RP100N331D-TR-FE
RP100N331D-TR-FE
    NISSHINBO(日清纺)
    SC-74A
    PMIC - 稳压器 - 线性 正 固定 1 输出 200mA SOT-23-5
RP100N331D-TR-FE 数据手册
RP100x SERIES 0.6% ACCURACY LOW NOISE 200mA LDO REGULATOR NO.EA-140-160425 OUTLINE The RP100x Series are CMOS-based voltage regulator ICs with high output voltage accuracy, extremely low supply current, low ON-resistance, and high ripple rejection. Each of these ICs consists of a voltage reference unit, an error amplifier, resistor-net for voltage setting, a current limit circuit and a chip enable circuit. These ICs perform with low dropout voltage and a chip enable function. The line transient response and load transient response of the RP100x Series are excellent, thus these ICs are very suitable for the power supply for hand-held communication equipment. The output voltage of these ICs is fixed with high accuracy. Since the packages for these ICs are SOT-23-5 and DFN(PL)1612-4, therefore high density mounting of the ICs on boards is possible. FEATURES • • • • • • • • • • Supply Current ...................................................... Typ. 18μA Standby Current .................................................... Typ. 0.1μA Dropout Voltage .................................................... Typ. 0.13V (IOUT=150mA, VOUT=2.8V) Ripple Rejection .................................................... Typ. 75dB (f=1kHz) Temperature-Drift Coefficient of Output Voltage ... Typ. ±30ppm/°C Line Regulation ..................................................... Typ. 0.02%/V Output Voltage Accuracy....................................... ±0.6% Packages .............................................................. DFN(PL)1612-4, SOT-23-5 Input Voltage Range ............................................. 1.7V to 5.25V Output Voltage Range ........................................... 1.2V to 3.3V (0.1V steps) (For other voltages, please refer to MARK INFORMATIONS.) • Built-in Fold Back Protection Circuit ..................... Typ. 40mA (Current at short mode) • Ceramic capacitors are recommended to be used with this IC ..... 1.0μF or more APPLICATIONS • Power source for portable communication equipment. • Power source for electrical appliances such as cameras, VCRs and camcorders. • Power source for battery-powered equipment. 1 RP100x NO.EA-140-160425 BLOCK DIAGRAMS RP100xxx1B VDD RP100xxx1D VOUT VDD Vref VOUT Vref Current Limit Current Limit CE GND CE GND SELECTION GUIDE The output voltage, auto discharge function, package, and the taping type, etc. for the ICs can be selected at the user’s request. Product Name RP100Kxx1∗-TR RP100Nxx1∗-TR-FE Package DFN(PL)1612-4 SOT-23-5 Quantity per Reel Pb Free Halogen Free 5,000 pcs Yes Yes 3,000 pcs Yes Yes xx : The output voltage can be designated in the range from 1.2V(12) to 3.3V(33) in 0.1V steps. (For other voltages, please refer to MARK INFORMATIONS.) ∗ : CE pin polarity and auto discharge function at off state are options as follows. (B) "H" active, without auto discharge function at off state (D) "H" active, with auto discharge function at off state 2 RP100x NO.EA-140-160425 PIN CONFIGURATIONS • SOT-23-5 • DFN(PL)1612-4 Bottom View Top View 4 3 3 5 4 4 (mark side) 1 2 2 1 1 2 3 PIN DESCRIPTIONS • DFN(PL)1612-4 Pin No Symbol Pin Description 1 VOUT Output Pin 2 GND Ground Pin 3 CE Chip Enable Pin ("H" Active) 4 VDD Input Pin ∗) Tab is GND level. (They are connected to the reverse side of this IC.) The tab is better to be connected to the GND, but leaving it open is also acceptable. • SOT-23-5 Pin No Symbol Pin Description 1 VDD 2 GND 3 CE Chip Enable Pin ("H" Active) 4 NC No Connection 5 VOUT Output Pin Input Pin Ground Pin 3 RP100x