RP101N181D-TR-FE
RP101N181D-TR-FE
    NISSHINBO(日清纺)
    SC-74A
    PMIC - 稳压器 - 线性 正 固定 1 输出 300mA SOT-23-5
RP101N181D-TR-FE 数据手册
RP101x SERIES 0.6% ACCURACY LOW NOISE 300mA LDO REGULATOR NO.EA-167-160425 OUTLINE The RP101x Series are CMOS-based voltage regulator ICs with high output voltage accuracy, extremely low supply current, low ON-resistance, and high ripple rejection. Each of these ICs consists of a voltage reference unit, an error amplifier, resistor-net for voltage setting, a current limit circuit, and a chip enable circuit. These ICs perform with low dropout voltage and a chip enable function. The line transient response and load transient response of the RP101x Series are excellent, thus these ICs are very suitable for the power supply for hand-held communication equipment. The output voltage of these ICs is fixed with high accuracy. Since the packages for these ICs are SOT-23-5 and DFN(PL)1612-4 (t=0.6mm type) or DFN(PL)1612-4B (t=0.4mm type), therefore high density mounting of the ICs on boards is possible. FEATURES           Supply Current ............................................................. Typ. 18A Standby Current ........................................................... Typ. 0.1A Dropout Voltage............................................................ Typ. 0.13V (IOUT150mA, VOUT2.8V) Ripple Rejection ........................................................... Typ. 75dB (f1kHz) Temperature-Drift Coefficient of Output Voltage .......... Typ. 30ppm/C Line Regulation ............................................................ Typ. 0.02%/V Output Voltage Accuracy ..............................................0.6% Packages...................................................................... DFN(PL)1612-4, DFN(PL)1612-4B, SOT-23-5 Input Voltage Range ..................................................... 1.7V to 5.25V Output Voltage Range .................................................. 1.2V to 3.3V (0.1V steps) (For other voltages, please refer to MARK INFORMATIONS.)  Built-in Fold Back Protection Circuit ............................. Typ. 40mA (Current at short mode)  Ceramic capacitors are recommended to be used with this IC .... 1.0F or more APPLICATIONS     Power source for portable communication equipment. Power source for electrical appliances such as cameras, VCRs and camcorders. Power source for battery-powered equipment. Power source for home appliances. 1 RP101x NO.EA-167-160425 BLOCK DIAGRAMS RP101xxxxB RP101xxxxD VDD VOUT VDD VOUT Vref Vref Current Limit Current Limit CE GND CE GND SELECTION GUIDE The output voltage, auto discharge function, package, and the taping type, etc. for the ICs can be selected at the user’s request. Product Name Package Quantity per Reel Pb Free Halogen Free RP101Kxx1-TR DFN(PL)1612-4(t=0.6mm) 5,000 pcs Yes Yes RP101Kxx2-TR DFN(PL)1612-4B (t=0.4mm) 5,000 pcs Yes Yes 3,000 pcs Yes Yes RP101Nxx1-TR-FE SOT-23-5 xx : The output voltage can be designated in the range from 1.2V(12) to 3.3V(33) in 0.1V steps. (For other voltages, please refer to MARK INFORMATIONS.)  : CE pin polarity and auto discharge function at off state are options as follows. (B) "H" active, without auto discharge function at off state (D) "H" active, with auto discharge function at off state 2 RP101x NO.EA-167-160425 PIN CONFIGURATIONS SOT-23-5 • DFN(PL)1612-4, DFN(PL)1612-4B Bottom View Top View 4 3 3 5 4 4 (mark side) 1 2 2 1 1 2 3 PIN DESCRIPTIONS • DFN(PL)1612-4, DFN(PL)1612-4B Pin No Symbol Pin Description 1 VOUT Output Pin 2 GND Ground Pin 3 CE Chip Enable Pin ("H" Active) 4 VDD Input Pin  ) Tab is GND level. (They are connected to the reverse side of this IC.) The tab is better to be connected to the GND, but leaving it open is also acceptable.  