SN74HC160N
SN74HC160N
    XBLW(芯伯乐)
    DIP16_19.2X6.6MM
    十进制同步计数器,工作电压(Vcc)(v)2-6V,静态电流Iq(Typ)8uA
SN74HC160N 数据手册
XBLW 74HC/HCT160 SYNCHRONOUS 4-BIT COUNTERS General Description The SN74HC/HCT160 is a synchronous presettable decade counter with an internal look-ahead carry. Synchronous operation is provided by having all flip-flops clocked simultaneously on the positive-going edge of the clock (CP). The outputs (Q0 to Q3) of the counters may be preset HIGH or LOW. A LOW at the parallel enable input (P�) disables the counting action and causes the data at the data inputs (D0 to D3) to be loaded into the counter on the positive-going edge of the clock. Preset takes place regardless of the levels at count enable inputs (CEP and CET). A LOW at the master reset input (M�) sets Q0 to Q3 LOW regardless of the levels at input pins CP, P�, CET and CEP (thus providing an asynchronous clear function). The look-ahead carry simplifies serial cascading of the counters. Both CEP and CET must be HIGH to count. The CET input is fed forward to enable the terminal count output (TC). The TC output thus enabled will produce a HIGH output pulse of a duration approximately equal to a HIGH output of Q0. This pulse can be used to enable the next cascaded stage. The maximum clock frequency for the cascaded counters is determined by the CP to TC propagation delay and CEP to CP set-up time, according to the following formula: fmax=1/(tP(max)(CP to TC)+tSU(CEP to CP)) Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. Features  Input levels: For SN74HC160: CMOS level For SNSN74HCT160: TTL level  Synchronous counting and loading  2 count enable inputs for n-bit cascading  Asynchronous reset  Positive-edge triggered clock  Specified from -40℃ to +105℃  Packaging information: DIP16/SOP16/TSSOP16 ORDERING INFORMATION DEVICE Package Type MARKING Packing Packing QTY SN74HC160N SN74HC160DTR SN74HCT160DTR SN74HCT160TDTR DIP-16 SOP-16 SOP-16 TSSOP-16 74HC160N 74HC160 74HCT160 74HCT160 Tube Tape Tape Tape 1000/Box 2500/Reel 2500/Reel 3000/Reel XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com      技术支持热线:4009682003 第 1 页 共 24 页 XBLW 74HC/HCT160 SYNCHRONOUS 4-BIT COUNTERS Block Diagram And Pin Description Block Diagram Figure 1. Logic symbol XBLW version 1.0 Figure 2. IEC Logic symbol 文档仅供参考,实际应用测试为准 www.xinboleic.com      技术支持热线:4009682003 第 2 页 共 24 页 XBLW 74HC/HCT160 SYNCHRONOUS 4-BIT COUNTERS Figure 3. Functional diagram Figure 4. Logic diagram Figure 5. State diagram XBLW version 1.0 Figure 6. Typical timing sequence 文档仅供参考,实际应用测试为准 www.xinboleic.com      技术支持热线:4009682003 第 3 页 共 24 页 XBLW 74HC/HCT160 SYNCHRONOUS 4-BIT COUNTERS Pin Configurations Pin Description Pin No. Pin Name Description 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 M� CP D0 D1 D2 D3 CEP GND P� CET Q3 Q2 Q1 Q0 TC VCC asynchronous master reset(active LOW) clock input(LOW-to-HIGH,edge triggered) data