and capacitive load, the control loop can be optimized for a robust and stable operation and with an improved load transient response. This optimization will minimize the amount of required output decoupling capacitors for a given load transient requirement yielding an optimized cost and minimized board space. The optimization together with load step simulations can be made using the Flex Power Designer software. Dynamic Loop Compensation (DLC) Only some of the products that this specification covers have this feature (see section Ordering Information). The DLC feature might in some documents be referred to as “Auto Compensation” or “Auto Tuning” feature. The DLC feature measures the characteristics of the power train and calculates the proper compensator PID coefficients. 1/28701-BMR 464 Rev.B 51 July 2019 © Flex The default configuration is that once the output voltage ramp up has completed, the DLC algorithm will begin and a new optimized compensator solution (PID setting) will be found and implemented. The DLC algorithm typically takes between 50 ms and 200 ms to complete. By the PMBus command AUTO_COMP_CONFIG the user may select between several different modes of operation: • Disable • Autocomp once, will run DLC algorithm each time the output is enabled (default configuration) • Autocomp every second will initiate a new DLC algorithm each 1 second • Autocomp every minute will initiate a new DLC algorithm every minute. The DLC can also be configured to run once only after the first ramp up (after input power have been applied) and to use that temporary stored PID settings in all subsequent ramps. If input power is cycled a new DLC algorithm will be performed after the first ramp up. The default setting is however to run the DLC algorithm after every ramp up. The DLC algorithm can also be initiated manually by sending the AUTO_COMP_CONTROL command. The DLC can also be configured with Auto Comp Gain Control. This scales the DLC results to allow a trade-off between transient response and steady-state duty cycle jitter. A setting of 100% will provide the fastest transient response while a setting of 10% will produce the lowest jitter. The default is 50%. Changing DLC and PID Setting Some caution must be considered while DLC is enabled and when it is changed from enabled or disabled. When operating, the controller IC uses the settings loaded in its (volatile) RAM memory. When the input power is applied the RAM settings are retrieved from the pin-strap resistors and the two non-volatile memories (DEFAULT and USER). The sequence is described in the “Initialization Procedure” section. When DLC is enabled: When DLC is enabled, the normal sequence (after input power has been applied) that a value stored in the user non-volatile memory overwrites any previously loaded value does not apply for the PID setting (stored in the PID_TAPS register). The PID setting in the user non-volatile memory is ignored and a nonconfigurable default PID setting is loaded to RAM to act as a safe starting value for the DLC. Once the output has been enabled and the DLC algorithm has found a new optimized PID setting, it will be loaded in RAM and used by the control loop. When saving changes to the user non-volatile memory, all changes made to the content of RAM will be saved. This also includes the default PID setting (loaded to RAM to act as a safe starting value) or the PID setting changed by the DLC algorithm after enabling output. The result is that as long as DLC is enabled the PID setting in the user non-volatile memory is ignored, but it might accidentally get overwritten. When changing DLC from disabled to enabled: A non-configurable default PID setting is loaded to RAM to act as a safe starting value for the DLC (same as above). Technical Specification BMR46 series PoL Regulators Input 4.5-14 V, Output up to 50 A / 165 W When changing DLC from enabled to disabled: When changing DLC from enabled to disabled, the PID setting in the user non-volatile memory will be loaded to RAM. Any new optimized PID setting in RAM will be lost, if not first stored to the user non-volatile memory. When DLC is disabled: When DLC is disabled and input power has been applied, the PID setting in the user non-volatile memory will be loaded to RAM and used in the control loop. The original PID setting in the user non-volatile memory is quite slow and not recommended for optimal performance. If DLC is disabled it is recommended to either: 1. Use the DLC to find optimized PID setting. 