TU SERIES
1W UNREGULATED
FEATURES
DUAL IN LINE PACKAGE
1W UNREGULATED OUTPUT POWER
100% BURNED IN
HIGH EFFICIENCY
INTERNAL SMD TECHNOLOGY
LOW COST
NO HEATSINK REQUIRED
UL 94V-0 PACKAGE MATERIAL
CUSTOM SOLUTIONS AVAILABLE
1500VDC ISOLATION
RoHS COMPLIANT
3 YEARS WARRANTY
OUTPUT SPECIFICATIONS
Voltage Setpoint Accuracy
INPUT SPECIFICATIONS
+/-2% max Input Voltage Range
Temperature Coefficient
1
Ripple & Noise(20MHz BW)
2
Line Regulation
3
Load Regulation
Minimum Load
Short Circuit Protection
+/-10% max
+/-0.05%/ °C Input Filter
Capacitor Typ
100mVp-p max Protection
Fuse Recommended
+/-1.2% max Input Reflected Ripple Current
+/-8% max
50mAp-p max
GENERAL SPECIFICATIONS
10% of Full Load Efficiency
70%-82%
4
Momentary Isolation Voltage
1500 VDC min
9
Isolation Resistance
10 ohms min
Isolation Capacitance
80pF max
Switching Frequency
50KHz min
5
>2,000,000 Hours
Weight
2.2g Typ
MTBF
ENVIRONMENTAL SPECIFICATIONS
Operating Temperature
Case Temperature
-25 °C to +71 °C Case Material
+90°C max Case Size
Storage Temperature
-55 °C to +125 °C Conducted Emissions
Humidity
Cooling
Non-Conductive Plastic
20.3mm*10.2mm*7.1mm
95% max Radiated Emissions
EN55022 Class A
EN55022 Class A
Free-Air Convection
ALL SPECIFICATIONS TYPICAL AT NOMINAL LINE, FULL LOAD , AND 25 OC UNLESS OTHERWISE NOTED.
1
2
3
4
5
Measured with 1uF ceramic capacitor connect to the output pins.
Line Regulation is for a 1.0% change in input Voltage.
Load Regulation is for output load current change from 20% to 100%.
For 10 seconds.
MIL-HDBK-217F @25 °C , Ground Benign.
DANUBE
http://www.danube.com.tw
1
2011/06/28
SELECTION GUIDE
1W OUTPUT
MODEL
NUMBER
INPUT
OUTPUT
OUTPUT
VOLTAGE
VOLTAGE
CURRENT
(VDC)
(VDC)
(mA)
INPUT 6
CURRENT(mA) EFF
FULL
NO
PACKAGE
(%)7
LOAD LOAD
TUS-0505 (A or B)
5
5
200
274
35
73
A or B
TUS-0512 (A or B)
5
12
84
253
26
79
A or B
TUS-0515 (A or B)
5
15
67
253
28
79
A or B
TUD-0505A
5
+/-5
+/-100
274
26
73
A
TUD-0512A
5
+/-12
+/-42
253
26
79
A
TUD-0515A
5
+/-15
+/-34
253
28
79
A
TUD-0524A
5
+/-24
+/-21
257
28
78
A
TUS-1205 (A or B)
12
5
200
112
11
74
A or B
TUS-1212 (A or B)
12
12
84
102
11
82
A or B
TUS-1215 (A or B)
12
15
67
102
12
82
A or B
TUD-1205A
12
+/-5
+/-100
112
11
74
A
TUD-1212A
12
+/-12
+/-42
102
11
82
A
TUD-1215A
12
+/-15
+/-34
102
12
82
A
TUS-2405 (A or B)
24
5
200
57
8
73
A or B
TUS-2412 (A or B)
24
12
84
54
8
77
A or B
TUS-2415 (A or B)
24
15
67
52
7
80
A or B
TUD-2405A
24
+/-5
+/-100
57
8
73
A
TUD-2412A
24
+/-12
+/-42
54
8
77
A
TUD-2415A
24
+/-15
+/-34
54
9
77
A
Note: Other input to output voltages may be available. Please contact factory.
6
7
NOMINAL INPUT VOLTAGE.
NOMINAL INPUT VOLTAGE, FULL LOAD.
