PU-2W SERIES
2W UNREGULATED
FEATURES
SINGLE IN LINE PACKAGE
2W UNREGULATED OUTPUT POWER
100% BURN IN
HIGH EFFICIENCY
INTERNAL SMD TECHNOLOGY
LOW COST
NO HEATSINK REQUIRED
UL 94V-0 PACKAGE MATERIAL
CUSTOM SOLUTIONS AVAILABLE
RoHS COMPLIANT
3 YEARS WARRANTY
OUTPUT SPECIFICATIONS
Voltage Set-point Accuracy
Temperature Coefficient
1
Ripple & Noise(20MHz BW)
2
Line Regulation
3
Load Regulation
Minimum Load
Short Circuit Protection
INPUT SPECIFICATIONS
+/-2% max Input Voltage Range
+/-10% max
+/-0.05%/°C Input Filter
Capacitor Type
100mVp-p max Protection
Fuse Recommended
+/-1.2% max
+/-8% max
GENERAL SPECIFICATIONS
10% of Full Load Efficiency
70%-85%
4
Momentary Isolation Voltage
1500 VDC min
Standard Models
3000 VDC min
Suffix “D” Models
9
Isolation Resistance
10 ohms min
Isolation Capacitance
80pF max
Switching Frequency
100KHz min
5
>1,800,000 Hours
Weight
2.3g Typ
MTBF
ENVIRONMENTAL SPECIFICATIONS
Operating Temperature
Storage Temperature
Humidity
Cooling
-40 °C to +71 °C Case Material
-55 °C to +125 °C Case Size
Non-Conductive Plastic
19.6mm*7.1mm*10.2mm
95% max Conducted Emissions
Free-Air Convection Radiated Emissions
EN55022 Class A
EN55022 Class B
ALL SPECIFICATIONS TYPICAL AT NOMINAL LINE, FULL LOAD AND 25 OC UNLESS OTHERWISE NOTED.
1
2
3
4
5
Measured with 1uF ceramic capacitor connect to the output pins.
Line Regulation is for a 1.0% change in input Voltage.
Load Regulation is for output load current change from 20% to 100%.
1500VDC for 10 seconds,3000VDC for 3 seconds.
MIL-HDBK-217F @25 °C , Ground Benign.
DANUBE
http://www.danube.com.tw
7-1
2012/05/25
SELECTION GUIDE(1)
2W OUTPUT
6
INPUT
INPUT
OUTPUT
OUTPUT
MODEL
CURRENT(mA)
EFF
VOLTAGE VOLTAGE CURRENT
NUMBER
(VDC)
(VDC)
(mA)
FULL
NO
LOAD
LOAD
7
ISOLATION
PACKAGE
(VDC)
PUS-03.305-2W
3.3
5
400
782
65
78
1500
C
PUS-03.324-2W
3.3
24
84
782
65
78
1500
C
PUS-0503.3-2W
5
3.3
500
452
60
73
1500
C
PUS-0505-2W
5
5
400
520
60
77
1500
C
PUS-0509-2W
5
9
222
506
60
79
1500
C
PUS-0512-2W
5
12
167
500
60
80
1500
C
PUS-0515-2W
5
15
133
488
60
82
1500
C
3.3
+/-15
+/-67
740
65
82
1500
C
PUD-0505-2W
5
+/-5
+/-200
488
60
82
1500
C
PUD-0512-2W
5
+/-12
+/-84
500
60
80
1500
C
PUD-0515-2W
5
+/-15
+/-67
488
60
82
1500
C
PUD-0524-2W
5
+/-24
+/-42
504
60
79
1500
C
PUS-1203.3-2W
12
3.3
500
185
15
74
1500
C
PUS-1205-2W
12
5
400
214
15
78
1500
C
PUS-1209-2W
12
9
222
214
15
78
1500
C
PUS-1212-2W
12
12
167
200
15
83
1500
C
PUS-1215-2W
12
15
133
196
15
85
1500
C
PUD-1205-2W
12
+/-5
+/-200
214
15
78
1500
C
PUD-1212-2W
12
+/-12
+/-84
200
17
83
1500
C
PUD-1215-2W
12
+/-15
+/-67
196
15
85
1500
C
PUS-2403.3-2W
24
3.3
500
92
15
74
1500
C
PUS-2405-2W
24
5
400
107
15
78
1500
C
PUS-2409-2W
24
9
222
107
15
78
1500
C
PUS-2412-2W
24
12
167
104
15
80
1500
C
PUS-2415-2W
24
15
133
101
15
83
1500
C
PUD-2405-2W
24
+/-5
+/-200
107
15
78
1500
C
PUD-2412-2W
24
+/-12
+/-84
103
15
81
1500
C
PUD-2415-2W
24
+/-15
+/-67
103
15
81
1500
C
PUD-03.315-2W
Note: Other input to output voltages may be available. Please contact factory.