SOT-23-5 Pin No Symbol Pin Description 1 VDD 2 GND 3 CE Chip Enable Pin ("H" Active) 4 NC No Connection 5 VOUT Output Pin Input Pin Ground Pin 3 RP101x NO.EA-167-160425 ABSOLUTE MAXIMUM RATINGS Symbol Item Rating Unit VIN Input Voltage 6.0 V VCE Input Voltage (CE Pin) 6.0 V VOUT Output Voltage 0.3 to VIN0.3 V IOUT Output Current 310 mA Power Dissipation (DFN(PL)1612-4) ∗ PD Power Dissipation (DFN(PL)1612-4B) 610 ∗ 580 mW Power Dissipation (SOT-23-5)  420 Topt Operating Temperature Range 40 to 85 C Tstg Storage Temperature Range 55 to 125 C ) For Power Dissipation, please refer to PACKAGE INFORMATION. ABSOLUTE MAXIMUM RATINGS Electronic and mechanical stress momentarily exceeded absolute maximum ratings may cause the permanent damages and may degrade the life time and safety for both device and system using the device in the field. The functional operation at or over these absolute maximum ratings is not assured. 4 RP101x NO.EA-167-160425 ELECTRICAL CHARACTERISTICS  RP101xxxxB/D VINSet VOUT1V, IOUT1mA, CINCOUT1F, unless otherwise noted. Topt25C Symbol Item VOUT Output Voltage IOUT Output Current VOUT/ IOUT VDIF ISS Istandby Load Regulation Dropout Voltage Min. Typ. Max. Unit VOUT > 2.0V 0.994 1.006 V VOUT  2.0V 12 12 mV 300 1mA  IOUT  150mA IOUT150mA mA 20 40 1.2V  VOUT < 1.5V 0.40 0.50 1.5V  VOUT < 1.7V 0.24 0.38 1.7V  VOUT < 2.0V 0.21 0.34 2.0V  VOUT < 2.5V 0.17 0.30 2.5V  VOUT < 2.8V 0.14 0.25 2.8V  VOUT  3.3V 0.13 0.23 mV V Supply Current IOUT0mA 18 25 A Standby Current VCE0V 0.1 2.0 A Set VOUT0.5V  VIN  5.0V 0.02 0.10 %/V VOUT/VIN Line Regulation RR Ripple Rejection VIN Input Voltage*1 VOUT/ Topt Conditions f1kHz, Ripple 0.2Vp-p VINSet VOUT1V, IOUT30mA (In case that VOUT  2.0V, VIN3.0V) 75 1.7 dB 5.25 V Output Voltage Temperature Coefficient 40C  Topt  85C 30 ppm /C ISC Short Current Limit VOUT0V 40 mA IPD CE Pull-down Current 0.3 A VCEH CE Input Voltage "H" VCEL CE Input Voltage "L" en RLOW 1.1 V 0.3 V Output Noise BW10Hz to 100kHz IOUT30mA 30 Vrms Low Output Nch Tr. ON Resistance (of D version) VIN4.0V, VCE0V 30  ) The maximum Input Voltage of the ELECTRICAL CHARACTERISTICS is 5.25V. In case of exceeding this specification, the IC must be operated on condition that the Input Voltage is up to 5.5V and the total operating time is within 500hrs. RECOMMENDED OPERATING CONDITIONS (ELECTRICAL CHARACTERISTICS) All of electronic equipment should be designed that the mounted semiconductor devices operate within the recommended operating conditions. The semiconductor devices cannot operate normally over the recommended operating conditions, even if when they are used over such conditions by momentary electronic noise or surge. And the semiconductor devices may receive serious damage when they continue to operate over the recommended operating conditions. 5 RP101x NO.EA-167-160425 TYPICAL APPLICATION VDD C1 VOUT RP101x Series CE VOUT C2 GND (External Components) C2 1.0F MURATA: GRM155B31A105KE15 TECHNICAL NOTES When using these ICs, consider the following points: Phase Compensation In these ICs, phase compensation is made for securing stable operation even if the load current is varied. For this purpose, use a capacitor C2 with 1.0F or more capacity. Ceramic capacitors have different temperature characteristics and bias characteristics depending on their dimensions and manufacturers. If the setting voltage is 2.5V or more and the capacitor’s dimensions for VOUT equal to 1.0mm by 0.5mm or smaller than that, the capacitance value might be extremely low. As a result, the capacitance might be much less than expected. In such cases, the operation might be unstable at low temperature. (20C or less) In that case, use a larger capacity, or a large dimensions’ capacitor. (For example 1.6mm by 0.8mm) If a tantalum capacitor is selected as an output capacitor, large ESR may be a cause of unstable operation. Evaluate the operation of PCB with considerable frequency characteristics. PCB Layout Make VDD and GND lines sufficient. If their impedance is high, noise pickup or unstable operation may result. Connect a capacitor C1 with a capacitance value as much as 1.0F or more between VDD and GND pin, and as close as possible to the pins. Set external components, especially the output capacitor C2, as close as possible to the ICs, and make wiring as short as possible. 