RN5RL33AA-TR-FE
RN5RL33AA-TR-FE
    NISSHINBO(日清纺)
    SC-74A
    PMIC - 稳压器 - 线性 正 固定 1 输出 50mA SOT-23-5
RN5RL33AA-TR-FE 数据手册
Rx5RL SERIES VOLTAGE REGULATOR NO. EA-022-120404 OUTLINE The Rx5RL Series are CMOS-based voltage regulator ICs with high accuracy output voltage and ultra-low quiescent current. Each of these ICs consists of a voltage reference unit, an error amplifier, a driver transistor, and resistors for setting output voltage. The output voltage is fixed with high accuracy. Three types of packages, TO-92 (Discontinued), SOT-89 (Mini-power Mold), SOT-23-5 (Mini-mold), are available. FEATURES • • • • • • • • Supply Current ............................................................. Typ. 1.1μA (VOUT=3.0V, VIN=5.0V) Dropout Voltage ........................................................... Typ. 0.04V (IOUT=1mA, VOUT=2.8V) Input Voltage Range .................................................... Max. 10.0V Output Voltage Range.................................................. 2.0V to 6.0V (0.1V steps) (For other voltages, please refer to MARK INFORMATIONS.) Output Voltage Accuracy..............................................±2.5% Temperature-Drift Coefficient of Output Voltage .......... Typ. ± 100ppm/°C Line Regulation ............................................................ Typ. 0.05%/V Packages ..................................................................... SOT-23-5 (Mini-mold), SOT-89 (Mini-power Mold), TO-92 (Discontinued) APPLICATIONS • Power source for battery-powered equipment • Power source for cameras, video instruments such as camcorders, VCRs, and hand- held communication equipment • Precision voltage references 1 Rx5RL BLOCK DIAGRAMS Rx5RL VIN VOUT 2 3 + – Vref 1 GND SELECTION GUIDE The output voltage and package for the ICs can be selected at the user’s request. Product Name Package Quantity per Reel Pb Free Halogen Free RN5RLxxAA-TR-FE SOT-23-5 3,000 pcs Yes Yes RH5RLxxAA-T1-FE SOT-89 1,000 pcs Yes Yes RE5RLxxAA-TR-F TO-92 (Discontinued) 2,500 pcs Yes No xx : The output voltage can be designated in the range from 2.0V (20) to 6.0V (60) in 0.1V steps. (For other voltages, please refer to MARK INFORMATIONS.) 2 Rx5RL PIN CONFIGURATION z SOT-23-5 5 z SOT-89 z TO-92 4 (mark side) (mark side) 1 1 2 2 (mark side) 3 3 1 2 3 PIN DESCRIPTION • • • SOT-23-5 Pin No Symbol Pin Description 1 GND 2 VIN 3 VOUT Output Pin 4 NC No Connection 5 NC No Connection Ground Pin Input Pin SOT-89 Pin No Symbol 1 GND 2 VIN 3 VOUT Pin Description Ground Pin Input Pin Output Pin TO-92 (Discontinued) Pin No Symbol 1 GND 2 VIN 3 VOUT Pin Description Ground Pin Input Pin Output Pin 3 Rx5RL ABSOLUTE MAXIMUM RATINGS Symbol VIN Item Input Voltage Rating Unit 12 V VOUT Output Voltage −0.3 to VIN+0.3 V IOUT Output Current 150 mA ∗ Power Dissipation ∗ PD Power Dissipation ∗ Power Dissipation (SOT-23-5) 420 (SOT-89) 900 (TO-92) (Discontinued) 300 mW Topt Operating Temperature Range −40 to 85 °C Tstg Storage Temperature Range −55 to 125 °C Tsolder Lead Temperature (Soldering) 260°C,10s ∗) For Power Dissipation, please refer to