92 21 06
    KNIPEX(凯尼派克)
    镊子 防磁 尖头 极精细型 3.25"(82.6mm)
92 21 06 数据手册
Stripping Tweezers 15 Stripping tips, steel and plastic > Magnetic tips > Stripping tips are replaceable depending on gauge of wire to be stripped > Tweezer body made from spring steel, oil-hardened > Plastic handles Product Number Length Width Height Finish Gripping Surface 15 11 120 5" 3/8" 1 9/16" steel with plastic handles, magnetic, acid resistant cutting edge 15 19 005 3/4" 3/8" 3/16" steel spare blades for 15 11 120, 0.5 mm diameter, magnetic, acid resistant cutting edge 15 19 006 3/4" 3/8" 3/16" steel spare blades for 15 11 120, 0.6 mm diameter, magnetic, acid resistant cutting edge 15 19 008 3/4" 3/8" 3/16" steel spare blades for 15 11 120, 0.8 mm diameter, magnetic, acid resistant cutting edge 15 19 010 3/4" 3/8" 3/16" steel spare blades for 15 11 120, 1.0 mm diameter, magnetic, acid resistant cutting edge Cutting Tweezers 92 Cutting tips, stainless steel > Stainless steel offers corrosion resistance > 100% magnetic > Cutting edges designed for cutting fine components > ESD handle discharges electrostatic energy through the handles in a gradual and controlled manner (dissipative 104/109 OHM regarding DIN EN 61340-5-1) 92 11 01 and 92 11 01 ESD 12 Product Number Length Width Height Finish Style Gripping Surface 92 11 01 4 1/2" 7/16" 9/16" stainless steel, magnetic, acid resistant angled cutting edge 92 11 01 ESD 4 1/2" 7/16" 11/16" stainless steel, magnetic, acid resistant, ESD angled cutting edge
92 21 06 价格&库存
很抱歉,暂时无法提供与“92 21 06”相匹配的价格&库存,您可以联系我们找货