NO.EA-140-160425 ABSOLUTE MAXIMUM RATINGS Symbol Item Rating Unit VIN Input Voltage 6.0 V VCE Input Voltage (CE Pin) 6.0 V VOUT Output Voltage −0.3 to VIN+0.3 V IOUT Output Current 300 mA PD Power Dissipation (SOT-23-5)∗ Power Dissipation (DFN(PL)1612-4) 420 ∗ 610 mW Topt Operating Temperature Range −40 to 85 °C Tstg Storage Temperature Range −55 to 125 °C ∗) For Power Dissipation, please refer to PACKAGE INFORMATION. ABSOLUTE MAXIMUM RATINGS Electronic and mechanical stress momentarily exceeded absolute maximum ratings may cause the permanent damages and may degrade the life time and safety for both device and system using the device in the field. The functional operation at or over these absolute maximum ratings is not assured. 4 RP100x NO.EA-140-160425 ELECTRICAL CHARACTERISTICS • RP100xxx1B/D VIN=Set VOUT+1V, IOUT=1mA, CIN=COUT =1μF, unless otherwise noted. Symbol Item VOUT Output Voltage IOUT Output Current ΔVOUT/ΔIOUT Load Regulation VDIF Dropout Voltage Conditions Topt=25°C Min. Typ. Max. VOUT > 2.0V ×0.994 ×1.006 V VOUT ≤ 2.0V −12 +12 mV 200 1mA ≤ IOUT ≤ 150mA IOUT=150mA Unit mA 20 40 1.2V ≤ VOUT < 1.5V 0.40 0.50 1.5V ≤ VOUT < 1.7V 0.24 0.38 1.7V ≤ VOUT < 2.0V 0.21 0.34 2.0V ≤ VOUT < 2.5V 0.17 0.30 2.5V ≤ VOUT < 2.8V 0.14 0.25 2.8V ≤ VOUT ≤ 3.3V 0.13 0.23 mV V Supply Current IOUT=0mA 18 25 μA Istandby Standby Current VCE=0V 0.1 2.0 μA ΔVOUT/ΔVIN Line Regulation Set VOUT+0.5V ≤ VIN ≤ 5.0V 0.02 0.10 %/V RR Ripple Rejection f=1kHz, Ripple 0.2Vp-p VIN=Set VOUT+1V, IOUT=30mA (In case that VOUT ≤ 2.0V, VIN=3V) VIN Input Voltage∗ ISS 75 1.7 dB 5.25 V Output Voltage Temperature Coefficient −40°C ≤ Topt ≤ 85°C ±30 ppm /°C ISC Short Current Limit VOUT=0V 40 mA IPD CE Pull-down Current 0.3 μA VCEH CE Input Voltage "H" VCEL CE Input Voltage "L" ΔVOUT/ΔTopt en RLOW 1.1 V 0.3 V Output Noise BW=10Hz to 100kHz IOUT=30mA 30 μVrms Low Output Nch Tr. ON Resistance (of D version) VIN=4.0V, VCE=0V 30 Ω ∗) The maximum Input Voltage of the ELECTRICAL CHARACTERISTICS is 5.25V. In case of exceeding this specification, the IC must be operated on condition that the Input Voltage is up to 5.5V and the total operating time is within 500hrs. RECOMMENDED OPERATING CONDITIONS (ELECTRICAL CHARACTERISTICS) All of electronic equipment should be designed that the mounted semiconductor devices operate within the recommended operating conditions. The semiconductor devices cannot operate normally over the recommended operating conditions, even if when they are used over such conditions by momentary electronic noise or surge. And the semiconductor devices may receive serious damage when they continue to operate over the recommended operating conditions. 5 RP100x NO.EA-140-160425 TYPICAL APPLICATION VDD C1 VOUT RP100x Series CE VOUT C2 GND (External Components) C2 1.0μF MURATA: GRM155B31A105KE15 TECHNICAL NOTES When using these ICs, consider the following points: Phase Compensation In these ICs, phase compensation is made for securing stable operation even if the load current is varied. For this purpose, use a capacitor C2 with good frequency characteristics and ESR (Equivalent Series Resistance). Ceramic capacitors have different temperature characteristics and bias characteristics depending on their dimensions and manufacturers. If the setting voltage is 2.5V or more and the capacitor’s dimensions for VOUT equal to 1.0mm by 0.5mm or smaller than that, the capacitance value might be extremely low. As a result, the capacitance might be much less than expected value. In such cases, the operation might be unstable at low temperature. (−20°C or less) In that case, use a larger capacity, or a large dimensions’ capacitor. (For