C322J102J40C000
C322J102J40C000
    FARATRONIC(法拉)
    CAP-13X4MM_TM
C322J102J40C000 数据手册
C32 MKP21 series 金属化聚丙烯膜电容器 Metallized polypropylene film capacitor(Box-type) ■ 外形图 Outline Drawing W±0.4, H±0.4, T±0.4 ■ 特点 っ Features ● 金属化聚丙烯膜 ● 高频损耗小 む Metallized polypropylene film む Low loss at high frequency ● 内部温升小 む Small inherent temperature rise ● 塑料外壳(UL94 V-0), 阻燃环氧填充 む Plastic case(UL94 V-0), epoxy resin sealing ■ 主要用途 っ Typical Applications ● 广泛应用于高频、直流、交流和脉冲电路中 ● 电视机、显示器S校正电路 む Widely used in high frequency, DC, AC and pulse circuits む S-correction circuits for TV sets and monitors ■ 技术要求 Specifications 引用标准 Reference Standard GB/T 10190 (IEC 60384-16) 气候类别 Climatic Category 55/105/56 额定温度 Rated Temperature 85Ⓘ 工作温度 Operating Temperature Range -55Ⓘ~105Ⓘ (+85Ⓘ to +105Ⓘ 额定电压 Rated Voltage 160Vdc(90Vac), 250Vdc(160Vac), 400Vdc(220Vac), 630Vdc(250Vac) 1 000Vdc(400Vac), 1 600Vdc(600Vac), 2 000Vdc(700Vac) 电容量范围 Capacitance Range 0.00056μF~15.0μF 电容量偏差 Capacitance Tolerance ±2(G), ±3(H), ±5(J), ±10(K), ±20(M) 耐电压 Voltage Proof 1.6UR (5s) 损耗角正切 Dissipation Factor 绝缘电阻 Insulation Resistance decreasing factor 1.25% per Ⓘ for UR ) -4 10×10 (20Ⓘ, 1kHz) R 100 000MΩ, CN 0.33μF RCN 30 000s, CN >0.33μF (20Ⓘ, 100V, 1min) dV/dt(V/μs) UR(V) 最大脉冲爬升速率 Maximum Pulse Rise Time(dV/ dt):若实际工作电压 U 比额定电压 UR 低,电容器可工 作在更高的 dV/dt 场合,这样 dV/dt 允许值应为右表值 乘以 UR/Uㄌ If the working voltage(U) is lower than the rated voltage(UR),the capacitor can be worked at a higher dV/dt. In this case, the maximum allowed dV/dt is obtain by multiplying the right value with UR /U. P=5.0 P=7.5 P=10.0 P=15.0 P=22.5 P=27.5 160 110 310 190 110 65 55 250 270 660 560 310 130 110 400 440 900 780 600 300 130 630 550 1500 1200 900 400 200 1 000 - - 2200 2 000 800 - 1 600 - - - 4 500 1 800 - 2 000 - - - 9 500 4 500 - 67 C32 ® MKP21 series ■ 产品编码说明 Part number system  15 位产品代码如下: The 15 digits part number is formed as follow: 1 2 3 C 3 2 第 1~3 位 4 5 6 7 8 9 10 11 12 13 14 15 型号代码 Digit 1 to 3 C32= MKP21 第 4~5 位 C32= MKP21 直流额定电压 2C=160V Digit 4 to 5 2E=250V 2G=400V 2J=630V Digit 6 to 8 3 2J=630V Rated capacitance value for example: 103=10×10 pF=0.01μF 容量偏差 Digit 9 Capacitance tolerance G=±2%, H=±3%, J=±5% G=±2%, H=±3%, J=±5% K=±10%, M=±20% K=±10%, M=±20% 引线脚距 P 第 11 位 2G=400V 3 举例:103=10×10 pF=0.01μF 第 10 位 2E=250V 3A=1 000V 3C=1 600V 3D=2 000V 标称容量 第9位 D.C. rated voltage 2C=160V 3A=1 000V 3C=1 600V 3D=2 000V 第 6~8 位 Series code Digit 10 2=5.0mm 3=7.5mm 6=15.0mm 9=22.5mm B=27.5mm Pitch 4=10.0mm 内部特征码 第 12~15 位 引线加工和包装代码 2=5.0mm 3=7.5mm 4=10.0mm 6=15.0mm 9=22.5mm B=27.5mm Digit 11 Internal use Digit 12 to 15 Lead form and packaging code  Table 1 引线加工和包装代码 lead form and packaging code ⺮ 12 呕 Digit 12 ⺮ 13 呕 Digit 13 ⺮ 14 呕 Digit 14 代码 说明 代码 说明 代码 Code explanation Code explanation Code A 弹带包装 ammo-pack C 2 0 代码 explanation Code 表示直脚 1 说明 explanation 产品在连续的两个载带孔之间 each cap.among two consecutive holes P3=12.7mm, H=18.5mm(For pitch=5.0/7.5mm) straight 3 F=7.5mm 4 F=10.0mm 6 F=15.0mm 