PACKAGE INFORMATION. ABSOLUTE MAXIMUM RATINGS Electronic and mechanical stress momentarily exceeded absolute maximum ratings may cause the permanent damages and may degrade the life time and safety for both device and system using the device in the field. The functional operation at or over these absolute maximum ratings is not assured. RECOMMENDED OPERATING CONDITIONS (ELECTRICAL CHARACTERISTICS) All of electronic equipment should be designed that the mounted semiconductor devices operate within the recommended operating conditions. The semiconductor devices cannot operate normally over the recommended operating conditions, even if when they are used over such conditions by momentary electronic noise or surge. And the semiconductor devices may receive serious damage when they continue to operate over the recommended operating conditions. 4 Rx5RL ELECTRICAL CHARACTERISTICS • Rx5RL20A Symbol Topt=25˚C Item Conditions VIN=4.0V VOUT Output Voltage IOUT Output Current VIN=4.0V ∆VOUT Load Regulation VIN=4.0V ∆IOUT VDIF ISS ∆VOUT ∆VIN VIN ∆VOUT ∆Topt 10µA≤IOUT≤10mA Min. Typ. Max. Unit 1.950 2.000 2.050 V 25 35 1mA≤IOUT≤35mA mA 30 45 mV Dropout Voltage IOUT=1mA 60 90 mV Quiescent Current VIN=4.0V 1.0 3.0 µA 0.05 0.20 %/V 10 V Line Regulation IOUT=1mA VOUT+0.5V≤VIN≤10V Input Voltage Output Voltage Temperature Coefficient IOUT=10mA ±100 –40˚C≤Topt≤85˚C ppm/˚C • Rx5RL30A Symbol Topt=25˚C Item VOUT Output Voltage IOUT Output Current ∆VOUT ∆IOUT Load Regulation VDIF Dropout Voltage Quiescent Current ISS ∆VOUT ∆VIN VIN ∆VOUT ∆ Topt Line Regulation Conditions VIN=5.0V 10µA≤IOUT≤10mA VIN=5.0V VIN=5.0V Min. Typ. Max. Unit 2.925 3.000 3.075 V 35 50 40 60 mV IOUT=1mA 40 60 mV VIN=5.0V 1.1 3.3 µA IOUT=1mA VOUT+0.5V≤VIN≤10V 0.05 0.20 %/V 10 V 1mA≤IOUT≤50mA Input Voltage Output Voltage Temperature Coefficient mA IOUT=10mA –40˚C≤Topt≤85˚C ±100 ppm/˚C 5 Rx5RL • Rx5RL40A Symbol Topt=25˚C Item VOUT Output Voltage IOUT Output Current ∆VOUT Load Regulation ∆IOUT VDIF ISS ∆VOUT ∆VIN VIN ∆VOUT ∆Topt Conditions VIN=6.0V 10µA≤IOUT≤10mA VIN=6.0V Min. Typ. Max. Unit 3.900 4.000 4.100 V 45 65 VIN=6.0V 1mA≤IOUT≤65mA mA 50 75 mV Dropout Voltage IOUT=1mA 25 38 mV Quiescent Current VIN=6.0V 1.2 3.6 µA 0.05 0.20 %/V 10 V Line Regulation IOUT=1mA VOUT+0.5V≤VIN≤10V Input Voltage Output Voltage Temperature Coefficient IOUT=10mA ±100 –40˚C≤Topt≤85˚C ppm/˚C • Rx5RL50A Symbol Item VOUT Output Voltage IOUT Output Current ∆VOUT Load Regulation ∆IOUT VDIF ISS ∆VOUT ∆VIN VIN ∆VOUT ∆Topt 6 Topt=25˚C Conditions VIN=7.0V 10µA≤IOUT≤10mA VIN=7.0V VIN=7.0V 1mA≤IOUT≤80mA Min. Typ. Max. Unit 4.875 5.000 5.125 V 55 80 mA 60 90 mV Dropout Voltage IOUT=1mA 25 38 mV Quiescent Current VIN=7.0V 1.3 3.9 µA 0.05 0.20 %/V 10 V Line Regulation IOUT=1mA VOUT+0.5V≤VIN≤10V Input Voltage Output Voltage Temperature Coefficient IOUT=10mA –40˚C≤Topt≤85˚C ±100 ppm/˚C Rx5RL • Rx5RL60A Topt=25˚C Symbol Item VOUT Output Voltage IOUT Output Current ∆VOUT Load Regulation ∆IOUT VDIF ISS ∆VOUT ∆VIN VIN ∆VOUT ∆Topt Conditions VIN=8.0V 10µA≤IOUT≤10mA VIN=8.0V VIN=8.0V 1mA≤IOUT≤80mA Min. Typ. Max. Unit 