Bellnix High Efficiency, Ultra Small Size, Non-Isolated Type POL DC-DC Converter
RoHS
4A/6A BSI-P Series
Compliance
Ultra High Efficiency (92%), Minimum Size Step-Down DC-DC Converter
Output: +5.0V (+3.0V to +5.0V)
Input: +6V, +12V, +15V
Models
Input V
Output V
BSI-P Series
BSI-5.0S4R0PA
BSI-5.0S4R0FPA
Vdc
Vdc
5.0
(3.0-5.0)
6-16.5
Output I Line Reg Load Reg Ripple/Noise Efficiency
A
%(typ.)
0-4
0.3
%(typ.) mVpp(typ.) %(typ.)
0.2
50
92
Note 1: When operating at output current 3A-6A, air flow (1m/sec) is required.
Note 2: The output voltage inside the ( ) indicates the adjustable range.
Note 3: External capacitors are required.
Note 4: Suffix "A" stands for version.
BSI-5.0S4R0FPA (h=9.3typ)
0.8 2.5typ
(Temp Derating Required)
Bellnix
5
18
14
0.64
22.86
P2.54×4=10.16
3.0typ
15.24
5.5typ
P2.54×4=10.16
Units: mm Weight: 12g typ.
Load current: 3A or more
Air flow (1m/sec) required.
pin Function
1
+Vin
2 2.25+Vin
3
-Vin
4
-Vin
5 ON/OFF
14 V.ADJ
15 -Vout
16 -Vout
17 +Vout
18 +Vout
Bellnix
5
1
14
50(+1/-0.5)
18
10.3max
C/L
1
t0.8
9.8 max
50(+1/-0.5)
- RoHS Compliance
5.5typ
19
C/L
36
0.64
22.86
2.54×4=10.16
20.5(+1/-0.5)
(t=8.8typ)
BSI-5.0S4R0PA
20.5(+1/-0.5)
- Efficiency 92%
- Latest Technology, Synchronous
Rectification Circuit
- Adjustable Output Voltage
- Non-Isolated Type Converter
- Short Circuit, Over-Current
Protection
- No Electrolytic Capacitor used
No Tantalum Capacitor used
- Heat Sink Not Required
- Minimum Size
- Remote ON/OFF Control
- Low Standby Current 100µA
- MTBF 1,000,000Hrs
- High Reliability, High Performance
- Operating Temp Range
-10°C to +70°C
2.54×4=10.16
pin Function
1
+Vin
2
+Vin
3
-Vin
4
-Vin
5 ON/OFF
14 V.ADJ
15 -Vout
16 -Vout
17 +Vout
18 +Vout
NC
19
36
NC
+Vin
1
FET1
18
+Vout
2
C1
-Vin
C3
17
3
PWM.OCP.CONT
16
ON/OFF CONT
4
Load
C2
FET2
15
ON/OFF 5
ON = Open
OFF= Short
(0 to 0.5V)
-Vout
14
V.adj
Open =5V
- External Capacitors
C1=100µF20WV× 2 pcs or more (Recommended OS-CON SH, FA type)
C2=220µF10WV× 2 pcs or more (Recommended OS-CON SH, FA type)
- ON/OFF Control
The ON/OFF control is controlled by opening and shortening between 5pin(ON/OFF) and 3, 4pin (-Vin).
The output voltage is adjustable by connecting a resistor between 14pin (V.ADJ) and 17, 18pin (+Vout).
- Note!
This catalogue is an outline of the products.
When designing, be sure to refer to the
data sheets.
When 14pin is open, the rated output voltage is as follows
BSI-5.0S = +5.0V±5%
很抱歉,暂时无法提供与“BSI-5.0S4R0PA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+283.241411+34.35292
- 10+244.0931110+29.60482
- 50+240.9337750+29.22164
- 100+231.45576100+28.07210
- 500+224.03819500+27.17246
- 1000+218.818421000+26.53938
- 国内价格 香港价格
- 国内价格 香港价格
