MC33063ADTR
MC33063ADTR
    XBLW(芯伯乐)
    SOP8_5X4.4MM
    DC-DC转换器控制电路,工作电压3-40V,输出电流1.5A
MC33063ADTR 数据手册
XBLW MC33063 1 .5A Step-Up/Down/Inverting Switching Regulator General Description The MC33063 is a monolithic control circuit containing the primary functions required for DC- to- DC converters. This device consists of an internal temperature compensated reference ( 1.25V ) ,comparator, controlled duty cycle oscillator with an active current limit circuit, driver and high current output switch. The IC is specifically designed to be used in Step- Down and Step- Up and Voltage- Inverting applications with a minimum number of external components. The MC33063 is available in DIP8 and SOP8 package. F eatu res FunctionalBlockDiagram Operation from 3.0V to 40V Input Low Standby Current Current Limiting Output Switch Current to 1.5A Output Voltage Adjustable Frequency Operation to 100kHz Precision 2% Reference Ordering Information DEVICE XBLW MC33063ADTR XBLWversion1 . 0 Package Type MARKING SOP-8 MC33063A Packing Tape 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 Packing QTY 2500/Reel 第 1页 共 9页 XBLW MC33063 1.5 A Step-Up/Down/Inverting Switching Regulator Pin Configuration Pin Description Pin Number Pin Name Function Description Pin Number Pin Name Function Description 1 SC Switch collector 5 FB Comparator inverting input 2 SE Switch emitter 6 V CC Input voltage 3 CT Timing capacitor 7 Ipk Ipk sense 4 GND Ground 8 DC Drive collector Absolute Maximum Ratings ( Ta= 2 5 ° C) Symbol Value Unit Power Supply Voltage Vcc 40 V Comparator Input Voltage Range V IR -0.3~40 V Switch Collector Voltage Vc( switch) 40 V Switch Emitter Voltage (VPin1=40 V) VE (switch) 40 V Switch Collector to Emitter Voltage VCE( switch) 40 V Driver Collector Voltage Vc( drive) 40 V Driver Collector Current Ic(drive) 100 mA ISW 1.5 A Parameter Name Switch Current DIP8 Power Dissipation 1.25 W 625 mW Ta 0~70 Tstg -65~ 150 ℃ PD SOP8 Operating Ambient Temperature Range Storage Temperature Range ℃ Electrical Characteristics ( Unless otherwise noted , Vcc= 5 . 0 V, Ta= 0 ~ 7 0 ° C) Symbol Min Typ Max Unit Frequency (Vpin5=0V,CT=1.0nF, Ta=25°C) fosc 24 33 42 kHz Charge Current (Vcc=5.0~40V, Ta=25°C) Ichg 24 35 42 pA Idischg 140 220 260 pA Idischg/ Ichg 5.2 6.5 7.5 Vipk( sense) 250 300 350 Parameter Name OSCILLATOR Discharge Current (Vcc=5.0~40V, Ta=25°C) Discharge to Charge Current Ratio (Pin7 to Vcc, Ta=25°C) Current limit Sense Voltage (Ichg=Idischg, Ta=25°C) XBLWversion1 . 0 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 mA 第 2页 共 9页 XBLW MC33063 1.5 A Step-Up/Down/Inverting Switching Regulator OUTPUT SWITCH Saturation Voltage, Darlington Connection (ISW=1.0A, Pins 1,8 Connected) Saturation Voltage, Darlington Connection (ISW=1.0A, Rpin 8=82Ω to Vcc, Forced β ≈ 20) DC Current Gain (ISW=1.0A,VCE=5.0V, Ta=25°C) Collector Off- State Current (VCE=40 V) VCE( sat) 1.0 1.3 V VCE( sat) 0.45 0.7 V 0.01 100 pA 1.25 1.275 hFE 50 Ic(off) 75 COMPARATOR Threshold Voltage (Ta=25 °C) Vth Threshold Voltage (Ta=0~70 °C) Threshold Voltage Line Regulation (Vcc=3.0~40V) Input Bias Current(Vin=0 V) 1.225 1.21 1.29 V Regline 1.4 5.0 mV IIB -20 -400 nA 4.0 mA TOTAL DEVICE Supply Current (Vcc=5.0~40V, CT=1.0nF, Pin7= Vcc, Vpin5> Vth, pin2= Gnd, Remaining Pins Open) Icc Characteristics Curves XBLWversion1 . 