NJW4617DL3-TE1
NJW4617DL3-TE1
    NISSHINBO(日清纺)
    TO-252-6
    LED 驱动器 IC 1 输出 线性 恒定电流 PWM 调光 500mA TO-252-5
NJW4617DL3-TE1 数据手册
NJW4617 Constant Current LED Driver with PWM Dimming Control ■ GENERAL DESCRIPTION The NJW4617 is a constant current LED driver with PWM dimming control. The output current can be set by external sensing resister, and the NJW4617 can set up to 500mA. Because the withstand voltage of the output (LED) pin is 40V, it can series-connect the LED depending on forward voltage of the LED. The LED dimming control can be regulated via PWM duty cycle. It is suitable for back light, light source and so on. ■ PACKAGE OUTLINE NJW4617DL3 (TO-252-5) ■ FEATURES ▪ Operating Voltage Range: 2.5V to 40V ▪ Output Voltage: VLED=40V max. ▪ Output Current: ILED=20mA to 500mA ▪ Output Current Accuracy: 1.5% ▪ To 11 of White LED can be operated. (at LED Vf=3.4V) ▪ Quiescent Current: 450µA max. ▪ PWM Dimming Control and Enable Control (Common Pin) ▪ Over Current Protection ▪ Thermal Shutdown Protection ▪ LED Short Protection ▪ Package: TO-252-5 ■ BLOCK DIAGRAM VDD LED + VREF (0.2V) RS Current Limit Thermal Shut Down LED Short Protection Control Logic Standby Timer GND Ver.2020-06-11 EN/PWM -1- NJW4617 ■ PIN CONFIGURATION 5. LED 4. RS 3. GND 2. EN/PWM 1. VDD ■ PIN DESCRIPTIONS Pin No. Pin Name 1 VDD I/O - 2 EN/PWM I 3 GND - 4 RS O 5 LED O -2- Function Power supply pin Standby control pin and PWM signal input pin for dimming control. [At Standby control] Normal operation: High Level. Standby mode: Low Level. [At PWM signal input] The LED dimming control can be regulated by PWM duty cycle. In the case without dimming, ILED becomes the current set by the external resistor (Rs) when High level is input to this pin. Note that this pin should not be open. Ground pin Resistor connect pin of ILED setting. The LED current can be set with connected resistor (RS) between RS pin and GND pin. RS [Ω] = 0.2 [V] / ILED [A] Constant current circuit output pin Connect cathode pin of LED. Ver.2020-06-11 NJW4617 ■ ABSOLUTE MAXIMUM RATINGS PARAMETER SYMBOL Supply Voltage VDD Output Voltage VLED EN/PWM Pin Voltage VENPWM Power Dissipation PD Junction Temperature Range Operating Temperature Range Storage Temperature Range Tj Topr Tstg RATINGS -0.3 to +45 -0.3 to +45 -0.3 to +45 1190 (*1) 3125 (*2) -40 to +150 -40 to +125 -50 to +150 (Ta = 25C) UNIT V V V mW C C C 2 (*1) Mounted on glass epoxy board. (76.2 × 114.3 × 1.6mm: based on EIA/JEDEC standard size, 2Layers, Cu area 100mm ) (*2) Mounted on glass epoxy board. (76.2 × 114.3 × 1.6mm: based on EIA/JEDEC standard, 4Layers), (For 4Layers: Applying 74.2 × 74.2mm inner Cu area and a thermal via hole to a board based on JEDEC standard JESD51-5) ■ RECOMMENDED OPERATING CONDITIONS PARAMETER SYMBOL Supply Voltage VDD Output Current ILED Output Voltage VLED TEST CONDITIONS MIN. 2.5 20 - TYP. - MAX. 40 500 40 UNIT V mA V ■ ELECTRICAL CHARACTERISTICS (Unless otherwise noted, VDD = 12V, VLED = 1V, RS = 2Ω, VENPWM = VDD, Ta = 25C ) PARAMETER SYMBOL TEST CONDITIONS MIN TYP MAX Unit Quiescent Current IDD 330 450 µA Quiescent Current at OFF State IDD_OFF VENPWM = GND 0.1 µA Output Current Accuracy -1.5 +1.5 % ILED Output (LED) Pin Leak Current ILEAK VENPWM = GND, VDD = VLED = 40V 0.1 µA OFF Delay Time tD_OFF 10 25 