5 P3=25.4mm; H=18.5mm (For pitch=10.0/15.0mm) (Detaill parameter refer to page 16) 说明 explanation 0 引线长度偏差±0.5mm 或标准长度 直脚 代码 straight lead C in the figure above Code 00 标准的引线长度(18mm ~26 mm) standard lead length 45 68 F=5.0mm 说明 ⺮ 15 呕 Digit 15 引线长度 4.5mm lead length 4.5mm Length tolerance±0.5mm Or standard length C32 MKP21 series ■ 外形尺寸 Dimensions(mm) 160V(90Vac) CN (μF) W H T P d 0.027 7.2 7.5 3.5 5.0 0.033 7.2 7.5 3.5 0.039 7.2 7.5 0.047 7.2 0.056 160V(90Vac) Part number CN (μF) W H T P d Part number 0.5 C322C273-20**** 0.82 17.5 14.5 8.5 15.0 0.8 C322C824-60**** 5.0 0.5 C322C333-20**** 1.0 17.5 16.0 10.0 15.0 0.8 C322C105-60**** 3.5 5.0 0.5 C322C393-20**** 1.2 17.5 16.0 10.0 15.0 0.8 C322C125-60**** 9.5 4.5 5.0 0.6 C322C473-20**** 1.5 17.5 19.0 11.0 15.0 0.8 C322C155-60**** 7.2 9.5 4.5 5.0 0.6 C322C563-20**** 1.8 17.5 19.0 11.0 15.0 0.8 C322C185-60**** 0.068 7.2 9.5 4.5 5.0 0.6 C322C683-20**** 0.47 26.5 15.0 6.0 22.5 0.8 C322C474-90**** 0.082 7.2 10.0 5.0 5.0 0.6 C322C823-20**** 0.56 26.5 15.0 6.0 22.5 0.8 C322C564-90**** 0.10 7.2 10.0 5.0 5.0 0.6 C322C104-20**** 0.68 26.5 15.0 6.0 22.5 0.8 C322C684-90**** 0.12 7.2 11.0 6.0 5.0 0.6 C322C124-20**** 0.82 26.5 16.0 7.0 22.5 0.8 C322C824-90**** 0.15 7.2 11.0 6.0 5.0 0.6 C322C154-20**** 1.0 26.5 16.0 7.0 22.5 0.8 C322C105-90**** 0.068 10.5 9.0 4.0 7.5 0.6 C322C683-30**** 1.2 26.5 17.0 8.5 22.5 0.8 C322C125-90**** 0.082 10.5 9.0 4.0 7.5 0.6 C322C823-30**** 1.5 26.5 17.0 8.5 22.5 0.8 C322C155-90**** 0.10 10.5 11.0 5.0 7.5 0.6 C322C104-30**** 1.8 26.5 18.5 10.0 22.5 0.8 C322C185-90**** 0.12 10.5 11.0 5.0 7.5 0.6 C322C124-30**** 2.2 26.5 20.0 11.0 22.5 0.8 C322C225-90**** 0.15 10.5 12.0 6.0 7.5 0.6 C322C154-30**** 2.7 26.5 22.0 12.0 22.5 0.8 C322C275-90**** 0.18 10.5 12.0 6.0 7.5 0.6 C322C184-30**** 3.3 26.5 22.0 12.0 22.5 0.8 C322C335-90**** 0.082 13.0 9.0 4.0 10.0 0.6 C322C823-40**** 1.0 32.0 18.0 9.0 27.5 0.8 C322C105-B0**** 0.10 13.0 9.0 4.0 10.0 0.6 C322C104-40**** 1.2 32.0 18.0 9.0 27.5 0.8 C322C125-B0**** 0.12 13.0 11.0 5.0 10.0 0.6 C322C124-40**** 1.5 32.0 18.0 9.0 27.5 0.8 C322C155-B0**** 0.15 13.0 11.0 5.0 10.0 0.6 C322C154-40**** 1.8 32.0 18.0 9.0 27.5 0.8 C322C185-B0**** 0.18 13.0 11.0 5.0 10.0 0.6 C322C184-40**** 2.2 32.0 18.0 9.0 27.5 0.8 C322C225-B0**** 0.22 13.0 12.0 6.0 10.0 0.6 C322C224-40**** 2.7 32.0 20.0 11.0 27.5 0.8 C322C275-B0**** 0.27 13.0 12.0 6.0 10.0 0.6 C322C274-40**** 3.3 32.0 20.0 11.0 27.5 0.8 C322C335-B0**** 0.18 17.5 11.0 5.0 15.0 0.8 C322C184-60**** 3.9 32.0 22.0 13.0 27.5 0.8 C322C395-B0**** 0.22 17.5 11.0 5.0 15.0 0.8 C322C224-60**** 4.7 32.0 28.0 14.0 27.5 0.8 C322C475-B0**** 0.27 17.5 11.0 5.0 15.0 0.8 C322C274-60**** 5.6 32.0 24.5 15.0 27.5 0.8 C322C565-B0**** 0.33 17.5 11.0 5.0 15.0 0.8 C322C334-60**** 6.8 32.0 33.0 18.0 27.5 0.8 C322C685-B0**** 0.39 17.5 12.0 6.0 15.0 0.8 C322C394-60**** 8.2 32.0 33.0 18.0 27.5 0.8 C322C825-B0**** 0.47 17.5 12.0 6.0 15.0 0.8 C322C474-60**** 10.0 32.0 33.0 18.0 27.5 0.8 C322C106-B0**** 0.56 17.5 13.5 7.5 15.0 0.8 C322C564-60**** 12.0 32.0 37.0 22.0 27.5 0.8 C322C126-B0**** 0.68 17.5 13.5 7.5 15.0 0.8 C322C684-60**** 15.0 32.0 37.0 22.0 27.5 0.8 C322C156-B0**** 备注 Note 1.