SCT2A26STER
SCT2A26STER
    SCT(芯洲科技)
    ESOP8_150MIL
    DC-DC电源芯片 VIN=5.5V~100V VOUT=30V 4A ESOP8
SCT2A26STER 数据手册
芯 洲 科 SCT2A26 技 Silicon Content Technology Rev.1.0 5.5V-100V Vin, 4A Peak Current Limit, High Efficiency Asynchronous Step-down DCDC Converter FEATURES DESCRIPTION           The SCT2A26 is an asynchronous buck converter with wide input voltage ranging from 5.5V to 100V which accommodates a variety of step-down applications, making it ideal for automotive, industry, and lighting applications. The SCT2A26 integrates an 500mΩ highside MOSFET and has 4A peak output current limit to support high peak current application in GPS tracker with 4G Module. Wide Input Range: 5.5V-100V Maximum Output Voltage: 30V 2A Continuous Output Current 4A Peak Current Limit Integrated 500mΩ High-Side Power MOSFET 140uA Quiescent Current 1.2V ±1% Feedback Reference Voltage 4ms Internal Soft-start Time Fixed Switching Frequency at 300KHz COT Control Mode with Integrated Loop Compensation Precision Enable Threshold for Programmable Input Voltage Under-voltage Lock Out Protection (UVLO) Threshold and Hysteresis Cycle-by-Cycle Current Limiting Over-Voltage Protection Over-Temperature Protection Available in an ESOP-8 Package      APPLICATIONS     The SCT2A26, adopting the constant-on time (COT) mode control with integrated loop compensation greatly simplifies the converter off-chip configuration. The SCT2A26 features Pulse Frequency Modulation (PFM) mode at light load with typical 140uA low quiescent current, which enables the converter to achieve the high-power efficiency during light-load or no-load conditions. The SCT2A26 offers cycle-by-cycle current limit, thermal shutdown protection, output over-voltage protection and input voltage under-voltage protection. The device is available in an 8-pin thermally enhanced SOP-8 package. GPS Tracker E-bike, Scooter Moto Drives, Drones 48V Industry Power Bus System TYPICAL APPLICATION 100 GND 90 SW 80 VIN BST Efficiency(%) VIN SCT2A26 ON/OFF EN NC TM FB 70 60 50 24VIN 12VOUT 40 36VIN 12VOUT 30 48VIN 12VOUT 20 60VIN 12VOUT 10 0 0.001 72VIN 12VOUT 0.01 Iout(A) 0.1 1 Efficiency, Vout=12V For more information www.silicontent.com © 2022 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2A26 1 SCT2A26 REVISION HISTORY NOTE: Page numbers for previous revisions may differ from page numbers in the current version. Revision 0.8: Sampling DEVICE ORDER INFORMATION PART NUMBER PACKAGE MARKING PACKAGE DISCRIPTION SCT2A26STE 2A26 8-Lead Plastic ESOP 1)For Tape & Reel, Add Suffix R (e.g. SCT2A26STER). ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION Over operating free-air temperature unless otherwise DESCRIPTION MIN noted(1) MAX UNIT VIN -0.3 110 V BST -0.3 116 V SW -1 110 V BST-SW -0.3 6 V EN, FB, TM -0.3 6 V Operating junction temperature TJ(2) -40 150 °C Storage temperature TSTG -65 150 °C (1) (2) GND 1 VIN 2 EN 3 NC 4 Thermal PAD 9 8 SW 7 BST 6 TM 5 FB Figure 1. 8-Lead Plastic E-SOP Stresses beyond those listed under Absolute Maximum Rating may cause device permanent damage. The device is not guaranteed to function outside of its Recommended Operation Conditions. The IC includes over temperature protection to protect the device during overload conditions. Junction temperature will exceed 150°C when over temperature protection is active. Continuous operation above the specified maximum operating junction temperature will reduce lifetime. PIN FUNCTIONS NAME NO. GND 1 VIN 2 EN 3 NC 2 FB 5 TM 6 BST 7 SW 8 Thermal Pad 9 2 PIN FUNCTION Ground Input supply voltage. Connect a local bypass capacitor from VIN pin to GND pin. Path from VIN pin to high frequency bypass capacitor and GND must be as short as possible. Enable pin to the regulator with internal pull-up current source. Pull below 1.23V to disable the converter. Floating to enable the converter. Not Connection. Inverting input of the