RM590L152B-TR
RM590L152B-TR
    NISSHINBO(日清纺)
    LQFN8
    降压 开关稳压器 IC 正 固定 1.5V 1 输出 400mA 8-LQFN
RM590L152B-TR 数据手册
RM590L Series 400mA Synchronous Step-down DC/DC Module with MODE pin and Inductor No.EA-592-210906 OVERVIEW The RM590L is a synchronous, step-down DC/DC converter which delivers up to 400mA of output current. The RM590L can be configured for either PWM/VFM automatic shift operation or forced PWM operation by controlling of MODE pin. It has a built-in inductor and is available in 2.2 (mm) x 2.0 (mm) x 1.5 (mm) sized QFN2220-8 package for high density mounting. Therefore, it is possible to save space in the mounting area. KEY BENEFITS ● Having an inductor built-in, it is possible to simplify the board design and reduce the mounting area. ● PWM/VFM automatic shift operation provides high efficiency at light loads. ● Having an inductor built-in, the number of parts can be reduced, and the man-hours for managing purchased parts can be reduced (concern about EOL). • • • • • • • • Input Voltage Range (Maximum Rating): 2.3 V to 5.5 V (6.5 V) Output Voltage (Fixed Output Voltages): from 0.6V to 3.3V in 0.1V increments ±1.5% (VSET ≥ 1.2 V), ±18 mV (VSET < 1.2 V) Output Voltage Accuracy Output Voltage (Adjustable Output Voltages): 0.6 V to 5.5 V 0.6V Reference (VFB), ±9 mV Voltage Accuracy Selectable Oscillator Frequency: Typ. 6.0 MHz Oscillator Maximum Duty: Min. 100% MOSFET ON Resistance (VIN = 3.6 V): High Side MOSFET Typ. 0.245 Ω Low Side MOSFET Typ. 0.225 Ω UVLO Detector Threshold: Typ. 2.0 V Soft-start Time: Typ. 0.15 ms Thermal Shutdown Function: Detection Temperature 140°C Release Temperature 100°C Efficiency VOUT=1.8V 100 90 VFM / PWM Auto 80 70 Efficiency η [%] • TYPICAL CHARACTERISTICS KEY SPECIFICATIONS 60 40 30 20 10 0 0.01 0.1 1 10 100 1000 Output Current IOUT [mA] TYPICAL APPLICATIONS VIN LX VIN CIN MODE Control VOUT L1 L2 COUT MODE VOUT RM590L CE GND CE Control Fixed Output Voltage Type (RM590Lxx2A/B) VIN PACKAGE Forced PWM VIN = 3.6V VIN ==2.7V VIN 2.7V VIN ==3.6V VIN 3.6V VIN ==4.2V VIN 4.2V VIN ==5.0V VIN 5.0V 50 LX VIN VOUT L1 L2 R1 CIN MODE Control QFN2220-8 2.2 x 2.0 x 1.5 (mm) MODE VFB RM590L CE C1 COUT R2 GND CE Control Adjustable Output Voltage Type (RM590L002C/D) APPLICATIONS • • • • Devices need to be miniaturized such as wearables, hearables Phones, domestic LAN systems Communication modules, and applications for Industrial equipment Instrumentation equipment such as flow meters and pressure gauges 1 RM590L No.EA-592-210906 SELECTION GUIDE The set output voltage, the output voltage type, and the auto-discharge function are user-selectable options. Selection Guide Product Name Package Quantity per Reel Pb Free Halogen Free RM590Lxx2$-TR QFN2220-8 2,000 Yes Yes xx:Set Output Voltage (VSET) Fixed Output Voltage Type:06 to 33 (0.6 V to 3.3 V, 0.1 V steps) The voltage in 0.05 V step is shown as follows. Ex. 1.25 V: RM590L122$5 Refer to Product-specific Electrical Characteristics for details. Adjustable Output Voltage Type:00 $ :Versions $ A B C D Output Voltage Type Fixed Adjustable Auto-discharge Function No Yes No Yes VSET 0.6 V to 3.3 V 0.6 V to 5.5 V 2 RM590L No.EA-592-210906 BLOCK DIAGRAMS RM590Lxx2A/B (Fixed Output Voltage Type) L2 L1 UVLO MODE Mode Control Slope Generator Vref Thermal Protection On Time Control Hi Side Current Detector VIN Switching Control LX Comp. Soft Start Amp. VOUT Low Side Current Detector CE GND Enable Control RM590Lxx2A Block Diagram L2 L1 UVLO MODE Mode Control Slope Generator Vref Thermal Protection On Time Control Hi Side Current Detector VIN Switching Control LX Comp. Soft Start Amp. VOUT Low Side Current Detector CE GND Enable Control RM590Lxx2B Block Diagram 3 RM590L No.EA-592-210906 RM590L002C/D (Adjustable Output Voltage Type) L2 L1 UVLO MODE Mode Control Slope Generator Vref Thermal Protection On Time Control Hi Side Current Detector VIN Switching Control LX Comp. Soft Start Amp. VFB Low Side Current Detector CE GND Enable Control RM590L002C Block Diagram L2 L1 UVLO MODE Mode Control Slope Generator Vref Thermal Protection On Time Control Hi Side Current Detector VIN Switching Control LX Comp. Soft Start Amp. VFB Low Side Current Detector CE GND Enable Control RM590L002D Block Diagram 4 RM590L No.EA-592-210906 PIN DESCRIPTIONS Top View 7 6 Bottom View 5 5 8 4 4 3 1 2 6 7 8 2 1 3 RM590L(QFN2220-8)Pin Configuration RM590L (QFN2220-8) Pin Descriptions Pin No. Symbol I/O Description Output/Feedback Pin Fixed Output Voltage Type: Connect to VOUT pin and L2 pin. Adjustable Output Voltage Type: Receives the feedback voltage from a 1 VOUT/VFB I Resistive divider connected across the output. Refer to “Adjustable Output Voltage Setting” Switch Node Connection to the Inductor. This pin connects to the drains of the internal Main and synchronous 2 LX O power MOSFET switches. Mode Select Input. To select forced PWM, connect this pin to a voltage above designated "High". 