ORDERING INFORMATION:
FOR EXAMPLE:
PUS-****-2W(2W SINGLE OUTPUT)
PUD-****-2W(2W DUAL OUTPUT)
6
7
NOMINAL INPUT VOLTAGE.
NOMINAL INPUT VOLTAGE, FULL LOAD.
DANUBE
7-2
2012/05/25
SELECTION GUIDE(2)
2W OUTPUT
8
INPUT
INPUT
OUTPUT
OUTPUT
MODEL
CURRENT(mA)
EFF
NUMBER
(VDC)
(VDC)
(mA)
FULL
NO
LOAD
LOAD
9
ISOLATION
PACKAGE
(VDC)
PUS-0503.3D-2W
5
3.3
500
452
60
73
3000
D
PUS-0505D-2W
5
5
400
520
60
77
3000
D
PUS-0509D-2W
5
9
222
510
60
78
3000
D
PUS-0512D-2W
5
12
167
500
60
80
3000
D
PUS-0515D-2W
5
15
133
492
60
81
3000
D
PUD-0505D-2W
5
+/-5
+/-200
520
60
77
3000
D
PUD-0509D-2W
5
+/-9
+/-111
512
60
78
3000
D
PUD-0512D-2W
5
+/-12
+/-84
500
60
80
3000
D
PUD-0515D-2W
5
+/-15
+/-67
488
60
82
3000
D
PUS-1203.3D-2W
12
3.3
500
185
15
74
3000
D
PUS-1205D-2W
12
5
400
210
15
79
3000
D
PUS-1209D-2W
12
9
222
210
15
79
3000
D
PUS-1212D-2W
12
12
167
205
15
81
3000
D
PUS-1215D-2W
12
15
133
200
15
83
3000
D
PUD-1205D-2W
12
+/-5
+/-200
214
15
78
3000
D
PUD-1212D-2W
12
+/-12
+/-84
203
15
82
3000
D
PUD-1215D-2W
12
+/-15
+/-67
200
15
83
3000
D
PUD-1218D-2W
12
+/-18
+/-55
199
3000
D
PUS-2403.3D-2W
24
3.3
500
92
15
74
3000
D
PUS-2405D-2W
24
5
400
108
15
77
3000
D
PUS-2409D-2W
24
9
222
108
15
77
3000
D
PUS-2412D-2W
24
12
167
104
15
80
3000
D
PUS-2415D-2W
24
15
133
102
15
82
3000
D
PUD-2405D-2W
24
+/-5
+/-200
107
15
78
3000
D
PUD-2412D-2W
24
+/-12
+/-84
103
15
81
3000
D
PUD-2415D-2W
24
+/-15
+/-67
102
15
81
3000
D
FOR EXAMPLE:
PUS-****D-2W(2W SINGLE OUTPUT)
PUD-****D-2W(2W DUAL OUTPUT)
8
9
DANUBE
7-3
2012/05/25
MECHANICAL DIMENSIONS &
RECOMMENDED FOOTPRINT DETAILS
PACKAGE ”C”
19.6[0.77]
FRONT
VIEW
10.14[0.40]
3.81[0.15]
2.54[0.10]
7.1[0.28]
SINGLE
DUAL
1
+Vin
+Vin
2
-Vin
-Vin
4
-Vout
-Vout
5
NP
COMMON
6
+Vout
+Vout
NOTE : All Dimensions In mm(Inches)
BOTTOM VIEW
1 2
PIN
1. Pin Size is 0.50x0.30mm[0.02x0.01”]
4 5 6
2. Pin is Tolerance .XX= ±0.05mm
3. Tolerance .X
1.2[0.05]
or
.XX= ±0.5mm
SINGLE
OUTPUT
2.54mm
TOP VIEW
1 2
4
DUAL
OUTPUT
2.54mm
2.54mm
All dimensions are in mm[inches]
2.54mm
TOP VIEW
6
4 5 6
1 2
PACKAGE ”D”
19.6[0.77]
FRONT
VIEW
10.14[0.40]
3.81[0.15]
2.54[0.10]
7.1[0.28]
SINGLE
DUAL
1
+Vin
+Vin
2
-Vin
-Vin
5
-Vout
-Vout
6
NP
COMMON
7
+Vout
+Vout
BOTTOM VIEW
1 2
PIN
5 6 7
3. Tolerance .X
1.2[0.05]
or
.XX= ±0.5mm
SINGLE
OUTPUT
TOP VIEW
1 2
5
DANUBE
7
DUAL
OUTPUT
2.54mm
TOP VIEW
1 2
2.54mm
2.54mm
2.54mm
5 6 7
7-4
2012/05/25
SIMPLIFIED SCHEMATIC
SINGLE OUTPUT
DUAL OUTPUT
+Vin
+Vin
+Vout
OSCILLATOR
DRIVER
+Vout
OSCILLATOR
DRIVER
-Vout
COMMON
-Vin
-Vin
-Vout
TYPICAL APPLICATIONS
SINGLE OUTPUT
INPUT
OUTPUT
+Vin
DUAL OUTPUT
INPUT
+Vout
OUTPUT
+Vin
+Vout
LOAD1
DC-DC
CONVERTER
LOAD
DC-DC
CONVERTER
-Vin
Common
-Vin
-Vout
LOAD2
-Vout
TYPICAL PERFORMANCE CURVES
Specifications typical at TA=25 OC,nominal input voltage , rated output current unless otherwise specified.
