24C64BN
24C64BN
    XBLW(芯伯乐)
    SOP8_150MIL
    EEPROM存储器 64-Kbit(4096 X 8bit),I2C接口 1.8-5.5V 1MHz
24C64BN 数据手册
XBLW 24C64 Two-Wire Serial EEPROM 64K(8-bit wide) DESCRIPTION The 24C64 series are 65,536 bits of serial Electrical Erasable and Programmable Read Only Memory, commonly known as EEPROM. They are organized as 8192 words of 8 bits (one byte) each. The devices are fabricated with proprietary advanced CMOS process for low power and low voltage applications. These devices are available in standard 8-lead DIP, 8-lead SOP, 8-lead MSOP, 8-lead TSSOP, 8-lead UDFN, 5-lead SOT23, and 5-lead TSOT23 packages. A standard 2-wire serial interface is used to address all read and write functions. Our extended VCC range (1.8V to 5.5V) devices enables wide spectrum of applications. FEATURES  Low voltage and low power operations: 24C64: VCC = 1.8V to 5.5V  32 bytes page write mode.  Partial page write operation allowed.  Internally organized: 4,096 × 8 (64K).  Standard 2-wire bi-directional serial interface.  Schmitt trigger, filtered inputs for noise protection.  Self-timed Write Cycle (5ms maximum).  1000 kHz (2.5V-5.5V), 400 kHz (1.8V) Compatibility.  Automatic erase before write operation.  Write protect pin for hardware data protection.  High reliability: typically 1,000,000 cycles endurance.  100 years data retention.  Industrial temperature range (-40℃ to 85℃).  Standard 8-lead DIP/SOP/MSOP/TSSOP/UDFN and 5-lead SOT23/TSOT23 Pb-free packages. ORDERING INFORMATION DEVICE 24C64S 24C64N 24C64BN XBLW version 1.0 Package Type SOT23-5 DIP-8 SOP-8 MARKING 24C64S 24C64N 24C64BN Packing Tape Tube Tape Packing QTY 3000/Reel 2000/Box 4000/Reel 文档仅供参考,实际应用测试为准 www.xinboleic.com     技术支持热线:4009682003 第 1 页 共 20 页 XBLW 24C64 Two-Wire Serial EEPROM 64K(8-bit wide) PIN CONFIGURATION Pin Name A2, A1, A0 SDA SCL WP NC VCC GND Pin Function Device Address Inputs Serial Data Input / Open Drain Output Serial Clock Input Write Protect No- Connect Power Supply Ground All these packaging types come in Pb-free certified. ABSOLUTE MAXIMUM RATINGS Industrial operating temperature ............................................................................................................ -4 0 ℃ to 85 ℃ Storage temperature .............................................................................................................................. -50 ℃ to 125 ℃ Input voltage on any pin relative to ground .................................................................................... -0.3V to VCC +0.3V Maximum voltage .......................................................................................................................................................... 8V ESD protection on all pins .................................................................................................................................... >4000V * Stresses exceed those listed under “ Absolute Maximum Rating” may cause permanent damage to the device. Functional operation of the device at conditions beyond those listed in the specification is not guaranteed. Prolonged exposure to extreme conditions may affect device reliability or functionality. XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com     技术支持热线:4009682003 第 2 页 共 20 页 XBLW 24C64 Two-Wire Serial EEPROM 64K(8-bit wide) Block Diagram Block Diagram PIN DESCRIPTIONS (A) DEVICE / CHIP SELECT ADDRESSES (A2, A1, A0) These are the chip select input signals for the serial EEPROM devices. Typically, these signals are hardwired to either VIH or VIL. If left unconnected, they are internally recognized as VIL. (B) SERIAL CLOCK (SCL) The rising edge of this SCL input is to latch data into the EEPROM device while the falling edge of this clock is to clock data out of the EEPROM device. (C) SERIAL DATA LINE (SDA) XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com     技术支持热线:4009682003 第 3 页 共 20 页 XBLW 24C64 Two-Wire Serial EEPROM 64K(8-bit wide) SDA data line is a bi-directional signal for the serial devices. It is an open drain output signal and can be wiredOR with other open-drain output devices. (D) WRITE PROTECT (WP) The 24C64 devices have a WP pin to protect the whole EEPROM array from programming. Programming operations are allowed if WP pin is