“-”表示容量偏差。 - =capacitance tolerance code. M=±20%, K=±10%, J=±5%, H=±3%, G=±2%. 2. **** 表示引线加工和包装代码(见表 1)。 **** =lead form and packing code refer to table 1). 69 C32 ® MKP21 series ■ 外形尺寸 Dimensions(mm) 250V(160Vac) CN (μF) W H T P d 0.012 7.2 7.5 3.5 5.0 0.015 7.2 7.5 3.5 5.0 0.018 7.2 7.5 3.5 0.022 7.2 7.5 0.027 7.2 0.033 7.2 0.039 250V(160Vac) Part number CN (μF) W H T P d Part number 0.5 C322E123-20**** 0.18 17.5 11.0 5.0 15.0 0.8 C322E184-60**** 0.5 C322E153-20**** 0.22 17.5 11.0 5.0 15.0 0.8 C322E224-60**** 5.0 0.5 C322E183-20**** 0.27 17.5 12.0 6.0 15.0 0.8 C322E274-60**** 3.5 5.0 0.5 C322E223-20**** 0.33 17.5 12.0 6.0 15.0 0.8 C322E334-60**** 7.5 3.5 5.0 0.5 C322E273-20**** 0.39 17.5 13.5 7.5 15.0 0.8 C322E394-60**** 7.5 3.5 5.0 0.5 C322E333-20**** 0.47 17.5 13.5 7.5 15.0 0.8 C322E474-60**** 7.2 7.5 3.5 5.0 0.5 C322E393-20**** 0.56 17.5 13.5 7.5 15.0 0.8 C322E564-60**** 0.047 7.2 9.5 4.5 5.0 0.6 C322E473-20**** 0.68 17.5 14.5 8.5 15.0 0.8 C322E684-60**** 0.056 7.2 9.5 4.5 5.0 0.6 C322E563-20**** 0.82 17.5 16.0 10.0 15.0 0.8 C322E824-60**** 0.068 7.2 10.0 5.0 5.0 0.6 C322E683-20**** 1.0 17.5 16.0 10.0 15.0 0.8 C322E105-60**** 0.082 7.2 10.0 5.0 5.0 0.6 C322E823-20**** 1.2 17.5 19.0 11.0 15.0 0.8 C322E125-60**** 0.10 7.2 11.0 6.0 5.0 0.6 C322E104-20**** 0.39 26.5 15.0 6.0 22.5 0.8 C322E394-90**** 0.12 7.2 11.0 6.0 5.0 0.6 C322E124-20**** 0.47 26.5 15.0 6.0 22.5 0.8 C322E474-90**** 0.027 10.5 9.0 4.0 7.5 0.6 C322E273-30**** 0.56 26.5 15.0 6.0 22.5 0.8 C322E564-90**** 0.033 10.5 9.0 4.0 7.5 0.6 C322E333-30**** 0.68 26.5 15.0 6.0 22.5 0.8 C322E684-90**** 0.039 10.5 9.0 4.0 7.5 0.6 C322E393-30**** 0.82 26.5 15.0 6.0 22.5 0.8 C322E824-90**** 0.047 10.5 9.0 4.0 7.5 0.6 C322E473-30**** 1.0 26.5 16.0 7.0 22.5 0.8 C322E105-90**** 0.056 10.5 9.0 4.0 7.5 0.6 C322E563-30**** 1.2 26.5 17.0 8.5 22.5 0.8 C322E125-90**** 0.068 10.5 9.0 4.0 7.5 0.6 C322E683-30**** 1.5 26.5 17.0 8.5 22.5 0.8 C322E155-90**** 0.082 10.5 11.0 5.0 7.5 0.6 C322E823-30**** 1.8 26.5 18.5 10.0 22.5 0.8 C322E185-90**** 0.10 10.5 11.0 5.0 7.5 0.6 C322E104-30**** 2.2 26.5 20.0 11.0 22.5 0.8 C322E225-90**** 0.12 10.5 11.0 5.0 7.5 0.6 C322E124-30**** 2.7 26.5 22.0 12.0 22.5 0.8 C322E275-90**** 0.15 10.5 12.0 6.0 7.5 0.6 C322E154-30**** 0.82 32.0 18.0 9.0 27.5 0.8 C322E824-B0**** 0.18 10.5 12.0 6.0 7.5 0.6 C322E184-30**** 1.0 32.0 18.0 9.0 27.5 0.8 C322E105-B0**** 0.033 13.0 9.0 4.0 10.0 0.6 C322E333-40**** 1.2 32.0 18.0 9.0 27.5 0.8 C322E125-B0**** 0.039 13.0 9.0 4.0 10.0 0.6 C322E393-40**** 1.5 32.0 18.0 9.0 27.5 0.8 C322E155-B0**** 0.047 13.0 9.0 4.0 10.0 0.6 C322E473-40**** 1.8 32.0 18.0 9.0 27.5 0.8 C322E185-B0**** 0.056 13.0 9.0 4.0 10.0 0.6 C322E563-40**** 2.2 32.0 18.0 9.0 27.5 0.8 C322E225-B0**** 0.068 13.0 9.0 4.0 10.0 0.6 C322E683-40**** 2.7 32.0 20.0 11.0 27.5 0.8 