3 MODE I Connecting this pin to a voltage between 0 V and designated "Low" selects PWM/VFM automatic shift operation mode. Inductor Pin 1 (Input pin of inductor built-in.) 4 L1 I Connect this pin to Lx pin. Power Input Supply. 5 VIN I Decouple this pin to GND with a capacitor. Forcing this pin below designated "Low" level shuts down the RM590L. In shutdown all functions are disabled except auto discharge function. 6 CE I (option) Ground Pin 7 GND I Inductor Pin 2 (This pin connects to built-in inductor) 8 L2 O Connect a capacitor between this pin and GND. 5 RM590L No.EA-592-210906 ABSOLUTE MAXIMUM RATINGS Symbol VIN VLX VCE VMODE VOUT/VFB ILX PD Item Input Voltage LX / L1 / L2 Pin Voltage CE Pin Voltage MODE Pin Voltage VOUT / VFB Pin Voltage LX / L1 / L2 Pin Input / Output Current Power Dissipation Ratings −0.3 to 6.5 −0.3 to VIN +0.3 −0.3 to 6.5 −0.3 to 6.5 −0.3 to 6.5 1.6 Unit V V V V V A Refer to Appendix "POWER DISSIPATION" Tj Junction Temperature Range −40 to 125 °C Tstg Storage Temperature Range −55 to 125 °C ABSOLUTE MAXIMUM RATINGS Electronic and mechanical stress momentarily exceeded absolute maximum ratings may cause permanent damage and may degrade the lifetime and safety for both device and system using the device in the field. The functional operation at or over these absolute maximum ratings are not assured. ELECTROSTATIC DISCHARGE (ESD) RATINGS Symbol VHBM VCDM Conditions HBM C = 100pF, R = 1.5kΩ CDM Ratings -750 / +2000 ± 1000 Unit V V ELECTROSTATIC DISCHARGE RATINGS The electrostatic discharge test is done based on JESD47. In the HBM method, ESD is applied using the power supply pin and GND pin as reference pins. RECOMMENDED OPERATING CONDITIONS Symbol VIN Ta Item Input Voltage Operating Temperature Range Ratings 2.3 to 5.5 −40 to 85 Unit V °C RECOMMENDED OPERATING CONDITIONS All of electronic equipment should be designed that the mounted semiconductor devices operate within the recommended operating conditions. The semiconductor devices cannot operate normally over the recommended operating conditions, even if they are used over such ratings by momentary electronic noise or surge. And the semiconductor devices may receive serious damage when they continue to operate over the recommended operating conditions. 6 RM590L No.EA-592-210906 ELECTRICAL CHARACTERISTICS The specifications surrounded by are guaranteed by design engineering at -40°C ≤ Ta ≤ 85°C. RM590Lxx2A/B Electrical Characteristics Symbol VOUT (Ta = 25°C) Parameter Output Voltage Conditions Min. Typ. VIN = VCE = 3.6 V VSET ≥ 1.2 V x 0.985 (VSET ≤ 2.6 V), VIN = VCE = VSET + 1 V VSET < 1.2 V −0.018 (VSET > 2.6 V) fOSC Oscillator Frequency VIN = VCE = 3.6 V, VSET = 1.8 V, "Closed Loop Control" IDD Supply Current VIN = VCE = VOUT = 3.6 V, VMODE = 0 V 4.8 Max. Unit x 1.015 V +0.018 6.0 7.2 MHz µA 15 Standby Current VIN = 5.5 V, VCE = 0 V 0 5 µA ICEH CE "High" Input Current VIN = VCE = 5.5 V −1 0 1 µA ICEL CE "Low" Input Current VIN = 5.5 V, VCE = 0 V −1 0 1 µA IMODEH MODE "High" Input Current VIN = VMODE = 5.5 V, VCE = 0 V −1 0 1 µA IMODEL MODE "Low" Input Current VIN = 5.5 V, VCE = VMODE = 0 V −1 0 1 µA IVOUTH VOUT "High" Input Current VIN = VOUT = 5.5 V, VCE = 0 V −1 0 1 µA IVOUTL VOUT "Low" Input Current VIN = 5.5 V, VCE = VOUT = 0 V −1 0 1 µA RDISTR Auto-discharge MOSFET On-resistance ( 1) VIN = 3.6 V, VCE = 0 V ILXLEAKH LX "High" Leakage Current VIN = VLX = 5.5 V, VCE = 0 V −1 0 5 µA ILXLEAKL LX "Low" Leakage Current VIN = 5.5 V, VCE = VLX = 0 V −5 0 1 µA VCEH CE "High" Input Voltage VIN = 5.5 V 1.0 VCEL ISTANDBY Ω 40 V CE "Low" Input Voltage VIN = 2.3 V VMODEH MODE "High" Input Voltage VIN = VCE = 5.5 V VMODEL MODE "Low" Input Voltage VSET ≤ 2.3 V, VIN = VCE = 2.3 V VSET > 2.3 V, VIN = VSET RONP On-resistance of High Side MOSFET VIN = 3.6 V, ILX = −100 mA 0.245 Ω RONN On-resistance of Low Side MOSFET VIN = 3.6 V, ILX = −100 mA 0.225 Ω Maxduty Maximum Duty Cycle 0.4 1.0 V V 0.4 V % 100 tSTART Soft-start Time VIN = VCE = 3.6 V (VSET ≤ 2.6 V), VIN = VCE = VSET + 1 V (VSET > 2.6 V) ILXLIM LX Current Limit VIN = VCE = 3.6 V (VSET ≤ 2.6 V), VIN = VCE = VSET + 1 V (VSET > 2.6 V) 600 1000 VIN = VCE, Falling 1.85 2.00 2.20 V 1.90 2.05 2.25 V VUVLO1 VUVLO2 UVLO Threshold Voltage VIN = VCE, Rising 150 300 µs mA All test items listed under Electrical Characteristics are done under the pulse load condition (Tj ≈ Ta = 25°C). Test circuit is operated with “Open Loop Control” (GND = 0 V), unless otherwise specified. (1) RM590Lxx2B only 7 RM590L No.EA-592-210906 The specifications surrounded by are guaranteed by design engineering at -40°C ≤ Ta ≤ 85°C. RM590L002C/D Electrical Characteristics Symbol VFB (Ta = 25°C) Parameter Conditions Feedback Voltage VIN = VCE = 3.6 V fOSC Oscillator Frequency VIN = VCE = 3.6 V, VSET = 1.8 V, "Closed Loop Control" IDD Supply Current VIN = VCE = VOUT = 3.6 V, VMODE = 0 V Standby Current VIN = 5.5 V, VCE = 0 V ICEH CE "High" Input Current VIN = VCE = 5.5 V ICEL CE "Low" Input Current IMODEH Min. Typ. Max. Unit 0.591 0.600 0.609 V 4.8 6.0 7.2 MHz µA 15 0 5 µA −1 0 1 µA VIN = 5.5 V, VCE = 0 V −1 0 1 µA MODE "High" Input Current VIN = VMODE = 5.5 V, VCE = 0 V −1 0 1 µA IMODEL MODE "Low" Input Current VIN = 5.5 V, VCE = VMODE = 0 V −1 0 1 µA IVOUTH VOUT "High" Input Current VIN = VOUT = 5.5 V, VCE = 0 V −1 0 1 µA IVOUTL VOUT "Low" Input Current VIN = 5.5 V, VCE = VOUT = 0 V −1 0 1 µA RDISTR Auto-discharge MOSFET On-resistance ( 1) VIN = 3.6 V, VCE = 0 V ILXLEAKH LX "High" Leakage Current VIN = VLX = 5.5 V, VCE = 0 V −1 0 5 µA ILXLEAKL LX "Low" Leakage Current VIN = 5.5 V, VCE = VLX = 0 V −5 0 1 µA VCEH CE "High" Input Voltage VIN = 5.5 V 1.0 VCEL CE "Low" Input Voltage VIN = 2.3 V VMODEH MODE "High" Input Voltage VIN = VCE = 5.5 V VMODEL MODE "Low" Input Voltage VSET ≤ 2.3 V, VIN = VCE = 2.3 V VSET > 2.3 V, VIN = VSET RONP On-resistance of High Side MOSFET VIN = 3.6 V, ILX = −100 mA 0.245 Ω RONN On-resistance of Low Side MOSFET VIN = 3.6 V, ILX = −100 mA 0.225 Ω ISTANDBY Maxduty Maximum Duty Cycle Soft-start Time VIN = VCE = 3.6 V (VSET ≤ 2.6 V), VIN = VCE = VSET + 1 V (VSET > 2.6 V) ILXLIM LX Current Limit VIN = VCE = 3.6 V (VSET ≤ 2.6 V), VIN = VCE = VSET + 1 V (VSET > 2.6 V) VUVLO2 UVLO Threshold Voltage V 0.4 1.0 V V 0.4 V % 100 tSTART VUVLO1 Ω 40 150 300 µs mA 600 1000 VIN = VCE, Falling 1.85 2.00 2.20 V VIN = VCE, Rising 1.90 2.05 2.25 V All test items listed under Electrical Characteristics are done under the pulse load condition (Tj ≈ Ta = 25°C). Test circuit is operated with “Open Loop Control” (GND = 0 V), unless otherwise specified. (1) RM590L002D only 8 RM590L No.EA-592-210906 The specifications surrounded by are guaranteed by Design Engineering at −40°C ≤ Ta ≤ 85°C RM590L series (Fixed Output Voltage Type) Product-specific Electrical Characteristics (Ta = 25°C) Product Name RM590L062x RM590L072x RM590L082x RM590L092x RM590L102x RM590L102x5 RM590L112x RM590L112x5 RM590L122x RM590L132x RM590L142x RM590L152x RM590L162x RM590L172x RM590L182x RM590L192x RM590L202x RM590L212x RM590L222x RM590L232x RM590L242x RM590L252x RM590L262x RM590L272x RM590L282x RM590L292x RM590L302x RM590L312x RM590L322x RM590L332x Min. 0.582 0.682 0.782 0.882 0.982 1.032 1.082 1.132 1.182 1.281 1.379 1.478 1.576 1.675 1.773 1.872 1.970 2.069 2.167 2.266 2.364 2.463 2.561 2.660 2.758 2.857 2.955 3.054 3.152 3.251 VOUT [V] VSET 0.600 0.700 0.800 0.900 1.000 1.050 1.100 1.150 1.200 1.300 1.400 1.500 1.600 1.700 1.800 1.900 2.000 2.100 2.200 2.300 2.400 2.500 2.600 2.700 2.800 2.900 3.000 3.100 3.200 3.300 Max. 0.618 0.718 0.818 0.918 1.018 1.068 1.118 1.168 1.218 1.319 1.421 1.522 1.624 1.725 1.827 1.928 2.030 2.131 2.233 2.334 2.436 2.537 2.639 2.740 2.842 2.943 3.045 3.146 3.248 3.349 9 RM590L No.EA-592-210906 TYPICAL APPLICATION CIRCUIT VIN LX VIN CIN MODE Control VOUT L1 L2 COUT MODE VOUT RM590L CE GND CE Control RM590Lxx2A/B (Fixed Output Voltage Type) VIN LX VIN VOUT L1 L2 R1 CIN MODE Control MODE VFB RM590L CE C1 COUT R2 GND CE Control RM590L002C/D (Adjustable Output Voltage Type) Recommended External Components Symbol CIN COUT Descriptions 4.7 µF and more, Ceramic Capacitor 10 µF, Ceramic Capacitor 10 RM590L No.EA-592-210906 Precautions for the Selection of External Parts Choose a low ESR ceramic capacitor. The capacitance of CIN between VIN and GND should be more than or equal to 4.7 µF. The capacitance of a ceramic capacitor (COUT) should be 10 µF. Also, choose the capacitor with consideration for bias characteristics and input/output voltages. 