comparator. The tap of external feedback resistor divider from the output to GND sets the output voltage. The device regulates FB voltage to the internal reference value of 1.2V typical. Test mode pin for factory use only. Connect TM to EN pin, ground or leave floating. Power supply bias for high-side power MOSFET gate driver. Connect a 0.1uF capacitor from BOOT pin to SW pin. Bootstrap capacitor is charged when low-side power MOSFET is on or SW voltage is low. Regulator switching output. Connect SW to an external power inductor Heat dissipation path of die. Electrically connection to GND pin. Must be connected to ground plane on PCB for proper operation and optimized thermal performance. For more information www.silicontent.com © 2022 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2A26 SCT2A26 RECOMMENDED OPERATING CONDITIONS Over operating free-air temperature range unless otherwise noted PARAMETER DEFINITION VIN VOUT TJ Input voltage range Output voltage range Operating junction temperature MIN MAX UNIT 5.5 1.2 -40 100 30 150 V V °C MIN MAX UNIT -1 +1 kV -1 +1 kV ESD RATINGS PARAMETER VESD DEFINITION Human Body Model(HBM), per ANSI-JEDEC-JS-001-2014 specification, all pins(1) Charged Device Model(CDM), per ANSI-JEDEC-JS-0022014 specification, all pins(2) (1) JEDEC document JEP155 states that 500V HBM allows safe manufacturing with a standard ESD control process. (2) JEDEC document JEP157 states that 250V CDM allows safe manufacturing with a standard ESD control process. THERMAL INFORMATION PARAMETER RθJA RθJC THERMAL METRIC Junction to ambient thermal resistance(1) Junction to case thermal resistance(1) ESOP-8L 42 45.8 UNIT °C/W (1) SCT provides RθJA and RθJC numbers only as reference to estimate junction temperatures of the devices. RθJA and RθJC are not a characteristic of package itself, but of many other system level characteristics such as the design and layout of the printed circuit board (PCB) on which the SCT2A26 is mounted, thermal pad size, and external environmental factors. The PCB board is a heat sink that is soldered to the leads and thermal pad of the SCT2A26. Changing the design or configuration of the PCB board changes the efficiency of the heat sink and therefore the actual RθJA and RθJC. For more information www.silicontent.com © 2022 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2A26 3 SCT2A26 ELECTRICAL CHARACTERISTICS VIN=48V, TJ=-40°C~125°C, typical value is tested under 25°C. SYMBOL PARAMETER TEST CONDITION Power Supply VIN Operating input voltage VIN rising Hysteresis Shutdown current from VIN pin Quiescent current from VIN pin ISHDN IQ TYP 5.5 VIN UVLO Threshold VUVLO MIN Power MOSFETs High-side MOSFET onRDSON_H resistance 4.7 5 MAX UNIT 100 V 5.3 V 440 mV EN=0, no load 4.2 10 μA EN floating, no load, non- switching, BOOT-SW=5V 140 240 μA VBOOT-VSW=5V 500 950 mΩ 1.2 1.212 Reference and Control Loop VREF Reference voltage of FB 1.188 Enable and Soft-startup VEN_H Enable high threshold V 1.25 V IEN_L Enable pin pull-up current EN=0V 0.3 uA IEN_H Enable pin pull-up current Enable pin pull-up current hysteresis Internal soft start time EN=1.5V 2.1 μA 1.8 uA 4 ms IEN_Hys Tss Switching Frequency Timing FSW Switching frequency TOFF_MIN Minimum off-time 260 300 340 kHz 200 260 ns A Current Limit and Over Current Protection ILIM HS MOSFET current limit TJ=25°C 3.5 4 4.5 TJ=-40°C~125°C 3.3 4 4.7 Protection VOVP TSD Feedback overvoltage with respect to reference voltage Thermal shutdown threshold* VFB/VREF rising 120 % VFB/VREF falling TJ rising Hysteresis 115 160 23 % °C °C *Derived from bench characterization 4 For more information www.silicontent.com © 2022 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2A26 SCT2A26 100 100 90 90 80 80 70 70 Efficiency(%) Efficiency(%) TYPICAL CHARACTERISTICS 60 50 24VIN 12VOUT 40 36VIN 12VOUT 30 48VIN 12VOUT 20 60VIN 12VOUT 10 0.01 Iout(A) 0.1 12VIN 