C322E275-B0**** 0.082 13.0 9.0 4.0 10.0 0.6 C322E823-40**** 3.3 32.0 20.0 11.0 27.5 0.8 C322E335-B0**** 0.10 13.0 11.0 5.0 10.0 0.6 C322E104-40**** 3.9 32.0 22.0 13.0 27.5 0.8 C322E395-B0**** 0.12 13.0 11.0 5.0 10.0 0.6 C322E124-40**** 4.7 32.0 28.0 14.0 27.5 0.8 C322E475-B0**** 0.15 13.0 11.0 5.0 10.0 0.6 C322E154-40**** 5.6 32.0 24.5 15.0 27.5 0.8 C322E565-B0**** 0.18 13.0 12.0 6.0 10.0 0.6 C322E184-40**** 6.8 32.0 33.0 18.0 27.5 0.8 C322E685-B0**** 0.22 13.0 12.0 6.0 10.0 0.6 C322E224-40**** 8.2 32.0 33.0 18.0 27.5 0.8 C322E825-B0**** 0.10 17.5 11.0 5.0 15.0 0.8 C322E104-60**** 10.0 32.0 33.0 18.0 27.5 0.8 C322E106-B0**** 0.12 17.5 11.0 5.0 15.0 0.8 C322E124-60**** 12.0 32.0 37.0 22.0 27.5 0.8 C322E126-B0**** 0.15 17.5 11.0 5.0 15.0 0.8 C322E154-60**** 15.0 32.0 37.0 22.0 27.5 0.8 C322E156-B0**** 备注 Note 1.“-”表示容量偏差。 - =capacitance tolerance code. M=±20%, K=±10%, J=±5%, H=±3%, G=±2%. 2. **** 表示引线加工和包装代码(见表 1)。 **** =lead form and packing code refer to table 1). 70 C32 MKP21 series ■ 外形尺寸 Dimensions(mm) @ @ 400V(220Vac) CN (μF) W H T P d 400V(220Vac) Part number CN (μF) W H T P d Part number 0.0039 7.2 7.5 3.5 5.0 0.5 C322G392-20**** 0.082 17.5 11.0 5.0 15.0 0.8 C322G823-60**** 0.0047 7.2 7.5 3.5 5.0 0.5 C322G472-20**** 0.10 17.5 11.0 5.0 15.0 0.8 C322G104-60**** 0.0056 7.2 7.5 3.5 5.0 0.5 C322G562-20**** 0.12 17.5 11.0 5.0 15.0 0.8 C322G124-60**** 0.0068 7.2 7.5 3.5 5.0 0.5 C322G682-20**** 0.15 17.5 12.0 6.0 15.0 0.8 C322G154-60**** 0.0082 7.2 7.5 3.5 5.0 0.5 C322G822-20**** 0.18 17.5 12.0 6.0 15.0 0.8 C322G184-60**** 0.010 7.2 7.5 3.5 5.0 0.5 C322G103-20**** 0.22 17.5 13.5 7.5 15.0 0.8 C322G224-60**** 0.012 7.2 7.5 3.5 5.0 0.5 C322G123-20**** 0.27 17.5 13.5 7.5 15.0 0.8 C322G274-60**** 0.015 7.2 9.5 4.5 5.0 0.6 C322G153-20**** 0.33 17.5 14.5 8.5 15.0 0.8 C322G334-60**** 0.018 7.2 9.5 4.5 5.0 0.6 C322G183-20**** 0.39 17.5 16.0 10.0 15.0 0.8 C322G394-60**** 0.022 7.2 9.5 4.5 5.0 0.6 C322G223-20**** 0.47 17.5 16.0 10.0 15.0 0.8 C322G474-60**** 0.027 7.2 10.0 5.0 5.0 0.6 C322G273-20**** 0.56 17.5 19.0 11.0 15.0 0.8 C322G564-60**** 0.033 7.2 11.0 6.0 5.0 0.6 C322G333-20**** 0.68 17.5 19.0 11.0 15.0 0.8 C322G684-60**** 0.039 7.2 11.0 6.0 5.0 0.6 C322G393-20**** 0.18 26.5 15.0 6.0 22.5 0.8 C322G184-90**** 0.047 7.2 11.0 6.0 5.0 0.6 C322G473-20**** 0.22 26.5 15.0 6.0 22.5 0.8 C322G224-90**** 0.010 10.5 9.0 4.0 7.5 0.6 C322G103-30**** 0.27 26.5 15.0 6.0 22.5 0.8 C322G274-90**** 0.012 10.5 9.0 4.0 7.5 0.6 C322G123-30**** 0.33 26.5 15.0 6.0 22.5 0.8 C322G334-90**** 0.015 10.5 9.0 4.0 7.5 0.6 C322G153-30**** 0.39 26.5 16.0 7.0 22.5 0.8 C322G394-90**** 0.018 10.5 9.0 4.0 7.5 0.6 C322G183-30**** 0.47 26.5 16.0 7.0 22.5 0.8 C322G474-90**** 0.022 10.5 9.0 4.0 7.5 0.6 C322G223-30**** 0.56 26.5 17.0 8.5 22.5 0.8 C322G564-90**** 0.027 10.5 9.0 4.0 7.5 0.6 C322G273-30**** 0.68 26.5 17.0 8.5 22.5 0.8 C322G684-90**** 0.033 10.5 11.0 5.0 7.5 0.6 C322G333-30**** 0.82 26.5 18.5 10.0 22.5 0.8 C322G824-90**** 0.039 10.5 11.0 5.0 7.5 0.6 