ETA5055V120DS2F
ETA5055V120DS2F
    ETA(钰泰半导体)
ETA5055V120DS2F 数据手册
ETA5055 Ultra-High PSRR, Ultra-Low Iq, 500mA LDO for RF and Analog Circuits DESCRIPTION FEATURES ETA5055 is a low-dropout (LDO) linear voltage regulator that features ultra-high power supply rejection ratio (PSRR), ultra-low quiescent current, fast start-up, and excellent line and load transient responses. Its PSRR can be as high as 102dB at 1.2V output. Therefore, ETA5055 is an ideal power supply for noise-sensitive applications such as RF  transmissions, cellphones, CMOS sensors and audios etc.   ETA5055 is available in DFN1X1-4, DFN2x2-6, SOT23-5, and CSP-4 packages.     Ultra-High PSRR up to 102dB Typ. 94dB at 1KHz Ultra-Low Quiescent Current: 4.5uA 500mA Output Current Ultra-Low Dropout Voltage Stable with a Wide Range of Ceramic Capacitor, Larger than 1μF Excellent Load and Line Transient Response RoHS Compliant APPLICATIONS    RF Power Smartphones, Tablets Cameras, DVRs, STB TYPICAL APPLICATION IN VIN 1uF OUT ETA5055 VOUT 1uF EN EN GND ORDERING INFORMATION PART No. PACKAGE TOP MARK Pcs/Reel ETA5055VXXXDS2F SOT23-5 PPYW 3000 ETA5055VXXXDD2G DFN2x2-6 PPYW 3000 ETA5055VXXXDD1E DFN1x1-4 PP YW 10000 ETA5055VXXXDF1E DFN1x1-4 PP YW 10000 ETA5055VXXXDCNE CSP-4 P 10000 XXX: voltage code www.etasolution.com ETA5055 Rev2.1 e.g., 120=1.2V 1 PP/P: product code YW: data code Empower, Transcend, Achieve! ETA5055 PIN CONFIGURATION ABSOLUTE MAXIMUM RATINGS (Note: Exceeding these limits may damage the device. Exposure to absolute maximum rating conditions for long periods may affect device reliability.) OUT 1 4 IN 3 EN IN 1 GND 2 EN 3 5 OUT 4 NC IN, EN, OUT Voltage.................................–0.3V to 6V Operating Temperature Range …...……–40° C to 85° C Storage Temperature Range …...….…–55° C to 150° C Thermal Resistance JA JC CSP-4………..……….........45…......................... ° C/W SOT23-5…………..…........180….......90............. ° C/W DFN1x1-4…………............120….......60............. ° C/W DFN2x2-6…………….........80…........30............. °C/W Lead Temperature (Soldering 10sec) ……....…..260° C ESD HBM (Human Body Mode)…………..….…….4KV ESD CDM (Charged Device Mode)……….……….1KV ETA5055 GND 2 ETA5055 DFN1x1-4 SOT23-5 OUT 1 NC 2 GND 3 ETA5055 GND 6 IN 5 NC A OUT GND ETA5055 EN 4 2 1 B DFN2x2-6 Top View Not in Scale IN EN CSP-4 ELECTRICAL CHARACTERISTICS (VIN = VOUT+1V, CIN=1µ F, COUT=1µ F unless otherwise specified. Typical values are at TA = 25° C.) PARAMETER Input Voltage Range (1) Quiescent Current Quiescent Current Shutdown Current Dropout Voltage Continuous