MAX3232EDTR
MAX3232EDTR
    XBLW(芯伯乐)
    SOP16_150MIL
    低功耗 3.3V工作电压 速率 250kbps Rs232收发器,通道数CH(#)2*2,工作电压(Vcc)(v)3.3~5.0V
MAX3232EDTR 数据手册
XBLW MAX3232 5VDual channel RS-232 Drivers/Receivers General Description The MAX3232 is a dual driver/receiver of RS-232 standard with a single supply voltage and bipolar output voltage of the transmitter formed by a built-In voltage multiplying generator on four 1.0µF external capacitors, designed for use in state-of-the-art high performance computing systems, high-speed electronic devices with high reliability of information exchange between remote objects. Input voltage levels are compatible with standard CMOS and TTL levels Features  Output voltage levels are compatible with input levels of CMOS and TTL integrated circuits  Meets All EIA/TIA-232E and V.28/V.24 Specifications  Supply voltage range from 5.5V  Low input current: 1.0µA at 25°C  Output current 30mA  Available in SOP-16 DIP-16 Package Applications  Portable Computers  Battery-Powered RS-232 Systems  Interface Translation  Low-Power Modems  Terminals Order Information Product Model Package Type Marking Packing Packing Qty XBLW MAX3232N DIP-16 MAX3232N Tape 1000/Box XBLW MAX3232EDTR SOP-16 MAX3232E Tube 2500/Reel XBLW MAX3232EEDTR SOP-16 MAX3232EE Tube 2500/Reel XBLWversion1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 Additional Remarks ESD 第1页共8页 XBLW MAX3232 5VDual channel RS-232 Drivers/Receivers ABSOLUTE MAXIMUM RATINGS PARAMETER SYMBOL MIN. MAX. UNIT VCC -0.3 5.5 V Transmitter High Output Voltage V+ VCC-0.3 7 V Transmitter Low Output Voltage V- -7.0 0.3 V Transmitter Input Voltage VTIN -0.3 V+ +0.3 V Receiver Input Voltage VRIN - 12 12 V Voltage Applied to Transmitter Output V TOUT V- -0.3 V+ +0.3 V Voltage Applied to Receiver Output VROUT -0.3 VCC+0.3 V T STG -65 150 °C SYMBOL MIN. MAX. UNIT Supply Voltage VCC 3.0 5.5 V Transmitter Input Voltage VTIN 0 VCC V Receiver Input Voltage VRIN - 12 12 V Output Current of Transmitter Short Circuit ISC - ±60 mA Ambient Temperature Range TA -40 +85 °C Supply Voltage Storage Temperature Range RECOMMENDED OPERATING CONDITIONS PARAMETER PIN CONFIGURATION XBLWversion1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 第2页共8页 XBLW MAX3232 5VDual channel RS-232 Drivers/Receivers PIN DESCRIPTION Pin Description Pin No. Pin Name 1 C1+ Terminal for Positive Charge- Pump C1 Capacitor 2 V+ Positive Voltage Generated by the Charge- Pump 3 C1- Terminal for Negative Charge- Pump C1 Capacitor 4 C2+ Terminal for Positive Charge- Pump C2 Capacitor 5 C2- Terminal for Negative Charge- Pump C2 Capacitor 6 V- Negative Voltage Generated by the Charge- Pump 7 T2 OUT RS-232 Driver Output (Levels RS-232) 8 R2IN RS-232 Receiver Input (Levels RS-232) 9 R2OUT 10 T2IN RS-232 Driver Input (Levels TTL/CMOS) 11 T1IN RS-232 Driver Input (Levels TTL/CMOS) 12 R1OUT 13 R1IN RS-232 Receiver Input (Levels RS-232) 14 T1 OUT RS-232 Driver Output (Levels RS-232) 15 GND Ground 16 VCC Supply Voltage Input XBLWversion1.0 RS- 232 Receiver Output (Levels TTL/CMOS) RS- 232 Receiver Output (Levels TTL/CMOS) 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 第3页共8页 XBLW MAX3232 5VDual channel RS-232 Drivers/Receivers TYPICAL APPLICATION CIRCUIT FUNCTION TABLE XBLWversion1.0 INPUT OUTPUT (RIN, TIN) (ROUT, TOUT) L (Low Level) H (High Level) H (High Level) L (Low Level) 