C322G393-30**** 1.0 26.5 20.0 11.0 22.5 0.8 C322G105-90**** 0.047 10.5 11.0 5.0 7.5 0.6 C322G473-30**** 1.2 26.5 22.0 12.0 22.5 0.8 C322G125-90**** 0.056 10.5 12.0 6.0 7.5 0.6 C322G563-30**** 1.5 26.5 22.0 12.0 22.5 0.8 C322G155-90**** 0.068 10.5 12.0 6.0 7.5 0.6 C322G683-30**** 0.56 32.0 18.0 9.0 27.5 0.8 C322G564-B0**** 0.015 13.0 9.0 4.0 10.0 0.6 C322G153-40**** 0.68 32.0 18.0 9.0 27.5 0.8 C322G684-B0**** 0.018 13.0 9.0 4.0 10.0 0.6 C322G183-40**** 0.82 32.0 18.0 9.0 27.5 0.8 C322G824-B0**** 0.022 13.0 9.0 4.0 10.0 0.6 C322G223-40**** 1.0 32.0 18.0 9.0 27.5 0.8 C322G105-B0**** 0.027 13.0 9.0 4.0 10.0 0.6 C322G273-40**** 1.2 32.0 20.0 11.0 27.5 0.8 C322G125-B0**** 0.033 13.0 9.0 4.0 10.0 0.6 C322G333-40**** 1.5 32.0 20.0 11.0 27.5 0.8 C322G155-B0**** 0.039 13.0 9.0 4.0 10.0 0.6 C322G393-40**** 1.8 32.0 22.0 13.0 27.5 0.8 C322G185-B0**** 0.047 13.0 11.0 5.0 10.0 0.6 C322G473-40**** 2.2 32.0 24.5 15.0 27.5 0.8 C322G225-B0**** 0.056 13.0 11.0 5.0 10.0 0.6 C322G563-40**** 2.7 32.0 28.0 14.0 27.5 0.8 C322G275-B0**** 0.068 13.0 11.0 5.0 10.0 0.6 C322G683-40**** 3.3 32.0 33.0 18.0 27.5 0.8 C322G335-B0**** 0.082 13.0 12.0 6.0 10.0 0.6 C322G823-40**** 3.9 32.0 33.0 18.0 27.5 0.8 C322G395-B0**** 0.10 13.0 12.0 6.0 10.0 0.6 C322G104-40**** 4.7 32.0 37.0 22.0 27.5 0.8 C322G475-B0**** 0.068 17.5 11.0 5.0 15.0 0.8 C322G683-60**** 5.6 32.0 37.0 22.0 27.5 0.8 C322G565-B0**** 备注 Note 1.“-”表示容量偏差。 - =capacitance tolerance code. M=±20%, K=±10%, J=±5%, H=±3%, G=±2%. 2. **** 表示引线加工和包装代码(见表 1)。 **** =lead form and packing code refer to table 1). 3. @ 不用作跨线,请参见抗干扰电容器(Page 109)ㄌ @ Not suitable for across-the-line application. Pls refer to Interference Suppression Capacitors(Page 109). 71 C32 ® MKP21 series ■ 外形尺寸 Dimensions(mm) @ @ 630V(250Vac) CN (μF) W H 0.0010 7.2 0.0012 @ 630V(250Vac) Part number CN (μF) 7.5 3.5 5.0 0.5 C322J102-20**** 0.027 7.2 7.5 3.5 5.0 0.5 C322J122-20**** 0.033 0.0015 7.2 7.5 3.5 5.0 0.5 C322J152-20**** 0.0010 13.0 0.0018 7.2 7.5 3.5 5.0 0.5 C322J182-20**** 0.0022 7.2 7.5 3.5 5.0 0.5 0.0027 7.2 0.0033 630V(250Vac) P d Part number CN (μF) 10.5 12.0 6.0 7.5 0.6 C322J273-30**** 0.12 17.5 13.5 7.5 15.0 0.8 C322J124-60**** 10.5 12.0 6.0 7.5 0.6 C322J333-30**** 0.15 17.5 13.5 7.5 15.0 0.8 C322J154-60**** 9.0 4.0 10.0 0.6 C322J102-40**** 0.18 17.5 14.5 8.5 15.0 0.8 C322J184-60**** 0.0012 13.0 9.0 4.0 10.0 0.6 C322J122-40**** 0.22 17.5 16.0 10.0 15.0 0.8 C322J224-60**** C322J222-20**** 0.0015 13.0 9.0 4.0 10.0 0.6 C322J152-40**** 0.27 17.5 19.0 11.0 15.0 0.8 C322J274-60**** 7.5 3.5 5.0 0.5 C322J272-20**** 0.0018 13.0 9.0 4.0 10.0 0.6 C322J182-40**** 0.33 17.5 19.0 11.0 15.0 0.8 C322J334-60**** 7.2 7.5 3.5 5.0 0.5 C322J332-20**** 0.0022 13.0 9.0 4.0 10.0 0.6 C322J222-40**** 0.082 26.5 15.0 6.0 22.5 0.8 C322J823-90**** 0.0039 7.2 9.5 4.5 5.0 0.6 C322J392-20**** 0.0027 13.0 9.0 4.0 10.0 0.6 C322J272-40**** 0.10 26.5 15.0 6.0 22.5 0.8 C322J104-90**** 0.0047 7.2 9.5 4.5 5.0 0.6 C322J472-20**** 0.0033 13.0 9.0 4.0 10.0 0.6 