input data input data input data input count enable input ground(0V) parallel enable input(active LOW) count enable carry input flip-flop output flip-flop output flip-flop output flip-flop output terminal count output supply voltage XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com      技术支持热线:4009682003 第 4 页 共 24 页 XBLW 74HC/HCT160 SYNCHRONOUS 4-BIT COUNTERS Function Table Input Operating mode M� L H H H H H reset(clear) parallel load count hold(do nothing) CP X ↑ ↑ ↑ X X CEP X X X h l X CET X X X h X l Output P� X l l h h h Dn X l h X X X Qn L L H count qn qn TC L L [2] [2] [2] L Note: [1] H=HIGH voltage level; L=LOW voltage level; X=don’t care; ↑=LOW-to-HIGH clock transition; l=LOW voltage level one set-up time prior to the LOW-to-HIGH clock transition; h=HIGH voltage level one set-up time prior to the LOW-to-HIGH CP transition; qn=lower case letters indicate the state of the referenced output one set-up time prior to the LOW-to-HIGH CP transition. [2] The TC output is HIGH when CET is HIGH and the counter is at terminal count (HLLH). Electrical Parameter Absolute Maximum Ratings (Voltages are referenced to GND (ground=0V), unless otherwise specified.) Parameter Symbol Conditions Min. Max. Unit supply voltage input clamping current output clamping current output current supply current ground current storage temperature total power dissipation VCC IIK IOK IO ICC IGND Tstg Ptot -0.5 -50 -65 - +7.0 ±20 ±20 ±25 50 +150 500 V mA mA mA mA mA ℃ mW soldering temperature TL VI < -0.5V or VI > VCC+0.5V VO < -0.5V or VO > VCC+0.5V -0.5V < VO <VCC +0.5V DIP 10s SOP 245 250 ℃ Note: [1] For DIP16 packages: above 70℃ the value of Ptot derates linearly with 12mW/K. [2] For SOP16 packages: above 70℃ the value of Ptot derates linearly with 8mW/K. [3] For (T)SSOP16 packages: above 60℃ the value of Ptot derates linearly with 5.5mW/K. XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com      技术支持热线:4009682003 第 5 页 共 24 页 XBLW 74HC/HCT160 SYNCHRONOUS 4-BIT COUNTERS Recommended Operating Conditions Parameter Symbol supply voltage input voltage output voltage VCC VI VO input transition rise and fall rate Δt/ΔV ambient temperature Tamb supply voltage input voltage output voltage input transition rise and fall rate ambient temperature VCC VI VO Conditions SN74HC160 VCC=2.0V VCC=4.5V VCC=6.0V SN74HCT160 - Min. Typ. Max. Unit 2.0 0 0 -40 5.0 1.67 - 6.0 VCC VCC 625 139 83 +105 V V V ns/V ns/V ns/V ℃ 4.5 0 0 5.0 - 5.5 VCC VCC V V V Δt/ΔV VCC=4.5V - 1.67 139 ns/V Tamb - -40 - +105 ℃ Electrical Characteristics DC Characteristics 1 (Tamb=25℃, voltages are referenced to GND (ground=0V), unless otherwise specified.) Parameter Symbol Conditions HIGH-level input voltage VIH LOW-level input voltage VIL HIGH-level output voltage VOH VI=VIH or VIL LOW-level output voltage VOL VI=VIH or VIL XBLW version 1.0 SN74HC160 VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V IO=-20uA;VCC=2.0V