Bellnix Tracking Function, Non-Isolated Type POL DC-DC Converter
RoHS Tracking Output
Preoision
Sequencial
Simultaneous
Ratio-Metric
Compliance
World Standard Size!
±2%
6A/10A/16A BST Series
Low Price, Tracking Function, Step Down DC-DC Converter
Input: +2.8 to +5.5V Output: +0.75V[+0.75 to +3.3V]
Input: +10 to 14V Output: +0.75V[+0.75 to +5.0V]
Voltage can be optionally set with external resistors. (Ex.: 1V, 1.2V, 1.5V, 1.8V, 2.5V, 3.3V, 5V)
- Tracking Function
Models
Sequencial Operation
BST Series
BST04-0.7S06PCM
BST12-0.7S06PCM
BST04-0.7S10PCM
BST12-0.7S10PCM
BST04-0.7S16PCM
BST12-0.7S16PCM
Simultaneous Tracking Operation
Ratio-Metric Tracking Operation
- Remote ON/ OFF Control
- Industry's Standard Package
- Surface Mount Package (SMD)
- Ultra High Efficiency
- Adjustable Output Voltage
- Over-Current Protection
- No Electrolytic Capacitor,
No Tantalum Capacitor
- Operating Temp Range
-40°C to +85°C
(Temp Derating Required)
- RoHS Compliance
- DOSA Compatible
Input V
Vdc
Vdc
2.8-5.5
10-14
2.8-5.5
10-14
2.8-5.5
10-14
0.75-3.3
0.75-5.0
0.75-3.3
0.75-5.0
0.75-3.3
0.75-5.0
(6A series)
2.00
%(typ.)
6
0.3
0.2
%(typ.)
0.4
10
0.3
0.4
16
0.3
0.4
Efficiency
mVpp(typ.)
%(typ.)
40
30
25
30
25
30
94
91.5
96
94.5
95
93.5
(10/16A series)
33.0
4.83 4.83 4.83 4.83 7.54
2.00
1
1.40
3.8
Bottom View
This catalogue is an outline of the products.
When in designing, be sure to refer to the
data sheets.
Pin
1
2
3
4
5
6
30K
Function
On/Off
Vin
Seq
13.5
1.2
Model
BST04
BST12
Pin no. is not
shown on the
converter.
Gnd
Trim
Vout
Bottom View
Weight : BST04-16A : 8.0g typ.
Weight : BST04-10A : 9.0g typ.
Weight : BST12-10A/16A : 9.0g typ.
Units : mm
Pin
1
2
3
4
5
6
7
H(Height)
8.3
9.7
Function
On/Off
Vin
Seq
Pin no. is not
shown on the
converter.
Gnd
Vout
Trim
Sense
BST-10A/16A Series
Vin
Cout
R1
Vin
Load
Vout
BST**-0.7S10PCM
BST**-0.7S16PCM
30K
Trim
Gnd
Sense
Trim
Seq
On/Off
Cin
Gnd
Cout
R1
Load
SW1
SW1
Cin: BST04=47µF Ceramic capacitor//2×100µF Tantalum capacitor
BST12=2×22µF Ceramic capacitor
Cout: 1µF Ceramic capacitor//10µF Tantalum capacitor
(Common for BST04 and 12)
R1: Vout up Resistor
1.91
1
Vout
Seq
On/Off
7
2.80
BST **-0.7S06P CM
Cin
6
2
0.120
BST-6A Series
Vin
5
29.90
Weight : BST-6A : 4.0g typ.
Units : mm
- Note!
4
0.64
1.50
2
0.120
3
6
8.64
5
4
1.5
3
10.29
2.3
11.4
8.89
1.5
1.40
A
H(HEIGHT)max.
4.83 4.06 4.06 4.57
7.1max.
Output I Line Reg. Load Reg. Ripple Noise
Note 1:When the output voltage is not adjusted, the rated output voltage is Vo=0.75V.
Note 2: When adjusting the Vout, the input and output voltage difference must be greater than 0.5V.
Vin(V)-Vo(V)≧0.5V
Note 3: Ripple noise is measured at 20MHz bandwidth.
Note 4: Efficiency is when BST04 series is at: Vin=5V,Vo=3.3V and BST12 series is at: Vin=12V,Vo=5V
respectively.
Note 5: Depending on the ambient temp conditions, air flow cooling is required.
27.9
Vin
Output V
(Common for 10A and 16A series)
BST12 (10A series)=4×22µF Ceramic capacitor
BST12 (16A series)=6×22µF Ceramic capacitor
R1:Vout up Resistor
很抱歉,暂时无法提供与“BST12-0.7S10PCM”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+171.291001+20.77502
- 10+140.6591710+17.05984
- 50+108.9284450+13.21138
- 100+105.76910100+12.82820