Output Current Output Current Limit Output Foldback Current Limit Line Regulation Load Regulation Output Voltage Range Output Voltage Accuracy Power Supply Rejection Ratio Start-up Time EN pin input Logic Low EN pin input Logic High Discharge Resistance Thermal Shutdown CONDITIONS MIN 1.8 IOUT=0mA, VEN=VIN IOUT=0mA, Dropout VEN = 0V, 1.8V ≤ VIN ≤ 5.5V IOUT =200mA, VOUT=2.8V IOUT =200mA, VOUT=3.3V (CSP-4) TYP MAX 5.5 4.5 10 1 130 90 500 VOUT = 95% VOUT = 0V VOUT + 1V ≤ VIN ≤ 5.5V 1mA ≤ IOUT ≤ 200 mA Available in 100mV steps IOUT =30mA, VOUT>1.8V Freq = 100Hz, IOUT = 20mA Freq = 1KHz, IOUT = 20mA 540 800 400 0.2 15 1.1 -2 3.6 2 96 94 100 1.8V ≤ VIN ≤ 5.5V 1.8V ≤ VIN ≤ 5.5V VIN=2.8V, VEN=0V Rising, IOUT>1mA, Hysteresis =40° C Rising, IOUT=0mA, Hysteresis =40° C dB 0.4 0.9 90 140 135 UNIT V µA µA µA mV mV mA mA mA %/V mV V % µs V V Ω °C °C (1): Minimum VIN is 1.8V or VOUT + VDROPOUT, whichever is greater. www.etasolution.com ETA5055 Rev2.1 2 Empower, Transcend, Achieve! ETA5055 PIN DESCRIPTION SOT23-5 PIN# CSP-4 DFN1x1-4 DFN2x2-6 NAME PIN# PIN# PIN# 1 2 A2 B1 4 2 6 3 IN GND 3 B2 3 4 EN 4 5 NA A1 NA 1 2, 5 1 NC OUT DESCRIPTION Input supply pin Ground pin Enable pin. Drive it high to enable IC, drive it low to disable IC. Not Connected Output of regulator pin TYPICAL CHARACTERISTICS (Typical values are at TA = 25oC unless otherwise specified.) Line Regulation Load Regulation 0.6% 0.6% Vout=1.8V Vout=1.8V 0.4% 0.2% Line Regulation Load Regulation 0.4% 0.0% -0.2% 0.2% 0.0% -0.2% -0.4% Iout=0mA -0.4% Vin=2.5V Iout=100mA -0.6% -0.6% 0 0.1 0.2 0.3 0.4 0.5 2.5 3 3.5 Load Regulation 4.5 5 5.5 Line Regulation 2.0% 2.0% Vout=2.8V Vout=2.8V 1.0% Line Regulation 1.2% Load Regulation 4 Vin(V) Iout(A) 0.4% -0.4% 0.0% -1.0% Iout=0mA -2.0% -1.2% Vin=3.3V Iout=100mA -3.0% -2.0% 0 0.1 0.2 www.etasolution.com ETA5055 Rev2.1 Iout(A) 0.3 0.4 0.5 3 2.5 3 3.5 4 4.5 5 5.5 Vin(V) Empower, Transcend, Achieve! ETA5055 TYPICAL CHARACTERISTICS Cont’d (Typical values are at TA = 25oC unless otherwise specified.) Line Regulation Load Regulation 0.4% 0.6% Vout=3.0V Vout=3.0V 0.2% Line Regulation Load Regulation 0.4% 0.2% 0.0% -0.2% 0.0% -0.2% -0.4% Iout=0mA Vin=3.3V Iout=100mA -0.4% -0.6% 0 0.1 0.2 Iout(A) 0.3 0.4 3 0.5 3.5 4 Vin(V) 4.5 5 5.5 Line Regulation Load Regulation 0.4% 0.6% Vout=3.3V Vout=3.3V 0.4% Line Regulation Load Regulation 0.2% 0.2% 0.0% -0.2% 0.0% Iout=0mA -0.2% -0.4% Vin=3.8V Iout=100mA -0.6% -0.4% 0 0.1 0.2 0.3 0.4 0.5 3.5 Iout(A) 4 Iq Vs. Vin 4.5 Vin(V) 5 Vdropout Vs. Iout 12 0.3 Vout=3.3V,Iout=0mA 10 0.25 8 0.2 Vdropout(V) Iq(uA) 