C322J332-40**** 0.12 26.5 15.0 6.0 22.5 0.8 C322J124-90**** 0.0056 7.2 10.0 5.0 5.0 0.6 C322J562-20**** 0.0039 13.0 9.0 4.0 10.0 0.6 C322J392-40**** 0.15 26.5 15.0 6.0 22.5 0.8 C322J154-90**** 0.0068 7.2 10.0 5.0 5.0 0.6 C322J682-20**** 0.0047 13.0 9.0 4.0 10.0 0.6 C322J472-40**** 0.18 26.5 15.0 6.0 22.5 0.8 C322J184-90**** 0.0082 7.2 11.0 6.0 5.0 0.6 C322J822-20**** 0.0056 13.0 9.0 4.0 10.0 0.6 C322J562-40**** 0.22 26.5 16.0 7.0 22.5 0.8 C322J224-90**** 0.010 7.2 11.0 6.0 5.0 0.6 C322J103-20**** 0.0068 13.0 9.0 4.0 10.0 0.6 C322J682-40**** 0.27 26.5 17.0 8.5 22.5 0.8 C322J274-90**** 0.012 7.2 11.0 6.0 5.0 0.6 C322J123-20**** 0.0082 13.0 9.0 4.0 10.0 0.6 C322J822-40**** 0.33 26.5 17.0 8.5 22.5 0.8 C322J334-90**** 0.0010 10.5 9.0 4.0 7.5 0.6 C322J102-30**** 0.010 13.0 9.0 4.0 10.0 0.6 C322J103-40**** 0.39 26.5 18.5 10.0 22.5 0.8 C322J394-90**** 0.0012 10.5 9.0 4.0 7.5 0.6 C322J122-30**** 0.012 13.0 9.0 4.0 10.0 0.6 C322J123-40**** 0.47 26.5 18.5 10.0 22.5 0.8 C322J474-90**** 0.0015 10.5 9.0 4.0 7.5 0.6 C322J152-30**** 0.015 13.0 9.0 4.0 10.0 0.6 C322J153-40**** 0.56 26.5 20.0 11.0 22.5 0.8 C322J564-90**** 0.0018 10.5 9.0 4.0 7.5 0.6 C322J182-30**** 0.018 13.0 9.0 4.0 10.0 0.6 C322J183-40**** 0.68 26.5 22.0 12.0 22.5 0.8 C322J684-90**** 0.0022 10.5 9.0 4.0 7.5 0.6 C322J222-30**** 0.022 13.0 11.0 5.0 10.0 0.6 C322J223-40**** 0.33 32.0 18.0 9.0 27.5 0.8 C322J334-B0**** 0.0027 10.5 9.0 4.0 7.5 0.6 C322J272-30**** 0.027 13.0 11.0 5.0 10.0 0.6 C322J273-40**** 0.39 32.0 18.0 9.0 27.5 0.8 C322J394-B0**** 0.0033 10.5 9.0 4.0 7.5 0.6 C322J332-30**** 0.033 13.0 11.0 5.0 10.0 0.6 C322J333-40**** 0.47 32.0 18.0 9.0 27.5 0.8 C322J474-B0**** 0.0039 10.5 9.0 4.0 7.5 0.6 C322J392-30**** 0.039 13.0 12.0 6.0 10.0 0.6 C322J393-40**** 0.56 32.0 20.0 11.0 27.5 0.8 C322J564-B0**** 0.0047 10.5 9.0 4.0 7.5 0.6 C322J472-30**** 0.047 13.0 12.0 6.0 10.0 0.6 C322J473-40**** 0.68 32.0 20.0 11.0 27.5 0.8 C322J684-B0**** 0.0056 10.5 9.0 4.0 7.5 0.6 C322J562-30**** 0.027 17.5 11.0 5.0 15.0 0.8 C322J273-60**** 0.82 32.0 20.0 11.0 27.5 0.8 C322J824-B0**** 0.0068 10.5 9.0 4.0 7.5 0.6 C322J682-30**** 0.033 17.5 11.0 5.0 15.0 0.8 C322J333-60**** 1.0 32.0 22.0 13.0 27.5 0.8 C322J105-B0**** 0.0082 10.5 9.0 4.0 7.5 0.6 C322J822-30**** 0.039 17.5 11.0 5.0 15.0 0.8 C322J393-60**** 1.2 32.0 24.5 15.0 27.5 0.8 C322J125-B0**** 0.010 10.5 9.0 4.0 7.5 0.6 C322J103-30**** 0.047 17.5 11.0 5.0 15.0 0.8 C322J473-60**** 1.5 32.0 28.0 14.0 27.5 0.8 C322J155-B0**** 0.012 10.5 9.0 4.0 7.5 0.6 C322J123-30**** 0.056 17.5 11.0 5.0 15.0 0.8 C322J563-60**** 1.8 32.0 33.0 18.0 27.5 0.8 C322J185-B0**** 0.015 10.5 11.0 5.0 7.5 0.6 C322J153-30**** 0.068 17.5 12.0 6.0 15.0 0.8 C322J683-60**** 2.2 32.0 33.0 18.0 27.5 0.8 C322J225-B0**** 0.018 10.5 11.0 5.0 7.5 0.6 C322J183-30**** 0.082 17.5 12.0 6.0 15.0 0.8 C322J823-60**** 2.7 32.0 37.0 22.0 27.5 0.8 C322J275-B0**** 0.022 10.5 11.0 5.0 7.5 0.6 C322J223-30**** 0.10 17.5 13.5 7.5 15.0 0.8 C322J104-60**** 3.3 32.0 37.0 22.0 27.5 0.8 C322J335-B0**** T P d W H T W H T P d 备注 Note 1.