left un-connected or input to VIL. Conversely all programming functions are disabled if WP pin is connected to VIH or VCC. Read operations is not affected by the WP pin’s input level. MEMORY ORGANIZATION The 24C64devices have 256 pages. Since each page has 32 bytes, random word addressing to 24C64 will require 13 bits data word addresses respectively. DEVICE OPERATION (A) SERIAL CLOCK AND DATA TRANSITIONS The SDA pin is typically pulled to high by an external resistor. Data is allowed to change only when Serial clock SCL is at VIL. Any SDA signal transition may interpret as either a START or STOP condition as described below. (B) START CONDITION With SCL ≥ VIH, a SDA transition from high to low is interpreted as a START condition. All valid commands must begin with a START condition. (C) STOP CONDITION With SCL ≥ VIH, a SDA transition from low to high is interpreted as a STOP condition. All valid read or write commands end with a STOP condition. The device goes into the STANDBY mode if it is after a read command. A STOP condition after page or byte write command will trigger the chip into the STANDBY mode after the self-timed internal programming finish (see Figure 1). (D) ACKNOWLEDGE The 2-wire protocol transmits address and data to and from the EEPROM in 8 bit words. The EEPROM acknowledges the data or address by outputting a "0" after receiving each word. The ACKNOWLEDGE signal occurs on the 9th serial clock after each word. (E) STANDBY MODE The EEPROM goes into low power STANDBY mode after a fresh power up, after receiving a STOP bit in read mode, or after completing a self-time internal programming operation. XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com     技术支持热线:4009682003 第 4 页 共 20 页 XBLW 24C64 Two-Wire Serial EEPROM 64K(8-bit wide) Figure1: Timing diagram for START and STOP conditions START Condition Figure 2: Timing diagram for output ACKNOWLEDGE DEVICE ADDRESSING The 2-wire serial bus protocol mandates an 8 bits device address word after a START bit condition to invoke a valid read or write command. The first four most significant bits of the device address must be 1010, which is common to all serial EEPROM devices. The next three bits are device address bits. These three device address bits (5th, 6th and 7th) are to match with the external chip select/address pin states. If a match is made, the EEPROM device outputs an ACKNOWLEDGE signal after the 8th read/write bit, otherwise the chip will go into STANDBY mode. However, matching may not be needed for some or all device address bits (5th, 6th and 7th) as noted below. The last or 8th bit is a read/write command bit. If the 8th bit is at VIH then the chip goes into read mode. If a “0” is detected, the device enters programming mode. XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com     技术支持热线:4009682003 第 5 页 共 20 页 XBLW 24C64 Two-Wire Serial EEPROM 64K(8-bit wide) WRITE OPERATIONS (A) BYTE WRITE A write operation requires two 8-bit data word address following the device address word and ACKNOWLEDGE signal. Upon receipt of this address, the EEPROM will respond with a “0” and then clock in the first 8-bit data word. Following receipt of the 8-bit data word, the EEPROM will again output a “0”. The addressing device, such as a microcontroller, must terminate the write sequence with a STOP condition. At this time the EEPROM enters into an internally-timed write cycle state. All inputs are disabled during this write cycle and the EEPROM will not respond until the writing is completed (Figure 3). (B) PAGE WRITE The 64K EEPROM are capable of 32-byte page write. A page write is initiated the same way as a byte write, but the microcontroller does not send a STOP condition after the first data word is clocked in. The microcontroller can transmit up to 31 more data words after the EEPROM acknowledges receipt of the first data word. The EEPROM will respond with a “0” after each data word is received. The microcontroller must terminate the page write sequence with a STOP condition (see Figure 4). The lower five bits of the data word address are internally incremented following the receipt of each data word. The higher data word address bits are not incremented, retaining the memory page row location. If more