XBLW LM1875T
20W AUDIO POWER AMPLIFIER
General Description
The XBLW LM1875 is a monolithic power amplifier offering
very low distortion and high quality performance for
consumer audio applications.
The LM1875 delivers 20 wants into a 4 Ω or 8Ω load
on +25V supplies.Using an 8 Ω load and +30V
supplies,over 30 watts of power may be delivered.The
amplifier is designed to operate with a minimum ofexternal
components.Device overload protection consists of both
internal current limit and thernal shutdown.
The LM1875 design takes advantage of advanced
circuit techniques and processing to achieve extremely low
distortion levels even at high output power levels.Other
outstanding features include high gain,fast slew rate and a
wide power bandwidth,large output voltage swing,high
current capability,and a very wide supply range.The
amplifier is internally compensated and stable for gains of
10 or greater.
Features
Up to 30 watts output power
Avo typically 90 dB
Low distortion: 0.015%,1kHz,20W
Wide power bandwidth: 70kHz
Protection for AC and DC short circuits to ground
Themal protection with parole circuit
High current capability: 4A
Wide supply range 16V-50V
Internal output protection diodes
94 dB ripple rejection
APPLICATIONS
High performance audio systems
Bridge amplifiers
Stereo phonographs
Servo amplifiers
Instrument systems
Ordering Information
Product Model
XBLW LM1875T
XBLWversion1.0
Package Type
TO-220B
Marking
Packing
Packing Qty
LM1875T
Tube
1000PCS/Box
文档仅供参考,实际应用测试为准
www.xinboleic.com
技术支持热线:4009682003
第1页共7页
XBLW LM1875T
TYPICAL APPLICATIONS
ABSOLUTE MAXIMUM RATINGS
PARAMETER
Supply Voltage
Input Voltage
Storage Temperature
Junction Temperature
Lead Temperature(Soldering,10 seconds)
SYMBOL
RATING
UNIT
Vs
VIN
Tstg
TJ
TL
50
-VEE ~ Vcc
-65 ~ +150
150
260
V
V
SYMBOL
RATING
THERMAL DATA
DESCRIPTION
Thermal Resistance, Junction-case
Thermal Resistance, Junction-ambient
UNIT
θJC
3
℃/W
θJA
73
℃/W
ELECTRICAL CHARACTERISTICS
Vcc=+25V,-VEE=-25V,TAMBIENT=25℃,RL=8Ω,Av=20(26dB),fo=1kHz,unless otherwise
specified
PARAMETER
SYMBOL
TEST CONDITIONS
MIN
Supply Current
Output Power(Note 1)
Total Harmonic Distortion (Note 1)
Offset Voltage
XBLWversion1.0
Vs
Po
THD
POUT=0W
THD=1%
POUT=20W,fo=1kHz
POUT =20W, fo =20kHz
POUT
=20W,RL=4Ω,fo=1kHz
POUT
=20W,RL=4Ω,fo=20kHz
TYP
MAX
UNIT
70
25
0.015
0.05
0.022
0.07
100
mA
W
0.4
±1
±15
Vos
文档仅供参考,实际应用测试为准
www.xinboleic.com
技术支持热线:4009682003
0.6
mV
第2页共7页
XBLW LM1875T
PARAMETER
Input Bias current
Input Offset Current
Gain-Bandwidth Product
Open Loop Gain
Power Supply Rejection Ratio
Max Slew Rate
Current Limit
Equivalent Input Noise
Voltage
SYMBOL
Iib
IIO
GBW
Gv
PSRR
SR
ILIM
en
CONDITIONS
MIN
Fo=20kHz
DC
Vcc,1kHz,1 Vrms
VEE,1kHz,1 Vrms
20W,8Ω,70kHz BW
VOUT=VSUPPLY – 10V
Rs=600Ω,CCIR
TYP
MAX
UNIT
±0.2
90
95
83
8
4
3
±2
±0.5
µA
µA
MHz
dB
52
52
dB
3
V/µs
A
µVrms
Note 1: Assumes the use of a heat sink having a thermal resistance of 1℃/W and no insulator with an ambient
temperature of 25℃.Because the output limiting circuitry has a negative temperature coefficient,the
maximum output power delivered to a 4Ωload may be slightly reduced when the tab temperature exceeds
55℃ .
TYPICAL APPLICATIONS(CONTINUED)
TYPICAL PERFORMANCE CHARACTERISTICS
XBLWversion1.0
文档仅供参考,实际应用测试为准
www.xinboleic.com
技术支持热线:4009682003
第3页共7页
XBLW LM1875T
XBLWversion1.0
文档仅供参考,实际应用测试为准
www.xinboleic.com
技术支持热线:4009682003
第4页共7页
XBLW LM1875T
XBLWversion1.0
文档仅供参考,实际应用测试为准
www.xinboleic.com
技术支持热线:4009682003
第5页共7页
XBLW LM1875T
XBLWversion1.0
文档仅供参考,实际应用测试为准
www.xinboleic.com
技术支持热线:4009682003
第6页共7页
XBLW LM1875T
Statement:
Shenzhen xinbole electronics co., ltd. reserves the right to change the product specifications, without notice!
Before placing an order, the customer needs to confirm whether the information obtained is the latest version,
and verify the integrity of the relevant information.
Any semiconductor product is liable to fail or malfunction under certain conditions, and the buyer shall be
responsible for complying with safety standards in the system design and whole machine manufacturing using
Shenzhen xinbole electronics co., ltd products, and take appropriate security measures to avoid the potential risk
of failure may result in personal injury or property losses of the situation occurred!
Product performance is never ending, Shenzhen xinbole electronics co., ltd will be dedicated to provide
customers with better performance, better quality of integrated circuit products.
XBLWversion1.0
文档仅供参考,实际应用测试为准
www.xinboleic.com
技术支持热线:4009682003
第7页共7页
很抱歉,暂时无法提供与“LM1875T(XBLW)”相匹配的价格&库存,您可以联系我们找货