11 RM590L No.EA-592-210906 OPERATION Chip Enable Function Forcing above designated "High" voltage to CE pin, the RM590L becomes active. Forcing below designated "Low" voltage to CE pin shuts down the RM590L. In shutdown (Standby) condition, all functions are disabled except Auto Discharge function. (Option) With Auto-Discharge option, the MOSFET to discharge the output capacitor turns on and the output is pulled down to GND. Without Auto-Discharge option, the output becomes "Hi-Z". CE pin can accept input range voltage regardless of the input of VIN pin. If Chip Enable function is not necessary, tie CE pin to VIN pin or other designated "High" voltage node at start-up. Soft-start Time Starting-up with CE Pin The IC starts to operate when the CE pin voltage (VCE) exceeds the threshold voltage. The threshold voltage is preset between CE "High" input voltage (VCEH) and CE "Low" input voltage (VCEL). After the start-of the start-up of the IC, soft-start circuit starts to operate. Then, after a certain period of time, the reference voltage (VREF) in the IC gradually increases up to the specified value. Notes: Soft start time (tSTART)( 1) is not always equal to the turn-on speed of the step-down DC/DC module. Please note that the turn-on speed could be affected by the power supply capacity, the output current, the inductance value and the COUT value. CE Pin Input Voltage (VCE) IC Internal Reference Voltage (VREF) LX Voltage (VLX) Output Voltage (VOUT) VCEH Threshold Level VCEL Soft-start Time (tSTART) Soft-start Circuit operation starts. Depending on Power Supply, Load Current, External Components Timing Chart when Starting-up with CE Pin (1) Soft-start time (tSTART) indicates the duration until the reference voltage (VREF) reaches the specified voltage after soft-start circuit’s activation. 12 RM590L No.EA-592-210906 Starting-up with Power Supply After the power-on, when VIN exceeds the UVLO released voltage (VUVLO2), the IC starts to operate. Then, softstart circuit starts to operate and after a certain period of time, VREF gradually increases up to the specified value. Notes: Please note that the turn-on speed of VOUT could be affected by the power supply capacity, the output current, the inductance value, the COUT value and the turn-on speed of VIN determined by CIN. VUVLO2 Input Voltage (VIN) Soft-start Time (tSTART) IC Internal Reference Voltage (VREF) LX Voltage (VLX) VSET Output Voltage (VOUT) Depending on Power Supply, Load Current, External Components Timing Chart when Starting-up with Power Supply Auto Discharge Function When turned off, the Vout voltage drops rapidly to near 0V by discharging the charge stored in the output capacitor through the MOSFET connected between the LX and GND pins. The auto discharge function is enabled when the CE pin = "low" or the thermal shutdown detection or the UVLO detection. On-resistance of MOSFET is Typ. 40Ω. This function may be required to meet the required sequence for electronic components powered by this device. 13 RM590L No.EA-592-210906 Undervoltage Lockout (UVLO) Circuit If VIN becomes lower than VSET, the step-down DC/DC module stops the switching operation and ON duty becomes 100%, and then VOUT gradually drops according to VIN. If the VIN drops more and becomes lower than the UVLO detector threshold (VUVLO1), the UVLO circuit starts to operate, VREF stops, and High Side and Low Side built-in MOSFETs turn "OFF". As a result, VOUT drops according to the COUT capacitance value and the load. To restart the operation, VIN needs to be higher than VUVLO2. The timing chart below shows the voltage shifts of VREF, VLX and VOUT when VIN value is varied. Notes: Falling edge (operating) and rising edge (releasing) waveforms of VOUT could be affected by the initial voltage of COUT and the output current of VOUT. Input Voltage (VIN) VSET VUVLO2 VUVLO1 Soft-start Time (tSTART) IC Internal Reference Voltage (VREF) LX Voltage (VLX) Output Voltage (VOUT) VOUT Depending on Power Supply, Load Current, External Components Timing Chart with Variations in Input Voltage (VIN) 14 RM590L No.EA-592-210906 Current limiting circuit Current limit circuit supervises the inductor peak current (the peak current flowing through High Side MOSFET) in each switching cycle, and if the current exceeds the LX current limit (ILXLIM), it turns off High Side MOSFET ILXLIM of the RM590L is set to Typ.1.0 A. Over