50CE47LX
50CE47LX
    SUNCON
50CE47LX 数据手册
Aluminum Electrolytic Type / Surface Mount Type CE-LX Aluminum Electrolytic Capacitors Surface Mount Type CE-LD CE-FSS CE-FS(High Voltage) Long Life Low Impedance Series 105℃ 2,000 to 5,000hours Solvent proof (within 2 minutes) ● AEC-Q200 ■ Specifications ● ● Items Condition Specifications Rated voltage (V) − 6.3 10 16 25 35 50 63 80 100 Surge voltage (V) Room temperature 8.0 13 20 32 44 63 79 100 125 Category temperature range (℃) − Capacitance tolerance (%) 120Hz/20℃ Dissipation Factor(tan δ) tanδ (max.) 120Hz/20℃ −55 to +105 M : ±20 φ4 to φ6.3 0.26 0.20 φ8 to φ18 0.28 0.24 CE-ZX CE-ZC Leakage current (LC) μA/after 2minutes (max.), 20℃ Impedance ratio at Iow temperature Based on the value at −40℃ Z/Z20℃ 120Hz, +20℃ −55℃ Z/Z20℃ Endurance 105℃ rated voltage applied (With the rated ripple current) CE-LX CE-GA CE-LS CE-LH 0.16 0.14 0.12 0.12 0.08 ー ー 0.22 0.16 0.14 0.14 0.08 0.08 0.07 Exceeding 1,000μF, +0.02 every 1,000μF CE-FS CE-AX RoHS compliance The greater value of either 0.01CV or 3 3 3 3 3 3 3 2 2 2 4 4 4 3 3 3 3 3 3 Test CE-LH(High Voltage) φ4 to φ6.3 : 2,000hours, φ8 to φ18 : 5,000hours △C/C Within ±30% of the initial value tanδ Less than 300% of the specified value LC Less than the specified value CE-LL CE-LF CE-PH ■ Marking, Dimensions CE-PS [ φD≤10 ] CE-FN Lot No. Rated Capacitance Series Symbol Rated Voltage(6.3V→6) L [ φD≥12.5 ] Polarity (Cathode) Lot No. Indicated φD=16, 18 2DT 3300 16 L C CE-JX 2D 470 16 L W H CE-TH 0.3max. Polarity (Cathode) φD CE-PF (Unit : mm) D±0.5 (P) CE-PC R (+) A pressure relief vent is provided for φD=8 or bigger Rated Capacitance (P)reference size Series Symbol Rated Voltage(6.3V→6) ■ Part number LX W±0.2 H±0.2 C±0.2 R P 4 6.0 4.3 4.3 5.0 0.5 to 0.8 1.0 5 6.0 5.3 5.3 6.0 0.5 to 0.8 1.4 6.3 6.0 6.6 6.6 7.3 0.5 to 0.8 2.2 6.3 7.7 6.6 6.6 7.3 0.5 to 0.8 2.2 8 10.2 8.3 8.3 9.0 0.7 to 1.0 3.2 10 10.2 10.3 10.3 11.0 1.0 to 1.4 4.6 10 13.5±0.5 10.3 10.3 11.0 1.0 to 1.4 4.6 12.5 13.5±0.5 12.8 12.8 13.5 1.0 to 1.4 4.6 16 16.5±0.5 16.3 16.3 17.3 1.7 to 2.1 7.0 18 16.5±1.0 19.0 19.0 20.0 1.7 to 2.1 7.0 18 21.5±1.0 19.0 19.0 20.0 1.7 to 2.1 7.0 LXS 16 CE 470 LX 35 CE 100 LXS Series symbol Rated capacitance Type symbol Rated voltage LXC Series symbol Rated capacitance Type symbol Rated voltage LXT 35 CE 470 LXC 16 CE 3300 LX T Series symbol Rated capacitance Type symbol Rated voltage 48 L±0.3 Sn plating terminal option Series symbol Rated capacitance Type symbol Rated voltage Aluminum Electrolytic Type / Surface Mount Type RoHS compliance ■ Size, Impedance, Rated Ripple Current V μF 6.3 10 16 25 35 90 90 5×6.0 0.70 170 4×6.0 1.45 90 5×6.0 0.70 170 5×6.0 0.70 170 4×6.0 1.45 90 5×6.0 0.70 170 5×6.0 0.70 170 5×6.0 0.70 170 15 22 27 4×6.0 1.45 90 5×6.0 0.70 170 5×6.0 0.70 170 6.3×6.0 0.39 250 6.3×6.0 0.39 250 33 