5.5 6 4 Vout=3.3V 0.15 0.1 0.05 2 Iq 0 0 0 1 2 3 4 5 6 www.etasolution.com ETA5055 Rev2.1 0 100 200 300 400 500 Iout(mA) Vin(V) 4 Empower, Transcend, Achieve! ETA5055 TYPICAL CHARACTERISTICS Cont’d (Typical values are at TA = 25oC unless otherwise specified.) Vdropout Vs. Iout Vdropout Vs. Iout 0.5 0.4 0.35 Vout=1.8V Vout=2.8V 0.4 Vdropout(V) Vdropout(V) 0.3 0.25 0.2 0.15 0.1 0.3 0.2 0.1 0.05 0 0 0 100 200 300 400 500 0 100 200 Iout(mA) 300 400 PSRR Vs. Freq. Vdropout Vs. Iout (CSP-4 Package) 110 0.25 100 Vout=1.2V 90 Vout=3.3V 0.2 500 Iout(mA) PSRR(dB) Vdropout(V) 80 0.15 0.1 70 60 50 40 Iout=10mA Iout=20mA Iout=100mA Iout=250mA 30 0.05 20 10 0 0 0 0.1 0.2 Iout(A) 0.3 0.4 0.5 0.1 1 PSRR Vs. Freq. 100 1000 PSRR Vs. Freq. 100 100 90 Vout=1.8V 80 70 70 60 60 50 40 30 10 50 40 Iout=10mA Iout=20mA Iout=100mA Iout=250mA 30 Iout=10mA Iout=20mA Iout=100mA Iout=250mA 20 Vout=3.3V 90 80 PSRR(dB) PSRR(dB) 10 Frequency(KHz) 20 10 0 0 0.1 1 10 Frequency(KHz) www.etasolution.com ETA5055 Rev2.1 100 1000 5 0.1 1 10 Frequency(KHz) 100 1000 Empower, Transcend, Achieve! ETA5055 TYPICAL CHARACTERISTICS Cont’d (Typical values are at TA = 25oC unless otherwise specified.) Load Transient Response Vin=2.8V,Vout=1.8V,Iout=1mA to 250mA Load Transient Response Vin=2.8V,Vout=1.8V,Iout=250mA to 1mA Vout Vout Iout Iout 10mV/div 200mA/div 10mV/div Load Transient Response Vin=5V,Vout=3.3V,Iout=1mA to 250mA 200mA/div Load Transient Response Vin=5V,Vout=3.3V,Iout=250mA to 1mA Vout Vout Iout Iout 20mV/div 100mA/div 20mV/div Line Transient Response Vin=2.3V-5V,Vout=1.8V,Iout=10mA Line Transient Response Vin=3.8V-5V,Vout=3.3V,Iout=10mA Vout Vout Vin Vin 5mV/div www.etasolution.com ETA5055 Rev2.1 100mA/div 2V/div 10mV/div 6 2V/div Empower, Transcend, Achieve! ETA5055 FUNCTIONAL BLOCK DIAGRAM VIN VOUT 90Ω EN REGULATOR OFF ILIMS BIAS BANDGAP RESISTOR NETWORK GND THERMAL MONITOR RES 5pF FUNCTIONAL DESCRIPTION The ETA5055 family of LDO regulators has been optimized for application in noise-sensitive equipment. The device features extremely low dropout voltages, high PSRR, low output noise, low quiescent current, and enable-input to reduce supply currents to less than 1μA when the regulator is turned off. Enable Sequence ETA5055 is enabled when all below conditions happen. Otherwise, ETA5055 is in standby mode.  EN pin voltage above Logic High level  VIN is higher than Under-Voltage-Lock-Out Level.  