example 1.6mm by 0.8mm) If a tantalum capacitor is selected as an output capacitor, large ESR may be a cause of unstable operation. Evaluate the operation of PCB with considerable frequency characteristics. PCB Layout Make VDD and GND lines sufficient. If their impedance is high, noise pickup or unstable operation may result. Connect a capacitor C1 with a capacitance value as much as 1.0μF or more between VDD and GND pin, and as close as possible to the pins. Set external components, especially the output capacitor C2, as close as possible to the ICs, and make wiring as short as possible. 6 RP100x NO.EA-140-160425 TEST CIRCUITS VDD VOUT RP100x Series C1 CE C2 V VOUT IOUT GND C1=Ceramic 1.0μF C2=Ceramic 1.0μF Basic Test Circuit VDD A VOUT RP100x Series C1 ISS VOUT CE C2 GND C1=Ceramic 1.0μF C2=Ceramic 1.0μF Test Circuit for Supply Current Pulse Generator VDD VOUT RP100x Series P.G. CE C2 IOUT GND C2=Ceramic 1.0μF Test Circuit for Ripple Rejection VDD C1 RP100x Series CE VOUT VOUT C2 GND IOUTa IOUTb C1=Ceramic 1.0μF C2=Ceramic 1.0μF Test Circuit for Load Transient Response 7 RP100x NO.EA-140-160425 TYPICAL CHARACTERISTICS 1) Output Voltage vs. Output Current (C1=1.0μF, C2=1.0μF, Topt=25°C) RP100x251x 1.4 2.7 1.2 2.4 Output Voltage VOUT (V) Output Voltage VOUT (V) RP100x121x VIN=2.2V VIN=3.6V VIN=4.2V VIN=5.0V VIN=5.5V 1.0 0.8 0.6 0.4 0.2 0 2.1 1.8 VIN=3.5V VIN=4.2V VIN=5.0V VIN=5.5V 1.5 1.2 0.9 0.6 0.3 0 0 100 200 300 Output Current IOUT (mA) 400 0 100 200 300 Output Current IOUT (mA) 400 RP100x331x Output Voltage VOUT (V) 3.5 3.0 VIN=4.3V VIN=5.0V VIN=5.5V 2.5 2.0 1.5 1.0 0.5 0 0 100 200 300 Output Current IOUT (mA) 400 2) Output Voltage vs. Input Voltage (C1=1.0μF, C2=1.0μF, Topt=25°C) RP100x121x 1.4 2.8 1.2 2.4 1.0 0.8 IOUT=1mA IOUT=30mA IOUT=50mA 0.6 0.4 0.2 0 2.0 1.6 IOUT=1mA IOUT=30mA IOUT=50mA 1.2 0.8 0.4 0 0 8 Output Voltage VOUT (V) Output Voltage VOUT (V) RP100x121x 1 2 3 4 Input Voltage VIN (V) 5 0 1 2 3 4 Input Voltage VIN (V) 5 RP100x NO.EA-140-160425 RP100x121x Output Voltage VOUT (V) 3.5 3.0 2.5 2.0 IOUT=1mA IOUT=30mA IOUT=50mA 1.5 1.0 0.5 0 0 1 2 3 4 Input Voltage VIN (V) 5 3) Supply Current vs. Input Voltage (C1=1.0μF, C2=1.0μF, Topt=25°C) RP100x251x 35 35 30 30 Supply Current ISS (μA) Supply Current ISS (μA) RP100x121x 25 20 15 10 5 0 25 20 15 10 5 0 0 1 2 3 4 Input Voltage VIN (V) 5 0 1 2 3 4 Input Voltage VIN (V) 5 RP100x331x Supply Current ISS (μA) 35 30 25 20 15 10 5 0 0 1 2 3 4 Input Voltage VIN (V) 5 9 RP100x NO.EA-140-160425 4) Output Voltage vs. Temperature (C1=1.0μF, C2=1.0μF, IOUT=1mA) 1.25 1.24 1.23 1.22 1.21 1.20 1.19 1.18 1.17 1.16 1.15 -40 -25 RP100x251x VIN=2.2V Output Voltage VOUT (V) Output Voltage VOUT (V) RP100x121x 0 25 50 Temperature Topt (°C) 75 85 2.55 2.54 2.53 2.52 2.51 2.50 2.49 2.48 2.47 2.46 2.45 -40 -25 VIN=3.5V 0 25 50 Temperature Topt (°C) 75 85 Output Voltage VOUT (V) RP100x331x 3.35 3.34 3.33 3.32 3.31 3.30 3.29 3.28 3.27 3.26 3.25 -40 -25 VIN=4.3V 0 25 50 Temperature Topt (°C) 75 85 5) Supply Current vs. Temperature (C1=1.0μF, C2=1.0μF, IOUT=0mA) RP100x121x 25 20 15 10 5 0 -40 -25 10 VIN=2.2V 30 Supply Current ISS (μA) Supply Current ISS (μA) 30 RP100x251x 0 25 50 Temperature Topt (°C) 75 85 VIN=3.5V 25 20 15 10 5 0 -40 -25 0 25 50 Temperature Topt (°C) 75 85 RP100x NO.EA-140-160425 RP100x331x VIN=4.3V Supply Current ISS (μA) 30 25 20 15 10 5 0 -40 -25 0 25 50 Temperature Topt (°C) 75 85 6) Dropout Voltage vs. Output Current (C1=1.0μF,C2=1.0μF) RP100x121x RP100x151x 350 400 85°C 25°C -40°C 350 300 Dropout Voltage VDIF (mV) Dropout Voltage VDIF (mV) 450 250 200 150 100 50 0 85°C 25°C -40°C 300 250 200 150 100 50 0 0 50 100 150 Output Current IOUT (mA) 200 0 RP100x171x 200 RP100x201x 300 350 85°C 25°C -40°C 300 250 Dropout Voltage VDIF (mV) Dropout Voltage VDIF (mV) 50 100 150 Output Current IOUT (mA) 200 150 100 50 85°C 25°C -40°C 250 200 150 100 50 0 0 0 50 100 150 Output Current IOUT (mA) 200 0 50 100 150 Output Current IOUT (mA) 200 11 RP100x NO.EA-140-160425 RP100x251x RP100x281x 250 85°C 25°C -40°C 200 Dropout Voltage VDIF (mV) Dropout Voltage VDIF (mV) 250 150 100 50 0 85°C 25°C -40°C 200 150 100 50 0 0 50 100 150 Output Current IOUT (mA) 200 0 50 100 150 Output Current IOUT (mA) RP100x331x Dropout Voltage VDIF (mV) 200 85°C 25°C -40°C 150 100 50 0 0 50 100 150 Output Current IOUT (mA) 200 7) Dropout Voltage vs Set Output Voltage (C1=1.0μF, C2=1.0μF, Topt=25°C) Dropout voltage VDIF (mV) 500 10mA 30mA 100mA 150mA 200mA 400 300 200 100 0 1 12 1.5 2.0 2.5 3.0 Set Output Voltage VREG (V) 3.5 200 RP100x NO.EA-140-160425 8) Ripple Rejection vs. Input Bias Voltage (C1=none, C2=1.0μF, Ripple=0.2Vp-p, Topt=25°C) RP100x121x IOUT=1mA 90 80 70 60 50 40 30 1kHz 10kHz 100kHz 20 10 IOUT=30mA 90 Ripple Rejection RR (dB) Ripple Rejection RR (dB) RP100x121x 80 70 60 50 40 30 1kHz 10kHz 100kHz 20 10 0 1.2 1.7 2.2 2.7 3.2 3.7 4.2 4.7 5.2 Input Voltage VIN (V) 0 1.2 1.7 2.2 2.7 3.2 3.7 4.2 4.7 5.2 Input Voltage VIN (V) RP100x281x RP100x281x C1=none IOUT=30mA 90 90 80 80 Ripple Rejection RR (dB) Ripple Rejection RR (dB) C1=none IOUT=1mA 70 60 50 40 30 1kHz 10kHz 100kHz 20 10 0 2.8 3.3 3.8 4.3 4.8 Input Voltage VIN (V) 70 60 50 40 30 1kHz 10kHz 100kHz 20 10 0 2.8 5.3 3.3 3.8 4.3 4.8 Input Voltage VIN (V) 5.3 9) Ripple Rejection vs. Frequency (C1=none, C2=1.0μF, Ripple=0.2Vp-p) RP100x121x VIN=2.2V IOUT=1mA IOUT=30mA IOUT=150mA 100 80 60 40 20 0 0.1 1 10 100 Frequency f (kHz) 1000 VIN=3.5V 120 Ripple Reiection RR (dB) 120 Ripple Reiection RR (dB) RP100x121x IOUT=1mA IOUT=30mA IOUT=150mA 100 80 60 40 20 0 0.1 1 10 100 Frequency f (kHz) 1000 13 RP100x NO.EA-140-160425 RP100x331x VIN=4.3V Ripple Reiection RR (dB) 120 IOUT=1mA IOUT=30mA IOUT=150mA 100 80 60 40 20 0 0.1 1 10 100 Frequency f (kHz) 1000 RP100x121x VIN=2.2V 120 -40°C 25°C 85°C 100 80 60 40 20 0 0.1 1 10 100 Frequency f (kHz) 1000 RP100x331x VIN=4.3V Ripple Reiection RR (dB) 120 80 60 40 20 0 0.1 14 -40°C 25°C 85°C 100 1 10 100 Frequency f (kHz) 1000 VIN=3.5V 120 Ripple Reiection RR (dB) Ripple Reiection RR (dB) RP100x251x -40°C 25°C 85°C 100 80 60 40 20 0 0.1 1 10 100 Frequency f (kHz) 1000 RP100x NO.EA-140-160425 10) Input Transient Response (IOUT=30mA, tr=tf=5μs, Topt=25°C) RP100x121x RP100x251x 5.0 2.0 1.203 1.198 Output Voltage 1.193 1.188 4.5 Input Voltage 4.0 3.5 2.0 2.506 2.501 Input Voltage VIN(V) 2.5 Output Voltage VOUT (V) 3.0 Input Voltage Input Voltage VIN(V) Output Voltage VOUT (V) 3.5 Output Voltage 2.496 2.491 0 20 40 60 Time t (μs) 80 100 0 20 40 60 Time t (μs) 80 100 RP100x331x 5 Input Voltage 4 3.305 3.300 3.295 Input Voltage VIN(V) Output Voltage VOUT (V) 6 Output Voltage 3.290 0 20 40 60 Time t (μs) 80 100 11) Load Transient Response (C2=1.0μF, Topt=25°C) RP100x251x 50 100mA 0 1.20 1.19 1.18 Output Voltage 1.17 1.16 Output Voltage VOUT (V) 150 100 Output Current 50mA VIN=3.5V tr=tf=0.5μs Output Current IOUT (mA) Output Voltage VOUT (V) VIN=2.2V tr=tf=0.5μs 150 100 50 Output Current 50mA 100mA 0 2.51 2.50 2.49 2.48 Output Voltage 2.47 Output Current IOUT (mA) RP100x121x 2.46 0 20 40 60 Time t (μs) 80 100 0 20 40 60 Time t (μs) 80 100 15 RP100x NO.EA-140-160425 RP100x121x 50 100mA 0 3.31 3.30 3.29 Output Voltage 3.26 0 20 40 60 Time t (μs) 80 1.25 1.20 1.15 1.10 1.05 1.00 100 Output Voltage 0 20 RP100x251x 0 2.6 2.5 Output Voltage Output Voltage VOUT (V) 50 Output Current IOUT (mA) Output Voltage VOUT (V) 100 Output Current 1mA 150mA 2.2 0 20 40 60 Time t (μs) 80 Output Current 1mA 150mA 3.35 3.30 3.25 3.20 3.15 3.10 3.05 100 0 20 80 100 Output Voltage Output Voltage VOUT (V) Output Current 1mA 150mA 200 150 100 50 0 VIN=3.5V tr=tf=5μs Output Current IOUT (mA) Output Voltage VOUT (V) 40 60 Time t (μs) RP100x251x VIN=2.2V tr=tf=5μs 200 150 100 Output Current 1mA 150mA 50 0 2.6 2.5 2.4 Output Voltage 2.3 2.2 0 16 200 150 100 50 0 Output Voltage RP100x121x 1.25 1.20 1.15 1.10 1.05 1.00 100 VIN=4.3V tr=tf=0.5μs 200 150 2.3 80 RP100x331x VIN=3.5V tr=tf=0.5μs 2.4 40 60 Time t (μs) 20 40 60 Time t (μs) Output Current IOUT (mA) 3.27 Output Current 1mA 150mA 200 150 100 50 0 80 100 0 20 40 60 Time t (μs) 80 100 Output Current IOUT (mA) 3.28 Output Voltage VOUT (V) 150 100 Output Current 50mA VIN=2.2V tr=tf=0.5μs Output Current IOUT (mA) Output Voltage VOUT (V) VIN=4.3V tr=tf=0.5μs Output Current IOUT (mA) RP100x331x RP100x NO.EA-140-160425 Output Voltage VOUT (V) VIN=4.3V tr=tf=5μs Output Current 1mA 150mA 3.35 3.30 3.25 3.20 3.15 3.10 200 150 100 50 0 Output Voltage 0 20 40 60 Time t (μs) 80 Output Current IOUT (mA) RP100x331x 100 12) Turn On Speed with CE pin (C1=1.0μF, C2=1.0μF, Topt=25°C) RP100x121x RP100x121x IOUT=0mA IOUT=30mA 0 2 1 Output Voltage 0 2 CE Input Voltage 1 0 2 1 Output Voltage CE Input Voltage VCE (V) 1 Output Voltage VOUT (V) 2 CE Input Voltage 3 CE Input Voltage VCE (V) Output Voltage VOUT (V) 3 0 0 20 40 60 Time t (μs) 80 100 0 20 40 60 Time t (μs) 80 100 RP100x121x IOUT=150mA 2 CE Input Voltage 1 0 2 1 Output Voltage CE Input Voltage VCE (V) Output Voltage VOUT (V) 3 0 0 20 40 60 Time t (μs) 80 100 17 RP100x NO.EA-140-160425 RP100x251x RP100x251x 4 4 2 0 3 2 Output Voltage 1 0 CE Input Voltage 0 3 2 Output Voltage 1 0 20 40 60 Time t (μs) 80 100 0 20 RP100x251x 40 60 4 4 2 0 3 Output Voltage 1 Output Voltage VOUT (V) 6 CE Input Voltage VCE (V) CE Input Voltage 2 0 3 2 Output Voltage 1 0 0 20 40 60 80 100 0 20 RP100x331x 40 60 80 RP100x331x IOUT=0mA IOUT=150mA CE Input Voltage 2 0 4 Output Voltage 0 Output Voltage VOUT (V) 4 6 CE Input Voltage VCE (V) 6 2 100 4 CE Input Voltage 2 0 4 2 Output Voltage 0 0 20 40 60 80 100 0 20 40 60 80 100 CE Input Voltage VCE (V) Output Voltage VOUT (V) CE Input Voltage IOUT=150mA 6 0 Output Voltage VOUT (V) 100 RP100x251x IOUT=30mA 2 80 CE Input Voltage VCE (V) 0 18 2 CE Input Voltage VCE (V) 6 Output Voltage VOUT (V) CE Input Voltage IOUT=10mA 6 CE Input Voltage VCE (V) Output Voltage VOUT (V) IOUT=0mA RP100x NO.EA-140-160425 13) Turn Off Speed with CE pin (D Version) (C1=1.0μF, C2=1.0μF, Topt=25°C) RP100x121D RP100x121D IOUT=0mA IOUT=10mA 1 0 2 Output Voltage 1 0 2 CE Input Voltage 1 0 2 Output Voltage 1 0 50 100 150 200 Time t (μs) 250 0 300 50 RP100x121D 100 150 200 Time t (μs) 250 300 RP100x121D IOUT=30mA IOUT=150mA CE Input Voltage 1 0 2 Output Voltage 1 Output Voltage VOUT (V) 2 3 CE Input Voltage VCE (V) 0 2 CE Input Voltage 1 0 2 Output Voltage 1 0 0 50 100 150 200 Time t (μs) 250 300 0 20 RP100x251D 40 60 Time t (μs) 80 100 RP100x251D IOUT=0mA IOUT=10mA 2 0 3 2 Output Voltage 1 0 Output Voltage VOUT (V) CE Input Voltage 4 CE Input Voltage VCE (V) 4 CE Input Voltage 2 0 3 2 Output Voltage 1 CE Input Voltage VCE (V) Output Voltage VOUT (V) 3 CE Input Voltage VCE (V) 0 Output Voltage VOUT (V) CE Input Voltage VCE (V) CE Input Voltage Output Voltage VOUT (V) 2 3 CE Input Voltage VCE (V) Output Voltage VOUT (V) 3 0 0 50 100 150 200 Time t (μs) 250 300 0 50 100 150 200 Time t (μs) 250 300 19 RP100x NO.EA-140-160425 RP100x251D RP100x251D IOUT=30mA IOUT=150mA 3 2 Output Voltage 1 0 2 CE Input Voltage 0 3 2 Output Voltage 