5VOUT 40 24VIN 5VOUT 30 36VIN 5VOUT 20 48VIN 5VOUT 60VIN 5VOUT 1 5 4.99 12.06 4.98 12.04 4.97 12.02 4.96 Vout(V) 12.1 12 11.98 VIN=24V 1 4.95 4.94 VIN=24V VIN=36V VIN=48V 4.91 VIN=60V 11.9 0.1 4.92 VIN=48V 11.92 Iout(A) 4.93 VIN=36V 11.94 0.01 Figure 3. Efficiency vs Load Current, Vout=5V 12.08 11.96 72VIN 5VOUT 0 0.001 Figure 2. Efficiency vs Load Current, Vout=12V Vout(V) 50 10 72VIN 12VOUT 0 0.001 60 VIN=60V 4.9 0 0.5 1 1.5 2 0 0.5 Iout(A) 1 1.5 2 Iout(A) Figure 4. Load Regulation, Vout=12V Figure 5. Load Regulation, Vout=5V 12.07 330 325 12.05 320 Fsw(KHz) Vout(V) 12.03 12.01 11.99 315 310 305 300 295 290 11.97 285 11.95 280 10 20 30 40 50 60 70 80 90 100 20 Vin(V) 40 60 80 100 Vin(V) Figure 6. Line Regulation, Vout=12V Figure 7. Switching Frequency vs Vin, Vout=5V For more information www.silicontent.com © 2022 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2A26 5 SCT2A26 FUNCTIONAL BLOCK DIAGRAM VIN 0.3uA 2.1uA Thermal Shutdown + EN EN LOGIC VIN UVLO Reference 1.25V VREF VCC Boot Charge Current Limit and Off Timer Soft-start Timer BST DC Error Correction 1.2V Boot UVLO PWM + + FB Q1 Ramp Compensation + Control Logic SW OVP 120%VREF VCC On-Time Generator TM GND Figure 8. Functional Block Diagram 6 For more information www.silicontent.com © 2022 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2A26 SCT2A26 OPERATION Overview The SCT2A26 is a 5.5V-100V input, 4A peak current limit, Step-down DCDC converter with built-in 500mΩ highside power MOSFET. It implements constant on time control to regulate output voltage, providing excellent line and load transient response, and internal error amplifier integrated improve the line and load regulation. The SCT2A26 features an internal 4ms soft-start time to avoid large inrush current and output voltage overshoot during startup. The switching frequency is fixed at 300KHz. The device also supports monolithic startup with prebiased output condition. The SCT2A26 has a default input start-up voltage of 5V with 440mV hysteresis. The EN pin has a precision threshold that can be used to adjust the input voltage lockout thresholds with two external resistors to meet accurate higher UVLO system requirements. Floating EN pin enables the device with the internal pull-up current to the pin. The SCT2A26 full protection features include the VIN input under-voltage lockout, the output over-voltage protection, over current protection with cycle-by-cycle current limit, output hard short protection and thermal shutdown protection. Constant On-Time Mode Control The SCT2A26 employs constant on-time (COT) Mode control providing fast transient with pseudo fixed switching frequency. At the beginning of each switching cycle, since the feedback voltage (VFB) is lower than the internal reference voltage (VREF), the high-side MOSFET (Q1) is turned on during one on-time and the inductor current rises to charge up the output voltage. The on-time is determined by the input voltage and output voltage. After the on-time, the high-side MOSFET (Q1) turns off. The inductor current drops and the output capacitors are discharged. When the output voltage decreases and the VFB decreased below the VREF or SS, the Q1 turns on again after another dead time duration. This repeats on cycle-by-cycle. The SCT2A26 works with an internal compensation, so customer could use the device easily. Feedforward cap Cf is necessary to provide flexibility for optimizing the loop stability and transient response. Enable and Under Voltage Lockout Threshold The SCT2A26 is enabled when the VIN pin voltage rises above 5V and the EN pin voltage exceeds the enable threshold of 1.24V. The device is disabled when the VIN pin voltage falls below 4.56V or when the EN pin voltage is below 1.23V. Internal pull up current source to EN pin allows the device enable when EN pin floats. For a higher system UVLO threshold, connect an external resistor divider (R3 and R4) shown in Figure 9 from VIN to EN. The UVLO rising and falling threshold can be calculated by Equation 1 and Equation 2 respectively. 