MGDK10 10W POWER
BOARD MOUNTED ISOLATED DC/DC CONVERTER
0.3’’ LOW PROFILE
Description
The MGDK10 series features a Quality Cost Effective range of 10W board mounted isolated dc/dc
converters. With multiple selection of wide input voltage ranges, the MGDK10 is proposed with a single,
double, symmetrical or triple output channel. The converter embeds an output overload protection,
and comes encapsulated in a low profile fully potted 1.6’’x0.3’’x1’’ metallic case.
Fields of Application
General purpose application
Transportation
Telecom
Rnewable Energy
Part-numbering
MGD S K 10 H C
output nb.
Input range
S = single
B = double
T = Triple
C = 4.5-5.5
D = 4.5-16
H = 9-36
I = 18-36
O = 18-75
Q = 36-140
Output
B = 3.3
C=5
E = 12
F = 15
(voltage value)
Selection Guide
Part Number
Part Number
Output
Voltage
(Vdc)
Output
Power
(Watt)
Output Current
(Adc)
+/-0.4
MGDSK10HF
12
10
0.8
10
0.66
MGDBK10HC
+/-5
10
+/-1
+/-12
10
+/-0.4
MGDBK10HE
+/-12
10
+/-0.4
MGDBK10CF
+/-15
10
+/-0.33
MGDBK10HF
+/-15
10
+/-0.33
MGDSK10DC
5
10
2
MGDTK10H3E
+3,8 +/-12
10
+1 +/-0.2
MGDBK10DC
+/-5
10
+/-1
MGDTK10HCE
+5 +/-12
10
+1 +/-0.2
MGDBK10DF
5
10
2
MGDTK10HCF
+5 +/-15
10
+1 +/-0.17
MGDSK10HB
3.3
6.6
2
MGDTK10ICE
+5 +/-12
10
+1 +/-0.2
MGDSK10HC
5
10
2
MGDTK10ICF
+5 +/-15
10
+1 +/-0.17
MGDSK10H5.5
5.5
10
1.8
MGDSK10OC
5
10
2
MGDSK10HE
12
10
0.8
MGDBK10OF
+/-15
10
+/-0.33
Output
Voltage
(Vdc)
Output
Power
(Watt)
Output Current
(Adc)
MGDSK10CE
+/-12
10
MGDSK10CF
15
MGDBK10CE
for more information go to https://www.gaia-converter.com
FC19-097.01/21 Revision C
1/5
WWW.GAIA-CONVERTER.COM
MGDK10 10W POWER
0.3’’ LOW PROFILE
Selection Guide (continued)
Part Number
Part Number
Output
Voltage
(Vdc)
Output
Power
(Watt)
Output Current
(Adc)
2
MGDBK10QE
12
10
0.8
10
2
MGDBK10QE/Y
12
10
0.8
5
10
2
MGDBK10QF
15
10
0.66
+/-5
10
+/-1
Output
Voltage
(Vdc)
Output
Power
(Watt)
Output Current
(Adc)
MGDSK10QB
3.3
6.6
MGDSK10QC
5
MGDSK10QC/Y
MGDBK10QC
1-ELECTRICAL SPECIFICATIONS
Specification
Data are valid at +25°C, unless otherwise specified
Parameter
Conditions
Limit
Units
C input
D input
H input
I input
Nominal Input Voltage
(Ui nom)
Full temperature range
Nominal
Vdc
5
9
Input Voltage Range
Min.-Max.
Vdc
4.5-5.5
4.5-16
9-36
18-36
Transient Input Voltage
Maximum
Vdc/s
36
36
Start-up input voltage
Turn on -turn off
Min.-Max.
Vdc
4-4.5
7-8.5
12-15.5
16-17.5
Start-up time
Maximum
ms
50
Ui Nominal 75% load
Typical
80
Ui nominal
(hic-up mode)
Maximum
mA
30
30
Conditions
Limit
Units
O input
Qinput
(Ui nom)
Nominal
Vdc
48
72
Input Voltage Range
Min.-Max.