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 第4页共8页 XBLW MAX3232 5VDual channel RS-232 Drivers/Receivers ELECTRICAL CHARACTERISTICS ( Limits in standard typeface are for TA=2 5 ° C, and the limits in boldface type apply over full operating temperature range.) PARAMETER SYMBOL TEST CONDITIONS MIN. TYP. MAX. UNIT ICC VCC = 5.5V VIL = 0V - - 8 10.0 mA Hysteresis Voltage Vh VCC = 5.0V 0.2 0.2 - 0.9 1.0 V On (Operation) Voltage Von VO ≤ 0.1V, IOL ≤ 20µA - - 2.4 2.3 V Off (Dropout) Voltage Voff VO ≥ VCC - 0.1V IOH ≤ -20µA 0.8 0.9 - - V Output Low Voltage VOL IL = 3.2mA, VCC = 4.5V, VIH = 2.4V - - 0.3 0.4 V Output High Voltage VOH IOH = -1.0mA, VCC = 4.5V, VIL = 0.8V 3.6 3.5 - - V VCC = 5.0V 3.0 3.0 - 7.0 7.0 kΩ Supply Current Receiver Parameters Input Resistance RI Transmitter Parameters Output Low Voltage VOL VCC = 4.5V, VIH = 2.0V, RL = 3.0kΩ - - -5.2 -5.0 V Output High Voltage VOH VCC = 4.5V, VIL = 0.8V, RL = 3.0kΩ 5.2 5.0 - - V Input Low Current IIL VCC = 5.5V, VIL = 0V - - -1.0 -10.0 µA Input High Current IIH VCC = 5.5V, VIH = VCC - - 1.0 10.0 µA Speed Of Output Front Charge SR 3.0 2.7 - 30 27 V/ µs Output Resistance RO VCC = 5.0V, CL = 50 - 1000pF, RL = 3.0 - 7.0kΩ VCC = V+ = V- = 0V VO = ±2V 350 300 - - Ω - - -50 -60 - - 50 60 Short Circuit Output Current ISC VCC = 5.5V VO = 0V VI = VCC VI = 0 mA ST VCC = 4.5V, CL = 1000pF, RL = 3.0kΩ , tW = 7 µs (for extreme, tW = 8 µs) 250 300 - - kbit/s Signal Propagation Delay Time When Switching On (Off) tPHLR (tPLHR) VCC = 4.5V, CL = 150pF, VIL = 0V, VIH = 3.0V, tLH = tHL ≤ 10ns - - 9.7 10.0 µs Signal Propagation Delay Time When Switching On (Off) tPHLT (tPLHT) VCC = 4.5V, CL = 2500pF, VIL = 0V, VIH = 3.0V, RL = 3kΩ , tLH = tHL ≤ 10ns - - 5.0 6.0 µs Speed Of Information Transmission Dynamic Parameters XBLWversion1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 第5页共8页 XBLW MAX3232 5VDual channel RS-232 Drivers/Receivers TIMING DIAGRAM Figure 1 . tPHL and tPLH waveforms of Receiver Figure 2 . tPHL and tPLH waveforms of Transmitter Figure 3 . tSLH and tSHL waveforms of Transmitter XBLWversion1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 第6页共8页 XBLW MAX3232 5VDual channel RS-232 Drivers/Receivers Package Information SOP16 XBLWversion1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 第7页共8页 XBLW MAX3232 5VDual channel RS-232 Drivers/Receivers Statement:  Shenzhen xinbole electronics co., ltd. reserves the right to change the product specifications, without notice! Before placing an order, the customer needs to confirm whether the information obtained is the latest version, and verify the integrity of the relevant information.  Any semiconductor product is liable to fail or malfunction under certain conditions, and the buyer shall be responsible for complying with safety standards in the system design and whole machine manufacturing using Shenzhen xinbole electronics co., ltd products, and take appropriate security measures to avoid the potential risk of failure may result in personal injury or property losses of the situation occurred!  Product performance is never ending, Shenzhen xinbole electronics co., ltd will be dedicated to provide customers with better performance, better quality of integrated circuit products. XBLWversion1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 第8页共8页
MAX3232EDTR 价格&库存
很抱歉,暂时无法提供与“MAX3232EDTR”相匹配的价格&库存,您可以联系我们找货