6 RP101x NO.EA-167-160425 TEST CIRCUITS VDD VOUT RP101x Series C1 CE C2 V VOUT IOUT GND C1=Ceramic 1.0F C2=Ceramic 1.0F Basic Test Circuit VDD A VOUT RP101x Series C1 ISS VOUT CE C2 GND C1=Ceramic 1.0F C2=Ceramic 1.0F Test Circuit for Supply Current Pulse Generator VDD VOUT RP101x Series P.G. CE C2 IOUT GND C2=Ceramic 1.0F Test Circuit for Ripple Rejection VDD C1 RP101x Series CE VOUT VOUT C2 GND IOUTa IOUTb C1=Ceramic 1.0F C2=Ceramic 1.0F Test Circuit for Load Transient Response 7 RP101x NO.EA-167-160425 TYPICAL CHARACTERISTICS 1) Output Voltage vs. Output Current (C11.0F, C21.0F, Topt25C) RP101x12xx RP101x25xx 3.0 1.2 1.0 Output Voltage VOUT (V) Output Voltage VOUT (V) 1.4 VIN=2.2V VIN=3.6V VIN=4.2V 0.8 0.6 0.4 0.2 0 2.5 VIN=3.5V VIN=4.2V VIN=5.0V VIN=5.5V 2.0 1.5 1.0 0.5 0 0 100 200 300 400 500 Output Current IOUT (mA) 0 600 100 200 300 400 500 Output Current IOUT (mA) 600 RP101x33xx Output Voltage VOUT (V) 3.5 3.0 2.5 VIN=4.3V VIN=5.0V VIN=5.5V 2.0 1.5 1.0 0.5 0 0 100 200 300 400 500 Output Current IOUT (mA) 600 2) Output Voltage vs. Input Voltage (C11.0F, C21.0F, Topt25C) RP101x25xx 2.8 1.2 2.4 1.0 0.8 IOUT=1mA IOUT=30mA IOUT=50mA 0.6 0.4 0.2 0 2.0 1.6 IOUT=1mA IOUT=30mA IOUT=50mA 1.2 0.8 0.4 0 0 8 Output Voltage VOUT (V) Output Voltage VOUT (V) RP101x12xx 1.4 1 2 3 4 Input Voltage VIN (V) 5 0 1 2 3 4 Input Voltage VIN (V) 5 RP101x NO.EA-167-160425 RP101x33xx Output Voltage VOUT (V) 3.5 3.0 2.5 2.0 IOUT=1mA IOUT=30mA IOUT=50mA 1.5 1.0 0.5 0 0 1 2 3 4 Input Voltage VIN (V) 5 3) Supply Current vs. Input Voltage (C11.0F, C21.0F, Topt25C) RP101x25xx 35 30 30 Supply Current ISS (μA) Supply Current ISS (μA) RP101x12xx 35 25 20 15 10 5 0 25 20 15 10 5 0 0 1 2 3 4 Input Voltage VIN (V) 5 0 1 2 3 4 Input Voltage VIN (V) 5 RP101x33xx Supply Current ISS (μA) 35 30 25 20 15 10 5 0 0 1 2 3 4 Input Voltage VIN (V) 5 9 RP101x NO.EA-167-160425 4) Output Voltage vs. Temperature (C11.0F, C21.0F, IOUT1mA) 1.25 1.24 1.23 1.22 1.21 1.20 1.19 1.18 1.17 1.16 1.15 -40 -25 RP101x25xx VIN=2.2V Output Voltage VOUT (V) Output Voltage VOUT (V) RP101x12xx 0 25 50 Temperature Topt (°C) 75 85 2.55 2.54 2.53 2.52 2.51 2.50 2.49 2.48 2.47 2.46 2.45 -40 -25 VIN=3.5V 0 25 50 Temperature Topt (°C) 75 85 Output Voltage VOUT (V) RP101x33xx 3.35 3.34 3.33 3.32 3.31 3.30 3.29 3.28 3.27 3.26 3.25 -40 -25 VIN=4.3V 0 25 50 Temperature Topt (°C) 75 85 5) Supply Current vs. Temperature (C11.0F, C21.0F, IOUT0mA) RP101x12xx 25 20 15 10 5 0 -40 -25 10 30 Supply Current ISS (μA) Supply Current ISS (μA) 30 RP101x25xx VIN=2.2V 0 25 50 Temperature Topt (°C) 75 85 VIN=3.5V 25 20 15 10 5 0 -40 -25 0 25 50 Temperature Topt (°C) 75 85 RP101x NO.EA-167-160425 RP101x33xx VIN=4.3V Supply Current ISS (μA) 30 25 20 15 10 5 0 -40 -25 0 25 50 Temperature Topt (°C) 75 85 6) Dropout Voltage vs. Output Current (C11.0F, C21.0F) RP101x12xx RP101x15xx 500 Dropout Voltage VDIF (mV) Dropout Voltage VDIF (mV) 700 85°C 25°C - 40°C 600 500 400 300 200 100 0 85°C 25°C - 40°C 400 300 200 100 0 0 50 100 150 200 250 Output Current IOUT (mA) 0 300 RP101x17xx 300 RP101x20xx 400 Dropout Voltage VDIF (mV) 500 Dropout Voltage VDIF (mV) 50 100 150 200 250 Output Current IOUT (mA) 85°C 25°C - 40°C 400 300 200 100 0 350 85°C 25°C - 40°C 300 250 200 150 100 50 0 0 50 100 150 200 250 Output Current IOUT (mA) 300 0 50 100 150 200 250 Output Current IOUT (mA) 300 11 RP101x NO.EA-167-160425 RP101x25xx RP101x28xx 400 350 Dropout Voltage VDIF (mV) Dropout Voltage VDIF (mV) 400 85°C 25°C - 40°C 300 250 200 150 100 50 0 350 85°C 25°C - 40°C 300 250 200 150 100 50 0 0 50 100 150 200 250 Output Current IOUT (mA) 300 0 50 100 150 200 250 Output Current IOUT (mA) RP101x33xx Dropout Voltage VDIF (mV) 400 350 85°C 25°C - 40°C 300 250 200 150 100 50 0 0 50 100 150 200 250 Output Current IOUT (mA) 300 7) Dropout Voltage vs. Set Output Voltage (C11.0F, C21.0F, Topt25C) Dropout Voltage VDIF (mV) 600 500 400 300 200 100 0 1.0 12 10mA 30mA 100mA 150mA 200mA 300mA 1.5 2.0 2.5 3.0 Set Output Voltage VREG (V) 3.5 300 RP101x NO.EA-167-160425 8) Ripple Rejection vs. Input Bias Voltage (C1none, C21.0F, Ripple0.2Vp-p, Topt25C) RP101x12xx 