Vdc
18-75
36-140
Maximum
Vdc/s
75
175/0.1
Turn on -turn off
Min.-Max.
Vdc
12-15
33-36
Start-up time
Maximum
ms
50
Ui Nominal 75% load
Typical
80
Ui nominal
(hic-up mode)
Maximum
mA
INPUT
Power efficiency
Input current in short
circuit mode (Average)
Parameter
50
50
INPUT
Power efficiency
2/5
30
MGDK10 10W POWER
1-ELECTRICAL SPECIFICATIONS (Continued)
Specification
Parameter
Conditions
Limit
Units
All inputs
Ui nom @75% load
Maximum
+/- 2.5
Output regulation (Line)
25% to full load
Maximum
+/- 1.5
Output regulation (Load)
Ui min. To Ui max
25% to full load
0% to 25% load
Maximum
Typical
OUTPUT
Set Point accuracy
+/- 2.5
+20 to +/-2.5
Minimum 10% load is recommended, operation with no load during more than
1s may partially damage the converter output.
Output ripple voltage
B output (3V3)
C output (5V)
E output (12V)
F output (15V)
Admissible capacitor
B output (3V3)
C output (5V)
E output (12V)
F output (15V)
Ui min. To Ui max
Ui min. Full load
( per output)
Maximum
mVpp
150
150
300
450
500
500
150
100
Maximum
µF
Typical
Khz
480
Vdc
1500
MISCELLANEOUS
Switching Frequency
Isolation Strength
(Input output)
EMC Compliance
FC19-0967 01/21 Revision C
3/5
Input output
With input capacitor
With input filter
EN555032 class A
EN555032 class B
MGDK10 10W POWER
2-THERMAL & MECHANICAL SPECIFICATIONS
Parameter
Conditions
Case temperature range
Storage temperature range
Not operating
Case Material
Limit
Units
Parameter
Mini.Max.
°C
-40 to 95
Mini.Max.
°C
Regular model
110
Metallic black anodized coated
Pin Material
Copper plated with pure matte tin over nickel
underplate
Case to Air thermal resistance
Typical
°C/W
Connections
Pin#
1
2
3
4
5
6
7
8
MGDSK10
(Single)
MGDBK10
(Double)
MGDTK10
(Triple)
+Input (Vi)
Do Not Connect
-Input (Gi)
Output (Vo)
Common (Go)
No pin
No pin
+Input (Vi)
Do Not Connect
-Input (Gi)
Output+ (Vo)
Common (Go)
Output-(-Vo)
No pin
No pin
+Input (Vi)
Do Not Connect
-Input (Gi)
Output1 (Vo1)
No pin
Common (Go)
Output2+ (+V2)
Output2- (-V2)
White dot on top
side
Dimensions MGDK10
Dimensions are given in mm (inches) . Tolerance : +/-0.25mm (0.01’’) unless otherwise specified
weight : < 15gr (0.5oz) max.
4/5
12
MGDK10 10W POWER
3-APPLICATION
Typical connections
Input and output capacitor values are given as suggestion
OCP FUNCTION
The converter series incorporates an over current
protection circuit. When the output current reaches a
value above typically 200% of it’s full-rated current, the
converter falls into hiccup mode by testing periodically if
an overload is applied. The module restarts automatically
to normal operation when overcurrent is removed.
International Headquarters
GAÏA Converter - France
18 rue caroline Aigle
33186 LE HAILLAN - FRANCE
Tel. : + (33)-5-57-92-12-80
Fax : + (33)-5-57-92-12-89
5/5
North American Headquarters
GAÏA Converter Canada, Inc
4038 Le Corbusier Blvd
LAVAL, QUEBEC - CANADA H7L 5R2
Tel. : (514)-333-3169
Fax : (514)-333-4519
很抱歉,暂时无法提供与“MGDBK10HC”相匹配的价格&库存,您可以联系我们找货
