35 41 115
    KNIPEX(凯尼派克)
    电子设备 钳子 平头 平滑 4.50"(114.3mm)
35 41 115 数据手册
Product information 35 41 115 ● precision pliers for fine assembly work, e g. in electronics and fine mechanics ● Load-optimised for a more direct feel when working ● for gripping, holding and bending ● sturdy, zero backlash box joint ● smooth ground gripping surfaces ● Soft transitions; no sharp edges ● low-friction double spring for gentle and even opening ● the polish or mirror polish (only finish 2) together with a fine film of oil offer effective rust protection - no circuit faults caused by peeling chrome from plated tools ● Narrow sleeves pulled up to the head of the pliers enable the tool to be guided securely and comfortably, also between thumb and index finger ● Ball bearing chrome steel ● Special tool steel, forged, oil-hardened Electronics Pliers DIN ISO 9655 Allgemein Article No. 35 41 115 EAN 4003773082248 Head mirror polished Handles with multi-component grips weight 61 g Dimensions 115 x 66 x 14 mm Technische Attribute Head width 11.0 Dimensions angle 45 Klassifikation eCl@ss 5.1.4 21040301 proficl@ss 6.0 EAA840c015 technical change and errors excepted KNIPEX Werk - C. Gustav Putsch KG - 42337 Wuppertal 26.03.2019 | page 1 1
35 41 115 价格&库存
很抱歉,暂时无法提供与“35 41 115”相匹配的价格&库存,您可以联系我们找货
