SPECIFICATION FOR APPROVAL
承
认
书
Magnetic Buzzer
Description
Vender’s Part No.
Customer’s. Part No.
Serial No.
FDM-2004
Version No.
1.1
HYG-9605B
CUSTOMER’S APPROVED SIGNATURE
江苏省兴化市陈堡镇人民路 1 号
TEL: 13625199874
E-Mail: 391245375@qq.com
Approved By
钱万进
FAX: +86-523-83723118
Http: //www.js-huayu.com
Checked By
易
申
Made By
吕 玲
A. SCOPE
This specification applies magnetic buzzer, HYG-9605B 5V
B. SPECIFICATION
No.
Item
Unit
Specification
Condition
1
Oscillation Frequency
KHz
2.7±0.3
2
Operating Voltage
VDC
4~7
3
Rated Voltage
VDC
5
4
Current Consumption
mA
MAX. 30
at Rated Voltage
5
Sound Pressure Level
dB
MIN. 80
at 10cm at Rated Voltage
6
Tone Nature
7
Operating Temperature
-20 ~ +70
8
Storage Temperature
-30 ~ +85
9
Dimension
mm
9.6x 9.6x H5.0
10
Weight (MAX)
gram
1.5
11
Housing Material
PPS( Black )
12
Leading Pin
Plated Brass(Au)
13
Environmental
Protection Regulation
RoHS
Single
See appearance drawing
C. APPEARANCE DRAWING
Tol : ±0.3
Unit: mm
兴化市华宇电子有限公司 XINGHUA HUAYU
ELECTRONIC CO.,LTD
2/6 HYG-9605B
5v
D.TESTING METHOD
Standard Measurement conditions
Temperature:25±2℃ Humidity:45-65%
Acoustic Characteristics:
The oscillation frequency, current consumption and sound pressure are measured by the
measuring instruments shown below
In the measuring test, buzzer is placed as follows:
E. VOLTAGE / CURRENT / SOUND PRESSURE CHARACTERISTICS
mA-V
dB-V
(dB)
(mA)
95
30
90
25
85
15
Temp 25°
at 10cm
75
3
4
5
6
7
Temp 25°
at 10cm
10
8
(VDC)
3
4
ELECTRONIC CO.,LTD
5
6
7
8
3/6 HYG-9605B
(VDC)
5v
F. Soldering Condition
(1)Recommendable reflow soldering condition is as follows
(Reflow soldering is twice)
Note:It is requested that reflow soldering should be executed
after heat of product goes down to normal.
Heat resistant line
(Used when heat resistant reliability test is performed)
(2)Manual soldering
Manual soldering temperature 350 º
C within 5 sec.
ELECTRONIC CO.,LTD
4/6 HYG-9605B
5v
G. RELIABILITY TEST
NO.
ITEM
TEST CONDITION AND REQUIREMENT
1
High Temperature
Test (Storage)
After being placed in a chamber with 85 2º
C for 96 hours and then
being placed in normal condition for 2 hours.
Allowable variation of SPL after test:
2
Low Temperature
Test (Storage)
After being Placed in a chamber with -30 2º
3
10dB.
10dB.
After being Placed in a chamber with 90-95% R.H. at 40 2º
C for 96
hours and then being placed in normal condition for 2 hours.
Humidity Test
Allowable variation of SPL after test: 10dB.
The part shall be subjected to 5 cycles. One cycle shall be consist of:
+70ºC
+25ºC
4
5
6
Temperature Cycle
Test
+25ºC
- 20ºC
Drop on a hard wood board of 4cm thick, any directions ,6 times,
at the height of 75cm .
Drop Test
After being applied vibration of amplitude of 1.5mm with 10 to 55 Hz
band of vibration frequency to each of 3 perpendicular directions for
2 hours .
Vibration Test
Lead terminals are immersed in rosin for 5 seconds and then
7
Solderability
Test
8
Terminal Strength
Pulling Test
immersed in solder bath of +300 5º
C for 3 1 seconds .
90% min. lead terminals shall be wet with solder
(Except the edge of terminals).
The force of 9.8N(1.0kg) is applied to each terminal in axial direction for
10 seconds.
No visible damage and cutting off.
TEST CONDITION.
Standard Test Condition
一般测试条件
Judgment Test Condition
争议时测试条件
a) Temperature : +5 ~ +35℃
a) 温度 : +5 ~ +35℃
a) Temperature : +25 ±2℃
a) 温度 : +25 ±2℃
b) Humidity : 45-85%
b) 湿度 : 45-85%
b) Humidity : 60-70%
b) 湿度 : 60-70%
ELECTRONIC CO.,LTD
c) Pressure : 860-1060mbar
c) 气压 : 860-1060mbar
5/6 HYG-9605B
5v
H. PACKING STANDARD
1 Reel : 600PCS
Carton Box
(10 Inner Box)
Inner Box
(1Layer Reel)
Inner Box
330mmx330mmx30mm
1x600PCS=600PCS
Carton Box
350mmx350mmx370mm
10x600PCS=6,000PCS
ELECTRONIC CO.,LTD
6/6 HYG-9605B
5v
很抱歉,暂时无法提供与“HYG-9605B 5V”相匹配的价格&库存,您可以联系我们找货