2. Use Flex Power Designer to find appropriate PID setting. 3. Use Universal PID as defined below. The Universal PID setting (taps) is: A = 3289.56, B = -6248.12, C = 2964.06 Write 0x7CB941FDC3417CCD99 to PID_TAPS register and write command STORE_USER_ALL Note that if DLC is enabled, for best results VI must be stable before DLC algorithm begins. Load Transient Response Optimization The product incorporates a Non-Linear transient Response, NLR, loop that decreases the response time and the output voltage deviation during a load transient. The NLR results in a higher equivalent loop bandwidth than is possible using a traditional linear control loop. The product is pre-configured with appropriate NLR settings for robust and stable operation for a wide range of input voltage and a capacitive load range as defined in the section External Decoupling Capacitors. For an application with a specific input voltage, output voltage, and capacitive load, the NLR configuration can be optimized for a robust and stable operation and with an improved load transient response. This will also reduce the amount of output decoupling capacitors and yield a reduced cost. However, the NLR slightly reduces the efficiency. In order to obtain maximal energy efficiency the load transient requirement has to be met by the standard control loop compensation and the decoupling capacitors. The NLR settings can be reconfigured using the PMBus interface. See application note AN306 for further information. Remote Sense The product has remote sense that can be used to compensate for voltage drops between the output and the point of load. The sense traces should be located close to the PWB ground layer to reduce noise susceptibility. Due to derating of internal output capacitance the voltage drop should be kept below VDROPMAX  (5.5  VO ) / 2 . A large voltage drop will impact the electrical performance of the regulator. If the remote sense is not needed, +S should be connected to VOUT 1/28701-BMR 464 Rev.B 52 July 2019 © Flex and −S should be connected to GND. Output Voltage Adjust using Pin-strap Resistor Using an external Pin-strap resistor, RSET, the output voltage can be set in the VSET range 0.6 V to 3.3 V at 28 RSET different levels shown in the PREF table below. The resistor should be applied between the VSET pin and the PREF pin. RSET also sets the maximum output voltage, see section “Output Voltage Range Limitation”. The resistor is sensed only during product start-up. Changing the resistor value during normal operation will not change the output voltage. The input voltage must be at least 1 V larger than the output voltage in order to deliver the correct output voltage. See Ordering Information for output voltage range. The following table shows recommended resistor values for RSET. Maximum 1% tolerance resistors are required. VO [V] RSET[kΩ] VO [V] RSET[kΩ] 0.60 10 1.50 46.4 0.65 11 1.60 51.1 0.70 12.1 1.70 56.2 0.75 13.3 1.80 61.9 0.80 14.7 1.90 68.1 0.85 16.2 2.00 75 0.90 17.8 2.10 82.5 0.95 19.6 2.20 90.9 1.00 21.5 2.30 100 1.05 23.7 2.50 110 1.10 26.1 3.00 121 1.15 28.7 3.30 133 1.20 31.6 1.25 34.8 1.30 38.3 1.40 42.2 The output voltage and the maximum output voltage can be pin strapped to three fixed values by connecting the VSET pin according to the table below. VO [V] 0.60 1.2 2.5 VSET Shorted to PREF Open “high impedance” Logic High, GND as reference Technical Specification 53 BMR46 series PoL Regulators Input 4.5-14 V, Output up to 50 A / 165 W 1/28701-BMR 464 Rev.B Output Voltage Adjust using PMBus The output voltage set by pin-strap can be overridden by configuration file or by using a PMBus command. See Electrical Specification for adjustment range. Over Voltage Protection (OVP) The product includes over voltage limiting circuitry for protection of the load. The default OVP limit is 15% above the nominal output voltage. If the output voltage exceeds the OVP limit, the product can respond in different ways: When setting the output voltage by configuration file or by a PMBus command, the specified output voltage accuracy is valid only when the set output voltage level falls within the same bin range as the voltage level defined by the pin-strap resistor RSET. The applicable bin ranges are defined in the table below. Valid accuracy for voltage levels outside the applicable bin range is two times the specified. Example: Nominal