than 32 data words are transmitted to the EEPROM, the data word address will “roll over” and the previous data will be overwritten. (C) ACKNOWLEDGE POLLING ACKNOWLEDGE polling may be used to poll the programming status during a self-timed internal programming. By issuing a valid read or write address command, the EEPROM will not acknowledge at the 9th clock cycle if the device is still in the self-timed programming mode. However, if the programming completes and the chip has returned to the STANDBY mode, the device will return a valid ACKNOWLEDGE signal at the 9th clock cycle. READ OPERATIONS The read command is similar to the write command except the 8th read/write bit in address word is set to “1”. The three read operation modes are described as follows: (A) CURRENT ADDRESS READ The EEPROM internal address word counter maintains the last read or write address plus one if the power supply to the device has not been cut off. To initiate a current address read operation, the microcontroller issues a START bit and a valid device address word with the read/write bit (8th) set to “1”. The EEPROM will response with an ACKNOWLEDGE signal on the 9th serial clock cycle. An 8-bit data word will then be serially clocked out. The internal address word counter will then automatically increase by one. For current address read the micro-controller XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com     技术支持热线:4009682003 第 6 页 共 20 页 XBLW 24C64 Two-Wire Serial EEPROM 64K(8-bit wide) will not issue an ACKNOWLEDGE signal on the 18th clock cycle. The micro-controller issues a valid STOP bit after the 18th clock cycle to terminate the read operation. The device then returns to STANDBY mode (see Figure 5). (B) SEQUENTIAL READ The sequential read is very similar to current address read. The micro-controller issues a START bit and a valid device address word with read/write bit (8th) set to “1”. The EEPROM will response with an ACKNOWLEDGE signal on the 9th serial clock cycle. An 8-bit data word will then be serially clocked out. Meanwhile the internally address word counter will then automatically increase by one. Unlike current address read, the micro-controller sends an ACKNOWLEDGE signal on the 18th clock cycle signaling the EEPROM device that it wants another byte of data. Upon receiving the ACKNOWLEDGE signal, the EEPROM will serially clocked out an 8-bit data word based on the incremented internal address counter. If the microcontroller needs another data, it sends out an ACKNOWLEDGE signal on the 27th clock cycle. Another 8-bit data word will then be serially clocked out. This sequential read continues as long as the micro-controller sends an ACKNOWLEDGE signal after receiving a new data word. When the internal address counter reaches its maximum valid address, it rolls over to the beginning of the memory array address. Similar to current address read, the micro controller can terminate the sequential read by not acknowledging the last data word received, but sending a STOP bit afterwards instead (Figure 6). (C) RANDOM READ Random read is a two-steps process. The first step is to initialize the internal address counter with a target read address using a “dummy write” instruction. The second step is a current address read. To initialize the internal address counter with a target read address, the micro-controller issues a START bit first, follows by a valid device address with the read/write bit (8th) set to “0”. The EEPROM will then acknowledge. The micro-controller will then send two address words. Again the EEPROM will acknowledge. Instead of sending a valid written data to the EEPROM, the micro-controller performs a current address read instruction to read the data. Note that once a START bit is issued, the EEPROM will reset the internal programming process and continue to execute the new instruction - which is to read the current address (Figure 7). XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com     技术支持热线:4009682003 第 7 页 共 20 页 XBLW 24C64 Two-Wire Serial EEPROM 64K(8-bit wide) Figure 3: Byte Write Figure 4: Page Write Figure 5: Current Address Read XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com     技术支持热线:4009682003 第 8 页 共 20 页 XBLW 24C64 Two-Wire Serial