DANUBE
2
2011/06/28
MECHANICAL DIMENSIONS &
RECOMMENDED FOOTPRINT DETAILS
PACKAGE ”A”
BOTTOM VIEW
SIDE VIEW
3.81[0.15]
10.16[0.40]
14 1
15.24[0.60]
20.32[0.80]
11
9
8
7
2.54[0.10]
7.12[0.28]
7.62[0.30]
All dimensions are in millimeters[inches]
PIN
SINGLE
DUAL
1
-Vin
-Vin
7
NC
NC
8
-Vout
COMMON
9
+Vout
+Vout
11
NC
-Vout
14
+Vin
+Vin
NOTE : All Dimensions In mm(Inches)
1. Pin Size is 0.50x0.30mm[0.02x0.01”]
2. Pin is Tolerance .XX= ±0.05mm
3. Tolerance .X
or
.XX= ±0.5mm
PACKAGE ”B”
BOTTOM VIEW
SIDE VIEW
3.81[0.15]
10.16[0.40]
14 1
15.24[0.60]
20.32[0.80]
11
9
8
7
2.54[0.10]
PIN
SINGLE
1
-Vin
7
NC
8
NO PIN
9
+Vout
11
-Vout
14
+Vin
7.12[0.28]
7.62[0.30]
or
.XX= ±0.5mm
TOP VIEW
2.54mm
3. Tolerance .X
2.54mm
14
1
DANUBE
11
9 8
7
3
2011/06/28
SIMPLIFIED SCHEMATIC
SINGLE OUTPUT
DUAL OUTPUT
+Vin
+Vin
+Vout
OSCILLATOR
DRIVER
+Vout
OSCILLATOR
DRIVER
-Vout
COMMON
-Vin
-Vin
-Vout
TYPICAL APPLICATIONS
SINGLE OUTPUT
INPUT
OUTPUT
+Vin
DUAL OUTPUT
INPUT
+Vout
OUTPUT
+Vin
+Vout
LOAD1
DC-DC
CONVERTER
LOAD
DC-DC
CONVERTER
-Vin
Common
-Vin
-Vout
LOAD2
-Vout
TYPICAL PERFORMANCE CURVES
Specifications typical at TA=25 OC,nominal input voltage , rated output current unless otherwise specified.
VOUT VS LOAD(+/- 5Vout Models)
6.4
6.4
6.0
6.0
Vout(V)
Vout(V)
VOUT VS LOAD(5Vout Models)
5.6
5.6
5.2
5.2
4.8
4.8
100
150
200
Output Current(mA)
+/-25
+/-50
+/-75
+/-100
Output Current(mA)
VOUT VS LOAD(12Vout Models)
DANUBE
VOUT VS LOAD(+/- 12Vout Models)
4
2011/06/28
13.5
13.0
13.0
Vout(V)
Vout(V)
13.5
12.5
12.0
12.5
12.0
11.5
11.5
60
80
Output Current(mA)
+/-30
+/-40
VOUT VS LOAD(+/- 15Vout Models)
16.5
16.5
16.0
16.0
Vout(V)
Vout(V)
+/-20
Output Current(mA)
VOUT VS LOAD(15Vout Models)
15.5
15.0
15.5
15.0
14.5
14.5
30
45
60
Output Current(mA)
+/-7.5
+/-15
+/-22.5
+/-30
Output Current(mA)
DERATING CURVE
EFFICIENCY VS LOAD
125%
EFFICIENCY(%)
OUTPUT POWER(%)
+/-10
100%
SAFE
OPERATING
AREA
75%
50%
25%
80.0
60.0
40.0
20.0
0%
0.0
-25
50
70
100
TA(degree C)
60
80
100
% OF RATED LOAD(%)
INPUT FUSE SELECTION GUIDE
4.5-5.5V
10.8-13.2V
21.6-26.4V
INPUT VOLTAGE(VDC)
INPUT VOLTAGE(VDC)
INPUT VOLTAGE(VDC)
400mA Slow-Blow Type
200mA Slow-Blow Type
90mA Slow-Blow Type
INPUT
OUTPUT
Fuse
+Vin
+Vout
DC-DC
CONVERTER
-Vin
-Vout
Note: Certain applications may require the installation of external fuse in front of the input.
DANUBE
5
2011/06/28
TU SERIES APPLICATION NOTES:
EXTERNAL CAPACITANCE REQUIREMENTS:
Output filtering is required for operation. A minimum of 10uF is needed. Output capacitance may be
increased for additional filtering, not to exceed 220uF.
To meet the reflected ripple requirements of the converter, an input impedance of less than 0.5 ohm
from DC to 250KHz is required.
We Can Offer EMC-Filter According To EN55011/22 Class B.
Negative Outputs:
A negative output voltage may be obtained by connecting the +OUT to circuit ground and
connecting –OUT as the negative output.
FOR MORE INFORMATION CALL:
Danube Enterprise Co., Ltd.
Tel: 886-7-3755165
Fax: 886-7-3755330
Home Page
DANUBE
E-mail: danube@ms10.hinet.net
6
2011/06/28
很抱歉,暂时无法提供与“TUD-0512A”相匹配的价格&库存,您可以联系我们找货