80 70 60 50 40 30 1kHz 10kHz 100kHz 20 10 IOUT=30mA 90 Ripple Rejection RR (dB) 90 Ripple Rejection RR (dB) RP101x12xx IOUT=1mA 0 1.2 1.7 2.2 2.7 3.2 3.7 4.2 4.7 5.2 Input Voltage VIN (V) 80 70 60 50 40 30 1kHz 10kHz 100kHz 20 10 0 1.2 1.7 2.2 2.7 3.2 3.7 4.2 4.7 5.2 Input Voltage VIN (V) RP101x28xx RP101x28xx C1=none IOUT=30mA 90 90 80 80 Ripple Rejection RR (dB) Ripple Rejection RR (dB) C1=none IOUT=1mA 70 60 50 40 30 1kHz 10kHz 100kHz 20 10 0 2.8 3.3 3.8 4.3 4.8 Input Voltage VIN (V) 5.3 70 60 50 40 30 1kHz 10kHz 100kHz 20 10 0 2.8 3.3 3.8 4.3 4.8 Input Voltage VIN (V) 5.3 13 RP101x NO.EA-167-160425 9)) Ripple Rejection vs. Frequency (C1=none, C2=1.0µF, Ripple=0.2Vp-p) RP101x25xx RP101x12xx VIN=2.2V 80 60 40 20 0 0.1 14 IOUT=1mA IOUT=30mA IOUT=150mA 100 1 10 100 Frequency f (kHz) 1000 VIN=3.5V 120 Ripple Rejection RR (dB) Ripple Rejection RR (dB) 120 IOUT=1mA IOUT=30mA IOUT=150mA 100 80 60 40 20 0 0.1 1 10 100 Frequency f (kHz) 1000 RP101x NO.EA-167-160425 RP101x33xx VIN=4.3V Ripple Rejection RR (dB) 120 IOUT=1mA IOUT=30mA IOUT=150mA 100 80 60 40 20 0 0.1 1 10 100 Frequency f (kHz) 1000 RP101x12xx 120 - 40°C 25°C 85°C 100 80 60 40 20 0 0.1 1 10 100 Frequency f (kHz) 1000 VIN=3.5V 120 Ripple Rejection RR (dB) Ripple Rejection RR (dB) RP101x25xx VIN=2.2V - 40°C 25°C 85°C 100 80 60 40 20 0 0.1 1 10 100 Frequency f (kHz) 1000 RP101x33xx VIN=4.3V Ripple Rejection RR (dB) 120 - 40°C 25°C 85°C 100 80 60 40 20 0 0.1 1 10 100 Frequency f (kHz) 1000 15 RP101x NO.EA-167-160425 10) Input Transient Response (IOUT30mA, trtf5s, Topt25C) RP101x12xx RP101x25xx 2.5 2.0 1.203 1.198 Output Voltage 1.193 1.188 4.5 Input Voltage 4.0 3.5 3.0 2.506 2.501 Input Voltage VIN (V) 3.0 Input Voltage Output Voltage VOUT (V) 5.0 Input Voltage VIN (V) Output Voltage VOUT (V) 3.5 Output Voltage 2.496 2.491 0 20 40 60 Time t (μs) 80 0 100 20 40 60 Time t (μs) 80 100 RP101x33xx 5 Input Voltage 4 3.305 3.300 3.295 Input Voltage VIN (V) Output Voltage VOUT (V) 6 Output Voltage 3.290 0 20 40 60 Time t (μs) 80 100 11) Load Transient Response (C21.0F, Topt25C) RP101x25xx 50 0 1.20 1.19 1.18 Output Voltage 1.17 150 100 50 Output Current 50mA 100mA 0 2.51 2.50 2.49 2.48 Output Voltage 2.47 2.46 1.16 0 16 Output Voltage VOUT (V) 150 100 Output Current 50mA 100mA VIN=3.5V tr=tf=0.5μs Output Current IOUT (mA) Output Voltage VOUT (V) VIN=2.2V tr=tf=0.5μs 20 40 60 Time t (μs) 80 100 0 20 40 60 Time t (μs) 80 100 Output Current IOUT (mA) RP101x12xx RP101x NO.EA-167-160425 RP101x12xx 50 0 3.31 3.30 3.29 Output Voltage 3.27 3.26 20 40 60 Time t (μs) 80 1.25 1.20 1.15 1.10 1.05 1.00 Output Voltage 0 100 20 RP101x25xx 0 2.6 2.5 Output Voltage 2.3 2.2 40 60 Time t (μs) 80 Output Voltage VOUT (V) 50 Output Current IOUT (mA) Output Voltage VOUT (V) 100 Output Current 1mA 150mA 20 Output Current 1mA 150mA 3.35 3.30 3.25 3.20 3.15 3.10 3.05 100 0 20 40 60 Time t (μs) 80 100 RP101x25xx Output Voltage Output Voltage VOUT (V) Output Current 1mA 150mA 200 150 100 50 0 VIN=3.5V tr=tf=5μs Output Current IOUT (mA) VIN=2.2V tr=tf=5μs Output Voltage VOUT (V) 200 150 100 50 0 Output Voltage RP101x12xx 1.25 1.20 1.15 1.10 1.05 1.00 100 VIN=4.3V tr=tf=0.5μs 200 150 0 80 RP101x33xx VIN=3.5V tr=tf=0.5μs 2.4 40 60 Time t (μs) Output Current IOUT (mA) 0 Output Current 1mA 150mA 200 150 100 50 0 200 150 100 Output Current 1mA 150mA 50 0 2.6 2.5 2.4 Output Voltage 2.3 Output Current IOUT (mA) 3.28 Output Voltage VOUT (V) 150 100 Output Current 50mA 100mA VIN=2.2V tr=tf=0.5μs Output Current IOUT (mA) Output Voltage VOUT (V) VIN=4.3V tr=tf=0.5μs Output Current IOUT (mA) RP101x33xx 2.2 0 20 40 60 Time t (μs) 80 100 0 20 40 60 Time t (μs) 80 100 17 RP101x NO.EA-167-160425 Output Voltage VOUT (V) VIN=4.3V tr=tf=5μs Output Current 1mA 150mA 3.35 3.30 3.25 3.20 3.15 3.10 200 150 100 50 0 Output Voltage 0 20 40 60 Time t (μs) 80 Output Current IOUT (mA) RP101x33xx 100 12) Turn On Speed with CE pin (C11.0F, C21.0F, Topt25C) RP101x12xx RP101x12xx IOUT=0mA IOUT=10mA 0 2 1 Output Voltage Output Voltage VOUT (V) 1 CE Input Voltage VCE (V) 0 2 CE Input