SHENZHEN HAOLIN ELECTRONICS TECHNOLOGY CO., LTD
SOT-23 Plastic-Encapsulate MOSFET
5N04
N-Channel MOSFET
V(BR)DSS
SOT-23
ID
RDS(on)MAX
3
35 mΩ@10V
40V
5A
50 mΩ@4.5V
60 mΩ@2.5V
1. GATE
2. SOURCE
1
2
3. DRAIN
FEATURE
z TrenchFET Power MOSFET
z Low RDS(ON)
z Typical ESD Protection
APPLICATION
z Ideal for Load Swith and Battery
MARKING
Equivalent Circuit
Protection Applications
D
5N04
G
S
ABSOLUTE MAXIMUM RATINGS (Ta=25℃ unless otherwise noted)
Parameter
Symbol
Value
Unit
Drain-Source Voltage
VDS
40
V
Gate-Source Voltage
VGS
±20
V
ID
5
A
Pulsed Drain Current
IDM*
A
Thermal Resistance from Junction to Ambient
RθJA
417
℃/W
Junction Temperature
TJ
150
Storage Temperature
TSTG
-55~+150
TL
260
Continuous Drain Current
Lead Temperature for Soldering Purposes(1/8’’ from case for 10 s)
*Repetitive rating:Pluse width limited by junction temperature.
1
A,Apr,2017
MOSFET ELECTRICAL CHARACTERISTICS
Ta =25 ℃ unless otherwise specified
Parameter
Symbol
Test Condition
Min
Typ
Max
Unit
STATIC PARAMETERS
V(BR)DSS
VGS = 0V, ID =250µA
Zero gate voltage drain current
IDSS
VDS =40V,VGS = 0V
Gate-body leakage current
IGSS
VGS =±20V, VDS = 0V
VGS(th)
VDS =VGS, ID =250µA
Drain-source breakdown voltage
Gate threshold voltage(note 1)
Drain-source on-resistance (note 1)
RDS(on)
40
V
1
1.0
µA
±100
nA
2.5V
V
VGS =20V, ID =5A
35
42
mΩ
VGS =4.5V, ID =5A
48
72
mΩ
VGS =2.5V, ID =5A
60
80
mΩ
15
Forward tranconductance (note 1)
gFS
VDS =5V, ID =4A
Diode forward voltage (note 1)
VSD
IS=1A, VGS = 0V
S
1
V
DYNAMIC PARAMETERS (note2)
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
245
pF
35
pF
Crss
pF
td(on)
2
ns
VDS =15V,VGS =0V,f =1MHz
SWITCHING PARAMETERS (note 2)
Turn-on delay time
Turn-on rise time
Turn-off delay time
Turn-off fall time
tr
VDD=15V,VGS=10V
3.5
ns
td(off)
RL=3.75Ω,RGEN=3Ω
22
ns
3.5
ns
tf
Total Gate Charge
Qg
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
Notes :
10
VDS =15V,VGS =10V,ID=4A
nC
0.5
nC
1
nC
1. Pulse Test : Pulse width≤300μs, duty cycle≤0.5%.
2. Guaranteed by design, not subject to production testing.
2
A,Apr,2017
Typical Characteristics
Output Characteristics
40
Ta=25℃
18
Transfer Characteristics
14
VDS=3V
VGS=2.5V,3V,4V,5V
Pulsed
Pulsed
12
16
(A)
10
Ta=100℃
Ta=25℃
ID
(A)
12
DRAIN CURRENT
ID
DRAIN CURRENT
VGS=2V
14
10
8
6
8
6
4
VGS=1.5V
4
2
2
0.5
1.0
1.5
2.0
2.5
3.0
3.5
DRAIN TO SOURCE VOLTAGE
VDS
4.0
4.5
5.0
0.5
(V)
1.0
1.5
2.0
GATE TO SOURCE VOLTAGE
2.5
VGS
RDS(ON) —— VGS
RDS(ON) —— ID
50
250
Pulsed
Ta=25℃
Pulsed
ID=5A
45
(m)
RDS(ON)
(m)
ON-RESISTANCE
RDS(ON)
ON-RESISTANCE
200
VGS=2.5V
40
VGS=4.5V
35
VGS=10V
30
25
0.5
3.0
(V)
1.0
1.5
2.0
2.5
3.0
DRAIN CURRENT
3.5
ID
4.0
4.5
150
50
Ta=100℃
100
Ta=25℃
(A)
1
2
3
4
5
6
7
VGS
8
9
10
(V)
Threshold Voltage
IS —— VSD
6
1.4
Pulsed
VTH
1
Ta=100℃
THRESHOLD VOLTAGE
SOURCE CURRENT
IS (A)
(V)
1.2
Ta=25℃
0.1
1.0
ID=250uA
0.8
0.6
0.4
0.2
0.01
0.0
0.2
0.4
0.6
0.8
1.0
1.2
SOURCE TO DRAIN VOLTAGE
1.4
1.6
0.0
25
1.8
VSD (V)
50
75
JUNCTION TEMPERATURE
3
100
Tj
125
A,Apr,2017
SOT-23 Package Outline Dimensions
Symbol
A
A1
A2
b
c
D
E
E1
e
e1
L
L1
θ
Dimensions In Millimeters
Min
Max
0.900
1.150
0.000
0.100
0.900
1.050
0.300
0.500
0.080
0.150
2.800
3.000
1.200
1.400
2.250
2.550
0.950 TYP
1.800
2.000
0.550 REF
0.300
0.500
0°
8°
Dimensions In Inches
Min
Max
0.035
0.045
0.000
0.004
0.035
0.041
0.012
0.020
0.003
0.006
0.110
0.118
0.047
0.055
0.089
0.100
0.037 TYP
0.071
0.079
0.022 REF
0.012
0.020
0°
8°
SOT-23 Suggested Pad Layout
4
A,Apr,2017
很抱歉,暂时无法提供与“5N04”相匹配的价格&库存,您可以联系我们找货