45 ms V EN/PWM Pin ON Voltage1 VENPWM_ON1 VDD < 5V, ILED = OFF  ON 0.7VDD VDD EN/PWM Pin ON Voltage2 VENPWM_ON2 VDD ≥ 5V, ILED = OFF  ON 3.5 VDD V V EN/PWM Pin OFF Voltage VENPWM_OFF ILED = ON  OFF 0 0.5 EN/PWM Pin Input Current IENPWM 7 µA RS Pin Output Current IOUT_RS LED = OPEN 4 µA PWM Dimming ON Delay Time tPWM_ON 13 µs RS = 0.4Ω, VENPWM = L  H PWM Dimming OFF Delay Time tPWM_OFF 1 µs RS = 0.4Ω, VENPWM = H  L LED Short Protection VLED_SHORT 18 21 24 V Detect Voltage Maximum Output Current ILED_MAX RS = 0Ω 500 850 mA Ver.2020-06-11 -3- NJW4617 ■ TYPICAL APPLICATION VDD / V+ (*3) VDD LED ILED + VREF (0.2V) Current Limit Thermal Shut Down LED Short Protection H : ON L : OFF PWM : Dimming Control ILED RS Control Logic 0 Output Current Wave Form at PWM Dimming RS : Current Sense Resistor Standby Timer GND EN/PWM The Rs Resistance Setting formula: RS ( )  0.2(V ) ILED ( A) (*3) If the wiring from the power supply to the LED anode pin is long, the voltage may change due to the influence of the parasitic elements. As the countermeasure, it should connect a decoupling capacitor as close to the LED as possible. -4- Ver.2020-06-11 NJW4617 ■ TYPICAL CHARACTERISTICS Quiescent Current vs. Supply Voltage Quiescent Current vs. Temperature [VLED=1V, VENPWM=VDD, RS=2Ω] 450 400 400 Quiescent Current : IDD [μA] Quiescent Current : IDD [μA] [VDD=12V, VLED=1V, VENPWM=VDD, RS=2Ω] 450 350 300 250 200 150 100 -40℃ 25℃ 50 350 300 250 200 150 100 50 125℃ 150℃ 0 0 0 10 20 30 Supply Voltage : VDD [V] -50 40 -25 0 25 50 75 100 125 150 Temperature : [ºC] Quiescent Current at OFF State : IDD_OFF [nA] Quiescent Current at OFF State vs. Temperature [VLED=1V, VENPWM=GND, RS=2Ω] 100 VDD=2.5V VDD=12V 10 VDD=40V 1 0.1 -50 -25 0 25 50 75 100 125 150 Temperature : [ºC] Output Pin Leak Current vs. Temperature 1000 40 VLED=1V VLED=5V 100 [VDD=12V, VLED=1V] 45 OFF Delay Time : tD_OFF [ms] Output Pin Leak Current : ILEAK [nA] OFF Delay Time vs. Temperature [VDD=40V, VLED=40V, VENPWM=GND, RS=2Ω] VLED=40V 10 1 35 30 25 20 15 10 5 0 0.1 -50 Ver.2020-06-11 -25 0 25 50 75 100 125 150 Temperature : [ºC] -50 -25 0 25 50 75 100 125 150 Temperature : [ºC] -5- NJW4617 ■ TYPICAL CHARACTERISTICS EN/PWM Pin ON Voltage vs. Temperature [VLED=1V, RS=2Ω] EN/PWM Pin ON Voltage : VENPWM_ON [V] EN/PWM Pin ON Voltage : VENPWM_ON [V] EN/PWM Pin ON Voltage vs. Supply Voltage 3 2.5 2 1.5 1 -40℃ 0.5 25℃ 125℃ 150℃ 0 0 10 20 30 Supply Voltage : VDD [V] 2.5 2 1.5 1 0.5 0 -50 40 3 2.5 2 1.5 1 -40℃ 25℃ 0.5 125℃ 150℃ 0 0 10 20 30 Supply Voltage : VDD [V] 40 -25 0 25 50 75 100 125 150 Temperature : [ºC] EN/PWM Pin OFF Voltage vs. Temperature EN/PWM Pin OFF Voltage : VENPWM_OFF [V] EN/PWM Pin OFF Voltage : VENPWM_OFF [V] EN/PWM Pin OFF Voltage vs. Supply Voltage [VLED=1V, RS=2Ω] [VDD=12V, VLED=1V, RS=2Ω] 3 [VDD=12V, VLED=1V, RS=2Ω] 3 2.5 2 1.5 1 0.5 0 -50 -25 0 25 50 75 100 125 150 Temperature [ºC] EN/PWM Pin Input Current : IENPWM [μA] EN/PWM Pin Input Current vs. EN/PWM Pin Voltage [VDD=VENPWM, VLED=1V, RS=2Ω] 60 -40℃ 25℃ 50 125℃ 150℃ 40 30 20 10 0 0 -6- 10 20 30 EN/PWM Pin Voltage : VENPWM [V] 40 Ver.2020-06-11 NJW4617 ■ TYPICAL CHARACTERISTICS PWM Dimming ON Delay Time vs. Output Current 18 16 14 12 10 8 6 4 2 0 0 100 200 300 400 Output Current : ILED [mA] 500 PWM Dimming OFF Delay Time vs. Output