𝑉𝐼𝑁𝑟𝑖𝑠𝑒 = 𝑉𝐸𝑁_𝐻 ∗ 𝑅3 + 𝑅4 𝑅4 (1) VIN I2 2.1 uA I1 0.3uA (2) 𝑉𝐼𝑁_ℎ𝑦𝑠 = 𝐼2 ∗ 𝑅3 R3 Where EN VIN_rise: Vin rise threshold to enable the device VIN_hys: Vin hysteresis threshold + EN 1.25V R4 I2=2.1uA VEN_H=1.25V Figure 9. System UVLO by enable divide For more information www.silicontent.com © 2022 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2A26 7 SCT2A26 Output Voltage The SCT2A26 regulates the internal reference voltage at 1.2V with 1% tolerance over the operating temperature and voltage range. The output voltage is set by a resistor divider from the output node to the FB pin. It is recommended to use 1% tolerance or better resistors. Use Equation 3 to calculate resistance of resistor dividers. To improve efficiency at light loads, larger value resistors are recommended. However, if the values are too high, the regulator will be more susceptible to noise affecting output voltage accuracy. 𝑉𝑂𝑈𝑇 𝑅𝐹𝐵_𝑇𝑂𝑃 = ( − 1) ∗ 𝑅𝐹𝐵_𝐵𝑂𝑇 𝑉𝑅𝐸𝐹 (3) where  RFB_TOP is the resistor connecting the output to the FB pin.  RFB_BOT is the resistor connecting the FB pin to the ground. Internal Soft-Start The SCT2A26 integrates an internal soft-start circuit that ramps the reference voltage from zero volts to 1.2V reference voltage in 4ms. If the EN pin is pulled below 1.23V, switching stops and the internal soft-start resets. The soft-start also resets during shutdown due to thermal overloading. Bootstrap Voltage Regulator An external bootstrap capacitor between BOOT pin and SW pin powers the floating gate driver to high-side power MOSFET. The bootstrap capacitor voltage is charged from an integrated voltage regulator when high-side power MOSFET is off and low-side power MOSFET is on. The UVLO of high-side MOSFET gate driver has rising threshold of 2.95V and hysteresis of 250mV. When the device operates with high duty cycle or extremely light load, bootstrap capacitor may be not recharged in considerable long time. The voltage at bootstrap capacitor is insufficient to drive high-side MOSFET fully on. When the voltage across bootstrap capacitor drops below 2.7V, BOOT UVLO occurs. The converter forces turning on an integrated low-side MOSFET periodically to refresh the voltage of bootstrap capacitor to guarantee the converter’s operation over a wide duty range. Over Current Limit The inductor current is monitored during high-side FET turn on. The SCT2A26 implements over current protection with cycle-by-cycle limiting high-side MOSFET peak current during unexpected overload or output hard short. SCT2A26 also provide a HS current limit off timer for making the IC safer when trigger over current condition. Once trigger HS over current, the present on-time period is immediately terminated to avoid the inductor current run away. The length of off time is controlled by FB voltage and VIN voltage and could be calculated by the following equation. 𝑉𝐼𝑁 𝑇𝑜𝑓𝑓 = 1.5 ∗ ( ) 𝑢𝑠 20 ∗ 𝑉𝐹𝐵 + 4.35 (4) Over voltage Protection The SCT2A26 implements the Over-voltage Protection OVP circuitry to minimize output voltage overshoot during load transient, recovering from output fault condition or light load transient. The overvoltage comparator in OVP circuit compares the FB pin voltage to the internal reference voltage. When FB voltage exceeds 120% of internal 1.2V reference voltage, the high-side MOSFET turns off to avoid output voltage continue to increase. When the FB pin voltage falls below 115% of the 1.2V reference voltage, the high-side MOSFET can turn on again. Thermal Shutdown The SCT2A26 protects the device from the damage during excessive heat and power dissipation conditions. Once the junction temperature exceeds 160°C, the internal thermal sensor stops power MOSFETs switching. When the junction temperature falls below 137°C, the device restarts with internal soft start phase. 