11.30 [0.445]
5.00 [0.197]
TOP VIEW
8.60 [0.339]
14.40 [0.567]
RIGHT SIDE VIEW
11.94 [0.470]
7.14 [0.281]
1.02 [0.040]
2-Ø1.95 [Ø0.077]
17.70 [0.697]
9.80 [0.386]
FRONT VIEW
11.94 [0.470]
7.14 [0.281]
1.02 [0.040]
0.70 [0.028]
1.80 [0.071]
1 23 45 6 7 8
8.10 [0.319]
17.14 [0.675]
2-Ø0.98 [Ø0.038]
2.50 [0.098]
4.20 [0.165]
13.60 [0.535]
12.25 [0.482]
17.14 [0.675]
19.14 [0.754]
RECOMMENDED PCB LAYOUT
VIEWED FROM COMPONENT SIDE
5.45 [0.215]
3.90 [0.154]
1
J1
2
3
4
5
J2
J3
J4
J5
6
J6
7
J7
8
J8
XKB Connecitity
6.79 [0.267]
11.55 [0.455]
PCB SIDE TO PHY
13.40 [0.528]
12.75 [0.502]
13.90 [0.547]
CABLE SIDE
XKB Connecitity
XKB Connecitity
6.60 [0.260]
MATERIAL 材料:
HOUSING 外壳: LCP,UL94V-0,BLACK.
TERMINAL 端子: PHOSPHOR BRONZE ,T=0.35MM,
GOLD PLATING ON CONTACT AREA.
SHIELD 保护物 :C2680,T=0.20MM,20~50U" MIN NICKEL PLATING
ON ALL AREA.
MECHANICAL 机械:
DURABILITY 耐用性: 750 CYCLES MIN.12.5MM/MINUTE
INSERTION FORCE 插入力 : 2.2KG.F MAX
RETENTION STRENGTH 固位力 :7.7KG.F BETWEEN JACK AND PLUG
OPERATING TEMPERATURE 工作温度 : -40°C~+85°C.
STORAGE TEMPERATURE 储存温度 : -40°C~+85°C.
ALL CRITICAL DIMENSIONS WITH "*"
ELECTRICAL 电动:
VOLTAGE 电压:125 VOLTS AC
CURRENT RATING 额定电流 :1.5AMP
DIELECTRIC STRENGTH 介电强度 :1000 VAC RMS 50HZ OR 60HZ,1MIN
INSULATION RESISTANCE 绝缘电阻 :500 MEGA OHMS MIN.INITIAL
AFTER 500V DC FOR 1 MINUTE
CONTACT RESISTANCE 接触电阻 :SINGLE TERMINAL 30 MILLIOHMS MAX
INITIAL 50 MILLIOHMS MAX.AFTER
DURABILITY TEST
BOTTOM VIEW
X
X
X
MARK
DATE
DESCRIPTION
REVISIONS
www.xk-dg.cn
www.helloxkb.com
REVISED
APPROVED
ANGLAR
L≤4
4
很抱歉,暂时无法提供与“X38ADGWA6SB1133”相匹配的价格&库存,您可以联系我们找货
