MGDK35 35W POWER
BOARD MOUNTED ISOLATED DC/DC CONVERTER
Description
The MGDK35 series features a Quality Cost Effective range of 35W board mounted isolated dc/dc
converters. With multiple selection of wide input voltage ranges from 9V up to 140V dc, the
MGDK35 is proposed with a single, symmetrical or triple output channel. The converter
embeds an output overload protection, and comes encapsulated in a low profile fully potted
2.9’’x1.9’’X0.5’’ metallic case.
Fields of Application
General purpose application
Transportation
Telecom
Renewable Energy
Part-numbering
MGD S K 35 H C
output nb.
Input Voltage range Output Voltage Range
S = single
B = double
T = Triple
H = 9-36
O = 18-75
Q = 36-140
B = 3.3
C=5
E = 12
F = 15
Selection Guide
Part Number
Part Number
Output
Voltage
(Vdc)
Output
Power
(Watt)
Output Current
(Adc)
7
MGDSK35OC
5
23
7
35
7
MGDSK35OE
12
35
7
12
35
2.9
MGDSK35OF
15
35
2.9
MGDSK35HF
15
35
2.3
MGDBK35OC
+5/-5
35
3.5
MGDBK35HC
+5/-5
35
+/-3.5
MGDBK35OE
+12/-12
35
+/-1.45
MGDBK35HE
+12/-12
35
+/-1.45
MGDTK35OCE
+5 +/-11.7
35
4 +/-0.625
MGDBK35HF
+15/-15
35
+/-1.15
MGDTK35OCF
+5 +/-14.7
35
4 +/-0.5
MGDTK35HCE
+5 +/-11.8
35
4 +/-0.625
MGDSK35QC
+5
35
7
MGDTK35HCF
+5 +/-14.7
35
4 +/-0.5
MGDBK35QE
+12/-12
35
+/-1.45
Output Voltage
(Vdc)
Output
Power
(Watt)
Iutput Current
(Adc)
MGDSK35HB
3.3
23
MGDSK35HC
5
MGDSK35HE
for more information go to https://www.gaia-converter.com
FC19-0100.01/21 Revision C
1/5
WWW.GAIA-CONVERTER.COM
MGDK35 35W POWER
1-ELECTRICAL SPECIFICATIONS
Specification
Data are valid at +25°C, unless otherwise specified
Parameter
Conditions
Limit
Units
H input
O input
Q input
Nominal Input Voltage
(Ui nom)
Full temperature range
Nominal
Vdc
72
Transient Input Voltage
Maximum
Vdc/s
36
75
175/0.1
Typical
Vdc
8.8/8
15.8/14
33/30
Maximum
ms
Ui Nominal 75% load
Typical
83
84
85
(hic-up mode)
Maximum
mW
300
500
800
Ui nom @75% load
Maximum
+/- 2.5
Output regulation (Line)
25% to full load
Maximum
+/- 1.5
Output regulation (Load)
Ui min. To Ui max
25% to full load
0% to 25% load
Maximum
Typical
+/- 2.5
+15 to +/-2.5
INPUT
Start-up input voltage
Turn on /turn off
Start-up time
Power efficiency
No load input power
30
OUTPUT
Set Point accuracy
Cross Load Output
regulation
Vout1 @75% load
Vout2@25% load
Output ripple voltage
B & C output (3V3) (5V)
E & F output (12V) (15V)
Ui min. To Ui max
+/- 0.5
Maximum
mVpp
150
300
Maximum
µF
2200
330
Khz
250
+/-5
Vdc
1500
Admissible capacitor
B & C output
E & F output
Ui min. Full load
( per output)
MISCELLANEOUS
Switching Frequency
Typical
Output Trim Range
Min.Max.
Isolation Strength
(Input output)
Ui min. To Ui max
EMC Compliance
With input capacitor
With input filter
2/5
EN555032 class A
EN555032 class B
MGDK35 35W POWER
2-THERMAL & MECHANICAL SPECIFICATIONS
Parameter
Conditions
Case temperature range
Storage temperature range
Not operating
Case Material
Limit
Units
Parameter
Mini.Max.
°C
-40 to 95
Mini.Max.
°C
Regular model
Pin Material
Copper plated with pure matte tin over nickel
underplate
Case to Air thermal resistance
Typical
°C/W
Connections
Pin#
1
2
3
4
5
6
7
8
11
13
15
17
MGDSK35
(Single)
MGDBK35
(Double)
MGDTK35
(Triple)
Do not Connect
-Input (Gi)
Do not Connect
+Input (Vi)
Trim
Do not Connect
Vref
On/Off
Do not Connect
Do not Connect
Common (Go)
Output (Vo)
Do not Connect
-Input (Gi)
Do not Connect
+Input (Vi)
Trim
Do not Connect
Do not Connect
Vref
Output-(-Vo)
Do not Connect
Common (Go)
Output (Vo)
Do not Connect
-Input (Gi)
Do not Connect
+Input (Vi)
Trim
Do not Connect
Do not Connect
Vref
Output2- (-Vo2)
Output2+ (+Vo2)
Common (Go)
Output1 (Vo1)
Dimensions MGDK35
Dimensions are given in mm (inches) . Tolerance : +/-0.25mm (0.01’’) unless otherwise specified
weight : < 80gr (2.8oz) max.
3/5
110
Metallic black anodized coated
7
MGDK35 35W POWER
3-APPLICATION
Typical connections
Trim down
Trim up
TRIM FUNCTION:
TRIM UP Function:
TRIM Down Function:
The Module can be trimmed up using a resistor
connected across Trim pin and Vref. pin, the
ressitor value can be evaluatedusing the following
formula:
The Module can be trimmed down using a resistor
connected across Trim pin and Go pin, the ressitor
value can be evaluatedusing the following formula:
𝑉𝑜
−1
Ru = 12. 2. 𝑉𝑜𝑛𝑜𝑚
− 47
𝑉𝑜
1−
𝑉𝑜𝑛𝑜𝑚
Ru = 12.
With Ru: resistor value in KΩ
Vo: desired voltage
Vonom: nominal voltage
4/5
𝑉𝑜
𝑉𝑜𝑛𝑜𝑚
− 47
𝑉𝑜𝑛𝑜𝑚
2. (1 −
𝑉𝑜
Vo: desired voltage
MGDK35 35W POWER
3-APPLICATION
ON OFF FUNCTION:
The converter is naturally enabled as far as the on/off pin
remains unconnected. To disable the converter the pin
on/off should be shorted to Go using a switch, an open
collector or open drain transistor. Several converters of
the same input bus can be remotely controlled by the
same signal just by connecting all the pins on/off
together.
International Headquarters
GAÏA Converter - France
18 rue caroline Aigle
33186 LE HAILLAN - FRANCE
Tel. : + (33)-5-57-92-12-80
Fax : + (33)-5-57-92-12-89
5/5
North American Headquarters
GAÏA Converter Canada, Inc
4038 Le Corbusier Blvd
LAVAL, QUEBEC - CANADA H7L 5R2
Tel. : (514)-333-3169
Fax : (514)-333-4519
很抱歉,暂时无法提供与“MGDSK35OC”相匹配的价格&库存,您可以联系我们找货