IO=-20uA;VCC=4.5V IO=-20uA;VCC=6.0V IO=-4.0mA;VCC=4.5V IO=-5.2mA;VCC=6.0V IO=20uA;VCC=2.0V IO=20uA;VCC=4.5V IO=20uA;VCC=6.0V IO=4.0mA;VCC=4.5V Min. Typ. Max. Unit 1.5 3.15 4.2 1.9 4.4 5.9 3.98 5.48 - 1.2 2.4 3.2 0.8 2.1 2.8 2.0 4.5 6.0 4.32 5.81 0 0 0 0.15 0.5 1.35 1.8 0.1 0.1 0.1 0.26 V V V V V V V V V V V V V V V 文档仅供参考,实际应用测试为准 www.xinboleic.com      技术支持热线:4009682003 第 6 页 共 24 页 XBLW 74HC/HCT160 SYNCHRONOUS 4-BIT COUNTERS IO=5.2mA;VCC=6.0V - 0.16 0.26 V VI=Vcc or GND;VCC=6.0V - - ±0.1 μA VI=VCC or GND;IO=0A;VCC=6.0V - - 8.0 μA - 3.5 - pF VCC=4.5V to 5.5V 2.0 1.6 - V VCC=4.5V to 5.5V - 1.2 0.8 V 4.4 3.98 - 4.5 4.32 0 0.15 0.1 0.26 V V V V input leakage current supply current II ICC input apacitance CI SN74HCT160 VIH VIL HIGH-level input voltage LOW-level input voltage HIGH-level output voltage VOH VI=VIH or VIL VCC=4.5V LOW-level output voltage VOL VI=VIH or VIL VCC=4.5V input leakage current supply current additional Supply currend II VI=Vcc or GND;VCC=5.5V - - ±0.1 μA ICC VI=VCC or GND;IO=0A;VCC=5.5V - - 8.0 μA pin M� - 95 342 μA pin CP - 110 396 μA pin CEP and Dn - 25 90 μA pin CET - 75 270 μA pin P� - 30 108 μA - 3.5 - pF ΔICC input apacitance IO=-20uA IO=-4.0uA IO=20uA IO=4.0uA VI=VCC-2.1V; other inputs at VCC or GND;IO=0V; VCC=4.5V to 5.5V CI - DC Characteristics 2 (Tamb=-40℃ to +85℃, voltages are referenced to GND (ground=0V), unless otherwise specified.) Parameter Symbol Conditions HIGH-level input voltage VIH LOW-level input voltage VIL HIGH-level output voltage VOH VI=VIH or VIL LOW-level VOL VI=VIH or VIL XBLW version 1.0 SN74HC160 VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V IO=-20uA;VCC=2.0V IO=-20uA;VCC=4.5V IO=-20uA;VCC=6.0V IO=-4.0mA;VCC=4.5V IO=-5.2mA;VCC=6.0V IO=20uA;VCC=2.0V Min. Typ. Max. Unit 1.5 3.15 4.2 1.9 4.4 5.9 3.84 5.34 - - 0.5 1.35 1.8 0.1 V V V V V V V V V V V V 文档仅供参考,实际应用测试为准 www.xinboleic.com      技术支持热线:4009682003 第 7 页 共 24 页 XBLW 74HC/HCT160 SYNCHRONOUS 4-BIT COUNTERS output voltage input leakage current supply current IO=20uA;VCC=4.5V IO=20uA;VCC=6.0V IO=4.0mA;VCC=4.5V IO=5.2mA;VCC=6.0V - - 0.1 0.1 0.33 0.33 V V V V II VI=Vcc or GND;VCC=6.0V - - ±1.0 μA ICC VI=VCC or GND;IO=0A;VCC=6.0V - - 80 μA SN74HCT160 HIGH-level input voltage LOW-level input voltage VIH VCC=4.5V to 5.5V 2.0 - - V VIL VCC=4.5V to 5.5V - - 0.8 V 4.4 3.84 - - 0.1 0.33 V V V V HIGH-level output voltage VOH VI=VIH or VIL VCC=4.5V LOW-level output voltage VOL VI=VIH or VIL VCC=4.5V input leakage current supply current additional Supply currend IO=-20uA IO=-4.0uA IO=20uA IO=4.0uA II VI=Vcc or GND;VCC=5.5V - - ±1.0 μA ICC VI=VCC or GND;IO=0A;VCC=5.5V - - 80 μA pin M� - - 427.5 μA pin CP - - 495 μA pin CEP and Dn - - 112.5 μA pin CET - - 337.5 μA pin P� - - 135 μA ΔICC VI=VCC-2.1V; other inputs at VCC or GND;IO=0V; VCC=4.5V to 5.5V DC Characteristics 3 (Tamb=-40℃ to +105℃, voltages are referenced to GND (ground=0V), unless otherwise