YGW40N65F1
650V /40A Trench Field Stop IGBT
FEATURES
High breakdown voltage up to 650V for
improved reliability
Trench-Stop Technology offering :
VCE
650
V
IC
40
A
VCE(SAT) IC=40A
1.80
V
High speed switching
High ruggedness, temperature stable
Low VCEsat
Easy parallel switching capability due
to positive temperature coefficient in
VCEsat
Enhanced avalanche capability
APPLICATION
Uninterruptible Power Supplies
Inverter
Welding Converters
PFC applications
Converter with high switching frequency
Product
YGW40N65F1
http://www.lu-semi.com
Package
TO247
1
Packaging
Tube
2022.06 / Rev4.3
YGW40N65F1
Maximum Ratings (Tj= 25℃ unless otherwise specified)
Parameter
Symbol
Value
Unit
VCE
650
V
IC
80
40
A
IF
80
40
A
Continuous Gate-emitter voltage
VGE
±20
V
Transient Gate-emitter voltage
VGE
±30
V
120
A
Pulse collector current, VGE =15V,
tp limited by Tjmax
ICM
120
A
Power dissipation , Tj=25°C
Ptot
188
W
Operating junction temperature
Tj
-40...+175
°C
Storage temperature
TS
-55...+150
°C
260
°C
M
0.6
Nm
Collector-Emitter Breakdown Voltage
DC collector current, limited by Tjmax
TC = 25°C
TC = 100°C
Diode Forward current, limited by Tjmax
TC = 25°C
TC = 100°C
Turn off safe operating area VCE ≤650V,
Tj ≤ 175°C, tp = 1μs
Soldering temperature, wave soldering
1.6mm (0.063in.) from case for 10s
Mounting torque, M3 screw Maximum of
mounting processes: 3
Thermal Resistance
Parameter
Symbol
Max. Value
Unit
IGBT thermal resistance,
junction - case
Rθ(j-c)
0.8
K/W
Diode thermal resistance,
junction - case
Rθ(j-c)
1.1
K/W
Thermal resistance,
junction - ambient
Rθ(j-a)
40
K/W
2
2022.06 / Rev4.3
YGW40N65F1
Electrical Characteristics (Tj= 25℃ unless otherwise specified)
Parameter
Symbol
Conditions
Min
Typ
Max
Unit
Static
Voltage
BVCES
VGE=0V , IC=250uA
650
V
Gate Threshold Voltage
VGE(th)
VGE=VCE, IC=250uA
4.0
4.9
5.6
V
Collector-Emitter Saturation
Voltage
VCE(sat)
VGE=15V, IC=40A
Tj = 25°C
Tj = 175°C
1.80
2.60
2.40
V
Zero gate voltage collector current
ICES
VCE = 650V, VGE = 0V
Tj = 25°C
Tj = 175°C
0.1
40
4000
μA
Gate-emitter leakage current
IGES
VCE = 0V, VGE = ±20V
100
nA
Transconductance
gfs
VCE = 20V, IC = 40A
S
Min
Typ
Max
Unit
2100
100
40
90
Parameter
Symbol
Conditions
Dynamic
Input capacitance
Cies
Output capacitance
Coes
Reverse transfer capacitance
Cres
Gate charge
QG
VCE = 30V, VGE = 0V,
f = 1MHz
VCC = 520V, IC = 40A,
VGE = 15V
3
pF
nC
2022.06 / Rev4.3
YGW40N65F1
Switching Characteristic, Inductive Load
Parameter
Symbol
Conditions
Min
Typ
Max
Unit
td(on)
45
tr
80
120
ns
75
ns
Dynamic Tj=25C
Turn-on Delay Time
Rise Time
Turn-off Delay Time
td(off)
Fall Time
tf
VCC = 400V, IC = 40.0A,
VGE = 0.0/15.0V,
Rg=20Ω
ns
ns
Turn-on Energy
Eon
2.0
mJ
Turn-off Energy
Eoff
0.4
mJ
Unit
Electrical Characteristics of the DIODE(Tj= 25℃ unless otherwise specified)
Parameter
Symbol
Conditions
Min
Typ
Max
1.8
2.4
V
75
ns
12
A
550
nC
Dynamic
Diode Forward Voltage
VFM
Reverse Recovery Time
Trr
Reverse Recovery Current
Irr
Reverse Recovery Charge
Qrr
IF = 40A
IF= 40A,
VR = 400V,
di/dt= 300A/μs,
4
2022.06 / Rev4.3
YGW40N65F1
Fig. 1 FBSOA characteristics
Fig. 2 Power dissipation as a function of TC
200
100
180
160
140
tP = 10μs
10
120
Ptot(W)
50μs
IC(A)
100μs
500μs
100
80
1ms
DC
1
60
40
Ta=25°C, Tj ≤175℃ , VGE=15V
1
10
100
25
1000
50
75
100
Fig. 3 Output characteristics
150
175
Fig. 4 Saturation voltage characteristics
80
100
70
90
25℃
150℃
80
175℃
VGE = 20V
17V
60
15V
70
13V
50
60
IC(A)
11V
IC(A)
125
TC(℃)
VCE(V)
9V
40
50
7V
40
30
30
VGE = 15V
10
2
3
4
5
VCE(V)
1
2
3
4
VCE(V)
5
2022.06 / Rev4.3
5
YGW40N65F1
Fig. 5 Switching times vs. gate resistor
Fig. 6 Switching times vs. collector current
1000
td(off)
td(off)
tf
tf
td(on)
td(on)
tr
tr
t, SWITCHING TIMES [ns]
1000
100
100
Common Emitter
Common Emitter
VCC = 400V, VGE = 15V, IC=40A
VCC = 400V, VGE = 15V, RG=20Ω
Ta=25℃
Ta=25℃
10
10
40
50
60
Rg (Ω)
40
50
60
70
80
IC(A)
Fig. 7 Switching loss vs. gate resistor
Fig. 8 Switching loss vs. collector current
3
4.5
Eoff
Eoff
4
Eon
Eon
2.5
3.5
3
Switching loss (mJ)
Switching loss (mJ)
2
1.5
1
2.5
2
1.5
1
0.5
Common Emitter
0.5
Common Emitter
Ta=25℃
RG=20Ω, Ta=25℃
5 10 15 20 25 30 35 40 45 50 55 60
Rg (Ω)
10
40
50
60
70
80
Ic (A)
6
2022.06 / Rev4.3
YGW40N65F1
Fig. 9 Gate charge characteristics
Fig. 10 Capacitance characteristics
10000
15
Ciss(pF)
360V
Coss(pF)
Crss(pF)
520V
12
1000
VGE (V)
Capacitance
9
6
100
Common Emitter
IC= 40A ,Ta=25℃
3
Common Emitter
VGE = 0V, f = 1MHz
Ta=25℃
100
Qg (nC)
7
10
VCE(V)
2022.06 / Rev4.3
30
YGW40N65F1
TO247 package information
8
2022.06 / Rev4.3
很抱歉,暂时无法提供与“YGW40N65F1”相匹配的价格&库存,您可以联系我们找货