“-”表示容量偏差。 - =capacitance tolerance code. M=±20%, K=±10%, J=±5%, H=±3%, G=±2%. 2. **** 表示引线加工和包装代码(见表 1)。 **** =lead form and packing code refer to table 1). 3. @ 不用作跨线,请参见抗干扰电容器(Page 109)ㄌ @ 72 Not suitable for across-the-line application. Pls refer to Interference Suppression Capacitors(Page 109). Part number C32 MKP21 series ■ 外形尺寸 Dimensions(mm) 1 000V(400Vac) CN (μF) W H T P d 1 600V(600Vac) Part number CN (μF) W H T P d 2 000V(700Vac) Part number CN (μF) W H T P d Part number 0.0010 13.0 9.0 4.0 10.0 0.6 C323A102-40**** 0.00056 17.5 11.0 5.0 15.0 0.8 C323C561-60**** 0.00056 17.5 11.0 5.0 15.0 0.8 C323D561-60**** 0.0012 13.0 9.0 4.0 10.0 0.6 C323A122-40**** 0.00062 17.5 11.0 5.0 15.0 0.8 C323C621-60**** 0.00062 17.5 11.0 5.0 15.0 0.8 C323D621-60**** 0.0015 13.0 9.0 4.0 10.0 0.6 C323A152-40**** 0.00068 17.5 11.0 5.0 15.0 0.8 C323C681-60**** 0.00068 17.5 11.0 5.0 15.0 0.8 C323D681-60**** 0.0018 13.0 9.0 4.0 10.0 0.6 C323A182-40**** 0.00082 17.5 11.0 5.0 15.0 0.8 C323C821-60**** 0.00082 17.5 11.0 5.0 15.0 0.8 C323D821-60**** 0.0022 13.0 9.0 4.0 10.0 0.6 C323A222-40**** 0.0010 17.5 11.0 5.0 15.0 0.8 C323C102-60**** 0.0010 17.5 11.0 5.0 15.0 0.8 C323D102-60**** 0.0027 13.0 9.0 4.0 10.0 0.6 C323A272-40**** 0.0012 17.5 11.0 5.0 15.0 0.8 C323C122-60**** 0.0012 17.5 11.0 5.0 15.0 0.8 C323D122-60**** 0.0033 13.0 9.0 4.0 10.0 0.6 C323A332-40**** 0.0015 17.5 11.0 5.0 15.0 0.8 C323C152-60**** 0.0015 17.5 11.0 5.0 15.0 0.8 C323D152-60**** 0.0039 13.0 9.0 4.0 10.0 0.6 C323A392-40**** 0.0018 17.5 11.0 5.0 15.0 0.8 C323C182-60**** 0.0018 17.5 11.0 5.0 15.0 0.8 C323D182-60**** 0.0047 13.0 11.0 5.0 10.0 0.6 C323A472-40**** 0.0022 17.5 11.0 5.0 15.0 0.8 C323C222-60**** 0.0022 17.5 11.0 5.0 15.0 0.8 C323D222-60**** 0.0056 13.0 11.0 5.0 10.0 0.6 C323A562-40**** 0.0027 17.5 11.0 5.0 15.0 0.8 C323C272-60**** 0.0027 17.5 11.0 5.0 15.0 0.8 C323D272-60**** 0.0068 13.0 11.0 5.0 10.0 0.6 C323A682-40**** 0.0033 17.5 11.0 5.0 15.0 0.8 C323C332-60**** 0.0033 17.5 11.0 5.0 15.0 0.8 C323D332-60**** 0.0082 13.0 12.0 6.0 10.0 0.6 C323A822-40**** 0.0039 17.5 11.0 5.0 15.0 0.8 C323C392-60**** 0.0039 17.5 11.0 5.0 15.0 0.8 C323D392-60**** 0.010 13.0 12.0 6.0 10.0 0.6 C323A103-40**** 0.0047 17.5 11.0 5.0 15.0 0.8 C323C472-60**** 0.0047 17.5 11.0 5.0 15.0 0.8 C323D472-60**** 0.0022 17.5 11.0 5.0 15.0 0.8 C323A222-60**** 0.0056 17.5 11.0 5.0 15.0 0.8 C323C562-60**** 0.0056 17.5 12.0 6.0 15.0 0.8 C323D562-60**** 0.0027 17.5 11.0 5.0 15.0 0.8 C323A272-60**** 0.0068 17.5 11.0 5.0 15.0 0.8 C323C682-60**** 0.0068 17.5 12.0 6.0 15.0 0.8 C323D682-60**** 0.0033 17.5 11.0 5.0 15.0 0.8 C323A332-60**** 0.0082 17.5 12.0 6.0 15.0 0.8 C323C822-60**** 0.0082 17.5 13.5 7.5 15.0 0.8 C323D822-60**** 0.0039 17.5 11.0 5.0 15.0 0.8 C323A392-60**** 0.010 17.5 12.0 6.0 15.0 0.8 C323C103-60**** 0.010 17.5 13.5 7.5 15.0 0.8 C323D103-60**** 0.0047 17.5 11.0 5.0 15.0 0.8 C323A472-60**** 0.012 17.5 12.0 6.0 15.0 0.8 C323C123-60**** 