Voltage 1 0 2 1 Output Voltage 0 0 20 40 60 Time t (μs) 80 100 0 20 RP101x12xx 40 60 Time t (μs) 80 RP101x12xx IOUT=30mA IOUT=150mA 1 0 2 Output Voltage 0 2 CE Input Voltage 1 0 2 1 Output Voltage 0 0 18 Output Voltage VOUT (V) 2 CE Input Voltage 3 CE Input Voltage VCE (V) Output Voltage VOUT (V) 3 1 100 20 40 60 Time t (μs) 80 100 0 20 40 60 Time t (μs) 80 100 CE Input Voltage VCE (V) Output Voltage VOUT (V) 2 CE Input Voltage CE Input Voltage VCE (V) 3 3 RP101x NO.EA-167-160425 RP101x25xx RP101x25xx IOUT=0mA IOUT=10mA 0 3 2 Output Voltage 1 0 4 2 CE Input Voltage 0 3 2 Output Voltage 1 0 20 40 60 Time t (μs) 80 100 0 20 RP101x25xx 40 60 Time t (μs) 80 100 RP101x25xx IOUT=30mA IOUT=150mA 2 CE Input Voltage 0 3 2 Output Voltage 1 Output Voltage VOUT (V) 4 6 CE Input Voltage VCE (V) 0 4 2 CE Input Voltage 0 3 2 Output Voltage 1 0 0 20 40 60 Time t (μs) 80 0 100 20 RP101x33xx 40 60 Time t (μs) 80 RP101x33xx IOUT=0mA IOUT=150mA 6 2 0 4 Output Voltage 0 Output Voltage VOUT (V) 4 CE Input Voltage CE Input Voltage VCE (V) 6 2 100 4 CE Input Voltage 2 0 4 Output Voltage 2 CE Input Voltage VCE (V) Output Voltage VOUT (V) 6 CE Input Voltage VCE (V) 0 Output Voltage VOUT (V) CE Input Voltage VCE (V) 2 CE Input Voltage Output Voltage VOUT (V) 4 6 CE Input Voltage VCE (V) Output Voltage VOUT (V) 6 0 0 20 40 60 Time t (μs) 80 100 0 20 40 60 Time t (μs) 80 100 19 RP101x NO.EA-167-160425 13) Turn Off Speed with CE pin (D Version) (C11.0F, C21.0F, Topt25C) RP101x12xD RP101x12xD IOUT=0mA IOUT=10mA 1 0 2 Output Voltage 1 0 2 CE Input Voltage 1 0 2 Output Voltage 1 0 50 100 150 200 Time t (μs) 250 300 0 50 RP101x12xD 100 150 200 Time t (μs) 250 300 RP101x12xD IOUT=30mA IOUT=150mA CE Input Voltage 1 0 2 Output Voltage 1 Output Voltage VOUT (V) 2 3 CE Input Voltage VCE (V) 0 2 CE Input Voltage 0 2 Output Voltage 1 0 0 50 100 150 200 Time t (μs) 250 300 0 20 RP101x25xD 40 60 Time t (μs) 80 IOUT=10mA 2 0 3 Output Voltage 1 0 Output Voltage VOUT (V) CE Input Voltage 4 CE Input Voltage VCE (V) 4 2 100 RP101x25xD IOUT=0mA Output Voltage VOUT (V) 1 CE Input Voltage 2 0 3 Output Voltage 2 1 0 0 50 100 150 200 Time t (μs) 250 300 0 50 100 150 200 Time t (μs) 250 300 CE Input Voltage VCE (V) Output Voltage VOUT (V) 3 CE Input Voltage VCE (V) 0 20 CE Input Voltage VCE (V) CE Input Voltage Output Voltage VOUT (V) 2 3 CE Input Voltage VCE (V) Output Voltage VOUT (V) 3 RP101x NO.EA-167-160425 RP101x25xD RP101x25xD IOUT=30mA IOUT=150mA 3 Output Voltage 2 1 0 2 CE Input Voltage 0 3 Output Voltage 2 1 0 50 100 150 200 Time t (μs) 250 300 0 50 RP101x33xD 100 150 200 Time t (μs) 250 300 RP101x33xD IOUT=0mA IOUT=10mA CE Input Voltage 2 0 4 Output Voltage 2 Output Voltage VOUT (V) 4 6 CE Input Voltage VCE (V) 0 4 CE Input Voltage 2 0 4 Output Voltage 2 0 0 50 100 150 200 Time t (μs) 250 300 0 50 RP101x33xD 100 150 200 Time t (μs) 250 300 RP101x33xD IOUT=30mA IOUT=150mA CE Input Voltage 2 0 4 Output Voltage 2 0 Output Voltage VOUT (V) 4 6 CE Input Voltage VCE (V) 6 4 CE Input Voltage 2 0 4 Output Voltage 2 CE Input Voltage VCE (V) Output Voltage VOUT (V) 6 CE Input Voltage VCE (V) 0 Output Voltage VOUT (V) CE Input Voltage VCE (V) 0 Output Voltage VOUT (V) 2 CE Input Voltage 4 CE Input Voltage VCE (V) Output Voltage VOUT (V) 4 0 0 50 100 150 200 Time t (μs) 250 300 0 20 40 60 Time t (μs) 80 100 21 RP101x NO.EA-167-160425 14) Dropout Voltage vs. Temperature (C11.0F, C21.0F) RP101x12xx RP101x25xx 350 500 Dropout Voltage VDIF (mV) Dropout Voltage VDIF (mV) 600 300mA 150mA 100mA 50mA 400 300 200 100 0 -40 -25 0 25 50 Temperature Topt (°C) 75 85 300 250 200 150 100 50 0 -40 -25 RP101x33xx Dropout Voltage VDIF (mV) 350 300 250 300mA 150mA 100mA 50mA 200 150 100 50 0 -40 -25 0 25 50 Temperature Topt (°C) 75 85 15) Output Voltage vs. Input Voltage (C11.0F, C21.0F) Output Voltage VOUT (V) 3.2 3.0 2.8 2.6 2.2 2.0 2.7 22 IOUT=0mA IOUT=10mA IOUT=50mA IOUT=100mA IOUT=150mA 2.4 2.8 2.9 3.0 3.1 Input Voltage VIN (V) 3.2 300mA 150mA 100mA 50mA 0 25 50 Temperature Topt (°C) 75 85 RP101x NO.EA-167-160425 ESR vs. Output Current When using these