Current PWM Dimming OFF Delay Time : tPWM_OFF [μs] PWM Dimming ON Delay Time : tPWM_ON [µs] [VDD=12V, VLED=1V] 20 4.5 4 3.5 3 2.5 2 1.5 1 0.5 0 0 30 RS=10Ω 25 RS=2Ω RS=0.4Ω 20 15 10 5 0 -50 -25 0 25 50 75 100 125 150 Temperature : [ºC] 100 200 300 400 Output Current : ILED [mA] [VDD=12V, VLED=1V] 1.4 RS=10Ω 1.2 RS=2Ω 1 RS=0.4Ω 0.8 0.6 0.4 0.2 0 -50 -25 Output Current vs. Output Pin Voltage 0 25 50 75 100 125 150 Temperature : [ºC] Output Current vs. Temperature [VDD=12V, VENPWM=VDD] 600 500 PWM Dimming OFF Delay Time vs. Temperature PWM Dimming OFF Delay Time : tPWM_OFF [μs] PWM Dimming ON Delay Time : tPWM_ON [μs] PWM Dimming ON Delay Time vs. Temperature [VDD=12V, VLED=1V] [VDD=12V, VLED=1V] 5 [VDD=12V, VLED=1V, RS=2Ω, VENPWM=VDD] 110 108 RS=2Ω 500 Output Current : ILED [mA] Output Current : ILED [mA] RS=10Ω RS=0.667Ω RS=0.4Ω 400 300 200 100 106 104 102 100 98 96 94 92 0 90 0 Ver.2020-06-11 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 Output Pin Voltage : VLED [V] 1 -50 -25 0 25 50 75 100 125 150 175 200 Temperature : [ºC] -7- NJW4617 ■ TYPICAL CHARACTERISTICS Maximum Output Current vs. Output Pin Voltage LED Short Protection Voltage vs. Temperature LED Short Protection Voltage : VLED_SHORT/OFF [V] Detect Voltage 23 Release Voltage 22 21 20 19 18 17 16 15 -50 -25 0 Maximum Output Current : ILED_MAX [mA] [VDD=12V, VENPWM=VDD, RS=0Ω] 24 700 600 500 400 300 200 100 0 0 600 500 400 300 40 [VDD=12V, VENPWM=VDD, VLED=1V] 1000 Output Current : ILED [mA] Maximum Output Current : ILED_MAX [mA] 700 10 20 30 Output Pin Voltage : VLED [V] Output Current vs. Current Sense Resistance [VDD=12V, VLED=1V, VENPWM=VDD, RS=0Ω] 800 Detect Voltage 800 25 50 75 100 125 150 Temperature : [ºC] 900 Release Voltage 900 Maximum Output Current vs. Temperature 1000 [VDD=12V, VENPWM=VDD, RS=0Ω] 1000 100 200 100 0 10 -50 -8- -25 0 25 50 75 100 125 150 Temperature : [ºC] 0.1 1 10 Current Sense Resistance : RS [Ω] 100 Ver.2020-06-11 NJW4617 Application Manual ■ The number of LED series connection It is necessary to drive LED that is the LED forward voltage (Vf) or more. When the LED was series connected, the supply voltage should be input sum of LED Vf (ΣLED Vf) the series connected or more. In NJW4617, it is necessary as minimum V+ that is ΣLED Vf + NJW4617 output voltage (VLED = 1V). The maximum LED connected number that NJW4617 can drive is limited by the recommended output voltage maximum value (40V). Moreover, it should be used with ΣLED Vf within 39V that is subtracted the VLED = 1V. The table below shows maximum LED number at each Vf. (All LED Vf assumes ideally same) LED Vf is up to 3.0V ▪▪▪ up to 13 lights LED Vf is up to 3.2V ▪▪▪ up to 12 lights LED Vf is up to 3.5V ▪▪▪ up to 11 lights LED Vf is up to 3.9V ▪▪▪ up to 10 lights LED Vf is up to 4.3V ▪▪▪ up to 9 lights V+ 40V VDD (*4) (*3) Vf  n pcs. =  LEDVf  39V VDD LED + VREF (0.2V) Current Limit Thermal Shut Down LED Short Protection RS Control Logic Standby Timer GND EN/PWM (*4) If the wiring from the power supply to the VDD pin is long, the voltage may change due to the influence of the parasitic elements. As the countermeasure, it should connect a decoupling capacitor as close to the VDD pin as possible. Ver.2020-06-11 -9- NJW4617 Application Manual ■ PWM input pulse and PWM dimming accuracy