Current Protection LX Current Limit (ILXLIM) LX Current High Side MOSFET Current LX Voltage (VLX) Over-Current Protection Operation 15 RM590L No.EA-592-210906 Operation of Step-down DC/DC module and Output Current The step-down DC/DC module charges energy in the inductor when LX MOSFET turns “ON”, and discharges the energy from the inductor when LX MOSFET turns “OFF” and controls with less energy loss, so that a lower output voltage (VOUT) than the input voltage (VIN) can be obtained. The operation of the step-down DC/DC module is explained in the following figures. IL ILMAX i1 VIN High Side MOSFET Low Side MOSFET VOUT L ILMIN tOPEN i1 i2 i2 CL GND tON tOFF T=1/fOSC Basic Circuit Step1. Inductor Current (IL) flowing through Inductor (L) High Side MOSFET turns “ON” and IL (i1) flows, L is charged with energy. At this moment, i1 increases from the minimum inductor current (ILMIN), which is 0 A, and reaches the maximum inductor current (ILMAX) in proportion to the on-time period (tON) of High Side MOSFET. Step2. When High Side MOSFET turns “OFF”, L tries to maintain IL at ILMAX, so L turns Low Side MOSFET “ON” and IL (i2) flows into L. Step3. i2 decreases gradually and reaches ILMIN after the open-time period (tOPEN) of Low Side MOSFET, and then Low Side MOSFET turns “OFF”. This is called discontinuous current mode. As the output current (IOUT) increases, the off-time period (tOFF) of High Side MOSFET runs out before IL reaches ILMIN. The next cycle starts, and High Side MOSFET turns “ON” and Low Side MOSFET turns “OFF”, which means IL starts increasing from ILMIN. This is called continuous current mode. In PWM mode, VOUT is maintained by controlling tON. The oscillator frequency (fOSC) is maintained constant during PWM mode. When the step-down DC/DC operation is constant, ILMIN and ILMAX during tON of High Side MOSFET would be same as during tOFF of High Side MOSFET. The current differential between ILMAX and ILMIN is described as ∆I, as the following equation (1). ∆I = ILMAX − ILMIN = VOUT × tOPEN / 0.5 = (VIN − VOUT) × tON / 0.5 ························································ (1) The above equation is predicated on the following requirements. T = 1 / fOSC = tON + tOFF duty (%) = tON / T × 100 = tON × fOSC × 100 tOPEN ≤ tOFF In Equation 1, “VOUT × tOPEN / 0.5” shows the amount of current change in "OFF" state. Also, “(VIN − VOUT) × tON / L0.5” shows the amount of current change at "ON" state. 16 RM590L No.EA-592-210906 Discontinuous Mode and Continuous Mode As illustrated in Figure A., when IOUT is relatively small, tOPEN < tOFF. In this case, the energy charged into L during tON will be completely discharged during tOFF, as a result, ILMIN = 0. This is called discontinuous mode. When IOUT is gradually increased, eventually tOPEN = tOFF and when IOUT is increased further, eventually ILMIN > 0 as illustrated in Figure B. This is called continuous mode. IL ILMAX IL ILMAX ILMIN ILMIN tOPEN t tON ICONST t tOFF tON T=1/fOSC Figure A. Discontinuous Mode tOFF T=1/fOSC Figure B. Continuous Mode In the continuous mode, the solution of Equation (1) is described as tONC. tONC = T × VOUT / VIN ··············································································································· (2) When tON < tONC, it is discontinuous mode, and when tON = tONC, it is continuous mode. 17 RM590L No.EA-592-210906 Forced PWM Mode and VFM Mode Output voltage controlling method is selectable between a forced PWM control type and a PWM/VFM autoswitching control type, and can be set by the MODE pin. The forced PWM control switches at fixed frequency rate in order to reduce noise in low output current. The PWM/VFM auto-switching control automatically switches from PWM mode to VFM mode in order to achieve high efficiency in low output current. Forced PWM Mode By setting the MODE pin to "High", the IC switches the frequency at the fixed rate to reduce noise even when the output load is light. Therefore, when IOUT is ∆IL/2 or less, ILMIN becomes less than “0”. That is, the accumulated electricity in CL is discharged through the IC side while IL is increasing from ILMIN to “0” during tON, and also while IL is decreasing from “0” to ILMIN during tOFF. VFM Mode By setting the MODE pin to "Low", in low output current, the IC automatically switches into VFM mode in order to achieve high efficiency. In VFM mode, tON is determined depending on VIN and VOUT. ILMAX IL ILMAX IL ΔIL