5.850 6.000 6.150 V 55 80 mA 60 90 mV Dropout Voltage IOUT=1mA 25 38 mV Quiescent Current VIN=8.0V 1.3 3.9 µA 0.05 0.20 %/V 10 V Line Regulation IOUT=1mA VOUT+0.5V≤VIN≤10V Input Voltage Output Voltage Temperature Coefficient IOUT=10mA –40˚C≤TOPt≤85˚C ±100 ppm/˚C 7 Rx5RL ELECTRICAL CHARACTEISTICS BY OUTPUT VOLTAGE Part Number Conditions Rx5RL20A Rx5RL21A Rx5RL22A Rx5RL23A Rx5RL24A Rx5RL25A Rx5RL26A Rx5RL27A Rx5RL28A Rx5RL29A Rx5RL30A Rx5RL31A Rx5RL32A Rx5RL33A Rx5RL34A Rx5RL35A Rx5RL36A Rx5RL37A Rx5RL38A Rx5RL39A Rx5RL40A Rx5RL41A Rx5RL42A Rx5RL43A Rx5RL44A Rx5RL45A Rx5RL46A Rx5RL47A Rx5RL48A Rx5RL49A Rx5RL50A Rx5RL51A Rx5RL52A Rx5RL53A Rx5RL54A Rx5RL55A Rx5RL56A Rx5RL57A Rx5RL58A Rx5RL59A Rx5RL60A 8 Output Voltage OutputCurrent Load Regulation Dropout Voltage VOUT(V) IOUT(mA) ∆VOUT(mV) VDIF (mV) Min. 1.950 2.048 2.145 2.243 2.340 2.438 2.535 2.633 2.730 2.828 2.925 3.023 3.120 3.218 3.315 3.413 VIN– 3.510 VOUT 3.608 =2.0V 3.705 3.803 3.900 10µA≤ 3.998 IOUT 4.095 ≤10mA 4.193 4.290 4.388 4.485 4.583 4.680 4.778 4.875 4.973 5.070 5.168 5.265 5.363 5.460 5.558 5.655 5.753 5.850 Typ. Max. 2.000 2.100 2.200 2.300 2.400 2.500 2.600 2.700 2.800 2.900 3.000 3.100 3.200 3.300 3.400 3.500 3.600 3.700 3.800 3.900 4.000 4.100 4.200 4.300 4.400 4.500 4.600 4.700 4.800 4.900 5.000 5.100 5.200 5.300 5.400 5.500 5.600 5.700 5.800 5.900 6.000 2.050 2.152 2.255 2.357 2.460 2.562 2.665 2.767 2.870 2.972 3.075 3.177 3.280 3.382 3.485 3.587 3.690 3.792 3.895 3.997 4.100 4.202 4.305 4.407 4.510 4.612 4.715 4.817 4.920 5.022 5.125 5.227 5.330 5.432 5.535 5.637 5.740 5.842 5.945 6.047 6.150 Conditions Min. Typ. Conditions Typ. Max. Conditions VIN– VOUT Typ. Max. 60 90 50 75 40 60 35 53 30 45 25 38 =2.0V 25 35 30 45 1mA≤ IOUT ≤35mA VIN– VOUT =2.0V 35 50 40 60 1mA≤ IOUT ≤50mA VIN– VOUT IOUT =2.0V =1mA VIN– VOUT 45 65 =2.0V 50 70 1mA≤ IOUT ≤65mA VIN– VOUT =2.0V 55 80 60 1mA≤ IOUT ≤80mA 90 Rx5RL Topt=25˚C Quiescent Current Line Regulation Iss(µA) ∆VOUT/∆VIN(%/V) Conditions Typ. Max. 1.0 3.0 1.1 3.3 Conditions Typ. Max. Input Voltage Output Voltage Tempco. VIN(V) Max. ∆VOUT/∆T(ppm/˚C) Conditions Typ. IOUT =1mA IOUT VIN =10mA 0.05 VOUT 0.2 10 ±100 =2.0V VOUT+ 1.2 3.6 1.3 3.9 –40˚C≤ 0.5V≤ Topt VIN≤ 85˚C ≤10V 9 Rx5RL OPERATION VOUT VIN Output voltage, VOUT divided at the node between Registers R1 and R2 is compared with the reference volt- Error Amplifier age by the error amplifier, so that a constant voltage is out- – R1 put. + Vref R2 GND GND FIG. 1 Brock Diagram TEST CIRCUITS VIN VIN CI 1µF VOUT Rx5RL SERIES + GND ISS IOUT VOUT + Co 1µF CI 1µF P.G Rx5RL SERIES VOUT GND VOUT + Co 0.1µF FIG. 4 Line Transient Response Test Circuit 10 + Rx5RL SERIES GND FIG. 3 Quiescent Current Test Circuit FIG. 2 Test Circuit VIN VIN VIN Ro VOUT Rx5RL TYPICAL CHARACTERISTICS 1) Output Voltage vs. Output Current Rx5RL40A Rx5RL30A VIN=5.0V Output Voltage VOUT(V) Output Voltage VOUT(V) 3.1 3.0 Topt=−40˚C 2.9 25˚C 85˚C 2.8 4.1 VIN=6.0V 4.0 Topt=−40˚C 3.9 85˚C 25˚C 3.8 3.7 2.7 0 20 0 2 0 4 0 6 0 8 0 100 120 140 160 180 40 60 80 100 120 140 Output Current IOUT(mA) Rx5RL50A Output