specified.) Parameter Symbol HIGH-level input voltage VIH LOW-level input voltage VIL HIGH-level output voltage VOH XBLW version 1.0 Conditions VI=VIH or VIL SN74HC160 VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V IO=-20uA;VCC=2.0V IO=-20uA;VCC=4.5V IO=-20uA;VCC=6.0V IO=-4.0mA;VCC=4.5V IO=-5.2mA;VCC=6.0V Min. Typ. Max. Unit 1.5 3.15 4.2 1.9 4.4 5.9 3.7 5.2 - 0.5 1.35 1.8 - V V V V V V V V V V V 文档仅供参考,实际应用测试为准 www.xinboleic.com      技术支持热线:4009682003 第 8 页 共 24 页 XBLW 74HC/HCT160 SYNCHRONOUS 4-BIT COUNTERS LOW-level output voltage input leakage current supply current VOL IO=20uA;VCC=2.0V IO=20uA;VCC=4.5V IO=20uA;VCC=6.0V IO=4.0mA;VCC=4.5V IO=5.2mA;VCC=6.0V VI=VIH or VIL - - 0.1 0.1 0.1 0.4 0.4 V V V V V II VI=Vcc or GND;VCC=6.0V - - ±1.0 μA ICC VI=VCC or GND;IO=0A;VCC=6.0V - - 160 μA SN74HCT160 HIGH-level input voltage LOW-level input voltage VIH VCC=4.5V to 5.5V 2.0 - - V VIL VCC=4.5V to 5.5V - - 0.8 V 4.4 3.7 - - 0.1 0.4 V V V V HIGH-level output voltage VOH VI=VIH or VIL VCC=4.5V LOW-level output voltage VOL VI=VIH or VIL VCC=4.5V input leakage current supply current additional Supply currend IO=-20uA IO=-4.0uA IO=20uA IO=4.0uA II VI=Vcc or GND;VCC=5.5V - - ±1.0 μA ICC VI=VCC or GND;IO=0A;VCC=5.5V - - 160 μA pin M� - - 465.5 μA pin CP - - 539 μA pin CEP and Dn - - 122.5 μA pin CET - - 367.5 μA pin P� - - 147 μA ΔICC VI=VCC-2.1V; other inputs at VCC or GND;IO=0V; VCC=4.5V to 5.5V AC Characteristics 1 (Tamb=25℃, GND =0V; tr=tf=6ns; CL=50pF,unless otherwise specified.) Parameter Symbol Conditions CP to Qn; see Figure8[1] Propagation delay tpd CP to TC; see Figure8 CET to TC; see Figure9 XBLW version 1.0 SN74HC160 VCC=2.0V VCC=4.5V VCC=5.0V;CL=15pF VCC=6.0V VCC=2.0V VCC=4.5V VCC=5.0V;CL=15pF VCC=6.0V VCC=2.0V VCC=4.5V VCC=5.0V;CL=15pF Min. Typ. Max. Unit - 61 22 19 18 69 25 21 20 47 17 14 185 37 31 215 43 31 150 30 - ns ns ns ns ns ns ns ns ns ns ns 文档仅供参考,实际应用测试为准 www.xinboleic.com      技术支持热线:4009682003 第 9 页 共 24 页 XBLW 74HC/HCT160 SYNCHRONOUS 4-BIT COUNTERS M� to Qn; see Figure10 High to LOW Propagation delay tPHL transition time tt pulse width M� to TC; see Figure10 tw see Figure8 and see Figure9[2] CP HIGH or LOW;see Figure8 M� LOW; see Figure10 Recovery time trec M� to CP; see Figure10 Dn to CP; see Figure11 Set-up time tsu P� to CP; see Figure11 CEP,CET to CP; see Figure12 Dn to CP; see Figure11 Hold time th P� to CP; see Figure11 CEP,CET to CP; see Figure12 Maximum XBLW version 1.0 fMAX CP;see Figure8 VCC=6.0V VCC=2.0V VCC=4.5V VCC=5.0V;CL=15pF VCC=6.0V VCC=2.0V VCC=4.5V VCC=5.0V;CL=15pF VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V 80 16 14 80 16 14 100 20 17 80 16 14 135 27 23 200 40 34 0 0 0 0 0 0 0 0 0 6 文档仅供参考,实际应用测试为准 www.xinboleic.com      技术支持热线:4009682003 14 69 25 21 20 69 25 21 20 19 7 6 22 8 3 28 10 8 30 11 9 22 8 6 41 15 12 63 23 18 -17 -6 -5 -41 -15 -12 -58 -21 -17 18 26 210 42 36 220 44 37 75 15 13 - ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns MHz 第 10 页 共 24 页 XBLW 74HC/HCT160 SYNCHRONOUS 4-BIT COUNTERS frequency power dissipation capacitance VCC=4.5V VCC=5.0V;CL=15pF VCC=6.0V CPD Propagation delay tpd HIGH to LOW proapagation delay tPHL transition time tt pulse width tw Recovery time trec Set-up time tsu Hold time th Maximum frequency fMAX power dissipation capacitance Note: fi=1MHz;;VI=GND to VCC[3] SN74HCT160 VCC=4.5V CP to Qn; see Figure8[1] VCC=5.0V;CL=15pF VCC=4.5V CP to TC; see Figure8 VCC=5.0V;CL=15pF VCC=4.5V CET to TC; see Figure9 VCC=5.0V;CL=15pF VCC=4.5V M� to Qn; see Figure10 VCC=5.0V;CL=15pF VCC=4.5V M� to TC; see Figure10 VCC=5.0V;CL=15pF VCC=4.5V;see Figure8,9[2] CP HIGH or LOW;VCC=4.5V;see Figure8 M� LOW;VCC=4.5V;see Figure10 M� CP;VCC=4.5V;see Figure10 Dn to CP;VCC=4.5V;see Figure11 P� to CP;VCC=4.5V;see Figure11 CEP,CET to CP;VCC=4.5V;see Figure12 Dn to CP;VCC=4.5V;see Figure11 P� to CP;VCC=4.5V;see Figure11 CEP,CET to CP;VCC=4.5V;see Figure12 VCC=4.5V CP;see Figure8 VCC=5.0V;CL=15pF CPD fi=1MHz;;VI=GND to VCC-1.5V[3] 30 35 55 61 66 - MHz MHz MHz - 39 - pF 16 20 20 18 30 50 0 0 0 16 - 25 21 28 24 17 14 27 23 30 26 7 8 11 9 10 18 30 -8 -13 -21 -28 31 43 48 35 50 50 15 - ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns MHz MHz - 34 - pF [1]tpd is the same as tPLH and tPHL. [2]tt is the same as tTHL and tTLH. [3]CPD is used to determine the dynamic power dissipation (PD in uW). PD=CPD×VCC2×fi×N+∑(CL×VCC2×fo) where: fi=input frequency in MHz; fo=output frequency in MHz; CL=output load capacitance in pF; XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com      技术支持热线:4009682003 第 11 页 共 24 页 XBLW 74HC/HCT160 SYNCHRONOUS 4-BIT COUNTERS VCC=supply voltage in V; N=number of inputs switching; ∑(CL×VCC2×f`)=sum of outputs. AC Characteristics 2 (Tamb=-40℃ to +85℃,tr=tf=6ns;CL=50pF, unless otherwise specified.) Parameter Symbol Conditions CP to Qn; see Figure8[1] Propagation delay tpd CP to TC; see Figure8 CET to TC; see Figure9 M� to Qn; see Figure10 High to LOW Propagation delay tPHL transition time tt pulse width M� to TC; see Figure10 tw see Figure8 and see Figure9[2] CP HIGH or LOW;see Figure8 M� LOW; see Figure10 Recovery time trec M� to CP; see Figure10 Dn to CP; see Figure11 Set-up time tsu P� to CP; see Figure11 XBLW version 1.0 SN74HC160 VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V Min. Typ. Max. Unit 100 20 17 100 20 17 125 25 21 100 20 17 170 34 29 - 230 46 39 270 54 46 190 38 33 265 53 45 275 55 47 95 19 16 - ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns 文档仅供参考,实际应用测试为准 www.xinboleic.com      技术支持热线:4009682003 第 12 页 共 24 页 XBLW 74HC/HCT160 SYNCHRONOUS 4-BIT COUNTERS VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V Dn to CP; VCC=4.5V see Figure11 VCC=6.0V VCC=2.0V P� to CP; see Figure11 VCC=4.5V VCC=6.0V VCC=2.0V CEP,CET to CP; VCC=4.5V see Figure12 VCC=6.0V VCC=2.0V CP;see Figure8 VCC=4.5V VCC=6.0V SN74HCT160 