VOUT VS LOAD(5Vout Models)
4.2
6.4
3.9
6.0
Vout(V)
Vout(V)
VOUT VS LOAD(3.3Vout Models)
3.6
3.3
5.6
5.2
3.0
4.8
250
375
500
Output Current(mA)
6.0
10.0
Vout(V)
Vout(V)
10.4
5.6
9.6
5.2
9.2
4.8
8.8
+/-100
+/-150
Output Current(mA)
DANUBE
400
VOUT VS LOAD(9Vout Models)
6.4
+/-50
300
Output Current(mA)
VOUT VS LOAD(+/- 5Vout Models)
+/-200
111
167
222
Output Current(mA)
7-5
2012/05/25
VOUT VS LOAD(+/- 12Vout Models)
13.5
13.5
13.0
13.0
Vout(V)
Vout(V)
VOUT VS LOAD(12Vout Models)
12.5
12.5
12.0
12.0
11.5
11.5
84
126
167
Output Current(mA)
16.0
16.0
Vout(V)
Vout(V)
16.5
15.5
+/-84
15.5
15.0
15.0
14.5
14.5
67
+/-63
VOUT VS LOAD(+/- 15Vout Models)
16.5
34
+/-42
Output Current(mA)
VOUT VS LOAD(15Vout Models)
101
133
Output Current(mA)
+/-17
+/-34
+/-52
+/-67
Output Current(mA)
DERATING CURVES
EFFICIENCY VS LOAD
100 %
75%
EFFICIENCY(%)
OU TPUT POW ER(%)
125 %
SA F E
O P E R AT IN G
A R EA
50%
25%
-40
-2 0
TA (d e gr ee C )
60
80
100
80.0
60.0
40.0
20.0
0.0
60
80
100
% OF RATED LOAD(%)
DANUBE
7-6
2012/05/25
INPUT FUSE SELECTION GUIDE
2.97-3.63V
4.5-5.5V
10.8-13.2V
21.6-26.4V
INPUT VOLTAGE (VDC)
INPUT VOLTAGE (VDC)
INPUT VOLTAGE (VDC)
INPUT VOLTAGE (VDC)
1200mA Slow-Blow Type
800mA Slow-Blow Type
300mA Slow-Blow Type
170mA Slow-Blow Type
INPUT
OUTPUT
Fuse
+Vin
+Vout
DC-DC
CONVERTER
-Vin
-Vout
Note: Certain applications may require the installation of external fuse in front of the input.
PU-2W SERIES APPLICATION NOTES:
EXTERNAL CAPACITANCE REQUIREMENTS:
Output filtering is required for operation. A minimum of 10uF is needed. Output capacitance may be
increased for additional filtering, not to exceed 220uF.
To meet the reflected ripple requirements of the converter, an input impedance of less than 0.5ohm
from DC to 250KHz is required.
We Can Offer EMC-Filter According To EN55011/22 Class B.
Negative Outputs:
A negative output voltage may be obtained by connecting the +OUT to circuit ground and
connecting –OUT as the negative output.
FOR MORE INFORMATION CALL:
Danube Enterprise Co., Ltd.
Tel: 886-7-3755165
Fax: 886-7-3755330
Home Page
DANUBE
E-mail: danube@ms10.hinet.net
7-7
2012/05/25
Additional Information :
한국 총판점 : ㈜디웰전자 (Diwell Electronics Co., Ltd.)
경기도 군포시 당정동 358 군포창업보육센터 202호
202, Kunpo Business Incubator Center, 358,
Dangjung-Dong, Gunpo-City, Gyeonggi-Do, South Korea
Phone : 070-8235-0820 (+82-70-8235-0820)
Fax
: 031-429-0821 (+82-31-429-0821)
Homepage: http:// www.diwell.com
기술 및 구매 문의 email : expoeb2@diwell.com,
dsjeong@diwell.com
很抱歉,暂时无法提供与“PUD-1205-2W”相匹配的价格&库存,您可以联系我们找货
