78 61 125 ESD
78 61 125 ESD
    KNIPEX(凯尼派克)
    侧面(对角) 切割器 椭圆形 凹槽 5.00"(127.0mm)
78 61 125 ESD 数据手册
Product information 78 61 125 ESD ● precision pliers for ultra fine cutting work, e. g. in electronics and fine mechanics ● electrically discharging handles - dissipative ● ground, very sharp cutting edges without bevel ● Shear cut with controlled micro cutting edge misalignment for the most precise cutting of even the thinnest of wires and for a long service life ● precision shaped tips cut wires resting on a board from 0.2 mm dia. ● joint with stainless steel rivet ● extremely smooth movement for minimum operator fatigue ● with opening spring and opening limiter ● with two-colour dual component grips, black/grey ● cutting edges additionally induction hardened, cutting edge hardness approx. 64 HRC ● special tool steel, burnished ● High-grade special tool steel, oil-hardened Electronic Super Knips® ESD DIN ISO 9654 DIN EN 61 340-5 Allgemein Article No. 78 61 125 ESD EAN 4003773025184 Pliers burnished Head burnished Handles with multi-component grips weight 56 g Dimensions 125 x 70 x 13 mm Technische Attribute Style 6 Cutting capacities medium hard wire (diameter) Ø 1.2 Cutting capacities soft wire (diameter) Ø 0.2 – 1.6 mm 9 mm 7.5 mm Head width 13.5 mm ESD yes Klassifikation eCl@ss 5.1.4 21040302 ETIM 5.0 EC000165 ETIM 6.0 EC000165 proficl@ss 6.0 AAA949c004 technical change and errors excepted KNIPEX Werk - C. Gustav Putsch KG - 42337 Wuppertal 26.03.2019 | page 1 1
78 61 125 ESD 价格&库存
很抱歉,暂时无法提供与“78 61 125 ESD”相匹配的价格&库存,您可以联系我们找货