CP to Qn; VCC=4.5V see Figure8[1] CP to TC; VCC=4.5V see Figure8 CET to TC; VCC=4.5V see Figure9 M� to Qn; VCC=4.5V see Figure10 M� to TC; VCC=4.5V see Figure10 VCC=4.5V;see Figure8,9[2] CP HIGH or LOW;VCC=4.5V;see Figure8 M� LOW;VCC=4.5V;see Figure10 M� to CP;VCC=4.5V;see Figure10 Dn to CP;VCC=4.5V;see Figure11 P� to CP;VCC=4.5V;see Figure11 CEP,CET to CP;VCC=4.5V;see Figure12 Dn to CP;VCC=4.5V;see Figure11 P� to CP;VCC=4.5V;see Figure11 CEP,CET to CP;VCC=4.5V;see Figure12 250 50 43 0 0 0 0 0 0 0 0 0 4.8 24 28 - - ns ns ns ns ns ns ns ns ns ns ns ns MHz MHz MHz - - 54 ns - - 60 ns - - 44 ns - - 63 ns - - 63 ns 20 25 25 25 44 63 0 0 0 - 19 - ns ns ns ns ns ns ns ns ns ns CP;see Figure8 13 - - MHz CEP,CET to CP; see Figure12 Hold time th Maximum frequency fMAX Propagation delay tpd High to LOW proapagation delay tPHL transition time tt pulse width tw Recovery time trec Set-up time tsu Hold time th Maximum frequency Note: fMAX VCC=4.5V [1] tpd is the same as tPLH and tPHL. [2] tt is the same as tTHL and tTLH. XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com      技术支持热线:4009682003 第 13 页 共 24 页 XBLW 74HC/HCT160 SYNCHRONOUS 4-BIT COUNTERS AC Characteristics 3 (Tamb=-40℃ to +105℃; GND=0V; tr=tf=6ns; CL=50pF, unless otherwise specified.) Parameter Symbol Conditions CP to Qn; see Figure8[1] Propagation delay tpd CP to TC; see Figure8 CET to TC; see Figure9 M� to Qn; see Figure10 High to LOW Propagation delay tPHL transition time tt pulse width M� to TC; see Figure10 tw see Figure8 and see Figure9[2] CP HIGH or LOW;see Figure8 M� LOW; see Figure10 Recovery time trec M� to CP; see Figure10 Dn to CP; see Figure11 Set-up time tsu P� to CP; see Figure11 XBLW version 1.0 SN74HC160 VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V Min. Typ. Max. Unit 120 24 20 120 24 20 150 30 26 120 24 20 205 41 35 - 280 56 48 325 65 55 225 45 38 315 63 54 330 66 56 110 22 19 - ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns 文档仅供参考,实际应用测试为准 www.xinboleic.com      技术支持热线:4009682003 第 14 页 共 24 页 XBLW 74HC/HCT160 SYNCHRONOUS 4-BIT COUNTERS VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V Dn to CP; VCC=4.5V see Figure11 VCC=6.0V VCC=2.0V P� to CP; see Figure11 VCC=4.5V VCC=6.0V VCC=2.0V CEP,CET to CP; VCC=4.5V see Figure12 VCC=6.0V VCC=2.0V CP;see Figure8 VCC=4.5V VCC=6.0V SN74HCT160 CP to Qn; VCC=4.5V see Figure8[1] CP to TC; VCC=4.5V see Figure8 CET to TC; VCC=4.5V see Figure9 M� to Qn; VCC=4.5V see Figure10 M� to TC; VCC=4.5V see Figure10 VCC=4.5V;see Figure8,9[2] CP HIGH or LOW;VCC=4.5V;see Figure8 M� LOW;VCC=4.5V;see Figure10 M� to CP;VCC=4.5V;see Figure10 Dn to CP;VCC=4.5V;see Figure11 P� to CP;VCC=4.5V;see Figure11 CEP,CET to CP;VCC=4.5V;see Figure12 Dn to CP;VCC=4.5V;see Figure11 P� to CP;VCC=4.5V;see Figure11 CEP,CET to CP;VCC=4.5V;see Figure12 300 60 51 0 0 0 0 0 0 0 0 0 4.0 20 24 - - ns ns ns ns ns ns ns ns ns ns ns ns MHz MHz MHz - - 65 ns - - 72 