EEPROM 64K(8-bit wide) Figure 6: Sequential Read Figure 7: Random Read Notes:1) *=Don’t Care bits Figure 8: SCL and SDA Bus Timing XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com     技术支持热线:4009682003 第 9 页 共 20 页 XBLW 24C64 Two-Wire Serial EEPROM 64K(8-bit wide) Electrical Specifications (A) Power-Up Requirements During a power-up sequence, the VCC supplied to the device should monotonically rise from GND to the minimum VCC level, with a slew rate no faster than 0.05 V/μs and no slower then 0.1 V/ms. A decoupling cap should be connected to the VCC PAD which is no smaller than 10nF. (B) Device Reset To prevent inadvertent write operations or any other spurious events from occurring during a powerup sequence, this device includes a Power-on Reset (POR) circuit. Upon power-up, the device will not respond to any commands until the VCC level crosses the internal voltage threshold (VPOR) that brings the device out of Reset and into Standby mode. The system designer must ensure the instructions are not sent to the device until the VCC supply has reached a stable value greater than or equal to the minimum VCC level. Figure 9: Power on and Power down If an event occurs in the system where the VCC level supplied to the device drops below the maximum VPOR level specified, it is recommended that a full power cycle sequence be performed by first driving the VCC pin to GND, waiting at least the minimum tPOFF time and then performing a new power-up sequence in compliance with the requirements defined in this section. XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com     技术支持热线:4009682003 第 10 页 共 20 页 XBLW 24C64 Two-Wire Serial EEPROM 64K(8-bit wide) AC CHARACTERISTICS Symbol 1.8V Min Max Parameter[1] 2.5-5.5V Min Max fSCL tLOW tHIGH tI tAA Clock frequency,SCL 400 1000 Clock pulse width low 1.2 0.6 Clock pulse width high 0.4 0.3 Noise suppression time 120 120 Clock low to data out valid 1.2 0.55 Time the bus must be free before a new tBUF 1.3 1.2 transmission can start tHD.STA START hold time 0.6 0.6 tSU.STA START set-up time 0.6 0.6 tHD.DAT Data in hold time 0 0 tSU.DAT Data in set-up time 100 100 tR Input rise time 300 300 tF Input fall time 300 300 tSU.STO STOP set-up time 0.6 0.6 tDH Date out hold time 200 50 tPWR,R Vcc slew rate at power up 0.1 50 0.1 50 Time required after VCC is stable before tPUP 100 100 the device can accept commands Minimum time at Vcc=0V between power tPORF 500 500 cycles tWR Write cycle time 5 5 Endurance 25℃,Page Mode,3.3V 1,000,000 Notes: 1. This Parameter is expected by characterization but is not fully screened by test. Unit kHz μS μS ns μS μS μS μS μS ns ns ns μS ns V/ms μS ms ms Write Cycles 2. AC Measurement conditions: RL (Connects to Vcc): 1.3KΩ Input Pulse Voltages: 0.3Vcc to 0.7Vcc Input and output timing reference Voltages: 0.5Vcc XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com     技术支持热线:4009682003 第 11 页 共 20 页 XBLW 24C64 Two-Wire Serial EEPROM 64K(8-bit wide) DC CHARACTERISTICS Symbol Parameter Test Conditions Min Typical Max Unit S 5.5 1.0 3.0 V mA mA VCC1 ICC1 ICC2 Power supply Vcc Supply read current Supply write current Vcc @ 5.0V SCL=400 kHz Vcc @ 5.0V SCL=400 kHz 0.4 2.0 ISB1 Supply current Vcc @ 1.8V,VIN = Vcc or Vss <1.0 μA ISB2 Supply current Vcc @ 2.5V,VIN = Vcc or Vss <1.0 μA ISB3 Supply current Vcc @ 5.0V,VIN = Vcc or Vss <1.0 μA IIL ILO VIL VIH VOL1 VOL2 1.8 Input leakage current VIN = Vcc or Vss Output leakage current VIN = Vcc or Vss Input low level -0.6 Input high level Vcc × 0.7 Output low level Vcc @ 1.8V,lOL =0.15 mA Output low level Vcc @3.0V,lOL =2.1 mA Notes: 1. The parameters are expected by characterization but are not fully screened by test. XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com     技术支持热线:4009682003 3.0 3.0 Vcc × 0.3 Vcc + 0.5 0.2 0.4 μA μA V V V V 第 12 页 共 20 页 XBLW 24C64 Two-Wire Serial EEPROM 64K(8-bit wide) PACKAGE OUTLINE DIMENSIONS DIP8 Symbol A A1 A2 B B1 C D E E1 e L E2 XBLW version 1.0 Dimensions In Millimeters Min Max 3.710 0.510 3.200 0.380 4.310 3.600 0.570 Dimensions In Inches Min Max 0.146 0.020 0.126 0.015 1.524(BSC) 0.204 9.000 6.200 7.320 0.142 0.022 0.060(BSC) 0.360 9.400 6.600 7.920 0.008 0.354 0.244 0.288 2.540(BSC) 3.000 8.400 0.170 0.014 0.370 0.260 