ICs, consider the following points: The relations between IOUT (Output Current) and ESR of an output capacitor are shown below. The conditions when the white noise level is under 40V (Avg.) are marked as the hatched area in the graph. Measurement conditions Frequency Band : 10Hz to 2MHz Temperature : 40C to 85C RP101x12xx RP101x12xx Topt=85°C VIN=1.7V to 5.5V C1=Ceramic 1.0μF 1000 1000 100 100 ESR (Ω) ESR (Ω) Topt=-40°C VIN=1.7V to 5.5V C1=Ceramic 1.0μF 10 1 0.1 10 1 0.1 0.01 0.01 0 50 100 150 200 250 Output Current IOUT (mA) 300 0 RP101x33xx 300 RP101x33xx Topt=-40°C VIN=3.3V to 5.5V C1=Ceramic 1.0μF Topt=85°C VIN=3.3V to 5.5V C1=Ceramic 1.0μF 1000 1000 100 100 ESR (Ω) ESR (Ω) 50 100 150 200 250 Output Current IOUT (mA) 10 1 0.1 10 1 0.1 0.01 0.01 0 50 100 150 200 250 Output Current IOUT (mA) 300 0 50 100 150 200 250 Output Current IOUT (mA) 300 23 RP101x NO.EA-167-160425 PACKAGE INFORMATION Power Dissipation (DFN(PL)1612-4) Power Dissipation (PD) depends on conditions of mounting on board. This specification is based on the measurement at the condition below: Measurement Conditions Standard Test Land Pattern Mounting on Board (Wind velocity=0m/s) Glass cloth epoxy plastic (Double sided) 40mm*40mm*1.6mm Top side: Approx. 50%, Back side: Approx. 50%  0.54mm * 24pcs Environment Board Material Board Dimensions Copper Ratio Through-holes Measurement Result (Ta=25C) Standard Test Land Pattern 610mW (Tjmax=125C) 762mW(Tjmax=150C) ja = (125-25C)/0.61W= 164C/W jc = 48C/W Power Dissipation Thermal Resistance 40 762 700 600 610 500 400 300 40 Power Dissipation PD (mW) 800 200 100 0 0 25 50 75 85 100 125 150 Ambient Temperature (°C) Power Dissipation Measurent Board Pattern IC Mount Area Unit : mm *The above graph shows the Power Dissipation of the package based on Tjmax=125C and Tjmax=150C. Operating the IC in the shaded area in the graph might have an influence it's lifetime. Operating time must be within the time limit described in the table below, in case of operating in the shaded area. Operating Time 13,000 hours 24 Estimated years (Operating four hours/day) 9years RP101x NO.EA-167-160425 Package Dimensions (DFN(PL)1612-4) 1.00.1 1.2 0.6 B A 3 X4 4 1.6 0.70.1 0.20.1 ※ 0.05 INDEX S 0.05 S 1 0.30.1 0.6MAX. 0.05MIN. 2 Bottom View 0.05 M AB (Unit : mm) ※) Tab is GND level. (They are connected to the reverse side of this IC.) The tab is better to be connected to the GND, but leaving it open is also acceptable. Mark Specification (DFN(PL)1612-4)   : Product Code … Please refer to the RP101Kxx1x Series Mark Specification Table. : Lot Number … Alphanumeric Serial Number   25 RP101x NO.EA-167-160425 RP101Kxx1x Series Mark Specification Table PKG: DFN(PL)1612-4 26 RP101Kxx1B Part Number  Vset RP101Kxx1D Part Number  Vset RP101K121B 3A 1.2V RP101K121D 4A 1.2V RP101K131B 3B 1.3V RP101K131D 4B 1.3V RP101K151B 3C 1.5V RP101K151D 4C 1.5V RP101K181B 3D 1.8V RP101K181D 4D 1.8V RP101K181B5 3E 1.85V RP101K181D5 4E 1.85V RP101K191B 3F 1.9V RP101K191D 4F 1.9V RP101K201B 3G 2.0V RP101K201D 4G 2.0V RP101K251B 3H 2.5V RP101K251D 4H 2.5V RP101K261B 3J 2.6V RP101K261D 4J 2.6V RP101K271B 3K 2.7V RP101K271D 4K 2.7V RP101K281B 3L 2.8V RP101K281D 4L 2.8V RP101K281B5 3M 2.85V RP101K281D5 4M 2.85V RP101K291B 3N 2.9V RP101K291D 4N 2.9V RP101K301B 3P 3.0V RP101K301D 4P 3.0V RP101K311B 3Q 3.1V RP101K311D 4Q 3.1V RP101K331B 3R 3.3V RP101K331D 4R 3.3V RP101K211B 3S 2.1V RP101K211D 4S 2.1V RP101K231B 3T 2.3V RP101K231D 4T 2.3V RP101K241B 3U 2.4V RP101K241D 4U 2.4V RP101K321B 3V 3.2V RP101K321D 4V 3.2V RP101K221B 3W 2.2V RP101K221D 4W 2.2V RP101x NO.EA-167-160425 Power Dissipation (DFN(PL)1612-4B) Power Dissipation (PD) depends on conditions of mounting on board. This specification is based on the measurement at the condition below: Measurement Conditions Standard Test Land Pattern Mounting on Board (Wind velocity=0m/s) Glass cloth epoxy plastic (Double sided) 40mm*40mm*1.6mm Top side: Approx. 50%, Back side: Approx. 