Junction Temperature is not at Over-Temperature Protection level. Once all above conditions happen, ETA5055 first enable internal 2.4V regulator, before enable BIAS, and BANDGAP. Finally, when internal bias ready, ETA5055 enable LDO core. ETA5055 is completed forced in shutdown mode when EN pin is at below LOGIC_LOW that supply current is less than 1μA. Otherwise, part only shutdown the VOUT while other circuit still in operation. Once ETA5055 is in shutdown conditions, Output is discharged by 90Ω resistor. Output Current Limit and Foldback Current Limit ETA5055 family features an internal current limit. In normal operation, the ETA5055 limits output current to approximately 800mA. When current limiting engages, the output voltage scales back linearly until the over current condition ends. In case output is in hard short conditions, ETA5055 also features an internal foldback limit that reduces the output current limit to a lower level, 400mA, then reduce power dissipation ratings of the package. Over-Temperature Protection Thermal protection disables the output when the junction temperature rises to approximately 150° C, allowing the device to cool down. When the junction temperature cools to approximately 120° C, the output circuitry is again enabled. Depending on power dissipation, thermal resistance, and ambient temperature, the thermal protection circuit may cycle on and off. This cycling limits regulator dissipation, protecting the device from damage as a result of overheating. www.etasolution.com ETA5055 Rev2.1 7 Empower, Transcend, Achieve! ETA5055 PACKAGE OUTLINE Package: SOT23-5 ETA5055VXXXDS2F www.etasolution.com ETA5055 Rev2.1 8 Empower, Transcend, Achieve! ETA5055 PACKAGE OUTLINE Package: CSP-4 ETA5055VXXXDCNE RECOMMENDED LAND PATTERN www.etasolution.com ETA5055 Rev2.1 9 Empower, Transcend, Achieve! ETA5055 Package: DFN1x1-4 From assembly house1: ETA5055VXXXDF1E 3 4 2 1 From assembly house2: ETA5055VXXXDD1E www.etasolution.com ETA5055 Rev2.1 10 Empower, Transcend, Achieve! ETA5055 Package: DFN2x2-6 ETA5055VXXXDD2G www.etasolution.com ETA5055 Rev2.1 11 Empower, Transcend, Achieve! ETA5055 AVAILABLE PART NUMBER Part Description Part Number Package Mark Pcs/Reel 1.2V With Discharge CSP-4 ETA5055V120DCNE CSP-4 B 10000 1.8V With Discharge CSP-4 ETA5055V180DCNE CSP-4 D 10000 2.8V With Discharge CSP-4 ETA5055V280DCNE CSP-4 F 10000 3.3V With Discharge CSP-4 ETA5055V330DCNE CSP-4 K 10000 1.1V with Discharge DFN1x1-4 ETA5055V110DD1E DFN1x1-4 ev 10000 1.2V with Discharge DFN1x1-4 ETA5055V120DD1E DFN1x1-4 YW CD 10000 YW 1.5V with Discharge DFN1x1-4 ETA5055V150DD1E DFN1x1-4 CN 10000 YW 1.8V with Discharge DFN1x1-4 ETA5055V180DD1E DFN1x1-4 CX 10000 YW 2.8V with Discharge