IOUT 0 0 ILMIN ILMIN t tON tOFF t tON tOFF T=1/fOSC Forced PWM Mode VFM Mode 18 RM590L No.EA-592-210906 Thermal Shutdown Function When the junction temperature exceeds the thermal shutdown detection temperature (Typ. 140°C), this IC cuts off the output and suppresses the self-heating. When the junction temperature falls below the thermal shutdown release temperature (Typ. 100°C), this IC will restart with the soft start operation. Thermal Shutdown Release Detect Release Soft-start Time (tSTART) Reference Voltage (VREF) Lx Voltage (VLX) Output Voltage (VOUT) tSTARTUP_delay 19 RM590L No.EA-592-210906 TECHNICAL NOTES The performance of a power source circuit using this device is highly dependent on a peripheral circuit. A peripheral component or the device mounted on PCB should not exceed its rated voltage, rated current or rated power. When designing a peripheral circuit, please be fully aware of the following points. • Set the external components as close as possible to the IC and minimize the wiring between the components and the IC. Especially, place a capacitor (CIN) as close as possible to the VIN pin and GND. • Ensure the VIN and GND lines are sufficiently robust. If their impedance is too high, noise pickup or unstable operation may result. • A large switching current flows through the VIN line, GND line, VOUT line, inductor, LX, L1 and L2. Make the wirings short and wide. • For any setting type of output voltage, the input/output voltage ratio must meet the following requirement to achieve a stable VFM mode at light load when the MODE pin is "Low" (at PWM/VFM Auto Switching) : VOUT / VIN < 0.7 VMODE = "Low", PWM / VFM Auto Switching Input Voltage VIN (V) 5.5 Adjustable Output 4.7 Fixed Output Voltage Type Voltage Type 3.9 3.1 2.3 0.6 1.2 1.8 2.4 3.0 3.6 4.2 Output Voltage VOUT (V) Available Voltage Area with Stable VFM Mode • The thermal shutdown function is to prevent smoke and ignition of the IC, not to ensure the reliability of the IC or to keep it below the absolute maximum rating. In addition, it is not effective against heat generated when the IC is not operating normally, such as latch-up and overvoltage application. • Do not design with depending on the thermal shutdown function of this IC as the system protection. The thermal shutdown function is designed for this IC. • ESD Control Take appropriate precautions when handling this product or PCB included this product. Ex. ・ Use of an antistatic wrist band ・ Use of an ionizer 20 RM590L No.EA-592-210906 APPLICATION INFORMATION Adjustable Output Voltage Setting (RM590L002C/D) By connecting divider resistors (R1, R2) to the VFB pin, the set output voltage (VSET) can be set using the following equation. VSET = VFB × (R1 + R2) / R2 The reference voltage (VFB) of this IC is set to 0.6 V, and the accuracy of VFB and the output voltage setting range are as follows. VSET: 0.6V ≤ VSET ≤ 5.5 V VFB : 0.6 V ± 9mV Refer to the following table for the recommended values for R1, R2 and C1. Set Output Voltage (VSET) vs. R1 / R2 / C1 (Adjustable Output Voltage Type) VSET [V] R1 [kΩ] R2 [kΩ] 0. 6 0 220 0. 6 < VSET ≤ 0 .9 220 0. 9 < VSET ≤ 1 .8 220 1. 8 < VSET ≤ 2 .1 150 2. 1 < VSET ≤ 2 .4 R1 = (VSET / VFB -1) x R2 100 2. 4 < VSET ≤ 2 .7 68 2. 7 < VSET ≤ 3 .0 47 3. 0 < VSET ≤ VIN 47 C1 [pF] Open 47 33 10 10 10 10 6.8 21 RM590L No.EA-592-210906 PCB Layout RM590L (QFN2220-8) Board Diagram Top Layer Bottom Layer 22 RM590L No.EA-592-210906 TYPICAL CHARACTERISTICS Note: Typical Characteristics are intended to be used as reference data; they are not guaranteed. 1) Efficiency vs. Output Current VOUT=0.9V VOUT=1.2V 100 100 90 90 VFM / PWM Auto 70 70 60 60 50 VIN"2.7V" = 2.7V VIN"3.6V" = 3.6V VIN"4.2V" = 4.2V VIN"5.0V" = 5.0V 40 30 20 VFM / PWM Auto 80 Efficiency η [%] Efficiency η [%] 80 Forced PWM VIN = 3.6V 10 VIN == 2.7V VIN 2.7V VIN == 3.6V VIN 3.6V VIN == 4.2V VIN 4.2V VIN == 5.0V VIN 5.0V 50 40 30 20 10 0 0.01 0.1 1 10 100 0 0.01 1000 0.1 Output Current IOUT [mA] 1000 100 90 VFM / PWM Auto 80 80 70 70 60 Forced PWM VIN = 3.6V VIN ==2.7V VIN 2.7V VIN ==3.6V VIN 3.6V VIN ==4.2V VIN 4.2V VIN ==5.0V VIN 5.0V 50 40 30 20 Efficiency η [%] Efficiency η [%] 100 10 VOUT=3.3V 100 10 VFM / PWM Auto Forced PWM VIN = 4.2V 60 VIN VIN = 4.2V VIN = 5.0V VIN 50 40 30 20 10 0 0.01 0.1 1 10 100 0 0.01 1000 2) Output Voltage vs. Output Current VIN=3.6V, VOUT=1.8V MODE = "H" Forced PWM Mode 1.82 1.82 Output Voltage VOUT [V] 1.83 1.81 1.80 1.79 1.78 