Current IOUT(mA) VIN=7.0V 5.1 Output Voltage VOUT(V) Topt=−40˚C 5.0 4.9 85˚C 25˚C 4.8 4.7 0 50 100 150 Output Current IOUT(mA) 200 2) Output Voltage vs. Input Voltage Rx5RL30A 3.2 Rx5RL30A Topt=25˚C 3.05 Topt=25˚C IOUT=1mA 2.8 Output Voltage VOUT(V) Output Voltage VOUT(V) 3.04 3.0 IOUT=1mA 2.6 10mA 2.4 3.02 3.01 3.00 2.99 2.98 2.97 2.96 5mA 2.2 3.03 2.95 2.5 3.0 Input Voltage VIN(V) 3.5 3 4 5 6 7 8 Input Voltage VIN(V) 9 10 11 Rx5RL Rx5RL40A Rx5RL40A Topt=25˚C 4.2 4.05 Topt=25˚C IOUT=1mA 4.0 Output Voltage VOUT(V) Output Voltage VOUT(V) 4.04 IOUT=1mA 3.8 5mA 3.6 10mA 3.4 4.03 4.02 4.01 4.00 3.99 3.98 3.97 3.96 3.2 3.5 4.0 Input Voltage VIN(V) Rx5RL50A 4 5 6 7 8 Input Voltage VIN(V) Rx5RL50A Topt=25˚C 5.05 9 10 Topt=25˚C IOUT=1mA 5.04 5.0 Output Voltage VOUT(V) Output Voltage VOUT(V) 5.2 3.95 4.5 IOUT=1mA 4.8 5mA 10mA 4.6 4.4 5.03 5.02 5.01 5.00 4.99 4.98 4.97 4.96 4.2 4.5 5.0 Input Voltage VIN(V) 4.95 5.5 5 6 10 9 7 8 Input Voltage VIN(V) 3) Dropout Voltage vs. Output Curret Rx5RL30A Rx5RL40A 2.0 1.8 1.6 1.4 85˚C 1.2 Dropout Voltage VDIF(V) Dropout Voltage VDIF(V) 2.0 1.8 25˚C 1.0 0.8 0.6 0.4 Topt=−40˚C 0.2 12 10 20 30 40 Output Current IOUT(mA) 1.2 25˚C 1.0 85˚C 0.8 0.6 0.4 Topt=− 40˚C 0.2 0.0 0 1.6 1.4 50 0.0 0 10 20 30 40 Output Current IOUT(mA) 50 Rx5RL Rx5RL50A Dropout Voltage VDIF(V) 2.0 1.8 1.6 1.4 1.2 85˚C 1.0 0.8 25˚C 0.6 0.4 Topt=–40˚C 0.2 0.0 0 10 20 30 40 Output Current IOUT(mA) 50 4) Output Voltage vs.Temperature Rx5RL30A VIN=5.0V 3.03 3.01 2.99 2.97 2.95 –50 –30 –10 10 30 50 70 Temperature Topt(˚C) 5.10 4.05 Output Voltage VOUT(V) Output Voltage VOUT(V) 3.05 IOUT=10mA 90 IN=6.0V Rx5RL40A IVOUT =10mA 4.03 4.01 3.99 3.97 3.95 –50 –30 –10 10 30 50 70 Temperature Topt(˚C) 90 IN=7.0V Rx5RL50A IVOUT =10mA 5.08 Output Voltage VOUT(V) 5.06 5.04 5.02 5.00 4.98 4.96 4.94 4.92 4.90 –50 –30 –10 10 30 50 70 Temperature Topt(˚C) 90 13 Rx5RL 5) Quiescent Current vs. Input Voltage Rx5RL30C 1.5 1.4 1.4 1.3 1.3 Quiescent Current Iss(µA) Quiescent Current Iss(µA) Rx5RL40A Topt=25˚C 1.5 1.2 1.1 1.0 0.9 0.8 0.7 0.6 0.5 Topt=25˚C 1.2 1.1 1.0 0.9 0.8 0.7 0.6 0.5 3 4 5 6 7 8 Input Voltage VIN(V) Rx5RL50A 2.0 9 10 5 6 7 8 Input Voltage VIN(V) 9 10 Topt=25˚C Quiescent Current Iss(µA) 1.9 1.8 1.7 1.6 1.5 1.4 1.3 1.2 1.1 1.0 4 5 6 7 8 Input Voltage VIN(V) 9 10 2.0 1.4 1.9 1.3 1.8 1.2 1.1 1.0 0.9 0.8 0.7 0.6 0.5 –40 –20 0 20 40 60 Temperature Topt(˚C) 14 Rx5RL40A 1.5 Quiescent Current Iss(µA) Quiescent Current Iss(µA) 6) Quiescent Current vs. Temperature Rx5RL30A VIN=5.0V 80 100 VIN=6.0V 1.7 1.6 1.5 1.4 1.3 1.2 1.1 1.0 20 40 60 80 100 –40 –20 0 Temperature Topt(˚C) Rx5RL Rx5RL50A 7) Dropout Voltage vs. Set Output Voltage VIN=7.0V 2.5 0.7 0.6 2.3 Dropout Voltage VDIF(V) Quiescent Current Iss(µA) 2.4 2.2 2.1 2.0 1.9 1.8 1.7 1.6 1.5 –40 –20 0 20 40 60 Temperature Topt(˚C) 0.5 0.4 0.3 IOUT=10mA 0.2 5mA 0.1 1mA 0.0 80 100 0 1 2 3 4 5 Set Output Voltage Vreg(V) 6 8) Line Transient Response (1) IOUT=1mA 8.0 Input Voltage/Output Voltage(V) Input Voltage 7.5 7.0 6.5 6.0 5.5 Output Voltage 5.0 4.5 4.0 0 1 2 Time t(ms) 3 4 9) Line Transient