1 0 50 100 150 200 Time t (μs) 250 300 0 50 RP100x331D 100 150 200 Time t (μs) 250 300 RP100x331D IOUT=0mA IOUT=10mA CE Input Voltage 2 0 4 Output Voltage 2 Output Voltage VOUT (V) 4 6 CE Input Voltage VCE (V) 0 4 CE Input Voltage 0 4 Output Voltage 2 0 0 50 100 150 200 Time t (μs) 250 300 0 50 RP100x331D 100 150 200 Time t (μs) 250 IOUT=150mA CE Input Voltage 2 0 4 Output Voltage 0 Output Voltage VOUT (V) 4 6 CE Input Voltage VCE (V) 6 2 300 RP100x331Dx IOUT=30mA Output Voltage VOUT (V) 2 4 CE Input Voltage 2 0 4 Output Voltage 2 0 0 50 100 150 200 Time t (μs) 250 300 0 20 40 60 Time t (μs) 80 100 CE Input Voltage VCE (V) Output Voltage VOUT (V) 6 CE Input Voltage VCE (V) 0 20 CE Input Voltage VCE (V) 0 Output Voltage VOUT (V) 2 CE Input Voltage 4 CE Input Voltage VCE (V) Output Voltage VOUT (V) 4 RP100x NO.EA-140-160425 14) Dropout Voltage vs Temperature (C1=1.0μF, C2=1.0μF) RP100x121x RP100x251x 400 Dropout Voltage VDIF (mV) Dropout Voltage VDIF (mV) 450 350 300 250 200 150 100 50mA 100mA 150mA 50 0 -40 -25 0 25 50 Temperature Topt (°C) 75 85 200 180 160 140 120 100 80 60 40 20 0 -40 -25 200 180 160 140 120 100 80 60 40 20 0 -40 -25 50mA 100mA 150mA 0 25 50 Temperature Topt (°C) 0 25 50 Temperature Topt (°C) 75 85 RP100x331x Dropout Voltage VDIF (mV) Dropout Voltage VDIF (mV) RP100x301x 50mA 100mA 150mA 75 85 200 180 160 140 120 100 80 60 40 20 0 -40 -25 50mA 100mA 150mA 0 25 50 Temperature Topt (°C) 75 85 15) Output Voltage vs. Input Voltage (C1=1.0μF, C2=1.0μF) Output Voltage VOUT (V) 3.2 3.0 2.8 2.6 IOUT=0mA IOUT=10mA IOUT=50mA IOUT=100mA IOUT=150mA 2.4 2.2 2.0 2.7 2.8 2.9 3.0 3.1 Input Voltage VIN (V) 3.2 21 RP100x NO.EA-140-160425 ESR vs. Output Current When using these ICs, consider the following points: The relations between IOUT (Output Current) and ESR of an output capacitor are shown below. The conditions when the white noise level is under 40μV (Avg.) are marked as the hatched area in the graph. Measurement conditions Frequency Band: 10Hz to 2MHz Temperature: −40°C to 85°C RP100x121x RP100x251x VIN=1.7V to 5.5V C1=C2=1.0μF VIN=2.5V to 5.5V C1=C2=1.0μF Topt=-40/25/85°C Topt=-40/25/85°C 100 ESR (Ω) ESR (Ω) 100 10 1 0.1 0.01 0 50 100 150 Output Current IOUT (mA) 200 RP100x331x VIN=3.3V to 5.5V C1=C2=1.0μF Topt=-40/25/85°C 100 ESR (Ω) 1 0.1 0.01 10 1 0.1 0.01 0 22 10 50 100 150 Output Current IOUT (mA) 200 0 50 100 150 Output Current IOUT (mA) 200 RP100x NO.EA-140-160425 PACKAGE INFORMATION Power Dissipation (DFN(PL)1612-4) This specification is at mounted on board. Power Dissipation (PD) depends on conditions of mounting on board. This specification is based on the measurement at the condition below: Measurement Conditions Standard Test Land Pattern Mounting on Board (Wind velocity=0m/s) Glass cloth epoxy plastic (Double sided) 40mm*40mm*1.6mm Top side: Approx. 50%, Back side: Approx. 50% Environment Board Material Board Dimensions Copper Ratio Through-holes φ 0.54mm * 24pcs Measurement Result (Ta=25°C) Standard Test Land Pattern 610mW (Tjmax=125°C) 762mW(Tjmax=150°C) θja = (125-25°C)/0.61W= 164°C/W θjc = 48°C/W Power Dissipation Thermal Resistance 40 762 700 600 610 500 400 40 Power Dissipation PD (mW) 800 300 200 100 0 0 25 50 75 85 100 125 150 Ambient Temperature (°C) Power Dissipation Measurent Board Pattern IC Mount Area Unit : mm The above graph shows the Power Dissipation of the package based on Tjmax=125°C and Tjmax=150°C. Operating the IC in the shaded area in the graph might have an influence it's lifetime. Operating time must be within the time limit described in the table below, in case of operating in the shaded area. Operating Time 13,000 hours Estimated years (Operating