1.77 100 200 300 Output Current IOUT [mA] 1 10 100 1000 VIN=3.6V, VOUT=1.8V MODE = "L" PWM/VFM Auto Switching 1.83 0 0.1 Output Current IOUT [mA] Output Current IOUT [mA] Output Voltage VOUT [V] 1 Output Current IOUT [mA] VOUT=1.8V 90 Forced PWM VIN = 3.6V 400 1.81 1.80 1.79 1.78 1.77 0 100 200 300 400 Output Current IOUT [mA] 23 RM590L No.EA-592-210906 3) Oscillator Frequency vs. Input Voltage IOUT=1mA MODE = "H" Forced PWM Mode IOUT=1mA MODE = "L" PWM/VFM Auto Switching 7 200 Frequency fosc [kHz] Frequency fosc [MHz] 5 4 3 2 VOUT = 0.9V V OUT = 0.9V V VOUT 1.2V OUT ==1.2V V VOUT 1.8V OUT ==1.8V V OUT ==3.3V VOUT 3.3V 1 VOUT ==1.2V 1.2V VOUT 160 VOUT ==1.8V 1.8V VOUT 140 VOUT ==3.3V 3.3V VOUT 120 100 80 60 40 20 0 0 2.0 2.5 3.0 3.5 4.0 4.5 Input Voltage VIN [V] 5.0 5.5 IOUT=200mA MODE = "H" Forced PWM Mode 2.0 2.5 3.0 5.0 5.5 5.0 5.5 Frequency fosc [MHz] 7 6 5 4 3 2 6 5 4 3 2 VOUT 0.9V V OUT ==0.9V V VOUT 1.2V OUT ==1.2V V VOUT 1.8V OUT ==1.8V V VOUT 3.3V OUT ==3.3V 1 VOUT == 0.9V VOUT 0.9V VOUT == 1.2V VOUT 1.2V VOUT == 1.8V VOUT 1.8V VOUT == 3.3V VOUT 3.3V 1 0 0 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 2.0 2.5 3.0 Input Voltage VIN [V] 3.5 4.0 4.5 Input Voltage VIN [V] 4) Ripple Voltage vs. Input Voltage VIN=3.6V, VOUT=1.8V MODE = "H" Forced PWM Mode VIN=3.6V, VOUT=1.8V MODE = "L" PWM/VFM Auto Switching 50 50 45 45 IIout 1mA OUT ==1mA IIout 400mA OUT ==400mA 40 35 Output Voltage Vripple [mV] Output Voltage Vripple [mV] 3.5 4.0 4.5 Input Voltage VIN [V] IOUT=200mA MODE = "L" PWM/VFM Auto Switching 7 Frequency fosc [MHz] VOUT 0.9V VOUT ==0.9V 180 6 30 25 20 15 10 5 0 2 3 4 Input Voltage VIN [V] 5 6 Iout IOUT = = 1mA IOUT = 400mA Iout 40 35 30 25 20 15 10 5 0 2 3 4 5 6 Input Voltage VIN [V] 24 RM590L No.EA-592-210906 VIN=3.6V, VOUT=1.8V, IOUT=1mA MODE = "L" PWM/VFM Auto Switching 1.85 1.85 1.84 1.84 1.83 1.83 Output Voltage VOUT [V] Output Voltage VOUT [V] 5) Output Voltage Waveform VIN=3.6V, VOUT=1.8V, IOUT=1mA MODE = "H" Forced PWM Mode 1.82 1.81 1.80 1.79 1.78 1.77 1.76 1.82 1.81 1.80 1.79 1.78 1.77 1.76 1.75 0.0 0.5 1.0 1.5 1.75 2.0 0 Time t [ms] 100 150 200 Time t [μs] VIN=3.6V, VOUT=1.8V, IOUT=400mA MODE = "H" Forced PWM Mode VIN=3.6V, VOUT=1.8V, IOUT=400mA MODE = "L" PWM/VFM Auto Switching 1.85 1.85 1.84 1.84 1.83 1.83 Output Voltage VOUT [V] Output Voltage VOUT [V] 50 1.82 1.81 1.80 1.79 1.78 1.77 1.76 1.82 1.81 1.80 1.79 1.78 1.77 1.76 1.75 0.0 0.5 1.0 1.5 2.0 Time t [ms] 6) Ripple Voltage vs. Output Current VIN=3.6V, VOUT=1.8V MODE = "L" PWM/VFM Auto Switching, MODE = "H" Forced PWM Mode 1.75 0.0 0.5 1.0 1.5 2.0 Time t [ms] 50 Output Voltage Vripple [mV] 45 Forced PWM 40 AUTO 35 30 25 20 15 10 5 0 0 50 100 150 200 250 300 350 400 Output Current IOUT [mA] 25 RM590L No.EA-592-210906 7) Load Transient Response Waveform VIN=3.6V, VOUT=1.8V, IOUT=1mA->200mA MODE = "H" Forced PWM Mode 1.9 0 1.8 Output Voltage 1.7 100 Output Current 0 1.9 1.8 Output Voltage 1.7 1.6 1.6 100 200 300 0 400 100 Time t [μs] 400 100 1.9 0 1.8 Output Voltage 300 200 Output Voltage VOUT [V] 200 Output Current Output Current IOUT [mA] VIN=3.6V, VOUT=1.8V, IOUT=200mA->1mA MODE = "L" PWM/VFM Auto Switching 300 Output Voltage VOUT [V] 300 Time t [μs] VIN=3.6V, VOUT=1.8V, IOUT=1mA->200mA MODE = "L" PWM/VFM Auto Switching 1.7 200 1.6 100 Output Current 1.9 0 1.8 Output Current IOUT [mA] 0 Output Voltage 1.7 1.6 0 100 200 300 400 0 200 Time t [μs] 2 1.9 0 1.8 Output Voltage 1.6 100 200 Time t [μs] 800 1000 300 400 6 4 Output Voltage VOUT [V] MODE pin Voltage MODE Pin Voltage [V] 4 0 600 MODE = "H" -> "L" 6 1.7 400 Time t [μs] 8) Mode Switching Waveform VIN=3.6V, VOUT=1.8V, IOUT=1mA MODE = "L" -> "H" Output Voltage VOUT [V] Output Current IOUT [mA] 100 200 2 MODE pin Voltage 1.9 0 MODE Pin Voltage [V] Output Voltage VOUT [V] 200 Output Current 300 Output Voltage VOUT [V] 300 Output Current IOUT [mA] VIN=3.6V, VOUT=1.8V, IOUT=200mA->1mA MODE = "H" Forced PWM Mode 1.8 Output Voltage 1.7 1.6 0 200 400 600 800 1000 Time t [μs] 26 RM590L No.EA-592-210906 Test Circuit VIN LX VIN CIN MODE Control VOUT L1 L2 COUT MODE VOUT RM590L CE GND CE Control RM590Lxx2A/B (Fixed Output Voltage Type) VIN LX VIN VOUT L1 L2 R1 CIN MODE Control MODE VFB RM590L CE C1 COUT R2 GND CE Control RM590L002C/D (Adjustable Output Voltage Type) Components list for our evaluation Symbol Specification Maximum Ratings Model CIN 4.7µF 6.3V C1005X5R0J475M050BC COUT 10uF 6.3V GRM155R60J106ME44D 27 POWER DISSIPATION QFN2220-8 PD-QFN2220-8(85125)-JE-A The power dissipation of the package is dependent on PCB material, layout, and environmental conditions. The following measurement conditions are based on JEDEC STD. 51. Measurement Conditions Item Measurement Conditions Environment Mounting on Board (Wind Velocity = 0 m/s) Board Material Glass Cloth Epoxy Plastic (Four-Layer Board) Board Dimensions 76.2 mm × 114.3 mm × 1.6 mm Copper Ratio Outer Layer (First Layer): More than 90% of 74.2 mm Square Inner Layers (Second and Third Layers): Approx. 