XBLW CD4072
Positive Dual 4-Input
General Description
The CD4072 provides the positive dual 4-input OR function. The outputs are fully buffered for highest noise
immunity and pattern insensitivity of output impedance.
It operates over a recommended VDD power supply range of 3V to 15V referenced to VSS (usually ground).
Unused inputs must be connected to VDD, VSS, or another input.
Features
Wide supply voltage range from 3V to 15V
Fully static operation
5V, 10V, and 15V parametric ratings
Standardized symmetrical output characteristics
Inputs and outputs are protected against eletrostatic effects
Specified from -40℃ to +105℃
Packaging information: DIP14/SOP14/TSSOP14
ORDERING INFORMATION
DEVICE
Package Type
MARKING
Packing
Packing QTY
CD4072BE
CD4072BDTR
CD4072BTDTR
DIP-14
SOP-14
TSSOP-14
CD4072BE
CD4072B
CD4072B
Tube
Tape
Tape
1000/Box
2500/Reel
3000/Reel
XBLW version 1.0
文档仅供参考,实际应用测试为准
第 1 页 共 11 页
XBLW CD4072
Block Diagram And Pin Description
Block Diagram
Figure 1. Functional diagram
Figure 2. Logic diagram(one gate)
Pin Configurations
XBLW version 1.0
文档仅供参考,实际应用测试为准
第 2 页 共 11 页
XBLW CD4072
Pin Description
Pin No.
Pin Name
Description
1
2
3
4
5
6
7
8
9
10
11
12
13
14
1Y
1A
1B
1C
1D
n.c.
VSS
n.c.
2A
2B
2C
2D
2Y
VDD
data output
data input
data input
data input
data input
not connected
ground (0V)
not connected
data input
data input
data input
data input
data output
supply voltage
Function Table
Input
Output
nA
nB
nC
L
L
L
H
X
X
X
H
X
X
X
H
X
X
X
Note: H=HIGH voltage level; L=LOW voltage level;X=don’t care
nD
L
X
X
X
H
nY
L
H
H
H
H
Electrical Parameter
Absolute Maximum Ratings (Voltages are referenced to VSS (ground=0V), unless otherwise specified.)
Parameter
Symbol
Conditions
Min.
Max.
Unit
supply voltage
DC input current
input voltage
storage temperature
total power
dissipation
device dissipation
VDD
IIK
VI
Tstg
any one input
all inputs
-0.5
-0.5
-65
+18
±10
VDD +0.5
+150
V
mA
V
Ptot
500
mW
100
mW
Soldering
temperature
XBLW version 1.0
P
TL
per output transistor
DIP
10s
SOP
文档仅供参考,实际应用测试为准
245
250
第 3 页 共 11 页
XBLW CD4072
Note:
[1] For DIP14 packages: above 70℃ the value of Ptot derates linearly with 12mW/K.
[2] For SOP14 packages: above 70℃ the value of Ptot derates linearly with 8mW/K.
[3] For (T)SSOP14 packages: above 60℃ the value of Ptot derates linearly with 5.5mW/K.
Recommended Operating Conditions
Parameter
Symbol
Conditions
Min.
Typ.
Max.
Unit
supply voltage
ambient
temperature
VDD
3
15
V
Tamb
in free air
-40
+105
Electrical Characteristics
DC Characteristics 1 (Tamb=25℃, voltages are referenced to VSS (ground=0V), unless otherwise specified.)
Parameter
supply current
Symbol
IDD
LOW-level
output current
IOL
HIGH-level
output current
IOH
LOW-level
output voltage
VOL
HIGH-level
output voltage
VOH
LOW-level
input voltage
VIL
HIGH-level
input voltage
VIH
XBLW version 1.0
VO
Conditions(V)
VIN
VDD
Min.
Tamb=25℃
Typ.
Max.
Unit
0, 5
5
0.01
0.25
μA
0, 10
10
0.01
0.5
μA
0, 15
15
0.01
1
μA
0.4
0.5
1.5
4.6
2.5
9.5
13.5
0.5, 4.5
1, 9
1.5, 13.5
4.5
9
13.5
0, 5
0, 10
0, 15
0, 5
0, 5
0, 10
0, 15
0, 5
0, 10
0, 15
0, 5
0, 10
0, 15
5
10
15
5
5
10
15
5
10
15
5
10
15
5
10
15
5
10
15
0.51
1.3
3.4
-0.51
-1.6
-1.3
-3.4
4.95
9.95
14.95
3.5
7
11
1
2.6
6.8
-1
-3.2
-2.6
-6.8
10
15
0.05
0.05
0.05
1.5
3
4
mA
mA
mA
mA
mA
mA
mA
V
V
V
V
V
V
V
V
V
V
V
V
文档仅供参考,实际应用测试为准
第 4 页 共 11 页
XBLW CD4072
input leakage
II
current
DC Characteristics 2
0, 15
15
±10-5
μA
±0.1
(Tamb=-40℃ to +105℃, voltages are referenced to VSS (ground=0V), unless otherwise specified.)
Parameter
supply
current
Symbol
IDD
LOW-level
output
current
IOL
HIGH-level
output
current
IOH
LOW-level
output
voltage
VOL
HIGH-level
output
voltage
VOH
LOW-level
input voltage
VIL
HIGH-level
input voltage
VIH
input leakage
current
II
XBLW version 1.0
Conditions(V)
VO
VIN VDD
Tamb=-40℃
Min.
Max.
Tamb=+85℃
Min. Max.
Tamb=+105℃
Min. Max.