0.012 17.5 14.5 8.5 15.0 0.8 C323D123-60**** 0.0056 17.5 11.0 5.0 15.0 0.8 C323A562-60**** 0.015 17.5 13.5 7.5 15.0 0.8 C323C153-60**** 0.015 17.5 14.5 8.5 15.0 0.8 C323D153-60**** 0.0068 17.5 11.0 5.0 15.0 0.8 C323A682-60**** 0.018 17.5 13.5 7.5 15.0 0.8 C323C183-60**** 0.018 17.5 16.0 10.0 15.0 0.8 C323D183-60**** 0.0082 17.5 11.0 5.0 15.0 0.8 C323A822-60**** 0.022 17.5 14.5 8.5 15.0 0.8 C323C223-60**** 0.022 17.5 19.0 11.0 15.0 0.8 C323D223-60**** 0.010 17.5 11.0 5.0 15.0 0.8 C323A103-60**** 0.027 17.5 16.0 10.0 15.0 0.8 C323C273-60**** 0.0068 26.5 15.0 6.0 22.5 0.8 C323D682-90**** 0.012 17.5 11.0 5.0 15.0 0.8 C323A123-60**** 0.033 17.5 16.0 10.0 15.0 0.8 C323C333-60**** 0.0082 26.5 15.0 6.0 22.5 0.8 C323D822-90**** 0.015 17.5 12.0 6.0 15.0 0.8 C323A153-60**** 0.039 17.5 19.0 11.0 15.0 0.8 C323C393-60**** 0.010 26.5 15.0 6.0 22.5 0.8 C323D103-90**** 0.018 17.5 12.0 6.0 15.0 0.8 C323A183-60**** 0.047 17.5 19.0 11.0 15.0 0.8 C323C473-60**** 0.012 26.5 15.0 6.0 22.5 0.8 C323D123-90**** 0.022 17.5 13.5 7.5 15.0 0.8 C323A223-60**** 0.015 26.5 15.0 6.0 22.5 0.8 C323C153-90**** 0.015 26.5 15.0 6.0 22.5 0.8 C323D153-90**** 0.027 17.5 13.5 7.5 15.0 0.8 C323A273-60**** 0.018 26.5 15.0 6.0 22.5 0.8 C323C183-90**** 0.018 26.5 16.0 7.0 22.5 0.8 C323D183-90**** 0.033 17.5 14.5 8.5 15.0 0.8 C323A333-60**** 0.022 26.5 15.0 6.0 22.5 0.8 C323C223-90**** 0.022 26.5 17.0 8.5 22.5 0.8 C323D223-90**** 0.039 17.5 16.0 10.0 15.0 0.8 C323A393-60**** 0.027 26.5 16.0 7.0 22.5 0.8 C323C273-90**** 0.027 26.5 17.0 8.5 22.5 0.8 C323D273-90**** 0.047 17.5 16.0 10.0 15.0 0.8 C323A473-60**** 0.033 26.5 16.0 7.0 22.5 0.8 C323C333-90**** 0.033 26.5 18.5 10.0 22.5 0.8 C323D333-90**** 0.056 17.5 19.0 11.0 15.0 0.8 C323A563-60**** 0.039 26.5 17.0 8.5 22.5 0.8 C323C393-90**** 0.039 26.5 18.5 10.0 22.5 0.8 C323D393-90**** 0.068 17.5 19.0 11.0 15.0 0.8 C323A683-60**** 0.047 26.5 18.5 10.0 22.5 0.8 C323C473-90**** 0.047 26.5 22.0 12.0 22.5 0.8 C323D473-90**** 0.018 26.5 15.0 6.0 22.5 0.8 C323A183-90**** 0.056 26.5 18.5 10.0 22.5 0.8 C323C563-90**** 0.056 26.5 22.0 12.0 22.5 0.8 C323D563-90**** 0.022 26.5 15.0 6.0 22.5 0.8 C323A223-90**** 0.068 26.5 22.0 12.0 22.5 0.8 C323C683-90**** 0.027 26.5 15.0 6.0 22.5 0.8 C323A273-90**** 0.082 26.5 22.0 12.0 22.5 0.8 C323C823-90**** 0.033 26.5 15.0 6.0 22.5 0.8 C323A333-90**** 0.10 26.5 22.0 12.0 22.5 0.8 C323C104-90**** 0.039 26.5 15.0 6.0 22.5 0.8 C323A393-90**** 0.047 26.5 16.0 7.0 22.5 0.8 C323A473-90**** 0.056 26.5 16.0 7.0 22.5 0.8 C323A563-90**** 0.068 26.5 17.0 8.5 22.5 0.8 C323A683-90**** 0.082 26.5 17.0 8.5 22.5 0.8 C323A823-90**** 0.10 26.5 18.5 10.0 22.5 0.8 C323A104-90**** 0.12 26.5 22.0 12.0 22.5 0.8 C323A124-90**** 0.15 26.5 22.0 12.0 22.5 0.8 C323A154-90**** 备注 Note 1.“-”表示容量偏差。 - =capacitance tolerance code. M=±20%, K=±10%, J=±5%, H=±3%, G=±2%. 2. **** 表示引线加工和包装代码(见表 1)。 **** =lead form and packing code refer to table 1). 73
C322J102J40C000 价格&库存
很抱歉,暂时无法提供与“C322J102J40C000”相匹配的价格&库存,您可以联系我们找货