four hours/day) 9years 23 RP100x NO.EA-140-160425 Package Dimensions (DFN(PL)1612-4) 1.0±0.1 1.2 0.6 B A 3 4 X4 1.6 0.7±0.1 0.2±0.1 ※ 0.05 INDEX S 0.05 S 1 0.3±0.1 0.6MAX. 0.05MIN. 2 Bottom View (Unit : mm) ※) Tab is GND level. (They are connected to the reverse side of this IC.) The tab is better to be connected to the GND, but leaving it open is also acceptable. Mark Specifications (DFN(PL)1612-4) cd ef : Product Code …Refer to the marking list table : Lot No ………… Alphanumeric serial number. cd ef 24 0.05 M AB RP100x NO.EA-140-160425 RP100K Series marking list table RP100KxxxB Part Number RP100K121B RP100K131B RP100K151B RP100K181B RP100K181B5 RP100K191B RP100K201B RP100K251B RP100K261B RP100K271B RP100K281B RP100K281B5 RP100K291B RP100K301B RP100K311B RP100K331B RP100K211B RP100K121B5 RP100K241B RP100K221B cd 1A 1B 1C 1D 1E 1F 1G 1H 1J 1K 1L 1M 1N 1P 1Q 1R 1S 1T 1U 1V PKG: DFN(PL)1612-4 RP100KxxxD Vset Part Number 1.2V RP100K121D 1.3V RP100K131D 1.5V RP100K151D 1.8V RP100K181D 1.85V RP100K181D5 1.9V RP100K191D 2.0V RP100K201D 2.5V RP100K251D 2.6V RP100K261D 2.7V RP100K271D 2.8V RP100K281D 2.85V RP100K281D5 2.9V RP100K291D 3.0V RP100K301D 3.1V RP100K311D 3.3V RP100K331D 2.1V RP100K211D 1.25V RP100K121D5 2.4V RP100K241D 2.2V RP100K221D cd 2A 2B 2C 2D 2E 2F 2G 2H 2J 2K 2L 2M 2N 2P 2Q 2R 2S 2T 2U 2V Vset 1.2V 1.3V 1.5V 1.8V 1.85V 1.9V 2.0V 2.5V 2.6V 2.7V 2.8V 2.85V 2.9V 3.0V 3.1V 3.3V 2.1V 1.25V 2.4V 2.2V 25 RP100x NO.EA-140-160425 Power Dissipation (SOT-23-5) This specification is at mounted on board. Power Dissipation (PD) depends on conditions of mounting on board. This specification is based on the measurement at the condition below: (Power Dissipation (SOT-23-5) is substitution of SOT-23-6.) Measurement Conditions Standard Test Land Pattern Mounting on Board (Wind velocity=0m/s) Glass cloth epoxy plastic (Double sided) 40mm * 40mm * 1.6mm Top side: Approx. 50%, Back side: Approx. 50% Environment Board Material Board Dimensions Copper Ratio Through-holes φ 0.5mm * 44pcs Measurement Result (Ta=25°C) Power Dissipation Thermal Resistance Standard Test Land Pattern 420mW(Tjmax=125°C) 525mW(Tjmax=150°C) θja = (125-25°C)/0.42W= 238°C/W Free Air 250mW(Tjmax=125°C) 400°C/W 600 40 On Board 500 400 420 Free Air 300 250 40 Power Dissipation PD (mW) 525 200 100 0 0 25 50 75 85 100 125 150 Ambient Temperature (°C) Power Dissipation Measurement Board Pattern IC Mount Area (Unit: mm) The above graph shows the Power Dissipation of the package based on Tjmax=125°C and Tjmax=150°C. Operating the IC in the shaded area in the graph might have an influence it's lifetime. Operating time must be within the time limit described in the table below, in case of operating in the shaded area. Operating Time 9,000 hours 26 Estimated years (Operating four hours/day) 6years RP100x NO.EA-140-160425 Package Dimensions (SOT-23-5) 2.9±0.2 1.1±0.1 1.9±0.2 0.8±0.1 (0.95) 4 0~0.1 1 2 2.8±0.3 +0.2 1.6-0.1 5 0.2min. (0.95) 3 +0.1 0.15-0.05 0.4±0.1 Unit : mm Mark Specifications (SOT-23-5) cde fg : Product Code … Refer to the marking list table : Lot No …………. Alphanumeric serial number. 5 4 cdefg 1 2 3 27 RP100x NO.EA-140-160425 RP100N Series marking list table PKG: SOT-23-5 RP100NxxxB Part Number RP100N121B RP100N131B RP100N151B RP100N181B RP100N181B5 RP100N191B RP100N201B RP100N251B RP100N261B RP100N271B RP100N281B RP100N281B5 RP100N291B RP100N301B RP100N311B RP100N331B RP100N211B RP100N121B5 RP100N241B RP100N221B 28 cde 50A 50B 50C 50D 50E 50F 50G 50H 50J 50K 50L 50M 50N 50P 50Q 50R 50S 50T 50U 50V Vset 1.2V 1.3V 1.5V 1.8V 1.85V 1.9V 2.0V 2.5V 2.6V 2.7V 2.8V 2.85V 2.9V 3.0V 3.1V 3.3V 2.1V 1.25V 2.4V 2.2V RP100NxxxD Part Number