0.312 0.100(BSC) 3.600 9.000 0.118 0.331 文档仅供参考,实际应用测试为准 www.xinboleic.com     技术支持热线:4009682003 0.142 0.354 第 13 页 共 20 页 XBLW 24C64 Two-Wire Serial EEPROM 64K(8-bit wide) SOP8 Symbol A A1 A2 b c D E E1 e L θ XBLW version 1.0 Dimensions In Millimeters Min Max 1.350 0.100 1.350 0.330 0.170 4.700 3.800 5.800 1.750 0.250 1.550 0.510 0.250 5.100 4.000 6.200 Dimensions In Inches Min Max 0.053 0.004 0.053 0.013 0.006 0.185 0.150 0.228 1.270(BSC) 0.400 0° 0.069 0.010 0.061 0.020 0.010 0.200 0.157 0.244 0.050(BSC) 1.270 8° 0.016 0° 文档仅供参考,实际应用测试为准 www.xinboleic.com     技术支持热线:4009682003 0.050 8° 第 14 页 共 20 页 XBLW 24C64 Two-Wire Serial EEPROM 64K(8-bit wide) MSOP8 Symbol A A1 A2 b c D e E E1 L θ XBLW version 1.0 Dimensions In Millimeters Min Max 0.820 1.100 0.020 0.150 0.750 0.950 0.250 0.380 0.090 0.230 2.900 3.100 0.65(BSC) 2.900 3.100 4.750 5.050 0.400 0.800 0° 6° Dimensions In Inches Min Max 0.320 0.043 0.001 0.006 0.030 0.037 0.010 0.015 0.004 0.009 0.114 0.122 0.026(BSC) 0.114 0.122 0.187 0.199 0.016 0.031 0° 6° 文档仅供参考,实际应用测试为准 www.xinboleic.com     技术支持热线:4009682003 第 15 页 共 20 页 XBLW 24C64 Two-Wire Serial EEPROM 64K(8-bit wide) TSSOP8 Symbol D E b c E1 A A2 A1 e L H θ XBLW version 1.0 Dimensions In Millimeters Min Max 2.900 4.300 0.190 0.090 6.250 0.800 0.020 Dimensions In Inches Min Max 3.100 4.500 0.300 0.200 6.550 1.100 1.000 0.150 0.114 0.169 0.007 0.004 0.246 0.700 0.020 0.031 0.001 0.65(BSC) 0.500 0.026(BSC) 0.25(TYP) 1° 0.122 0.177 0.012 0.008 0.258 0.043 0.039 0.006 0.028 0.01(TYP) 7° 1° 文档仅供参考,实际应用测试为准 www.xinboleic.com     技术支持热线:4009682003 7° 第 16 页 共 20 页 XBLW 24C64 Two-Wire Serial EEPROM 64K(8-bit wide) SOT23-5 Symbol A A1 A2 b c D E E1 e e1 L θ XBLW version 1.0 Dimensions In Millimeters Min Max 1.050 0.000 1.050 0.300 0.100 2.820 1.500 2.650 1.250 0.100 1.150 0.500 0.200 3.020 1.700 2.950 Dimensions In Inches Min Max 0.041 0.000 0.041 0.012 0.004 0.111 0.059 0.104 0.95(BSC) 1.800 0.300 0° 0.049 0.004 0.045 0.020 0.008 0.119 0.067 0.116 0.037(BSC) 2.000 0.600 8° 0.071 0.012 0° 文档仅供参考,实际应用测试为准 www.xinboleic.com     技术支持热线:4009682003 0.079 0.024 6° 第 17 页 共 20 页 XBLW 24C64 Two-Wire Serial EEPROM 64K(8-bit wide) TSOT23-5 Symbol A A1 A2 b c D E E1 e e1 L θ XBLW version 1.0 Dimensions In Millimeters Min Max 0.700 0.900 0.000 0.100 0.700 0.800 0.350 0.500 0.080 0.200 2.820 3.020 1.600 1.700 2.650 2.950 0.95(BSC) 1.90(BSC) 0.300 0.600 0° 8° Dimensions In Inches Min Max 0.028 0.035 0.000 0.004 0.028 0.031 0.014 0.020 0.003 0.008 0.111 0.119 0.063 0.067 0.104 0.116 0.037(BSC) 0.075(BSC) 0.012 0.024 0° 8° 文档仅供参考,实际应用测试为准 www.xinboleic.com     技术支持热线:4009682003 第 18 页 共 20 页 XBLW 24C64 Two-Wire Serial EEPROM 64K(8-bit wide) UDFN8 Symbol A A1 b b1 C D D2 e Nd E E2 L h XBLW version 1.0 Dimensions In Millimeters Min Max 0.450 0.550 0.000 0.050 0.180 0.300 0.160REF 0.100 0.200 1.900 2.100 1.400 1.600 0.500BSC 1.500BSC 2.900 3.100 1.500 1.700 0.300 0.500 0.200 0.300 Dimensions In Inches Min Max 0.017 0.021 0.000 0.002 0.007 0.039 0.006REF 0.004 0.008 0.075 0.083 0.055 0.062 0.020BSC 0.059BSC 0.114 0.122 0.059 0.067 0.012 0.020 0.066 0.12 文档仅供参考,实际应用测试为准 www.xinboleic.com     技术支持热线:4009682003 第 19 页 共 20 页 XBLW 24C64 Two-Wire Serial EEPROM 64K(8-bit wide) Statement:  Shenzhen xinbole electronics co., ltd. reserves the right to change the product specifications, without notice! Before placing an order, the customer needs to confirm whether the information obtained is the latest version, and verify the integrity of the relevant information.  Any semiconductor product is liable to fail or malfunction under certain conditions, and the buyer shall be responsible for complying with safety standards in the system design and whole machine manufacturing using Shenzhen xinbole electronics co., ltd products, and take appropriate security measures to avoid the potential risk of failure may result in personal injury or property losses of the situation occurred!  Product performance is never ending, Shenzhen xinbole electronics co., ltd will be dedicated to provide customers with better performance, better quality of integrated circuit products. XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com     技术支持热线:4009682003 第 20 页 共 20 页
24C64BN 价格&库存
很抱歉,暂时无法提供与“24C64BN”相匹配的价格&库存,您可以联系我们找货