DFN1x1-4 ETA5055V280DD1E DFN1x1-4 C8 10000 YW 2.9V with Discharge DFN1x1-4 ETA5055V290DD1E DFN1x1-4 3.0V with Discharge DFN1x1-4 ETA5055V300DD1E DFN1x1-4 eq 10000 YW Cy 10000 YW 3.3V with Discharge DFN1x1-4 ETA5055V330DD1E DFN1x1-4 Ck 10000 YW 1.1V with Discharge DFN1x1-4 ETA5055V110DF1E DFN1x1-4 ev 10000 YW 1.2V with Discharge DFN1x1-4 ETA5055V120DF1E DFN1x1-4 CD 10000 YW 1.5V with Discharge DFN1x1-4 ETA5055V150DF1E DFN1x1-4 1.8V with Discharge DFN1x1-4 ETA5055V180DF1E DFN1x1-4 CN 10000 YW CX 10000 YW 2.8V with Discharge DFN1x1-4 ETA5055V280DF1E DFN1x1-4 C8 10000 YW 2.9V with Discharge DFN1x1-4 ETA5055V290DF1E DFN1x1-4 eq 10000 YW 3.0V with Discharge DFN1x1-4 ETA5055V300DF1E DFN1x1-4 Cy 10000 YW 3.3V with Discharge DFN1x1-4 ETA5055V330DF1E DFN1x1-4 Ck 10000 1.1V with Discharge SOT23-5 ETA5055V110DS2F SOT23-5 evYW 3000 1.2V with Discharge SOT23-5 ETA5055V120DS2F SOT23-5 WDYW 3000 1.5V with Discharge SOT23-5 ETA5055V150DS2F SOT23-5 WNYW 3000 1.8V with Discharge SOT23-5 ETA5055V180DS2F SOT23-5 WXYW 3000 2.5V with Discharge SOT23-5 ETA5055V250DS2F SOT23-5 WJ∣YW 3000 YW www.etasolution.com ETA5055 Rev2.1 12 Empower, Transcend, Achieve! ETA5055 Part Description Part Number Package Mark Pcs/Reel 2.8V with Discharge SOT23-5 ETA5055V280DS2F SOT23-5 W8YW 3000 2.9V with Discharge SOT23-5 ETA5055V290DS2F SOT23-5 WS∣YW 3000 3.0V with Discharge SOT23-5 ETA5055V300DS2F SOT23-5 WyYW 3000 3.3V with Discharge SOT23-5 ETA5055V330DS2F SOT23-5 WkYW 3000 1.1V with Discharge DFN2X2-6 ETA5055V110DD2G DFN2X2-6 evYW 3000 1.2V with Discharge DFN2X2-6 ETA5055V120DD2G DFN2X2-6 CDYW 3000 1.5V with Discharge DFN2X2-6 ETA5055V150DD2G DFN2X2-6 CNYW 3000 1.8V with Discharge DFN2X2-6 ETA5055V180DD2G DFN2X2-6 CXYW 3000 2.5V with Discharge DFN2X2-6 ETA5055V250DD2G DFN2X2-6 CJ∣YW 3000 2.8V with Discharge DFN2X2-6 ETA5055V280DD2G DFN2X2-6 C8YW 3000 3.0V with Discharge DFN2X2-6 ETA5055V300DD2G DFN2X2-6 CyYW 3000 3.3V with Discharge DFN2X2-6 ETA5055V330DD2G DFN2X2-6 CkYW 3000 TAPE AND REEL INFORMATION Device ETA5055VXXXDCNE Package Type CSP-4 Reel Pins SPQ Reel Diameter Width W1 (mm) (mm) A0 B0 K0 P1 W Pin1 (mm) (mm) (mm) (mm) (mm) Quadrant 4 10000 178 9.5 0.45 0.45 0.34 2 8 Q1 ETA5055VXXXDD1E DFN1x1-4 4 10000 180 9.5 1.16 1.16 0.5 2 8 Q1 ETA5055VXXXDF1E DFN1x1-4 4 10000 180 9.5 1.16 1.16 0.5 2 8 Q1 ETA5055VXXXDD2G DFN2x2-6 6 3000 180 9.5 2.3 2.3 1.1 4 8 Q1 ETA5055VXXXDS2F 5 3000 180 9.5 3.17 3.23 1.37 4 8 Q3 SOT23-5 www.etasolution.com ETA5055 Rev2.1 13 Empower, Transcend, Achieve!
ETA5055V120DS2F 价格&库存
很抱歉,暂时无法提供与“ETA5055V120DS2F”相匹配的价格&库存,您可以联系我们找货