The ILED transient behavior corresponding to PWM input pulse has some delay at rise/fall time. PWM Input Pulse Output Current Pulse tPWM_ON tPWM_OFF Output Current PWM ON/OFF Propagation Delay ( Output Current Pulse Width Error : εt = tPWM_ON - tPWM_OFF) If enter a PWM signal with short pulse width, for the output current pulse width error becomes larger against the PWM input pulse width, it is incapable of accurate PWM dimming. The Output current pulse width error rate (εt) becomes the following value. ( εt=tPWM_ON –tPWM_OFF ) εt = approx. 12µs (Output Current: ILED=500mA,Ta=25C typ. ) The actual value of the output current pulse width error rate can calculate by above error rate (εt) and the frequency and Duty of the PWM input pulse. (fPWM: PWM input pulse frequency, D: PWM input pulse Duty) Based on the allowable value of the output current pulse width error rate, you should determine the frequency and Duty of the PWM input pulse. PWM Input pulse width = D / 100 × ( 1 / fPWM ) Output Current pulse width = PWM Input pulse width - εt Output Current pulse width error rate = (Output Current pulse width - PWM Input pulse width) / PWM Input pulse width × 100 = -εt / PWM Input pulse width × 100 [%] 【 Output current pulse width error rate calculation example: operation with PWM input pulse frequency 200Hz and Duty1% 】 PWM Input pulse width = 1 [%] / 100 × ( 1 / 200[Hz] ) = 50 [µs] Output Current pulse width error rate = -12 [µs] / 50 [µs] × 100 = -24 [%] Output Current Duty vs. PWM Input Pulse Duty 【 Measurement Conditions 】 100 ILED=20mA Output Current (ILED) Output Current Duty [%] ILED=100mA ILED=500mA 10 1 20mA (RS = 10Ω) 100mA (RS = 2Ω) 500mA (RS = 0.4Ω) Supply Voltage 12V Output (LED) pin Input Voltage at 1V PWM Input Pulse 200Hz, 0 to 5V Output Current ILED Pulse Width The time is more than 90% of set current. 0.1 Ambient Temperature Ta=25ºC 0.01 0.01 - 10 - 0.1 1 10 PWM Input Pulse Duty [%] 100 Ver.2020-06-11 NJW4617 Application Manual ■ Protection Circuit ▪ Over Current Protection (Refer to Maximum Output Current vs. Output Pin Voltage) This protection function limits the output current, when the RS pin and GND pin was shorted. The limited current is dependence on output (LED) pin voltage. When the output (LED) pin voltage is less than "LED Short Protection Detect Voltage", maximum output current is limited to approx. 850mA (output (LED) pin voltage=1V, Ta=25C). The output current returns to set current, when the short status is release. ▪ LED Short Protection (Refer to Maximum Output Current vs. Output Pin Voltage) This protection function limits the output current, when the output (LED) pin rises as in LED shorten at output FET ON. The output current is limited to approx. 400mA when the output (LED) pin voltage rose to approx. 21V. ▪ Thermal Shutdown Function (Refer to Output Current vs. Temperature) When junction temperature of the NJW4617 exceeds the 160°C*, internal thermal shutdown circuit function stops the device function. When junction temperature decreases to 140°C* or less, the device operation returns to normal operation. The purpose of this function is to prevent malfunctioning of IC at the high junction temperature. Therefore it is not something that urges positive use. It should make sure to operate within