88 01 300
    KNIPEX(凯尼派克)
    可调(水泵) 钳子 平头 有齿 11.81"(300.0mm)
88 01 300 数据手册
Product information 88 01 300 ● good access to the workpiece due to slim size of head and joint area ● more output and comfort compared to conventional water pump pliers of the same length: 9-notch adjustment positioning for 30 % more gripping capacity ● box-joint design for high stability due to double guide ● self-locking on pipes and nuts: no slipping on the workpiece and low handforce required ● guard prevents operators' fingers being pinched ● favourable lever action: optimum transmission of force ● gripping surfaces with special hardened teeth, teeth hardness approx. 61 HRC: high wear resistance and stable gripping ● Chrome vanadium electric steel, forged, multi stage oil-hardened KNIPEX Alligator® DIN ISO 8976 Allgemein Article No. 88 01 300 EAN 4003773034094 Pliers black atramentized Head polished Handles with non-slip plastic coating weight 511 g Dimensions 300 x 53 x 15 mm Technische Attribute Adjustment positions 9 Capacities for pipes (diameter) Ø 2 3/4 Capacities for nuts 60 mm Capacities for pipes (diameter) Ø 70 mm Klassifikation eCl@ss 5.1.4 21040301 ETIM 5.0 EC000164 ETIM 6.0 EC000164 proficl@ss 6.0 AAA936c004 technical change and errors excepted KNIPEX Werk - C. Gustav Putsch KG - 42337 Wuppertal 26.03.2019 | page 1 1
88 01 300 价格&库存
很抱歉,暂时无法提供与“88 01 300”相匹配的价格&库存,您可以联系我们找货