Response (2) IOUT=10mA Input Voltage/Output Voltage(V) 8.0 Input Voltage 7.5 7.0 6.5 6.0 5.5 Output Voltage 5.0 4.5 4.0 0 1 2 Time t(ms) 3 4 15 Rx5RL TYPICAL APPLICATION In Rx5RL Series, a constant voltage can be obtained without using Capacitors C1 and C2. However, when the VIN VIN C1 + Rx5RL SERIES VOUT wire connected to Vin is long, use Capacitor C1. Output VOUT + noise can be reduced by using Capacitor C2. C2 GND Insert Capacitors C1 and C2 with the capacitance of 0.1µF to 2.0µF between Input/Output Pins and GND Pin GND GND with minimum wiring. APPLICATION CIRCUITS • VOLTAGE BOOST CIRCUIT The output voltage can be obtained by the following formula : VIN VIN Rx5RL SERIES VOUT VOUT Since the quiescent current of Rx5RE Series is so + GND C2 R1 small that the resistances of R1 and R2 can be set as ISS + 1 VOUT=Vreg* · (1+R2/R1) + ISS R · 2 large as several hundreds kΩ and therefore the sup- C1 ply current of “Voltage Boost Circuit” itself can be R2 reduced. Furthermore, since Rx5RL Series are operated by a constant voltage, the supply current of “Voltage Boost Circuit” is not substantially affected by the input voltage. *1) Vreg : Set Output Voltage of Rx5RL Series. • DUAL POWER SUPPLY CIRCUIT As shown in the circuit diagram, a dual power supIC1 ply circuit can be constructed by using two Rx5RL VOUT VIN VIN VOUT1 5V Rx5RL20A C1 + This circuit diagram shows a dual power supply D ISS GND circuit with an output of 3V and an output of 5V. IC2 VOUT VIN VOUT2 3V Rx5RL30A C2 + C3 + R 16 When the minimum output current of IC2 is larger than ISS of IC1, Resistor R is unnecessary. Diode D is a protection diode for the case where VOUT2 becomes GND GND Series. GND larger than VOUT1. Rx5RL • CURRENT BOOST CIRCUIT Output current of 60mA or more can be obtained by Tr.1 the current boost circuit constructed as shown in this cirVIN VIN C1 cuit diagram. VOUT Rx5RL SERIES VOUT + + GND C2 GND GND • CURRENT BOOST CIRCUIT WITH OVERCURRENT LIMIT CIRCUIT A circuit for protecting Tr.1 from the destruction R2 Tr.1 caused by output short-circuit or overcurrent is shown in Vbe2 this circuit diagram. Tr.2 IOUT VIN VIN C1 + R1 Rx5RL SERIES VOUT + VOUT C2 GND When the voltage reduction caused by the current ( aa IOUT) which flows through R2 reaches Vbe2 of Tr.2 by additionally providing the current boost circuit with Tr.2 and R2, Tr.2 is turned on and the base current of Tr.1 is GND GND increased, so that the output current is limited. Current limit of overcurrent limit circuit is obtained as follows : IOUT Vbe2/R2 • CURRENT SOURCE A current source with the structure as shown in this IOUT VIN VIN C1 + Rx5RL SERIES GND VOUT R ISS circuit diagram can be used. Output Current IOUT is obtained as follows : 1 IOUT= Vreg* /R + ISS Output current, IOUT should not exceed its allowable current. *1) Vreg : Set output voltage of Rx5RL Series. 17 1. The products and the product specifications described in this document are subject to change or discontinuation of production without notice for reasons such as improvement. Therefore, before deciding to use the products, please refer to our sales representatives for the latest information thereon. 