KNIPEX TwinKey®
00
for all standard cabinets and shut-off systems
11
10 Profiles, 2 crosses, 1 key
For all common locking systems
>> multifunctional key for the actuation of locking systems from the
areas of facilities engineering (heating and sanitation, air conditioning,
electro technology), gas and water supply and shut-off systems
>> 8-arm version: 2, 4-way wheel wrenches connected in a space-saving
way using magnets
>> reversible bit: slot 3/64 x 9/32" (1.0 x 7 mm) and PH2 cross slot
>> key and reversible bit joined by stable stainless steel wire
>> quality surface coating
>> lightweight-optimized zinc die-cast design
00 11 01
TwinKey
WARNING: This product can expose you to chemicals including Nickel, which is known to the
State of California to cause cancer. For more information go to www.P65Warnings.ca.gov
Product Number Packaging
00 11 01
192
X
Inch
mm
Inch
mm
Inch
mm
3 3/4
95
13/64, 15/64 - 9/32, 5/16 - 23/64, 25/64 - 7/16
5 / 6 - 7 / 8 - 9 / 10 - 11
9/32 - 5/16, 23/64 - 25/64, 7/16 - 15/32
7 - 8 / 9 - 10 / 11 - 12
Inch
mm
Inch
mm
Inch
mm
lbs
1/8 - 13/64 15/64 15/64 - 23/64
0.33
3-5
6
6-9
很抱歉,暂时无法提供与“00 11 01”相匹配的价格&库存,您可以联系我们找货