5×6.0 0.70 170 5×6.0 0.70 170 6.3×6.0 0.39 250 6.3×6.0 0.39 250 6.3×6.0 0.39 250 47 5×6.0 0.70 170 6.3×6.0 0.39 250 6.3×6.0 0.39 250 6.3×6.0 0.39 250 6.3×6.0 0.39 250 56 5×6.0 0.70 170 6.3×6.0 0.39 250 6.3×6.0 0.39 250 6.3×6.0 0.39 250 6.3×7.7 0.30 300 68 6.3×6.0 0.39 250 6.3×6.0 0.39 250 6.3×6.0 0.39 250 6.3×6.0 0.39 250 6.3×7.7 0.30 300 5×6.0 ★1 0.70 170 6.3×7.7 ★1 0.30 300 100 6.3×6.0 0.39 250 6.3×6.0 0.39 250 6.3×6.0 0.39 250 150 6.3×6.0 0.39 250 6.3×6.0 0.39 250 6.3×7.7 0.30 300 220 6.3×6.0 0.39 250 6.3×7.7 0.30 300 6.3×7.7 0.30 330 6.3×7.7 0.30 300 8×10.2 0.17 600 8×10.2 0.17 600 8×10.2 0.17 600 8×10.2 8×10.2 470 0.30 300 8×10.2 0.17 600 8×10.2 0.17 600 8×10.2 0.17 600 CE-LD 300 8×10.2 0.17 600 8×10.2 0.17 600 CE-FSS 0.17 600 8×10.2 0.17 600 10×10.2 0.090 850 CE-FS(High Voltage) 0.17 600 10×10.2 0.090 850 10×13.5 ★2 0.070 950 CE-FS 0.060 1100 CE-AX 6.3×7.7 12.5×13.5 8×10.2 680 0.17 600 10×10.2 0.090 850 10×10.2 0.090 850 10×13.5 ★2 0.070 950 10×13.5 ★2 0.070 12.5×13.5 1000 8×10.2 0.17 600 10×10.2 0.090 10×13.5 ★2 0.070 1500 10×10.2 12.5×13.5 2200 0.090 850 12.5×13.5 0.060 1100 12.5×13.5 850 12.5×13.5 0.060 1100 12.5×13.5 0.060 1100 0.060 1100 0.035 1800 16×16.5 0.060 1100 12.5×13.5 0.060 1100 0.060 1100 0.035 1800 3900 0.035 1800 5600 CE-GA CE-LS 16×16.5 16×16.5 CE-ZC CE-LX 0.060 1100 12.5×13.5 16×16.5 0.035 1800 16×16.5 0.035 1800 CE-LH 16×16.5 0.035 1800 18×16.5 0.033 2060 CE-LH(High Voltage) 18×21.5 0.028 2260 CE-LL 18×16.5 0.033 2060 CE-LF 18×21.5 0.028 2260 CE-PC 2700 4700 CE-ZX 950 950 3300 18×16.5 0.033 2060 CE-PH 18×21.5 0.028 2260 CE-PS 6800 16×16.5 0.035 1800 18×16.5 0.033 2060 CE-PF 18×21.5 0.028 2260 CE-TH 8200 18×16.5 0.033 2060 10000 18×16.5 0.033 2060 CE-JX 12000 18×21.5 0.028 2260 CE-FN V μF 50 63 80 4×6.0 2.90 60 10 6.3×6.0 0.88 165 6.3×6.0 1.50 80 22 6.3×6.0 0.88 165 6.3×7.7 1.20 120 27 6.3×7.7 0.68 195 33 6.3×7.7 0.68 195 47 6.3×7.7 0.68 195 4.7 100 10×10.2 0.65 200 10×10.2 0.65 200 12.5×13.5 0.32 500 56 8×10.2 0.34 350 68 8×10.2 0.34 350 12.5×13.5 0.32 500 100 8×10.2 0.34 350 12.5×13.5 0.16 800 12.5×13.5 0.32 500 16×16.5 0.17 793 150 10×10.2 0.18 670 12.5×13.5 0.16 800 12.5×13.5 0.32 500 16×16.5 0.17 793 220 10×10.2 0.18 670 12.5×13.5 0.16 800 18×16.5 0.153 917 330 12.5×13.5 0.12 900 16×16.5 0.082 1410 16×16.5 0.17 793 18×21.5 0.083 1230 470 16×16.5 0.073 1610 16×16.5 0.082 1410 18×16.5 0.153 917 680 16×16.5 0.073 1610 18×16.5 0.080 1690 1000 16×16.5 0.073 1610 18×21.5 0.055 1960 1200 18×16.5 0.068 1900 1500 18×21.5 0.042 2180 Please refer to page 14 for ripple current frequency coefficients. ★1 LXS ★2 LXC Surface Mount Type 1.45 1.45 Aluminum Electrolytic Capacitors 10 4×6.0 4×6.0 4.7 Case size:φDxL(mm) φ16, φ18:CE-LXT Impedance(Ω) max. at 100kHz, 20℃ Rated ripple current mArms(100kHz, 105℃) 49
50CE47LX 价格&库存
很抱歉,暂时无法提供与“50CE47LX”相匹配的价格&库存,您可以联系我们找货