RP100N121D RP100N131D RP100N151D RP100N181D RP100N181D5 RP100N191D RP100N201D RP100N251D RP100N261D RP100N271D RP100N281D RP100N281D5 RP100N291D RP100N301D RP100N311D RP100N331D RP100N211D RP100N121D5 RP100N241D RP100N221D cde 51A 51B 51C 51D 51E 51F 51G 51H 51J 51K 51L 51M 51N 51P 51Q 51R 51S 51T 51U 51V Vset 1.2V 1.3V 1.5V 1.8V 1.85V 1.9V 2.0V 2.5V 2.6V 2.7V 2.8V 2.85V 2.9V 3.0V 3.1V 3.3V 2.1V 1.25V 2.4V 2.2V 1. The products and the product specifications described in this document are subject to change or discontinuation of production without notice for reasons such as improvement. Therefore, before deciding to use the products, please refer to our sales representatives for the latest information thereon. 2. The materials in this document may not be copied or otherwise reproduced in whole or in part without prior written consent of our company. 3. Please be sure to take any necessary formalities under relevant laws or regulations before exporting or otherwise taking out of your country the products or the technical information described herein. 4. The technical information described in this document shows typical characteristics of and example application circuits for the products. The release of such information is not to be construed as a warranty of or a grant of license under our company's or any third party's intellectual property rights or any other rights. 5. The products listed in this document are intended and designed for use as general electronic components in standard applications (office equipment, telecommunication equipment, measuring instruments, consumer electronic products, amusement equipment etc.). Those customers intending to use a product in an application requiring extreme quality and reliability, for example, in a highly specific application where the failure or misoperation of the product could result in human injury or death (aircraft, spacevehicle, nuclear reactor control system, traffic control system, automotive and transportation equipment, combustion equipment, safety devices, life support system etc.) should first contact us. 6. We are making our continuous effort to improve the quality and reliability of our products, but semiconductor products are likely to fail with certain probability. In order to prevent any injury to persons or damages to property resulting from such failure, customers should be careful enough to incorporate safety measures in their design, such as redundancy feature, fire containment feature and fail-safe feature. We do not assume any liability or responsibility for any loss or damage arising from misuse or inappropriate use of the products. 7. Anti-radiation design is not implemented in the products described in this document. 8. The X-ray exposure can influence functions and characteristics of the products. Confirm the product functions and characteristics in the evaluation stage. 9. WLCSP products should be used in light shielded environments. The light exposure can influence functions and characteristics of the products under operation or storage. 10. There can be variation in the marking when different AOI (Automated Optical Inspection) equipment is used. In the case of recognizing the marking characteristic with AOI, please contact our sales or our distributor before attempting to use AOI. 11. Please contact our sales representatives should you have any questions or comments concerning the products or the technical information. Official website https://www.nisshinbo-microdevices.co.jp/en/ Purchase information https://www.nisshinbo-microdevices.co.jp/en/buy/
RP100N331D-TR-FE 价格&库存
很抱歉,暂时无法提供与“RP100N331D-TR-FE”相匹配的价格&库存,您可以联系我们找货