8 For more information www.silicontent.com © 2022 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2A26 SCT2A26 APPLICATION INFORMATION Typical application L1 68uH VOUT=12V IOUT= 2A GND C1 10uF SW C2 0.1uF C3 0.1uF VIN VIN=5.5~100V D1 100V/5A BST C4 44uF R2 271K C5 150pF SCT2A26 ON/OFF EN TM NC FB R3 5K R1 30K Figure 10. SCT2A26 Design Example, 12V Output with Programmable UVLO Design Parameters Design Parameters Example Value Input Voltage 48V Normal, 24V to 100V Output Voltage 12V Maximum Output Current 2A Switching Frequency 300 KHz Output voltage ripple (peak to peak) 15mV Transient Response 0.2A to 1.8A load step ∆Vout = 100mV Transient Response 0.75A to 1.25A load step ∆Vout = 50mV For more information www.silicontent.com © 2022 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2A26 9 SCT2A26 Output Voltage The output voltage is set by an external resistor divider R1 and R2 in typical application schematic. Recommended R1 resistance is 30KΩ. Use equation 5 to calculate R2. 𝑉𝑂𝑈𝑇 𝑅2 = ( − 1) ∗ 𝑅1 𝑉𝑅𝐸𝐹 where:  Table 1. R1, R2Value for Common Output Voltage (Room Temperature) (5) VOUT R2 R1 5 V 95 KΩ 30 KΩ 12 V 271 KΩ 30 KΩ 24V 191 KΩ 10 KΩ VREF is the feedback reference voltage of 1.2V Under Voltage Lock-Out An external voltage divider network of R3 from the input to EN pin and R4 from EN pin to the ground can set the input voltage’s Under Voltage Lock-Out (UVLO) threshold. The UVLO has two thresholds, one for power up when the input voltage is rising and the other for power down or brown outs when the input voltage is falling. For the example design, the supply should turn on and start switching once the input voltage increases above 15V (start or enable). After the regulator starts switching, it should continue to do so until the input voltage falls below 14V (stop or disable). Use Equation 6 and Equation 7 to calculate the values 464 kΩ and 42.2 kΩ of R3 and R4 resistors. 𝑉𝐼𝑁𝑟𝑖𝑠𝑒 = 𝑉𝐸𝑁_𝐻 ∗ 𝑅3 + 𝑅4 𝑅4 VIN (6) I2 2.1uA I1 0.3uA (7) 𝑉𝐼𝑁_ℎ𝑦𝑠 = 𝐼2 ∗ 𝑅3 R3 Where EN VIN_rise: Vin rise threshold to enable the device VIN_hys: Vin hysteresis threshold + EN 1.25V R4 I2=2.1uA VEN_H=1.25V Figure 11. System UVLO by enable divide Inductor Selection There are several factors should be considered in selecting inductor such as inductance, saturation current, the RMS current and DC resistance(DCR). Larger inductance results in less inductor current ripple and therefore leads to lower output voltage ripple. However, the larger value inductor always corresponds to a bigger physical size, higher series resistance, and lower saturation current. A good rule for determining the inductance to use is to allow the inductor peak-to-peak ripple current to be approximately 20%~40% of the maximum output current. The peak-to-peak ripple current in the inductor ILPP can be calculated as in Equation 8. 𝐼𝐿𝑃𝑃 = 10 𝑉𝑂𝑈𝑇 ∗ (𝑉𝐼𝑁 − 𝑉𝑂𝑈𝑇 ) 𝑉𝐼𝑁 ∗ 𝐿 ∗ 𝑓𝑆𝑊 (8) For more information www.silicontent.com © 2022 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2A26 SCT2A26 Where      ILPP is the inductor peak-to-peak current L is the inductance of inductor fSW is the switching frequency VOUT is the output voltage VIN is the input voltage Since the inductor-current ripple increases with the input voltage, so the maximum input voltage in application is always used to calculate the minimum inductance required. Use Equation 9 to calculate the inductance value. 𝐿𝑀𝐼𝑁 = Where       𝑉𝑂𝑈𝑇 𝑉𝑂𝑈𝑇 ∗ (1 − ) 𝑓𝑆𝑊 ∗ 𝐿𝐼𝑅 ∗ 𝐼𝑂𝑈𝑇(𝑚𝑎𝑥) 𝑉𝐼𝑁(𝑚𝑎𝑥) (9) LMIN is the minimum inductance required fsw is the switching frequency VOUT is the output voltage VIN(max) is the maximum input voltage IOUT(max) is the maximum DC load current LIR is coefficient of ILPP to IOUT The total current flowing through the inductor is the inductor ripple current plus the output current. When selecting an inductor, choose its rated current especially the saturation current larger than its peak operation current and RMS current also not be exceeded. Therefore, the peak switching current of inductor, ILPEAK and ILRMS can be calculated as in equation 10 and equation 11. 