AZ4020-01G.R7G
AZ4020-01G.R7G
    AMAZING(晶焱)
AZ4020-01G.R7G 数据手册
AZ4020-01G Transient Voltage Suppressing Device For ESD/Surge/Transient Protection Features over-voltage damage and latch-up caused by ESD/Surge Protection for 1 Line with Electrostatic Discharging (ESD), Electrical Fast Unidirectional. Transients Provide ESD protection for each line to Discharge Event (CDE). (EFT), Lightning, and Cable AZ4020-01G is a unique design which IEC 61000-4-2 (ESD) ±30kV (air / contact) IEC 61000-4-4 (EFT) 80A (5/50ns) IEC 61000-4-5 (Lightning) 30A (8/20µs) Suitable for, 20V and below, operating voltage includes proprietary clamping cell in a single applications clamping cell prevents over-voltage on the power Small package saves board space line Protect one I/O line or one power line downstream components. package. During transient conditions, the proprietary Fast turn-on and Low clamping voltage or control/data lines, protecting any AZ4020-01G may be used to meet the ESD Solid-state silicon-avalanche and active circuit immunity requirements of IEC 61000-4-2, Level 4 triggering technology (±15kV air, ±8kV contact discharge). Green part Circuit Diagram / Pin Configuration Applications Battery Contacts Power Manager System PDA’s 1 Portable Devices Digital Cameras Digital Frames Cellular Handsets and Accessories Notebooks, desktops, and servers Microprocessor-based equipment Peripherals Description 2 AZ4020-01G is a design which includes a unidirectional ESD rated clamping cell to protect one power line, or one control line, or one low speed data line in an electronic systems. The SOD-123 (Top View) AZ4020-01G has been specifically designed to protect sensitive components which are connected to power and control lines from Revision 2015/01/29 © 2015 Amazing Micro. 1 www.amazingIC.com AZ4020-01G Transient Voltage Suppressing Device For ESD/Surge/Transient Protection SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS PARAMETER SYMBOL RATING UNITS Peak Pulse Current (tp =8/20µs) IPP 30 A Operating Supply Voltage (pin-1 to pin-2) VDC 22 V Pin-1 to pin-2 ESD per IEC 61000-4-2 (Air) VESD-1 ±30 kV Pin-1 to pin-2 ESD per IEC 61000-4-2 (Contact) VESD-2 ±30 Lead Soldering Temperature TSOL 260 (10 sec.) o Operating Temperature TOP -55 to +85 o -55 to +150 o Storage Temperature TSTO C C C ELECTRICAL CHARACTERISTICS PARAMETER SYMBOL CONDITIONS MINI TYP MAX UNITS 20 V 1 µA Reverse Stand-Off VRWM Pin-1 to pin-2, T=25 oC. Voltage Reverse Leakage Current ILeak VRWM = 20V, T=25 oC, pin-1 to pin-2. Reverse Breakdown VBV IBV = 1mA, T=25 oC, pin-1 to pin-2 22.2 24.5 V VF IF = 15mA, T=25 oC, pin-2 to pin-1 0.6 1.2 V Voltage Forward Voltage Surge Clamping Voltage ESD Clamping Voltage VCL-surge Vclamp ESD Dynamic Turn-on Rdynamic Resistance Channel Input Capacitance CIN IPP=5A, tp=8/20µs, T=25 oC, pin-1 to pin-2 IEC 61000-4-2 +6kV, T=25 oC, Contact mode, pin-1 to pin-2. IEC 61000-4-2 0~+6kV, T=25 oC, Contact mode, pin-1 to pin-2. VR = 0V, f = 1MHz, T=25 oC, pin-1 to pin-2. Revision 2015/01/29 © 2015 Amazing Micro. 2 23.5 V 26 V 0.12 Ω 580 pF www.amazingIC.com AZ4020-01G Transient Voltage Suppressing Device For ESD/Surge/Transient Protection Typical Characteristics Reverse Clamping Voltage vs. Peak Pulse Current Forward Clamping Voltage vs. Peak Pulse Current 40 5 Pin-1 to Pin-2 Pin-2 to Pin-1 4 Clamping Voltage (V) Clamping Voltage (V) 35 30 25 Waveform Parameters: tr = 8µs td = 20µs 20 3 2 Waveform Parameters: tr = 8µs td = 20µs 1 15 0 0 5 10 15 20 25 30 35 0 5 10 Peak Pulse Current (A) 20 25 30 35 Typical Variation CIN vs. VIN Transmission Line Pulsing (TLP) Measurement 600 25 f = 1MHz, T = 25°C V_pulse Pulse from a transmission line 20 100ns + TLP_V 15 TLP_I DUT _ 10 Pin-1 to Pin-2 500 Input Capacitance (pF) Transmission Line Pulsing (TLP) Current (A) 15 Peak Pulse Current (A) Pin-1 to Pin-2 5 400 300 200 100 0 0 0 5 10 15 20 25 0 30 10 15 20 Input Voltage (V) Transmission Line Pulsing (TLP) Voltage (V) Revision 2015/01/29 © 2015 Amazing Micro. 5 3 www.amazingIC.com AZ4020-01G Transient Voltage Suppressing Device For ESD/Surge/Transient Protection Mechanical Details SOD-123 PACKAGE DIMENSIONS PACKAGE DIAGRAMS TOP VIEW Symbol Inches MIN. MAX. MIN. MAX. A 1.050 1.250 0.041 0.049 A1 0.000 0.100 0.000 0.004 A2 1.050 1.150 0.041 0.045 b 0.450 0.650 0.018 0.026 c 0.080 0.150 0.003 0.006 D 1.500 1.700 0.059 0.067 E 2.600 2.800 0.102 0.110 E1 3.550 3.850 0.140 0.152 L L1 θ SIDE VIEW Millimeters 0.500 REF 0.250 0° 0.450 8° 0.020 REF 0.010 0° 0.018 8° LAND LAYOUT 0.7 mm Notes: This LAND LAYOUT is for reference purposes only. Please consult your manufacturing partners to ensure your company’s PCB design guidelines are met. Revision 2015/01/29 © 2015 Amazing Micro. 4 www.amazingIC.com AZ4020-01G Transient Voltage Suppressing Device For ESD/Surge/Transient Protection MARKING CODE BX BX 1 2 Part Number Marking Code AZ4020-01G (Green Part) BX Note. Green means Pb-free, RoHS, and Halogen free compliant. B = Device Code X = Date Code Ordering Information PN# Material Type Reel size MOQ AZ4020-01G.R7G Green T/R 7 inch 3,000/reel MOQ/internal box MOQ/carton 4 reel= 12,000/box 6 box =72,000/carton Revision History Revision Modification Description Revision 2014/06/09 Preliminary Release. Revision 2014/09/04 Update the specification of Lightning. Revision 2015/01/29 Formal Release. Revision 2015/01/29 © 2015 Amazing Micro. 5 www.amazingIC.com
AZ4020-01G.R7G 价格&库存
很抱歉,暂时无法提供与“AZ4020-01G.R7G”相匹配的价格&库存,您可以联系我们找货
AZ4020-01G.R7G
    • 1+0.87910
    库存:5
    AZ4020-01G.R7G
      • 1+1.57920
      库存:5
