PRD-1205G
PRD-1205G
    DIWELL
    SIP5 模块
    隔离模块 直流转换器 2 输出 5V -5V 100mA,100mA 10.8V - 13.2V 输入
PRD-1205G 数据手册
PRD SERIES 1W REGULATED FEATURES             SINGLE IN LINE PACKAGE UP TO 1W REGULATED OUTPUT POWER 100% BURNED IN EFFICIENCY UP TO 60% INTERNAL SMD TECHNOLOGY NO EXTERNAL COMPONENTS REQUIRED LOW COST 1500VDC ISOLATION UL 94V-0 PACKAGE MATERIAL CUSTOM SOLUTIONS AVAILABLE RoHS COMPLIANT 3 YEARS WARRANTY OUTPUT SPECIFICATIONS Voltage Setpoint Accuracy +/-3% max Input Voltage Range Temperature Coefficient Ripple & Noise(20MHz BW) Line Regulation 1 2 +/-10% max +/-0.05%/°C Input Filter Capacitor Typ 100mVp-p max Protection Fuse Recommended +/-2% max 3 Load Regulation +/-2% max Minimum Load GENERAL SPECIFICATIONS 10% of Full Load Efficiency Short Circuit Protection Short Circuit Restart Transient Response INPUT SPECIFICATIONS 5 Current Limit Protection Isolation Voltage Humidity Cooling 9 10 ohms min 100uS max Isolation Capacitance 80pF max Switching Frequency 100KHz min ENVIRONMENTAL SPECIFICATIONS Storage Temperature 1500VDC min Automatic Isolation Resistance MTBF Operating Temperature 50% min 4 6 >1,800,000 Hours Weight -25 °C to +71 °C Case Material -55 °C to +125 °C Case Size 2.3g Typ Non-Conductive Plastic 19.6mm*7.5mm*10.2mm 95% max Conducted Emissions Free-Air Convection Radiated Emissions EN55022 Class A EN55022 Class A ALL SPECIFICATIONS TYPICAL AT NOMINAL LINE, FULL LOAD , AND 25°C UNLESS OTHERWISE NOTED. 1 2 3 4 5 6 Measured with 1uF ceramic capacitor connect to the output pins. High Line to Low Line. Load Regulation is for output load current change from 10% to 100%. 1500VDC for 10 seconds 25% Step Load Change. MIL-HDBK-217F @25 °C , Ground Benign. DANUBE http://www.danube.com.tw 5-1 2015/11/30  SELECTION GUIDE 1W OUTPUT 1500VDC ISOLATION MODEL NUMBER INPUT OUTPUT OUTPUT VOLTAGE VOLTAGE CURRENT (VDC) (VDC) (mA) INPUT CURRENT(mA) EFF ISOLATION FULL NO LOAD LOAD (%) (VDC) OUTPUT POWER (Watt) PRD-0505G 4.5-5.5 +/-5 +/-100 350 35 57 1500 1 PRD-0512G 4.5-5.5 +/-12 +/-42 350 50 57 1500 1 PRD-0515G 4.5-5.5 +/-15 +/-34 350 60 57 1500 1 PRD-1205G 10.8-13.2 +/-5 +/-100 141 20 59 1500 1 PRD-1215G 10.8-13.2 +/-15 +/-34 134 30 62 1500 1 PRD-2405G 21.6-26.4 +/-5 +/-100 70 5 60 1500 1 PRD-2412G 21.6-26.4 +/-12 +/-42 70 40 60 1500 1 Note: Other input to output voltages may be available. Please contact factory. DANUBE http://www.danube.com.tw 5-2 2015/11/30  MECHANICAL DIMENSIONS & RECOMMENDED FOOTPRINT DETAILS PACKAGE ”G” 19.6[0.77] FRONT VIEW PIN DUAL 1 +Vin 2 -Vin 5 -Vout 6 Common 7 +Vout 10.2[0.40] 3.81[0.15] 5.08[0.20] 2.54[0.10] 7.5[0.30] NOTE : All Dimensions In mm(Inches) BOTTOM VIEW 1 2 1. Pin Size is 0.50x0.30mm[0.02x0.01”] 5 6 7 2.18[0.086] 2. Pin is Tolerance .XX= ±0.05mm 3. Tolerance .X 1.2[0.05] or .XX= ±0.5mm All dimensions are in mm[inches]  SIMPLIFIED SCHEMATIC  TYPICAL APPLICATIONS INPUT +Vin REGULATOR +Vout OSCILLATOR DRIVER +Vin REGULATOR Common DC-DC CONVERTER -Vin DANUBE +Vout LOAD1 Com. -Vout -Vin OUTPUT LOAD2 -Vout http://www.danube.com.tw 5-3 2015/11/30  TYPICAL PERFORMANCE CUREVES Specifications typical at ta=25 °C,nominal input voltage , rated output current unless otherwise specified. EFFICIENCY VS LOAD 125% EFFICIENCY(%) OUTPUT POWER(%) DERATING CURVE 100% SAFE OPERATING AREA 75% 50% 25% 80.0 60.0 40.0 20.0 0% 0.0 -25 0 25 50 70 100 0 TA(degree C) 20 40 60 80 100 %OF RATED LOAD(%)  INPUT FUSE SELECTION GUIDE 4.5-5.5V 10.8-13.2V 21.6-26.4V INPUT VOLTAGE(VDC) INPUT VOLTAGE(VDC) INPUT VOLTAGE(VDC) 500mA Slow-Blow Type 250mA Slow-Blow Type INPUT 100mA Slow-Blow Type OUTPUT Fuse +Vin +Vout DC-DC CONVERTER -Vin -Vout Note: Certain applications may require the installation of external fuse in front of the input. DANUBE http://www.danube.com.tw 5-4 2015/11/30 PRD SERIES APPLICATION NOTES: EXTERNAL CAPACITANCE REQUIREMENTS: No external capacitance is required for operation of the PRD series. To meet the reflected ripple requirements of the converter, an input impedance of less than 0.5 ohm from DC to 250KHz is required. External output capacitance is not required for operation, however it is recommended that 10uF tantalum and 0.1uF ceramic capacitance be selected for reduced system noise. Additional output capacitance may be added for increased filtering, but should not exceed 100uF. We Can Offer EMC-Filter According To EN55011/22 Class B. Negative Outputs: A negative output voltage may be obtained by connecting the +OUT to circuit ground and connecting –OUT as the negative output. FOR MORE INFORMATION CALL: Danube Enterprise Co., Ltd. Tel: 886-7-3755165 Fax: 886-7-3755330 Home Page http://www.danube.com.tw DANUBE E-mail: danube@ms10.hinet.net http://www.danube.com.tw 5-5 2015/11/30
PRD-1205G 价格&库存
很抱歉,暂时无法提供与“PRD-1205G”相匹配的价格&库存,您可以联系我们找货