𝐼𝐿𝑃𝐸𝐴𝐾 = 𝐼𝑂𝑈𝑇 + 𝐼𝐿𝑃𝑃 2 𝐼𝐿𝑅𝑀𝑆 = √(𝐼𝑂𝑈𝑇 )2 + Where     (10) 1 ∗ (𝐼𝐿𝑃𝑃 )2 12 (11) ILPEAK is the inductor peak current IOUT is the DC load current ILPP is the inductor peak-to-peak current ILRMS is the inductor RMS current In overloading or load transient conditions, the inductor peak current can increase up to the switch current limit of the device which is typically 4A. The most conservative approach is to choose an inductor with a saturation current rating greater than 4A. Because of the maximum ILPEAK limited by device, the maximum output current that the SCT2A26 can deliver also depends on the inductor current ripple. Thus, the maximum desired output current also affects the selection of inductance. The smaller inductor results in larger inductor current ripple leading to a lower maximum output current. Diode Selection The SCT2A26 requires an external catch diode between the SW pin and GND. The selected diode must have a reverse voltage rating equal to or greater than VIN(max). The peak current rating of the diode must be greater than the maximum inductor current. Schottky diodes are typically a good choice for the catch diode due to their low forward voltage. The lower the forward voltage of the diode, the higher the efficiency of the regulator. Typically, diodes with higher voltage and current ratings have higher forward voltages. A diode with a minimum of 100-V reverse voltage is preferred to allow input voltage transients up to the rated voltage of the SCT2A26. For more information www.silicontent.com © 2022 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2A26 11 SCT2A26 For the example design, the SS510 Schottky diode is selected for its lower forward voltage and good thermal characteristics compared to smaller devices. The typical forward voltage of the SS510 is 0.7 volts at 5 A. The diode must also be selected with an appropriate power rating. The diode conducts the output current during the off-time of the internal power switch. The off-time of the internal switch is a function of the maximum input voltage, the output voltage, and the switching frequency. The output current during the off-time is multiplied by the forward voltage of the diode to calculate the instantaneous conduction losses of the diode. At higher switching frequencies, the ac losses of the diode need to be taken into account. The ac losses of the diode are due to the charging and discharging of the junction capacitance and reverse recovery charge. Equation 12 is used to calculate the total power dissipation, including conduction losses and ac losses of the diode. The SS510 diode has a junction capacitance of 300 pF. Using Equation 12, the total loss in the diode at the maximum input voltage is 1.24 W. If the power supply spends a significant amount of time at light load currents or in sleep mode, consider using a diode which has a low leakage current and slightly higher forward voltage drop. 𝑃𝐷 = (𝑉𝐼𝑁_𝑀𝐴𝑋 − 𝑉𝑂𝑈𝑇 ) × 𝐼𝑂𝑈𝑇 × 𝑉𝑑 𝐶𝑗 × 𝑓𝑆𝑊 × (𝑉𝐼𝑁 + 𝑉𝑑 )2 + 𝑉𝐼𝑁_𝑀𝐴𝑋 2 (12) Input Capacitor Selection The input current to the step-down DCDC converter is discontinuous, therefore it requires a capacitor to supply the AC current to the step-down DCDC converter while maintaining the DC input voltage. Use capacitors with low ESR for better performance. Ceramic capacitors with X5R or X7R dielectrics are usually suggested because of their low ESR and small temperature coefficients, and it is strongly recommended to use another lower value capacitor (e.g. 0.1uF) with small package size (0603) to filter high frequency switching noise. Place the small size capacitor as close to VIN and GND pins as possible. The