VO is set to 1.10 V by RSET = 26.1 kΩ. 1.10 V falls within the bin range 0.988-1.383 V, thus specified accuracy is valid when adjusting VO within 0.988-1.383V. VO bin ranges [V] 0.600 – 0.988 0.988 – 1.383 1.383 – 1.975 1.975 – 2.398 2.398 – 2.963 2.963 – 3.753 For parallel operation, see application notes AN307. Output Voltage Range Limitation The output voltage range that is possible to set by configuration or by the PMBus interface is limited by the pinstrap resistor RSET. The maximum output voltage is set to 110% of the nominal output value defined by RSET, VO, MAX  1.1 VO, RSET . This protects the load from an over voltage due to an accidental wrong PMBus command. Output Voltage Adjust Limitation using PMBus In addition to the maximum output voltage limitation by the pinstrap resistor RSET, there is also a limitation in how much the output voltage can be increased while the output is enabled. If output is disabled then RSET resistor is the only limitation. Example: If the output is enabled with output voltage set to 1.0 V, then it is only possible to adjust/change the output voltage up to 1.7V as long as the output is enabled. VO setting when enabled [V] VO set range while enabled [V] 0.000 – 0.988 ~0.2 to >1.2 0.988 – 1.383 ~0.2 to >1.7 1.383 – 1.975 ~0.2 to >2.5 1.975 – 2.398 ~0.2 to >2.97 2.398 – 2.963 ~0.2 to >3.68 2.963 – 3.753 ~0.2 to >4.65 July 2019 © Flex 1. Initiate an immediate shutdown until the fault has been cleared. The user can select a specific number of retry attempts. 2. Turn off the high-side MOSFET and turn on the low-side MOSFET. The low-side MOSFET remains ON until the device attempts a restart, i.e. the output voltage is pulled to ground level (crowbar function). The default response from an overvoltage fault is to immediately shut down as in 2. The device will continuously check for the presence of the fault condition, and when the fault condition no longer exists the device will be re-enabled. For continuous OVP when operating from an external clock for synchronization, the only allowed response is an immediate shutdown. The OVP limit and fault response can be reconfigured using the PMBus interface. Under Voltage Protection (UVP) The product includes output under voltage limiting circuitry for protection of the load. The default UVP limit is 15% below the nominal output voltage. The UVP limit can be reconfigured using the PMBus interface. Power Good The product provides a Power Good (PG) flag in the Status Word register that indicates the output voltage is within a specified tolerance of its target level and no fault condition exists. If specified in section Connections, the product also provides a PG signal output. The PG pin is active high and by default open-drain but may also be configured as push-pull via the PMBus interface. By default, the PG signal will be asserted when the output reaches above 90% of the nominal voltage, and de-asserted when the output falls below 85% of the nominal voltage. These limits may be changed via the PMBus interface. A PG delay period is defined as the time from when all conditions within the product for asserting PG are met to when the PG signal is actually asserted. The default PG delay is set to 10 ms. This value can be reconfigured using the PMBus interface. For products with DLC the PG signal is by default asserted directly after the DLC operation have been completed. If DLC is disabled the configured PG delay will be used. This can be reconfigured using the PMBus interface. Switching Frequency The fundamental switching frequency is 320 kHz, which yields optimal power efficiency. The switching frequency can be set to any value between 200 kHz and 640 kHz using the PMBus interface. The switching frequency will change the efficiency/power dissipation, load transient response and output ripple. For optimal control loop performance in a product without DLC, the control loop must be re-optimized when changing the switching frequency. Technical Specification BMR46 series PoL Regulators Input 4.5-14 V, Output up to 50 A / 165 W Synchronization Synchronization is a feature that allows multiple products to be synchronized to a common frequency. Synchronized products powered from the same bus eliminate beat frequencies reflected back to the input supply, and also reduces EMI filtering requirements. Eliminating the slow beat frequencies (usually
BMR4641002/001 价格&库存
很抱歉,暂时无法提供与“BMR4641002/001”相匹配的价格&库存,您可以联系我们找货