the junction temperature range rated (+150°C). *) Design value Ver.2020-06-11 - 11 - NJW4617 Application Manual ■ The Loss of Constant Current Driver The power consumption of the LED lighting circuit is classified as "the power consumption of the constant current driver" "the power consumption of the LED" and "the power consumption of the current sense resistor (RS)". The loss of constant current driver is caused mainly by quiescent current (IDD) and output current (ILED). The power dissipation of the device can calculate by follow equation. VDD V+ (*4) PD ≈ VDD  IDD + (VLED - VRS)  ILED = VDD  IDD + (V+ - LED Vf - 0.2)  ILED [W] (*3)  LEDVf Rs pin voltage (VRS): 0.2V ΣLED Vf represents the sum of the LED Vf of use. IDD VDD LED + VREF (0.2V) Current Limit Thermal Shut Down LED Short Protection ILED VLED - VRS RS Control Logic e.g.) VDD = V+ = 12[V], IDD=330[µA], LED Vf = 9[V], ILED = 400[mA] PD ≈ 12[V]  330[µA] + (12[V] - 9[V] -0.2[V])  400[mA] ≈ 1124[mW] Standby Timer EN/PWM GND As shown in the above equation, the loss of constant current driver will increase in proportion to the voltage difference between the LED driving voltage V+ and ΣLED Vf. The device power dissipation must be below the power dissipation rate of the device package including thermal derating to ensure correct operation. It should set the LED operating Voltage (V+) and output current (ILED) with consideration of PD. NJW4617DL3 (TO-252-5) Power Dissipation (Topr=-40ºC to +125ºC, Tj=150ºC) 3500 The device power dissipation must be below the power dissipation rate of the device package including thermal derating to ensure correct operation. (*2) on 4 Layers Board Package Power : Pd [mW] 3000 2500 2000 (*1): Mounted on glass epoxy board. (76.2 × 114.3 × 1.6mm: 1500 (*1) on 2 Layers Board based on EIA/JEDEC standard size, 2Layers, Cu area 100mm2) 1000 (*2): Mounted on glass epoxy board. (76.2 × 114.3 × 1.6mm: based on EIA/JEDEC standard, 4Layers), 500 (For 4Layers: Applying 74.2 × 74.2mm inner Cu area and a 0 -50 - 12 - -25 0 25 50 75 100 Ambient Temperature : Ta [ºC] 125 150 thermal via hole to a board based on JEDEC standard JESD51-5) Ver.2020-06-11 NJW4617 Application Manual ■ Parallel Drive of NJW4617 For applications that require more than 500mA, it can correspond by parallel connecting two or more NJW4617. The LED current becomes sum of LED current of each NJW4617. Each device accepts different set current. ILED [A] = ILED1 + ILED2 = 0.2 / RS1 [Ω] + 0.2 / RS2 [Ω] (e.g. ILED = 750 [mA] setting: RS1 = 0.4 [Ω], RS2 = 0.8 [Ω] ) V+ (*3) ILED VDD (*4) ILED1 VDD ILED2 VDD LED LED + VREF (0.2V) Current Limit Thermal Shut Down LED Short Protection + VREF (0.2V) RS Control Logic RS 1 Current Limit Thermal Shut Down LED Short Protection Standby Timer GND RS Control Logic RS 2 Standby Timer EN/PWM GND EN/PWM PWM Ver.2020-06-11 - 13 - NJW4617 MEMO [CAUTION] The specifications on this databook are only given for information, without any guarantee as regards either mistakes or omissions. The application circuits in this databook are described only to show representative usages of the product and not intended for the guarantee or permission of any right including the industrial rights. - 14 - Ver.2020-06-11
NJW4617DL3-TE1 价格&库存
很抱歉,暂时无法提供与“NJW4617DL3-TE1”相匹配的价格&库存,您可以联系我们找货