voltage rating of the input capacitor must be greater than the maximum input voltage. And the capacitor must also have a ripple current rating greater than the maximum input current ripple. The RMS current in the input capacitor can be calculated using Equation 13. ICINRMS = IOUT ∗ √ VOUT VOUT ∗ (1 − ) VIN VIN (13) The worst case condition occurs at VIN=2*VOUT, where: (14) ICINRMS = 0.5 ∗ IOUT For simplification, choose an input capacitor with an RMS current rating greater than half of the maximum load current. When selecting ceramic capacitors, it needs to consider the effective value of a capacitor decreasing as the DC bias voltage across a capacitor increasing. The input capacitance value determines the input ripple voltage of the regulator. The input voltage ripple can be calculated using Equation 15 and the maximum input voltage ripple occurs at 50% duty cycle. ∆VIN = IOUT VOUT VOUT ∗ ∗ (1 − ) fSW ∗ CIN VIN VIN (15) For this example, two 2.2μF, X7R ceramic capacitors rated for 100 V in parallel are used. And a 0.1 μF for highfrequency filtering capacitor is placed as close as possible to the device pins. Bootstrap Capacitor Selection 12 For more information www.silicontent.com © 2022 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2A26 SCT2A26 A 0.1μF ceramic capacitor must be connected between BOOT pin and SW pin for proper operation. A ceramic capacitor with X5R or better grade dielectric is recommended. The capacitor should have a 10V or higher voltage rating. Output Capacitor Selection The selection of output capacitor will affect output voltage ripple in steady state and load transient performance. The output ripple is essentially composed of two parts. One is caused by the inductor current ripple going through the Equivalent Series Resistance ESR of the output capacitors and the other is caused by the inductor current ripple charging and discharging the output capacitors. To achieve small output voltage ripple, choose a low-ESR output capacitor like ceramic capacitor. For ceramic capacitors, the capacitance dominates the output ripple. For simplification, the output voltage ripple can be estimated by Equation 16 desired. ∆VOUT = Where       𝑉𝑂𝑈𝑇 ∗ (𝑉𝐼𝑁 − 𝑉𝑂𝑈𝑇 ) (16) 8 ∗ 𝑓𝑆𝑊 2 ∗ 𝐿 ∗ 𝐶𝑂𝑈𝑇 ∗ 𝑉𝐼𝑁 ΔVOUT is the output voltage ripple fSW is the switching frequency L is the inductance of inductor COUT is the output capacitance VOUT is the output voltage VINis the input voltage Due to capacitor’s degrading under DC bias, the bias voltage can significantly reduce capacitance. Ceramic capacitors can lose most of their capacitance at rated voltage. Therefore, leave margin on the voltage rating to ensure adequate effective capacitance. Typically, two 22μF ceramic output capacitors work for most applications. Table 2 lists typical values of external components for some standard output voltages. Table 2: Component List with Typical Output Voltage BOM list Vout L1 COUT R2 R1 C5 5V 33uH 2*22uF 95K 30K 68pF 12V 68uH 2*22uF 271K 30K 150pF 24V 100uH 2*22uF 191k 10K 150pF For more information www.silicontent.com © 2022 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2A26 13 SCT2A26 Application Waveforms Vin=48V, Vout=12V, unless otherwise noted 14 Figure 12. Power up (Iload=2A) Figure 13. Power down (Iload=2A) Figure 14. EN toggle (Iload=2A) Figure 15. EN toggle (Iload=10mA) Figure 16. Over Current Protection Figure 17. Over Current Release For more information www.silicontent.com © 2022 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2A26 SCT2A26 Application Waveforms(Continued) Vin=48V, Vout=12V, unless otherwise noted Figure 18. Load Transient (0.2A-1.8A, 1.6A/us) Figure 19. Load Transient (0.75A-1.25A, 1.6A/us) Figure 20. Output Ripple (Iload=0A) Figure 21. Output Ripple (Iload=0.1A) Figure 22. Output Ripple (Iload=2A) Figure 23. Thermal, 48VIN, 12Vout,2A For more information www.silicontent.com © 2022 