Unit
0, 5
5
0.25
7.5
7.5
μA
0, 10
10
0.5
15
15
μA
0, 15
15
1
30
30
μA
0.4
0.5
1.5
4.6
2.5
9.5
13.5
0.5, 4.5
1, 9
1.5, 13.5
4.5
9
13.5
0, 5
0, 10
0, 15
0, 5
0, 5
0, 10
0, 15
0, 5
0, 10
0, 15
0, 5
0, 10
0, 15
5
10
15
5
5
10
15
5
10
15
5
10
15
5
10
15
5
10
15
0.61
1.5
4
-0.61
-1.8
-1.5
-4
4.95
9.95
14.95
3.5
7
11
0.05
0.05
0.05
1.5
3
4
0.42
1.1
2.8
-0.42
-1.3
-1.1
-2.8
4.95
9.95
14.95
3.5
7
11
0.05
0.05
0.05
1.5
3
4
0.36
0.9
2.4
-0.36
-1.15
-0.9
-2.4
4.95
9.95
14.95
3.5
7
11
0.05
0.05
0.05
1.5
3
4
mA
mA
mA
mA
mA
mA
mA
V
V
V
V
V
V
V
V
V
V
V
V
0, 15
15
±0.1
±1.0
±1.0
μA
文档仅供参考,实际应用测试为准
第 5 页 共 11 页
XBLW CD4072
AC Characteristics (Tamb=25℃, VSS=0V, tr, tf=20ns, CL=50pF, RL=200KΩ, unless otherwise specified.)
Parameter
Symbol
Conditions
propagation
delay time
tPHL, tPLH
see Figure 4
transition time
tTHL, tTLH
see Figure 4
input
capacitance
CI
Min.
Typ.
Max.
Unit
125
60
45
100
50
40
250
120
90
200
100
80
ns
ns
ns
ns
ns
ns
5
7.5
pF
VDD=5V
VDD=10V
VDD=15V
VDD=5V
VDD=10V
VDD=15V
any input
Testing Circuit
AC Testing Circuit
Figure 3. Test circuit for switching times
Definitions for test circuit:
DUT=Device Under Test
CL=Load capacitance including jig and probe capacitance.
RT=Termination resistance should be equal to the output impedance Zo of the pulse generator.
XBLW version 1.0
文档仅供参考,实际应用测试为准
第 6 页 共 11 页
XBLW CD4072
AC Testing Waveforms
Figure 4. Propagation delay, output transition time
Measurement Points
Supply voltage
VDD
5V to 15V
Input
VM
0.5×VDD
Output
VM
0.5×VDD
Test Data
Supply voltage
VDD
VI
tr, tf
Load
CL
5V to 15V
VSS or VDD
≤20ns
50pF
XBLW version 1.0
Input
文档仅供参考,实际应用测试为准
第 7 页 共 11 页
XBLW CD4072
Package Information
DIP14
Symbol
A
A1
A2
B
B1
C
D
E
E1
e
L
E2
XBLW version 1.0
Dimensions In Millimeters
Min
Max
3.710
4.310
0.510
3.200
3.600
0.380
0.570
1.524(BSC)
0.204
0.360
18.800
19.200
6.200
6.600
7.320
7.920
2.540(BSC)
3.000
3.600
8.400
9.000
文档仅供参考,实际应用测试为准
Dimensions In Inches
Min
Max
0.146
0.170
0.020
0.126
0.142
0.015
0.022
0.060(BSC)
0.008
0.014
0.740
0.756
0.244
0.260
0.288
0.312
0.100(BSC)
0.118
0.142
0.331
0.354
第 8 页 共 11 页
XBLW CD4072
SOP14
XBLW version 1.0
文档仅供参考,实际应用测试为准
第 9 页 共 11 页
XBLW CD4072
TSSOP14
SYMBOL
A
A1
A2
A3
b
b1
c
c1
D
E1
E
e
L
L1
θ
XBLW version 1.0
文档仅供参考,实际应用测试为准
MILLIMETER
MIN
MAX
1.20
0.05
0.15
0.90
1.05
0.39
0.49
0.20
0.30
0.19
0.25
0.13
0.19
0.12
0.14
4.86
5.06
4.30
4.50
6.20
6.60
0.65BSC
0.45
0.75
1.00BSC
0°
8°
第 10 页 共 11 页
XBLW CD4072
Statements And Notes
Part name
Lead and
lead
compounds
Lead frame
Plastic resin
Chip
The lead
Plastic sheet
installed
explanation
Cadmium
and
cadmium
compounds
Hazardous substances or Elements
Polybro
Hexavalent
Polybro
minated
Dibutyl
chromium
minated
phthalate
biphenyl
compounds biphenyls
ethers
Mercury
and
mercury
compounds
Butyl
benzyl
phthalate
Di-2ethylhexyl
phthalate
Diisobutyl
phthalate
○: Indicates that the content of hazardous substances or elements in the detection limit of the following the SJ/T11363-2006 standard.
×: Indicates that the content of hazardous substances or elements exceeding the SJ/T11363-2006 Standard limit requirements
Statement:
Shenzhen xinbole electronics co., ltd. reserves the right to change the product specifications, without notice!
Before placing an order, the customer needs to confirm whether the information obtained is the latest version,
and verify the integrity of the relevant information.
Any semiconductor product is liable to fail or malfunction under certain conditions, and the buyer shall be
responsible for complying with safety standards in the system design and whole machine manufacturing using
Shenzhen xinbole electronics co., ltd products, and take appropriate security measures to avoid the potential risk
of failure may result in personal injury or property losses of the situation occurred!
Product performance is never ending, Shenzhen xinbole electronics co., ltd will be dedicated to provide
customers with better performance, better quality of integrated circuit products.
XBLW version 1.0
文档仅供参考,实际应用测试为准
第 11 页 共 11 页