50%  0.54mm * 24pcs Environment Board Material Board Dimensions Copper Ratio Through-holes Measurement Result (Ta=25C) Standard Test Land Pattern 580mW (Tjmax=125C) 725mW (Tjmax=150C) Power Dissipation ja = (125-25 C) / 0.58W= 172 C/W Thermal Resistance jc = 51 C/W Power Dissipation Measurent Board Pattern 40 725 700 600 580 500 400 40 Power Dissipation PD (mW) 800 300 200 100 0 0 25 50 75 85 100 125 150 Ambient Temperature (°C) IC Mount Area Unit : mm *The above graph shows the Power Dissipation of the package based on Tjmax=125C and Tjmax=150C. Operating the IC in the shaded area in the graph might have an influence it's lifetime. Operating time must be within the time limit described in the table below, in case of operating in the shaded area. Operating Time 13,000 hours Estimated years (Operating four hours/day) 9years 27 RP101x NO.EA-167-160425 Package Dimensions (DFN(PL)1612-4B) 1.00.1 1.2 0.6 B A 3 X4 0.05 S 0.70.1 0.4MAX. 1.6 0.05MIN. INDEX 0.20.1 ※ 0.05 S 4 2 1 0.30.1 Bottom View 0.05 M AB (Unit : mm) ※) Tab is GND level. (They are connected to the reverse side of this IC.) The tab is better to be connected to the GND, but leaving it open is also acceptable. Mark Specification (DFN(PL)1612-4B)   : Product Code … Please refer to the RP101Kxx2x Series Mark Specification Table. : Lot Number … Alphanumeric Serial Number   28 RP101x NO.EA-167-160425 RP101Kxx2x Series Mark Specification Table PKG: DFN(PL)1612-4B RP101Kxx2B Part Number  Vset RP101K122B 5A 1.2V RP101K132B 5B RP101K152B RP101Kxx2D Part Number  Vset RP101K122D 6A 1.2V 1.3V RP101K132D 6B 1.3V 5C 1.5V RP101K152D 6C 1.5V RP101K182B 5D 1.8V RP101K182D 6D 1.8V RP101K182B5 5E 1.85V RP101K182D5 6E 1.85V RP101K192B 5F 1.9V RP101K1921D 6F 1.9V RP101K202B 5G 2.0V RP101K202D 6G 2.0V RP101K252B 5H 2.5V RP101K252D 6H 2.5V RP101K262B 5J 2.6V RP101K262D 6J 2.6V RP101K272B 5K 2.7V RP101K272D 6K 2.7V RP101K282B 5L 2.8V RP101K282D 6L 2.8V RP101K282B5 5M 2.85V RP101K282D5 6M 2.85V RP101K292B 5N 2.9V RP101K292D 6N 2.9V RP101K302B 5P 3.0V RP101K302D 6P 3.0V RP101K312B 5Q 3.1V RP101K312D 6Q 3.1V RP101K332B 5R 3.3V RP101K332D 6R 3.3V RP101K212B 5S 2.1V RP101K212D 6S 2.1V RP101K232B 5T 2.3V RP101K232D 6T 2.3V RP101K242B 5U 2.4V RP101K242D 6U 2.4V RP101K322B 5V 3.2V RP101K322D 6V 3.2V RP101K222B 5W 2.2V RP101K222D 6W 2.2V 29 RP101x NO.EA-167-160425 Power Dissipation (SOT-23-5) Power Dissipation (PD) depends on conditions of mounting on board. This specification is based on the measurement at the condition below: (Power Dissipation (SOT-23-5) is substitution of SOT-23-6.) Measurement Conditions Standard Test Land Pattern Mounting on Board (Wind velocity=0m/s) Glass cloth epoxy plastic (Double sided) 40mm*40mm*1.6mm Top side: Approx. 50%, Back side: Approx. 50%  0.5mm * 44pcs Environment Board Material Board Dimensions Copper Ratio Through-holes Measurement Result (Ta=25C) Standard Test Land Pattern 420mW(Tjmax=125C) 525mW(Tjmax=150C) ja = (125-25C)/0.42W= 238C/W Power Dissipation Thermal Resistance Free Air 250mW(Tjmax=125C) 400C/W 600 40 On Board 500 400 420 300 Free Air 40 Power Dissipation PD (mW) 525 250 200 100 0 0 25 50 75 85 100 125 150 Measurement Board Pattern Ambient Temperature (C) IC Mount Area (Unit: mm) Power Dissipation *The above graph shows the Power Dissipation of the package based on Tjmax=125C and Tjmax=150C. Operating the IC in the shaded area in the graph might have an influence it's lifetime. Operating time must be within the time limit described in the table below, in case of operating in the shaded area. Operating Time 9,000 hours 30 Estimated years (Operating four hours/day) 6years RP101x NO.EA-167-160425 Package Dimensions (SOT-23-5) 2.9±0.2 1.1±0.1 1.9±0.2 0.8±0.1 (0.95) 4 1 2 0~0.1 0.2min. +0.2 1.6-0.1 5 2.8±0.3 (0.95) 3 +0.1 0.15-0.05 0.4±0.1 Unit : mm Mark Specification (SOT-23-5)   : Product Code … Please refer to the RP101N Series Mark Specification Table. : Lot Number … Alphanumeric Serial Number 5 4  1 2 3 31 RP101x NO.EA-167-160425 RP101N Series Mark Specification Table PKG: SOT-23-5 RP101NxxxB Part Number 32  Vset RP101N121B 7 0A 1.2V RP101N131B 7 0B RP101N151B RP101NxxxD Part Number  Vset RP101N121D 7 1A 1.2V 