0 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 第 3页 共 9页 XBLW MC33063 1.5 A Step-Up/Down/Inverting Switching Regulator Typical 1. Application Step- Up Converter Test Conditions Results Line Regulation Vin=8.0V~ 16V, Io= 175mA 30mV=±0.05% Load Regulation Vin= 12V,Io=75mA~ 175mA 10mV=±0.017% Output Ripple Vin= 12V, Io= 175mA 400mVpp Efficiency Vin=12V, Io= 175mA 87.7% Output Ripple With Optional Filter Vin=12V, Io= 175mA 40mVpp XBLWversion1 . 0 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 第 4页 共 9页 XBLW MC33063 1.5 A Step-Up/Down/Inverting Switching Regulator 2. Step-Down Converter Test Conditions Results Line Regulation Vin=15V~25V, Io=500mA 12mV=±0. 12% Load Regulation Vin=25V,Io=50mA~500mA 3.0mV=±0.03% Output Ripple Vin=25V, Io=500mA 120mVpp Short Circuit Current Vin=25V,RL=0. 1Ω 1. 1A Efficiency Vin=25V, Io=500mA 83.7% Output Ripple With Optional Filter Vin=25V, Io=500mA 40mVpp 3 . Voltage Inverting Converter XBLWversion1 . 0 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 第 5页 共 9页 XBLW MC33063 1 .5A Step-Up/Down/Inverting Switching Regulator Test Conditions Results Line Regulation Vin=4.5V~6.0V, Io= 100mA 3.0mV=±0.012 % Load Regulation Vin=5.0V,Io= 10mA~ 100mA 0.022V=±0.09% Output Ripple Vin=5.0V, Io= 100mA 500mVpp Short Circuit Current Vin=5.0V,RL=0. 1Ω 910mA Efficiency Vin=5.0V, Io= 100mA 62.2% Output Ripple With Optional Filter Vin=5.0V, Io= 100mA 70mVpp Application Information XBLWversion1 . 0 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 第 6页 共 9页 XBLW MC33063 1 .5A Step-Up/Down/Inverting Switching Regulator Vsat = Saturation voltage of the output switch VF = Forward voltage drop of the output rectifier The following power supply characteristics must be chosen: Vin — Nominal input voltage Vout — Desired output voltage , | Vout |= 1.25 × ( 1 +R2 /R1) Iout — Desired output current fmin — Minimun desired output switching frequency at the selected values of Vin and Io Vripple( pp) — Desired peak−to −peak output ripple voltage. In practice, the calculated capacitor value will need to be increased due to its equivalent series resistance and board layout. The ripple voltage should be kept to a low value since it will directly affect the line and load regulation. Outline Dimensions Unit: mm DIP8 33063 Un it: mm SOP8 XBLWversion1 . 0 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 第 7页 共 9页 XBLW MC33063 1 .5A Step-Up/Down/Inverting Switching Regulator 33063 XBLWversion1 . 0 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 第 8页 共 9页 XBLW MC33063 1 .5A Step-Up/Down/Inverting Switching Regulator Statement: Shenzhen xinbole electronics co., ltd. reserves the right to change the product specifications, without notice! Before placing an order, the customer needs to confirm whether the information obtained is the latest version, and verify the integrity of the relevant information. Any semiconductor product is liable to fail or malfunction under certain conditions, and the buyer shall be responsible for complying with safety standards in the system design and whole machine manufacturing using Shenzhen xinbole electronics co. , ltd products, and take appropriate security measures to avoid the potential risk of failure may result in personal injury or property losses of the situation occurred! Product performance is never ending, Shenzhen xinbole electronics co., ltd will be dedicated to provide customers with better performance, better quality of integrated circuit products. XBLWversion1 . 0 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 第 9页 共 9页
MC33063ADTR 价格&库存
很抱歉,暂时无法提供与“MC33063ADTR”相匹配的价格&库存,您可以联系我们找货
MC33063ADTR
  • 1+0.56810
  • 100+0.51984
  • 500+0.49381
  • 2500+0.42560