ns - - 53 ns - - 15 ns - - 75 ns 24 30 30 30 53 75 0 0 0 - 22 - ns ns ns ns ns ns ns ns ns ns CP;see Figure8 11 - - MHz CEP,CET to CP; see Figure12 Hold time th Maximum frequency fMAX Propagation delay tpd High to LOW proapagation delay tPHL transition time tt pulse width tw Recovery time trec Set-up time tsu Hold time th Maximum frequency Note: fMAX VCC=4.5V [1] tpd is the same as tPLH and tPHL. [2] tt is the same as tTHL and tTLH. XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com      技术支持热线:4009682003 第 15 页 共 24 页 XBLW 74HC/HCT160 SYNCHRONOUS 4-BIT COUNTERS Testing Circuit AC Testing Circuit Figure 7. Test circuit for measuring switching times Definitions for test circuit: CL=Load capacitance including jig and probe capacitance. RT=Termination resistance should be equal to the output impedance Zo of the pulse generator. RL=Load resistance S1=Test selection switch XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com      技术支持热线:4009682003 第 16 页 共 24 页 XBLW 74HC/HCT160 SYNCHRONOUS 4-BIT COUNTERS AC Testing Waveforms Figure 8. The clock (CP) to outputs (Qn, TC) propagation delays, pulse width, output transition times and maximum frequency Figure 9. The count enable carry input (CET) to terminal count output (TC) propagation delays and output transition times XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com      技术支持热线:4009682003 第 17 页 共 24 页 XBLW 74HC/HCT160 SYNCHRONOUS 4-BIT COUNTERS Figure 10. The master reset (M�) pulse width, master reset to output (Qn, TC) propagation delays, and the master reset to clock (CP) recovery times XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com      技术支持热线:4009682003 第 18 页 共 24 页 XBLW 74HC/HCT160 SYNCHRONOUS 4-BIT COUNTERS Figure 11. The data input (Dn) and parallel enable input (P�) set-up and hold times Figure 12. The count enable input (CEP) and count enable carry input (CET) set-up and hold times Measurement Points Type SN74HC160 SN74HCT160 Input VI GND to VCC GND to 3V VM 0.5×VCC 1.3V Output VM 0.5×VCC 1.3V Test Data Type XBLW version 1.0 Input Load 文档仅供参考,实际应用测试为准 www.xinboleic.com      技术支持热线:4009682003 S1 position 第 19 页 共 24 页 XBLW 74HC/HCT160 SYNCHRONOUS 4-BIT COUNTERS VI tr,tf CL RL tPHL,tPLH SN74HC160 VCC 6.0ns 15pF,50pF 1KΩ open SN74HCT160 3.0V 6.0ns 15pF,50pF 1KΩ open Package Information DIP16 XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com      技术支持热线:4009682003 第 20 页 共 24 页 XBLW 74HC/HCT160 SYNCHRONOUS 4-BIT COUNTERS Symbol A A1 A2 B B1 C D E E1 e L E2 Dimensions In Millimeters Min Max 3.710 4.310 0.510 3.200 3.600 0.380 0.570 1.524(BSC) 0.204 0.360 18.800 19.200 6.200 6.600 7.320 7.920 2.540(BSC) 3.000 3.600 8.400 9.000 Dimensions In Inches Min Max 0.146 0.170 0.020 0.126 0.142 0.015 0.022 0.060(BSC) 0.008 0.014 0.740 0.756 0.244 0.260 0.288 0.312 0.100(BSC) 0.118 0.142 0.331 0.354 SOP16 XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com      技术支持热线:4009682003 