MGDK04 4W POWER
WIDE INPUT RANGE ISOLATED DC/DC CONVERTER
0.3’’ LOW PROFILE
Description
The MGDK04 series features a Quality Cost Effective range of 4W board mounted isolated dc/dc
converters. With multiple selection of wide input voltage ranges, the MGDK04 is proposed with a single
symmetrical or triple output channel. The converter embeds an output short circuit protection, and
comes encapsulated in a low profile fully potted DIL 24 compliant metallic case.
Fields of Application
General purpose application
Transportation
Telecom
Renewable Energy
Part-numbering
MGD S K 04 H C
output nb.
S = single
B = double
T = Triple
Input range
Output
C = 4.5-5.5
H = 9-36
I = 18-36
Q = 36-140
B = 3.3
C=5
E = 12
F = 15
Selection Guide
Part Number
Part Number
Output
Voltage
(Vdc)
Output
Power
(Watt)
Output Current
(Adc)
0.8
MGDBK04CE
+/-12
4
+/-0.165
4
0.8
MGDSK04HF
15
4
0.26
+/-5
4
+/-0.4
MGDTK04ICF
+5 +/-15
4
0.4 +/-0.06
MGDSK04CF
15
4
0.26
MGDSK04QC(Y)
5
4
0.8
MGDBK04CE
+/-12
4
+/-0.165
MGDSK04QE(Y)
12
4
0.33
MGDBK04CF
+/-12
4
+/-0.165
MGDSK04QF(Y)
15
4
0.26
MGDSK04HB
3.3
3.3
1
MGDSK04HC
5
4
0.8
MGDSK04HE
12
4
0.33
Output
Voltage
(Vdc)
Output
Power
(Watt)
Output Current
(Adc)
MGDSK04CC(Y)
5
4
MGDSK04CC
5
MGDBK04CC
/Y = High isolation option
for more information go to https://www.gaia-converter.com
FC19-096.01/21 Revision C
1/5
WWW.GAIA-CONVERTER.COM
MGDK04 4W POWER
1-ELECTRICAL SPECIFICATIONS
Specification
Data are valid at +25°C, unless otherwise
specified
Parameter
Conditions
Limit
Units
C input
H input
I input
Q input
Nominal Input Voltage
(Ui nom)
Full temperature
range
Nominal
Vdc
5
72
Input Voltage range
Full temperature
range
Min.-Max.
Vdc
4.5-5.5
9-36
18-36
36-140
Transient Input Voltage
Full temperature
range
Maximum
Vdc/s
5.5/1
36/1
36/1
175/0.1
Start up input voltage
Full temperature
range
Maximum
Vdc
8.5
15.5
33
Ui Nominal 75% load
Typical
Ui nominal
(hic-up mode)
Maximum
mA
30
Set Point accuracy
Ui nom @75% load
Maximum
+/- 2
Output regulation
(Line)
25% to full load
Maximum
+/- 1.5
Output regulation
(Load)
Ui min. To Ui max
25% to full load
0% to 25% load
Maximum
Typical
+/- 2.5
+20 to +/-2.5
INPUT
Power efficiency
Input current in short
circuit mode (Average)
80
30
OUTPUT
Minimum 10% load is recommended, operation with no load during more
than 1s may partially damage the converter output.
Output ripple voltage
B output (3V3)
C output (5V)
E output (12V)
F output (15V)
Admissible capacitor
B output (3V3)
C output (5V)
E output (12V)
F output (15V)
Ui min. To Ui max
Ui min. Full load
( per output)
Typical
Maximum
150
150
300
450
mVpp
500
500
47
47
µF
MISCELLANEOUS
Switching Frequency
Isolation Strength
(Input output)
EMC Compliance
2/5
Khz
regular model
/Y option model
Vdc
With input capacitor
With input filter
480
480
480
1500
3000
EN555032 class A
EN555032 class B
430
MGDK04 4W POWER
2-THERMAL & MECHANICAL SPECIFICATIONS
Parameter
Conditions
Case temperature range
Storage temperature range
Not operating
Case Material
Limit
Units
Parameter
Mini.Max.
°C
-40 to 95
Mini.Max.
°C
Regular model
/Y model
110
Metallic black anodized coated
Black plastic
Pin Material
Copper plated with pure matte tin over nickel
underplate
Case to Air thermal resistance
Typical
°C/W
Connections
Pin#
MGDSK04
(Single)
+Input (Vi)
1
+Input (Vi)
2
10
Common (Go)
11
Common (Go)
12
Output (Vo)
13
Output (Vo)
14
15
On/off *
-Input (Gi)
23
-Input (Gi)
24
* Pin not available for Q
MGDBK04
(Double)
MGDTK04
(Triple)
+Input (Vi)
+Input (Vi)
Common (Go)
Common (Go)
Output-(-Vo)
Output+(+Vo)
On/off *
-Input (Gi)
-Input (Gi)
+Input (Vi)
+Input (Vi)
Common (Go)
Common (Go)
Output2(-V2)
Output1(V1)
Output2 (+V2)
On/off *
-Input (Gi)
-Input (Gi)
White dot on top
side
input range models
Dimension MGDSK04 & MGDBK04 serie (C,H,I input)
Dimension are given in mm (inches) . Tolerance : +/-0.25mm (0.01’’) unless otherwise specified
weight : < 15gr (0.5oz) max.
Metallic case
Plastic case
Dimension MGDTK04 serie, & Q input serie
Metallic case
3/5
Plastic case
MGDK04 4W POWER
3-APPLICATION
Typical connections
Input and output capacitor values are given as example of min values
ON-OFF FUNCTION
The converter is naturally enabled as far as the on/off
pin remains unconnected. To disable the converter the
pin on/off should be shorted to Go using a switch, an
open collector or open drain transistor. Several
converters of the same input bus can be remotely
controlled by the same signal just by connecting all the
pins on/off together.
4/5
MGDK04 4W POWER
3-APPLICATION (continued)
OCP FUNCTION
The converter series incorporates an over current
protection circuit. When the output current reaches a
value above typically 200% of it’s full-rated current, the
converter falls into hiccup mode by testing periodically if
an overload is applied. The module restarts automatically
to normal operation when overcurrent is removed.
International Headquarters
GAÏA Converter - France
18 rue caroline Aigle
33186 LE HAILLAN - FRANCE
Tel. : + (33)-5-57-92-12-80
Fax : + (33)-5-57-92-12-89
5/5
North American Headquarters
GAÏA Converter Canada, Inc
4038 Le Corbusier Blvd
LAVAL, QUEBEC - CANADA H7L 5R2
Tel. : (514)-333-3169
Fax : (514)-333-4519
很抱歉,暂时无法提供与“MGDBK04QF”相匹配的价格&库存,您可以联系我们找货