1.3V RP101N131D 7 1B 1.3V 7 0C 1.5V RP101N151D 7 1C 1.5V RP101N181B 7 0D 1.8V RP101N181D 7 1D 1.8V RP101N181B5 70E 1.85V RP101N181D5 71E 1.85V RP101N191B 7 0F 1.9V RP101N191D 7 1F 1.9V RP101N201B 7 0G 2.0V RP101N201D 7 1G 2.0V RP101N251B 7 0H 2.5V RP101N251D 7 1H 2.5V RP101N261B 7 0J 2.6V RP101N261D 7 1J 2.6V RP101N271B 7 0K 2.7V RP101N271D 7 1K 2.7V RP101N281B 7 0L 2.8V RP101N281D 7 1L 2.8V RP101N281B5 7 0M 2.85V RP101N281D5 7 1M 2.85V RP101N291B 7 0N 2.9V RP101N291D 7 1N 2.9V RP101N301B 70P 3.0V RP101N301D 71P 3.0V RP101N311B 7 0Q 3.1V RP101N311D 7 1Q 3.1V RP101N331B 7 0R 3.3V RP101N331D 7 1R 3.3V RP101N211B 70S 2.1V RP101N211D 71S 2.1V RP101N231B 7 0T 2.3V RP101N231D 7 1T 2.3V RP101N241B 7 0U 2.4V RP101N241D 7 1U 2.4V RP101N321B 70V 3.2V RP101N321D 71V 3.2V RP101N221B 7 0W 2.2V RP101N221D 7 1W 2.2V 1. The products and the product specifications described in this document are subject to change or discontinuation of production without notice for reasons such as improvement. Therefore, before deciding to use the products, please refer to our sales representatives for the latest information thereon. 2. The materials in this document may not be copied or otherwise reproduced in whole or in part without prior written consent of our company. 3. Please be sure to take any necessary formalities under relevant laws or regulations before exporting or otherwise taking out of your country the products or the technical information described herein. 4. The technical information described in this document shows typical characteristics of and example application circuits for the products. The release of such information is not to be construed as a warranty of or a grant of license under our company's or any third party's intellectual property rights or any other rights. 5. The products listed in this document are intended and designed for use as general electronic components in standard applications (office equipment, telecommunication equipment, measuring instruments, consumer electronic products, amusement equipment etc.). Those customers intending to use a product in an application requiring extreme quality and reliability, for example, in a highly specific application where the failure or misoperation of the product could result in human injury or death (aircraft, spacevehicle, nuclear reactor control system, traffic control system, automotive and transportation equipment, combustion equipment, safety devices, life support system etc.) should first contact us. 6. We are making our continuous effort to improve the quality and reliability of our products, but semiconductor products are likely to fail with certain probability. In order to prevent any injury to persons or damages to property resulting from such failure, customers should be careful enough to incorporate safety measures in their design, such as redundancy feature, fire containment feature and fail-safe feature. We do not assume any liability or responsibility for any loss or damage arising from misuse or inappropriate use of the products. 7. Anti-radiation design is not implemented in the products described in this document. 8. The X-ray exposure can influence functions and characteristics of the products. Confirm the product functions and characteristics in the evaluation stage. 9. WLCSP products should be used in light shielded environments. The light exposure can influence functions and characteristics of the products under operation or storage. 10. There can be variation in the marking when different AOI (Automated Optical Inspection) equipment is used. In the case of recognizing the marking characteristic with AOI, please contact our sales or our distributor before attempting to use AOI. 11. Please contact our sales representatives should you have any questions or comments concerning the products or the technical information. Official website https://www.nisshinbo-microdevices.co.jp/en/ Purchase information https://www.nisshinbo-microdevices.co.jp/en/buy/
RP101N181D-TR-FE 价格&库存
很抱歉,暂时无法提供与“RP101N181D-TR-FE”相匹配的价格&库存,您可以联系我们找货