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2A26 15 SCT2A26 Layout Guideline Proper PCB layout is a critical for SCT2A26’s stable and efficient operation. The traces conducting fast switching currents or voltages are easy to interact with stray inductance and parasitic capacitance to generate noise and degrade performance. For better results, follow these guidelines as below: 1. Power grounding scheme is very critical because of carrying power, thermal, and glitch/bouncing noise associated with clock frequency. The thumb of rule is to make ground trace lowest impendence and power are distributed evenly on PCB. Sufficiently placing ground area will optimize thermal and not causing over heat area. 2. Place a low ESR ceramic capacitor as close to VIN pin and the ground as possible to reduce parasitic effect. 3. For operation at full rated load, the top side ground area must provide adequate heat dissipating area. Make sure top switching loop with power have lower impendence of grounding. 4. The bottom layer is a large ground plane connected to the ground plane on top layer by vias. The power pad should be connected to bottom PCB ground planes using multiple vias directly under the IC. The center thermal pad should always be soldered to the board for mechanical strength and reliability, using multiple thermal vias underneath the thermal pad. Improper soldering thermal pad to ground plate on PCB will cause SW higher ringing and overshoot besides downgrading thermal performance. It is recommended 8mil diameter drill holes of thermal vias, but a smaller via offers less risk of solder volume loss. On applications where solder volume loss thru the vias is of concern, plugging or tenting can be used to achieve a repeatable process. 5. Output inductor should be placed close to the SW pin. The area of the PCB conductor minimized to prevent excessive capacitive coupling. 6. Route BST capacitor trace on the bottom layer to provide wide path for topside ground. VOUT Inductor Output capacitors GND Top layer ground area 1 GND Input bypass capacitor SW VIN VIN BST Programmable UVLO resistors EN TM BST Capacitor Thermal VIA NC FB Feedback resistors GND Top layer ground area Figure 24. PCB Layout Example 16 For more information www.silicontent.com © 2022 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2A26 SCT2A26 PACKAGE INFORMATION ESOP8/PP(95x130) Package Outline Dimensions Symbol A A1 A2 b c D D1 E E1 E2 e L  Dimensions in Millimeters Min. Max. 1.300 1.700 0.000 0.100 1.350 1.550 0.330 0.510 0.170 0.250 4.700 5.100 3.050 3.250 3.800 4.000 5.800 6.200 2.160 2.360 1.270(BSC) Dimensions in Inches Min. Max. 0.051 0.067 0.000 0.004 0.053 0.061 0.013 0.020 0.007 0.010 0.185 0.201 0.120 0.128 0.150 0.157 0.228 0.244 0.085 0.093 0.050(BSC) 0.400 0° 0.016 0° 1.270 8° 0.050 8° NOTE: 1. 2. 3. 4. 5. 6. Drawing proposed to be made a JEDEC package outline MO-220 variation. Drawing not to scale. All linear dimensions are in millimeters. Thermal pad shall be soldered on the board. Dimensions of exposed pad on bottom of package do not include mold flash. Contact PCB board fabrication for minimum solder mask web tolerances between the pins. For more information www.silicontent.com © 2022 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2A26 17 SCT2A26 TAPE AND REEL INFORMATION Orderable Device SCT2A26STER Package Type ESOP-8L Pins 8 SPQ 4000 NOTICE: The information in this document is subject to change without notice. Users should warrant and guarantee the third party Intellectual Property rights are not infringed upon when integrating Silicon Content Technology (SCT) products into any application. SCT will not assume any legal responsibility for any said applications. 18 For more information www.silicontent.com © 2022 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2A26
SCT2A26STER 价格&库存
很抱歉,暂时无法提供与“SCT2A26STER”相匹配的价格&库存,您可以联系我们找货