100% of 74.2 mm Square Outer Layer (Fourth Layer): More than 90% of 74.2 mm Square Through-holes φ 0.3 mm × 4 pcs Measurement Result (Ta = 25°C, Tjmax = 125°C) Item Measurement Result Power Dissipation 880 mW Thermal Resistance (θja) θja = 113°C/W Thermal Characterization Parameter (ψjt) ψjt = 55°C/W θja: Junction-to-Ambient Thermal Resistance ψjt: Junction-to-Top Thermal Characterization Parameter 76.2 74.2 1000 880 900 700 74.2 600 500 114.3 Power Dissipation (mW) 800 400 300 200 100 0 0 25 50 75 85 Ambient Temperature (°C) 100 Power Dissipation vs. Ambient Temperature 125 Measurement Board Pattern i PACKAGE DIMENSIONS QFN2220-8 DM-QFN2220-8-JE-A QFN2220-8 Package Dimensions * i 1. The products and the product specifications described in this document are subject to change or discontinuation of production without notice for reasons such as improvement. Therefore, before deciding to use the products, please refer to our sales representatives for the latest information thereon. 2. The materials in this document may not be copied or otherwise reproduced in whole or in part without prior written consent of our company. 3. Please be sure to take any necessary formalities under relevant laws or regulations before exporting or otherwise taking out of your country the products or the technical information described herein. 4. The technical information described in this document shows typical characteristics of and example application circuits for the products. The release of such information is not to be construed as a warranty of or a grant of license under our company's or any third party's intellectual property rights or any other rights. 5. The products listed in this document are intended and designed for use as general electronic components in standard applications (office equipment, telecommunication equipment, measuring instruments, consumer electronic products, amusement equipment etc.). Those customers intending to use a product in an application requiring extreme quality and reliability, for example, in a highly specific application where the failure or misoperation of the product could result in human injury or death (aircraft, spacevehicle, nuclear reactor control system, traffic control system, automotive and transportation equipment, combustion equipment, safety devices, life support system etc.) should first contact us. 6. We are making our continuous effort to improve the quality and reliability of our products, but semiconductor products are likely to fail with certain probability. In order to prevent any injury to persons or damages to property resulting from such failure, customers should be careful enough to incorporate safety measures in their design, such as redundancy feature, fire containment feature and fail-safe feature. We do not assume any liability or responsibility for any loss or damage arising from misuse or inappropriate use of the products. 7. Anti-radiation design is not implemented in the products described in this document. 8. The X-ray exposure can influence functions and characteristics of the products. Confirm the product functions and characteristics in the evaluation stage. 9. WLCSP products should be used in light shielded environments. The light exposure can influence functions and characteristics of the products under operation or storage. 10. There can be variation in the marking when different AOI (Automated Optical Inspection) equipment is used. In the case of recognizing the marking characteristic with AOI, please contact our sales or our distributor before attempting to use AOI. 11. Please contact our sales representatives should you have any questions or comments concerning the products or the technical information. Official website https://www.nisshinbo-microdevices.co.jp/en/ Purchase information https://www.nisshinbo-microdevices.co.jp/en/buy/
RM590L152B-TR 价格&库存
很抱歉,暂时无法提供与“RM590L152B-TR”相匹配的价格&库存,您可以联系我们找货