2. The materials in this document may not be copied or otherwise reproduced in whole or in part without prior written consent of our company. 3. Please be sure to take any necessary formalities under relevant laws or regulations before exporting or otherwise taking out of your country the products or the technical information described herein. 4. The technical information described in this document shows typical characteristics of and example application circuits for the products. The release of such information is not to be construed as a warranty of or a grant of license under our company's or any third party's intellectual property rights or any other rights. 5. The products listed in this document are intended and designed for use as general electronic components in standard applications (office equipment, telecommunication equipment, measuring instruments, consumer electronic products, amusement equipment etc.). Those customers intending to use a product in an application requiring extreme quality and reliability, for example, in a highly specific application where the failure or misoperation of the product could result in human injury or death (aircraft, spacevehicle, nuclear reactor control system, traffic control system, automotive and transportation equipment, combustion equipment, safety devices, life support system etc.) should first contact us. 6. We are making our continuous effort to improve the quality and reliability of our products, but semiconductor products are likely to fail with certain probability. In order to prevent any injury to persons or damages to property resulting from such failure, customers should be careful enough to incorporate safety measures in their design, such as redundancy feature, fire containment feature and fail-safe feature. We do not assume any liability or responsibility for any loss or damage arising from misuse or inappropriate use of the products. 7. Anti-radiation design is not implemented in the products described in this document. 8. The X-ray exposure can influence functions and characteristics of the products. Confirm the product functions and characteristics in the evaluation stage. 9. WLCSP products should be used in light shielded environments. The light exposure can influence functions and characteristics of the products under operation or storage. 10. There can be variation in the marking when different AOI (Automated Optical Inspection) equipment is used. In the case of recognizing the marking characteristic with AOI, please contact our sales or our distributor before attempting to use AOI. 11. Please contact our sales representatives should you have any questions or comments concerning the products or the technical information. Official website https://www.nisshinbo-microdevices.co.jp/en/ Purchase information https://www.nisshinbo-microdevices.co.jp/en/buy/
RN5RL33AA-TR-FE 价格&库存
很抱歉,暂时无法提供与“RN5RL33AA-TR-FE”相匹配的价格&库存,您可以联系我们找货
RN5RL33AA-TR-FE
    • 12000+3.1043012000+0.37370
    库存:3000