第 21 页 共 24 页 XBLW 74HC/HCT160 SYNCHRONOUS 4-BIT COUNTERS Symbol A A1 A2 b C D E E1 e L θ Dimensions In Millimeters Min Max 1.350 1.750 0.100 0.250 1.350 1.550 0.330 0.510 0.170 0.250 9.800 10.200 3.800 4.000 5.800 6.200 1.270(BSC) 0.400 1.270 0° 8° Dimens ons In Inches Min Max 0.053 0.069 0.004 0.010 0.053 0.061 0.013 0.020 0.007 0.010 0.386 0.402 0.150 0.157 0.228 0.244 0.050(BSC) 0.016 0.050 0° 8° TSSOP16 XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com      技术支持热线:4009682003 第 22 页 共 24 页 XBLW 74HC/HCT160 SYNCHRONOUS 4-BIT COUNTERS MILLIMETER SYMBOL MIN NOM MAX A Al A2 A3 b bl c cl D E E1 e L L1 θ 0.05 0.90 0.39 0.20 0.19 0.13 0.12 4.90 6.20 4.30 1.00 0.44 0.22 0.13 5.00 6.40 4.40 0.65BSC 0.60 1.00BSC - 0.45 0 1.20 0.15 1.05 0.49 0.28 0.25 0.17 0.14 5.10 6.60 4.50 0.75 8° Statements And Notes Hazardous substances or Elements Part name Lead and lead compounds Mercury and mercury compounds Cadmium and cadmium compounds Hexavalent chromium compounds Polybro minated biphenyls Polybro minated biphenyl ethers Dibutyl phthalate Butyl benzyl phthalate Di-2ethylhexyl phthalate Diisobutyl phthalate Lead frame ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ Plastic resin ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ Chip ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ The lead ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ Plastic sheet installed ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ explanation ○: Indicates that the content of hazardous substances or elements in the detection limit of the following the SJ/T11363-2006 standard. ×: Indicates that the content of hazardous substances or elements exceeding the SJ/T11363-2006 Standard limit requirements Statement: XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com      技术支持热线:4009682003 第 23 页 共 24 页 XBLW 74HC/HCT160 SYNCHRONOUS 4-BIT COUNTERS  Shenzhen xinbole electronics co., ltd. reserves the right to change the product specifications, without notice! Before placing an order, the customer needs to confirm whether the information obtained is the latest version, and verify the integrity of the relevant information.  Any semiconductor product is liable to fail or malfunction under certain conditions, and the buyer shall be responsible for complying with safety standards in the system design and whole machine manufacturing using Shenzhen xinbole electronics co., ltd products, and take appropriate security measures to avoid the potential risk of failure may result in personal injury or property losses of the situation occurred!  Product performance is never ending, Shenzhen xinbole electronics co., ltd will be dedicated to provide customers with better performance, better quality of integrated circuit products. XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com      技术支持热线:4009682003 第 24 页 共 24 页
SN74HC160N 价格&库存
很抱歉,暂时无法提供与“SN74HC160N”相匹配的价格&库存,您可以联系我们找货
